Bad Work Unit, several of them
KA1J
Hardware configuration: ROG Strix Z390-E Motherboard - i7-8700K @ 5100 MHz - 32 Gig GSkill RAM - NVIDIA GaForce GTX 1080
ASUS P8Z68-DELUXE-GEN3 - i72600K - 16 Gig Ram EVGA RTX 2060 KO Ultra - GTX 1060
Post by KA1J »
I've has some false starts it seems. Here's the failure log for the GPU, anything look interesting?
11:37:06:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:07:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:37:07:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:37:07:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:37:28:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
11:37:30:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:37:49:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:37:52:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:37:52:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
******************************* Date: 2020-05-10 *******************************
12:31:44:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:31:44:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:31:45:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:31:45:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:31:45:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:31:45:ERROR:WU00:FS01:Exception: Could not get an assignment
12:31:46:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:31:46:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:32:52:ERROR:WU00:FS01:Exception: Server did not assign work unit
12:32:52:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:32:53:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:32:53:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:32:53:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:32:53:ERROR:WU00:FS01:Exception: Could not get an assignment
12:34:30:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:34:47:ERROR:WU00:FS01:Exception: Server did not assign work unit
12:37:07:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
13:47:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:47:09:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:41:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:41:12:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:41:12:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:41:12:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:41:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:28:34:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:28:34:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:28:34:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:28:55:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:38:45:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:49:12:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:49:13:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:49:13:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:55:32:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:55:33:WARNING:WU03:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
17:55:33:WARNING:WU03:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
17:55:33:WARNING:WU03:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
17:55:33:WARNING:WU03:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
17:55:33:ERROR:WU03:FS01:Exception: Could not get an assignment
17:55:54:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
17:55:55:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
17:56:17:ERROR:WU03:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:56:34:WARNING:WU03:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:03:51:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:04:11:ERROR:WU02:FS01:Exception: Server did not assign work unit
18:04:11:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
18:04:12:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
18:04:33:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
18:04:55:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:11:22:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
Here is the whole log for the GPU
10:11:57:WU03:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
10:14:31:WU03:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
10:17:10:WU03:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
10:19:45:WU03:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
10:22:21:WU03:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
10:24:31:FS01:Paused
10:24:31:FS01:Shutting core down
10:24:31:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 47776
10:24:31:WU03:FS01:0x22:Exiting, please wait. . .
10:24:31:WU03:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
10:24:31:WU03:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:27:29:FS01:Unpaused
10:27:29:WU03:FS01:Starting
10:27:29:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 28312 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:27:29:WU03:FS01:Started FahCore on PID 8892
10:27:29:WU03:FS01:Core PID:46532
10:27:29:WU03:FS01:FahCore 0x22 started
10:27:30:WU03:FS01:0x22:*********************** Log Started 2020-05-10T10:27:29Z ***********************
10:27:30:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:27:30:WU03:FS01:0x22:       Type: 0x22
10:27:30:WU03:FS01:0x22:       Core: Core22
10:27:30:WU03:FS01:0x22:    Website: https://foldingathome.org/
10:27:30:WU03:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
10:27:30:WU03:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:27:30:WU03:FS01:0x22:             <rafal.wiewiora@choderalab.org>
10:27:30:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 8892 -checkpoint 3
10:27:30:WU03:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
10:27:30:WU03:FS01:0x22:             0 -gpu 0
10:27:30:WU03:FS01:0x22:     Config: <none>
10:27:30:WU03:FS01:0x22:************************************ Build *************************************
10:27:30:WU03:FS01:0x22:    Version: 0.0.5
10:27:30:WU03:FS01:0x22:       Date: Apr 22 2020
10:27:30:WU03:FS01:0x22:       Time: 04:42:59
10:27:30:WU03:FS01:0x22: Repository: Git
10:27:30:WU03:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
10:27:30:WU03:FS01:0x22:     Branch: HEAD
10:27:30:WU03:FS01:0x22:   Compiler: Visual C++ 2008
10:27:30:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:27:30:WU03:FS01:0x22:   Platform: win32 10
10:27:30:WU03:FS01:0x22:       Bits: 64
10:27:30:WU03:FS01:0x22:       Mode: Release
10:27:30:WU03:FS01:0x22:************************************ System ************************************
10:27:30:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
10:27:30:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:27:30:WU03:FS01:0x22:       CPUs: 12
10:27:30:WU03:FS01:0x22:     Memory: 31.92GiB
10:27:30:WU03:FS01:0x22:Free Memory: 18.52GiB
10:27:30:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
10:27:30:WU03:FS01:0x22: OS Version: 6.2
10:27:30:WU03:FS01:0x22:Has Battery: false
10:27:30:WU03:FS01:0x22: On Battery: false
10:27:30:WU03:FS01:0x22: UTC Offset: -4
10:27:30:WU03:FS01:0x22:        PID: 46532
10:27:30:WU03:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
10:27:30:WU03:FS01:0x22:         OS: Windows 10 Enterprise
10:27:30:WU03:FS01:0x22:    OS Arch: AMD64
10:27:30:WU03:FS01:0x22:********************************************************************************
10:27:30:WU03:FS01:0x22:Project: 16435 (Run 10, Clone 0, Gen 24)
10:27:30:WU03:FS01:0x22:Unit: 0x0000002b03854c135e9a4eff9191e4e3
10:27:30:WU03:FS01:0x22:Digital signatures verified
10:27:30:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:27:30:WU03:FS01:0x22:Version 0.0.5
10:27:30:WU03:FS01:0x22:  Found a checkpoint file
10:27:36:WU03:FS01:0x22:Completed 640000 out of 5000000 steps (12%)
10:27:36:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:28:04:WU03:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
10:30:37:WU03:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
10:33:09:WU03:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
10:35:42:WU03:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
10:38:15:WU03:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
10:40:47:WU03:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
10:43:21:WU03:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
10:45:54:WU03:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
10:48:32:WU03:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
10:51:07:WU03:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
10:53:41:WU03:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
10:56:15:WU03:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
10:58:49:WU03:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
11:01:24:WU03:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
11:03:59:WU03:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
11:06:36:WU03:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
11:09:13:WU03:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
11:11:49:WU03:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
11:14:25:WU03:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
11:17:02:WU03:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
11:19:41:WU03:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
11:22:20:WU03:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
11:24:58:WU03:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
11:27:36:WU03:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
11:30:15:WU03:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
11:32:56:WU03:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
11:35:35:WU03:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
11:37:05:WU03:FS01:0x22:ERROR:exception: clWaitForEvents
11:37:05:WU03:FS01:0x22:Saving result file ..\logfile_01.txt
11:37:05:WU03:FS01:0x22:Saving result file checkpointState.xml
11:37:05:WU03:FS01:0x22:Saving result file checkpt.crc
11:37:05:WU03:FS01:0x22:Saving result file positions.xtc
11:37:06:WU03:FS01:0x22:Saving result file science.log
11:37:06:WU03:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:06:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:16435 run:10 clone:0 gen:24 core:0x22 unit:0x0000002b03854c135e9a4eff9191e4e3
11:37:06:WU03:FS01:Uploading 58.93MiB to 3.133.76.19
11:37:06:WU03:FS01:Connecting to 3.133.76.19:8080
11:37:07:WU02:FS01:Connecting to assign1.foldingathome.org:80
11:37:07:WU02:FS01:Connecting to assign2.foldingathome.org:80
11:37:07:WU02:FS01:Connecting to assign3.foldingathome.org:80
11:37:07:WU02:FS01:Connecting to assign4.foldingathome.org:80
11:37:09:WU02:FS01:Assigned to work server 3.133.76.19
11:37:09:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 3.133.76.19
11:37:09:WU02:FS01:Connecting to 3.133.76.19:8080
11:37:28:WU03:FS01:Connecting to 3.133.76.19:80
11:37:30:WU02:FS01:Connecting to 3.133.76.19:80
11:37:49:WU03:FS01:Trying to send results to collection server
11:37:49:WU03:FS01:Uploading 58.93MiB to 3.21.157.11
11:37:49:WU03:FS01:Connecting to 3.21.157.11:8080
11:37:52:WU02:FS01:Connecting to assign1.foldingathome.org:80
11:37:52:WU02:FS01:Connecting to assign2.foldingathome.org:80
11:37:52:WU02:FS01:Assigned to work server 140.163.4.231
11:37:52:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.231
11:37:52:WU02:FS01:Connecting to 140.163.4.231:8080
11:37:55:WU03:FS01:Upload 11.67%
11:38:01:WU03:FS01:Upload 15.27%
11:38:07:WU02:FS01:Downloading 7.93MiB
11:38:07:WU03:FS01:Upload 17.93%
11:38:08:WU02:FS01:Download complete
11:38:08:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:9454 gen:17 core:0x22 unit:0x0000002b8ca304e75e6bbd431de70f6d
11:38:08:WU02:FS01:Starting
11:38:08:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 28312 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:38:08:WU02:FS01:Started FahCore on PID 48696
11:38:08:WU02:FS01:Core PID:46084
11:38:08:WU02:FS01:FahCore 0x22 started
11:38:08:WU02:FS01:0x22:*********************** Log Started 2020-05-10T11:38:08Z ***********************
11:38:08:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:38:08:WU02:FS01:0x22:       Type: 0x22
11:38:08:WU02:FS01:0x22:       Core: Core22
11:38:08:WU02:FS01:0x22:    Website: https://foldingathome.org/
11:38:08:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:38:08:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:38:08:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:38:08:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 48696 -checkpoint 3
11:38:08:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:38:08:WU02:FS01:0x22:             0 -gpu 0
11:38:08:WU02:FS01:0x22:     Config: <none>
11:38:08:WU02:FS01:0x22:************************************ Build *************************************
11:38:08:WU02:FS01:0x22:    Version: 0.0.5
11:38:08:WU02:FS01:0x22:       Date: Apr 22 2020
11:38:08:WU02:FS01:0x22:       Time: 04:42:59
11:38:08:WU02:FS01:0x22: Repository: Git
11:38:08:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
11:38:08:WU02:FS01:0x22:     Branch: HEAD
11:38:08:WU02:FS01:0x22:   Compiler: Visual C++ 2008
11:38:08:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:08:WU02:FS01:0x22:   Platform: win32 10
11:38:08:WU02:FS01:0x22:       Bits: 64
11:38:08:WU02:FS01:0x22:       Mode: Release
11:38:08:WU02:FS01:0x22:************************************ System ************************************
11:38:08:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:38:08:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:38:08:WU02:FS01:0x22:       CPUs: 12
11:38:09:WU02:FS01:0x22:     Memory: 31.92GiB
11:38:09:WU02:FS01:0x22:Free Memory: 17.27GiB
11:38:09:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
11:38:09:WU02:FS01:0x22: OS Version: 6.2
11:38:09:WU02:FS01:0x22:Has Battery: false
11:38:09:WU02:FS01:0x22: On Battery: false
11:38:09:WU02:FS01:0x22: UTC Offset: -4
11:38:09:WU02:FS01:0x22:        PID: 46084
11:38:09:WU02:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
11:38:09:WU02:FS01:0x22:         OS: Windows 10 Enterprise
11:38:09:WU02:FS01:0x22:    OS Arch: AMD64
11:38:09:WU02:FS01:0x22:********************************************************************************
11:38:09:WU02:FS01:0x22:Project: 11751 (Run 0, Clone 9454, Gen 17)
11:38:09:WU02:FS01:0x22:Unit: 0x0000002b8ca304e75e6bbd431de70f6d
11:38:09:WU02:FS01:0x22:Reading tar file core.xml
11:38:09:WU02:FS01:0x22:Reading tar file integrator.xml
11:38:09:WU02:FS01:0x22:Reading tar file state.xml
11:38:10:WU02:FS01:0x22:Reading tar file system.xml
11:38:11:WU02:FS01:0x22:Digital signatures verified
11:38:11:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:38:11:WU02:FS01:0x22:Version 0.0.5
11:38:13:WU03:FS01:Upload 23.33%
11:38:19:WU03:FS01:Upload 27.36%
11:38:22:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
11:38:22:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:38:25:WU03:FS01:Upload 35.43%
11:38:31:WU03:FS01:Upload 45.40%
11:38:37:WU03:FS01:Upload 54.94%
11:38:43:WU03:FS01:Upload 64.91%
11:38:49:WU03:FS01:Upload 71.17%
11:38:55:WU03:FS01:Upload 82.09%
11:39:01:WU03:FS01:Upload 89.84%
11:39:05:WU03:FS01:Upload complete
11:39:06:WU03:FS01:Server responded WORK_ACK (400)
11:39:06:WU03:FS01:Cleaning up
11:39:26:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
11:40:28:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
11:41:32:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
11:42:35:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
11:43:38:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
11:44:45:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
11:45:49:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
11:46:52:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
11:47:56:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
11:49:01:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
11:50:09:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
11:51:12:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
11:52:15:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
11:53:18:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
11:54:22:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
11:55:30:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
11:56:33:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
11:57:37:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
11:58:40:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
11:59:44:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
12:00:51:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
12:01:55:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
12:02:59:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
12:04:03:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
12:05:06:WU02:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
12:06:13:WU02:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
12:07:15:WU02:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
12:08:17:WU02:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
12:09:20:WU02:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
12:10:22:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
12:11:28:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
12:12:31:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
12:13:32:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
12:14:34:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
12:15:37:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
12:16:42:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
12:17:44:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
12:18:47:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
12:19:49:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
12:20:52:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
12:21:58:WU02:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
12:23:01:WU02:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
12:24:04:WU02:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
12:25:06:WU02:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
12:26:08:WU02:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
12:27:14:WU02:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
12:28:17:WU02:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
12:29:20:WU02:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
12:30:21:WU02:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
12:31:23:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:31:23:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
12:31:26:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:31:26:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
12:31:29:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:31:29:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
12:31:29:WU02:FS01:0x22:ERROR:114: Max Retries Reached
12:31:29:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
12:31:29:WU02:FS01:0x22:Saving result file badstate-0.xml
12:31:33:WU02:FS01:0x22:Saving result file badstate-1.xml
12:31:36:WU02:FS01:0x22:Saving result file badstate-2.xml
12:31:39:WU02:FS01:0x22:Saving result file checkpointState.xml
12:31:42:WU02:FS01:0x22:Saving result file checkpt.crc
12:31:42:WU02:FS01:0x22:Saving result file positions.xtc
12:31:43:WU02:FS01:0x22:Saving result file science.log
12:31:43:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
12:31:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11751 run:0 clone:9454 gen:17 core:0x22 unit:0x0000002b8ca304e75e6bbd431de70f6d
12:31:44:WU02:FS01:Uploading 10.41MiB to 140.163.4.231
12:31:44:WU02:FS01:Connecting to 140.163.4.231:8080
12:31:44:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:31:44:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:31:45:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:31:45:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:31:45:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:31:46:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:31:46:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:31:46:WU00:FS01:Assigned to work server 3.133.76.19
12:31:46:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 3.133.76.19
12:31:46:WU00:FS01:Connecting to 3.133.76.19:8080
12:31:52:WU02:FS01:Upload complete
12:31:52:WU02:FS01:Server responded WORK_ACK (400)
12:31:52:WU02:FS01:Cleaning up
12:32:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:32:52:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:32:53:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:32:53:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:34:29:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:34:30:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:34:30:WU00:FS01:Assigned to work server 13.82.98.119
12:34:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 13.82.98.119
12:34:30:WU00:FS01:Connecting to 13.82.98.119:8080
12:37:07:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:37:07:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:37:08:WU00:FS01:Assigned to work server 140.163.4.241
12:37:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
12:37:08:WU00:FS01:Connecting to 140.163.4.241:8080
12:41:59:WU00:FS01:Downloading 4.53MiB
12:42:05:WU00:FS01:Download 42.77%
12:42:09:WU00:FS01:Download complete
12:42:09:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:3431 gen:100 core:0x22 unit:0x0000008a8ca304f15e69b05097463400
12:42:09:WU00:FS01:Starting
12:42:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 28312 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:42:10:WU00:FS01:Started FahCore on PID 49136
12:42:10:WU00:FS01:Core PID:33996
12:42:10:WU00:FS01:FahCore 0x22 started
12:42:10:WU00:FS01:0x22:*********************** Log Started 2020-05-10T12:42:10Z ***********************
12:42:10:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:42:10:WU00:FS01:0x22:       Type: 0x22
12:42:10:WU00:FS01:0x22:       Core: Core22
12:42:10:WU00:FS01:0x22:    Website: https://foldingathome.org/
12:42:10:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
12:42:10:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:42:10:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
12:42:10:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 49136 -checkpoint 3
12:42:10:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:42:10:WU00:FS01:0x22:             0 -gpu 0
12:42:10:WU00:FS01:0x22:     Config: <none>
12:42:10:WU00:FS01:0x22:************************************ Build *************************************
12:42:10:WU00:FS01:0x22:    Version: 0.0.5
12:42:10:WU00:FS01:0x22:       Date: Apr 22 2020
12:42:10:WU00:FS01:0x22:       Time: 04:42:59
12:42:10:WU00:FS01:0x22: Repository: Git
12:42:10:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
12:42:10:WU00:FS01:0x22:     Branch: HEAD
12:42:10:WU00:FS01:0x22:   Compiler: Visual C++ 2008
12:42:10:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:42:10:WU00:FS01:0x22:   Platform: win32 10
12:42:10:WU00:FS01:0x22:       Bits: 64
12:42:10:WU00:FS01:0x22:       Mode: Release
12:42:10:WU00:FS01:0x22:************************************ System ************************************
12:42:10:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
12:42:10:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:42:10:WU00:FS01:0x22:       CPUs: 12
12:42:10:WU00:FS01:0x22:     Memory: 31.92GiB
12:42:10:WU00:FS01:0x22:Free Memory: 16.94GiB
12:42:10:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
12:42:10:WU00:FS01:0x22: OS Version: 6.2
12:42:10:WU00:FS01:0x22:Has Battery: false
12:42:10:WU00:FS01:0x22: On Battery: false
12:42:10:WU00:FS01:0x22: UTC Offset: -4
12:42:10:WU00:FS01:0x22:        PID: 33996
12:42:10:WU00:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
12:42:10:WU00:FS01:0x22:         OS: Windows 10 Enterprise
12:42:10:WU00:FS01:0x22:    OS Arch: AMD64
12:42:10:WU00:FS01:0x22:********************************************************************************
12:42:10:WU00:FS01:0x22:Project: 11742 (Run 0, Clone 3431, Gen 100)
12:42:10:WU00:FS01:0x22:Unit: 0x0000008a8ca304f15e69b05097463400
12:42:10:WU00:FS01:0x22:Reading tar file core.xml
12:42:10:WU00:FS01:0x22:Reading tar file integrator.xml
12:42:10:WU00:FS01:0x22:Reading tar file state.xml
12:42:11:WU00:FS01:0x22:Reading tar file system.xml
12:42:12:WU00:FS01:0x22:Digital signatures verified
12:42:12:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:42:12:WU00:FS01:0x22:Version 0.0.5
12:42:20:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
12:42:20:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:43:28:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
12:44:36:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
12:45:46:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
12:46:55:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
12:48:03:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
12:49:13:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
12:50:21:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
12:51:31:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
12:52:39:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
12:53:46:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
12:54:57:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
12:56:05:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
12:57:15:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
12:58:24:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
12:59:31:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
13:00:42:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
13:01:50:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
13:02:59:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
13:04:06:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
13:05:14:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
13:06:23:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
13:07:30:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
13:08:40:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
13:09:48:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
13:10:55:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
13:12:05:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
13:13:13:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
13:14:22:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
13:15:30:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
13:16:38:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
13:17:47:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
13:18:55:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
13:20:04:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
13:21:11:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
13:22:19:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
13:23:28:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
13:24:35:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
13:25:44:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
13:26:52:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
13:27:59:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
13:29:08:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
13:30:15:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
13:31:25:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
13:32:32:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
13:33:39:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
13:34:49:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
13:35:56:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
13:37:05:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
13:38:12:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
13:39:18:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
13:40:28:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
13:41:35:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
13:42:45:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
13:43:52:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
13:44:59:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
13:46:09:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
13:46:52:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
13:46:52:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
13:46:55:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
13:46:55:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
13:46:59:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
13:46:59:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
13:46:59:WU00:FS01:0x22:ERROR:114: Max Retries Reached
13:46:59:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
13:46:59:WU00:FS01:0x22:Saving result file badstate-0.xml
13:47:01:WU00:FS01:0x22:Saving result file badstate-1.xml
13:47:03:WU00:FS01:0x22:Saving result file badstate-2.xml
13:47:05:WU00:FS01:0x22:Saving result file checkpointState.xml
13:47:06:WU00:FS01:0x22:Saving result file checkpt.crc
13:47:06:WU00:FS01:0x22:Saving result file positions.xtc
13:47:07:WU00:FS01:0x22:Saving result file science.log
13:47:07:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
13:47:08:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11742 run:0 clone:3431 gen:100 core:0x22 unit:0x0000008a8ca304f15e69b05097463400
13:47:08:WU00:FS01:Uploading 8.69MiB to 140.163.4.241
13:47:08:WU00:FS01:Connecting to 140.163.4.241:8080
13:47:08:WU02:FS01:Connecting to assign1.foldingathome.org:80
13:47:09:WU02:FS01:Connecting to assign2.foldingathome.org:80
13:47:09:WU02:FS01:Assigned to work server 140.163.4.241
13:47:09:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.241
13:47:09:WU02:FS01:Connecting to 140.163.4.241:8080
13:47:15:WU00:FS01:Upload 1.44%
13:47:24:WU00:FS01:Upload complete
13:47:24:WU00:FS01:Server responded WORK_ACK (400)
13:47:24:WU00:FS01:Cleaning up
13:47:32:WU02:FS01:Downloading 4.53MiB
13:47:35:WU02:FS01:Download complete
13:47:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:7510 gen:91 core:0x22 unit:0x0000007b8ca304f15e6bc500175336a4
13:47:35:WU02:FS01:Starting
13:47:35:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 28312 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:47:35:WU02:FS01:Started FahCore on PID 47280
13:47:35:WU02:FS01:Core PID:38304
13:47:35:WU02:FS01:FahCore 0x22 started
13:47:36:WU02:FS01:0x22:*********************** Log Started 2020-05-10T13:47:35Z ***********************
13:47:36:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:47:36:WU02:FS01:0x22:       Type: 0x22
13:47:36:WU02:FS01:0x22:       Core: Core22
13:47:36:WU02:FS01:0x22:    Website: https://foldingathome.org/
13:47:36:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
13:47:36:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:47:36:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
13:47:36:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 47280 -checkpoint 3
13:47:36:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:47:36:WU02:FS01:0x22:             0 -gpu 0
13:47:36:WU02:FS01:0x22:     Config: <none>
13:47:36:WU02:FS01:0x22:************************************ Build *************************************
13:47:36:WU02:FS01:0x22:    Version: 0.0.5
13:47:36:WU02:FS01:0x22:       Date: Apr 22 2020
13:47:36:WU02:FS01:0x22:       Time: 04:42:59
13:47:36:WU02:FS01:0x22: Repository: Git
13:47:36:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
13:47:36:WU02:FS01:0x22:     Branch: HEAD
13:47:36:WU02:FS01:0x22:   Compiler: Visual C++ 2008
13:47:36:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:47:36:WU02:FS01:0x22:   Platform: win32 10
13:47:36:WU02:FS01:0x22:       Bits: 64
13:47:36:WU02:FS01:0x22:       Mode: Release
13:47:36:WU02:FS01:0x22:************************************ System ************************************
13:47:36:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
13:47:36:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
13:47:36:WU02:FS01:0x22:       CPUs: 12
13:47:36:WU02:FS01:0x22:     Memory: 31.92GiB
13:47:36:WU02:FS01:0x22:Free Memory: 16.58GiB
13:47:36:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
13:47:36:WU02:FS01:0x22: OS Version: 6.2
13:47:36:WU02:FS01:0x22:Has Battery: false
13:47:36:WU02:FS01:0x22: On Battery: false
13:47:36:WU02:FS01:0x22: UTC Offset: -4
13:47:36:WU02:FS01:0x22:        PID: 38304
13:47:36:WU02:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
13:47:36:WU02:FS01:0x22:         OS: Windows 10 Enterprise
13:47:36:WU02:FS01:0x22:    OS Arch: AMD64
13:47:36:WU02:FS01:0x22:********************************************************************************
13:47:36:WU02:FS01:0x22:Project: 11742 (Run 0, Clone 7510, Gen 91)
13:47:36:WU02:FS01:0x22:Unit: 0x0000007b8ca304f15e6bc500175336a4
13:47:36:WU02:FS01:0x22:Reading tar file core.xml
13:47:36:WU02:FS01:0x22:Reading tar file integrator.xml
13:47:36:WU02:FS01:0x22:Reading tar file state.xml
13:47:36:WU02:FS01:0x22:Reading tar file system.xml
13:47:37:WU02:FS01:0x22:Digital signatures verified
13:47:37:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:47:37:WU02:FS01:0x22:Version 0.0.5
13:47:43:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
13:47:43:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:48:50:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
13:49:57:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
13:51:07:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
13:52:14:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
13:53:21:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
13:54:30:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
13:55:37:WU02:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
13:56:46:WU02:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
13:57:53:WU02:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
13:59:00:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
14:00:10:WU02:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
14:01:16:WU02:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
14:02:26:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
14:03:33:WU02:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
14:04:39:WU02:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
14:05:48:WU02:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
14:06:54:WU02:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
14:08:03:WU02:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
14:09:10:WU02:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
14:10:16:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
14:11:25:WU02:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
14:12:32:WU02:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
14:13:41:WU02:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
14:14:48:WU02:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
14:15:55:WU02:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
14:17:05:WU02:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
14:18:12:WU02:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
14:19:21:WU02:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
14:20:29:WU02:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
14:21:36:WU02:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
14:22:46:WU02:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
14:23:53:WU02:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
14:25:03:WU02:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
14:26:06:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:26:06:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
14:27:47:WU02:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
14:28:54:WU02:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
14:30:03:WU02:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
14:31:10:WU02:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
14:32:20:WU02:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
14:33:27:WU02:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
14:34:35:WU02:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
14:35:44:WU02:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
14:36:51:WU02:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
14:38:01:WU02:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
14:39:08:WU02:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
14:40:15:WU02:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
14:40:59:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:40:59:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
14:41:02:WU02:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
14:41:02:WU02:FS01:0x22:Following exception occured: Particle coordinate is nan
14:41:02:WU02:FS01:0x22:ERROR:114: Max Retries Reached
14:41:02:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
14:41:02:WU02:FS01:0x22:Saving result file badstate-0.xml
14:41:04:WU02:FS01:0x22:Saving result file badstate-1.xml
14:41:06:WU02:FS01:0x22:Saving result file badstate-2.xml
14:41:08:WU02:FS01:0x22:Saving result file checkpointState.xml
14:41:10:WU02:FS01:0x22:Saving result file checkpt.crc
14:41:10:WU02:FS01:0x22:Saving result file positions.xtc
14:41:11:WU02:FS01:0x22:Saving result file science.log
14:41:11:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:41:11:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11742 run:0 clone:7510 gen:91 core:0x22 unit:0x0000007b8ca304f15e6bc500175336a4
14:41:11:WU02:FS01:Uploading 7.85MiB to 140.163.4.241
14:41:11:WU02:FS01:Connecting to 140.163.4.241:8080
14:41:12:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:41:12:WU00:FS01:Connecting to assign2.foldingathome.org:80
14:41:12:WU00:FS01:Connecting to assign3.foldingathome.org:80
14:41:12:WU00:FS01:Connecting to assign4.foldingathome.org:80
14:41:13:WU00:FS01:Assigned to work server 206.223.170.146
14:41:13:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 206.223.170.146
14:41:13:WU00:FS01:Connecting to 206.223.170.146:8080
14:41:34:WU00:FS01:Connecting to 206.223.170.146:80
14:41:34:WU02:FS01:Upload 2.39%
14:41:40:WU02:FS01:Upload 46.18%
14:41:53:WU02:FS01:Upload complete
14:41:53:WU02:FS01:Server responded WORK_ACK (400)
14:41:53:WU02:FS01:Cleaning up
14:42:43:WU00:FS01:Downloading 11.77MiB
14:42:46:WU00:FS01:Download complete
14:42:46:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14564 run:19 clone:2 gen:0 core:0x22 unit:0x00000001cedfaa925eb08d3dbe9155aa
14:42:46:WU00:FS01:Starting
14:42:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 28312 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:42:46:WU00:FS01:Started FahCore on PID 42208
14:42:46:WU00:FS01:Core PID:48684
14:42:46:WU00:FS01:FahCore 0x22 started
14:42:46:WU00:FS01:0x22:*********************** Log Started 2020-05-10T14:42:46Z ***********************
14:42:46:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:42:46:WU00:FS01:0x22:       Type: 0x22
14:42:46:WU00:FS01:0x22:       Core: Core22
14:42:46:WU00:FS01:0x22:    Website: https://foldingathome.org/
14:42:46:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:42:46:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:42:46:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
14:42:46:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 42208 -checkpoint 3
14:42:46:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:42:46:WU00:FS01:0x22:             0 -gpu 0
14:42:46:WU00:FS01:0x22:     Config: <none>
14:42:46:WU00:FS01:0x22:************************************ Build *************************************
14:42:46:WU00:FS01:0x22:    Version: 0.0.5
14:42:46:WU00:FS01:0x22:       Date: Apr 22 2020
14:42:46:WU00:FS01:0x22:       Time: 04:42:59
14:42:46:WU00:FS01:0x22: Repository: Git
14:42:46:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
14:42:46:WU00:FS01:0x22:     Branch: HEAD
14:42:46:WU00:FS01:0x22:   Compiler: Visual C++ 2008
14:42:46:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:42:46:WU00:FS01:0x22:   Platform: win32 10
14:42:46:WU00:FS01:0x22:       Bits: 64
14:42:46:WU00:FS01:0x22:       Mode: Release
14:42:46:WU00:FS01:0x22:************************************ System ************************************
14:42:46:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
14:42:46:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
14:42:46:WU00:FS01:0x22:       CPUs: 12
14:42:46:WU00:FS01:0x22:     Memory: 31.92GiB
14:42:46:WU00:FS01:0x22:Free Memory: 16.29GiB
14:42:46:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:42:46:WU00:FS01:0x22: OS Version: 6.2
14:42:46:WU00:FS01:0x22:Has Battery: false
14:42:46:WU00:FS01:0x22: On Battery: false
14:42:46:WU00:FS01:0x22: UTC Offset: -4
14:42:46:WU00:FS01:0x22:        PID: 48684
14:42:46:WU00:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
14:42:46:WU00:FS01:0x22:         OS: Windows 10 Enterprise
14:42:46:WU00:FS01:0x22:    OS Arch: AMD64
14:42:46:WU00:FS01:0x22:********************************************************************************
14:42:46:WU00:FS01:0x22:Project: 14564 (Run 19, Clone 2, Gen 0)
14:42:46:WU00:FS01:0x22:Unit: 0x00000001cedfaa925eb08d3dbe9155aa
14:42:46:WU00:FS01:0x22:Reading tar file core.xml
14:42:46:WU00:FS01:0x22:Reading tar file integrator.xml
14:42:46:WU00:FS01:0x22:Reading tar file state.xml
14:42:46:WU00:FS01:0x22:Reading tar file system.xml
14:42:46:WU00:FS01:0x22:Digital signatures verified
14:42:46:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:42:46:WU00:FS01:0x22:Version 0.0.5
14:42:54:WU00:FS01:0x22:Completed 0 out of 8000000 steps (0%)
14:42:54:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:44:16:WU00:FS01:0x22:Completed 80000 out of 8000000 steps (1%)
14:45:39:WU00:FS01:0x22:Completed 160000 out of 8000000 steps (2%)
14:47:01:WU00:FS01:0x22:Completed 240000 out of 8000000 steps (3%)
14:48:23:WU00:FS01:0x22:Completed 320000 out of 8000000 steps (4%)
14:49:46:WU00:FS01:0x22:Completed 400000 out of 8000000 steps (5%)
14:51:09:WU00:FS01:0x22:Completed 480000 out of 8000000 steps (6%)
14:52:32:WU00:FS01:0x22:Completed 560000 out of 8000000 steps (7%)
14:53:56:WU00:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
14:55:20:WU00:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
14:56:43:WU00:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
14:58:06:WU00:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
14:59:30:WU00:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
15:00:09:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:00:09:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
15:01:10:WU00:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
15:02:33:WU00:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
15:03:57:WU00:FS01:0x22:Completed 1200000 out of 8000000 steps (15%)
15:05:20:WU00:FS01:0x22:Completed 1280000 out of 8000000 steps (16%)
15:05:22:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:05:22:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
15:06:45:WU00:FS01:0x22:Completed 1360000 out of 8000000 steps (17%)
15:08:09:WU00:FS01:0x22:Completed 1440000 out of 8000000 steps (18%)
15:09:32:WU00:FS01:0x22:Completed 1520000 out of 8000000 steps (19%)
15:10:55:WU00:FS01:0x22:Completed 1600000 out of 8000000 steps (20%)
15:12:18:WU00:FS01:0x22:Completed 1680000 out of 8000000 steps (21%)
15:13:42:WU00:FS01:0x22:Completed 1760000 out of 8000000 steps (22%)
15:15:05:WU00:FS01:0x22:Completed 1840000 out of 8000000 steps (23%)
15:16:29:WU00:FS01:0x22:Completed 1920000 out of 8000000 steps (24%)
15:17:53:WU00:FS01:0x22:Completed 2000000 out of 8000000 steps (25%)
15:19:16:WU00:FS01:0x22:Completed 2080000 out of 8000000 steps (26%)
15:20:40:WU00:FS01:0x22:Completed 2160000 out of 8000000 steps (27%)
15:22:03:WU00:FS01:0x22:Completed 2240000 out of 8000000 steps (28%)
15:23:26:WU00:FS01:0x22:Completed 2320000 out of 8000000 steps (29%)
15:24:49:WU00:FS01:0x22:Completed 2400000 out of 8000000 steps (30%)
15:26:13:WU00:FS01:0x22:Completed 2480000 out of 8000000 steps (31%)
15:27:36:WU00:FS01:0x22:Completed 2560000 out of 8000000 steps (32%)
15:28:33:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:28:33:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
15:28:33:WU00:FS01:0x22:ERROR:114: Max Retries Reached
15:28:33:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
15:28:33:WU00:FS01:0x22:Saving result file badstate-0.xml
15:28:33:WU00:FS01:0x22:Saving result file badstate-1.xml
15:28:33:WU00:FS01:0x22:Saving result file badstate-2.xml
15:28:33:WU00:FS01:0x22:Saving result file checkpointState.xml
15:28:33:WU00:FS01:0x22:Saving result file checkpt.crc
15:28:33:WU00:FS01:0x22:Saving result file positions.xtc
15:28:33:WU00:FS01:0x22:Saving result file science.log
15:28:33:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:28:34:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14564 run:19 clone:2 gen:0 core:0x22 unit:0x00000001cedfaa925eb08d3dbe9155aa
15:28:34:WU00:FS01:Uploading 14.33MiB to 206.223.170.146
15:28:34:WU00:FS01:Connecting to 206.223.170.146:
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
NVIDIA GeForce GTX 1080
bikeaddict
Re: Bad Work Unit, several of them
Post by bikeaddict »
I got some of these when I had my GPU overclocked, but they went away with stock settings.
No, that's not the whole log for the GPU. Clearly the WU didn't start a 8%.
If you're using FAHControl to view the log, you have to do a Refresh so it includes the beginning of the log. Notice that at 08:29:12 it says "Found a checkpoint file"
After my refresh, if I do nothing, it looks like this
If I do NOT select my GPU slot, the actual beginning of the flie looks like this:
*********************** Log Started 2020-05-10T08:28:49Z ***********************
08:28:49:****************************** FAHClient ******************************
08:28:49:        Version: 7.6.8
08:28:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:28:49:******************************** CBang ********************************
08:28:49:           Date: Apr 15 2020
08:28:49:           Time: 14:52:13
08:28:49:       Revision: 640ed4bc1084ddf2aa9cfa32aa9a2470dc8b7857
08:28:49:         Branch: master
08:28:49:       Compiler: Visual C++ 2008
08:28:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:28:49:       Platform: win32 10
08:28:49:           Bits: 32
08:28:49:           Mode: Release
08:28:49:******************************* System ********************************
08:28:49:            CPU: AMD A8-5500 APU with Radeon(tm) HD Graphics
08:28:49:         CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
08:28:49:           CPUs: 4
08:28:49:         Memory: 3.95GiB
08:28:49:    Free Memory: 2.22GiB
08:28:49:        Threads: WINDOWS_THREADS
08:28:49:     OS Version: 6.2
08:28:49:    Has Battery: false
08:28:49:     On Battery: false
08:28:49:     UTC Offset: -7
08:28:49:            PID: 9280
08:28:49:            CWD: C:\Users\ovies\AppData\Roaming\FAHClient
08:28:49:             OS: Windows 10 Home
08:28:49:        OS Arch: AMD64
08:28:49:           GPUs: 1
08:28:49:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
08:28:49:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
08:28:49:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:431.86
08:28:49:  Win32 Service: false
08:28:49:***********************************************************************
08:28:49:<config>
08:28:49:</config>
08:28:49:Trying to access database...
08:28:50:Successfully acquired database lock
08:28:50:Enabled folding slot 00: READY cpu:3
08:28:50:Enabled folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138
08:28:50:WU01:FS00:Cleaning up
08:28:51:WU00:FS01:Cleaning up
08:28:52:WU02:FS00:Starting
08:28:53:WU02:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\ovies\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 9280 -checkpoint 15 -np 3
08:28:54:WU02:FS00:Started FahCore on PID 10000
08:28:54:WU02:FS00:Core PID:10020
After my refresh, if I select slot 1 (my GPU slot) it looks like this:
08:28:56:WU03:FS01:Starting
08:28:57:WU03:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\ovies\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9280 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:28:57:WU03:FS01:Started FahCore on PID 8820
08:28:57:WU03:FS01:Core PID:9248
08:28:57:WU03:FS01:FahCore 0x22 started
08:29:01:WU03:FS01:0x22:*********************** Log Started 2020-05-10T08:29:01Z ***********************
08:29:01:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:29:01:WU03:FS01:0x22:       Type: 0x22
08:29:01:WU03:FS01:0x22:       Core: Core22
08:29:01:WU03:FS01:0x22:    Website: https://foldingathome.org/
08:29:01:WU03:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:29:01:WU03:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:29:01:WU03:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:29:01:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 8820 -checkpoint 15
08:29:01:WU03:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:29:01:WU03:FS01:0x22:             0 -gpu 0
08:29:01:WU03:FS01:0x22:     Config: <none>
08:29:01:WU03:FS01:0x22:************************************ Build *************************************
08:29:01:WU03:FS01:0x22:    Version: 0.0.5
08:29:01:WU03:FS01:0x22:       Date: Apr 22 2020
08:29:01:WU03:FS01:0x22:       Time: 04:42:59
08:29:01:WU03:FS01:0x22: Repository: Git
08:29:01:WU03:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
08:29:01:WU03:FS01:0x22:     Branch: HEAD
08:29:01:WU03:FS01:0x22:   Compiler: Visual C++ 2008
08:29:01:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:29:01:WU03:FS01:0x22:   Platform: win32 10
08:29:01:WU03:FS01:0x22:       Bits: 64
08:29:01:WU03:FS01:0x22:       Mode: Release
08:29:01:WU03:FS01:0x22:************************************ System ************************************
08:29:01:WU03:FS01:0x22:        CPU: AMD A8-5500 APU with Radeon(tm) HD Graphics
08:29:01:WU03:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
08:29:01:WU03:FS01:0x22:       CPUs: 4
08:29:01:WU03:FS01:0x22:     Memory: 3.95GiB
08:29:01:WU03:FS01:0x22:Free Memory: 2.15GiB
08:29:01:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
08:29:01:WU03:FS01:0x22: OS Version: 6.2
08:29:01:WU03:FS01:0x22:Has Battery: false
08:29:01:WU03:FS01:0x22: On Battery: false
08:29:01:WU03:FS01:0x22: UTC Offset: -7
08:29:01:WU03:FS01:0x22:        PID: 9248
08:29:01:WU03:FS01:0x22:        CWD: C:\Users\ovies\AppData\Roaming\FAHClient\work
08:29:01:WU03:FS01:0x22:         OS: Windows 10 Home
08:29:01:WU03:FS01:0x22:    OS Arch: AMD64
08:29:01:WU03:FS01:0x22:********************************************************************************
08:29:01:WU03:FS01:0x22:Project: 16444 (Run 0, Clone 958, Gen 6)
08:29:01:WU03:FS01:0x22:Unit: 0x0000000980fccb015eaa0015524997aa
08:29:01:WU03:FS01:0x22:Digital signatures verified
08:29:01:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:29:01:WU03:FS01:0x22:Version 0.0.5
08:29:12:WU03:FS01:0x22:  Found a checkpoint file
08:29:59:WU03:FS01:0x22:Completed 1120000 out of 5000000 steps (22%)
08:29:59:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:34:52:WU03:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
08:42:03:WU03:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
KA1J
Post by KA1J »
Bruce, Got it. After a refresh this is what it shows. Although at the moment it's chugging along apparently fine.
Anything of value here? I'm not used to seeing WU's disappear when still having more to go.
*********************** Log Started 2020-05-10T19:46:04Z ***********************
19:46:04:WU01:FS01:Starting
19:46:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 14852 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:46:04:WU01:FS01:Started FahCore on PID 5436
19:46:04:WU01:FS01:Core PID:15344
19:46:04:WU01:FS01:FahCore 0x22 started
19:46:05:WU01:FS01:0x22:*********************** Log Started 2020-05-10T19:46:04Z ***********************
19:46:05:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:46:05:WU01:FS01:0x22:       Type: 0x22
19:46:05:WU01:FS01:0x22:       Core: Core22
19:46:05:WU01:FS01:0x22:    Website: https://foldingathome.org/
19:46:05:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:46:05:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:46:05:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:46:05:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 5436 -checkpoint 3
19:46:05:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:46:05:WU01:FS01:0x22:             0 -gpu 0
19:46:05:WU01:FS01:0x22:     Config: <none>
19:46:05:WU01:FS01:0x22:************************************ Build *************************************
19:46:05:WU01:FS01:0x22:    Version: 0.0.5
19:46:05:WU01:FS01:0x22:       Date: Apr 22 2020
19:46:05:WU01:FS01:0x22:       Time: 04:42:59
19:46:05:WU01:FS01:0x22: Repository: Git
19:46:05:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
19:46:05:WU01:FS01:0x22:     Branch: HEAD
19:46:05:WU01:FS01:0x22:   Compiler: Visual C++ 2008
19:46:05:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:46:05:WU01:FS01:0x22:   Platform: win32 10
19:46:05:WU01:FS01:0x22:       Bits: 64
19:46:05:WU01:FS01:0x22:       Mode: Release
19:46:05:WU01:FS01:0x22:************************************ System ************************************
19:46:05:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
19:46:05:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:46:05:WU01:FS01:0x22:       CPUs: 12
19:46:05:WU01:FS01:0x22:     Memory: 31.92GiB
19:46:05:WU01:FS01:0x22:Free Memory: 27.69GiB
19:46:05:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:46:05:WU01:FS01:0x22: OS Version: 6.2
19:46:05:WU01:FS01:0x22:Has Battery: false
19:46:05:WU01:FS01:0x22: On Battery: false
19:46:05:WU01:FS01:0x22: UTC Offset: -4
19:46:05:WU01:FS01:0x22:        PID: 15344
19:46:05:WU01:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
19:46:05:WU01:FS01:0x22:         OS: Windows 10 Enterprise
19:46:05:WU01:FS01:0x22:    OS Arch: AMD64
19:46:05:WU01:FS01:0x22:********************************************************************************
19:46:05:WU01:FS01:0x22:Project: 14564 (Run 893, Clone 1, Gen 1)
19:46:05:WU01:FS01:0x22:Unit: 0x00000003cedfaa925eb08d3cc648fd4d
19:46:05:WU01:FS01:0x22:Digital signatures verified
19:46:05:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:46:05:WU01:FS01:0x22:Version 0.0.5
19:46:05:WU01:FS01:0x22:  Found a checkpoint file
19:46:07:WU01:FS01:0x22:Completed 580000 out of 8000000 steps (7%)
19:46:07:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:47:21:WU01:FS01:0x22:Completed 640000 out of 8000000 steps (8%)
19:48:56:WU01:FS01:0x22:Completed 720000 out of 8000000 steps (9%)
19:50:29:WU01:FS01:0x22:Completed 800000 out of 8000000 steps (10%)
19:52:02:WU01:FS01:0x22:Completed 880000 out of 8000000 steps (11%)
19:53:36:WU01:FS01:0x22:Completed 960000 out of 8000000 steps (12%)
19:55:08:WU01:FS01:0x22:Completed 1040000 out of 8000000 steps (13%)
19:56:43:WU01:FS01:0x22:Completed 1120000 out of 8000000 steps (14%)
ROG Strix Z390-E Motherboard
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
Post by Neil-B »
FWIW ... Since your WU returned "Faulty" this WU has been completed OK by another folder ... https://apps.foldingathome.org/wu#proje ... 31&gen=100 ... I'll let someone with better knowledge give guidance as to what might be the cause but this might mean it is less a "Bad WU" and more something about your setup (overclocked, drivers, etc.) ... but I am not a GPU guru so I may be way off base.
