"Ready" - but doesnt download
OlMi1
Post by OlMi1 »
Hey,
I have this error since I downloaded F@H in April. How do I get an Assignment ID?
Log:
16:16:58:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:16:58:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:17:28:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen (Translation: A recent connection with the Remotehost was closed).
Thanks
Re: "Ready" - but doesnt download
Post by Neil-B »
Please could you post a bit more of your log making sure to include the top 100 lines or so of the log that has the system configuration in it and a longer cut from the tail 100 lines or so ... This will help people diagnose the issue.
OlMi1
Post by OlMi1 »
Neil-B wrote:Please could you post a bit more of your log making sure to include the top 100 lines or so of the log that has the system configuration in it and a longer cut from the tail 100 lines or so ... This will help people diagnose the issue.
Log:
*********************** Log Started 2020-05-15T16:00:35Z ***********************
16:00:35:Trying to access database...
16:00:35:Successfully acquired database lock
16:00:35:Read GPUs.txt
16:00:35:Downloading GPUs.txt from assign1.foldingathome.org:80
16:00:35:Connecting to assign1.foldingathome.org:80
16:00:35:Enabled folding slot 00: READY cpu:12
16:00:36:****************************** FAHClient ******************************
16:00:36:        Version: 7.6.13
16:00:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:00:36:      Copyright: 2020 foldingathome.org
16:00:36:       Homepage: https://foldingathome.org/
16:00:36:           Date: Apr 27 2020
16:00:36:           Time: 21:21:01
16:00:36:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
16:00:36:         Branch: master
16:00:36:       Compiler: Visual C++ 2008
16:00:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:00:36:       Platform: win32 10
16:00:36:           Bits: 32
16:00:36:           Mode: Release
16:00:36:           Args: --open-web-control
16:00:36:         Config: F:\Programme\foldingathome\config.xml
16:00:36:******************************** CBang ********************************
16:00:36:           Date: Apr 24 2020
16:00:36:           Time: 17:07:55
16:00:36:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
16:00:36:           Bits: 32
16:00:36:******************************* System ********************************
16:00:36:            CPU: AMD Ryzen 5 2600X Six-Core Processor
16:00:36:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:00:36:           CPUs: 12
16:00:36:         Memory: 15.96GiB
16:00:36:    Free Memory: 3.17GiB
16:00:36:        Threads: WINDOWS_THREADS
16:00:36:     OS Version: 6.2
16:00:36:    Has Battery: false
16:00:36:     On Battery: false
16:00:36:     UTC Offset: 2
16:00:36:            PID: 21204
16:00:36:            CWD: F:\Programme\foldingathome
16:00:36:  Win32 Service: false
16:00:36:             OS: Windows 10 Enterprise
16:00:36:        OS Arch: AMD64
16:00:36:           GPUs: 0
16:00:36:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
16:00:36:                 angegebene Modul wurde nicht gefunden.
16:00:36:
16:00:36:OpenCL Device 0: Platform:0 Device:0 Bus:37 Slot:0 Compute:1.2 Driver:3004.7
16:00:36:******************************* libFAH ********************************
16:00:36:           Date: Apr 15 2020
16:00:36:           Time: 14:53:14
16:00:36:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:00:36:           Bits: 32
16:00:36:***********************************************************************
16:00:36:<config>
16:00:36:  <!-- Folding Slot Configuration -->
16:00:36:  <cause v='ALZHEIMERS'/>
16:00:36:
16:00:36:  <!-- Slot Control -->
16:00:36:  <power v='FULL'/>
16:00:36:
16:00:36:  <!-- User Information -->
16:00:36:  <team v='223518'/>
16:00:36:  <user v='OlMi1_YT'/>
16:00:36:
16:00:36:  <!-- Folding Slots -->
16:00:36:  <slot id='0' type='CPU'/>
16:00:36:</config>
16:00:36:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:00:37:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:37:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:00:37:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:37:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:00:37:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:37:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:00:37:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:37:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:00:38:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:00:38:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:38:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:00:38:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:38:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:00:38:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:38:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:00:38:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:00:38:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:00:39:9:127.0.0.1:New Web session
16:01:36:Saving configuration to config.xml
16:01:36:<config>
16:01:36:  <!-- Folding Slot Configuration -->
16:01:36:  <cause v='COVID_19'/>
16:01:36:
16:01:36:  <!-- Slot Control -->
16:01:36:  <power v='FULL'/>
16:01:36:
16:01:36:  <!-- User Information -->
16:01:36:  <team v='223518'/>
16:01:36:  <user v='OlMi1_YT'/>
16:01:36:
16:01:36:  <!-- Folding Slots -->
16:01:36:  <slot id='0' type='CPU'/>
16:01:36:</config>
16:01:38:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:01:38:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:01:38:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:01:38:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:01:38:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:01:38:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:01:38:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:01:38:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:01:38:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:03:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:03:15:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:03:15:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:03:15:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:03:15:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:03:15:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:03:15:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:03:16:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:03:16:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:05:52:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:05:52:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:05:52:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:05:53:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:05:53:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:05:53:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:05:53:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:05:53:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:05:53:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:10:06:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:10:07:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:10:07:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:10:07:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:10:07:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:10:07:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:10:07:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:10:07:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:10:07:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:11:00:25:127.0.0.1:New Web session
16:16:58:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:16:58:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:16:58:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:16:58:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:16:58:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:16:58:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:16:58:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:17:28:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:28:03:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:28:03:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:28:03:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:28:04:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:28:04:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:28:04:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:28:04:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:28:04:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:28:04:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:31:46:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:32:06:Saving configuration to config.xml
16:32:06:<config>
16:32:06:  <!-- Folding Slot Configuration -->
16:32:06:  <cause v='COVID_19'/>
16:32:06:
16:32:06:  <!-- Network -->
16:32:06:  <proxy v=':8080'/>
16:32:06:
16:32:06:  <!-- Slot Control -->
16:32:06:  <power v='FULL'/>
16:32:06:
16:32:06:  <!-- User Information -->
16:32:06:  <team v='251999'/>
16:32:06:  <user v='OlMi1_YT'/>
16:32:06:
16:32:06:  <!-- Folding Slots -->
16:32:06:  <slot id='0' type='CPU'/>
16:32:06:</config>
16:32:33:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:32:36:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:33:51:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:33:51:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:33:51:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:33:51:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:33:51:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:33:51:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:33:51:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:33:51:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:33:51:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:34:01:FS00:Paused
16:34:03:FS00:Unpaused
16:34:51:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:34:51:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:34:51:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:34:51:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:34:51:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:34:52:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:34:52:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:34:52:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:34:52:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:36:28:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:36:28:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:36:28:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:36:28:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:36:28:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:36:28:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:36:28:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:36:29:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:36:29:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:37:44:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:39:05:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:39:05:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:39:05:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:39:06:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:39:06:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:39:06:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:39:06:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:39:06:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:39:06:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:41:35:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
16:43:19:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:43:20:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:43:20:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:43:20:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:43:20:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:43:20:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:43:20:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:43:20:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:43:20:ERROR:WU00:FS00:Exception: Could not get an assignment ID
16:50:11:WU00:FS00:Connecting to assign1.foldingathome.org:80
16:50:11:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:50:11:WU00:FS00:Connecting to assign2.foldingathome.org:80
16:50:11:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:50:11:WU00:FS00:Connecting to assign3.foldingathome.org:80
16:50:12:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:50:12:WU00:FS00:Connecting to assign4.foldingathome.org:80
16:50:12:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
16:50:12:ERROR:WU00:FS00:Exception: Could not get an assignment ID
17:01:16:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:01:17:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:01:17:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:01:17:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:01:17:WU00:FS00:Connecting to assign3.foldingathome.org:80
17:01:17:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:01:17:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:01:17:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:01:17:ERROR:WU00:FS00:Exception: Could not get an assignment ID
17:19:13:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:19:14:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:19:14:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:19:14:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:19:14:WU00:FS00:Connecting to assign3.foldingathome.org:80
17:19:14:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:19:14:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:19:14:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:19:14:ERROR:WU00:FS00:Exception: Could not get an assignment ID
17:48:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
17:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:48:16:WU00:FS00:Connecting to assign2.foldingathome.org:80
17:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:48:16:WU00:FS00:Connecting to assign3.foldingathome.org:80
17:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:48:16:WU00:FS00:Connecting to assign4.foldingathome.org:80
17:48:16:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': 10001: Server responded: HTTP_NOT_FOUND
17:48:16:ERROR:WU00:FS00:Exception: Could not get an assignment ID
Post by Neil-B »
My gut feeling is that there is a comms issue - something like a firewall causing an issue here or some form of routing issue ... but it really needs one of the more technical forum contributors to give you proper advice rather just my guess ... hope someone gets it sorted for you :)
Does it happen all the time or just intermittently?
Welcome to the F@H Forum OlMi1,
Please note that you will not be able to contribute unless you can successfully get the assignment ID from the Server. It seems to be a connectivity issue at your end. Please review this topic to get some pointers on how to troubleshoot: viewtopic.php?f=18&t=17794
