Hi, I’m nearly new at Folding@home.
Sorry for my English and my simple questions:
I’ve being running FAH from the beginning of May till today without any problem.
My PC is running Windows 10 (version 10.0.18363.836).
Today, it has updated and after a reboot, the FAH client doesn’t start (or I can’t see it).
The page http://client.foldingathome.org/ is always "Connecting to your Folding@home client".
1) How can I start manually the client?
2) Would it be more simple to reinstall the software? If so, would I lose my user name?
Thank you in advance for your help
After reboot, FAH client doesn’t start (Windows 10)
Re: After reboot, FAH client doesn’t start (Windows 10)
During an installation, you can choose to have FAH start automatically. If you haven't, you can make a search (the zone of the taskbar with a magnifying glass) for fahclient and hit enter.
If you prefer to reinstall, it is always better to include the data (the uninstaller offers that possibility with a check-box) so that potentials problems are solved. Before uninstalling, though, you might want to make a copy of the file config.xml, that contains your username, your team, and your passkey (if you have defined those). It is handy to have this file open during the new installation, as you have then to (re-)enter these elements. You'll find the file config.xml in %AppData%\FAHClient (just copy this in the address line of an explorer window). As it si an xml, you can just double clic the file and it will open in a browser.
Thank you very much, ajm!
Your help has been perfect: All is working again, all the projects I've been working with are restored, all is perfect.
Folding again!
Folding again!
Great, thank you for reporting back and happy folding!
- Hardware configuration: CPU: AMD Ryzen 5 2600, Six Core, 3.4GHz
GPU: XFX Radeon R9 290X
Memory: Corsair Vengeance LPX, 3200MHz, 16GB
If it does not come back after a reboot, you might be having this issue: viewtopic.php?f=108&t=34839
