Download/Send progress bar no longer does incremental update
prcowley
Hardware configuration: Op Sys: Linux Ubuntu Studio 25.04
Kernel: 6.14.0-34-generic (64-bit)
Processor: AMD Ryzen 7 7800X3D 8-Core Processor
Mem: 32 GB
GPU: NVIDIA GeForce RTX 4080 SUPER/PCIe/SSE2
Post by prcowley »
Hi everyone
It has been quite some time since the progress bar for Downloads and uploads in FAH Control application has shown the incremental progress of files going up or down (yes, it did work once upon a time). Not sure if it now longer working is deliberate as I can not find any reference to the issues anywhere else in the forums. It is only minor, but would be nice to know especially when things are going really slowly. If it is a fault maybe it could be added to the list of things to fix at some stage.
So I have two examples:
1) Downloading a new WU.
A screen shot Image of the FAH Control shows that the percentage downloaded as 0%. Note the current time of 6:35:12 at the bottom.
A screen shot Image Looking at the log file, it shows at6:35:08 the percentage downloaded was 19.20%
2) Sending a complete WU
A screen shot Image of the FAH Control shows that the percentage sent as 100%, Note the current time of 6:37:22 at the bottom of the screen.
A screen shot Image looking at the logfile at 6:37:18 shows only 12.77% completion.
Cheers
Pete
Pete Cowley, Gisborne, New Zealand. The first city to see the light of the new day. :D
Re: Download/Send progress bar no longer does incremental up
I believe that this has been reported here as an enhancement: https://github.com/FoldingAtHome/fah-issues/issues/1444
prcowley
Mem: 32 GB
Post by prcowley »
OK, thanks for that. Didn't see this one in the issues list.
Strange that it used to work at some stage in the past.
Anyway, it is minor in the scheme of things and the grand mess that we have on our hands at the moment.
Cheers
Pete
