On the F@H statistics page (https://foldingathome.org/statistics/) it says "The donor and team stats are updated every hour, although this can be delayed if there were a lot of work units to come back during that hour. "
But on the stats-teams-usernames page (https://foldingathome.org/support/faq/s ... usernames/) it says "These files are updated every 3 hours."
What is correct?
How often are stats updated? One hour? Three hours?
Re: How often are stats updated? One hour? Three hours?
I think it is 3 hours, I know EOC updates every 3 hours
https://folding.extremeoverclocking.com ... ary.php?s=
Stats seems to be updated more often, maybe once in an hour to varying degrees, EOC from stats database once in 3 hours.
They both are usually always late.
It doesn't matter in long term.
It does matter to me as I am building a folding site and want to know how often I should pull the stats files.TPL wrote:Stats seems to be updated more often, maybe once in an hour to varying degrees, EOC from stats database once in 3 hours.
So somewhere between one and three hours then.
There is an article on EOC Folding Stats pages where the person who runs it states it is currently every 3 hrs the main stats update …https://folding.extremeoverclocking.com/ … 2nd down article "Why do things break …"
They slowed the updates down to help the stats server load.
Crawdaddy79
Not sure if this is what you're looking for, but the text file for all stats is updated every three hours.
Buried here under "How can I get a copy of all current stats?": https://foldingathome.org/support/faq/s ... usernames/
There are two methods of obtaining the stats from foldingathome.org. You can query the database directly and you can download the flat-files. Those flat-files are generated explicitly for those who which to obtain up-to-date snapshots of the entire db. The other 3rd party stats sites do download the flat files every three hours. A direct query of the database should not be used in a script in an attempt to get more frequest updates.agrikk wrote:It does matter to me as I am building a folding site and want to know how often I should pull the stats files.
The stats are maintained in a massive database and the computer resources required to add each hour's updates can be delayed by excessive random queries.
