Mod note: merged two first posts into single topic
I just installed v 7.6.13 of the controller package. The processor control switch appears to be non functional. The processor runs full-tilt, no matter what setting the control switch is on. I'll be unable to participate unless I can resolve this problem. Please help!
No Control of Processor Use
Re: No Control of Processor Use
I assume you are talking about the Power slider in the Web Control interface, at https://client.foldingathome.org/ ?
You can have a better control of the processor use with Advanced Control (aka FAHControl). Once there, click Configure -> Slots -> double-clic CPU and replace the "-1" in the CPUs field with the number of threads you want to allocate to FAH. Half of your processor's threads would be a good place to start.
And if that doesn't help, please post your log: viewtopic.php?p=327412&f=24#p327412
contrawise
Controller CPU Switch Has No effect
Mac laptop with i7 quad processor. OS Version 10.11.6
F@H CPU Controller - Light / Medium / Heavy - Switch appears to have no effect on processor use.
I'll be unable to participate unless I can have some processor control.
Battery is charging @2.5 A and making 0% charging headway with the CPU Switch set to "Light".
*********************** Log Started 2020-05-09T14:53:43Z ***********************
14:53:43:Trying to access database...
14:53:44:Successfully acquired database lock
14:53:44:Downloading GPUs.txt from assign1.foldingathome.org:80
14:53:44:Connecting to assign1.foldingathome.org:80
14:53:44:Read GPUs.txt
14:53:44:Enabled folding slot 00: READY cpu:3
14:53:44:****************************** FAHClient ******************************
14:53:44: Version: 7.6.13
14:53:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:53:44: Copyright: 2020 foldingathome.org
14:53:44: Homepage: https://foldingathome.org/
14:53:44: Date: Apr 27 2020
14:53:44: Time: 21:20:45
14:53:44: Revision: 5a652817f46116b6e135503af97f18e094414e3b
14:53:44: Branch: master
14:53:44: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:53:44: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:53:44: -Wno-unused-local-typedefs -stdlib=libc++
14:53:44: Platform: darwin 19.2.0
14:53:44: Bits: 64
14:53:44: Mode: Release
14:53:44: Args: --child --respawn
14:53:44: Config: /Library/Application Support/FAHClient/config.xml
14:53:44:******************************** CBang ********************************
14:53:44: Date: Apr 24 2020
14:53:44: Time: 17:07:50
14:53:44: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
14:53:44: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:53:44: Bits: 64
14:53:44:******************************* System ********************************
14:53:44: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
14:53:44: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
14:53:44: CPUs: 8
14:53:44: Memory: 16.00GiB
14:53:44:Free Memory: 1.79GiB
14:53:44: Threads: POSIX_THREADS
14:53:44: OS Version: 10.11
14:53:44:Has Battery: true
14:53:44: On Battery: false
14:53:44: UTC Offset: -5
14:53:44: PID: 7916
14:53:44: CWD: /Library/Application Support/FAHClient
14:53:44: OS: Darwin 15.6.0 x86_64
14:53:44: OS Arch: AMD64
14:53:44: GPUs: 0
14:53:44: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
14:53:44: dlopen(libcuda.dylib, 1): image not found
14:53:44: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
14:53:44: dlopen(libOpenCL.dylib, 1): image not found
14:53:44:******************************* libFAH ********************************
14:53:44: Date: Apr 15 2020
14:53:44: Time: 14:43:28
14:53:44: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:53:44: Bits: 64
14:53:44:***********************************************************************
14:53:44:<config>
14:53:44: <!-- Folding Slot Configuration -->
14:53:44: <cause v='ALZHEIMERS'/>
14:53:44:
14:53:44: <!-- Folding Slots -->
14:53:44: <slot id='0' type='CPU'/>
14:53:44:</config>
14:53:44:WARNING:WU00:FS00:Past final deadline 2020-03-26T03:12:32Z, dumping
14:53:44:WU00:FS00:Cleaning up
14:53:44:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:53:45:WU00:FS00:Assigned to work server 128.252.203.1
14:53:45:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.1
14:53:45:WU00:FS00:Connecting to 128.252.203.1:8080
14:54:04:WU00:FS00:Downloading 1.39MiB
14:54:05:WU00:FS00:Download complete
14:54:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16428 run:129 clone:3 gen:18 core:0xa7 unit:0x0000001480fccb015ea74f6d79e48419
14:54:05:WU00:FS00:Starting
14:54:05:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 7916 -checkpoint 15 -np 3
14:54:05:WU00:FS00:Started FahCore on PID 8652
14:54:05:WU00:FS00:Core PID:8653
14:54:05:WU00:FS00:FahCore 0xa7 started
14:54:06:WU00:FS00:0xa7:*********************** Log Started 2020-05-09T14:54:05Z ***********************
14:54:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:54:06:WU00:FS00:0xa7: Type: 0xa7
14:54:06:WU00:FS00:0xa7: Core: Gromacs
14:54:06:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8652 -checkpoint 15 -np 3
14:54:06:WU00:FS00:0xa7:************************************ CBang *************************************
14:54:06:WU00:FS00:0xa7: Date: Oct 26 2019
14:54:06:WU00:FS00:0xa7: Time: 03:00:53
14:54:06:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:54:06:WU00:FS00:0xa7: Branch: master
14:54:06:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:54:06:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:54:06:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:54:06:WU00:FS00:0xa7: Platform: darwin 19.0.0
14:54:06:WU00:FS00:0xa7: Bits: 64
14:54:06:WU00:FS00:0xa7: Mode: Release
14:54:06:WU00:FS00:0xa7:************************************ System ************************************
14:54:06:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
14:54:06:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
14:54:06:WU00:FS00:0xa7: CPUs: 8
14:54:06:WU00:FS00:0xa7: Memory: 16.00GiB
14:54:06:WU00:FS00:0xa7:Free Memory: 1.85GiB
14:54:06:WU00:FS00:0xa7: Threads: POSIX_THREADS
14:54:06:WU00:FS00:0xa7: OS Version: 10.11
14:54:06:WU00:FS00:0xa7:Has Battery: true
14:54:06:WU00:FS00:0xa7: On Battery: false
14:54:06:WU00:FS00:0xa7: UTC Offset: -5
14:54:06:WU00:FS00:0xa7: PID: 8653
14:54:06:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
14:54:06:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:54:06:WU00:FS00:0xa7: Version: 0.0.18
14:54:06:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:54:06:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
14:54:06:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
14:54:06:WU00:FS00:0xa7: Time: 03:06:33
14:54:06:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:54:06:WU00:FS00:0xa7:************************************ Build *************************************
14:54:06:WU00:FS00:0xa7: SIMD: avx_256
14:54:06:WU00:FS00:0xa7:********************************************************************************
14:54:06:WU00:FS00:0xa7:Project: 16428 (Run 129, Clone 3, Gen 18)
14:54:06:WU00:FS00:0xa7:Unit: 0x0000001480fccb015ea74f6d79e48419
14:54:06:WU00:FS00:0xa7:Reading tar file core.xml
14:54:06:WU00:FS00:0xa7:Reading tar file frame18.tpr
14:54:06:WU00:FS00:0xa7:Digital signatures verified
14:54:06:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpt 15 -nt 3
14:54:06:WU00:FS00:0xa7:Steps: first=9000000 total=500000
14:54:06:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:56:10:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:58:14:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
14:59:17:FS00:Paused
14:59:17:FS00:Shutting core down
14:59:17:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 8653
14:59:17:WU00:FS00:0xa7:Exiting, please wait. . .
14:59:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:59:50:Saving configuration to config.xml
14:59:50:<config>
14:59:50: <!-- Folding Slot Configuration -->
14:59:50: <cause v='ALZHEIMERS'/>
14:59:50:
14:59:50: <!-- Folding Slots -->
14:59:50: <slot id='0' type='CPU'>
14:59:50: <paused v='true'/>
14:59:50: </slot>
14:59:50:</config>
15:00:28:FS00:Unpaused
15:00:28:WU00:FS00:Starting
15:00:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 7916 -checkpoint 15 -np 3
15:00:28:WU00:FS00:Started FahCore on PID 8786
15:00:28:WU00:FS00:Core PID:8787
15:00:28:WU00:FS00:FahCore 0xa7 started
15:00:28:WU00:FS00:0xa7:*********************** Log Started 2020-05-09T15:00:28Z ***********************
15:00:28:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:00:28:WU00:FS00:0xa7: Type: 0xa7
15:00:28:WU00:FS00:0xa7: Core: Gromacs
15:00:28:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8786 -checkpoint 15 -np 3
15:00:28:WU00:FS00:0xa7:************************************ CBang *************************************
15:00:28:WU00:FS00:0xa7: Date: Oct 26 2019
15:00:28:WU00:FS00:0xa7: Time: 03:00:53
15:00:28:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
15:00:28:WU00:FS00:0xa7: Branch: master
15:00:28:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
15:00:28:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
15:00:28:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
15:00:28:WU00:FS00:0xa7: Platform: darwin 19.0.0
15:00:28:WU00:FS00:0xa7: Bits: 64
15:00:28:WU00:FS00:0xa7: Mode: Release
15:00:28:WU00:FS00:0xa7:************************************ System ************************************
15:00:28:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
15:00:28:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
15:00:28:WU00:FS00:0xa7: CPUs: 8
15:00:28:WU00:FS00:0xa7: Memory: 16.00GiB
15:00:28:WU00:FS00:0xa7:Free Memory: 1.84GiB
15:00:28:WU00:FS00:0xa7: Threads: POSIX_THREADS
15:00:28:WU00:FS00:0xa7: OS Version: 10.11
15:00:28:WU00:FS00:0xa7:Has Battery: true
15:00:28:WU00:FS00:0xa7: On Battery: false
15:00:28:WU00:FS00:0xa7: UTC Offset: -5
15:00:28:WU00:FS00:0xa7: PID: 8787
15:00:28:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
15:00:28:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:00:28:WU00:FS00:0xa7: Version: 0.0.18
15:00:28:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:00:28:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:00:28:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:00:28:WU00:FS00:0xa7: Time: 03:06:33
15:00:28:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
15:00:28:WU00:FS00:0xa7:************************************ Build *************************************
15:00:28:WU00:FS00:0xa7: SIMD: avx_256
15:00:28:WU00:FS00:0xa7:********************************************************************************
15:00:28:WU00:FS00:0xa7:Project: 16428 (Run 129, Clone 3, Gen 18)
15:00:28:WU00:FS00:0xa7:Unit: 0x0000001480fccb015ea74f6d79e48419
15:00:28:WU00:FS00:0xa7:Digital signatures verified
15:00:28:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpi state.cpt -cpt 15 -nt 3
15:00:28:WU00:FS00:0xa7:Steps: first=9000000 total=500000
15:00:28:WU00:FS00:0xa7:Completed 12552 out of 500000 steps (2%)
15:00:51:Saving configuration to config.xml
15:00:51:<config>
15:00:51: <!-- Folding Slot Configuration -->
15:00:51: <cause v='ALZHEIMERS'/>
15:00:51:
15:00:51: <!-- Folding Slots -->
15:00:51: <slot id='0' type='CPU'/>
15:00:51:</config>
15:01:20:FS00:Shutting core down
15:01:21:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 8787
15:01:21:WU00:FS00:0xa7:Exiting, please wait. . .
15:01:22:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:01:22:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:01:28:WU00:FS00:Starting
15:01:28:WARNING:WU00:FS00:Changed SMP threads from 3 to 8 this can cause some work units to fail
15:01:28:WARNING:WU00:FS00:AS lowered CPUs from 8 to 3
15:01:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 7916 -checkpoint 15 -np 3
15:01:28:WU00:FS00:Started FahCore on PID 8809
15:01:28:WU00:FS00:Core PID:8810
15:01:28:WU00:FS00:FahCore 0xa7 started
15:01:29:WU00:FS00:0xa7:*********************** Log Started 2020-05-09T15:01:28Z ***********************
15:01:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:01:29:WU00:FS00:0xa7: Type: 0xa7
15:01:29:WU00:FS00:0xa7: Core: Gromacs
15:01:29:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8809 -checkpoint 15 -np 3
15:01:29:WU00:FS00:0xa7:************************************ CBang *************************************
15:01:29:WU00:FS00:0xa7: Date: Oct 26 2019
15:01:29:WU00:FS00:0xa7: Time: 03:00:53
15:01:29:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
15:01:29:WU00:FS00:0xa7: Branch: master
15:01:29:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
15:01:29:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
15:01:29:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
15:01:29:WU00:FS00:0xa7: Platform: darwin 19.0.0
15:01:29:WU00:FS00:0xa7: Bits: 64
15:01:29:WU00:FS00:0xa7: Mode: Release
15:01:29:WU00:FS00:0xa7:************************************ System ************************************
15:01:29:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
15:01:29:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
15:01:29:WU00:FS00:0xa7: CPUs: 8
15:01:29:WU00:FS00:0xa7: Memory: 16.00GiB
15:01:29:WU00:FS00:0xa7:Free Memory: 1.83GiB
15:01:29:WU00:FS00:0xa7: Threads: POSIX_THREADS
15:01:29:WU00:FS00:0xa7: OS Version: 10.11
15:01:29:WU00:FS00:0xa7:Has Battery: true
15:01:29:WU00:FS00:0xa7: On Battery: false
15:01:29:WU00:FS00:0xa7: UTC Offset: -5
15:01:29:WU00:FS00:0xa7: PID: 8810
15:01:29:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
15:01:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:01:29:WU00:FS00:0xa7: Version: 0.0.18
15:01:29:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:01:29:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:01:29:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:01:29:WU00:FS00:0xa7: Time: 03:06:33
15:01:29:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
15:01:29:WU00:FS00:0xa7:************************************ Build *************************************
15:01:29:WU00:FS00:0xa7: SIMD: avx_256
15:01:29:WU00:FS00:0xa7:********************************************************************************
15:01:29:WU00:FS00:0xa7:Project: 16428 (Run 129, Clone 3, Gen 18)
15:01:29:WU00:FS00:0xa7:Unit: 0x0000001480fccb015ea74f6d79e48419
15:01:29:WU00:FS00:0xa7:Digital signatures verified
15:01:29:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpi state.cpt -cpt 15 -nt 3
15:01:29:WU00:FS00:0xa7:Steps: first=9000000 total=500000
15:01:29:WU00:FS00:0xa7:Completed 14672 out of 500000 steps (2%)
15:01:37:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
15:01:52:Saving configuration to config.xml
15:01:52:<config>
15:01:52: <!-- Folding Slot Configuration -->
15:01:52: <cause v='ALZHEIMERS'/>
15:01:52:
15:01:52: <!-- Slot Control -->
15:01:52: <power v='full'/>
15:01:52:
15:01:52: <!-- Folding Slots -->
15:01:52: <slot id='0' type='CPU'/>
15:01:52:</config>
15:02:14:FS00:Shutting core down
15:02:14:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 8810
15:02:14:WU00:FS00:0xa7:Exiting, please wait. . .
15:02:16:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:02:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:02:28:WU00:FS00:Starting
15:02:28:WARNING:WU00:FS00:Changed SMP threads from 8 to 3 this can cause some work units to fail
15:02:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 7916 -checkpoint 15 -np 3
15:02:28:WU00:FS00:Started FahCore on PID 8831
15:02:28:WU00:FS00:Core PID:8832
15:02:28:WU00:FS00:FahCore 0xa7 started
15:02:29:WU00:FS00:0xa7:*********************** Log Started 2020-05-09T15:02:28Z ***********************
15:02:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:02:29:WU00:FS00:0xa7: Type: 0xa7
15:02:29:WU00:FS00:0xa7: Core: Gromacs
15:02:29:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 8831 -checkpoint 15 -np 3
15:02:29:WU00:FS00:0xa7:************************************ CBang *************************************
15:02:29:WU00:FS00:0xa7: Date: Oct 26 2019
15:02:29:WU00:FS00:0xa7: Time: 03:00:53
15:02:29:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
15:02:29:WU00:FS00:0xa7: Branch: master
15:02:29:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
15:02:29:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
15:02:29:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
15:02:29:WU00:FS00:0xa7: Platform: darwin 19.0.0
15:02:29:WU00:FS00:0xa7: Bits: 64
15:02:29:WU00:FS00:0xa7: Mode: Release
15:02:29:WU00:FS00:0xa7:************************************ System ************************************
15:02:29:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
15:02:29:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
15:02:29:WU00:FS00:0xa7: CPUs: 8
15:02:29:WU00:FS00:0xa7: Memory: 16.00GiB
15:02:29:WU00:FS00:0xa7:Free Memory: 1.83GiB
15:02:29:WU00:FS00:0xa7: Threads: POSIX_THREADS
15:02:29:WU00:FS00:0xa7: OS Version: 10.11
15:02:29:WU00:FS00:0xa7:Has Battery: true
15:02:29:WU00:FS00:0xa7: On Battery: false
15:02:29:WU00:FS00:0xa7: UTC Offset: -5
15:02:29:WU00:FS00:0xa7: PID: 8832
15:02:29:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
15:02:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:02:29:WU00:FS00:0xa7: Version: 0.0.18
15:02:29:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:02:29:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:02:29:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:02:29:WU00:FS00:0xa7: Time: 03:06:33
15:02:29:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
15:02:29:WU00:FS00:0xa7:************************************ Build *************************************
15:02:29:WU00:FS00:0xa7: SIMD: avx_256
15:02:29:WU00:FS00:0xa7:********************************************************************************
15:02:29:WU00:FS00:0xa7:Project: 16428 (Run 129, Clone 3, Gen 18)
15:02:29:WU00:FS00:0xa7:Unit: 0x0000001480fccb015ea74f6d79e48419
15:02:29:WU00:FS00:0xa7:Digital signatures verified
15:02:29:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpi state.cpt -cpt 15 -nt 3
15:02:29:WU00:FS00:0xa7:Steps: first=9000000 total=500000
15:02:29:WU00:FS00:0xa7:Completed 16512 out of 500000 steps (3%)
15:02:53:Saving configuration to config.xml
15:02:53:<config>
15:02:53: <!-- Folding Slot Configuration -->
15:02:53: <cause v='ALZHEIMERS'/>
15:02:53:
15:02:53: <!-- Folding Slots -->
15:02:53: <slot id='0' type='CPU'/>
15:02:53:</config>
15:03:55:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
15:05:24:FS00:Paused
15:05:24:FS00:Shutting core down
15:05:24:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 8832
15:05:24:WU00:FS00:0xa7:Exiting, please wait. . .
15:05:25:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:05:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:05:56:Saving configuration to config.xml
15:05:56:<config>
15:05:56: <!-- Folding Slot Configuration -->
15:05:56: <cause v='ALZHEIMERS'/>
15:05:56:
15:05:56: <!-- Folding Slots -->
15:05:56: <slot id='0' type='CPU'>
15:05:56: <paused v='true'/>
15:05:56: </slot>
15:05:56:</config>
16:24:32:18:127.0.0.1:New Web session
16:27:16:Saving configuration to config.xml
16:27:16:<config>
16:27:16: <!-- Folding Slot Configuration -->
16:27:16: <cause v='ALZHEIMERS'/>
16:27:16:
16:27:16: <!-- User Information -->
16:27:16: <user v='Contrawise'/>
16:27:16:
16:27:16: <!-- Folding Slots -->
16:27:16: <slot id='0' type='CPU'>
16:27:16: <paused v='true'/>
16:27:16: </slot>
16:27:16:</config>
17:40:03:FS00:Unpaused
17:40:03:WU00:FS00:Starting
17:40:03:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 7916 -checkpoint 15 -np 3
17:40:03:WU00:FS00:Started FahCore on PID 12133
17:40:03:WU00:FS00:Core PID:12134
17:40:03:WU00:FS00:FahCore 0xa7 started
17:40:05:WU00:FS00:0xa7:*********************** Log Started 2020-05-09T17:40:05Z ***********************
17:40:05:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:40:05:WU00:FS00:0xa7: Type: 0xa7
17:40:05:WU00:FS00:0xa7: Core: Gromacs
17:40:05:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 12133 -checkpoint 15 -np
17:40:05:WU00:FS00:0xa7: 3
17:40:05:WU00:FS00:0xa7:************************************ CBang *************************************
17:40:05:WU00:FS00:0xa7: Date: Oct 26 2019
17:40:05:WU00:FS00:0xa7: Time: 03:00:53
17:40:05:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
17:40:05:WU00:FS00:0xa7: Branch: master
17:40:05:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
17:40:05:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
17:40:05:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
17:40:05:WU00:FS00:0xa7: Platform: darwin 19.0.0
17:40:05:WU00:FS00:0xa7: Bits: 64
17:40:05:WU00:FS00:0xa7: Mode: Release
17:40:05:WU00:FS00:0xa7:************************************ System ************************************
17:40:05:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4770HQ CPU @ 2.20GHz
17:40:05:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
17:40:05:WU00:FS00:0xa7: CPUs: 8
17:40:05:WU00:FS00:0xa7: Memory: 16.00GiB
17:40:05:WU00:FS00:0xa7:Free Memory: 150.88MiB
17:40:05:WU00:FS00:0xa7: Threads: POSIX_THREADS
17:40:05:WU00:FS00:0xa7: OS Version: 10.11
17:40:05:WU00:FS00:0xa7:Has Battery: true
17:40:05:WU00:FS00:0xa7: On Battery: false
17:40:05:WU00:FS00:0xa7: UTC Offset: -5
17:40:05:WU00:FS00:0xa7: PID: 12134
17:40:05:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
17:40:05:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:40:05:WU00:FS00:0xa7: Version: 0.0.18
17:40:05:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:40:05:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
17:40:05:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
17:40:05:WU00:FS00:0xa7: Time: 03:06:33
17:40:05:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
17:40:05:WU00:FS00:0xa7:************************************ Build *************************************
17:40:05:WU00:FS00:0xa7: SIMD: avx_256
17:40:05:WU00:FS00:0xa7:********************************************************************************
17:40:05:WU00:FS00:0xa7:Project: 16428 (Run 129, Clone 3, Gen 18)
17:40:05:WU00:FS00:0xa7:Unit: 0x0000001480fccb015ea74f6d79e48419
17:40:05:WU00:FS00:0xa7:Digital signatures verified
17:40:05:WU00:FS00:0xa7:Calling: mdrun -s frame18.tpr -o frame18.trr -x frame18.xtc -cpi state.cpt -cpt 15 -nt 3
17:40:05:WU00:FS00:0xa7:Steps: first=9000000 total=500000
17:40:05:WU00:FS00:0xa7:Completed 23602 out of 500000 steps (4%)
17:40:28:Saving configuration to config.xml
17:40:28:<config>
17:40:28: <!-- Folding Slot Configuration -->
17:40:28: <cause v='ALZHEIMERS'/>
17:40:28:
17:40:28: <!-- User Information -->
17:40:28: <user v='Contrawise'/>
17:40:28:
17:40:28: <!-- Folding Slots -->
17:40:28: <slot id='0' type='CPU'/>
17:40:28:</config>
17:40:40:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
17:42:44:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
17:44:49:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
17:46:55:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
17:49:00:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
17:51:05:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
17:53:11:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
17:55:17:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
17:57:21:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
17:59:27:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
18:01:32:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
18:03:36:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
18:05:42:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
Re: Controller CPU Switch Has No effect
You have 4 core processor with hyperthreading switched on so effectively an 8 core processor if I am reading your log correctly ... The WU you have has been downloaded as a 3 core WU ... WUs never use more cores than the number of cores they have been downloaded for.
Can't spot the CPU slot details but if it is set as -1 then the client will probably allocate 7 or 8 cores (depending on whether it puts one aside for a GPU - not sure that happens on MacOS) ... Heavy would use all those cores (but the WU is only a 3core WU so uses three) - Medium would use heavy less one core (so 6/7 but again WU is 3core so uses 3core) - light uses half heavy (so 3/4 but again WU is 3core) ... This would mean that whatever setting you have the power slider on the 3core WU is the limiting factor not the power slider.
If you need less then using advanced control and reducing the CPU slot to 2core ... If you need help with this ask back in this thread.
On Light, the software trys to use 1/2 the threads, F@H calls them CPUs.
14:53:44: CPUs: 8
So this work Unit will use 3 of the 8 CPUs you have. Medium would use 7 and Full would use 8.
I am not a MacOS user but if you can start Advanced Control I can show how to tune CPU use finer.
In Advanced Control, to the left is a Configure button, click it
You can enter any number from 1 to 8, the number of threads your CPU supports.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, and 8 are good numbers of CPUs to choose.
5 may work most of the time. 7 will bite you.
Type the number you want, and click save.
14:53:44: CPUs: 8
Having a MacBook Pro myself, I would limit the CPU thread count to 4 at the most, using more will activate the HT cores which uses more power and produces more heat. That can also push the CPU clock rate down due to thermal limiting.
From some other reports, power management on some of the later Retina MacBook Pro models is a bit off at times. Mine always has enough reserves enough power to charge the battery if it goes below the 95% threshold before charging will start. But what I have is a 2012 design with optical drive that I bought just over 4 years ago before it was discontinued.
Depending on which power adapter you are using, you should have some power left over for charging. The larger 80+ W adapters are better.
If the CPU still uses too much power on Light and 4 CPU Threads, open FAHControl and click on Configure and follow the directions given above to change the number to a lower value.
contrawise
ajm wrote:I assume you are talking about the Power slider in the Web Control interface, at https://client.foldingathome.org/ ?
No - I just followed your link to that interface, for the first time , just now. It has a similar "slider" to the slider that is a part of the Mac app. It appears to be a slider, but the indicator snaps between just three positions - like a 3-position switch. Please pardon the lack of information in this original post ... I wasn't actually done with it when I had to take a phone call. When I came back to the forum, the unfinished post had disappeared. I wrote a more complete one to replace it. Log is posted in that one.
I'll try out your suggestion. Thanks!
ajm wrote:You can have a better control of the processor use with Advanced Control (aka FAHControl). Once there, click Configure -> Slots -> double-clic CPU and replace the "-1" in the CPUs field with the number of threads you want to allocate to FAH. Half of your processor's threads would be a good place to start.
Reason: fixed up quoting
