Updated client unable to get work?
pompeyrodney
- Hardware configuration: 1 Dell server running Quad Xeon 2.4 Deino, SMP client. 2 Vista GPU client and 2 6.23 BetaR1. 8 other XP clients running 6.23.
I had an issue with my last client which when I reinstalled I ended up with 7.6.13. I kept the data from the uninstall if you see what I mean. Now the web control does not connect and when I look at the advanced control it is switching between updating and connecting. I cannot seem to get to the FAH log files, can somebody please help me. Thanks.
pompeyrodney
Re: Updated client unable to get work?
Found the log file now, lots of this
12:14:17:WARNING:304:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1589199217140&sid=a8d8ba3ef47d8ed1bdf1c4437569e853: Option 'gpu-index' has no default and is not set.
12:14:17:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
12:14:21:ERROR:Exception: Connection terminated
12:14:21:ERROR:Socket not openRe: Updated client unable to get work?
If it is so blocked, I would uninstall including data (you can first make a copy of the config file for reference - in Windows, it is in %AppData%\FAHClient in Linux in /etc/fahclient/), and then do a fresh install.
pompeyrodney
