My FAH client strange behaviour
OddSoxChris
I recently reinstalled FAH on my desktop PC with version 7.6.13 and also upgraded my GPU. After a while I noticed some unusual behaviour. The client started to download more jobs than necessary and putting them in the queue, some WUs were put "on hold". Look at this example:
https://ibb.co/KXGtHVP
The job 02 has the Ready status even though it was being processed before and is now kind of waiting to be resumed. But will it?
After a few hours the client will enter what I call "sleepwalker state" which looks like this:
https://ibb.co/vj5VGy0
In this state the client is still processing but as you can see you have no control over anything. All you can do at this point is reboot the computer and the client goes back to "normal". For the time being at least.
I still have v7.5 on my laptop and so far it has been working with no surprises.
Re: My FAH client strange behaviour
We need a logfile please to see what is going on.
How to post the logfile: viewtopic.php?p=327413&f=24#p327413
If you search the log with FAHControl, you can filter for individual WUs and/or individual slots. You can also turn on or off error messages only.
Were these WUs processed by the NVidia or the AMD GPU? Did they have errors?
Yes, we need to see the applicable segments of the log.
OddSoxChris
This is the most recent:foldy wrote:We need a logfile please to see what is going on.
*********************** Log Started 2020-05-07T10:39:59Z ***********************
10:39:59:Trying to access database...
10:39:59:Successfully acquired database lock
10:39:59:Read GPUs.txt
10:39:59:Enabled folding slot 00: READY cpu:14
10:40:01:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
10:40:01:Enabled folding slot 02: READY gpu:1:GP107 [GeForce GTX 1050 Ti] 2138
10:40:01:****************************** FAHClient ******************************
10:40:01: Version: 7.6.13
10:40:01: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:40:01: Copyright: 2020 foldingathome.org
10:40:01: Homepage: https://foldingathome.org/
10:40:01: Date: Apr 27 2020
10:40:01: Time: 21:21:01
10:40:01: Revision: 5a652817f46116b6e135503af97f18e094414e3b
10:40:01: Branch: master
10:40:01: Compiler: Visual C++ 2008
10:40:01: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:40:01: Platform: win32 10
10:40:01: Bits: 32
10:40:01: Mode: Release
10:40:01: Config: D:\FAHClient\config.xml
10:40:01:******************************** CBang ********************************
10:40:01: Date: Apr 24 2020
10:40:01: Time: 17:07:55
10:40:01: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
10:40:01: Bits: 32
10:40:01:******************************* System ********************************
10:40:01: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:40:01: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
10:40:01: CPUs: 16
10:40:01: Memory: 31.86GiB
10:40:01: Free Memory: 28.45GiB
10:40:01: Threads: WINDOWS_THREADS
10:40:01: OS Version: 6.2
10:40:01: Has Battery: false
10:40:01: On Battery: false
10:40:01: UTC Offset: 2
10:40:01: PID: 5784
10:40:01: CWD: D:\FAHClient
10:40:01: Win32 Service: false
10:40:01: OS: Windows 10 Enterprise
10:40:01: OS Arch: AMD64
10:40:01: GPUs: 2
10:40:01: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
10:40:01: 470/480/570/580/590]
10:40:01: GPU 1: Bus:5 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
10:40:01: CUDA Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:6.1 Driver:10.2
10:40:01:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
10:40:01:OpenCL Device 1: Platform:1 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:442.92
10:40:01:OpenCL Device 2: Platform:2 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
10:40:01:******************************* libFAH ********************************
10:40:01: Date: Apr 15 2020
10:40:01: Time: 14:53:14
10:40:01: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:40:01: Bits: 32
10:40:01:***********************************************************************
10:40:01:<config>
10:40:01: <!-- Folding Core -->
10:40:01: <core-priority v='low'/>
10:40:01:
10:40:01: <!-- Folding Slot Configuration -->
10:40:01: <cause v='COVID_19'/>
10:40:01:
10:40:01: <!-- Network -->
10:40:01: <proxy v=':8080'/>
10:40:01:
10:40:01: <!-- Slot Control -->
10:40:01: <pause-on-battery v='false'/>
10:40:01: <power v='full'/>
10:40:01:
10:40:01: <!-- User Information -->
10:40:01: <passkey v='*****'/>
10:40:01: <team v='247734'/>
10:40:01: <user v='OddSoxChris'/>
10:40:01:
10:40:01: <!-- Folding Slots -->
10:40:01: <slot id='0' type='CPU'/>
10:40:01: <slot id='1' type='GPU'/>
10:40:01: <slot id='2' type='GPU'/>
10:40:01:</config>
10:40:01:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:11744 run:0 clone:4672 gen:108 core:0x22 unit:0x000000928ca304f15e69f3a6dad8cb9a
10:40:01:WU04:FS01:Uploading 29.20MiB to 140.163.4.241
10:40:01:WU01:FS02:Starting
10:40:01:WU04:FS01:Connecting to 140.163.4.241:8080
10:40:01:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
10:40:01:WU01:FS02:Started FahCore on PID 14216
10:40:01:WU01:FS02:Core PID:12252
10:40:01:WU01:FS02:FahCore 0x22 started
10:40:01:WU02:FS00:Starting
10:40:01:WARNING:WU02:FS00:AS lowered CPUs from 14 to 13
10:40:01:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 13
10:40:01:WU02:FS00:Started FahCore on PID 1444
10:40:01:WU02:FS00:Core PID:7428
10:40:01:WU02:FS00:FahCore 0xa7 started
10:40:02:WU01:FS02:0x22:*********************** Log Started 2020-05-07T10:40:01Z ***********************
10:40:02:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
10:40:02:WU01:FS02:0x22: Type: 0x22
10:40:02:WU01:FS02:0x22: Core: Core22
10:40:02:WU01:FS02:0x22: Website: https://foldingathome.org/
10:40:02:WU01:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
10:40:02:WU01:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:40:02:WU01:FS02:0x22: <rafal.wiewiora@choderalab.org>
10:40:02:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 14216 -checkpoint 15
10:40:02:WU01:FS02:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
10:40:02:WU01:FS02:0x22: 0 -gpu 0
10:40:02:WU01:FS02:0x22: Config: <none>
10:40:02:WU01:FS02:0x22:************************************ Build *************************************
10:40:02:WU01:FS02:0x22: Version: 0.0.5
10:40:02:WU01:FS02:0x22: Date: Apr 22 2020
10:40:02:WU01:FS02:0x22: Time: 04:42:59
10:40:02:WU01:FS02:0x22: Repository: Git
10:40:02:WU01:FS02:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
10:40:02:WU01:FS02:0x22: Branch: HEAD
10:40:02:WU01:FS02:0x22: Compiler: Visual C++ 2008
10:40:02:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:40:02:WU01:FS02:0x22: Platform: win32 10
10:40:02:WU01:FS02:0x22: Bits: 64
10:40:02:WU01:FS02:0x22: Mode: Release
10:40:02:WU01:FS02:0x22:************************************ System ************************************
10:40:02:WU01:FS02:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:40:02:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
10:40:02:WU01:FS02:0x22: CPUs: 16
10:40:02:WU01:FS02:0x22: Memory: 31.86GiB
10:40:02:WU01:FS02:0x22:Free Memory: 28.21GiB
10:40:02:WU01:FS02:0x22: Threads: WINDOWS_THREADS
10:40:02:WU01:FS02:0x22: OS Version: 6.2
10:40:02:WU01:FS02:0x22:Has Battery: false
10:40:02:WU01:FS02:0x22: On Battery: false
10:40:02:WU01:FS02:0x22: UTC Offset: 2
10:40:02:WU01:FS02:0x22: PID: 12252
10:40:02:WU01:FS02:0x22: CWD: D:\FAHClient\work
10:40:02:WU01:FS02:0x22: OS: Windows 10 Pro
10:40:02:WU01:FS02:0x22: OS Arch: AMD64
10:40:02:WU01:FS02:0x22:********************************************************************************
10:40:02:WU01:FS02:0x22:Project: 11745 (Run 0, Clone 808, Gen 80)
10:40:02:WU01:FS02:0x22:Unit: 0x0000007f8ca304f15e67ec9e33491f71
10:40:02:WU01:FS02:0x22:Digital signatures verified
10:40:02:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
10:40:02:WU01:FS02:0x22:Version 0.0.5
10:40:02:WU02:FS00:0xa7:*********************** Log Started 2020-05-07T10:40:01Z ***********************
10:40:02:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:40:02:WU02:FS00:0xa7: Type: 0xa7
10:40:02:WU02:FS00:0xa7: Core: Gromacs
10:40:02:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 1444 -checkpoint 15 -np
10:40:02:WU02:FS00:0xa7: 13
10:40:02:WU02:FS00:0xa7:************************************ CBang *************************************
10:40:02:WU02:FS00:0xa7: Date: Oct 26 2019
10:40:02:WU02:FS00:0xa7: Time: 01:38:25
10:40:02:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:40:02:WU02:FS00:0xa7: Branch: master
10:40:02:WU02:FS00:0xa7: Compiler: Visual C++ 2008
10:40:02:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:40:02:WU02:FS00:0xa7: Platform: win32 10
10:40:02:WU02:FS00:0xa7: Bits: 64
10:40:02:WU02:FS00:0xa7: Mode: Release
10:40:02:WU02:FS00:0xa7:************************************ System ************************************
10:40:02:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:40:02:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
10:40:02:WU02:FS00:0xa7: CPUs: 16
10:40:02:WU02:FS00:0xa7: Memory: 31.86GiB
10:40:02:WU02:FS00:0xa7:Free Memory: 28.23GiB
10:40:02:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
10:40:02:WU02:FS00:0xa7: OS Version: 6.2
10:40:02:WU02:FS00:0xa7:Has Battery: false
10:40:02:WU02:FS00:0xa7: On Battery: false
10:40:02:WU02:FS00:0xa7: UTC Offset: 2
10:40:02:WU02:FS00:0xa7: PID: 7428
10:40:02:WU02:FS00:0xa7: CWD: D:\FAHClient\work
10:40:02:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
10:40:02:WU02:FS00:0xa7: Version: 0.0.18
10:40:02:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:40:02:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
10:40:02:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
10:40:02:WU02:FS00:0xa7: Time: 01:52:30
10:40:02:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:40:02:WU02:FS00:0xa7:************************************ Build *************************************
10:40:02:WU02:FS00:0xa7: SIMD: avx_256
10:40:02:WU02:FS00:0xa7:********************************************************************************
10:40:02:WU02:FS00:0xa7:Project: 14620 (Run 1207, Clone 1, Gen 76)
10:40:02:WU02:FS00:0xa7:Unit: 0x000000569bf7a4d55e876ce5a331f777
10:40:02:WU02:FS00:0xa7:Digital signatures verified
10:40:02:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
10:40:02:WU02:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -cpi state.cpt -cpt 15 -nt 12
10:40:02:WU02:FS00:0xa7:ERROR:Guru Meditation #a7c53e483fd63469.9688aae3e890292b (23270.24853) '02/01/pullx.xvg'
10:40:02:WU02:FS00:0xa7:WARNING:Unexpected exit() call
10:40:02:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
10:40:02:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
10:40:02:WU02:FS00:0xa7:Saving result file dhdl.xvg
10:40:02:WU02:FS00:0xa7:Saving result file frame76.trr
10:40:02:WU02:FS00:0xa7:Saving result file md.log
10:40:02:WU02:FS00:0xa7:Saving result file pullf.xvg
10:40:02:WU02:FS00:0xa7:ERROR:Guru Meditation #9a3ff096b239bab1.e39f90adf5562a95 (8040.8604) '02/01/pullf.xvg'
10:40:04:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
10:40:04:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
10:40:04:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:40:04:WU03:FS00:Starting
10:40:04:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 14
10:40:04:WU03:FS00:Started FahCore on PID 11368
10:40:04:WU03:FS00:Core PID:11332
10:40:04:WU03:FS00:FahCore 0xa7 started
10:40:04:WU03:FS00:0xa7:*********************** Log Started 2020-05-07T10:40:04Z ***********************
10:40:04:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:40:04:WU03:FS00:0xa7: Type: 0xa7
10:40:04:WU03:FS00:0xa7: Core: Gromacs
10:40:04:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 11368 -checkpoint 15 -np
10:40:04:WU03:FS00:0xa7: 14
10:40:04:WU03:FS00:0xa7:************************************ CBang *************************************
10:40:04:WU03:FS00:0xa7: Date: Oct 26 2019
10:40:04:WU03:FS00:0xa7: Time: 01:38:25
10:40:04:WU03:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:40:04:WU03:FS00:0xa7: Branch: master
10:40:04:WU03:FS00:0xa7: Compiler: Visual C++ 2008
10:40:04:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:40:04:WU03:FS00:0xa7: Platform: win32 10
10:40:04:WU03:FS00:0xa7: Bits: 64
10:40:04:WU03:FS00:0xa7: Mode: Release
10:40:04:WU03:FS00:0xa7:************************************ System ************************************
10:40:04:WU03:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:40:04:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
10:40:04:WU03:FS00:0xa7: CPUs: 16
10:40:04:WU03:FS00:0xa7: Memory: 31.86GiB
10:40:04:WU03:FS00:0xa7:Free Memory: 27.90GiB
10:40:04:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
10:40:04:WU03:FS00:0xa7: OS Version: 6.2
10:40:04:WU03:FS00:0xa7:Has Battery: false
10:40:04:WU03:FS00:0xa7: On Battery: false
10:40:04:WU03:FS00:0xa7: UTC Offset: 2
10:40:04:WU03:FS00:0xa7: PID: 11332
10:40:04:WU03:FS00:0xa7: CWD: D:\FAHClient\work
10:40:04:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
10:40:04:WU03:FS00:0xa7: Version: 0.0.18
10:40:04:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:40:04:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
10:40:04:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
10:40:04:WU03:FS00:0xa7: Time: 01:52:30
10:40:04:WU03:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:40:04:WU03:FS00:0xa7:************************************ Build *************************************
10:40:04:WU03:FS00:0xa7: SIMD: avx_256
10:40:04:WU03:FS00:0xa7:********************************************************************************
10:40:04:WU03:FS00:0xa7:Project: 14534 (Run 395, Clone 0, Gen 50)
10:40:04:WU03:FS00:0xa7:Unit: 0x0000003fcedfaa925ea34b4a7e917be8
10:40:04:WU03:FS00:0xa7:Reading tar file core.xml
10:40:04:WU03:FS00:0xa7:Reading tar file frame50.tpr
10:40:04:WU03:FS00:0xa7:Digital signatures verified
10:40:04:WU03:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
10:40:04:WU03:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
10:40:04:WU03:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpt 15 -nt 12
10:40:04:WU03:FS00:0xa7:Steps: first=50000000 total=1000000
10:40:04:WU03:FS00:0xa7:Completed 1 out of 1000000 steps (0%)
10:40:05:WU00:FS01:Assigned to work server 3.133.76.19
10:40:05:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
10:40:05:WU00:FS01:Connecting to 3.133.76.19:8080
10:40:07:WU04:FS01:Upload 3.21%
10:40:12:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
10:40:12:WU01:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:40:13:WU04:FS01:Upload 11.77%
10:40:19:WU04:FS01:Upload 20.98%
10:40:25:WU04:FS01:Upload 30.18%
10:40:26:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:40:26:WU00:FS01:Connecting to 3.133.76.19:80
10:40:31:WU04:FS01:Upload 39.39%
10:40:37:WU04:FS01:Upload 48.60%
10:40:43:WU04:FS01:Upload 55.45%
10:40:47:ERROR:WU00:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:40:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:40:48:WU00:FS01:Assigned to work server 140.163.4.241
10:40:48:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
10:40:48:WU00:FS01:Connecting to 140.163.4.241:8080
10:40:49:WU04:FS01:Upload 64.65%
10:40:55:WU04:FS01:Upload 73.64%
10:41:03:WU04:FS01:Upload 80.06%
10:41:09:WU04:FS01:Upload 87.56%
10:41:11:WU03:FS00:0xa7:Completed 10000 out of 1000000 steps (1%)
10:41:15:WU04:FS01:Upload 96.98%
10:41:31:WU04:FS01:Upload complete
10:41:31:WU04:FS01:Server responded WORK_ACK (400)
10:41:31:WU04:FS01:Cleaning up
10:42:19:WU03:FS00:0xa7:Completed 20000 out of 1000000 steps (2%)
10:43:07:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
10:43:08:WU00:FS01:Downloading 4.52MiB
10:43:13:WU00:FS01:Download complete
10:43:13:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:2105 gen:80 core:0x22 unit:0x0000007f8ca304f15e67e3bb0bd8ec91
10:43:13:WU00:FS01:Starting
10:43:13:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:43:13:WU00:FS01:Started FahCore on PID 11212
10:43:13:WU00:FS01:Core PID:10576
10:43:13:WU00:FS01:FahCore 0x22 started
10:43:14:WU00:FS01:0x22:*********************** Log Started 2020-05-07T10:43:13Z ***********************
10:43:14:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:43:14:WU00:FS01:0x22: Type: 0x22
10:43:14:WU00:FS01:0x22: Core: Core22
10:43:14:WU00:FS01:0x22: Website: https://foldingathome.org/
10:43:14:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
10:43:14:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:43:14:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
10:43:14:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 11212 -checkpoint 15
10:43:14:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:43:14:WU00:FS01:0x22: Config: <none>
10:43:14:WU00:FS01:0x22:************************************ Build *************************************
10:43:14:WU00:FS01:0x22: Version: 0.0.5
10:43:14:WU00:FS01:0x22: Date: Apr 22 2020
10:43:14:WU00:FS01:0x22: Time: 04:42:59
10:43:14:WU00:FS01:0x22: Repository: Git
10:43:14:WU00:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
10:43:14:WU00:FS01:0x22: Branch: HEAD
10:43:14:WU00:FS01:0x22: Compiler: Visual C++ 2008
10:43:14:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:43:14:WU00:FS01:0x22: Platform: win32 10
10:43:14:WU00:FS01:0x22: Bits: 64
10:43:14:WU00:FS01:0x22: Mode: Release
10:43:14:WU00:FS01:0x22:************************************ System ************************************
10:43:14:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:43:14:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
10:43:14:WU00:FS01:0x22: CPUs: 16
10:43:14:WU00:FS01:0x22: Memory: 31.86GiB
10:43:14:WU00:FS01:0x22:Free Memory: 27.20GiB
10:43:14:WU00:FS01:0x22: Threads: WINDOWS_THREADS
10:43:14:WU00:FS01:0x22: OS Version: 6.2
10:43:14:WU00:FS01:0x22:Has Battery: false
10:43:14:WU00:FS01:0x22: On Battery: false
10:43:14:WU00:FS01:0x22: UTC Offset: 2
10:43:14:WU00:FS01:0x22: PID: 10576
10:43:14:WU00:FS01:0x22: CWD: D:\FAHClient\work
10:43:14:WU00:FS01:0x22: OS: Windows 10 Pro
10:43:14:WU00:FS01:0x22: OS Arch: AMD64
10:43:14:WU00:FS01:0x22:********************************************************************************
10:43:14:WU00:FS01:0x22:Project: 11743 (Run 0, Clone 2105, Gen 80)
10:43:14:WU00:FS01:0x22:Unit: 0x0000007f8ca304f15e67e3bb0bd8ec91
10:43:14:WU00:FS01:0x22:Reading tar file core.xml
10:43:14:WU00:FS01:0x22:Reading tar file integrator.xml
10:43:14:WU00:FS01:0x22:Reading tar file state.xml
10:43:15:WU00:FS01:0x22:Reading tar file system.xml
10:43:15:WU00:FS01:0x22:Digital signatures verified
10:43:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:43:15:WU00:FS01:0x22:Version 0.0.5
10:43:25:WU03:FS00:0xa7:Completed 30000 out of 1000000 steps (3%)
10:43:27:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
10:43:27:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:44:33:WU03:FS00:0xa7:Completed 40000 out of 1000000 steps (4%)
10:45:29:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
10:45:41:WU03:FS00:0xa7:Completed 50000 out of 1000000 steps (5%)
10:46:02:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
10:46:49:WU03:FS00:0xa7:Completed 60000 out of 1000000 steps (6%)
10:47:30:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
10:47:56:WU03:FS00:0xa7:Completed 70000 out of 1000000 steps (7%)
10:48:56:WU01:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
10:49:04:WU03:FS00:0xa7:Completed 80000 out of 1000000 steps (8%)
10:49:32:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
10:50:12:WU03:FS00:0xa7:Completed 90000 out of 1000000 steps (9%)
10:51:20:WU03:FS00:0xa7:Completed 100000 out of 1000000 steps (10%)
10:51:32:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
10:51:51:WU01:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
10:52:28:WU03:FS00:0xa7:Completed 110000 out of 1000000 steps (11%)
10:53:33:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
10:53:36:WU03:FS00:0xa7:Completed 120000 out of 1000000 steps (12%)
10:54:44:WU03:FS00:0xa7:Completed 130000 out of 1000000 steps (13%)
10:54:45:WU01:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
10:55:36:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
10:55:53:WU03:FS00:0xa7:Completed 140000 out of 1000000 steps (14%)
10:57:04:WU03:FS00:0xa7:Completed 150000 out of 1000000 steps (15%)
10:57:40:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
10:57:44:WU01:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
10:58:13:WU03:FS00:0xa7:Completed 160000 out of 1000000 steps (16%)
10:59:21:WU03:FS00:0xa7:Completed 170000 out of 1000000 steps (17%)
10:59:42:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
11:00:29:WU03:FS00:0xa7:Completed 180000 out of 1000000 steps (18%)
11:00:39:WU01:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
11:01:37:WU03:FS00:0xa7:Completed 190000 out of 1000000 steps (19%)
11:01:42:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
11:02:45:WU03:FS00:0xa7:Completed 200000 out of 1000000 steps (20%)
11:03:33:WU01:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
11:03:42:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
11:03:53:WU03:FS00:0xa7:Completed 210000 out of 1000000 steps (21%)
11:05:01:WU03:FS00:0xa7:Completed 220000 out of 1000000 steps (22%)
11:05:45:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
11:06:09:WU03:FS00:0xa7:Completed 230000 out of 1000000 steps (23%)
11:06:28:WU01:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
11:07:17:WU03:FS00:0xa7:Completed 240000 out of 1000000 steps (24%)
11:07:46:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
11:08:25:WU03:FS00:0xa7:Completed 250000 out of 1000000 steps (25%)
11:09:23:WU01:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
11:09:33:WU03:FS00:0xa7:Completed 260000 out of 1000000 steps (26%)
11:09:49:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
11:10:41:WU03:FS00:0xa7:Completed 270000 out of 1000000 steps (27%)
11:11:50:WU03:FS00:0xa7:Completed 280000 out of 1000000 steps (28%)
11:11:52:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
11:12:21:WU01:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
11:12:59:WU03:FS00:0xa7:Completed 290000 out of 1000000 steps (29%)
11:13:54:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
11:14:07:WU03:FS00:0xa7:Completed 300000 out of 1000000 steps (30%)
11:15:16:WU01:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
11:15:16:WU03:FS00:0xa7:Completed 310000 out of 1000000 steps (31%)
11:15:59:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
11:16:25:WU03:FS00:0xa7:Completed 320000 out of 1000000 steps (32%)
11:17:36:WU03:FS00:0xa7:Completed 330000 out of 1000000 steps (33%)
11:18:02:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
11:18:10:WU01:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
11:18:45:WU03:FS00:0xa7:Completed 340000 out of 1000000 steps (34%)
11:19:55:WU03:FS00:0xa7:Completed 350000 out of 1000000 steps (35%)
11:20:07:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
11:21:04:WU03:FS00:0xa7:Completed 360000 out of 1000000 steps (36%)
11:21:05:WU01:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
11:22:09:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
11:22:12:WU03:FS00:0xa7:Completed 370000 out of 1000000 steps (37%)
11:23:20:WU03:FS00:0xa7:Completed 380000 out of 1000000 steps (38%)
11:24:00:WU01:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
11:24:12:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
11:24:30:WU03:FS00:0xa7:Completed 390000 out of 1000000 steps (39%)
11:25:41:WU03:FS00:0xa7:Completed 400000 out of 1000000 steps (40%)
11:26:18:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
11:26:54:WU03:FS00:0xa7:Completed 410000 out of 1000000 steps (41%)
11:26:58:WU01:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
11:28:03:WU03:FS00:0xa7:Completed 420000 out of 1000000 steps (42%)
11:28:22:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
11:29:14:WU03:FS00:0xa7:Completed 430000 out of 1000000 steps (43%)
11:29:53:WU01:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
11:30:24:WU03:FS00:0xa7:Completed 440000 out of 1000000 steps (44%)
11:30:28:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
11:31:35:WU03:FS00:0xa7:Completed 450000 out of 1000000 steps (45%)
11:32:32:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
11:32:45:WU03:FS00:0xa7:Completed 460000 out of 1000000 steps (46%)
11:32:48:WU01:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
11:33:54:WU03:FS00:0xa7:Completed 470000 out of 1000000 steps (47%)
11:34:34:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
11:35:03:WU03:FS00:0xa7:Completed 480000 out of 1000000 steps (48%)
11:35:43:WU01:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
11:36:13:WU03:FS00:0xa7:Completed 490000 out of 1000000 steps (49%)
11:36:39:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
11:37:22:WU03:FS00:0xa7:Completed 500000 out of 1000000 steps (50%)
11:38:31:WU03:FS00:0xa7:Completed 510000 out of 1000000 steps (51%)
11:38:37:WU01:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
11:38:43:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
11:39:41:WU03:FS00:0xa7:Completed 520000 out of 1000000 steps (52%)
11:40:48:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
11:40:50:WU03:FS00:0xa7:Completed 530000 out of 1000000 steps (53%)
11:41:36:WU01:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
11:42:02:WU03:FS00:0xa7:Completed 540000 out of 1000000 steps (54%)
11:42:52:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
11:43:12:WU03:FS00:0xa7:Completed 550000 out of 1000000 steps (55%)
11:44:21:WU03:FS00:0xa7:Completed 560000 out of 1000000 steps (56%)
11:44:31:WU01:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
11:44:54:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
11:45:31:WU03:FS00:0xa7:Completed 570000 out of 1000000 steps (57%)
11:46:41:WU03:FS00:0xa7:Completed 580000 out of 1000000 steps (58%)
11:47:00:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
11:47:25:WU01:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
11:47:50:WU03:FS00:0xa7:Completed 590000 out of 1000000 steps (59%)
11:49:00:WU03:FS00:0xa7:Completed 600000 out of 1000000 steps (60%)
11:49:03:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
11:50:09:WU03:FS00:0xa7:Completed 610000 out of 1000000 steps (61%)
11:50:20:WU01:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
11:51:08:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
11:51:20:WU03:FS00:0xa7:Completed 620000 out of 1000000 steps (62%)
11:52:30:WU03:FS00:0xa7:Completed 630000 out of 1000000 steps (63%)
11:53:12:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
11:53:15:WU01:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
11:53:40:WU03:FS00:0xa7:Completed 640000 out of 1000000 steps (64%)
11:54:49:WU03:FS00:0xa7:Completed 650000 out of 1000000 steps (65%)
11:55:14:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
11:55:58:WU03:FS00:0xa7:Completed 660000 out of 1000000 steps (66%)
11:56:14:WU01:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
11:57:07:WU03:FS00:0xa7:Completed 670000 out of 1000000 steps (67%)
11:57:19:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
11:58:16:WU03:FS00:0xa7:Completed 680000 out of 1000000 steps (68%)
11:59:08:WU01:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
11:59:20:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
11:59:25:WU03:FS00:0xa7:Completed 690000 out of 1000000 steps (69%)
12:00:35:WU03:FS00:0xa7:Completed 700000 out of 1000000 steps (70%)
12:01:24:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
12:01:43:WU03:FS00:0xa7:Completed 710000 out of 1000000 steps (71%)
12:02:03:WU01:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
12:02:52:WU03:FS00:0xa7:Completed 720000 out of 1000000 steps (72%)
12:03:26:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
12:04:01:WU03:FS00:0xa7:Completed 730000 out of 1000000 steps (73%)
12:04:58:WU01:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
12:05:10:WU03:FS00:0xa7:Completed 740000 out of 1000000 steps (74%)
12:05:28:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
12:06:20:WU03:FS00:0xa7:Completed 750000 out of 1000000 steps (75%)
12:07:29:WU03:FS00:0xa7:Completed 760000 out of 1000000 steps (76%)
12:07:32:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
12:07:52:WU01:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
12:08:38:WU03:FS00:0xa7:Completed 770000 out of 1000000 steps (77%)
12:09:34:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
12:09:47:WU03:FS00:0xa7:Completed 780000 out of 1000000 steps (78%)
12:10:51:WU01:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
12:10:55:WU03:FS00:0xa7:Completed 790000 out of 1000000 steps (79%)
12:11:38:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
12:12:04:WU03:FS00:0xa7:Completed 800000 out of 1000000 steps (80%)
12:13:13:WU03:FS00:0xa7:Completed 810000 out of 1000000 steps (81%)
12:13:40:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
12:13:45:WU01:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
12:14:22:WU03:FS00:0xa7:Completed 820000 out of 1000000 steps (82%)
12:15:31:WU03:FS00:0xa7:Completed 830000 out of 1000000 steps (83%)
12:15:42:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
12:16:40:WU01:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
12:16:40:WU03:FS00:0xa7:Completed 840000 out of 1000000 steps (84%)
12:17:47:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
12:17:49:WU03:FS00:0xa7:Completed 850000 out of 1000000 steps (85%)
12:18:58:WU03:FS00:0xa7:Completed 860000 out of 1000000 steps (86%)
12:19:35:WU01:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
12:19:49:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
12:20:08:WU03:FS00:0xa7:Completed 870000 out of 1000000 steps (87%)
12:21:18:WU03:FS00:0xa7:Completed 880000 out of 1000000 steps (88%)
12:21:54:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
12:22:27:WU03:FS00:0xa7:Completed 890000 out of 1000000 steps (89%)
12:22:30:WU01:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
12:23:35:WU03:FS00:0xa7:Completed 900000 out of 1000000 steps (90%)
12:23:56:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
12:24:46:WU03:FS00:0xa7:Completed 910000 out of 1000000 steps (91%)
12:25:28:WU01:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
12:25:55:WU03:FS00:0xa7:Completed 920000 out of 1000000 steps (92%)
12:25:58:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
12:27:04:WU03:FS00:0xa7:Completed 930000 out of 1000000 steps (93%)
12:28:02:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
12:28:13:WU03:FS00:0xa7:Completed 940000 out of 1000000 steps (94%)
12:28:23:WU01:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
12:29:22:WU03:FS00:0xa7:Completed 950000 out of 1000000 steps (95%)
12:30:04:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
12:30:33:WU03:FS00:0xa7:Completed 960000 out of 1000000 steps (96%)
12:31:18:WU01:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
12:31:45:WU03:FS00:0xa7:Completed 970000 out of 1000000 steps (97%)
12:32:11:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
12:32:55:WU03:FS00:0xa7:Completed 980000 out of 1000000 steps (98%)
12:34:04:WU03:FS00:0xa7:Completed 990000 out of 1000000 steps (99%)
12:34:13:WU01:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
12:34:14:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
12:35:13:WU03:FS00:0xa7:Completed 1000000 out of 1000000 steps (100%)
12:35:15:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
12:35:15:WU03:FS00:0xa7:Saving result file frame50.trr
12:35:15:WU03:FS00:0xa7:Saving result file frame50.xtc
12:35:15:WU03:FS00:0xa7:Saving result file md.log
12:35:15:WU03:FS00:0xa7:Saving result file science.log
12:35:15:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:35:15:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:35:15:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14534 run:395 clone:0 gen:50 core:0xa7 unit:0x0000003fcedfaa925ea34b4a7e917be8
12:35:15:WU03:FS00:Uploading 2.65MiB to 206.223.170.146
12:35:15:WU02:FS00:Starting
12:35:15:WU03:FS00:Connecting to 206.223.170.146:8080
12:35:15:WARNING:WU02:FS00:AS lowered CPUs from 14 to 13
12:35:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 13
12:35:15:WU02:FS00:Started FahCore on PID 12400
12:35:15:WU02:FS00:Core PID:3248
12:35:15:WU02:FS00:FahCore 0xa7 started
12:35:15:WU02:FS00:0xa7:*********************** Log Started 2020-05-07T12:35:15Z ***********************
12:35:15:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:35:15:WU02:FS00:0xa7: Type: 0xa7
12:35:15:WU02:FS00:0xa7: Core: Gromacs
12:35:15:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 12400 -checkpoint 15 -np
12:35:15:WU02:FS00:0xa7: 13
12:35:15:WU02:FS00:0xa7:************************************ CBang *************************************
12:35:15:WU02:FS00:0xa7: Date: Oct 26 2019
12:35:15:WU02:FS00:0xa7: Time: 01:38:25
12:35:15:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:35:15:WU02:FS00:0xa7: Branch: master
12:35:15:WU02:FS00:0xa7: Compiler: Visual C++ 2008
12:35:15:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:35:15:WU02:FS00:0xa7: Platform: win32 10
12:35:15:WU02:FS00:0xa7: Bits: 64
12:35:15:WU02:FS00:0xa7: Mode: Release
12:35:15:WU02:FS00:0xa7:************************************ System ************************************
12:35:15:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
12:35:15:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
12:35:16:WU02:FS00:0xa7: CPUs: 16
12:35:16:WU02:FS00:0xa7: Memory: 31.86GiB
12:35:16:WU02:FS00:0xa7:Free Memory: 22.74GiB
12:35:16:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
12:35:16:WU02:FS00:0xa7: OS Version: 6.2
12:35:16:WU02:FS00:0xa7:Has Battery: false
12:35:16:WU02:FS00:0xa7: On Battery: false
12:35:16:WU02:FS00:0xa7: UTC Offset: 2
12:35:16:WU02:FS00:0xa7: PID: 3248
12:35:16:WU02:FS00:0xa7: CWD: D:\FAHClient\work
12:35:16:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
12:35:16:WU02:FS00:0xa7: Version: 0.0.18
12:35:16:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:35:16:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
12:35:16:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
12:35:16:WU02:FS00:0xa7: Date: Oct 26 2019
12:35:16:WU02:FS00:0xa7: Time: 01:52:30
12:35:16:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:35:16:WU02:FS00:0xa7: Branch: master
12:35:16:WU02:FS00:0xa7: Compiler: Visual C++ 2008
12:35:16:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:35:16:WU02:FS00:0xa7: Platform: win32 10
12:35:16:WU02:FS00:0xa7: Bits: 64
12:35:16:WU02:FS00:0xa7: Mode: Release
12:35:16:WU02:FS00:0xa7:************************************ Build *************************************
12:35:16:WU02:FS00:0xa7: SIMD: avx_256
12:35:16:WU02:FS00:0xa7:********************************************************************************
12:35:16:WU02:FS00:0xa7:Project: 14620 (Run 1207, Clone 1, Gen 76)
12:35:16:WU02:FS00:0xa7:Unit: 0x000000569bf7a4d55e876ce5a331f777
12:35:16:WU02:FS00:0xa7:Digital signatures verified
12:35:16:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
12:35:16:WU02:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -cpi state.cpt -cpt 15 -nt 12
12:35:16:WU02:FS00:0xa7:ERROR:Guru Meditation #a7c53e483fd63469.9688aae3e890292b (23270.24853) '02/01/pullx.xvg'
12:35:16:WU02:FS00:0xa7:WARNING:Unexpected exit() call
12:35:16:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
12:35:16:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
12:35:16:WU02:FS00:0xa7:Saving result file dhdl.xvg
12:35:16:WU02:FS00:0xa7:Saving result file frame76.trr
12:35:16:WU02:FS00:0xa7:Saving result file md.log
12:35:16:WU02:FS00:0xa7:Saving result file pullf.xvg
12:35:16:WU02:FS00:0xa7:ERROR:Guru Meditation #9a3ff096b239bab1.e39f90adf5562a95 (8040.8604) '02/01/pullf.xvg'
12:35:18:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:35:18:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
12:35:21:WU03:FS00:Upload 30.64%
12:35:26:WU03:FS00:Upload complete
12:35:26:WU03:FS00:Server responded WORK_ACK (400)
12:35:26:WU03:FS00:Final credit estimate, 7042.00 points
12:35:26:WU03:FS00:Cleaning up
12:36:13:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
12:36:15:WU02:FS00:Starting
12:36:15:WARNING:WU02:FS00:AS lowered CPUs from 14 to 13
12:36:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 13
12:36:15:WU02:FS00:Started FahCore on PID 4872
12:36:15:WU02:FS00:Core PID:9152
12:36:15:WU02:FS00:FahCore 0xa7 started
12:36:16:WU02:FS00:0xa7:*********************** Log Started 2020-05-07T12:36:15Z ***********************
12:36:16:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:36:16:WU02:FS00:0xa7: Type: 0xa7
12:36:16:WU02:FS00:0xa7: Core: Gromacs
12:36:16:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 4872 -checkpoint 15 -np
12:36:16:WU02:FS00:0xa7: 13
12:36:16:WU02:FS00:0xa7:************************************ CBang *************************************
12:36:16:WU02:FS00:0xa7: Date: Oct 26 2019
12:36:16:WU02:FS00:0xa7: Time: 01:38:25
12:36:16:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:36:16:WU02:FS00:0xa7: Branch: master
12:36:16:WU02:FS00:0xa7: Compiler: Visual C++ 2008
12:36:16:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:36:16:WU02:FS00:0xa7: Platform: win32 10
12:36:16:WU02:FS00:0xa7: Bits: 64
12:36:16:WU02:FS00:0xa7: Mode: Release
12:36:16:WU02:FS00:0xa7:************************************ System ************************************
12:36:16:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
12:36:16:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
12:36:16:WU02:FS00:0xa7: CPUs: 16
12:36:16:WU02:FS00:0xa7: Memory: 31.86GiB
12:36:16:WU02:FS00:0xa7:Free Memory: 22.76GiB
12:36:16:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
12:36:16:WU02:FS00:0xa7: OS Version: 6.2
12:36:16:WU02:FS00:0xa7:Has Battery: false
12:36:16:WU02:FS00:0xa7: On Battery: false
12:36:16:WU02:FS00:0xa7: UTC Offset: 2
12:36:16:WU02:FS00:0xa7: PID: 9152
12:36:16:WU02:FS00:0xa7: CWD: D:\FAHClient\work
12:36:16:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
12:36:16:WU02:FS00:0xa7: Version: 0.0.18
12:36:16:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:36:16:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
12:36:16:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
12:36:16:WU02:FS00:0xa7: Time: 01:52:30
12:36:16:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:36:16:WU02:FS00:0xa7:************************************ Build *************************************
12:36:16:WU02:FS00:0xa7: SIMD: avx_256
12:36:16:WU02:FS00:0xa7:********************************************************************************
12:36:16:WU02:FS00:0xa7:Project: 14620 (Run 1207, Clone 1, Gen 76)
12:36:16:WU02:FS00:0xa7:Unit: 0x000000569bf7a4d55e876ce5a331f777
12:36:16:WU02:FS00:0xa7:Digital signatures verified
12:36:16:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
12:36:16:WU02:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -cpi state.cpt -cpt 15 -nt 12
12:36:16:WU02:FS00:0xa7:ERROR:Guru Meditation #a7c53e483fd63469.9688aae3e890292b (23270.24853) '02/01/pullx.xvg'
12:36:16:WU02:FS00:0xa7:WARNING:Unexpected exit() call
12:36:16:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
12:36:16:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
12:36:16:WU02:FS00:0xa7:Saving result file dhdl.xvg
12:36:16:WU02:FS00:0xa7:Saving result file frame76.trr
12:36:16:WU02:FS00:0xa7:Saving result file md.log
12:36:16:WU02:FS00:0xa7:Saving result file pullf.xvg
12:36:16:WU02:FS00:0xa7:ERROR:Guru Meditation #9a3ff096b239bab1.e39f90adf5562a95 (8040.8604) '02/01/pullf.xvg'
12:36:17:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:36:17:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
12:36:17:WARNING:WU02:FS00:Too many errors, failing
12:36:17:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14620 run:1207 clone:1 gen:76 core:0xa7 unit:0x000000569bf7a4d55e876ce5a331f777
12:36:17:WU02:FS00:Uploading 3.81MiB to 155.247.164.213
12:36:17:WU02:FS00:Connecting to 155.247.164.213:8080
12:36:17:WU03:FS00:Connecting to assign1.foldingathome.org:80
12:36:19:WU03:FS00:Assigned to work server 128.252.203.1
12:36:19:WU03:FS00:Requesting new work unit for slot 00: READY cpu:14 from 128.252.203.1
12:36:19:WU03:FS00:Connecting to 128.252.203.1:8080
12:36:20:WU03:FS00:Downloading 1.39MiB
12:36:23:WU02:FS00:Upload 24.61%
12:36:26:WU03:FS00:Download 40.44%
12:36:29:WU02:FS00:Upload 91.89%
12:36:30:WU02:FS00:Upload complete
12:36:30:WU02:FS00:Server responded WORK_QUIT (404)
12:36:30:WARNING:WU02:FS00:Server did not like results, dumping
12:36:30:WU02:FS00:Cleaning up
12:36:32:WU03:FS00:Download 85.36%
12:36:35:WU03:FS00:Download complete
12:36:35:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:16428 run:772 clone:1 gen:4 core:0xa7 unit:0x0000000780fccb015ea74e7b9eb85b5e
12:36:35:WU03:FS00:Starting
12:36:35:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 14
12:36:35:WU03:FS00:Started FahCore on PID 11880
12:36:35:WU03:FS00:Core PID:12944
12:36:35:WU03:FS00:FahCore 0xa7 started
OddSoxChris
Continued:
12:36:36:WU03:FS00:0xa7:*********************** Log Started 2020-05-07T12:36:35Z ***********************
12:36:36:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:36:36:WU03:FS00:0xa7: Type: 0xa7
12:36:36:WU03:FS00:0xa7: Core: Gromacs
12:36:36:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 11880 -checkpoint 15 -np
12:36:36:WU03:FS00:0xa7: 14
12:36:36:WU03:FS00:0xa7:************************************ CBang *************************************
12:36:36:WU03:FS00:0xa7: Date: Oct 26 2019
12:36:36:WU03:FS00:0xa7: Time: 01:38:25
12:36:36:WU03:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:36:36:WU03:FS00:0xa7: Branch: master
12:36:36:WU03:FS00:0xa7: Compiler: Visual C++ 2008
12:36:36:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:36:36:WU03:FS00:0xa7: Platform: win32 10
12:36:36:WU03:FS00:0xa7: Bits: 64
12:36:36:WU03:FS00:0xa7: Mode: Release
12:36:36:WU03:FS00:0xa7:************************************ System ************************************
12:36:36:WU03:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
12:36:36:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
12:36:36:WU03:FS00:0xa7: CPUs: 16
12:36:36:WU03:FS00:0xa7: Memory: 31.86GiB
12:36:36:WU03:FS00:0xa7:Free Memory: 22.78GiB
12:36:36:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
12:36:36:WU03:FS00:0xa7: OS Version: 6.2
12:36:36:WU03:FS00:0xa7:Has Battery: false
12:36:36:WU03:FS00:0xa7: On Battery: false
12:36:36:WU03:FS00:0xa7: UTC Offset: 2
12:36:36:WU03:FS00:0xa7: PID: 12944
12:36:36:WU03:FS00:0xa7: CWD: D:\FAHClient\work
12:36:36:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
12:36:36:WU03:FS00:0xa7: Version: 0.0.18
12:36:36:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:36:36:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
12:36:36:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
12:36:36:WU03:FS00:0xa7: Time: 01:52:30
12:36:36:WU03:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:36:36:WU03:FS00:0xa7:************************************ Build *************************************
12:36:36:WU03:FS00:0xa7: SIMD: avx_256
12:36:36:WU03:FS00:0xa7:********************************************************************************
12:36:36:WU03:FS00:0xa7:Project: 16428 (Run 772, Clone 1, Gen 4)
12:36:36:WU03:FS00:0xa7:Unit: 0x0000000780fccb015ea74e7b9eb85b5e
12:36:36:WU03:FS00:0xa7:Reading tar file core.xml
12:36:36:WU03:FS00:0xa7:Reading tar file frame4.tpr
12:36:36:WU03:FS00:0xa7:Digital signatures verified
12:36:36:WU03:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
12:36:36:WU03:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
12:36:36:WU03:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -x frame4.xtc -cpt 15 -nt 12
12:36:36:WU03:FS00:0xa7:Steps: first=2000000 total=500000
12:36:36:WU03:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:37:07:WU01:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
12:37:19:WU03:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
12:38:03:WU03:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
12:38:17:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
12:38:46:WU03:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
12:39:30:WU03:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
12:40:06:WU01:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
12:40:13:WU03:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
12:40:20:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
12:40:56:WU03:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
12:41:39:WU03:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
12:42:22:WU03:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
12:42:25:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
12:43:01:WU01:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
12:43:05:WU03:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
12:43:48:WU03:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
12:44:27:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
12:44:31:WU03:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
12:45:14:WU03:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
12:45:55:WU01:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
12:45:58:WU03:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
12:46:30:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
12:46:41:WU03:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
12:47:24:WU03:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
12:48:07:WU03:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
12:48:35:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
12:48:50:WU03:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
12:48:50:WU01:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
12:49:33:WU03:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:50:16:WU03:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
12:50:38:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
12:50:59:WU03:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
12:51:43:WU03:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:51:45:WU01:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
12:52:26:WU03:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:52:44:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
12:53:09:WU03:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:53:52:WU03:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
12:54:35:WU03:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
12:54:44:WU01:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
12:54:46:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
12:55:18:WU03:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
12:56:01:WU03:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
12:56:44:WU03:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
12:56:49:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
12:57:27:WU03:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
12:57:39:WU01:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
12:58:10:WU03:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
12:58:53:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
12:58:53:WU03:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
12:59:36:WU03:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
13:00:19:WU03:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
13:00:33:WU01:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
13:00:56:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
13:01:02:WU03:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
13:01:46:WU03:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
13:02:29:WU03:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
13:03:01:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
13:03:12:WU03:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
13:03:28:WU01:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
13:03:55:WU03:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
13:04:38:WU03:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
13:05:04:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
13:05:21:WU03:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
13:06:04:WU03:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
13:06:23:WU01:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
13:06:48:WU03:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
13:07:07:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
13:07:31:WU03:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
13:08:14:WU03:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
13:08:57:WU03:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
13:09:12:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
13:09:22:WU01:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
13:09:40:WU03:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
13:10:22:WU03:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
13:11:05:WU03:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
13:11:15:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
13:11:48:WU03:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
13:12:17:WU01:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
13:12:31:WU03:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
13:13:13:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
13:13:18:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
13:13:56:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
13:14:39:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
13:15:11:WU01:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
13:15:21:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
13:15:22:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
13:16:04:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
13:16:47:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
13:17:24:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
13:17:30:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
13:18:06:WU01:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
13:18:13:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:18:56:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:19:29:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
13:19:38:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:20:21:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
13:21:01:WU01:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
13:21:04:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
13:21:32:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
13:21:47:WU03:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
13:22:30:WU03:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
13:23:13:WU03:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
13:23:37:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
13:23:56:WU03:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
13:24:00:WU01:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
13:24:39:WU03:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
13:25:22:WU03:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
13:25:40:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
13:26:05:WU03:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
13:26:48:WU03:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
13:26:54:WU01:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
13:27:32:WU03:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
13:27:43:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
13:28:15:WU03:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
13:28:58:WU03:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
13:29:41:WU03:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
13:29:47:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
13:29:49:WU01:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
13:30:24:WU03:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
13:31:07:WU03:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
13:31:50:WU03:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
13:31:50:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
13:32:33:WU03:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
13:32:44:WU01:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
13:33:16:WU03:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
13:33:56:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
13:33:59:WU03:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
13:34:42:WU03:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
13:35:25:WU03:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
13:35:38:WU01:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
13:35:59:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
13:36:08:WU03:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
13:36:51:WU03:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
13:37:34:WU03:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
13:38:02:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
13:38:17:WU03:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
13:38:37:WU01:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
13:39:01:WU03:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
13:39:44:WU03:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
13:40:07:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
13:40:26:WU03:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
13:41:09:WU03:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
13:41:32:WU01:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
13:41:52:WU03:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
13:42:08:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
13:42:35:WU03:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
13:43:18:WU03:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
13:44:01:WU03:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
13:44:11:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
13:44:27:WU01:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
13:44:43:WU03:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
13:45:27:WU03:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
13:46:09:WU03:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
13:46:14:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
13:46:52:WU03:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
13:47:22:WU01:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
13:47:35:WU03:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
13:47:36:WU02:FS00:Connecting to assign1.foldingathome.org:80
13:47:37:WU02:FS00:Assigned to work server 128.252.203.2
13:47:37:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:14 from 128.252.203.2
13:47:37:WU02:FS00:Connecting to 128.252.203.2:8080
13:48:17:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
13:48:19:WU03:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
13:48:21:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
13:48:21:WU03:FS00:0xa7:Saving result file frame4.trr
13:48:21:WU03:FS00:0xa7:Saving result file frame4.xtc
13:48:21:WU03:FS00:0xa7:Saving result file md.log
13:48:21:WU03:FS00:0xa7:Saving result file science.log
13:48:21:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
13:48:21:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:48:21:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16428 run:772 clone:1 gen:4 core:0xa7 unit:0x0000000780fccb015ea74e7b9eb85b5e
13:48:21:WU03:FS00:Uploading 1.54MiB to 128.252.203.1
13:48:21:WU03:FS00:Connecting to 128.252.203.1:8080
13:48:27:WU03:FS00:Upload 65.04%
13:48:29:WU02:FS00:Downloading 21.90MiB
13:48:29:WU03:FS00:Upload complete
13:48:29:WU03:FS00:Server responded WORK_ACK (400)
13:48:29:WU03:FS00:Final credit estimate, 5597.00 points
13:48:29:WU03:FS00:Cleaning up
13:48:42:WU02:FS00:Download 7.42%
13:48:48:WU02:FS00:Download 10.84%
13:48:54:WU02:FS00:Download 13.41%
13:49:00:WU02:FS00:Download 15.13%
13:49:06:WU02:FS00:Download 17.69%
13:49:12:WU02:FS00:Download 19.98%
13:49:18:WU02:FS00:Download 22.83%
13:49:24:WU02:FS00:Download 25.11%
13:49:30:WU02:FS00:Download 27.40%
13:49:36:WU02:FS00:Download 29.39%
13:49:42:WU02:FS00:Download 31.68%
13:49:48:WU02:FS00:Download 34.25%
13:49:54:WU02:FS00:Download 36.53%
13:50:00:WU02:FS00:Download 38.81%
13:50:06:WU02:FS00:Download 41.10%
13:50:12:WU02:FS00:Download 43.38%
13:50:14:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
13:50:16:WU01:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
13:50:18:WU02:FS00:Download 45.09%
13:50:24:WU02:FS00:Download 47.09%
13:50:30:WU02:FS00:Download 49.37%
13:50:36:WU02:FS00:Download 51.08%
13:50:42:WU02:FS00:Download 53.65%
13:50:48:WU02:FS00:Download 55.65%
13:50:54:WU02:FS00:Download 58.22%
13:51:00:WU02:FS00:Download 61.07%
13:51:06:WU02:FS00:Download 63.93%
13:51:12:WU02:FS00:Download 66.78%
13:51:18:WU02:FS00:Download 69.06%
13:51:24:WU02:FS00:Download 71.63%
13:51:30:WU02:FS00:Download 73.34%
13:51:36:WU02:FS00:Download 75.06%
13:51:42:WU02:FS00:Download 77.05%
13:51:48:WU02:FS00:Download 78.48%
13:51:54:WU02:FS00:Download 80.19%
13:52:00:WU02:FS00:Download 83.05%
13:52:06:WU02:FS00:Download 84.19%
13:52:10:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
13:52:12:WU02:FS00:Download 85.61%
13:52:18:WU02:FS00:Download 87.33%
13:52:24:WU02:FS00:Download 89.61%
13:52:30:WU02:FS00:Download 92.18%
13:52:36:WU02:FS00:Download 94.18%
13:52:42:WU02:FS00:Download 95.60%
13:52:48:WU02:FS00:Download 98.17%
13:52:53:WU02:FS00:Download complete
13:52:53:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14583 run:0 clone:149 gen:67 core:0xa7 unit:0x0000004880fccb025e8bcb35c396bdc2
13:52:53:WU02:FS00:Starting
13:52:53:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 14
13:52:53:WU02:FS00:Started FahCore on PID 12956
13:52:53:WU02:FS00:Core PID:13172
13:52:53:WU02:FS00:FahCore 0xa7 started
13:52:54:WU02:FS00:0xa7:*********************** Log Started 2020-05-07T13:52:53Z ***********************
13:52:54:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:52:54:WU02:FS00:0xa7: Type: 0xa7
13:52:54:WU02:FS00:0xa7: Core: Gromacs
13:52:54:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 706 -lifeline 12956 -checkpoint 15 -np
13:52:54:WU02:FS00:0xa7: 14
13:52:54:WU02:FS00:0xa7:************************************ CBang *************************************
13:52:54:WU02:FS00:0xa7: Date: Oct 26 2019
13:52:54:WU02:FS00:0xa7: Time: 01:38:25
13:52:54:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:52:54:WU02:FS00:0xa7: Branch: master
13:52:54:WU02:FS00:0xa7: Compiler: Visual C++ 2008
13:52:54:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:52:54:WU02:FS00:0xa7: Platform: win32 10
13:52:54:WU02:FS00:0xa7: Bits: 64
13:52:54:WU02:FS00:0xa7: Mode: Release
13:52:54:WU02:FS00:0xa7:************************************ System ************************************
13:52:54:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
13:52:54:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
13:52:54:WU02:FS00:0xa7: CPUs: 16
13:52:54:WU02:FS00:0xa7: Memory: 31.86GiB
13:52:54:WU02:FS00:0xa7:Free Memory: 22.61GiB
13:52:54:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
13:52:54:WU02:FS00:0xa7: OS Version: 6.2
13:52:54:WU02:FS00:0xa7:Has Battery: false
13:52:54:WU02:FS00:0xa7: On Battery: false
13:52:54:WU02:FS00:0xa7: UTC Offset: 2
13:52:54:WU02:FS00:0xa7: PID: 13172
13:52:54:WU02:FS00:0xa7: CWD: D:\FAHClient\work
13:52:54:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
13:52:54:WU02:FS00:0xa7: Version: 0.0.18
13:52:54:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:52:54:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
13:52:54:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
13:52:54:WU02:FS00:0xa7: Time: 01:52:30
13:52:54:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:52:54:WU02:FS00:0xa7:************************************ Build *************************************
13:52:54:WU02:FS00:0xa7: SIMD: avx_256
13:52:54:WU02:FS00:0xa7:********************************************************************************
13:52:54:WU02:FS00:0xa7:Project: 14583 (Run 0, Clone 149, Gen 67)
13:52:54:WU02:FS00:0xa7:Unit: 0x0000004880fccb025e8bcb35c396bdc2
13:52:54:WU02:FS00:0xa7:Reading tar file core.xml
13:52:54:WU02:FS00:0xa7:Reading tar file frame67.tpr
13:52:54:WU02:FS00:0xa7:Digital signatures verified
13:52:54:WU02:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
13:52:54:WU02:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
13:52:54:WU02:FS00:0xa7:Calling: mdrun -s frame67.tpr -o frame67.trr -x frame67.xtc -cpt 15 -nt 12
13:52:54:WU02:FS00:0xa7:Steps: first=4187500 total=62500
13:52:59:WU02:FS00:0xa7:Completed 1 out of 62500 steps (0%)
13:53:13:WU01:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
13:54:07:WU02:FS00:0xa7:Completed 625 out of 62500 steps (1%)
13:54:17:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
13:55:16:WU02:FS00:0xa7:Completed 1250 out of 62500 steps (2%)
13:56:09:WU01:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
13:56:25:WU02:FS00:0xa7:Completed 1875 out of 62500 steps (3%)
13:56:29:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
13:57:33:WU02:FS00:0xa7:Completed 2500 out of 62500 steps (4%)
13:58:40:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
13:58:42:WU02:FS00:0xa7:Completed 3125 out of 62500 steps (5%)
13:59:05:WU01:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
13:59:50:WU02:FS00:0xa7:Completed 3750 out of 62500 steps (6%)
14:00:54:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
14:01:00:WU02:FS00:0xa7:Completed 4375 out of 62500 steps (7%)
14:02:01:WU01:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
14:02:09:WU02:FS00:0xa7:Completed 5000 out of 62500 steps (8%)
14:03:07:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
14:03:19:WU02:FS00:0xa7:Completed 5625 out of 62500 steps (9%)
14:04:29:WU02:FS00:0xa7:Completed 6250 out of 62500 steps (10%)
14:04:57:WU01:FS02:0x22:Completed 700000 out of 1000000 steps (70%)
14:05:23:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
14:05:38:WU02:FS00:0xa7:Completed 6875 out of 62500 steps (11%)
14:06:48:WU02:FS00:0xa7:Completed 7500 out of 62500 steps (12%)
14:07:36:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
14:07:36:WU03:FS01:Connecting to assign1.foldingathome.org:80
14:07:37:WARNING:WU03:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:07:37:WU03:FS01:Connecting to assign2.foldingathome.org:80
14:07:38:WU03:FS01:Assigned to work server 3.133.76.19
14:07:38:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
14:07:38:WU03:FS01:Connecting to 3.133.76.19:8080
14:07:58:WU02:FS00:0xa7:Completed 8125 out of 62500 steps (13%)
14:07:58:WU01:FS02:0x22:Completed 710000 out of 1000000 steps (71%)
14:08:46:WU03:FS01:Downloading 30.32MiB
14:08:52:WU03:FS01:Download 35.86%
14:08:58:WU03:FS01:Download 82.03%
14:09:00:WU03:FS01:Download complete
14:09:00:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:16435 run:104 clone:1 gen:8 core:0x22 unit:0x0000001103854c135e9a4ef67021ced2
14:09:13:WU02:FS00:0xa7:Completed 8750 out of 62500 steps (14%)
14:09:48:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
14:09:51:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:09:51:WU00:FS01:0x22:Saving result file checkpointState.xml
14:09:53:WU00:FS01:0x22:Saving result file checkpt.crc
14:09:53:WU00:FS01:0x22:Saving result file positions.xtc
14:09:54:WU00:FS01:0x22:Saving result file science.log
14:09:55:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
14:09:55:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:09:55:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11743 run:0 clone:2105 gen:80 core:0x22 unit:0x0000007f8ca304f15e67e3bb0bd8ec91
14:09:55:WU00:FS01:Uploading 12.57MiB to 140.163.4.241
14:09:55:WU00:FS01:Connecting to 140.163.4.241:8080
14:09:55:WU03:FS01:Starting
14:09:55:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:09:55:WU03:FS01:Started FahCore on PID 1064
14:09:55:WU03:FS01:Core PID:15368
14:09:55:WU03:FS01:FahCore 0x22 started
14:09:56:WU03:FS01:0x22:*********************** Log Started 2020-05-07T14:09:56Z ***********************
14:09:56:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:09:56:WU03:FS01:0x22: Type: 0x22
14:09:56:WU03:FS01:0x22: Core: Core22
14:09:56:WU03:FS01:0x22: Website: https://foldingathome.org/
14:09:56:WU03:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
14:09:56:WU03:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:09:56:WU03:FS01:0x22: <rafal.wiewiora@choderalab.org>
14:09:56:WU03:FS01:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 1064 -checkpoint 15
14:09:56:WU03:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:09:56:WU03:FS01:0x22: Config: <none>
14:09:56:WU03:FS01:0x22:************************************ Build *************************************
14:09:56:WU03:FS01:0x22: Version: 0.0.5
14:09:56:WU03:FS01:0x22: Date: Apr 22 2020
14:09:56:WU03:FS01:0x22: Time: 04:42:59
14:09:56:WU03:FS01:0x22: Repository: Git
14:09:56:WU03:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
14:09:56:WU03:FS01:0x22: Branch: HEAD
14:09:56:WU03:FS01:0x22: Compiler: Visual C++ 2008
14:09:56:WU03:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:09:56:WU03:FS01:0x22: Platform: win32 10
14:09:56:WU03:FS01:0x22: Bits: 64
14:09:56:WU03:FS01:0x22: Mode: Release
14:09:56:WU03:FS01:0x22:************************************ System ************************************
14:09:56:WU03:FS01:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
14:09:56:WU03:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
14:09:56:WU03:FS01:0x22: CPUs: 16
14:09:56:WU03:FS01:0x22: Memory: 31.86GiB
14:09:56:WU03:FS01:0x22:Free Memory: 22.18GiB
14:09:56:WU03:FS01:0x22: Threads: WINDOWS_THREADS
14:09:56:WU03:FS01:0x22: OS Version: 6.2
14:09:56:WU03:FS01:0x22:Has Battery: false
14:09:56:WU03:FS01:0x22: On Battery: false
14:09:56:WU03:FS01:0x22: UTC Offset: 2
14:09:56:WU03:FS01:0x22: PID: 15368
14:09:56:WU03:FS01:0x22: CWD: D:\FAHClient\work
14:09:56:WU03:FS01:0x22: OS: Windows 10 Pro
14:09:56:WU03:FS01:0x22: OS Arch: AMD64
14:09:56:WU03:FS01:0x22:********************************************************************************
14:09:56:WU03:FS01:0x22:Project: 16435 (Run 104, Clone 1, Gen 8)
14:09:56:WU03:FS01:0x22:Unit: 0x0000001103854c135e9a4ef67021ced2
14:09:56:WU03:FS01:0x22:Reading tar file core.xml
14:09:56:WU03:FS01:0x22:Reading tar file integrator.xml
14:09:56:WU03:FS01:0x22:Reading tar file state.xml
14:09:57:WU03:FS01:0x22:Reading tar file system.xml
14:09:57:WU03:FS01:0x22:Digital signatures verified
14:09:57:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:09:57:WU03:FS01:0x22:Version 0.0.5
14:10:01:WU00:FS01:Upload 6.47%
14:10:07:WU00:FS01:Upload 24.87%
14:10:13:WU00:FS01:Upload 40.29%
14:10:13:WU03:FS01:0x22:Completed 0 out of 5000000 steps (0%)
14:10:13:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:10:19:WU00:FS01:Upload 49.24%
14:10:24:WU02:FS00:0xa7:Completed 9375 out of 62500 steps (15%)
14:10:25:WU00:FS01:Upload 66.65%
14:10:31:WU00:FS01:Upload 87.04%
14:10:39:WU00:FS01:Upload complete
14:10:39:WU00:FS01:Server responded WORK_ACK (400)
14:10:39:WU00:FS01:Final credit estimate, 61097.00 points
14:10:39:WU00:FS01:Cleaning up
14:10:54:WU01:FS02:0x22:Completed 720000 out of 1000000 steps (72%)
14:11:33:WU02:FS00:0xa7:Completed 10000 out of 62500 steps (16%)
14:12:43:WU02:FS00:0xa7:Completed 10625 out of 62500 steps (17%)
14:13:50:WU01:FS02:0x22:Completed 730000 out of 1000000 steps (73%)
14:13:52:WU02:FS00:0xa7:Completed 11250 out of 62500 steps (18%)
14:14:48:WU03:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
14:15:01:WU02:FS00:0xa7:Completed 11875 out of 62500 steps (19%)
14:16:12:WU02:FS00:0xa7:Completed 12500 out of 62500 steps (20%)
14:16:47:WU01:FS02:0x22:Completed 740000 out of 1000000 steps (74%)
14:17:22:WU02:FS00:0xa7:Completed 13125 out of 62500 steps (21%)
14:18:31:WU02:FS00:0xa7:Completed 13750 out of 62500 steps (22%)
14:19:27:WU03:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
14:19:42:WU02:FS00:0xa7:Completed 14375 out of 62500 steps (23%)
14:19:43:WU01:FS02:0x22:Completed 750000 out of 1000000 steps (75%)
14:20:51:WU02:FS00:0xa7:Completed 15000 out of 62500 steps (24%)
14:22:01:WU02:FS00:0xa7:Completed 15625 out of 62500 steps (25%)
14:22:44:WU01:FS02:0x22:Completed 760000 out of 1000000 steps (76%)
14:23:17:WU02:FS00:0xa7:Completed 16250 out of 62500 steps (26%)
14:24:05:WU03:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
14:24:26:WU02:FS00:0xa7:Completed 16875 out of 62500 steps (27%)
14:25:36:WU02:FS00:0xa7:Completed 17500 out of 62500 steps (28%)
14:25:40:WU01:FS02:0x22:Completed 770000 out of 1000000 steps (77%)
14:26:45:WU02:FS00:0xa7:Completed 18125 out of 62500 steps (29%)
14:27:54:WU02:FS00:0xa7:Completed 18750 out of 62500 steps (30%)
14:28:37:WU01:FS02:0x22:Completed 780000 out of 1000000 steps (78%)
14:28:41:WU03:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
14:29:03:WU02:FS00:0xa7:Completed 19375 out of 62500 steps (31%)
14:30:12:WU02:FS00:0xa7:Completed 20000 out of 62500 steps (32%)
14:31:23:WU02:FS00:0xa7:Completed 20625 out of 62500 steps (33%)
14:31:33:WU01:FS02:0x22:Completed 790000 out of 1000000 steps (79%)
14:32:32:WU02:FS00:0xa7:Completed 21250 out of 62500 steps (34%)
14:33:18:WU03:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
14:33:42:WU02:FS00:0xa7:Completed 21875 out of 62500 steps (35%)
14:34:30:WU01:FS02:0x22:Completed 800000 out of 1000000 steps (80%)
14:34:52:WU02:FS00:0xa7:Completed 22500 out of 62500 steps (36%)
14:36:02:WU02:FS00:0xa7:Completed 23125 out of 62500 steps (37%)
14:37:12:WU02:FS00:0xa7:Completed 23750 out of 62500 steps (38%)
14:37:31:WU01:FS02:0x22:Completed 810000 out of 1000000 steps (81%)
14:37:57:WU03:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
14:38:27:WU02:FS00:0xa7:Completed 24375 out of 62500 steps (39%)
14:39:38:WU02:FS00:0xa7:Completed 25000 out of 62500 steps (40%)
14:40:28:WU01:FS02:0x22:Completed 820000 out of 1000000 steps (82%)
14:40:48:WU02:FS00:0xa7:Completed 25625 out of 62500 steps (41%)
14:41:59:WU02:FS00:0xa7:Completed 26250 out of 62500 steps (42%)
14:42:36:WU03:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
14:43:09:WU02:FS00:0xa7:Completed 26875 out of 62500 steps (43%)
14:43:24:WU01:FS02:0x22:Completed 830000 out of 1000000 steps (83%)
14:44:20:WU02:FS00:0xa7:Completed 27500 out of 62500 steps (44%)
14:45:30:WU02:FS00:0xa7:Completed 28125 out of 62500 steps (45%)
14:46:21:WU01:FS02:0x22:Completed 840000 out of 1000000 steps (84%)
14:46:42:WU02:FS00:0xa7:Completed 28750 out of 62500 steps (46%)
14:47:17:WU03:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
14:47:52:WU02:FS00:0xa7:Completed 29375 out of 62500 steps (47%)
14:49:01:WU02:FS00:0xa7:Completed 30000 out of 62500 steps (48%)
14:49:17:WU01:FS02:0x22:Completed 850000 out of 1000000 steps (85%)
14:50:13:WU02:FS00:0xa7:Completed 30625 out of 62500 steps (49%)
14:51:23:WU02:FS00:0xa7:Completed 31250 out of 62500 steps (50%)
14:51:55:WU03:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
14:52:19:WU01:FS02:0x22:Completed 860000 out of 1000000 steps (86%)
14:52:33:WU02:FS00:0xa7:Completed 31875 out of 62500 steps (51%)
14:53:49:WU02:FS00:0xa7:Completed 32500 out of 62500 steps (52%)
14:54:59:WU02:FS00:0xa7:Completed 33125 out of 62500 steps (53%)
14:55:15:WU01:FS02:0x22:Completed 870000 out of 1000000 steps (87%)
14:56:08:WU02:FS00:0xa7:Completed 33750 out of 62500 steps (54%)
14:56:32:WU03:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
14:57:18:WU02:FS00:0xa7:Completed 34375 out of 62500 steps (55%)
14:58:12:WU01:FS02:0x22:Completed 880000 out of 1000000 steps (88%)
14:58:26:WU02:FS00:0xa7:Completed 35000 out of 62500 steps (56%)
14:59:36:WU02:FS00:0xa7:Completed 35625 out of 62500 steps (57%)
15:00:47:WU02:FS00:0xa7:Completed 36250 out of 62500 steps (58%)
15:01:07:WU03:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
15:01:08:WU01:FS02:0x22:Completed 890000 out of 1000000 steps (89%)
15:01:56:WU02:FS00:0xa7:Completed 36875 out of 62500 steps (59%)
15:03:05:WU02:FS00:0xa7:Completed 37500 out of 62500 steps (60%)
15:04:05:WU01:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
15:04:15:WU02:FS00:0xa7:Completed 38125 out of 62500 steps (61%)
15:05:23:WU02:FS00:0xa7:Completed 38750 out of 62500 steps (62%)
15:05:41:WU03:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
15:06:33:WU02:FS00:0xa7:Completed 39375 out of 62500 steps (63%)
15:07:06:WU01:FS02:0x22:Completed 910000 out of 1000000 steps (91%)
15:07:42:WU02:FS00:0xa7:Completed 40000 out of 62500 steps (64%)
15:08:55:WU02:FS00:0xa7:Completed 40625 out of 62500 steps (65%)
15:10:02:WU01:FS02:0x22:Completed 920000 out of 1000000 steps (92%)
15:10:05:WU02:FS00:0xa7:Completed 41250 out of 62500 steps (66%)
15:10:16:WU03:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
15:11:15:WU02:FS00:0xa7:Completed 41875 out of 62500 steps (67%)
15:12:24:WU02:FS00:0xa7:Completed 42500 out of 62500 steps (68%)
15:12:58:WU01:FS02:0x22:Completed 930000 out of 1000000 steps (93%)
15:13:34:WU02:FS00:0xa7:Completed 43125 out of 62500 steps (69%)
15:14:43:WU02:FS00:0xa7:Completed 43750 out of 62500 steps (70%)
15:14:51:WU03:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
15:15:54:WU02:FS00:0xa7:Completed 44375 out of 62500 steps (71%)
15:15:55:WU01:FS02:0x22:Completed 940000 out of 1000000 steps (94%)
15:17:04:WU02:FS00:0xa7:Completed 45000 out of 62500 steps (72%)
15:18:15:WU02:FS00:0xa7:Completed 45625 out of 62500 steps (73%)
15:18:52:WU01:FS02:0x22:Completed 950000 out of 1000000 steps (95%)
15:19:25:WU02:FS00:0xa7:Completed 46250 out of 62500 steps (74%)
15:19:32:WU03:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
15:20:35:WU02:FS00:0xa7:Completed 46875 out of 62500 steps (75%)
15:21:46:WU02:FS00:0xa7:Completed 47500 out of 62500 steps (76%)
15:21:53:WU01:FS02:0x22:Completed 960000 out of 1000000 steps (96%)
15:22:56:WU02:FS00:0xa7:Completed 48125 out of 62500 steps (77%)
15:24:11:WU03:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
15:24:12:WU02:FS00:0xa7:Completed 48750 out of 62500 steps (78%)
15:24:49:WU01:FS02:0x22:Completed 970000 out of 1000000 steps (97%)
15:25:22:WU02:FS00:0xa7:Completed 49375 out of 62500 steps (79%)
15:26:32:WU02:FS00:0xa7:Completed 50000 out of 62500 steps (80%)
15:27:42:WU02:FS00:0xa7:Completed 50625 out of 62500 steps (81%)
15:27:46:WU01:FS02:0x22:Completed 980000 out of 1000000 steps (98%)
15:28:51:WU03:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
15:28:52:WU02:FS00:0xa7:Completed 51250 out of 62500 steps (82%)
15:30:01:WU02:FS00:0xa7:Completed 51875 out of 62500 steps (83%)
15:30:42:WU01:FS02:0x22:Completed 990000 out of 1000000 steps (99%)
15:30:43:WU00:FS02:Connecting to assign1.foldingathome.org:80
15:30:44:WARNING:WU00:FS02:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:30:44:WU00:FS02:Connecting to assign2.foldingathome.org:80
15:30:44:WARNING:WU00:FS02:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:30:44:WU00:FS02:Connecting to assign3.foldingathome.org:80
15:30:45:WARNING:WU00:FS02:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:30:45:WU00:FS02:Connecting to assign4.foldingathome.org:80
15:30:45:WARNING:WU00:FS02:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:30:45:ERROR:WU00:FS02:Exception: Could not get an assignment
15:30:45:WU00:FS02:Connecting to assign1.foldingathome.org:80
15:30:46:WU00:FS02:Assigned to work server 140.163.4.241
15:30:46:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP107 [GeForce GTX 1050 Ti] 2138 from 140.163.4.241
15:30:46:WU00:FS02:Connecting to 140.163.4.241:8080
15:30:49:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
15:30:49:WU00:FS02:Connecting to 140.163.4.241:80
15:30:52:ERROR:WU00:FS02:Exception: Failed to connect to 140.163.4.241:80: No connection could be made because the target machine actively refused it.
15:31:10:WU02:FS00:0xa7:Completed 52500 out of 62500 steps (84%)
15:31:46:WU00:FS02:Connecting to assign1.foldingathome.org:80
15:31:46:WU00:FS02:Assigned to work server 18.188.125.154
15:31:46:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP107 [GeForce GTX 1050 Ti] 2138 from 18.188.125.154
15:31:46:WU00:FS02:Connecting to 18.188.125.154:8080
15:31:48:WU00:FS02:Downloading 6.62MiB
15:31:51:WU00:FS02:Download complete
15:31:51:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13404 run:161 clone:61 gen:0 core:0x22 unit:0x0000000112bc7d9a5eb3a397620ae4fc
15:32:21:WU02:FS00:0xa7:Completed 53125 out of 62500 steps (85%)
15:33:28:WU03:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
15:33:30:WU02:FS00:0xa7:Completed 53750 out of 62500 steps (86%)
15:33:39:WU01:FS02:0x22:Completed 1000000 out of 1000000 steps (100%)
15:33:43:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
15:33:43:WU01:FS02:0x22:Saving result file checkpointState.xml
15:33:47:WU01:FS02:0x22:Saving result file checkpt.crc
15:33:47:WU01:FS02:0x22:Saving result file positions.xtc
15:33:48:WU01:FS02:0x22:Saving result file science.log
15:33:49:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:33:49:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:33:49:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:11745 run:0 clone:808 gen:80 core:0x22 unit:0x0000007f8ca304f15e67ec9e33491f71
15:33:49:WU01:FS02:Uploading 14.66MiB to 140.163.4.241
15:33:49:WU00:FS02:Starting
15:33:49:WU01:FS02:Connecting to 140.163.4.241:8080
15:33:49:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
15:33:50:WU00:FS02:Started FahCore on PID 1248
15:33:50:WU00:FS02:Core PID:15508
15:33:50:WU00:FS02:FahCore 0x22 started
OddSoxChris
Re: My FAH client strange behaviour
15:33:50:WU00:FS02:0x22:*********************** Log Started 2020-05-07T15:33:50Z ***********************
15:33:50:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:33:50:WU00:FS02:0x22: Type: 0x22
15:33:50:WU00:FS02:0x22: Core: Core22
15:33:50:WU00:FS02:0x22: Website: https://foldingathome.org/
15:33:50:WU00:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:33:50:WU00:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:33:50:WU00:FS02:0x22: <rafal.wiewiora@choderalab.org>
15:33:50:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 1248 -checkpoint 15
15:33:50:WU00:FS02:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
15:33:50:WU00:FS02:0x22: 0 -gpu 0
15:33:50:WU00:FS02:0x22: Config: <none>
15:33:50:WU00:FS02:0x22:************************************ Build *************************************
15:33:50:WU00:FS02:0x22: Version: 0.0.5
15:33:50:WU00:FS02:0x22: Date: Apr 22 2020
15:33:50:WU00:FS02:0x22: Time: 04:42:59
15:33:50:WU00:FS02:0x22: Repository: Git
15:33:50:WU00:FS02:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:33:50:WU00:FS02:0x22: Branch: HEAD
15:33:50:WU00:FS02:0x22: Compiler: Visual C++ 2008
15:33:50:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:33:50:WU00:FS02:0x22: Platform: win32 10
15:33:50:WU00:FS02:0x22: Bits: 64
15:33:50:WU00:FS02:0x22: Mode: Release
15:33:50:WU00:FS02:0x22:************************************ System ************************************
15:33:50:WU00:FS02:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:33:50:WU00:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:33:50:WU00:FS02:0x22: CPUs: 16
15:33:50:WU00:FS02:0x22: Memory: 31.86GiB
15:33:50:WU00:FS02:0x22:Free Memory: 22.46GiB
15:33:50:WU00:FS02:0x22: Threads: WINDOWS_THREADS
15:33:50:WU00:FS02:0x22: OS Version: 6.2
15:33:50:WU00:FS02:0x22:Has Battery: false
15:33:50:WU00:FS02:0x22: On Battery: false
15:33:50:WU00:FS02:0x22: UTC Offset: 2
15:33:50:WU00:FS02:0x22: PID: 15508
15:33:50:WU00:FS02:0x22: CWD: D:\FAHClient\work
15:33:50:WU00:FS02:0x22: OS: Windows 10 Pro
15:33:50:WU00:FS02:0x22: OS Arch: AMD64
15:33:50:WU00:FS02:0x22:********************************************************************************
15:33:50:WU00:FS02:0x22:Project: 13404 (Run 161, Clone 61, Gen 0)
15:33:50:WU00:FS02:0x22:Unit: 0x0000000112bc7d9a5eb3a397620ae4fc
15:33:50:WU00:FS02:0x22:Reading tar file core.xml
15:33:50:WU00:FS02:0x22:Reading tar file integrator.xml
15:33:50:WU00:FS02:0x22:Reading tar file state.xml
15:33:51:WU00:FS02:0x22:Reading tar file system.xml
15:33:51:WU00:FS02:0x22:Digital signatures verified
15:33:51:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:33:51:WU00:FS02:0x22:Version 0.0.5
15:33:53:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
15:33:53:WU01:FS02:Connecting to 140.163.4.241:80
15:33:56:WARNING:WU01:FS02:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: No connection could be made because the target machine actively refused it.
15:33:56:WU01:FS02:Trying to send results to collection server
15:33:56:WU01:FS02:Uploading 14.66MiB to 52.224.109.74
15:33:56:WU01:FS02:Connecting to 52.224.109.74:8080
15:34:02:WU01:FS02:Upload 8.53%
15:34:08:WU01:FS02:Upload 19.62%
15:34:12:WU00:FS02:0x22:Completed 0 out of 1000000 steps (0%)
15:34:12:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:34:14:WU01:FS02:Upload 40.51%
15:34:20:WU01:FS02:Upload 61.83%
15:34:26:WU01:FS02:Upload 82.73%
15:34:34:WU01:FS02:Upload complete
15:34:34:WU01:FS02:Server responded WORK_ACK (400)
15:34:34:WU01:FS02:Final credit estimate, 38428.00 points
15:34:34:WU01:FS02:Cleaning up
15:34:40:WU02:FS00:0xa7:Completed 54375 out of 62500 steps (87%)
15:35:49:WU02:FS00:0xa7:Completed 55000 out of 62500 steps (88%)
15:36:59:WU02:FS00:0xa7:Completed 55625 out of 62500 steps (89%)
15:38:06:WU03:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
15:38:14:WU02:FS00:0xa7:Completed 56250 out of 62500 steps (90%)
15:39:23:WU02:FS00:0xa7:Completed 56875 out of 62500 steps (91%)
15:40:33:WU02:FS00:0xa7:Completed 57500 out of 62500 steps (92%)
15:41:00:WU00:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
15:41:43:WU02:FS00:0xa7:Completed 58125 out of 62500 steps (93%)
15:42:44:WU03:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
15:42:53:WU02:FS00:0xa7:Completed 58750 out of 62500 steps (94%)
15:44:03:WU02:FS00:0xa7:Completed 59375 out of 62500 steps (95%)
15:45:12:WU02:FS00:0xa7:Completed 60000 out of 62500 steps (96%)
15:46:20:WU02:FS00:0xa7:Completed 60625 out of 62500 steps (97%)
15:47:19:WU03:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
15:47:30:WU02:FS00:0xa7:Completed 61250 out of 62500 steps (98%)
15:47:47:WU00:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
15:48:39:WU02:FS00:0xa7:Completed 61875 out of 62500 steps (99%)
15:48:40:WU01:FS00:Connecting to assign1.foldingathome.org:80
15:48:40:WU01:FS00:Assigned to work server 128.252.203.9
15:48:40:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:14 from 128.252.203.9
15:48:40:WU01:FS00:Connecting to 128.252.203.9:8080
15:49:02:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
15:49:02:WU01:FS00:Connecting to 128.252.203.9:80
15:49:49:WU02:FS00:0xa7:Completed 62500 out of 62500 steps (100%)
15:50:06:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
15:50:06:WU02:FS00:0xa7:Saving result file frame67.trr
15:50:07:WU02:FS00:0xa7:Saving result file frame67.xtc
15:50:07:WU02:FS00:0xa7:Saving result file md.log
15:50:07:WU02:FS00:0xa7:Saving result file science.log
15:50:07:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:50:07:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:50:07:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14583 run:0 clone:149 gen:67 core:0xa7 unit:0x0000004880fccb025e8bcb35c396bdc2
15:50:07:WU02:FS00:Uploading 11.03MiB to 128.252.203.2
15:50:07:WU02:FS00:Connecting to 128.252.203.2:8080
15:50:13:WU01:FS00:Downloading 8.14MiB
15:50:19:WU02:FS00:Upload 2.83%
15:50:19:WU01:FS00:Download 8.45%
15:50:25:WU02:FS00:Upload 37.40%
15:50:25:WU01:FS00:Download 13.82%
15:50:31:WU02:FS00:Upload 52.13%
15:50:31:WU01:FS00:Download 19.20%
15:50:37:WU01:FS00:Download 23.80%
15:50:37:WU02:FS00:Upload 64.60%
15:50:43:WU01:FS00:Download 29.18%
15:50:43:WU02:FS00:Upload 90.10%
15:50:44:WU02:FS00:Upload complete
15:50:44:WU02:FS00:Server responded WORK_ACK (400)
15:50:44:WU02:FS00:Final credit estimate, 8227.00 points
15:50:44:WU02:FS00:Cleaning up
15:50:50:WU01:FS00:Download 32.25%
15:50:56:WU01:FS00:Download 37.63%
15:51:02:WU01:FS00:Download 43.77%
15:51:08:WU01:FS00:Download 49.91%
15:51:14:WU01:FS00:Download 56.06%
15:51:20:WU01:FS00:Download 62.20%
15:51:26:WU01:FS00:Download 66.81%
15:51:32:WU01:FS00:Download 72.95%
15:51:38:WU01:FS00:Download 79.86%
15:51:39:WU03:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
15:51:44:WU01:FS00:Download 83.70%
15:51:50:WU01:FS00:Download 88.31%
15:51:56:WU01:FS00:Download 92.91%
15:52:02:WU01:FS00:Download 97.52%
15:52:05:WU01:FS00:Download complete
15:52:05:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13824 run:704 clone:0 gen:133 core:0xa7 unit:0x000000a080fccb095c924848876bbad2
15:52:05:WU01:FS00:Starting
15:52:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15 -np 14
15:52:05:WU01:FS00:Started FahCore on PID 11516
15:52:05:WU01:FS00:Core PID:15764
15:52:05:WU01:FS00:FahCore 0xa7 started
15:52:06:WU01:FS00:0xa7:*********************** Log Started 2020-05-07T15:52:05Z ***********************
15:52:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:52:06:WU01:FS00:0xa7: Type: 0xa7
15:52:06:WU01:FS00:0xa7: Core: Gromacs
15:52:06:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 11516 -checkpoint 15 -np
15:52:06:WU01:FS00:0xa7: 14
15:52:06:WU01:FS00:0xa7:************************************ CBang *************************************
15:52:06:WU01:FS00:0xa7: Date: Oct 26 2019
15:52:06:WU01:FS00:0xa7: Time: 01:38:25
15:52:06:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:52:06:WU01:FS00:0xa7: Branch: master
15:52:06:WU01:FS00:0xa7: Compiler: Visual C++ 2008
15:52:06:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:52:06:WU01:FS00:0xa7: Platform: win32 10
15:52:06:WU01:FS00:0xa7: Bits: 64
15:52:06:WU01:FS00:0xa7: Mode: Release
15:52:06:WU01:FS00:0xa7:************************************ System ************************************
15:52:06:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:52:06:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:52:06:WU01:FS00:0xa7: CPUs: 16
15:52:06:WU01:FS00:0xa7: Memory: 31.86GiB
15:52:06:WU01:FS00:0xa7:Free Memory: 24.26GiB
15:52:06:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
15:52:06:WU01:FS00:0xa7: OS Version: 6.2
15:52:06:WU01:FS00:0xa7:Has Battery: false
15:52:06:WU01:FS00:0xa7: On Battery: false
15:52:06:WU01:FS00:0xa7: UTC Offset: 2
15:52:06:WU01:FS00:0xa7: PID: 15764
15:52:06:WU01:FS00:0xa7: CWD: D:\FAHClient\work
15:52:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:52:06:WU01:FS00:0xa7: Version: 0.0.18
15:52:06:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:52:06:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
15:52:06:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
15:52:06:WU01:FS00:0xa7: Time: 01:52:30
15:52:06:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:52:06:WU01:FS00:0xa7:************************************ Build *************************************
15:52:06:WU01:FS00:0xa7: SIMD: avx_256
15:52:06:WU01:FS00:0xa7:********************************************************************************
15:52:06:WU01:FS00:0xa7:Project: 13824 (Run 704, Clone 0, Gen 133)
15:52:06:WU01:FS00:0xa7:Unit: 0x000000a080fccb095c924848876bbad2
15:52:06:WU01:FS00:0xa7:Reading tar file core.xml
15:52:06:WU01:FS00:0xa7:Reading tar file frame133.tpr
15:52:06:WU01:FS00:0xa7:Digital signatures verified
15:52:06:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
15:52:06:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
15:52:06:WU01:FS00:0xa7:Calling: mdrun -s frame133.tpr -o frame133.trr -x frame133.xtc -cpt 15 -nt 12
15:52:06:WU01:FS00:0xa7:Steps: first=16625000 total=125000
15:52:10:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
15:53:11:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
15:54:09:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
15:54:31:WU00:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
15:55:07:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
15:55:50:WU03:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
15:56:04:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
15:56:28:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:56:28:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
15:57:02:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
15:57:04:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:57:04:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
15:57:11:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:57:11:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
15:57:11:WU03:FS01:0x22:ERROR:114: Max Retries Reached
15:57:11:WU03:FS01:0x22:Saving result file ..\logfile_01.txt
15:57:11:WU03:FS01:0x22:Saving result file badstate-0.xml
15:57:11:WU03:FS01:0x22:Saving result file badstate-1.xml
15:57:11:WU03:FS01:0x22:Saving result file badstate-2.xml
15:57:11:WU03:FS01:0x22:Saving result file checkpointState.xml
15:57:11:WU03:FS01:0x22:Saving result file checkpt.crc
15:57:11:WU03:FS01:0x22:Saving result file positions.xtc
15:57:11:WU03:FS01:0x22:Saving result file science.log
15:57:11:WU03:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:57:12:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:57:12:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:16435 run:104 clone:1 gen:8 core:0x22 unit:0x0000001103854c135e9a4ef67021ced2
15:57:12:WU03:FS01:Uploading 62.03MiB to 3.133.76.19
15:57:12:WU03:FS01:Connecting to 3.133.76.19:8080
15:57:13:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:57:13:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:57:13:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:57:13:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:57:14:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:57:14:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:57:14:WU02:FS01:Connecting to assign4.foldingathome.org:80
15:57:15:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:57:15:ERROR:WU02:FS01:Exception: Could not get an assignment
15:57:15:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:57:15:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:57:15:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:57:16:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:57:16:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:57:16:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:57:16:WU02:FS01:Connecting to assign4.foldingathome.org:80
15:57:17:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:57:17:ERROR:WU02:FS01:Exception: Could not get an assignment
15:57:33:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
15:57:33:WU03:FS01:Connecting to 3.133.76.19:80
15:57:41:WU03:FS01:Upload 0.10%
15:58:00:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
15:58:15:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:58:15:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:58:15:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:58:16:WU02:FS01:Assigned to work server 3.133.76.19
15:58:16:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
15:58:16:WU02:FS01:Connecting to 3.133.76.19:8080
15:58:37:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
15:58:37:WU02:FS01:Connecting to 3.133.76.19:80
15:58:49:WU03:FS01:Upload 0.20%
15:58:49:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
15:58:49:WU03:FS01:Trying to send results to collection server
15:58:49:WU03:FS01:Uploading 62.03MiB to 3.21.157.11
15:58:49:WU03:FS01:Connecting to 3.21.157.11:8080
15:58:55:WU03:FS01:Upload 1.41%
15:58:57:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
15:58:58:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:59:01:WU03:FS01:Upload 4.63%
15:59:07:WU03:FS01:Upload 7.36%
15:59:13:WU03:FS01:Upload 10.98%
15:59:19:WU03:FS01:Upload 14.51%
15:59:25:WU03:FS01:Upload 16.73%
15:59:31:WU03:FS01:Upload 19.85%
15:59:37:WU03:FS01:Upload 23.27%
15:59:43:WU03:FS01:Upload 26.30%
15:59:49:WU03:FS01:Upload 29.52%
15:59:52:WU02:FS01:Connecting to assign1.foldingathome.org:80
15:59:53:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:59:53:WU02:FS01:Connecting to assign2.foldingathome.org:80
15:59:53:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
15:59:53:WU02:FS01:Connecting to assign3.foldingathome.org:80
15:59:54:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
15:59:54:WU02:FS01:Connecting to assign4.foldingathome.org:80
15:59:54:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
15:59:54:ERROR:WU02:FS01:Exception: Could not get an assignment
15:59:55:WU03:FS01:Upload 33.25%
15:59:55:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
16:00:01:WU03:FS01:Upload 36.88%
16:00:07:WU03:FS01:Upload 39.60%
16:00:13:WU03:FS01:Upload 42.62%
16:00:19:WU03:FS01:Upload 45.84%
16:00:25:WU03:FS01:Upload 48.56%
16:00:31:WU03:FS01:Upload 51.29%
16:00:37:WU03:FS01:Upload 54.81%
16:00:43:WU03:FS01:Upload 58.34%
16:00:49:WU03:FS01:Upload 61.16%
16:00:52:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
16:00:55:WU03:FS01:Upload 64.59%
16:01:01:WU03:FS01:Upload 67.00%
16:01:08:WU03:FS01:Upload 69.42%
16:01:15:WU03:FS01:Upload 71.84%
16:01:16:WU00:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
16:01:21:WU03:FS01:Upload 74.76%
16:01:27:WU03:FS01:Upload 77.89%
16:01:33:WU03:FS01:Upload 80.71%
16:01:39:WU03:FS01:Upload 82.92%
16:01:45:WU03:FS01:Upload 85.85%
16:01:50:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
16:01:51:WU03:FS01:Upload 87.56%
16:01:57:WU03:FS01:Upload 90.88%
16:02:03:WU03:FS01:Upload 92.90%
16:02:09:WU03:FS01:Upload 96.12%
16:02:15:WU03:FS01:Upload 98.74%
16:02:20:WU03:FS01:Upload complete
16:02:20:WU03:FS01:Server responded WORK_ACK (400)
16:02:20:WU03:FS01:Cleaning up
16:02:29:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:02:30:WU02:FS01:Assigned to work server 128.252.203.10
16:02:30:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
16:02:30:WU02:FS01:Connecting to 128.252.203.10:8080
16:02:47:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
16:02:51:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
16:02:51:WU02:FS01:Connecting to 128.252.203.10:80
16:03:13:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:03:44:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
16:04:41:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
16:05:39:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
16:06:35:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
16:06:44:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:06:44:WARNING:WU02:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
16:06:44:WU02:FS01:Connecting to assign2.foldingathome.org:80
16:06:45:WARNING:WU02:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
16:06:45:WU02:FS01:Connecting to assign3.foldingathome.org:80
16:06:45:WARNING:WU02:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
16:06:45:WU02:FS01:Connecting to assign4.foldingathome.org:80
16:06:46:WARNING:WU02:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
16:06:46:ERROR:WU02:FS01:Exception: Could not get an assignment
16:07:36:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
16:08:02:WU00:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
16:08:32:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
16:09:29:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
16:10:26:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
16:11:23:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
16:12:21:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
16:13:18:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
16:13:35:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:13:36:WU02:FS01:Assigned to work server 140.163.4.231
16:13:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.231
16:13:36:WU02:FS01:Connecting to 140.163.4.231:8080
16:14:15:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
16:14:47:WU00:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
16:15:04:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:15:12:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
16:16:09:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
16:17:05:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
16:18:02:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
16:18:59:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
16:19:56:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
16:20:53:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
16:21:32:WU00:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
16:21:50:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
16:22:49:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
16:23:46:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
16:24:41:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:24:41:WU02:FS01:Assigned to work server 3.133.76.19
16:24:41:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
16:24:41:WU02:FS01:Connecting to 3.133.76.19:8080
16:24:43:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
16:25:03:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
16:25:03:WU02:FS01:Connecting to 3.133.76.19:80
16:25:24:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:25:40:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
16:26:36:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
16:27:34:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
16:28:17:WU00:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
16:28:30:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
16:29:27:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
16:30:23:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
16:31:20:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
16:32:17:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
16:33:14:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
16:34:11:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
16:35:02:WU00:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
16:35:07:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
16:36:05:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
16:37:01:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
16:38:00:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
16:38:57:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
16:39:54:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
******************************* Date: 2020-05-07 *******************************
16:40:50:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
16:41:47:WU00:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
16:41:47:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
16:42:37:WU02:FS01:Connecting to assign1.foldingathome.org:80
16:42:38:WU02:FS01:Assigned to work server 140.163.4.231
OddSoxChris
I uploaded all earlier logs to my Google Drive:
https://drive.google.com/drive/folders/ ... sp=sharing
We might need to see the messages to confirm the problem in the log done just before the shutdown and upgrades. But it appears that the WU02 was carried over, but it looks like its checkpoint was damaged in some way, possibly by the shutdown not waiting long enough for the checkpoint to be written out fully.
Another CPU WU was downloaded, it is not clear why. It may be related to the update to the client and possibly not detecting that a WU was already in progress for the CPU slot.
