NVIDIA GeForce GTX 1660 Ti with Max-Q Design
tlmartins
Post by tlmartins »
Hi, here are the information you required :
C:\Program Files (x86)\FAHClient>FAHClient --lspci
0x8086:0xa348:0:31:3:Intel Corporation:controlador de ßudio da tecnologia Intel(R) Smart Sound
0x8086:0xa323:0:31:4:Intel Corporation:Intel(R) SMBus - A323
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) PCIe Controller (x16) - 1901
0x8086:0xa37c:0:19:0:Intel Corporation:Intel(R) Integrated Sensor Solution
0x10de:0x1aed:1:0:3:NVIDIA Corporation:NVIDIA USB Type-C Port Policy Controller
0x8086:0xa335:0:29:0:Intel Corporation:Intel(R) PCI Express Root Port #14 - A335
0x8086:0x3e9b:0:2:0:Intel Corporation:Intel(R) UHD Graphics 630
0x8086:0x1911:0:8:0:Intel Corporation:Intel(R) Gaussian Mixture Model - 1911
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Platform and Thermal Framework Processor Participant
0x8086:0xa36d:0:20:0:Intel Corporation:Controlador Host CompatÝvel com USB xHCI
0x8086:0xa369:0:21:1:Intel Corporation:Controlador Host Intel(R) Serial IO I2C - A369
0x168c:0x0042:3:0:0:Qualcomm Atheros:Qualcomm QCA9377 802.11ac Wireless Adapter
0x10de:0x1aec:1:0:2:NVIDIA Corporation:Controlador Host CompatÝvel com USB xHCI
0x10de:0x2191:1:0:0:NVIDIA Corporation:NVIDIA GeForce GTX 1660 Ti with Max-Q Design
0x10ec:0x8168:2:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GbE Family Controller
0x8086:0xa36f:0:20:2:Intel Corporation:PCI standard RAM Controller
0x8086:0xa324:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - A324
0x8086:0x3ec4:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 3EC4
0x8086:0xa360:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x282a:0:23:0:Intel Corporation:Intel(R) Chipset SATA/PCIe RST Premium Controller
0x10de:0x1aeb:1:0:1:NVIDIA Corporation:Controlador de High Definition Audio
0x8086:0xa368:0:21:0:Intel Corporation:Controlador Host Intel(R) Serial IO I2C - A368
0x8086:0xa379:0:18:0:Intel Corporation:Intel(R) Thermal Subsystem - A379
0x8086:0xa336:0:29:6:Intel Corporation:Intel(R) PCI Express Root Port #15 - A336
0x8086:0xa30d:0:31:0:Intel Corporation:Intel(R) 300 Series Chipset Family LPC Controller (HM370) - A30D
Logfile
*********************** Log Started 2020-05-11T00:35:19Z ***********************
00:35:19:****************************** FAHClient ******************************
00:35:19:      Version: 7.6.9
00:35:19:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:35:19:    Copyright: 2020 foldingathome.org
00:35:19:     Homepage: https://foldingathome.org/
00:35:19:         Date: Apr 17 2020
00:35:19:         Time: 11:13:06
00:35:19:     Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
00:35:19:       Branch: master
00:35:19:     Compiler: Visual C++ 2008
00:35:19:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:35:19:     Platform: win32 10
00:35:19:         Bits: 32
00:35:19:         Mode: Release
00:35:19:         Args: --open-web-control
00:35:19:       Config: C:\Users\tlock\AppData\Roaming\FAHClient\config.xml
00:35:19:******************************** CBang ********************************
00:35:19:         Time: 11:10:09
00:35:19:     Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
00:35:19:         Bits: 32
00:35:19:******************************* System ********************************
00:35:19:          CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
00:35:19:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
00:35:19:         CPUs: 12
00:35:19:       Memory: 31.81GiB
00:35:19:  Free Memory: 25.19GiB
00:35:19:      Threads: WINDOWS_THREADS
00:35:19:   OS Version: 6.2
00:35:19:  Has Battery: true
00:35:19:   On Battery: false
00:35:19:   UTC Offset: -3
00:35:19:          PID: 10356
00:35:19:          CWD: C:\Users\tlock\AppData\Roaming\FAHClient
00:35:19:           OS: Windows 10 Enterprise
00:35:19:      OS Arch: AMD64
00:35:19:         GPUs: 2
00:35:19:        GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 [xxx]
00:35:19:        GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116M [GeForce GTX 1660 Mobile]
00:35:19:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
00:35:19:       OpenCL: Not detected: clGetPlatformIDs() returned -1001
00:35:19:Win32 Service: false
00:35:19:******************************* libFAH ********************************
00:35:19:         Date: Apr 15 2020
00:35:19:         Time: 14:53:14
00:35:19:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
00:35:19:         Bits: 32
00:35:19:***********************************************************************
00:35:19:<config>
00:35:19:  <!-- Network -->
00:35:19:  <proxy v=':8080'/>
00:35:19:
00:35:19:  <!-- Slot Control -->
00:35:19:  <power v='FULL'/>
00:35:19:
00:35:19:  <!-- User Information -->
00:35:19:  <passkey v='*****'/>
00:35:19:  <user v='Tiago_Lock_Martins'/>
00:35:19:
00:35:19:  <!-- Folding Slots -->
00:35:19:  <slot id='0' type='CPU'/>
00:35:19:  <slot id='1' type='GPU'/>
00:35:19:</config>
00:35:19:Trying to access database...
00:35:19:Successfully acquired database lock
00:35:19:Enabled folding slot 00: READY cpu:11
00:35:19:Enabled folding slot 01: READY gpu:0:[xxx]
00:35:19:ERROR:No compute devices matched GPU #0 {
00:35:19:ERROR:  "vendor": 32902,
00:35:19:ERROR:  "device": 16027,
00:35:19:ERROR:  "type": 3,
00:35:19:ERROR:  "species": 1,
00:35:19:ERROR:  "description": "[xxx]"
00:35:19:ERROR:}.  You may need to update your graphics drivers.
00:35:19:WARNING:WU02:No longer matches Slot 1's configuration and there are no other matching slots, dumping
00:35:19:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:14538 run:0 clone:790 gen:104 core:0x22 unit:0x0000009c0d5262775e7b9cde5c666668
00:35:19:WU02:FS01:Connecting to 13.82.98.119:8080
00:35:19:WU00:FS00:Starting
00:35:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tlock\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10356 -checkpoint 15 -np 11
00:35:19:WU00:FS00:Started FahCore on PID 6336
00:35:20:WU00:FS00:Core PID:14928
00:35:20:WU00:FS00:FahCore 0xa7 started
00:35:20:WU00:FS00:0xa7:*********************** Log Started 2020-05-11T00:35:20Z ***********************
00:35:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:35:20:WU00:FS00:0xa7:       Type: 0xa7
00:35:20:WU00:FS00:0xa7:       Core: Gromacs
00:35:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6336 -checkpoint 15 -np
00:35:20:WU00:FS00:0xa7:             11
00:35:20:WU00:FS00:0xa7:************************************ CBang *************************************
00:35:20:WU00:FS00:0xa7:       Date: Oct 26 2019
00:35:20:WU00:FS00:0xa7:       Time: 01:38:25
00:35:20:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:35:20:WU00:FS00:0xa7:     Branch: master
00:35:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
00:35:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:35:20:WU00:FS00:0xa7:   Platform: win32 10
00:35:20:WU00:FS00:0xa7:       Bits: 64
00:35:20:WU00:FS00:0xa7:       Mode: Release
00:35:20:WU00:FS00:0xa7:************************************ System ************************************
00:35:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
00:35:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
00:35:20:WU00:FS00:0xa7:       CPUs: 12
00:35:20:WU00:FS00:0xa7:     Memory: 31.81GiB
00:35:20:WU00:FS00:0xa7:Free Memory: 25.18GiB
00:35:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
00:35:20:WU00:FS00:0xa7: OS Version: 6.2
00:35:20:WU00:FS00:0xa7:Has Battery: true
00:35:20:WU00:FS00:0xa7: On Battery: false
00:35:20:WU00:FS00:0xa7: UTC Offset: -3
00:35:20:WU00:FS00:0xa7:        PID: 14928
00:35:20:WU00:FS00:0xa7:        CWD: C:\Users\tlock\AppData\Roaming\FAHClient\work
00:35:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
00:35:20:WU00:FS00:0xa7:    Version: 0.0.18
00:35:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:35:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:35:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
00:35:20:WU00:FS00:0xa7:       Time: 01:52:30
00:35:20:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:35:20:WU00:FS00:0xa7:************************************ Build *************************************
00:35:20:WU00:FS00:0xa7:       SIMD: avx_256
00:35:20:WU00:FS00:0xa7:********************************************************************************
00:35:20:WU00:FS00:0xa7:Project: 13851 (Run 0, Clone 1530, Gen 106)
00:35:20:WU00:FS00:0xa7:Unit: 0x00000084287234c95e725894f186f164
00:35:20:WU00:FS00:0xa7:Digital signatures verified
00:35:20:WU00:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
00:35:20:WU00:FS00:0xa7:Calling: mdrun -s frame106.tpr -o frame106.trr -x frame106.xtc -e frame106.edr -cpi state.cpt -cpt 15 -nt 10
00:35:20:WU00:FS00:0xa7:Steps: first=53000000 total=500000
00:35:21:WU01:FS01:Connecting to 65.254.110.245:80
00:35:22:WU02:FS01:Server responded WORK_ACK (400)
00:35:22:WU02:FS01:Cleaning up
00:35:22:WU01:FS01:Assigned to work server 155.247.164.213
00:35:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[xxx] from 155.247.164.213
00:35:22:WU01:FS01:Connecting to 155.247.164.213:8080
00:35:22:WU00:FS00:0xa7:Completed 33562 out of 500000 steps (6%)
00:35:23:WU01:FS01:Downloading 2.83MiB
00:35:24:3:127.0.0.1:New Web session
00:35:25:WU01:FS01:Download complete
00:35:25:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14824 run:1591 clone:0 gen:30 core:0xa7 unit:0x000000249bf7a4d55ea344abb66427d5
00:35:25:WU01:FS01:Starting
00:35:25:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
00:35:26:WU01:FS01:Starting
00:35:26:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
Using Nvidia`s Geforce Game Driver version 445.87
Thanks for your time !
Re: NVIDIA GeForce GTX 1660 Ti with Max-Q Design
The nVidia GPU is already in the GPUs.txt file and whitelisted:
0x10de:0x2191:2:7:TU116M [GeForce GTX 1660 Mobile]
The problems is that a GPU folding slot pointing at the iGPU on the Intel processor has been created, that will not work.
If this is a laptop using nVidia's Optimus technology, you may need to disable the iGPU. There are a number of topics discussing the problems different people have run into.
Post by foldy »
Please download nvidia driver manually from nvidia.com and install to get OpenCL working for Nvidia GPU.
