Hi,
I am a Boinc cruncher but I started crunching again on Folding after having seen the great effort you are doing to fight the coronavirus.
I am running an host H24, it is a Xeon L5420 quad core processor coupled with a Nvidia 750ti. If I find a good offer I am planning to change it soon with a 1660 or a 1650 in order to contribute more efficiently.
Now I am running Folding full power on both CPU and GPU; the client automatically choose to use 3 cpu threads and leave the other one for the GPU. Perhaps in the next days or weeks I will start using again the CPU for Boinc projects related with Covid (WCG, Rosetta, Tn-Grid, Ibercivis) so I was wondering if it makes sense to limit the number of Boinc tasks to three in order to leave one core for the GPU running on FAH.
Moreover, another option: do you think is a good idea to continue running Folding also on CPU even if I start running Boinc again?
Thank you
Reserve a CPU core for GPU
Re: Reserve a CPU core for GPU
If you only use F@H for the GPUs, you still want to reserve a CPU for the GPU.
This more important for Nvidia GPUs than for AMD cards, but a good idea either way.
AMD uses interrupts, if a CPU is always available to handle the interrupt, F@H will be faster.
https://en.wikipedia.org/wiki/Interrupt
Nvidia on the other hand uses Polled I/O, where the program loop forever waiting for a response. It uses an entire thread even when nothing need attention.
https://en.wikipedia.org/wiki/Busy_waiting
So if you can, allocate one less CPU thread to the other DC program.
FireFox-89
- Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ Stock | Noctua NH-U14S
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FG
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X @ Stock | Noctua C14S
ASRock B450M/ac R2.0 | BIOS version p10.50
G.Skill Trident RGB 2x8GB DDR4-3000 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
be quiet! Pure Power 13 M 550W 80+ Gold PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ Stock | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Needs Sorting)
2x Sapphire Radeon RX 580 Nitro+ 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.5.5
So does the CPU feed the GPU with the calculations?
Do you even fold bro?
All Data gets on and off the Graphics card via CPU operations. Uploads/downloads and check points.
There is a sanity check calculation at every check point to be sure the GPU has not gone astray.
FireFox-89
Terra - Active
Anubis - Active
Ahh OK, that makes senseJimboPalmer wrote:All Data gets on and off the Graphics card via CPU operations. Uploads/downloads and check points.
I don't recommend running both FAH and BOINC on the remaining CPUs. They don't do a nice job of sharing. Choose one or the other.
You can run boinc and FAH together, as long as enough CPU threads are reserved for the GPU.
In Boinc you can easily set your system to use only 75% of (3 out of 4) cores, and the OS will assign the 4th core for sharing the GPU and the rest of the OS and client programs.
A quad core system will work better doing only one project though.
Sharing is easier when you have plenty of cores. But even then, it's often better to assign one PC to one project.
But it is possible; so long both programs aren't fighting for resources allocated to the other (you can't for instance, run Boinc and FAH on the same GPU; you'll lose more than 50% of performance).
