07:43:54:WU00:FS01:Connecting to 18.188.125.154:8080
07:43:55:WU00:FS01:Downloading 5.99MiB
07:43:58:WU00:FS01:Download complete
07:43:58:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13405 run:360 clone:26 gen:3 core:0x22 unit:0x0000000c12bc7d9a5eb3a383d6d2551b
07:44:53:WU00:FS01:Starting
07:44:53:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\XXXXXX\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10352 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:44:53:WU00:FS01:Started FahCore on PID 10600
07:44:53:WU00:FS01:Core PID:1896
07:44:53:WU00:FS01:FahCore 0x22 started
07:44:53:WU00:FS01:0x22:*********************** Log Started 2020-05-15T07:44:53Z ***********************
07:44:53:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:44:53:WU00:FS01:0x22: Type: 0x22
07:44:53:WU00:FS01:0x22: Core: Core22
07:44:53:WU00:FS01:0x22: Website: https://foldingathome.org/
07:44:53:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
07:44:53:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:44:53:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
07:44:53:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 10600 -checkpoint 15
07:44:53:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:44:53:WU00:FS01:0x22: 0 -gpu 0
07:44:53:WU00:FS01:0x22: Config: <none>
07:44:53:WU00:FS01:0x22:************************************ Build *************************************
07:44:53:WU00:FS01:0x22: Version: 0.0.5
07:44:53:WU00:FS01:0x22: Date: Apr 22 2020
07:44:53:WU00:FS01:0x22: Time: 04:42:59
07:44:53:WU00:FS01:0x22: Repository: Git
07:44:53:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
07:44:53:WU00:FS01:0x22: Branch: HEAD
07:44:53:WU00:FS01:0x22: Compiler: Visual C++ 2008
07:44:53:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:44:53:WU00:FS01:0x22: Platform: win32 10
07:44:53:WU00:FS01:0x22: Bits: 64
07:44:53:WU00:FS01:0x22: Mode: Release
07:44:53:WU00:FS01:0x22:************************************ System ************************************
07:44:53:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
07:44:53:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
07:44:53:WU00:FS01:0x22: CPUs: 8
07:44:53:WU00:FS01:0x22: Memory: 31.94GiB
07:44:53:WU00:FS01:0x22:Free Memory: 25.51GiB
07:44:53:WU00:FS01:0x22: Threads: WINDOWS_THREADS
07:44:53:WU00:FS01:0x22: OS Version: 6.2
07:44:53:WU00:FS01:0x22:Has Battery: false
07:44:53:WU00:FS01:0x22: On Battery: false
07:44:53:WU00:FS01:0x22: UTC Offset: 2
07:44:53:WU00:FS01:0x22: PID: 1896
07:44:53:WU00:FS01:0x22: CWD: C:\Users\Markus\AppData\Roaming\FAHClient\work
07:44:53:WU00:FS01:0x22: OS: Windows 10 Pro
07:44:53:WU00:FS01:0x22: OS Arch: AMD64
07:44:53:WU00:FS01:0x22:********************************************************************************
07:44:53:WU00:FS01:0x22:Project: 13405 (Run 360, Clone 26, Gen 3)
07:44:53:WU00:FS01:0x22:Unit: 0x0000000c12bc7d9a5eb3a383d6d2551b
07:44:53:WU00:FS01:0x22:Reading tar file core.xml
07:44:53:WU00:FS01:0x22:Reading tar file integrator.xml
07:44:53:WU00:FS01:0x22:Reading tar file state.xml
07:44:53:WU00:FS01:0x22:Reading tar file system.xml
07:44:53:WU00:FS01:0x22:Digital signatures verified
07:44:53:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:44:53:WU00:FS01:0x22:Version 0.0.5
07:45:01:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
07:45:01:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:46:18:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
07:47:34:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
09:18:26:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
09:19:42:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
09:20:43:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:20:43:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:20:53:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:20:53:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:21:04:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
09:21:04:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
09:21:04:WU00:FS01:0x22:ERROR:114: Max Retries Reached
09:21:04:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
09:21:04:WU00:FS01:0x22:Saving result file badstate-0.xml
09:21:04:WU00:FS01:0x22:Saving result file badstate-1.xml
09:21:04:WU00:FS01:0x22:Saving result file badstate-2.xml
09:21:04:WU00:FS01:0x22:Saving result file checkpointState.xml
09:21:05:WU00:FS01:0x22:Saving result file checkpt.crc
09:21:05:WU00:FS01:0x22:Saving result file globals.csv
09:21:05:WU00:FS01:0x22:Saving result file positions.xtc
09:21:05:WU00:FS01:0x22:Saving result file science.log
09:21:05:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
09:21:05:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:21:05:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13405 run:360 clone:26 gen:3 core:0x22 unit:0x0000000c12bc7d9a5eb3a383d6d2551b
09:21:05:WU00:FS01:Uploading 5.00MiB to 18.188.125.154
09:21:05:WU00:FS01:Connecting to 18.188.125.154:8080
09:21:11:WU00:FS01:Upload 47.54%
09:21:17:WU00:FS01:Upload complete
09:21:17:WU00:FS01:Server responded WORK_ACK (400)
09:21:17:WU00:FS01:Cleaning up
