I may need some client config help in a VM
PedestalTech
Hey all,
I just created a fresh Windows 10 Pro x64 VM (ESXi hosted) and I'm getting really low WU performance. If anyone is familiar with running F@h in a virtual environment, I would welcome some tips.
16 vCPUs; 2 sockets
Backed by a Xeon Silver 4110 @ 2.10 GHz
The VM is allowed up to 9 GHz and it's using it all.
16 GB RAM
Opted for the bigadv flag
All cores are running at near 100% it is estimating about 20 hours to complete a WU with only 498 base credit. Does that sound right?
16 vCPUs; 2 sockets
16 GB RAM
Re: I may need some client config help in a VM
Welcome to the F@H Forum PedestalTech,
Please note that you don't need the bigadv flag... it was discontinued years ago.
Check the log and see if 3% of the WU is done or not. It is likely that FAHControl is providing an estimate where it assumes (due to lack of data) that the assigned WU will take all the time until the Timeout period to finish. Also, we would like you to post the log file here especially the first 100 lines so we can get a better idea of the system and the client configuration. Guidance is provided here: viewtopic.php?f=24&t=26036
PedestalTech
PantherX, thank you for jumping in! Below is the log from the VM. I noticed "ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine." repeating after each step is completed...
After letting it run overnight, the current estimate is 13431 PPD (not sure if that includes any bonuses). The current WU with base credit of 1225 is at 50% with about 4 hours remaining until the ETA. I still see that error in the log.
*********************** Log Started 2020-05-07T18:49:41Z ***********************
18:49:41:Trying to access database...
18:49:41:Successfully acquired database lock
18:49:42:Read GPUs.txt
18:49:42:Enabled folding slot 00: PAUSED cpu:16 (by user)
18:49:42:****************************** FAHClient ******************************
18:49:42: Version: 7.6.13
18:49:42: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:49:42: Copyright: 2020 foldingathome.org
18:49:42: Homepage: https://foldingathome.org/
18:49:42: Date: Apr 27 2020
18:49:42: Time: 21:21:01
18:49:42: Revision: 5a652817f46116b6e135503af97f18e094414e3b
18:49:42: Branch: master
18:49:42: Compiler: Visual C++ 2008
18:49:42: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:49:42: Platform: win32 10
18:49:42: Bits: 32
18:49:42: Mode: Release
18:49:42: Config: C:\Users\pedfolding\AppData\Roaming\FAHClient\config.xml
18:49:42:******************************** CBang ********************************
18:49:42: Date: Apr 24 2020
18:49:42: Time: 17:07:55
18:49:42: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
18:49:42: Bits: 32
18:49:42:******************************* System ********************************
18:49:42: CPU: Intel(R) Xeon(R) Silver 4110 CPU @ 2.10GHz
18:49:42: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
18:49:42: CPUs: 16
18:49:42: Memory: 16.00GiB
18:49:42: Free Memory: 14.22GiB
18:49:42: Threads: WINDOWS_THREADS
18:49:42: OS Version: 6.2
18:49:42: Has Battery: false
18:49:42: On Battery: false
18:49:42: UTC Offset: -7
18:49:42: PID: 7176
18:49:42: CWD: C:\Users\pedfolding\AppData\Roaming\FAHClient
18:49:42:Win32 Service: false
18:49:42: OS: Windows 10 Enterprise
18:49:42: OS Arch: AMD64
18:49:42: GPUs: 0
18:49:42: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:49:42: specified module could not be found.
18:49:42:
18:49:42: OpenCL: Not detected: clGetPlatformIDs() returned -1001
18:49:42:******************************* libFAH ********************************
18:49:42: Date: Apr 15 2020
18:49:42: Time: 14:53:14
18:49:42: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:49:42: Bits: 32
18:49:42:***********************************************************************
18:49:42:<config>
18:49:42: <!-- Folding Slot Configuration -->
18:49:42: <cause v='COVID_19'/>
18:49:42: <client-type v='bigadv'/>
18:49:42:
18:49:42: <!-- Network -->
18:49:42: <proxy v=':8080'/>
18:49:42:
18:49:42: <!-- Slot Control -->
18:49:42: <power v='FULL'/>
18:49:42:
18:49:42: <!-- User Information -->
18:49:42: <passkey v='*****'/>
18:49:42: <team v='263283'/>
18:49:42: <user v='PedestalFolding'/>
18:49:42:
18:49:42: <!-- Folding Slots -->
18:49:42: <slot id='0' type='CPU'>
18:49:42: <paused v='true'/>
18:49:42: </slot>
18:49:42:</config>
18:51:39:FS00:Unpaused
18:51:39:WU00:FS00:Starting
18:51:39:WARNING:WU00:FS00:AS lowered CPUs from 16 to 15
18:51:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pedfolding\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7176 -checkpoint 15 -np 15
18:51:40:WU00:FS00:Started FahCore on PID 5424
18:51:40:WU00:FS00:Core PID:1168
18:51:40:WU00:FS00:FahCore 0xa7 started
18:51:41:WU00:FS00:0xa7:*********************** Log Started 2020-05-07T18:51:40Z ***********************
18:51:41:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:51:41:WU00:FS00:0xa7: Type: 0xa7
18:51:41:WU00:FS00:0xa7: Core: Gromacs
18:51:41:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 5424 -checkpoint 15 -np
18:51:41:WU00:FS00:0xa7: 15
18:51:41:WU00:FS00:0xa7:************************************ CBang *************************************
18:51:41:WU00:FS00:0xa7: Date: Oct 26 2019
18:51:41:WU00:FS00:0xa7: Time: 01:38:25
18:51:41:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:51:41:WU00:FS00:0xa7: Branch: master
18:51:41:WU00:FS00:0xa7: Compiler: Visual C++ 2008
18:51:41:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:51:41:WU00:FS00:0xa7: Platform: win32 10
18:51:41:WU00:FS00:0xa7: Bits: 64
18:51:41:WU00:FS00:0xa7: Mode: Release
18:51:41:WU00:FS00:0xa7:************************************ System ************************************
18:51:41:WU00:FS00:0xa7: CPU: Intel(R) Xeon(R) Silver 4110 CPU @ 2.10GHz
18:51:41:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
18:51:41:WU00:FS00:0xa7: CPUs: 16
18:51:41:WU00:FS00:0xa7: Memory: 16.00GiB
18:51:41:WU00:FS00:0xa7:Free Memory: 14.05GiB
18:51:41:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
18:51:41:WU00:FS00:0xa7: OS Version: 6.2
18:51:41:WU00:FS00:0xa7:Has Battery: false
18:51:41:WU00:FS00:0xa7: On Battery: false
18:51:41:WU00:FS00:0xa7: UTC Offset: -4
18:51:41:WU00:FS00:0xa7: PID: 1168
18:51:41:WU00:FS00:0xa7: CWD: C:\Users\pedfolding\AppData\Roaming\FAHClient\work
18:51:41:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:51:41:WU00:FS00:0xa7: Version: 0.0.18
18:51:41:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:51:41:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
18:51:41:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
18:51:41:WU00:FS00:0xa7: Time: 01:52:30
18:51:41:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:51:41:WU00:FS00:0xa7:************************************ Build *************************************
18:51:41:WU00:FS00:0xa7: SIMD: avx_256
18:51:41:WU00:FS00:0xa7:********************************************************************************
18:51:41:WU00:FS00:0xa7:Project: 16437 (Run 0, Clone 1612, Gen 10)
18:51:41:WU00:FS00:0xa7:Unit: 0x0000000b80fccb015ea74dcdb5bb196c
18:51:41:WU00:FS00:0xa7:Digital signatures verified
18:51:41:WU00:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -x frame10.xtc -cpi state.cpt -cpt 15 -nt 15
18:51:41:WU00:FS00:0xa7:Steps: first=2500000 total=250000
18:51:43:Saving configuration to config.xml
18:51:43:<config>
18:51:43: <!-- Folding Slot Configuration -->
18:51:43: <cause v='COVID_19'/>
18:51:43: <client-type v='bigadv'/>
18:51:43:
18:51:43: <!-- Network -->
18:51:43: <proxy v=':8080'/>
18:51:43:
18:51:43: <!-- Slot Control -->
18:51:43: <power v='FULL'/>
18:51:43:
18:51:43: <!-- User Information -->
18:51:43: <passkey v='*****'/>
18:51:43: <team v='263283'/>
18:51:43: <user v='PedestalFolding'/>
18:51:43:
18:51:43: <!-- Folding Slots -->
18:51:43: <slot id='0' type='CPU'/>
18:51:43:</config>
18:51:43:WU00:FS00:0xa7:Completed 372 out of 250000 steps (0%)
18:59:47:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
19:12:26:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
19:21:10:8:127.0.0.1:New Web session
19:26:07:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
19:39:33:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
19:53:00:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:05:49:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:17:56:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:30:14:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:42:39:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:54:56:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
21:06:39:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
21:18:49:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
21:31:08:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
21:43:02:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
21:55:08:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
22:07:06:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
22:18:59:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
22:31:07:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
22:43:03:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
22:55:08:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
23:07:24:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:19:15:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
23:31:24:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
23:43:19:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
23:53:42:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
23:55:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:55:51:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:56:15:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
23:56:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:57:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:57:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
23:58:45:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
23:58:51:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
23:59:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:00:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:01:16:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
00:01:37:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:02:28:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:03:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:03:45:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
00:04:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:05:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:06:15:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
00:06:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:07:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:08:47:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
00:09:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:09:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:10:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:11:13:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
00:12:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:13:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:13:40:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
00:14:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:15:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:15:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:07:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
00:16:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:16:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:17:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:18:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:18:34:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
00:18:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:19:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:20:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:21:03:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
00:21:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:21:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:22:04:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:22:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:23:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:23:36:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
00:24:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:24:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:25:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:04:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
00:26:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:26:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:28:31:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
00:28:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:29:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:30:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:30:58:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
00:31:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:31:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:32:54:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:33:26:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
00:33:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:33:59:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:34:32:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:35:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:35:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:35:54:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
00:36:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:36:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:37:15:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:37:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:38:27:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
00:39:10:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:39:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:40:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:40:54:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
00:41:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:41:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:42:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:42:43:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:43:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:43:22:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
00:43:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:43:52:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:45:34:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:45:50:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
00:46:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:46:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:48:20:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
00:48:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:49:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
******************************* Date: 2020-05-08 *******************************
00:49:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:50:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:51:09:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
00:51:33:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:52:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:53:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:53:40:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
00:54:05:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
00:54:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:54:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:55:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:55:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:56:08:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
00:56:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:56:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:57:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:58:36:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
00:58:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:59:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:01:05:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
01:01:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:01:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:02:45:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:03:33:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
01:03:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:04:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:05:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:06:01:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
01:06:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:07:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:08:56:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
01:09:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:10:37:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:11:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:11:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:12:21:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
01:12:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:13:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:14:48:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
01:14:59:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:15:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:16:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:17:20:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
01:18:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:18:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:19:50:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
01:20:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:20:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:21:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:21:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:22:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:22:23:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
01:22:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:23:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:24:51:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
01:26:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:27:18:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
01:27:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:27:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:28:57:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:29:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:29:45:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
01:29:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:30:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:31:17:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:32:13:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
01:32:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:33:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:34:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:34:41:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:34:41:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
01:36:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:37:12:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
01:39:11:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:39:39:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
01:40:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:41:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:42:07:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
01:42:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:43:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:43:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:43:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:44:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:44:35:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
01:44:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:45:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:46:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:46:29:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:47:03:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
01:47:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:47:54:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:49:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:49:35:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
01:50:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:50:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:51:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:52:10:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
01:52:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:53:37:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:54:02:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:54:38:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
01:55:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:55:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:56:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:56:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:57:06:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
01:57:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:58:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:58:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:59:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
01:59:33:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
01:59:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:00:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:00:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:01:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:01:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:02:01:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
02:02:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:02:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:03:53:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:04:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:04:28:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
02:04:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:05:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:06:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:06:53:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:07:01:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
02:08:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:09:13:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:09:29:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
02:10:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:11:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:11:57:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
02:12:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:12:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:13:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:13:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:14:14:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:14:24:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
02:14:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:15:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:16:53:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
02:17:03:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:17:42:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:18:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:18:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:19:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:19:22:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
02:19:55:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:20:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:21:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:21:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:21:58:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
02:22:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:22:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:23:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:24:19:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:24:25:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
02:24:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:25:35:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:26:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:26:53:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
02:27:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:27:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:29:06:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:29:21:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
02:29:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:30:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:31:49:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
02:31:49:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:32:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:33:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:33:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:33:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:34:18:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
02:34:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:35:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:35:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:36:39:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:36:51:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
02:37:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:37:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:38:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:39:20:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
02:39:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:41:49:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
02:42:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:42:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:43:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:44:16:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
02:44:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:45:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:45:49:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:46:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:46:44:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
02:46:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:47:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:48:41:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:49:05:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:49:14:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
02:50:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:50:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:51:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:51:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:51:44:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
02:52:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:52:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:53:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:53:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:54:16:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
02:54:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:54:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:55:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:55:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:56:43:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
02:57:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:59:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
02:59:11:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
02:59:13:WU01:FS00:Connecting to assign1.foldingathome.org:80
02:59:15:WU01:FS00:Assigned to work server 155.247.164.214
02:59:15:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 155.247.164.214
02:59:15:WU01:FS00:Connecting to 155.247.164.214:8080
02:59:16:WU01:FS00:Downloading 2.83MiB
02:59:22:WU01:FS00:Download 88.43%
02:59:22:WU01:FS00:Download complete
02:59:24:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14727 run:1318 clone:0 gen:10 core:0xa7 unit:0x0000000c9bf7a4d65ea609ed32813123
02:59:33:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:00:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
03:01:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:01:39:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
03:01:50:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:01:50:WU00:FS00:0xa7:Saving result file frame10.trr
03:01:50:WU00:FS00:0xa7:Saving result file frame10.xtc
03:01:50:WU00:FS00:0xa7:Saving result file md.log
03:01:50:WU00:FS00:0xa7:Saving result file science.log
03:01:51:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:01:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:01:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16437 run:0 clone:1612 gen:10 core:0xa7 unit:0x0000000b80fccb015ea74dcdb5bb196c
03:01:51:WU00:FS00:Uploading 2.16MiB to 128.252.203.1
As soon as you enter a Passkey, the client assumes you are getting the Quick Return Bonus. Actually you get the QRB after 10 Work Units with a 80% success rate.
So you may see higher estimates than the stats show for a bit.
Once it finishes sending, it should give the estimate.
PedestalTech
Right, so without the estimated bonus, why is this VM with 16 cores at 8 GHz performing about half as well as my laptop with only 8 cores at a burst of 3.6 GHz? Is this just expected with VM overhead?
You VM is limited to the speed of the actual CPU providing compute capacity, it is not running at 8 GHz. There is overhead involved as well. So your VM is actually running at 2.1 GHz. Each of the 2 Xeon processors indicated in your first post provide 8 CPU cores and 16 threads total through HT. Depending on how the host OS distributes the virtual thread over the physical processors, you may be running into NUMA issues.
Reason: fixed the thread count
PedestalTech
The CPU speed makes sense. The VM is reporting to be using upwards of 2.10 GHz, but I will assume the actual usage reads that way in ESXi because the host hardware needs that to support all 16 cores at 2.10 GHz. That makes sense in my head. lol What can I do to further investigate?
When you say its allowed 9ghz is it count that as 4 threads at 2.1 or 9 threads 1 each? Sounds like it may be limited to the performance of a 4 core cpu. If so that may be all the speed you get. I've never played with vm's before so no idea, just guessing.
My suggestion would be to try processing on 8 CPU threads. The host OS should be able to schedule the VM to run on just a single processor and utilize just the main CPU core for each thread instead of sharing the FPU using HT.
The 10053 errors in older versions of the client were coming from the connection with Web Control not being closed properly. Is Web Control running in a browser through the same VM? One of the defaults is to launch that when the client is started, that can be turned off.
PedestalTech
Essentially, we tell the hypervisor to only allow the VM to use up to xGHz to avoid it greedily consuming all available resources. The process is a 2.10 GHz chip, but the VM itself can utilize up to 9 GHz from the host to run all of the vCPUs.Rel25917 wrote:When you say its allowed 9ghz is it count that as 4 threads at 2.1 or 9 threads 1 each? Sounds like it may be limited to the performance of a 4 core cpu. If so that may be all the speed you get. I've never played with vm's before so no idea, just guessing.
PedestalTech
Thanks Joe_H. I reduced the VM down to a single socket with 8 cores. I'll let it run for a while and see when the PPD levels out. I wasn't using the Web Control, only the advanced client but maybe the browser had a hung process even though I closed the application. I did notice that the Advanced Control client would periodically go blank and read "connecting" every so often. That may coincide with the errors in the log. Now that I rebooted to make the CPU change, I'll keep an eye out for that error. Maybe I just needed to turn it off and on again. I also removed the bigadv option as noted by PantherX.Joe_H wrote:My suggestion would be to try processing on 8 CPU threads. The host OS should be able to schedule the VM to run on just a single processor and utilize just the main CPU core for each thread instead of sharing the FPU using HT.
