cumulative RAM usage increase
cayenne187
Hardware configuration: intel i7-4790 3.6ghz
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
Post by cayenne187 »
Mod note - moved topic to appropriate forum for client software issues
it appears that fah client causes my system to gradually increase RAM usage over time. it does not appear to be linked to msi afterburner or radeon software apps monitoring my gpus. nothing else running. requires rebooting every 2 days to reset. microsoft says malware or poorly written programs that don't release RAM usage back. recently had to start over after ssd failed. added 8gb RAM but after a day starting at 4gb it climbs to 7gb. please look into this.
Date of last Work Unit 2020-08-04 22:17:53
Total score 63,300,083
Total WUs 1,013
Overall rank (if points are combined) 15,440 of 2,735,299
Re: cumulative RAM usage increase
Post by Neil-B »
Welcome to the FAH Forums cayenne187.
RAM usage can vary from WU to WU but tbh I can't remember seeing a post indicating any of the FAH software has a RAM leak before … Not saying you haven't got a real issue - I'm going to check the GitHub issues to see if I can find this ever reported before - but it may be something else (like malware) which you might not realise is running … I'll post back to confirm if I find anything.
Post by Neil-B »
There have been cases in the past of memory leaks (a number of years ago) - looks like they were linked with and caught at the beta software stages … Nothing current or recent that I can see has been reported … I'll let one of the more technical volunteers advise/guide you through checking if the leak is FAH related - If it is I am sure someone will help get it raised as an issue.
Rel25917
Post by Rel25917 »
What version are you running? Older versions of fahcontrol had a memory leak but that was fixed. And is it fahclient or some other part that is using the memory?
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
it seems to be related to writing. every time the gpus pause and the cpu and ram spike to send data the result is an increase in RAM usage.
Total WUs 1,013
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
i am running newest 7.6.13
i just observed in real time the end of a wu and the ram dropped by 500mb as it started next. after 2 writes its back up to 6gb. i just got a big wu to monitor how much it goes up over time.
Total WUs 1,013
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
*********************** Log Started 2020-05-14T19:43:00Z ***********************
19:43:00:Trying to access database...
19:43:00:Successfully acquired database lock
19:43:00:Read GPUs.txt
19:43:00:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970] 3494
19:43:00:Enabled folding slot 02: READY gpu:1:Ellesmere XT [Radeon RX 470/480/570/580/590]
19:43:00:****************************** FAHClient ******************************
19:43:00:        Version: 7.6.13
19:43:00:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:43:00:      Copyright: 2020 foldingathome.org
19:43:00:       Homepage: https://foldingathome.org/
19:43:00:           Date: Apr 27 2020
19:43:00:           Time: 21:21:01
19:43:00:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:43:00:         Branch: master
19:43:00:       Compiler: Visual C++ 2008
19:43:00:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:00:       Platform: win32 10
19:43:00:           Bits: 32
19:43:00:           Mode: Release
19:43:00:           Args: --open-web-control
19:43:00:         Config: C:\Users\phil\AppData\Roaming\FAHClient\config.xml
19:43:00:******************************** CBang ********************************
19:43:00:           Date: Apr 24 2020
19:43:00:           Time: 17:07:55
19:43:00:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:43:00:           Bits: 32
19:43:00:******************************* System ********************************
19:43:00:            CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:43:00:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:43:00:           CPUs: 8
19:43:00:         Memory: 15.95GiB
19:43:00:    Free Memory: 13.03GiB
19:43:00:        Threads: WINDOWS_THREADS
19:43:00:     OS Version: 6.2
19:43:00:    Has Battery: false
19:43:00:     On Battery: false
19:43:00:     UTC Offset: -4
19:43:00:            PID: 9916
19:43:00:            CWD: C:\Users\phil\AppData\Roaming\FAHClient
19:43:00:  Win32 Service: false
19:43:00:             OS: Windows 10 Enterprise
19:43:00:        OS Arch: AMD64
19:43:00:           GPUs: 2
19:43:00:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970] 3494
19:43:00:          GPU 1: Bus:6 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
19:43:00:                 470/480/570/580/590]
19:43:00:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.0
19:43:00:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
19:43:00:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
19:43:00:******************************* libFAH ********************************
19:43:00:           Date: Apr 15 2020
19:43:00:           Time: 14:53:14
19:43:00:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:43:00:           Bits: 32
19:43:00:***********************************************************************
19:43:01:<config>
19:43:01:  <!-- Folding Core -->
19:43:01:  <checkpoint v='30'/>
19:43:01:
19:43:01:  <!-- Folding Slot Configuration -->
19:43:01:  <cause v='COVID_19'/>
19:43:01:
19:43:01:  <!-- Network -->
19:43:01:  <proxy v=':8080'/>
19:43:01:
19:43:01:  <!-- Slot Control -->
19:43:01:  <pause-on-battery v='false'/>
19:43:01:  <power v='full'/>
19:43:01:
19:43:01:  <!-- User Information -->
19:43:01:  <passkey v='*****'/>
19:43:01:  <user v='cayenne187'/>
19:43:01:
19:43:01:  <!-- Folding Slots -->
19:43:01:  <slot id='1' type='GPU'>
19:43:01:    <gpu-index v='0'/>
19:43:01:  </slot>
19:43:01:  <slot id='2' type='GPU'/>
19:43:01:</config>
19:43:01:WU00:FS02:Starting
19:43:01:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 9916 -checkpoint 30 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:43:01:WU00:FS02:Started FahCore on PID 8616
19:43:01:WU00:FS02:Core PID:10980
19:43:01:WU00:FS02:FahCore 0x22 started
19:43:01:WU01:FS01:Starting
19:43:02:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9916 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
19:43:02:WU01:FS01:Started FahCore on PID 13412
19:43:02:WU00:FS02:0x22:*********************** Log Started 2020-05-14T19:43:02Z ***********************
19:43:02:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:43:02:WU00:FS02:0x22:       Type: 0x22
19:43:02:WU00:FS02:0x22:       Core: Core22
19:43:02:WU00:FS02:0x22:    Website: https://foldingathome.org/
19:43:02:WU00:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:43:02:WU00:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:43:02:WU00:FS02:0x22:             <rafal.wiewiora@choderalab.org>
19:43:02:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8616 -checkpoint 30
19:43:02:WU00:FS02:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:43:02:WU00:FS02:0x22:     Config: <none>
19:43:02:WU00:FS02:0x22:************************************ Build *************************************
19:43:02:WU00:FS02:0x22:    Version: 0.0.5
19:43:02:WU00:FS02:0x22:       Date: Apr 22 2020
19:43:02:WU00:FS02:0x22:       Time: 04:42:59
19:43:02:WU00:FS02:0x22: Repository: Git
19:43:02:WU00:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:43:02:WU00:FS02:0x22:     Branch: HEAD
19:43:02:WU00:FS02:0x22:   Compiler: Visual C++ 2008
19:43:02:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:02:WU00:FS02:0x22:   Platform: win32 10
19:43:02:WU00:FS02:0x22:       Bits: 64
19:43:02:WU00:FS02:0x22:       Mode: Release
19:43:02:WU00:FS02:0x22:************************************ System ************************************
19:43:02:WU00:FS02:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:43:02:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:43:02:WU00:FS02:0x22:       CPUs: 8
19:43:02:WU00:FS02:0x22:     Memory: 15.95GiB
19:43:02:WU00:FS02:0x22:Free Memory: 12.93GiB
19:43:02:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
19:43:02:WU00:FS02:0x22: OS Version: 6.2
19:43:02:WU00:FS02:0x22:Has Battery: false
19:43:02:WU00:FS02:0x22: On Battery: false
19:43:02:WU00:FS02:0x22: UTC Offset: -4
19:43:02:WU00:FS02:0x22:        PID: 10980
19:43:02:WU00:FS02:0x22:        CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
19:43:02:WU00:FS02:0x22:         OS: Windows 10 Pro
19:43:02:WU00:FS02:0x22:    OS Arch: AMD64
19:43:02:WU00:FS02:0x22:********************************************************************************
19:43:02:WU00:FS02:0x22:Project: 11751 (Run 0, Clone 4917, Gen 42)
19:43:02:WU00:FS02:0x22:Unit: 0x000000598ca304e75e6a8057fbb89cb0
19:43:02:WU00:FS02:0x22:Reading tar file core.xml
19:43:02:WU00:FS02:0x22:Reading tar file integrator.xml
19:43:02:WU00:FS02:0x22:Reading tar file state.xml
19:43:02:WU01:FS01:Core PID:13896
19:43:02:WU01:FS01:FahCore 0x22 started
19:43:03:WU01:FS01:0x22:*********************** Log Started 2020-05-14T19:43:02Z ***********************
19:43:03:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:43:03:WU01:FS01:0x22:       Type: 0x22
19:43:03:WU01:FS01:0x22:       Core: Core22
19:43:03:WU01:FS01:0x22:    Website: https://foldingathome.org/
19:43:03:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:43:03:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:43:03:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:43:03:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13412 -checkpoint 30
19:43:03:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
19:43:03:WU01:FS01:0x22:             0 -gpu 0
19:43:03:WU01:FS01:0x22:     Config: <none>
19:43:03:WU01:FS01:0x22:************************************ Build *************************************
19:43:03:WU01:FS01:0x22:    Version: 0.0.5
19:43:03:WU01:FS01:0x22:       Date: Apr 22 2020
19:43:03:WU01:FS01:0x22:       Time: 04:42:59
19:43:03:WU01:FS01:0x22: Repository: Git
19:43:03:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:43:03:WU01:FS01:0x22:     Branch: HEAD
19:43:03:WU01:FS01:0x22:   Compiler: Visual C++ 2008
19:43:03:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:43:03:WU01:FS01:0x22:   Platform: win32 10
19:43:03:WU01:FS01:0x22:       Bits: 64
19:43:03:WU01:FS01:0x22:       Mode: Release
19:43:03:WU01:FS01:0x22:************************************ System ************************************
19:43:03:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
19:43:03:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:43:03:WU01:FS01:0x22:       CPUs: 8
19:43:03:WU01:FS01:0x22:     Memory: 15.95GiB
19:43:03:WU01:FS01:0x22:Free Memory: 12.64GiB
19:43:03:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:43:03:WU01:FS01:0x22: OS Version: 6.2
19:43:03:WU01:FS01:0x22:Has Battery: false
19:43:03:WU01:FS01:0x22: On Battery: false
19:43:03:WU01:FS01:0x22: UTC Offset: -4
19:43:03:WU01:FS01:0x22:        PID: 13896
19:43:03:WU01:FS01:0x22:        CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
19:43:03:WU01:FS01:0x22:         OS: Windows 10 Pro
19:43:03:WU01:FS01:0x22:    OS Arch: AMD64
19:43:03:WU01:FS01:0x22:********************************************************************************
19:43:03:WU01:FS01:0x22:Project: 14253 (Run 1898, Clone 3, Gen 5)
19:43:03:WU01:FS01:0x22:Unit: 0x0000000ccedfaa925eaba95beaaab5fd
19:43:03:WU01:FS01:0x22:Digital signatures verified
19:43:03:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:43:03:WU01:FS01:0x22:Version 0.0.5
19:43:03:WU01:FS01:0x22:  Found a checkpoint file
19:43:03:WU00:FS02:0x22:Reading tar file system.xml
19:43:04:WU00:FS02:0x22:Digital signatures verified
19:43:04:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:43:04:WU00:FS02:0x22:Version 0.0.5
19:43:13:21:127.0.0.1:New Web session
19:43:34:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
19:43:34:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:44:50:WU01:FS01:0x22:Completed 180000 out of 500000 steps (36%)
19:44:51:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
2:Core PID:6628
11:38:49:WU01:FS02:FahCore 0x22 started
11:38:49:WU01:FS02:0x22:*********************** Log Started 2020-05-15T11:38:49Z ***********************
11:38:49:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
11:38:49:WU01:FS02:0x22:       Type: 0x22
11:38:49:WU01:FS02:0x22:       Core: Core22
11:38:49:WU01:FS02:0x22:    Website: https://foldingathome.org/
11:38:49:WU01:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:38:49:WU01:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:38:49:WU01:FS02:0x22:             <rafal.wiewiora@choderalab.org>
11:38:49:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8548 -checkpoint 30
11:38:49:WU01:FS02:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
11:38:49:WU01:FS02:0x22:     Config: <none>
11:38:49:WU01:FS02:0x22:************************************ Build *************************************
11:38:49:WU01:FS02:0x22:    Version: 0.0.5
11:38:49:WU01:FS02:0x22:       Date: Apr 22 2020
11:38:49:WU01:FS02:0x22:       Time: 04:42:59
11:38:49:WU01:FS02:0x22: Repository: Git
11:38:49:WU01:FS02:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
11:38:49:WU01:FS02:0x22:     Branch: HEAD
11:38:49:WU01:FS02:0x22:   Compiler: Visual C++ 2008
11:38:49:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:49:WU01:FS02:0x22:   Platform: win32 10
11:38:49:WU01:FS02:0x22:       Bits: 64
11:38:49:WU01:FS02:0x22:       Mode: Release
11:38:49:WU01:FS02:0x22:************************************ System ************************************
11:38:49:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
11:38:49:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:38:49:WU01:FS02:0x22:       CPUs: 8
11:38:49:WU01:FS02:0x22:     Memory: 15.95GiB
11:38:49:WU01:FS02:0x22:Free Memory: 11.32GiB
11:38:49:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
11:38:49:WU01:FS02:0x22: OS Version: 6.2
11:38:49:WU01:FS02:0x22:Has Battery: false
11:38:49:WU01:FS02:0x22: On Battery: false
11:38:49:WU01:FS02:0x22: UTC Offset: -4
11:38:49:WU01:FS02:0x22:        PID: 6628
11:38:49:WU01:FS02:0x22:        CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
11:38:49:WU01:FS02:0x22:         OS: Windows 10 Pro
11:38:49:WU01:FS02:0x22:    OS Arch: AMD64
11:38:49:WU01:FS02:0x22:********************************************************************************
11:38:49:WU01:FS02:0x22:Project: 14253 (Run 528, Clone 4, Gen 11)
11:38:49:WU01:FS02:0x22:Unit: 0x00000011cedfaa925eab7012611add3a
11:38:49:WU01:FS02:0x22:Reading tar file core.xml
11:38:49:WU01:FS02:0x22:Reading tar file integrator.xml
11:38:49:WU01:FS02:0x22:Reading tar file state.xml
11:38:51:WU01:FS02:0x22:Reading tar file system.xml
11:38:52:WU01:FS02:0x22:Digital signatures verified
11:38:52:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
11:38:52:WU01:FS02:0x22:Version 0.0.5
11:40:40:WU01:FS02:0x22:Completed 0 out of 500000 steps (0%)
11:40:41:WU01:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:40:45:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
11:44:05:WU01:FS02:0x22:Completed 5000 out of 500000 steps (1%)
11:47:27:WU01:FS02:0x22:Completed 10000 out of 500000 steps (2%)
11:47:46:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
11:50:50:WU01:FS02:0x22:Completed 15000 out of 500000 steps (3%)
11:54:12:WU01:FS02:0x22:Completed 20000 out of 500000 steps (4%)
11:54:46:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
11:57:50:WU01:FS02:0x22:Completed 25000 out of 500000 steps (5%)
12:01:12:WU01:FS02:0x22:Completed 30000 out of 500000 steps (6%)
12:01:47:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
12:04:34:WU01:FS02:0x22:Completed 35000 out of 500000 steps (7%)
12:07:56:WU01:FS02:0x22:Completed 40000 out of 500000 steps (8%)
12:08:48:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
12:11:35:WU01:FS02:0x22:Completed 45000 out of 500000 steps (9%)
12:14:56:WU01:FS02:0x22:Completed 50000 out of 500000 steps (10%)
12:15:48:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
12:18:18:WU01:FS02:0x22:Completed 55000 out of 500000 steps (11%)
12:21:40:WU01:FS02:0x22:Completed 60000 out of 500000 steps (12%)
12:22:50:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
12:25:19:WU01:FS02:0x22:Completed 65000 out of 500000 steps (13%)
12:28:40:WU01:FS02:0x22:Completed 70000 out of 500000 steps (14%)
12:29:50:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
12:32:03:WU01:FS02:0x22:Completed 75000 out of 500000 steps (15%)
12:35:25:WU01:FS02:0x22:Completed 80000 out of 500000 steps (16%)
12:36:51:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
12:39:04:WU01:FS02:0x22:Completed 85000 out of 500000 steps (17%)
12:42:26:WU01:FS02:0x22:Completed 90000 out of 500000 steps (18%)
12:43:52:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
12:43:52:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:43:52:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:43:52:WU02:FS01:Connecting to assign2.foldingathome.org:80
12:43:52:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:43:52:WU02:FS01:Connecting to assign3.foldingathome.org:80
12:43:53:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:43:53:WU02:FS01:Connecting to assign4.foldingathome.org:80
12:43:53:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:43:53:ERROR:WU02:FS01:Exception: Could not get an assignment
12:43:53:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:43:53:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:43:53:WU02:FS01:Connecting to assign2.foldingathome.org:80
12:43:54:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:43:54:WU02:FS01:Connecting to assign3.foldingathome.org:80
12:43:54:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:43:54:WU02:FS01:Connecting to assign4.foldingathome.org:80
12:43:54:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:43:54:ERROR:WU02:FS01:Exception: Could not get an assignment
12:44:53:WU02:FS01:Connecting to assign1.foldingathome.org:80
12:44:53:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:44:53:WU02:FS01:Connecting to assign2.foldingathome.org:80
12:44:53:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:44:53:WU02:FS01:Connecting to assign3.foldingathome.org:80
12:44:54:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:44:54:WU02:FS01:Connecting to assign4.foldingathome.org:80
12:44:54:WU02:FS01:Assigned to work server 140.163.4.231
12:44:54:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 140.163.4.231
12:44:54:WU02:FS01:Connecting to 140.163.4.231:8080
12:45:21:WU02:FS01:Downloading 4.53MiB
12:45:21:WU02:FS01:Download complete
12:45:21:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:5719 gen:18 core:0x22 unit:0x000000268ca304e75e6bb0189716b47f
12:45:48:WU01:FS02:0x22:Completed 95000 out of 500000 steps (19%)
12:49:10:WU01:FS02:0x22:Completed 100000 out of 500000 steps (20%)
12:50:53:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
12:51:00:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
12:51:00:WU00:FS01:0x22:Saving result file checkpointState.xml
12:51:03:WU00:FS01:0x22:Saving result file checkpt.crc
12:51:03:WU00:FS01:0x22:Saving result file positions.xtc
12:51:06:WU00:FS01:0x22:Saving result file science.log
12:51:06:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:51:07:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:51:07:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14450 run:0 clone:266 gen:5 core:0x22 unit:0x0000000d03854c135eac4ad1e99c4f2f
12:51:07:WU00:FS01:Uploading 87.28MiB to 3.133.76.19
12:51:07:WU00:FS01:Connecting to 3.133.76.19:8080
12:51:07:WU02:FS01:Starting
12:51:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9916 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
12:51:07:WU02:FS01:Started FahCore on PID 10772
12:51:07:WU02:FS01:Core PID:3160
12:51:07:WU02:FS01:FahCore 0x22 started
12:51:08:WU02:FS01:0x22:*********************** Log Started 2020-05-15T12:51:07Z ***********************
12:51:08:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:51:08:WU02:FS01:0x22:       Type: 0x22
12:51:08:WU02:FS01:0x22:       Core: Core22
12:51:08:WU02:FS01:0x22:    Website: https://foldingathome.org/
12:51:08:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:51:08:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:51:08:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:51:08:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 10772 -checkpoint 30
12:51:08:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
12:51:08:WU02:FS01:0x22:             0 -gpu 0
12:51:08:WU02:FS01:0x22:     Config: <none>
12:51:08:WU02:FS01:0x22:************************************ Build *************************************
12:51:08:WU02:FS01:0x22:    Version: 0.0.5
12:51:08:WU02:FS01:0x22:       Date: Apr 22 2020
12:51:08:WU02:FS01:0x22:       Time: 04:42:59
12:51:08:WU02:FS01:0x22: Repository: Git
12:51:08:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:51:08:WU02:FS01:0x22:     Branch: HEAD
12:51:08:WU02:FS01:0x22:   Compiler: Visual C++ 2008
12:51:08:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:51:08:WU02:FS01:0x22:   Platform: win32 10
12:51:08:WU02:FS01:0x22:       Bits: 64
12:51:08:WU02:FS01:0x22:       Mode: Release
12:51:08:WU02:FS01:0x22:************************************ System ************************************
12:51:08:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
12:51:08:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:51:08:WU02:FS01:0x22:       CPUs: 8
12:51:08:WU02:FS01:0x22:     Memory: 15.95GiB
12:51:08:WU02:FS01:0x22:Free Memory: 10.97GiB
12:51:08:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
12:51:08:WU02:FS01:0x22: OS Version: 6.2
12:51:08:WU02:FS01:0x22:Has Battery: false
12:51:08:WU02:FS01:0x22: On Battery: false
12:51:08:WU02:FS01:0x22: UTC Offset: -4
12:51:08:WU02:FS01:0x22:        PID: 3160
12:51:08:WU02:FS01:0x22:        CWD: C:\Users\phil\AppData\Roaming\FAHClient\work
12:51:08:WU02:FS01:0x22:         OS: Windows 10 Pro
12:51:08:WU02:FS01:0x22:    OS Arch: AMD64
12:51:08:WU02:FS01:0x22:********************************************************************************
12:51:08:WU02:FS01:0x22:Project: 11748 (Run 0, Clone 5719, Gen 18)
12:51:08:WU02:FS01:0x22:Unit: 0x000000268ca304e75e6bb0189716b47f
12:51:08:WU02:FS01:0x22:Reading tar file core.xml
12:51:08:WU02:FS01:0x22:Reading tar file integrator.xml
12:51:08:WU02:FS01:0x22:Reading tar file state.xml
12:51:08:WU02:FS01:0x22:Reading tar file system.xml
12:51:08:WU02:FS01:0x22:Digital signatures verified
12:51:08:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:51:08:WU02:FS01:0x22:Version 0.0.5
12:51:22:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
12:51:22:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:51:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:51:28:WU00:FS01:Connecting to 3.133.76.19:80
12:51:29:WU00:FS01:Upload 0.07%
12:52:01:WU00:FS01:Upload 0.14%
12:52:01:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
12:52:01:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14450 run:0 clone:266 gen:5 core:0x22 unit:0x0000000d03854c135eac4ad1e99c4f2f
12:52:01:WU00:FS01:Uploading 87.28MiB to 3.133.76.19
12:52:01:WU00:FS01:Connecting to 3.133.76.19:8080
12:52:22:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:52:22:WU00:FS01:Connecting to 3.133.76.19:80
12:52:22:WU00:FS01:Upload 0.07%
12:52:49:WU01:FS02:0x22:Completed 105000 out of 500000 steps (21%)
12:53:37:WU00:FS01:Upload 0.21%
12:53:43:WU00:FS01:Upload 11.74%
12:53:49:WU00:FS01:Upload 25.49%
12:53:52:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
12:53:55:WU00:FS01:Upload 39.24%
12:54:01:WU00:FS01:Upload 52.99%
12:54:07:WU00:FS01:Upload 66.45%
12:54:13:WU00:FS01:Upload 79.91%
12:54:19:WU00:FS01:Upload 93.66%
12:54:22:WU00:FS01:Upload complete
12:54:22:WU00:FS01:Server responded WORK_ACK (400)
12:54:22:WU00:FS01:Final credit estimate, 159440.00 points
12:54:22:WU00:FS01:Cleaning up
12:56:11:WU01:FS02:0x22:Completed 110000 out of 500000 steps (22%)
12:56:22:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
12:58:55:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
12:59:33:WU01:FS02:0x22:Completed 115000 out of 500000 steps (23%)
13:01:25:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
13:02:55:WU01:FS02:0x22:Completed 120000 out of 500000 steps (24%)
13:03:56:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
13:06:28:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
13:06:34:WU01:FS02:0x22:Completed 125000 out of 500000 steps (25%)
13:08:59:WU02:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
13:09:56:WU01:FS02:0x22:Completed 130000 out of 500000 steps (26%)
13:11:32:WU02:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
13:13:18:WU01:FS02:0x22:Completed 135000 out of 500000 steps (27%)
13:14:02:WU02:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
13:16:33:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
13:16:40:WU01:FS02:0x22:Completed 140000 out of 500000 steps (28%)
13:19:06:WU02:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
13:20:18:WU01:FS02:0x22:Completed 145000 out of 500000 steps (29%)
13:21:36:WU02:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
13:23:40:WU01:FS02:0x22:Completed 150000 out of 500000 steps (30%)
13:24:09:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
13:26:40:WU02:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
13:27:02:WU01:FS02:0x22:Completed 155000 out of 500000 steps (31%)
13:29:10:WU02:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
13:30:24:WU01:FS02:0x22:Completed 160000 out of 500000 steps (32%)
13:31:43:WU02:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
13:34:03:WU01:FS02:0x22:Completed 165000 out of 500000 steps (33%)
13:34:14:WU02:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
13:36:47:WU02:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
13:37:25:WU01:FS02:0x22:Completed 170000 out of 500000 steps (34%)
13:39:18:WU02:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
13:40:47:WU01:FS02:0x22:Completed 175000 out of 500000 steps (35%)
13:41:48:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
13:44:09:WU01:FS02:0x22:Completed 180000 out of 500000 steps (36%)
13:44:21:WU02:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
******************************* Date: 2020-05-15 *******************************
13:46:52:WU02:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
13:47:48:WU01:FS02:0x22:Completed 185000 out of 500000 steps (37%)
13:49:25:WU02:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
13:51:10:WU01:FS02:0x22:Completed 190000 out of 500000 steps (38%)
13:51:56:WU02:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
13:54:27:WU02:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
13:54:32:WU01:FS02:0x22:Completed 195000 out of 500000 steps (39%)
13:57:00:WU02:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
13:57:54:WU01:FS02:0x22:Completed 200000 out of 500000 steps (40%)
13:59:31:WU02:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
14:01:32:WU01:FS02:0x22:Completed 205000 out of 500000 steps (41%)
14:02:04:WU02:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
14:04:34:WU02:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
14:04:54:WU01:FS02:0x22:Completed 210000 out of 500000 steps (42%)
14:07:05:WU02:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
14:08:16:WU01:FS02:0x22:Completed 215000 out of 500000 steps (43%)
14:09:38:WU02:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
14:11:38:WU01:FS02:0x22:Completed 220000 out of 500000 steps (44%)
14:12:09:WU02:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
14:14:42:WU02:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
14:15:17:WU01:FS02:0x22:Completed 225000 out of 500000 steps (45%)
14:17:13:WU02:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
14:18:39:WU01:FS02:0x22:Completed 230000 out of 500000 steps (46%)
14:19:44:WU02:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
14:22:01:WU01:FS02:0x22:Completed 235000 out of 500000 steps (47%)
14:22:17:WU02:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
14:24:48:WU02:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
14:25:24:WU01:FS02:0x22:Completed 240000 out of 500000 steps (48%)
14:27:21:WU02:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
14:29:03:WU01:FS02:0x22:Completed 245000 out of 500000 steps (49%)
14:29:52:WU02:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
14:32:23:WU02:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
14:32:25:WU01:FS02:0x22:Completed 250000 out of 500000 steps (50%)
14:34:56:WU02:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
14:35:47:WU01:FS02:0x22:Completed 255000 out of 500000 steps (51%)
14:37:26:WU02:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
14:39:09:WU01:FS02:0x22:Completed 260000 out of 500000 steps (52%)
14:40:00:WU02:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
14:42:30:WU02:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
14:42:48:WU01:FS02:0x22:Completed 265000 out of 500000 steps (53%)
14:45:01:WU02:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
14:46:10:WU01:FS02:0x22:Completed 270000 out of 500000 steps (54%)
14:47:34:WU02:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
14:49:32:WU01:FS02:0x22:Completed 275000 out of 500000 steps (55%)
14:50:05:WU02:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
14:52:38:WU02:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
14:52:54:WU01:FS02:0x22:Completed 280000 out of 500000 steps (56%)
14:55:09:WU02:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
14:56:34:WU01:FS02:0x22:Completed 285000 out of 500000 steps (57%)
14:57:40:WU02:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
14:59:56:WU01:FS02:0x22:Completed 290000 out of 500000 steps (58%)
15:00:13:WU02:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
15:02:44:WU02:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
15:03:17:WU01:FS02:0x22:Completed 295000 out of 500000 steps (59%)
15:05:17:WU02:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
15:06:39:WU01:FS02:0x22:Completed 300000 out of 500000 steps (60%)
15:07:48:WU02:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
15:10:18:WU01:FS02:0x22:Completed 305000 out of 500000 steps (61%)
15:10:19:WU02:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
15:12:52:WU02:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
15:13:41:WU01:FS02:0x22:Completed 310000 out of 500000 steps (62%)
15:15:23:WU02:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
15:17:03:WU01:FS02:0x22:Completed 315000 out of 500000 steps (63%)
15:17:57:WU02:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
15:20:25:WU01:FS02:0x22:Completed 320000 out of 500000 steps (64%)
15:20:28:WU02:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
15:22:59:WU02:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
15:24:04:WU01:FS02:0x22:Completed 325000 out of 500000 steps (65%)
15:25:32:WU02:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
15:27:26:WU01:FS02:0x22:Completed 330000 out of 500000 steps (66%)
15:28:04:WU02:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
15:30:37:WU02:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
15:30:48:WU01:FS02:0x22:Completed 335000 out of 500000 steps (67%)
15:33:08:WU02:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
15:34:10:WU01:FS02:0x22:Completed 340000 out of 500000 steps (68%)
15:35:40:WU02:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
15:37:50:WU01:FS02:0x22:Completed 345000 out of 500000 steps (69%)
15:38:13:WU02:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
15:40:44:WU02:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
15:41:12:WU01:FS02:0x22:Completed 350000 out of 500000 steps (70%)
15:43:17:WU02:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
15:44:33:WU01:FS02:0x22:Completed 355000 out of 500000 steps (71%)
15:45:49:WU02:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
15:47:55:WU01:FS02:0x22:Completed 360000 out of 500000 steps (72%)
15:48:20:WU02:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
15:50:54:WU02:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
15:51:34:WU01:FS02:0x22:Completed 365000 out of 500000 steps (73%)
15:53:25:WU02:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
15:54:56:WU01:FS02:0x22:Completed 370000 out of 500000 steps (74%)
15:55:58:WU02:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
15:58:18:WU01:FS02:0x22:Completed 375000 out of 500000 steps (75%)
15:58:29:WU02:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
16:01:01:WU02:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
16:01:40:WU01:FS02:0x22:Completed 380000 out of 500000 steps (76%)
16:03:35:WU02:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
16:05:19:WU01:FS02:0x22:Completed 385000 out of 500000 steps (77%)
16:06:06:WU02:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
16:08:39:WU02:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
16:08:41:WU01:FS02:0x22:Completed 390000 out of 500000 steps (78%)
16:11:11:WU02:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
16:12:03:WU01:FS02:0x22:Completed 395000 out of 500000 steps (79%)
16:13:42:WU02:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
16:15:25:WU01:FS02:0x22:Completed 400000 out of 500000 steps (80%)
16:16:16:WU02:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
16:18:47:WU02:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
16:19:04:WU01:FS02:0x22:Completed 405000 out of 500000 steps (81%)
16:21:20:WU02:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
16:22:27:WU01:FS02:0x22:Completed 410000 out of 500000 steps (82%)
16:23:52:WU02:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
16:25:48:WU01:FS02:0x22:Completed 415000 out of 500000 steps (83%)
16:26:23:WU02:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
16:28:56:WU02:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
16:29:11:WU01:FS02:0x22:Completed 420000 out of 500000 steps (84%)
16:31:27:WU02:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
16:32:50:WU01:FS02:0x22:Completed 425000 out of 500000 steps (85%)
16:34:01:WU02:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
16:36:12:WU01:FS02:0x22:Completed 430000 out of 500000 steps (86%)
16:36:32:WU02:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
16:39:04:WU02:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
16:39:33:WU01:FS02:0x22:Completed 435000 out of 500000 steps (87%)
16:41:37:WU02:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
16:42:55:WU01:FS02:0x22:Completed 440000 out of 500000 steps (88%)
16:44:09:WU02:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
16:46:34:WU01:FS02:0x22:Completed 445000 out of 500000 steps (89%)
16:46:42:WU02:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
16:49:13:WU02:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
16:49:56:WU01:FS02:0x22:Completed 450000 out of 500000 steps (90%)
16:51:45:WU02:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
16:53:19:WU01:FS02:0x22:Completed 455000 out of 500000 steps (91%)
16:54:18:WU02:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
16:56:40:WU01:FS02:0x22:Completed 460000 out of 500000 steps (92%)
16:56:50:WU02:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
16:59:23:WU02:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
17:00:20:WU01:FS02:0x22:Completed 465000 out of 500000 steps (93%)
17:01:55:WU02:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
17:01:56:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:01:58:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:01:58:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:01:59:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:01:59:WU00:FS01:Connecting to assign3.foldingathome.org:80
17:01:59:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:01:59:WU00:FS01:Connecting to assign4.foldingathome.org:80
17:01:59:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:01:59:ERROR:WU00:FS01:Exception: Could not get an assignment
17:01:59:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:02:00:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:02:00:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:02:00:WU00:FS01:Assigned to work server 3.133.76.19
17:02:00:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 3.133.76.19
17:02:00:WU00:FS01:Connecting to 3.133.76.19:8080
17:03:42:WU01:FS02:0x22:Completed 470000 out of 500000 steps (94%)
17:03:51:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:03:51:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:03:51:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:03:51:WU00:FS01:Connecting to assign2.foldingathome.org:80
17:03:52:WU00:FS01:Assigned to work server 13.82.98.119
17:03:52:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] 3494 from 13.82.98.119
17:03:52:WU00:FS01:Connecting to 13.82.98.119:8080
17:03:56:WU00:FS01:Downloading 119.45MiB
17:04:02:WU00:FS01:Download 41.13%
17:04:08:WU00:FS01:Download 82.88%
17:04:10:WU00:FS01:Download complete
17:04:10:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16445 run:0 clone:798 gen:32 core:0x22 unit:0x000000340d5262775eaa2b163671511a
17:04:26:WU02:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
17:04:29:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
17:04:29:WU02:FS01:0x22:Saving result file checkpointState.xml
17:04:30:WU02:FS01:0x22:Saving result file checkpt.crc
17:04:30:WU02:FS01:0x22:Saving result file positions.xtc
17:04:31:WU02:FS01:0x22:Saving result file science.log
17:04:31:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:04:32:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:04:32:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11748 run:0 clone:5719 gen:18 core:0x22 unit:0x000000268ca304e75e6bb0189716b47f
17:04:32:WU02:FS01:Uploading 12.63MiB to 140.163.4.231
17:04:32:WU02:FS01:Connecting to 140.163.4.231:8080
17:04:32:WU00:FS01:Starting
17:04:32:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 9916 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
17:04:32:WU00:FS01:Started FahCore on PID 6524
17:04:32:WU00:FS01:Core PID:8544
17:04:32:WU00:FS01:FahCore 0x22 started
17:04:32:WU00:FS01:0x22:*********************** Log Started 2020-05-15T17:04:32Z ***********************
17:04:32:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:04:32:WU00:FS01:0x22:       Type: 0x22
17:04:32:WU00:FS01:0x22:       Core: Core22
17:04:32:WU00:FS01:0x22:    Website: https://foldingathome.org/
17:04:32:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
17:04:32:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:04:32:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
17:04:32:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6524 -checkpoint 30
17:04:32:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
17:04:32:WU00:FS01:0x22:             0 -gpu 0
17:04:32:WU00:FS01:0x22:     Config: <none>
17:04:32:WU00:FS01:0x22:************************************ Build *************************************
17:04:32:WU00:FS01:0x22:    Version: 0.0.5
21:21:33:WU02:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
21:22:13:WU00:FS01:0x22:Completed 600000 out of 600000 steps (100%)
21:22:21:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:22:21:WU00:FS01:0x22:Saving result file checkpointState.xml
21:22:22:WU00:FS01:0x22:Saving result file checkpt.crc
21:22:22:WU00:FS01:0x22:Saving result file positions.xtc
21:22:22:WU00:FS01:0x22:Saving result file science.log
21:22:22:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:22:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:22:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16445 run:0 clone:798 gen:32 core:0x22 unit:0x000000340d5262775eaa2b163671511a
21:22:23:WU00:FS01:Uploading 76.81MiB to 13.82.98.119
21:22:23:WU00:FS01:Connecting to 13.82.98.119:8080
21:22:23:WU01:FS01:Starting
21:22:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\phil\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9916 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
21:22:23:WU01:FS01:Started FahCore on PID 11916
21:22:23:WU01:FS01:Core PID:9960
21:22:23:WU01:FS01:FahCore 0x22 started
21:22:24:WU01:FS01:0x22:*********************** Log Started 2020-05-15T21:22:24Z ***********************
21:22:24:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:22:24:WU01:FS01:0x22:       Type: 0x22
21:22:24:WU01:FS01:0x22:       Core: Core22
21:22:24:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:22:24:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:22:24:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:22:24:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:22:24:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11916 -checkpoint 30
21:22:24:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
21:22:24:WU01:FS01:0x22:             0 -gpu 0
21:22:24:WU01:FS01:0x22:     Config: <none>
21:22:24:WU01:FS01:0x22:************************************ Build *************************************
21:22:24:WU01:FS01:0x22:    Version: 0.0.5
21:22:24:WU01:FS01:0x22:       Date: Apr 22 2020
21:22:24:WU01:FS01:0x22:       Time: 04:42:59
21:22:24:WU01:FS01:0x22: Repository: Git
21:22:24:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:22:24:WU01:FS01:0x22:     Branch: HEAD
21:22:24:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:22:24:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:22:24:WU01:FS01:0x22:   Platform: win32 10
21:22:24:WU01:FS01:0x22:       Bits: 64
21:22:24:WU01:FS01:0x22:       Mode: Release
21:22:24:WU01:FS01:0x22:************************************ System ************************************
21:22:24:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
Total WUs 1,013
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
just posted the log. when i left this morning it was around 5gb after running over night. now it's at about 7gb. after this wu i will reboot and it should start about 4gb.
Total WUs 1,013
Above, I have noticed the decrease in Free RAM. Thus, there are few questions that pop into my mind:
Is this a dedicated system?
What applications are installed on it?
What applications beside F@H is running on it?
What services are running?
What does Resource Monitor says about RAM usage?
Are all Windows updates installed on it?
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
no
msi afterburner, radeon software, brave and chrome browsers
lots of services
resource monitor same as afterburner monitor, 5gb
all updates done. this is a new ssd and win 10 pro install after my ssd died
Total WUs 1,013
I am aware that Chrome likes to consume RAM. Could it be possible that Chrome is left running in the background and with multiple Windows and tabs, could be using up your RAM.
In Resource Monitor, look at the top 10 processes that are using the RAM and monitor it. That will tell us what process is continuously using up the RAM and not freeing it up (memory leak).
cayenne187
16gb ram
win 10 pro
GTX970 4gb
Radeon RX570 4gb
no. rarely use chrome. using brave now. trying to paste snippet. not working. fah client dominates ram usage.
Total WUs 1,013
I wonder if you can log the RAM usage... it will however, not show what process is accumulating it: https://www.instantfundas.com/2012/03/h ... -over.html
This is what the common and expected behavior is for F@H Software:
FAHClient should have very low RAM usage.
FAHControl should have low RAM usage.
FAHCoreWrapper should have very low RAM usage.
FAHCore_XX will have varying RAM usage. It may use up to 3 GBs of RAM depending on the WU assigned to it but once the WU has folded, it should release the RAM back.
In your case, you have 2 GPUs and assuming that they are given the largest GPU WU, that is 3 GB per GPU, that's 6 GBs of RAM in use.
Free memory is not a good way to measure the memory used by an application.
I'm assuming you're using the the windows task manager. Click on the processes tab. You may have to use the View button to add specific columns but look at Working Set and/or Private Working Set. Personally I also like to see PF Delta because it tells you when there are page faults that temporarily allocate or deallocate of space in the Page File. Periodically, FAHCore_22 will allocate extra memory when it writes a checkpoint, but that's not the same as a gradual increase over time, like you seem to be talking about.
In my case, there's a fairly stable Working Set that increases or decreases somewhat depending on what stage of the calculation process happens to be active. Long term trends should be absent.
As far as free memory is concerned, it's a single pool, managed by the operating system on behalf of all running programs. When any program needs more RAM, the OS will do two things. It will allocate space from free memory or it will move idle pages from RAM to virtual memory (in the page file on disk). Then if those pages are needed again, they'll either be read back into RAM or, if they're already there, simply activated. When any program writes data to the disk, it is first held in memory during the caching process so free memory can be consumed rather rapidly and held until the (relatively slow) disk drive can perform the actual storage process. Free memory is a list of pages that have not been used recently. Reductions in the free memory pool simply indicates that more pages are active and the OS is attempting to hold more in case it happens to be something that is needed again soon.
