5 x 1070 only getting 400k ppd
Hi,
I've setup a passkey few weeks ago. I'm done more than 600 Wus and still no more than 400k ppd
Any1 know something about it?
- Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s with 2 Noctua B9 Redux 1600 92mm Fans
Gigabyte B550 Gaming X V2 Revision 1.3 BIOS version FFg
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+Bronze PSU
Terra - Active
Intel Core i5-4690K @ 4.20GHz with Vcore of 1.138v | Corsair H100i V2 with 2 Corsair SP120 120mm fans
Gigabyte Z87X-UD3H BIOS version 10b
Kingston HyperX Fury 4x4GB DDR3-1866 | Timings 9-10-9-28
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212 with Noctua NF-F12 120mm IPPC 3000 fan
Gigabyte X99-SOC Champion BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Need Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+Platinum PSU
All machines running F@H v8.4.9 - Location: Lincolnshire, UK
Re: 5 x 1070 only getting 400k ppd
We need to see the start of a logfile from one of the machines. Assuming you're using Windows the logfile is in %APPDATA%\FAHClient. We need the first 100 lines or so.
You should see something similar to
If you open Advanced Control (click on the folding icon in the system tray), then Configure, Identity. You should see a whole lot of black circles in the passkey box. Do you?
Your 5x1070 should be hitting 4m per day so you have something incorrectly setup.
10:33:55: <!-- User Information -->
10:33:55: <passkey v='*****'/>
10:33:55: <team v='131'/>
10:33:55: <user v='HaloJones'/>
single 1070
[list]*********************** Log Started 2020-05-14T03:40:23Z ***********************
03:40:23:****************************** FAHClient ******************************
03:40:23: Version: 7.6.9
03:40:23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:40:23: Copyright: 2020 foldingathome.org
03:40:23: Homepage: https://foldingathome.org/
03:40:23: Date: Apr 17 2020
03:40:23: Time: 11:13:06
03:40:23: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
03:40:23: Branch: master
03:40:23: Compiler: Visual C++ 2008
03:40:23: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:40:23: Platform: win32 10
03:40:23: Bits: 32
03:40:23: Mode: Release
03:40:23: Config: C:\Users\Utilisateur\AppData\Roaming\FAHClient\config.xml
03:40:23:******************************** CBang ********************************
03:40:23: Time: 11:10:09
03:40:23: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
03:40:23: Bits: 32
03:40:23:******************************* System ********************************
03:40:23: CPU: Intel(R) Celeron(R) CPU G3900 @ 2.80GHz
03:40:23: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:40:23: CPUs: 2
03:40:23: Memory: 3.93GiB
03:40:23: Free Memory: 1.96GiB
03:40:23: Threads: WINDOWS_THREADS
03:40:23: OS Version: 6.2
03:40:23: Has Battery: false
03:40:23: On Battery: false
03:40:23: UTC Offset: -4
03:40:23: PID: 9100
03:40:23: CWD: C:\Users\Utilisateur\AppData\Roaming\FAHClient
03:40:23: OS: Windows 10 Enterprise
03:40:23: OS Arch: AMD64
03:40:23: GPUs: 5
03:40:23: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
03:40:23: GPU 1: Bus:2 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
03:40:23: GPU 2: Bus:3 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
03:40:23: GPU 3: Bus:5 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
03:40:23: GPU 4: Bus:6 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
03:40:23: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
03:40:23: CUDA Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:6.1 Driver:10.2
03:40:23: CUDA Device 2: Platform:0 Device:2 Bus:3 Slot:0 Compute:6.1 Driver:10.2
03:40:23: CUDA Device 3: Platform:0 Device:3 Bus:5 Slot:0 Compute:6.1 Driver:10.2
03:40:23: CUDA Device 4: Platform:0 Device:4 Bus:6 Slot:0 Compute:6.1 Driver:10.2
03:40:23:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
03:40:23:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.87
03:40:23:OpenCL Device 3: Platform:1 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:441.87
03:40:23:OpenCL Device 4: Platform:1 Device:2 Bus:3 Slot:0 Compute:1.2 Driver:441.87
03:40:23:OpenCL Device 5: Platform:1 Device:3 Bus:5 Slot:0 Compute:1.2 Driver:441.87
03:40:23:OpenCL Device 6: Platform:1 Device:4 Bus:6 Slot:0 Compute:1.2 Driver:441.87
03:40:23: Win32 Service: false
03:40:23:******************************* libFAH ********************************
03:40:23: Date: Apr 15 2020
03:40:23: Time: 14:53:14
03:40:23: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
03:40:23: Bits: 32
03:40:23:***********************************************************************
03:40:23:<config>
03:40:23: <!-- Folding Core -->
03:40:23: <checkpoint v='30'/>
03:40:23: <core-priority v='low'/>
03:40:23:
03:40:23: <!-- Network -->
03:40:23: <proxy v=':8080'/>
03:40:23:
03:40:23: <!-- Slot Control -->
03:40:23: <power v='FULL'/>
03:40:23:
03:40:23: <!-- User Information -->
03:40:23: <passkey v='*****'/>
03:40:23: <team v='251327'/>
03:40:23: <user v='Bigan_GSF71TjZygKbttwWxjXqUvUUVhGHcRb2yu'/>
03:40:23:
03:40:23: <!-- Folding Slots -->
03:40:23: <slot id='0' type='CPU'/>
03:40:23: <slot id='1' type='GPU'/>
03:40:23: <slot id='2' type='GPU'>
03:40:23: <cuda-index v='1'/>
03:40:23: <opencl-index v='1'/>
03:40:23: </slot>
03:40:23: <slot id='3' type='GPU'/>
03:40:23: <slot id='4' type='GPU'/>
03:40:23: <slot id='5' type='GPU'/>
03:40:23:</config>
03:40:23:Trying to access database...
03:40:23:Successfully acquired database lock
03:40:23:Enabled folding slot 00: READY cpu:1
03:40:23:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463
03:40:23:Enabled folding slot 02: READY gpu:1:GP104 [GeForce GTX 1070] 6463
03:40:23:Enabled folding slot 03: READY gpu:2:GP104 [GeForce GTX 1070] 6463
03:40:23:Enabled folding slot 04: READY gpu:3:GP104 [GeForce GTX 1070] 6463
03:40:23:Enabled folding slot 05: READY gpu:4:GP104 [GeForce GTX 1070] 6463
03:40:23:WU07:FS00:Starting
03:40:23:WU07:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 07 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -np 1
03:40:23:WU07:FS00:Started FahCore on PID 8240
03:40:24:WU07:FS00:Core PID:8272
03:40:24:WU07:FS00:FahCore 0xa7 started
03:40:24:WU06:FS01:Starting
03:40:24:WU06:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 06 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
03:40:24:WU06:FS01:Started FahCore on PID 8216
03:40:25:WU06:FS01:Core PID:8312
03:40:25:WU06:FS01:FahCore 0x22 started
03:40:25:WU04:FS04:Starting
03:40:25:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 04 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 3 -cuda-device 3 -gpu 3
03:40:25:WU04:FS04:Started FahCore on PID 8320
03:40:26:WU04:FS04:Core PID:8424
03:40:26:WU04:FS04:FahCore 0x22 started
03:40:26:WU05:FS05:Starting
03:40:26:WU05:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 05 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 4 -cuda-device 4 -gpu 4
03:40:26:WU05:FS05:Started FahCore on PID 8432
03:40:27:WU05:FS05:Core PID:7500
03:40:27:WU05:FS05:FahCore 0x22 started
03:40:27:WU02:FS02:Starting
03:40:27:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 1 -cuda-device 1 -gpu 1
03:40:27:WU02:FS02:Started FahCore on PID 7504
03:40:27:WU02:FS02:Core PID:8464
03:40:27:WU02:FS02:FahCore 0x22 started
03:40:27:WU03:FS03:Starting
03:40:27:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Utilisateur\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9100 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 2 -cuda-device 2 -gpu 2
03:40:27:WU03:FS03:Started FahCore on PID 8468
03:40:28:WU03:FS03:Core PID:8508
03:40:28:WU03:FS03:FahCore 0x22 started
03:40:30:WU07:FS00:0xa7:*********************** Log Started 2020-05-14T03:40:29Z ***********************
03:40:30:WU07:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:40:30:WU07:FS00:0xa7: Type: 0xa7
03:40:30:WU07:FS00:0xa7: Core: Gromacs
03:40:30:WU07:FS00:0xa7: Args: -dir 07 -suffix 01 -version 706 -lifeline 8240 -checkpoint 30 -np 1
03:40:30:WU07:FS00:0xa7:************************************ CBang *************************************
03:40:30:WU07:FS00:0xa7: Date: Oct 26 2019
03:40:30:WU07:FS00:0xa7: Time: 01:38:35
03:40:30:WU07:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:40:30:WU07:FS00:0xa7: Branch: master
03:40:30:WU07:FS00:0xa7: Compiler: Visual C++ 2008
03:40:30:WU07:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:40:30:WU07:FS00:0xa7: Platform: win32 10
03:40:30:WU07:FS00:0xa7: Bits: 64
03:40:30:WU07:FS00:0xa7: Mode: Release
03:40:30:WU07:FS00:0xa7:************************************ System ************************************
03:40:30:WU07:FS00:0xa7: CPU: Intel(R) Celeron(R) CPU G3900 @ 2.80GHz
03:40:30:WU07:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:40:30:WU07:FS00:0xa7: CPUs: 2
03:40:30:WU07:FS00:0xa7: Memory: 3.93GiB
03:40:30:WU07:FS00:0xa7:Free Memory: 1.90GiB
03:40:30:WU07:FS00:0xa7: Threads: WINDOWS_THREADS
03:40:30:WU07:FS00:0xa7: OS Version: 6.2
03:40:30:WU07:FS00:0xa7:Has Battery: false
03:40:30:WU07:FS00:0xa7: On Battery: false
03:40:30:WU07:FS00:0xa7: UTC Offset: -4
03:40:30:WU07:FS00:0xa7: PID: 8272
03:40:30:WU07:FS00:0xa7: CWD: C:\Users\Utilisateur\AppData\Roaming\FAHClient\work
03:40:30:WU07:FS00:0xa7:******************************** Build - libFAH ********************************
03:40:30:WU07:FS00:0xa7: Version: 0.0.18
03:40:30:WU07:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:40:30:WU07:FS00:0xa7: Copyright: 2019 foldingathome.org
03:40:30:WU07:FS00:0xa7: Homepage: https://foldingathome.org/
03:40:30:WU07:FS00:0xa7: Time: 01:52:44
03:40:30:WU07:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:40:30:WU07:FS00:0xa7:************************************ Build *************************************
03:40:30:WU07:FS00:0xa7: SIMD: sse2
03:40:30:WU07:FS00:0xa7:********************************************************************************
03:40:30:WU07:FS00:0xa7:Project: 16414 (Run 0, Clone 1766, Gen 44)
03:40:30:WU07:FS00:0xa7:Unit: 0x00000034a8f5c67d5e823060661d387f
03:40:30:WU07:FS00:0xa7:Digital signatures verified
03:40:30:WU07:FS00:0xa7:Calling: mdrun -s frame44.tpr -o frame44.trr -x frame44.xtc -cpi state.cpt -cpt 30 -nt 1
03:40:31:WU06:FS01:0x22:*********************** Log Started 2020-05-14T03:40:30Z ***********************
03:40:31:WU06:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:40:31:WU06:FS01:0x22: Type: 0x22
03:40:31:WU06:FS01:0x22: Core: Core22
03:40:31:WU06:FS01:0x22: Website: https://foldingathome.org/
03:40:31:WU06:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
03:40:31:WU06:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:40:31:WU06:FS01:0x22: <rafal.wiewiora@choderalab.org>
03:40:31:WU06:FS01:0x22: Args: -dir 06 -suffix 01 -version 706 -lifeline 8216 -checkpoint 30
03:40:31:WU06:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
03:40:31:WU06:FS01:0x22: 0 -gpu 0
03:40:31:WU06:FS01:0x22: Config: <none>
03:40:31:WU06:FS01:0x22:************************************ Build *************************************
03:40:31:WU06:FS01:0x22: Version: 0.0.5
03:40:31:WU06:FS01:0x22: Date: Apr 22 2020
03:40:31:WU06:FS01:0x22: Time: 04:42:59
03:40:31:WU06:FS01:0x22: Repository: Git
03:40:31:WU06:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
03:40:31:WU06:FS01:0x22: Branch: HEAD
03:40:31:WU06:FS01:0x22: Compiler: Visual C++ 2008
03:40:31:WU06:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:40:31:WU06:FS01:0x22: Platform: win32 10
03:40:31:WU06:FS01:0x22: Bits: 64
03:40:31:WU06:FS01:0x22: Mode: Release
03:40:31:WU06:FS01:0x22:************************************ System ************************************
03:40:31:WU06:FS01:0x22: CPU: Intel(R) Celeron(R) CPU G3900 @ 2.80GHz
03:40:31:WU06:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:40:31:WU06:FS01:0x22: CPUs: 2
03:40:31:WU06:FS01:0x22: Memory: 3.93GiB
03:40:31:WU06:FS01:0x22:Free Memory: 1.90GiB
03:40:31:WU06:FS01:0x22: Threads: WINDOWS_THREADS
03:40:31:WU06:FS01:0x22: OS Version: 6.2
03:40:31:WU06:FS01:0x22:Has Battery: false
03:40:31:WU06:FS01:0x22: On Battery: false
03:40:31:WU06:FS01:0x22: UTC Offset: -4
03:40:31:WU06:FS01:0x22: PID: 8312
03:40:31:WU06:FS01:0x22: CWD: C:\Users\Utilisateur\AppData\Roaming\FAHClient\work
03:40:31:WU06:FS01:0x22: OS: Windows 10 Pro
03:40:31:WU06:FS01:0x22: OS Arch: AMD64
03:40:31:WU06:FS01:0x22:********************************************************************************
03:40:31:WU06:FS01:0x22:Project: 11748 (Run 0, Clone 310, Gen 24)
03:40:31:WU06:FS01:0x22:Unit: 0x000000418ca304e75e6a7fe0f678651d
03:40:31:WU06:FS01:0x22:Digital signatures verified
03:40:31:WU06:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:40:31:WU06:FS01:0x22:Version 0.0.5[/list]
All togetherFireFox-89 wrote:So, 400,000 PPD each or all together?
JimboPalmer wrote:https://foldingathome.org/support/faq/points/passkey/
Get a passkey, put it on each instance of F@H
Yes I did and say it's valid
Sorry to be the bearer of bad tidings but your processor is a 2 core processor ... NVidia Cards need a core each to function properly ... To run these five cards you will really need at least a 6core processor.
If you pause three of the slots the other two may actually get a higher total PPD and the cards wont be fighting each other and the remaining two will be properly/adequately serviced.
Neil-B wrote:Sorry to be the bearer of bad tidings but your processor is a 2 core processor ... NVidia Cards need a core each to function properly ... To run these five cards you will really need at least a 6core processor.
So I can only run 1 card per that kind of processor?
NVidia cards need to have one core/thread to service them see viewtopic.php?f=61&t=35243#p334116
Your processor can run two cards.
It may be possible to get a processor upgrade ... someone in another thread (see below) was having the same issue with 4 GPU cards earlier today/yesterday ... I'll check you CPU and see what socket it uses and what upgrades might be available.
viewtopic.php?f=74&t=35221&hilit=+tesla
... and as someone has just pointed out to me I missed that you have a CPU slot
... WIth that you can only run one GPU ... So to be honest dropping the CPU slot is pretty much a given as a single core may well not complete WUs before deadlines and a second GPU running with be far more value to the science at this time.
You also have a CPU folding slot shown as active, that further reduces the ability of the CPU to be used by the GPU folding cores to send and receive WU data with the GPU. I would recommend you set that slot to Finish, and then delete the CPU slot after the current WU is done.
With the Celeron you have two cores and can support two GPU folding slots easily. You may even be able to run a third one without too much impact on the processing of the other two. But 5 is probably too much.
People will also bring up PCIe lanes. The throughput over them under Windows can be lower. Each card will run folding best with at least a 4x PCIe slot.
So your CPU probably uses a FCLGA1151 socket so it is possible that you will be able to upgrade (if motherboard allows) to a higher core processor ... https://ark.intel.com/content/www/us/en ... nt=Desktop shows there are compatible CPUs with 6 or 8 cores that should work with that socket (motherboard dependant) but it will need someone with a more solid technical grounding than I have to confirm this.
Delete the cpu slot - it's completely pointless folding on one of those.
Delete three gpu slots leaving slots "1" and "2" and let those two run.
See how many points the Advanced Control thinks you will get.
You also have five cards running in a motherboard that cannot possibly have five full PCIE slots. My guess is that at least three are using risers off a BTC mining motherboard. You will almost certainly need to remove three of the gpus. They will fetch a decent price if you choose to sell them.
Mining uses almost zero cpu and very little data transference so that Celeron and a motherboard with risers to the gpus would have worked fine but it won't work for folding.
Finding decent motherboards that can support multiple gpus isn't easy and generally requires very expensive models that can bifurcate the PCIE lanes using all sorts of exotic hardware to connect GPUs to the NVME connectors and all sorts of oddities.
As you can see from my signature, I have six GPUs running but that's across four machines. Two are twin gpu using the minimum spec to run them - Celeron G4400, 4GB and Linux, the others are standard desktops. You can build cheap machines to run the cards if you look around on auction sites.
single 1070
I've now have 1.1M PPD for 2 GPU's.
I don't know what is the best config for folding but mine are :
Power 100%
core clock +125
temperature 85
memery clock +500
I have 2 more cpu like that so I'll just do across 3 machines
Power 100%
core clock +125
temperature 85
memery clock +500
still something low if only 1.1m
what is each one getting? Is it split 550k/550k?
FWIW, my 1070s average over 800K each.
single 1070
- Hardware configuration: Intel i7 6850K - MSI Tomahawk - 32GB DDR4-3000 - Asus ROG 5700XT
Intel 2x Xeon X5675 - HP Board - 48GB DDR3-1333 ECC - nVIDIA Quadro K4000 - Location: Gatineau, QC
i have 1 GTX 1070, and runs around 800K PPD alone
Main - Intel 10700K / Asus Z490-E / 32GBGB DDR4-3200 / 2080Ti
Folding - HP Z220 Xeon E3 1245 V2 / 16GB DDR3-1600 / GTX 1060 6GB
Folding - HP Z420 Xeon E5 2650 / 16GB DDR3-1600 ECC / GTX 1070Ti
Folding - HP Z800 2X Xeon X5675 / 48GB DDR3-1333 ECC / RX480
