Issues getting nvidia 640M LE to fold on laptop
Fruban
Post by Fruban »
Hello, I'm having issues with my GPU folding. I'm seeing two errors pop up myself but this log will probably be more useful to someone else. I'm seeing a lot of "No WUs available for this configuration" and "BAD_WORK_UNIT (114 = 0x72)"
I've got the latest available drivers via GeForce Experience. I'm also running v7.6.13 of FaH client. I can post more of the log file if needed.
I'm wondering if I have a version of this GPU that isn't whitelisted or something. I disabled any overclocking of the GPU just in case. I made sure I'm not running on battery and the slider is set at least to medium. I did some light poking around to see if I could confirm that my GPU was whitelisted and I couldn't find an exact match for the device ID displayed in GPU-Z. I saw the 640M in there, but not specifically 640M LE...
Here's the GPU-Z info if it helps...
Please let me know of any other info to provide. Thanks.
EDIT: Sidenote/possible issue. For some reason the clock speed seems to be locked in at 1197mhz. I would have expected it to be 2.5GHz. Not sure if there's a setting I can adjust, but I've set the laptop for maximum power and tried adjusting some process priorities but nothing seems to change it. Image
21:13:01:WU00:FS00:0xa7:*********************** Log Started 2020-05-13T21:13:01Z ***********************
21:13:01:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:13:01:WU00:FS00:0xa7:       Type: 0xa7
21:13:01:WU00:FS00:0xa7:       Core: Gromacs
21:13:01:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3808 -checkpoint 15 -np 1
21:13:01:WU00:FS00:0xa7:************************************ CBang *************************************
21:13:01:WU00:FS00:0xa7:       Date: Oct 26 2019"
21:13:01:WU00:FS00:0xa7:       Time: 01:38:25
21:13:01:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:13:01:WU00:FS00:0xa7:     Branch: master
21:13:01:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:13:01:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:13:01:WU00:FS00:0xa7:   Platform: win32 10
21:13:01:WU00:FS00:0xa7:       Bits: 64
21:13:01:WU00:FS00:0xa7:       Mode: Release
21:13:01:WU00:FS00:0xa7:************************************ System ************************************
21:13:01:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:13:01:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:13:01:WU00:FS00:0xa7:       CPUs: 4
21:13:01:WU00:FS00:0xa7:     Memory: 5.90GiB
21:13:01:WU00:FS00:0xa7:Free Memory: 3.46GiB
21:13:01:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:13:01:WU00:FS00:0xa7: OS Version: 6.2
21:13:01:WU00:FS00:0xa7:Has Battery: true
21:13:01:WU00:FS00:0xa7: On Battery: false
21:13:01:WU00:FS00:0xa7: UTC Offset: -4
21:13:01:WU00:FS00:0xa7:        PID: 1232
21:13:01:WU00:FS00:0xa7:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:13:01:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:13:01:WU00:FS00:0xa7:    Version: 0.0.18
21:13:01:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:13:01:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:13:01:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:13:01:WU00:FS00:0xa7:       Time: 01:52:30
21:13:01:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:13:01:WU00:FS00:0xa7:************************************ Build *************************************
21:13:02:WU00:FS00:0xa7:       SIMD: avx_256
21:13:02:WU00:FS00:0xa7:********************************************************************************
21:13:02:WU00:FS00:0xa7:Project: 16428 (Run 922, Clone 2, Gen 36)
21:13:02:WU00:FS00:0xa7:Unit: 0x0000002980fccb015ea74ea32f2fafc6
21:13:02:WU00:FS00:0xa7:Digital signatures verified
21:13:02:WU00:FS00:0xa7:Calling: mdrun -s frame36.tpr -o frame36.trr -x frame36.xtc -cpi state.cpt -cpt 15 -nt 1
21:13:02:WU00:FS00:0xa7:Steps: first=18000000 total=500000
21:13:02:WU00:FS00:0xa7:Completed 32062 out of 500000 steps (6%)
21:13:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
21:13:22:WU02:FS01:Connecting to 3.133.76.19:80
21:14:09:ERROR:WU02:FS01:Exception: Server did not assign work unit
21:14:38:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:14:38:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:14:38:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:14:39:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:14:39:WU02:FS01:Connecting to assign3.foldingathome.org:80
21:14:39:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:14:39:WU02:FS01:Connecting to assign4.foldingathome.org:80
21:14:39:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:14:39:ERROR:WU02:FS01:Exception: Could not get an assignment
21:15:22:FS00:Shutting core down
21:15:22:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 1232
21:15:22:WU00:FS00:0xa7:Exiting, please wait. . .
21:15:25:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:15:25:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:15:25:WU00:FS00:Starting
21:15:25:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
21:15:25:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
21:15:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -np 1
21:15:25:WU00:FS00:Started FahCore on PID 5500
21:15:25:WU00:FS00:Core PID:9264
21:15:25:WU00:FS00:FahCore 0xa7 started
21:15:26:WU00:FS00:0xa7:*********************** Log Started 2020-05-13T21:15:26Z ***********************
21:15:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:15:26:WU00:FS00:0xa7:       Type: 0xa7
21:15:26:WU00:FS00:0xa7:       Core: Gromacs
21:15:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5500 -checkpoint 15 -np 1
21:15:26:WU00:FS00:0xa7:************************************ CBang *************************************
21:15:26:WU00:FS00:0xa7:       Date: Oct 26 2019
21:15:26:WU00:FS00:0xa7:       Time: 01:38:25
21:15:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:15:26:WU00:FS00:0xa7:     Branch: master
21:15:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:15:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:15:26:WU00:FS00:0xa7:   Platform: win32 10
21:15:26:WU00:FS00:0xa7:       Bits: 64
21:15:26:WU00:FS00:0xa7:       Mode: Release
21:15:26:WU00:FS00:0xa7:************************************ System ************************************
21:15:26:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:15:26:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:15:26:WU00:FS00:0xa7:       CPUs: 4
21:15:26:WU00:FS00:0xa7:     Memory: 5.90GiB
21:15:26:WU00:FS00:0xa7:Free Memory: 3.42GiB
21:15:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:15:26:WU00:FS00:0xa7: OS Version: 6.2
21:15:26:WU00:FS00:0xa7:Has Battery: true
21:15:26:WU00:FS00:0xa7: On Battery: false
21:15:26:WU00:FS00:0xa7: UTC Offset: -4
21:15:26:WU00:FS00:0xa7:        PID: 9264
21:15:26:WU00:FS00:0xa7:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:15:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:15:26:WU00:FS00:0xa7:    Version: 0.0.18
21:15:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:15:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:15:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:15:26:WU00:FS00:0xa7:       Time: 01:52:30
21:15:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:15:26:WU00:FS00:0xa7:************************************ Build *************************************
21:15:26:WU00:FS00:0xa7:       SIMD: avx_256
21:15:26:WU00:FS00:0xa7:********************************************************************************
21:15:26:WU00:FS00:0xa7:Project: 16428 (Run 922, Clone 2, Gen 36)
21:15:26:WU00:FS00:0xa7:Unit: 0x0000002980fccb015ea74ea32f2fafc6
21:15:26:WU00:FS00:0xa7:Digital signatures verified
21:15:26:WU00:FS00:0xa7:Calling: mdrun -s frame36.tpr -o frame36.trr -x frame36.xtc -cpi state.cpt -cpt 15 -nt 1
21:15:26:WU00:FS00:0xa7:Steps: first=18000000 total=500000
21:15:27:WU00:FS00:0xa7:Completed 32732 out of 500000 steps (6%)
21:15:47:FS00:Shutting core down
21:15:47:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 9264
21:15:47:WU00:FS00:0xa7:Exiting, please wait. . .
21:15:49:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:15:49:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:16:14:Saving configuration to config.xml
21:16:14:<config>
21:16:14:  <!-- Network -->
21:16:14:  <proxy v=':8080'/>
21:16:14:
21:16:14:  <!-- Slot Control -->
21:16:14:  <power v='full'/>
21:16:14:
21:16:14:  <!-- User Information -->
21:16:14:  <passkey v='*****'/>
21:16:14:  <team v='225605'/>
21:16:14:  <user v='Fruban'/>
21:16:14:
21:16:14:  <!-- Folding Slots -->
21:16:14:  <slot id='0' type='CPU'>
21:16:14:    <idle v='true'/>
21:16:14:  </slot>
21:16:14:  <slot id='1' type='GPU'>
21:16:14:  </slot>
21:16:14:</config>
21:17:04:FS00:Paused
21:17:04:FS01:Paused
21:17:15:Saving configuration to config.xml
21:17:15:<config>
21:17:15:  <!-- Network -->
21:17:15:  <proxy v=':8080'/>
21:17:15:
21:17:15:  <!-- Slot Control -->
21:17:15:  <power v='full'/>
21:17:15:
21:17:15:  <!-- User Information -->
21:17:15:  <passkey v='*****'/>
21:17:15:  <team v='225605'/>
21:17:15:  <user v='Fruban'/>
21:17:15:
21:17:15:  <!-- Folding Slots -->
21:17:15:  <slot id='0' type='CPU'>
21:17:15:    <paused v='true'/>
21:17:15:  </slot>
21:17:15:  <slot id='1' type='GPU'>
21:17:15:  </slot>
21:17:15:</config>
21:17:58:4:127.0.0.1:New Web session
21:18:13:FS00:Unpaused
21:18:13:FS01:Unpaused
21:18:13:WU00:FS00:Starting
21:18:13:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
21:18:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -np 1
21:18:13:WU00:FS00:Started FahCore on PID 9000
21:18:14:WU00:FS00:Core PID:3808
21:18:14:WU00:FS00:FahCore 0xa7 started
21:18:14:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:18:14:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:18:14:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:18:14:WU00:FS00:0xa7:*********************** Log Started 2020-05-13T21:18:14Z ***********************
21:18:14:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:18:14:WU00:FS00:0xa7:       Type: 0xa7
21:18:14:WU00:FS00:0xa7:       Core: Gromacs
21:18:14:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9000 -checkpoint 15 -np 1
21:18:14:WU00:FS00:0xa7:************************************ CBang *************************************
21:18:14:WU00:FS00:0xa7:       Date: Oct 26 2019
21:18:14:WU00:FS00:0xa7:       Time: 01:38:25
21:18:14:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:18:14:WU00:FS00:0xa7:     Branch: master
21:18:14:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:18:14:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:18:14:WU00:FS00:0xa7:   Platform: win32 10
21:18:14:WU00:FS00:0xa7:       Bits: 64
21:18:14:WU00:FS00:0xa7:       Mode: Release
21:18:14:WU00:FS00:0xa7:************************************ System ************************************
21:18:14:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:18:14:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:18:14:WU00:FS00:0xa7:       CPUs: 4
21:18:14:WU00:FS00:0xa7:     Memory: 5.90GiB
21:18:14:WU00:FS00:0xa7:Free Memory: 2.92GiB
21:18:14:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:18:14:WU00:FS00:0xa7: OS Version: 6.2
21:18:14:WU00:FS00:0xa7:Has Battery: true
21:18:14:WU00:FS00:0xa7: On Battery: false
21:18:14:WU02:FS01:Assigned to work server 140.163.4.241
21:18:14:WU00:FS00:0xa7: UTC Offset: -4
21:18:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 140.163.4.241
21:18:14:WU00:FS00:0xa7:        PID: 3808
21:18:14:WU02:FS01:Connecting to 140.163.4.241:8080
21:18:14:WU00:FS00:0xa7:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:18:14:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:18:14:WU00:FS00:0xa7:    Version: 0.0.18
21:18:14:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:18:14:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:18:14:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:18:14:WU00:FS00:0xa7:       Time: 01:52:30
21:18:14:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:18:14:WU00:FS00:0xa7:************************************ Build *************************************
21:18:14:WU00:FS00:0xa7:       SIMD: avx_256
21:18:14:WU00:FS00:0xa7:********************************************************************************
21:18:14:WU00:FS00:0xa7:Project: 16428 (Run 922, Clone 2, Gen 36)
21:18:14:WU00:FS00:0xa7:Unit: 0x0000002980fccb015ea74ea32f2fafc6
21:18:14:WU00:FS00:0xa7:Digital signatures verified
21:18:14:WU00:FS00:0xa7:Calling: mdrun -s frame36.tpr -o frame36.trr -x frame36.xtc -cpi state.cpt -cpt 15 -nt 1
21:18:14:WU00:FS00:0xa7:Steps: first=18000000 total=500000
21:18:15:WU00:FS00:0xa7:Completed 32832 out of 500000 steps (6%)
21:18:16:Saving configuration to config.xml
21:18:16:<config>
21:18:16:  <!-- Network -->
21:18:16:  <proxy v=':8080'/>
21:18:16:
21:18:16:  <!-- Slot Control -->
21:18:16:  <power v='full'/>
21:18:16:
21:18:16:  <!-- User Information -->
21:18:16:  <passkey v='*****'/>
21:18:16:  <team v='225605'/>
21:18:16:  <user v='Fruban'/>
21:18:16:
21:18:16:  <!-- Folding Slots -->
21:18:16:  <slot id='0' type='CPU'/>
21:18:16:  <slot id='1' type='GPU'/>
21:18:16:</config>
21:18:27:WU02:FS01:Downloading 4.53MiB
21:18:28:WU02:FS01:Download complete
21:18:28:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:1695 gen:89 core:0x22 unit:0x0000008d8ca304f15e67da3896c2bde0
21:18:28:WU02:FS01:Starting
21:18:28:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:18:28:WU02:FS01:Started FahCore on PID 7172
21:18:29:WU02:FS01:Core PID:7124
21:18:29:WU02:FS01:FahCore 0x22 started
21:18:29:WU02:FS01:0x22:*********************** Log Started 2020-05-13T21:18:29Z ***********************
21:18:29:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:18:29:WU02:FS01:0x22:       Type: 0x22
21:18:29:WU02:FS01:0x22:       Core: Core22
21:18:29:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:18:29:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:18:29:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:18:29:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:18:29:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 7172 -checkpoint 15
21:18:29:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:18:29:WU02:FS01:0x22:             0 -gpu 0
21:18:29:WU02:FS01:0x22:     Config: <none>
21:18:29:WU02:FS01:0x22:************************************ Build *************************************
21:18:29:WU02:FS01:0x22:    Version: 0.0.5
21:18:29:WU02:FS01:0x22:       Date: Apr 22 2020
21:18:29:WU02:FS01:0x22:       Time: 04:42:59
21:18:29:WU02:FS01:0x22: Repository: Git
21:18:29:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:18:29:WU02:FS01:0x22:     Branch: HEAD
21:18:29:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:18:29:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:18:29:WU02:FS01:0x22:   Platform: win32 10
21:18:29:WU02:FS01:0x22:       Bits: 64
21:18:29:WU02:FS01:0x22:       Mode: Release
21:18:29:WU02:FS01:0x22:************************************ System ************************************
21:18:29:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:18:29:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:18:29:WU02:FS01:0x22:       CPUs: 4
21:18:29:WU02:FS01:0x22:     Memory: 5.90GiB
21:18:29:WU02:FS01:0x22:Free Memory: 2.89GiB
21:18:29:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:18:29:WU02:FS01:0x22: OS Version: 6.2
21:18:29:WU02:FS01:0x22:Has Battery: true
21:18:29:WU02:FS01:0x22: On Battery: false
21:18:29:WU02:FS01:0x22: UTC Offset: -4
21:18:29:WU02:FS01:0x22:        PID: 7124
21:18:29:WU02:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:18:29:WU02:FS01:0x22:         OS: Windows 10 Pro
21:18:29:WU02:FS01:0x22:    OS Arch: AMD64
21:18:29:WU02:FS01:0x22:********************************************************************************
21:18:29:WU02:FS01:0x22:Project: 11742 (Run 0, Clone 1695, Gen 89)
21:18:29:WU02:FS01:0x22:Unit: 0x0000008d8ca304f15e67da3896c2bde0
21:18:29:WU02:FS01:0x22:Reading tar file core.xml
21:18:29:WU02:FS01:0x22:Reading tar file integrator.xml
21:18:29:WU02:FS01:0x22:Reading tar file state.xml
21:18:31:WU02:FS01:0x22:Reading tar file system.xml
21:18:32:WU02:FS01:0x22:Digital signatures verified
21:18:32:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:18:32:WU02:FS01:0x22:Version 0.0.5
21:18:48:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:18:48:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:18:48:WU02:FS01:0x22:Saving result file science.log
21:18:48:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:18:49:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:18:49:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11742 run:0 clone:1695 gen:89 core:0x22 unit:0x0000008d8ca304f15e67da3896c2bde0
21:18:49:WU02:FS01:Uploading 2.63KiB to 140.163.4.241
21:18:49:WU02:FS01:Connecting to 140.163.4.241:8080
21:18:49:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:18:49:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:18:49:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:18:50:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:18:50:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:18:50:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:18:50:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:18:50:WU01:FS01:Assigned to work server 140.163.4.231
21:18:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 140.163.4.231
21:18:50:WU01:FS01:Connecting to 140.163.4.231:8080
21:19:03:WU02:FS01:Upload complete
21:19:03:WU02:FS01:Server responded WORK_ACK (400)
21:19:03:WU02:FS01:Cleaning up
21:22:09:WU01:FS01:Downloading 4.53MiB
21:22:12:WU01:FS01:Download complete
21:22:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:3676 gen:23 core:0x22 unit:0x000000318ca304e75e6a7ff36678b766
21:22:12:WU01:FS01:Starting
21:22:12:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:22:12:WU01:FS01:Started FahCore on PID 9980
21:22:12:WU01:FS01:Core PID:596
21:22:12:WU01:FS01:FahCore 0x22 started
21:22:12:WU01:FS01:0x22:*********************** Log Started 2020-05-13T21:22:12Z ***********************
21:22:12:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:22:12:WU01:FS01:0x22:       Type: 0x22
21:22:13:WU01:FS01:0x22:       Core: Core22
21:22:13:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:22:13:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:22:13:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:22:13:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:22:13:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9980 -checkpoint 15
21:22:13:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:22:13:WU01:FS01:0x22:             0 -gpu 0
21:22:13:WU01:FS01:0x22:     Config: <none>
21:22:13:WU01:FS01:0x22:************************************ Build *************************************
21:22:13:WU01:FS01:0x22:    Version: 0.0.5
21:22:13:WU01:FS01:0x22:       Date: Apr 22 2020
21:22:13:WU01:FS01:0x22:       Time: 04:42:59
21:22:13:WU01:FS01:0x22: Repository: Git
21:22:13:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:22:13:WU01:FS01:0x22:     Branch: HEAD
21:22:13:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:22:13:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:22:13:WU01:FS01:0x22:   Platform: win32 10
21:22:13:WU01:FS01:0x22:       Bits: 64
21:22:13:WU01:FS01:0x22:       Mode: Release
21:22:13:WU01:FS01:0x22:************************************ System ************************************
21:22:13:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:22:13:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:22:13:WU01:FS01:0x22:       CPUs: 4
21:22:13:WU01:FS01:0x22:     Memory: 5.90GiB
21:22:13:WU01:FS01:0x22:Free Memory: 2.99GiB
21:22:13:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:22:13:WU01:FS01:0x22: OS Version: 6.2
21:22:13:WU01:FS01:0x22:Has Battery: true
21:22:13:WU01:FS01:0x22: On Battery: false
21:22:13:WU01:FS01:0x22: UTC Offset: -4
21:22:13:WU01:FS01:0x22:        PID: 596
21:22:13:WU01:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:22:13:WU01:FS01:0x22:         OS: Windows 10 Pro
21:22:13:WU01:FS01:0x22:    OS Arch: AMD64
21:22:13:WU01:FS01:0x22:********************************************************************************
21:22:13:WU01:FS01:0x22:Project: 11748 (Run 0, Clone 3676, Gen 23)
21:22:13:WU01:FS01:0x22:Unit: 0x000000318ca304e75e6a7ff36678b766
21:22:13:WU01:FS01:0x22:Reading tar file core.xml
21:22:13:WU01:FS01:0x22:Reading tar file integrator.xml
21:22:13:WU01:FS01:0x22:Reading tar file state.xml
21:22:15:WU01:FS01:0x22:Reading tar file system.xml
21:22:16:WU01:FS01:0x22:Digital signatures verified
21:22:16:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:22:16:WU01:FS01:0x22:Version 0.0.5
21:22:29:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:22:29:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:22:30:WU01:FS01:0x22:Saving result file science.log
21:22:30:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:22:30:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:22:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11748 run:0 clone:3676 gen:23 core:0x22 unit:0x000000318ca304e75e6a7ff36678b766
21:22:30:WU01:FS01:Uploading 2.63KiB to 140.163.4.231
21:22:30:WU01:FS01:Connecting to 140.163.4.231:8080
21:22:31:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:22:31:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:22:31:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:22:31:WU02:FS01:Assigned to work server 3.133.76.19
21:22:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
21:22:31:WU02:FS01:Connecting to 3.133.76.19:8080
21:22:52:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
21:22:52:WU02:FS01:Connecting to 3.133.76.19:80
21:23:13:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:23:13:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:23:14:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:23:14:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:23:14:WU02:FS01:Assigned to work server 128.252.203.1
21:23:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 128.252.203.1
21:23:14:WU02:FS01:Connecting to 128.252.203.1:8080
21:23:14:ERROR:WU02:FS01:Exception: Server did not assign work unit
21:24:13:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:24:14:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:24:14:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:24:14:WU02:FS01:Assigned to work server 128.252.203.2
21:24:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 128.252.203.2
21:24:14:WU02:FS01:Connecting to 128.252.203.2:8080
21:24:57:WU01:FS01:Upload complete
21:24:57:WU01:FS01:Server responded WORK_ACK (400)
21:24:57:WU01:FS01:Cleaning up
21:25:08:WU02:FS01:Downloading 33.07MiB
21:25:14:WU02:FS01:Download 66.15%
21:25:21:WU02:FS01:Download 73.15%
21:25:24:WU02:FS01:Download complete
21:25:24:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14561 run:0 clone:1466 gen:40 core:0x22 unit:0x0000003680fccb025e9615bf7a392393
21:25:24:WU02:FS01:Starting
21:25:24:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:25:24:WU02:FS01:Started FahCore on PID 7416
21:25:24:WU02:FS01:Core PID:9256
21:25:24:WU02:FS01:FahCore 0x22 started
21:25:24:WU02:FS01:0x22:*********************** Log Started 2020-05-13T21:25:24Z ***********************
21:25:24:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:25:24:WU02:FS01:0x22:       Type: 0x22
21:25:24:WU02:FS01:0x22:       Core: Core22
21:25:24:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:25:24:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:25:24:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:25:24:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:25:24:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15
21:25:24:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:25:24:WU02:FS01:0x22:             0 -gpu 0
21:25:24:WU02:FS01:0x22:     Config: <none>
21:25:24:WU02:FS01:0x22:************************************ Build *************************************
21:25:24:WU02:FS01:0x22:    Version: 0.0.5
21:25:24:WU02:FS01:0x22:       Date: Apr 22 2020
21:25:24:WU02:FS01:0x22:       Time: 04:42:59
21:25:24:WU02:FS01:0x22: Repository: Git
21:25:24:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:25:24:WU02:FS01:0x22:     Branch: HEAD
21:25:24:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:25:24:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:25:24:WU02:FS01:0x22:   Platform: win32 10
21:25:24:WU02:FS01:0x22:       Bits: 64
21:25:24:WU02:FS01:0x22:       Mode: Release
21:25:24:WU02:FS01:0x22:************************************ System ************************************
21:25:25:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:25:25:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:25:25:WU02:FS01:0x22:       CPUs: 4
21:25:25:WU02:FS01:0x22:     Memory: 5.90GiB
21:25:25:WU02:FS01:0x22:Free Memory: 3.39GiB
21:25:25:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:25:25:WU02:FS01:0x22: OS Version: 6.2
21:25:25:WU02:FS01:0x22:Has Battery: true
21:25:25:WU02:FS01:0x22: On Battery: false
21:25:25:WU02:FS01:0x22: UTC Offset: -4
21:25:25:WU02:FS01:0x22:        PID: 9256
21:25:25:WU02:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:25:25:WU02:FS01:0x22:         OS: Windows 10 Pro
21:25:25:WU02:FS01:0x22:    OS Arch: AMD64
21:25:25:WU02:FS01:0x22:********************************************************************************
21:25:25:WU02:FS01:0x22:Project: 14561 (Run 0, Clone 1466, Gen 40)
21:25:25:WU02:FS01:0x22:Unit: 0x0000003680fccb025e9615bf7a392393
21:25:25:WU02:FS01:0x22:Reading tar file core.xml
21:25:25:WU02:FS01:0x22:Reading tar file integrator.xml
21:25:25:WU02:FS01:0x22:Reading tar file state.xml
21:25:40:WU02:FS01:0x22:Reading tar file system.xml
21:25:49:WU02:FS01:0x22:Digital signatures verified
21:25:49:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:25:49:WU02:FS01:0x22:Version 0.0.5
21:26:35:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
21:27:26:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:27:26:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:27:26:WU02:FS01:0x22:Saving result file science.log
21:27:26:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:27:27:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:27:27:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14561 run:0 clone:1466 gen:40 core:0x22 unit:0x0000003680fccb025e9615bf7a392393
21:27:27:WU02:FS01:Uploading 2.65KiB to 128.252.203.2
21:27:27:WU02:FS01:Connecting to 128.252.203.2:8080
21:27:27:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:27:27:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:27:27:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:27:28:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:27:28:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:27:28:WU01:FS01:Assigned to work server 3.133.76.19
21:27:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
21:27:28:WU01:FS01:Connecting to 3.133.76.19:8080
21:27:36:WU02:FS01:Upload 100.00%
21:27:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:27:49:WU01:FS01:Connecting to 3.133.76.19:80
21:28:10:ERROR:WU01:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:28:11:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:28:11:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:28:11:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:28:11:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:28:11:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:28:11:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:28:11:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:28:12:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
21:28:12:ERROR:WU01:FS01:Exception: Could not get an assignment
21:28:18:WU02:FS01:Upload complete
21:28:18:WU02:FS01:Server responded WORK_ACK (400)
21:28:18:WU02:FS01:Cleaning up
21:29:11:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:29:11:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:29:11:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:29:11:WU01:FS01:Assigned to work server 128.252.203.1
21:29:11:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 128.252.203.1
21:29:11:WU01:FS01:Connecting to 128.252.203.1:8080
21:29:18:WU01:FS01:Downloading 22.48MiB
21:29:23:WU01:FS01:Download complete
21:29:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16441 run:518 clone:4 gen:4 core:0x22 unit:0x0000000580fccb015ea997ff6a633d34
21:29:23:WU01:FS01:Starting
21:29:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:29:23:WU01:FS01:Started FahCore on PID 6932
21:29:23:WU01:FS01:Core PID:7468
21:29:23:WU01:FS01:FahCore 0x22 started
21:29:24:WU01:FS01:0x22:*********************** Log Started 2020-05-13T21:29:23Z ***********************
21:29:24:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:29:24:WU01:FS01:0x22:       Type: 0x22
21:29:24:WU01:FS01:0x22:       Core: Core22
21:29:24:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:29:24:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:29:24:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:29:24:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:29:24:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6932 -checkpoint 15
21:29:24:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:29:24:WU01:FS01:0x22:             0 -gpu 0
21:29:24:WU01:FS01:0x22:     Config: <none>
21:29:24:WU01:FS01:0x22:************************************ Build *************************************
21:29:24:WU01:FS01:0x22:    Version: 0.0.5
21:29:24:WU01:FS01:0x22:       Date: Apr 22 2020
21:29:24:WU01:FS01:0x22:       Time: 04:42:59
21:29:24:WU01:FS01:0x22: Repository: Git
21:29:24:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:29:24:WU01:FS01:0x22:     Branch: HEAD
21:29:24:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:29:24:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:29:24:WU01:FS01:0x22:   Platform: win32 10
21:29:24:WU01:FS01:0x22:       Bits: 64
21:29:24:WU01:FS01:0x22:       Mode: Release
21:29:24:WU01:FS01:0x22:************************************ System ************************************
21:29:24:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:29:24:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:29:24:WU01:FS01:0x22:       CPUs: 4
21:29:24:WU01:FS01:0x22:     Memory: 5.90GiB
21:29:24:WU01:FS01:0x22:Free Memory: 3.45GiB
21:29:24:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:29:24:WU01:FS01:0x22: OS Version: 6.2
21:29:24:WU01:FS01:0x22:Has Battery: true
21:29:24:WU01:FS01:0x22: On Battery: false
21:29:24:WU01:FS01:0x22: UTC Offset: -4
21:29:24:WU01:FS01:0x22:        PID: 7468
21:29:24:WU01:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:29:24:WU01:FS01:0x22:         OS: Windows 10 Pro
21:29:24:WU01:FS01:0x22:    OS Arch: AMD64
21:29:24:WU01:FS01:0x22:********************************************************************************
21:29:24:WU01:FS01:0x22:Project: 16441 (Run 518, Clone 4, Gen 4)
21:29:24:WU01:FS01:0x22:Unit: 0x0000000580fccb015ea997ff6a633d34
21:29:24:WU01:FS01:0x22:Reading tar file core.xml
21:29:24:WU01:FS01:0x22:Reading tar file integrator.xml
21:29:24:WU01:FS01:0x22:Reading tar file state.xml
21:29:27:WU01:FS01:0x22:Reading tar file system.xml
21:29:30:WU01:FS01:0x22:Digital signatures verified
21:29:30:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:29:30:WU01:FS01:0x22:Version 0.0.5
21:30:22:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:30:22:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:30:22:WU01:FS01:0x22:Saving result file science.log
21:30:22:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:30:23:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:30:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:16441 run:518 clone:4 gen:4 core:0x22 unit:0x0000000580fccb015ea997ff6a633d34
21:30:23:WU01:FS01:Uploading 2.33KiB to 128.252.203.1
21:30:23:WU01:FS01:Connecting to 128.252.203.1:8080
21:30:23:WU02:FS01:Connecting to assign1.foldingathome.org:80
21:30:24:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:30:24:WU02:FS01:Connecting to assign2.foldingathome.org:80
21:30:24:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:30:24:WU02:FS01:Connecting to assign3.foldingathome.org:80
21:30:24:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:30:24:WU02:FS01:Connecting to assign4.foldingathome.org:80
21:30:24:WU02:FS01:Assigned to work server 140.163.4.241
21:30:24:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 140.163.4.241
21:30:24:WU02:FS01:Connecting to 140.163.4.241:8080
21:30:25:WU01:FS01:Upload complete
21:30:25:WU01:FS01:Server responded WORK_ACK (400)
21:30:25:WU01:FS01:Cleaning up
21:31:38:WU02:FS01:Downloading 11.98MiB
21:31:41:WU02:FS01:Download complete
21:31:41:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:1242 gen:84 core:0x22 unit:0x000000868ca304f15e67d7d85cfdf422
21:31:41:WU02:FS01:Starting
21:31:41:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:31:41:WU02:FS01:Started FahCore on PID 3412
21:31:41:WU02:FS01:Core PID:9512
21:31:41:WU02:FS01:FahCore 0x22 started
21:31:41:WU02:FS01:0x22:*********************** Log Started 2020-05-13T21:31:41Z ***********************
21:31:41:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:31:41:WU02:FS01:0x22:       Type: 0x22
21:31:41:WU02:FS01:0x22:       Core: Core22
21:31:41:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:31:41:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:31:41:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:31:41:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:31:41:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3412 -checkpoint 15
21:31:41:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:31:41:WU02:FS01:0x22:             0 -gpu 0
21:31:41:WU02:FS01:0x22:     Config: <none>
21:31:41:WU02:FS01:0x22:************************************ Build *************************************
21:31:41:WU02:FS01:0x22:    Version: 0.0.5
21:31:41:WU02:FS01:0x22:       Date: Apr 22 2020
21:31:41:WU02:FS01:0x22:       Time: 04:42:59
21:31:41:WU02:FS01:0x22: Repository: Git
21:31:41:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:31:41:WU02:FS01:0x22:     Branch: HEAD
21:31:41:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:31:41:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:31:41:WU02:FS01:0x22:   Platform: win32 10
21:31:41:WU02:FS01:0x22:       Bits: 64
21:31:41:WU02:FS01:0x22:       Mode: Release
21:31:41:WU02:FS01:0x22:************************************ System ************************************
21:31:41:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
21:31:41:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:31:41:WU02:FS01:0x22:       CPUs: 4
21:31:41:WU02:FS01:0x22:     Memory: 5.90GiB
21:31:41:WU02:FS01:0x22:Free Memory: 3.50GiB
21:31:41:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:31:41:WU02:FS01:0x22: OS Version: 6.2
21:31:41:WU02:FS01:0x22:Has Battery: true
21:31:41:WU02:FS01:0x22: On Battery: false
21:31:41:WU02:FS01:0x22: UTC Offset: -4
21:31:41:WU02:FS01:0x22:        PID: 9512
21:31:41:WU02:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
21:31:41:WU02:FS01:0x22:         OS: Windows 10 Pro
21:31:41:WU02:FS01:0x22:    OS Arch: AMD64
21:31:41:WU02:FS01:0x22:********************************************************************************
21:31:41:WU02:FS01:0x22:Project: 11741 (Run 0, Clone 1242, Gen 84)
21:31:41:WU02:FS01:0x22:Unit: 0x000000868ca304f15e67d7d85cfdf422
21:31:41:WU02:FS01:0x22:Reading tar file core.xml
21:31:41:WU02:FS01:0x22:Reading tar file integrator.xml
21:31:41:WU02:FS01:0x22:Reading tar file state.xml
21:31:47:WU02:FS01:0x22:Reading tar file system.xml
21:31:50:WU02:FS01:0x22:Digital signatures verified
21:31:50:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:31:50:WU02:FS01:0x22:Version 0.0.5
21:32:24:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:32:24:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:32:24:WU02:FS01:0x22:Saving result file science.log
21:32:24:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:32:25:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:32:25:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11741 run:0 clone:1242 gen:84 core:0x22 unit:0x000000868ca304f15e67d7d85cfdf422
21:32:25:WU02:FS01:Uploading 2.64KiB to 140.163.4.241
21:32:25:WU02:FS01:Connecting to 140.163.4.241:8080
21:32:25:WU02:FS01:Upload complete
21:32:25:WU02:FS01:Server responded WORK_ACK (400)
21:32:25:WU02:FS01:Cleaning up
21:32:25:WU01:FS01:Connecting to assign1.foldingathome.org:80
21:32:25:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
21:32:25:WU01:FS01:Connecting to assign2.foldingathome.org:80
21:32:26:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
21:32:26:WU01:FS01:Connecting to assign3.foldingathome.org:80
21:32:26:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
21:32:26:WU01:FS01:Connecting to assign4.foldingathome.org:80
21:32:26:WU01:FS01:Assigned to work server 3.133.76.19
21:32:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
21:32:26:WU01:FS01:Connecting to 3.133.76.19:8080
21:33:40:WU01:FS01:Downloading 9.20MiB
21:33:43:WU01:FS01:Download complete
21:33:43:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16433 run:821 clone:2 gen:15 core:0x22 unit:0x0000001803854c135e9a4efdfd65c9d0
21:33:43:WU01:FS01:Starting
21:33:43:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8536 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:33:43:WU01:FS01:Started FahCore on PID 8176
21:33:43:WU01:FS01:Core PID:7816
Fruban
Re: Issues getting nvidia 640M LE to fold on laptop
Post by Fruban »
Here's updated logs from today. I've noticed the GPU make it past 2% before I walk away, and then upon checking back in later it's been reset and I notice errors in the logs.
15:47:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11744 run:0 clone:9110 gen:102 core:0x22 unit:0x000000908ca304f15e6bc3f4d69290de
15:47:39:WU02:FS01:Uploading 2.64KiB to 140.163.4.241
15:47:39:WU02:FS01:Connecting to 140.163.4.241:8080
15:47:39:WU02:FS01:Upload complete
15:47:39:WU02:FS01:Server responded WORK_ACK (400)
15:47:39:WU02:FS01:Cleaning up
15:47:40:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:47:40:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:47:40:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:47:40:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:47:40:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:47:40:WU00:FS01:Assigned to work server 206.223.170.146
15:47:40:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 206.223.170.146
15:47:40:WU00:FS01:Connecting to 206.223.170.146:8080
15:47:47:ERROR:WU00:FS01:Exception: Server did not assign work unit
15:47:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:47:47:WU00:FS01:Assigned to work server 13.82.98.119
15:47:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 13.82.98.119
15:47:47:WU00:FS01:Connecting to 13.82.98.119:8080
15:48:09:ERROR:WU00:FS01:Exception: Server did not assign work unit
15:48:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:48:47:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:48:47:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:48:47:WU00:FS01:Assigned to work server 206.223.170.146
15:48:48:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 206.223.170.146
15:48:48:WU00:FS01:Connecting to 206.223.170.146:8080
15:48:48:WU00:FS01:Downloading 2.26MiB
15:48:49:WU00:FS01:Download complete
15:48:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14564 run:1325 clone:1 gen:4 core:0x22 unit:0x00000009cedfaa925eb08d3bb2468289
15:48:49:WU00:FS01:Starting
15:48:49:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11064 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:48:49:WU00:FS01:Started FahCore on PID 8104
15:48:49:WU00:FS01:Core PID:2284
15:48:49:WU00:FS01:FahCore 0x22 started
15:48:50:WU00:FS01:0x22:*********************** Log Started 2020-05-14T15:48:49Z ***********************
15:48:50:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:48:50:WU00:FS01:0x22:       Type: 0x22
15:48:50:WU00:FS01:0x22:       Core: Core22
15:48:50:WU00:FS01:0x22:    Website: https://foldingathome.org/
15:48:50:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:48:50:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:48:50:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:48:50:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8104 -checkpoint 15
15:48:50:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:48:50:WU00:FS01:0x22:             0 -gpu 0
15:48:50:WU00:FS01:0x22:     Config: <none>
15:48:50:WU00:FS01:0x22:************************************ Build *************************************
15:48:50:WU00:FS01:0x22:    Version: 0.0.5
15:48:50:WU00:FS01:0x22:       Date: Apr 22 2020
15:48:50:WU00:FS01:0x22:       Time: 04:42:59
15:48:50:WU00:FS01:0x22: Repository: Git
15:48:50:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:48:50:WU00:FS01:0x22:     Branch: HEAD
15:48:50:WU00:FS01:0x22:   Compiler: Visual C++ 2008
15:48:50:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:48:50:WU00:FS01:0x22:   Platform: win32 10
15:48:50:WU00:FS01:0x22:       Bits: 64
15:48:50:WU00:FS01:0x22:       Mode: Release
15:48:50:WU00:FS01:0x22:************************************ System ************************************
15:48:50:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
15:48:50:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:48:50:WU00:FS01:0x22:       CPUs: 4
15:48:50:WU00:FS01:0x22:     Memory: 5.90GiB
15:48:50:WU00:FS01:0x22:Free Memory: 2.03GiB
15:48:50:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
15:48:50:WU00:FS01:0x22: OS Version: 6.2
15:48:50:WU00:FS01:0x22:Has Battery: true
15:48:50:WU00:FS01:0x22: On Battery: false
15:48:50:WU00:FS01:0x22: UTC Offset: -4
15:48:50:WU00:FS01:0x22:        PID: 2284
15:48:50:WU00:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
15:48:50:WU00:FS01:0x22:         OS: Windows 10 Pro
15:48:50:WU00:FS01:0x22:    OS Arch: AMD64
15:48:50:WU00:FS01:0x22:********************************************************************************
15:48:50:WU00:FS01:0x22:Project: 14564 (Run 1325, Clone 1, Gen 4)
15:48:50:WU00:FS01:0x22:Unit: 0x00000009cedfaa925eb08d3bb2468289
15:48:50:WU00:FS01:0x22:Reading tar file core.xml
15:48:50:WU00:FS01:0x22:Reading tar file integrator.xml
15:48:50:WU00:FS01:0x22:Reading tar file state.xml
15:48:50:WU00:FS01:0x22:Reading tar file system.xml
15:48:50:WU00:FS01:0x22:Digital signatures verified
15:48:50:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:48:50:WU00:FS01:0x22:Version 0.0.5
15:48:59:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
15:48:59:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:48:59:WU00:FS01:0x22:Saving result file science.log
15:48:59:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:48:59:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:48:59:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14564 run:1325 clone:1 gen:4 core:0x22 unit:0x00000009cedfaa925eb08d3bb2468289
15:48:59:WU00:FS01:Uploading 2.33KiB to 206.223.170.146
15:48:59:WU00:FS01:Connecting to 206.223.170.146:8080
15:49:00:WU00:FS01:Upload complete
15:49:00:WU00:FS01:Server responded WORK_ACK (400)
15:49:00:WU00:FS01:Cleaning up
15:49:00:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:49:00:WU02:FS01:Assigned to work server 3.133.76.19
15:49:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
15:49:00:WU02:FS01:Connecting to 3.133.76.19:8080
15:49:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:49:21:WU02:FS01:Connecting to 3.133.76.19:80
15:49:42:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:49:43:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:49:43:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:49:43:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:49:43:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:49:43:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:49:43:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:49:43:WU02:FS01:Connecting to assign4.foldingathome.org:80
15:49:44:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:49:44:ERROR:WU02:FS01:Exception: Could not get an assignment
15:50:43:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:50:43:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:50:43:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:50:43:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:50:43:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:50:43:WU02:FS01:Assigned to work server 3.133.76.19
15:50:43:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
15:50:43:WU02:FS01:Connecting to 3.133.76.19:8080
15:51:04:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:51:04:WU02:FS01:Connecting to 3.133.76.19:80
15:52:02:WU02:FS01:Downloading 16.89MiB
15:52:04:WU02:FS01:Download complete
15:52:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:52:04:WU02:FS01:Starting
15:52:04:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 11064 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:52:04:WU02:FS01:Started FahCore on PID 4744
15:52:05:WU02:FS01:Core PID:5548
15:52:05:WU02:FS01:FahCore 0x22 started
15:52:05:WU02:FS01:0x22:*********************** Log Started 2020-05-14T15:52:05Z ***********************
15:52:05:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:52:05:WU02:FS01:0x22:       Type: 0x22
15:52:05:WU02:FS01:0x22:       Core: Core22
15:52:05:WU02:FS01:0x22:    Website: https://foldingathome.org/
15:52:05:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:52:05:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:52:05:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:52:05:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4744 -checkpoint 15
15:52:05:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:52:05:WU02:FS01:0x22:             0 -gpu 0
15:52:05:WU02:FS01:0x22:     Config: <none>
15:52:05:WU02:FS01:0x22:************************************ Build *************************************
15:52:05:WU02:FS01:0x22:    Version: 0.0.5
15:52:05:WU02:FS01:0x22:       Date: Apr 22 2020
15:52:05:WU02:FS01:0x22:       Time: 04:42:59
15:52:05:WU02:FS01:0x22: Repository: Git
15:52:05:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:52:05:WU02:FS01:0x22:     Branch: HEAD
15:52:05:WU02:FS01:0x22:   Compiler: Visual C++ 2008
15:52:05:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:52:05:WU02:FS01:0x22:   Platform: win32 10
15:52:05:WU02:FS01:0x22:       Bits: 64
15:52:05:WU02:FS01:0x22:       Mode: Release
15:52:05:WU02:FS01:0x22:************************************ System ************************************
15:52:05:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
15:52:05:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:52:05:WU02:FS01:0x22:       CPUs: 4
15:52:05:WU02:FS01:0x22:     Memory: 5.90GiB
15:52:05:WU02:FS01:0x22:Free Memory: 2.22GiB
15:52:05:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
15:52:05:WU02:FS01:0x22: OS Version: 6.2
15:52:05:WU02:FS01:0x22:Has Battery: true
15:52:05:WU02:FS01:0x22: On Battery: false
15:52:05:WU02:FS01:0x22: UTC Offset: -4
15:52:05:WU02:FS01:0x22:        PID: 5548
15:52:05:WU02:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
15:52:05:WU02:FS01:0x22:         OS: Windows 10 Pro
15:52:05:WU02:FS01:0x22:    OS Arch: AMD64
15:52:05:WU02:FS01:0x22:********************************************************************************
15:52:05:WU02:FS01:0x22:Project: 14439 (Run 0, Clone 257, Gen 14)
15:52:05:WU02:FS01:0x22:Unit: 0x0000001503854c135ea0a301d122394d
15:52:05:WU02:FS01:0x22:Reading tar file core.xml
15:52:05:WU02:FS01:0x22:Reading tar file integrator.xml
15:52:05:WU02:FS01:0x22:Reading tar file state.xml
15:52:08:WU02:FS01:0x22:Reading tar file system.xml
15:52:10:WU02:FS01:0x22:Digital signatures verified
15:52:10:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:52:10:WU02:FS01:0x22:Version 0.0.5
15:53:02:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
15:53:02:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
15:53:02:WU02:FS01:0x22:Saving result file science.log
15:53:02:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:53:03:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:53:03:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:53:03:WU02:FS01:Uploading 2.33KiB to 3.133.76.19
15:53:03:WU02:FS01:Connecting to 3.133.76.19:8080
15:53:04:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:53:04:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:53:04:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:53:04:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:53:04:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:53:04:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:53:04:WU00:FS01:Connecting to assign4.foldingathome.org:80
15:53:05:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:53:05:ERROR:WU00:FS01:Exception: Could not get an assignment
15:53:05:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:53:05:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:53:05:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:53:05:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:53:05:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:53:06:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:53:06:WU00:FS01:Connecting to assign4.foldingathome.org:80
15:53:06:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:53:06:ERROR:WU00:FS01:Exception: Could not get an assignment
15:53:24:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:53:24:WU02:FS01:Connecting to 3.133.76.19:80
15:53:45:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:53:45:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:53:45:WU02:FS01:Uploading 2.33KiB to 3.133.76.19
15:53:46:WU02:FS01:Connecting to 3.133.76.19:8080
15:54:05:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:54:05:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:54:05:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:54:05:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:54:05:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:54:06:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:54:06:WU00:FS01:Connecting to assign4.foldingathome.org:80
15:54:06:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:54:06:ERROR:WU00:FS01:Exception: Could not get an assignment
15:54:07:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:54:07:WU02:FS01:Connecting to 3.133.76.19:80
15:54:28:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:54:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:54:46:WU02:FS01:Uploading 2.33KiB to 3.133.76.19
15:54:46:WU02:FS01:Connecting to 3.133.76.19:8080
15:55:07:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:55:07:WU02:FS01:Connecting to 3.133.76.19:80
15:55:28:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:55:42:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:55:42:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:55:42:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:55:43:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:55:43:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:55:43:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:55:43:WU00:FS01:Connecting to assign4.foldingathome.org:80
15:55:43:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:55:43:ERROR:WU00:FS01:Exception: Could not get an assignment
15:56:23:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:56:23:WU02:FS01:Uploading 2.33KiB to 3.133.76.19
15:56:23:WU02:FS01:Connecting to 3.133.76.19:8080
15:56:44:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:56:44:WU02:FS01:Connecting to 3.133.76.19:80
15:57:05:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:58:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
15:58:20:WAR
15:58:20:WU00:FS01:Connecting to assign2.foldingathome.org:80
15:58:20:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:58:20:WU00:FS01:Connecting to assign3.foldingathome.org:80
15:58:20:WU00:FS01:Assigned to work server 3.133.76.19
15:58:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 3.133.76.19
15:58:20:WU00:FS01:Connecting to 3.133.76.19:8080
15:58:41:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:58:41:WU00:FS01:Connecting to 3.133.76.19:80
15:59:00:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14439 run:0 clone:257 gen:14 core:0x22 unit:0x0000001503854c135ea0a301d122394d
15:59:00:WU02:FS01:Uploading 2.33KiB to 3.133.76.19
15:59:00:WU02:FS01:Connecting to 3.133.76.19:8080
15:59:02:ERROR:WU00:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:59:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:59:21:WU02:FS01:Connecting to 3.133.76.19:80
15:59:24:WU02:FS01:Upload 100.00%
16:00:22:WU02:FS01:Upload complete
16:00:22:WU02:FS01:Server responded WORK_ACK (400)
16:00:22:WU02:FS01:Cleaning up
16:02:34:WU00:FS01:Connecting to assign1.foldingathome.org:80
16:02:34:WU00:FS01:Assigned to work server 13.82.98.119
16:02:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 13.82.98.119
16:02:34:WU00:FS01:Connecting to 13.82.98.119:8080
16:02:44:ERROR:WU00:FS01:Exception: Server did not assign work unit
16:09:25:WU00:FS01:Connecting to assign1.foldingathome.org:80
16:09:25:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:09:26:WU00:FS01:Connecting to assign2.foldingathome.org:80
16:09:26:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:09:26:WU00:FS01:Connecting to assign3.foldingathome.org:80
16:09:26:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:09:26:WU00:FS01:Connecting to assign4.foldingathome.org:80
16:09:26:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:09:26:ERROR:WU00:FS01:Exception: Could not get an assignment
16:20:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
16:20:31:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:20:31:WU00:FS01:Connecting to assign2.foldingathome.org:80
16:20:31:WU00:FS01:Assigned to work server 140.163.4.231
16:20:31:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK107 [GeForce GT 640M] from 140.163.4.231
16:20:31:WU00:FS01:Connecting to 140.163.4.231:8080
16:21:09:WU00:FS01:Downloading 7.92MiB
16:21:11:WU00:FS01:Download complete
16:21:11:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:5024 gen:19 core:0x22 unit:0x000000348ca304e75e6bbb083a080f5e
16:21:11:WU00:FS01:Starting
16:21:11:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Fruban\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11064 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:21:11:WU00:FS01:Started FahCore on PID 11192
16:21:11:WU00:FS01:Core PID:2720
16:21:11:WU00:FS01:FahCore 0x22 started
16:21:12:WU00:FS01:0x22:*********************** Log Started 2020-05-14T16:21:11Z ***********************
16:21:12:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:21:12:WU00:FS01:0x22:       Type: 0x22
16:21:12:WU00:FS01:0x22:       Core: Core22
16:21:12:WU00:FS01:0x22:    Website: https://foldingathome.org/
16:21:12:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:21:12:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:21:12:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:21:12:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11192 -checkpoint 15
16:21:12:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:21:12:WU00:FS01:0x22:             0 -gpu 0
16:21:12:WU00:FS01:0x22:     Config: <none>
16:21:12:WU00:FS01:0x22:************************************ Build *************************************
16:21:12:WU00:FS01:0x22:    Version: 0.0.5
16:21:12:WU00:FS01:0x22:       Date: Apr 22 2020
16:21:12:WU00:FS01:0x22:       Time: 04:42:59
16:21:12:WU00:FS01:0x22: Repository: Git
16:21:12:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
16:21:12:WU00:FS01:0x22:     Branch: HEAD
16:21:12:WU00:FS01:0x22:   Compiler: Visual C++ 2008
16:21:12:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:21:12:WU00:FS01:0x22:   Platform: win32 10
16:21:12:WU00:FS01:0x22:       Bits: 64
16:21:12:WU00:FS01:0x22:       Mode: Release
16:21:12:WU00:FS01:0x22:************************************ System ************************************
16:21:12:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
16:21:12:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
16:21:12:WU00:FS01:0x22:       CPUs: 4
16:21:12:WU00:FS01:0x22:     Memory: 5.90GiB
16:21:12:WU00:FS01:0x22:Free Memory: 2.17GiB
16:21:12:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
16:21:12:WU00:FS01:0x22: OS Version: 6.2
16:21:12:WU00:FS01:0x22:Has Battery: true
16:21:12:WU00:FS01:0x22: On Battery: false
16:21:12:WU00:FS01:0x22: UTC Offset: -4
16:21:12:WU00:FS01:0x22:        PID: 2720
16:21:12:WU00:FS01:0x22:        CWD: C:\Users\Fruban\AppData\Roaming\FAHClient\work
16:21:12:WU00:FS01:0x22:         OS: Windows 10 Pro
16:21:12:WU00:FS01:0x22:    OS Arch: AMD64
16:21:12:WU00:FS01:0x22:********************************************************************************
16:21:12:WU00:FS01:0x22:Project: 11751 (Run 0, Clone 5024, Gen 19)
16:21:12:WU00:FS01:0x22:Unit: 0x000000348ca304e75e6bbb083a080f5e
16:21:12:WU00:FS01:0x22:Reading tar file core.xml
16:21:12:WU00:FS01:0x22:Reading tar file integrator.xml
16:21:12:WU00:FS01:0x22:Reading tar file state.xml
16:21:19:WU00:FS01:0x22:Reading tar file system.xml
16:21:22:WU00:FS01:0x22:Digital signatures verified
16:21:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:21:22:WU00:FS01:0x22:Version 0.0.5
16:22:31:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:22:31:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:33:34:Saving configuration to config.xml
16:33:34:<config>
16:33:34:  <!-- Folding Core -->
16:33:34:  <core-priority v='low'/>
16:33:34:
16:33:34:  <!-- HTTP Server -->
16:33:34:  <allow v='192.168.50.33'/>
16:33:34:
16:33:34:  <!-- Network -->
16:33:34:  <proxy v=':8080'/>
16:33:34:
16:33:34:  <!-- Remote Command Server -->
16:33:34:  <password v='*****'/>
16:33:34:
16:33:34:  <!-- Slot Control -->
16:33:34:  <power v='medium'/>
16:33:34:
16:33:34:  <!-- User Information -->
16:33:34:  <passkey v='*****'/>
16:33:34:  <team v='225605'/>
16:33:34:  <user v='Fruban'/>
16:33:34:
16:33:34:  <!-- Folding Slots -->
16:33:34:  <slot id='0' type='CPU'/>
16:33:34:  <slot id='1' type='GPU'/>
16:33:34:</config>
16:52:24:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
17:02:18:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/g ... 0m-le.c349
We could do a lot of work to make this work, just to watch it not be able to complete on time. 96 cores is going to be over 4 times slower than the least GPU you can buy the GTX 1030
The problem is that your laptop, (I don't know the model so I can't say for sure) probably uses a technology callled Optimus, which uses an Intel GPU normally, then switches to a Nvidia to do intense graphics. Since F@H does not support Intel GPUs, it fails before it has time to get intense.
https://www.geforce.com/hardware/techno ... technology
There is not one 'correct way' I can give you to disable the Intel GPU, back in my day it was in the BiIOS, later in the 3D part of the Nvidia control panel. Some one had luck running MsI Afterburner all the time. Like I say, I don't know what will work for you, but if you get it working, it may be too slow to finish.
If you want to pursue this, give us the first 200 lines of the log that have your configuration, that may help.
viewtopic.php?f=24&t=26036
The 640M LE may work better than expected from the Techpowerup article description. There was at least three different 640M chips released, 2 of them were based on the Kepler chip with 384 cores compared to the 96 for the one based on the Fermi in that writeup. From the GPU-Z report, you have one of the Keplr based chips.
As JimboPalmer mentions, the Optimus tech is the most likely source of your problem getting GPU folding to work. There have been a number of topics posted here on getting laptops with this in place to work on folding.
Fruban
Post by Fruban »
So I've got a Sony Vaio 2013 SVS15113fxs with a hard physical switch that turns off the intel integrated graphics and exclusively uses the GPU. Optimus does sound familiar, but I have it on the "speed" setting for that. I do wonder if it could still be causing issues somehow but I would be surprised. Stamina mode manually forces everything through the integrated graphics. When the GPU starts working on a unit in Advanced View, I noticed that while the GPU is running, the sensors indicate it is under load, 100% utilization and the GPU clock speeds are maxed. I don't believe the integrated graphics are being utilized based on the gpu sensors, but hey maybe it's still interfering somehow. I've noticed before the errors come up and it resets the work unit that the estimated times to finish on the GPU usually range from 24-48 hours.
I remember reading about how the LE had a more efficient architecture (kepler) allowing for some good overclocking for a laptop card at least. It factored into my purchase decision back then.
Does any of this info change anything?
(Right click and view image, it's cut off a bit)
Fruban
Post by Fruban »
I almost forgot! I enabled a BIOS level overclock on the GPU (via flashing) a while back that doubled it's core speed. If you look at the nvidia website, you'll notice the core clock is only 500mhz but gpu Z from the first post reports what the BIOS thinks is stock, even though its past factory settings. Never had any issues with stability in real world use/gaming though. I can even squeeze out a bit more in MSI afterburner from there, but I disabled OCing in afterburner for troubleshooting this.
Also including log config lines here....
*********************** Log Started 2020-05-14T18:30:30Z ***********************
18:30:30:Trying to access database...
18:30:30:Successfully acquired database lock
18:30:30:Read GPUs.txt
18:30:30:Enabled folding slot 00: PAUSED cpu:2 (on battery)
18:30:30:Enabled folding slot 01: PAUSED gpu:0:GK107 [GeForce GT 640M] (on battery)
18:30:30:****************************** FAHClient ******************************
18:30:30:        Version: 7.6.13
18:30:30:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:30:30:      Copyright: 2020 foldingathome.org
18:30:30:       Homepage: https://foldingathome.org/
18:30:30:           Date: Apr 27 2020
18:30:30:           Time: 21:21:01
18:30:30:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
18:30:30:         Branch: master
18:30:30:       Compiler: Visual C++ 2008
18:30:30:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:30:30:       Platform: win32 10
18:30:30:           Bits: 32
18:30:30:           Mode: Release
18:30:30:           Args: --open-web-control
18:30:30:         Config: C:\Users\Fruban\AppData\Roaming\FAHClient\config.xml
18:30:30:******************************** CBang ********************************
18:30:30:           Date: Apr 24 2020
18:30:30:           Time: 17:07:55
18:30:30:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
18:30:30:           Bits: 32
18:30:30:******************************* System ********************************
18:30:30:            CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
18:30:30:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:30:30:           CPUs: 4
18:30:30:         Memory: 5.90GiB
18:30:30:    Free Memory: 2.37GiB
18:30:30:        Threads: WINDOWS_THREADS
18:30:30:     OS Version: 6.2
18:30:30:    Has Battery: true
18:30:30:     On Battery: true
18:30:30:     UTC Offset: -4
18:30:30:            PID: 9568
18:30:30:            CWD: C:\Users\Fruban\AppData\Roaming\FAHClient
18:30:30:  Win32 Service: false
18:30:30:             OS: Windows 10 Pro
18:30:30:        OS Arch: AMD64
18:30:30:           GPUs: 1
18:30:30:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK107 [GeForce GT 640M]
18:30:30:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.1
18:30:30:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:425.31
18:30:30:OpenCL Device 2: Platform:1 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
18:30:30:******************************* libFAH ********************************
18:30:30:           Date: Apr 15 2020
18:30:30:           Time: 14:53:14
18:30:30:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:30:30:           Bits: 32
18:30:30:***********************************************************************
18:30:31:<config>
18:30:31:  <!-- Folding Core -->
18:30:31:  <core-priority v='low'/>
18:30:31:
18:30:31:  <!-- HTTP Server -->
18:30:31:  <allow v='192.168.50.33'/>
18:30:31:
18:30:31:  <!-- Network -->
18:30:31:  <proxy v=':8080'/>
18:30:31:
18:30:31:  <!-- Remote Command Server -->
18:30:31:  <password v='*****'/>
18:30:31:
18:30:31:  <!-- Slot Control -->
18:30:31:  <power v='medium'/>
18:30:31:
18:30:31:  <!-- User Information -->
18:30:31:  <passkey v='*****'/>
18:30:31:  <team v='225605'/>
18:30:31:  <user v='Fruban'/>
18:30:31:
18:30:31:  <!-- Folding Slots -->
18:30:31:  <slot id='0' type='CPU'>
18:30:31:    <cpus v='2'/>
18:30:31:  </slot>
18:30:31:  <slot id='1' type='GPU'/>
18:30:31:</config>
18:30:45:4:127.0.0.1:New Web session
Nvidia website specs for my card:
GPU Engine Specs:
Up to 384 coresCUDA Cores
Up to 500 MHzGraphics Clock (MHz)
Up to 16.0Texture Fill Rate (billion/sec)
Memory Specs:
DDR3\DDR5Memory Interface
128bitMemory Interface Width
Up to 28.8Memory Bandwidth (GB/sec)
Feature Support:
4.5OpenGL
1.1OpenCL
PCI Express 2.0, PCI Express 3.0Bus Support
YesCertified for Windows 7
DirectX 11, Optimus, PhysX, OpenCL, DirectCompute, 3D Vision, CUDASupported Technologies
12 APIDirectX
EDIT: As suggested, I found 3d global settings in the nvidia control panel and set the preferred processor to the GPU instead of auto, so maybe that will help too. :)
I'll run it for a bit with updated msi afterburner up and having switched global 3d settings and see if it still fails to complete and report back. If anyone sees anymore useful info in what I provided and have more suggestions then please by all means let me know. Thanks so far!
MeeLee
Post by MeeLee »
Yeah, the 640LE is a bit slower than what GPUz mentioned.
Even if your GPU runs at 1Ghz (Hoping your motherboard GPU, and battery aren't being fried), you can safely dial down the frequencies in MSI Afterburner.
Even if it runs at 1Ghz, setting it to 500Mhz, or a bit higher might work fine.
There is the GT-640M LE, or the 640M.
Best to check the manufacturer's specs on this GPU.
If you flashed the BIOS, there might be wrong info shown in GPUZ.
Fruban
Post by Fruban »
I've got the GT 640M LE. The BIOS hack locks it in at 1ghz so I can't go lower unless I flash the BIOS again. I managed to find the OP with the BIOS hack but I can't post URLs yet I don't think. However, if you google the title of the post Sony Vaio S Bios Mod For Gt640m LE it's there. I'm confident the GPU-Z info is correct; I spent many days tweaking, reflashing and testing the versions of the BIOS with higher core clocks on each. Although I don't use this laptop for much anymore, it's been set this way for years.
It's still slower than I expected for FaH but it hasn't failed since trying the above suggestions so far. Temps haven't gone above 70c on GPU or CPU yet either luckily, but I'm sticking to medium folding to be safe.
The ETA updated to 3-4 days(CPU) and 4-5 days (gpu) but it's still under the time limit to complete the current WUs. No fails, stops, or errors yet *knocks on wood*
(Edited to turn the bios hack OP Title into a URL tag)
Post by Neil-B »
... use the Full Editor, type/paste url then highlight and use the URL button at top of edit window to add URL tags :)
Fruban
Post by Fruban »
According to the new user rules I can't since I joined a day or two ago, but let's see what happens! Maybe I've posted enough now.
http://forum.notebookreview.com/threads ... le.677079/
Anywho, been letting the lappy run all night and the GPU ETA went down to about 3.5 days for a decent amount of points without error. Something seems to be working better now. If anymore issues occur, I'll post here. I pretty much only tried the suggestions I found in here so far so thanks to all for the tips and help! I have 4 active clients now.
(Edit: looks like it works! Also made tag in previous post from the OP title)
MeeLee
Post by MeeLee »
If you're folding on a laptop, it's probably best to disable CPU folding, when you have a GPU folding, simply because most laptops are created for occasional loads, not continuous loads.
Good laptops usually pass a CPU or GPU stress test, but very few actually can deal with both CPU and GPU stress tests at the same time.
I would suggest to install HWMonitor, and keep an eye on CPU and GPU temperatures.
Also, if you're able to open the laptop (or provide some extra cooling from the bottom), just to make sure your battery isn't being heated.
Temperatures and charged Lithium batteries is a recipe for disaster.
0x10de:0x0fd3: is supporfed as [GeForce GT 640M]
