Gromacs / system is not well equilibrated errors
JuWaJo
Post by JuWaJo »
They haven't been common. However, i've thought that I should bring this to the forums attention.
*********************** Log Started 2020-05-05T20:56:44Z ***********************
21:59:10:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
22:15:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:51:52:WU02:FS00:0xa7:ERROR:
00:51:52:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
00:51:52:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
00:51:52:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
00:51:52:WU02:FS00:0xa7:ERROR:Fatal error:
00:51:52:WU02:FS00:0xa7:ERROR:1 particles communicated to PME rank 14 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
00:51:52:WU02:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
00:51:52:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
00:51:52:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
00:51:58:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
00:51:58:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
00:53:42:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:19:36:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:21:14:WU02:FS00:0xa7:ERROR:
01:21:14:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
01:21:14:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
01:21:14:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
01:21:14:WU02:FS00:0xa7:ERROR:Fatal error:
01:21:14:WU02:FS00:0xa7:ERROR:1 particles communicated to PME rank 10 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
01:21:14:WU02:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
01:21:14:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
01:21:14:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
01:21:20:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
01:21:20:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
******************************* Date: 2020-05-06 *******************************
03:07:58:WU02:FS00:0xa7:ERROR:
03:07:58:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
03:07:58:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:07:58:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
03:07:58:WU02:FS00:0xa7:ERROR:Fatal error:
03:07:58:WU02:FS00:0xa7:ERROR:1 particles communicated to PME rank 14 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
03:07:58:WU02:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
03:07:58:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:07:58:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:08:04:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:08:04:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
03:08:04:WARNING:WU02:FS00:Too many errors, failing
03:08:12:WARNING:WU01:FS00:AS lowered CPUs from 15 to 14
Re: Gromacs / system is not well equilibrated errors
Post by Neil-B »
What PRCG are these errors from? ... and what is your CPU slot configuration? ... Another similar report has been made - if these are from the same projectwith a similar configuration it might help the researchers identify the issue.
JuWaJo
Post by JuWaJo »
It looks like Project 14237. I am on a CPU ID of 0 as well as GPU being 1.
Please post the log showing the start of the WU, not just the error messages. That will identify exactly what WU this is.
JuWaJo
Post by JuWaJo »
20:56:44:****************************** FAHClient ******************************
20:56:44:        Version: 7.6.9
20:56:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:56:44:      Copyright: 2020 foldingathome.org
20:56:44:       Homepage: https://foldingathome.org/
20:56:44:           Date: Apr 17 2020
20:56:44:           Time: 11:13:06
20:56:44:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
20:56:44:         Branch: master
20:56:44:       Compiler: Visual C++ 2008
20:56:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:56:44:       Platform: win32 10
20:56:44:           Bits: 32
20:56:44:           Mode: Release
20:56:44:           Args: --open-web-control
20:56:44:         Config: C:\Users\Justin\AppData\Roaming\FAHClient\config.xml
20:56:44:******************************** CBang ********************************
20:56:44:           Time: 11:10:09
20:56:44:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
20:56:44:           Bits: 32
20:56:44:******************************* System ********************************
20:56:44:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
20:56:44:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
20:56:44:           CPUs: 16
20:56:44:         Memory: 15.96GiB
20:56:44:    Free Memory: 14.04GiB
20:56:44:        Threads: WINDOWS_THREADS
20:56:44:     OS Version: 6.2
20:56:44:    Has Battery: false
20:56:44:     On Battery: false
20:56:44:     UTC Offset: -4
20:56:44:            PID: 8284
20:56:44:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
20:56:44:             OS: Windows 10 Enterprise
20:56:44:        OS Arch: AMD64
20:56:44:           GPUs: 1
20:56:44:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
20:56:44:                 470/480/570/580/590]
20:56:44:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:56:44:                 specified module could not be found.
20:56:44:
20:56:44:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:2841.19
20:56:44:  Win32 Service: false
20:56:44:******************************* libFAH ********************************
20:56:44:           Date: Apr 15 2020
20:56:44:           Time: 14:53:14
20:56:44:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
20:56:44:           Bits: 32
20:56:44:***********************************************************************
20:56:44:<config>
20:56:44:  <!-- Folding Core -->
20:56:44:  <core-priority v='low'/>
20:56:44:
20:56:44:  <!-- Folding Slot Configuration -->
20:56:44:  <cause v='COVID_19'/>
20:56:44:
20:56:44:  <!-- Network -->
20:56:44:  <proxy v=':8080'/>
20:56:44:
20:56:44:  <!-- Remote Command Server -->
20:56:44:  <password v='*****'/>
20:56:44:
20:56:44:  <!-- Slot Control -->
20:56:44:  <pause-on-battery v='false'/>
20:56:44:  <power v='full'/>
20:56:44:
20:56:44:  <!-- User Information -->
20:56:44:  <passkey v='*****'/>
20:56:44:  <team v='33'/>
20:56:44:  <user v='vastspace91'/>
20:56:44:
20:56:44:  <!-- Folding Slots -->
20:56:44:  <slot id='0' type='CPU'/>
20:56:44:  <slot id='1' type='GPU'/>
20:56:44:</config>
20:56:44:Trying to access database...
20:56:44:Successfully acquired database lock
20:56:44:Enabled folding slot 00: READY cpu:15
20:56:44:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
20:56:44:WU00:FS01:Starting
20:56:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:56:45:WU00:FS01:Started FahCore on PID 8548
20:56:47:WU00:FS01:Core PID:6624
20:56:47:WU00:FS01:FahCore 0x22 started
20:56:51:WU02:FS00:Starting
20:56:51:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -np 15
20:56:51:WU02:FS00:Started FahCore on PID 408
20:56:52:WU00:FS01:0x22:*********************** Log Started 2020-05-05T20:56:52Z ***********************
20:56:52:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:56:52:WU00:FS01:0x22:       Type: 0x22
20:56:52:WU00:FS01:0x22:       Core: Core22
20:56:52:WU00:FS01:0x22:    Website: https://foldingathome.org/
20:56:52:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
20:56:52:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:56:52:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
20:56:52:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8548 -checkpoint 15
20:56:53:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:56:53:WU00:FS01:0x22:     Config: <none>
20:56:53:WU00:FS01:0x22:************************************ Build *************************************
20:56:53:WU00:FS01:0x22:    Version: 0.0.5
20:56:53:WU00:FS01:0x22:       Date: Apr 22 2020
20:56:53:WU00:FS01:0x22:       Time: 04:42:59
20:56:53:WU00:FS01:0x22: Repository: Git
20:56:53:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
20:56:53:WU00:FS01:0x22:     Branch: HEAD
20:56:53:WU00:FS01:0x22:   Compiler: Visual C++ 2008
20:56:53:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:56:53:WU00:FS01:0x22:   Platform: win32 10
20:56:53:WU00:FS01:0x22:       Bits: 64
20:56:53:WU00:FS01:0x22:       Mode: Release
20:56:53:WU00:FS01:0x22:************************************ System ************************************
20:56:53:WU00:FS01:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
20:56:53:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
20:56:53:WU00:FS01:0x22:       CPUs: 16
20:56:53:WU00:FS01:0x22:     Memory: 15.96GiB
20:56:53:WU00:FS01:0x22:Free Memory: 13.83GiB
20:56:53:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
20:56:53:WU00:FS01:0x22: OS Version: 6.2
20:56:53:WU00:FS01:0x22:Has Battery: false
20:56:53:WU00:FS01:0x22: On Battery: false
20:56:53:WU00:FS01:0x22: UTC Offset: -4
20:56:53:WU00:FS01:0x22:        PID: 6624
20:56:53:WU00:FS01:0x22:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
20:56:53:WU00:FS01:0x22:         OS: Windows 10 Pro
20:56:53:WU00:FS01:0x22:    OS Arch: AMD64
20:56:53:WU00:FS01:0x22:********************************************************************************
20:56:53:WU00:FS01:0x22:Project: 16435 (Run 712, Clone 3, Gen 4)
20:56:53:WU00:FS01:0x22:Unit: 0x0000000603854c135e9a4efaefb1adb4
20:56:53:WU00:FS01:0x22:Digital signatures verified
20:56:53:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:56:53:WU00:FS01:0x22:Version 0.0.5
20:56:56:WU02:FS00:Core PID:4336
20:56:56:WU02:FS00:FahCore 0xa7 started
20:56:58:WU02:FS00:0xa7:*********************** Log Started 2020-05-05T20:56:58Z ***********************
20:56:58:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:56:58:WU02:FS00:0xa7:       Type: 0xa7
20:56:58:WU02:FS00:0xa7:       Core: Gromacs
20:56:58:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 408 -checkpoint 15 -np 15
20:56:58:WU02:FS00:0xa7:************************************ CBang *************************************
20:56:58:WU02:FS00:0xa7:       Date: Oct 26 2019
20:56:58:WU02:FS00:0xa7:       Time: 01:38:25
20:56:58:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:56:58:WU02:FS00:0xa7:     Branch: master
20:56:58:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:56:58:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:56:58:WU02:FS00:0xa7:   Platform: win32 10
20:56:58:WU02:FS00:0xa7:       Bits: 64
20:56:58:WU02:FS00:0xa7:       Mode: Release
20:56:58:WU02:FS00:0xa7:************************************ System ************************************
20:56:58:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
20:56:58:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
20:56:58:WU02:FS00:0xa7:       CPUs: 16
20:56:58:WU02:FS00:0xa7:     Memory: 15.96GiB
20:56:58:WU02:FS00:0xa7:Free Memory: 13.31GiB
20:56:58:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:56:58:WU02:FS00:0xa7: OS Version: 6.2
20:56:58:WU02:FS00:0xa7:Has Battery: false
20:56:58:WU02:FS00:0xa7: On Battery: false
20:56:58:WU02:FS00:0xa7: UTC Offset: -4
20:56:58:WU02:FS00:0xa7:        PID: 4336
20:56:58:WU02:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
20:56:58:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:56:58:WU02:FS00:0xa7:    Version: 0.0.18
20:56:58:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:56:58:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:56:58:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:56:58:WU02:FS00:0xa7:       Time: 01:52:30
20:56:58:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:56:58:WU02:FS00:0xa7:************************************ Build *************************************
20:56:58:WU02:FS00:0xa7:       SIMD: avx_256
20:56:58:WU02:FS00:0xa7:********************************************************************************
20:56:58:WU02:FS00:0xa7:Project: 16803 (Run 10, Clone 661, Gen 14)
20:56:58:WU02:FS00:0xa7:Unit: 0x0000001282ed0b915e99f8d84e15ae3b
20:56:58:WU02:FS00:0xa7:Digital signatures verified
20:56:58:WU02:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 15 -nt 15
20:57:04:WU00:FS01:0x22:  Found a checkpoint file
20:57:11:WU02:FS00:0xa7:Steps: first=7000000 total=500000
20:57:15:WU02:FS00:0xa7:Completed 17801 out of 500000 steps (3%)
20:57:21:WU00:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
20:57:21:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:59:01:WU02:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
21:02:46:WU00:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
21:02:50:WU02:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
21:07:12:WU02:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
21:08:00:WU00:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
21:11:22:WU02:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
21:13:31:WU00:FS01:0x22:Completed 700000 out of 5000000 steps (14%)
21:15:19:WU02:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
21:18:10:WU00:FS01:0x22:Completed 750000 out of 5000000 steps (15%)
21:19:13:WU02:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
21:22:53:WU00:FS01:0x22:Completed 800000 out of 5000000 steps (16%)
21:23:11:WU02:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
21:27:09:WU02:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
21:27:35:WU00:FS01:0x22:Completed 850000 out of 5000000 steps (17%)
21:31:05:WU02:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
21:32:08:WU00:FS01:0x22:Completed 900000 out of 5000000 steps (18%)
21:35:04:WU02:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
21:37:04:WU00:FS01:0x22:Completed 950000 out of 5000000 steps (19%)
21:39:06:WU02:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
21:41:58:WU00:FS01:0x22:Completed 1000000 out of 5000000 steps (20%)
21:43:01:WU02:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
21:47:36:WU02:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
21:48:38:WU00:FS01:0x22:Completed 1050000 out of 5000000 steps (21%)
21:51:38:WU02:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
21:53:43:WU00:FS01:0x22:Completed 1100000 out of 5000000 steps (22%)
21:55:34:WU02:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
21:59:11:WU00:FS01:0x22:Completed 1150000 out of 5000000 steps (23%)
21:59:36:WU02:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
22:03:30:WU02:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
22:04:02:WU00:FS01:0x22:Completed 1200000 out of 5000000 steps (24%)
22:07:29:WU02:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
22:09:20:WU00:FS01:0x22:Completed 1250000 out of 5000000 steps (25%)
22:11:30:WU02:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
22:14:04:WU00:FS01:0x22:Completed 1300000 out of 5000000 steps (26%)
22:15:25:WU02:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
22:19:23:WU02:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
22:19:23:WU00:FS01:0x22:Completed 1350000 out of 5000000 steps (27%)
22:23:16:WU02:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
22:24:02:WU00:FS01:0x22:Completed 1400000 out of 5000000 steps (28%)
22:27:10:WU02:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
22:28:35:WU00:FS01:0x22:Completed 1450000 out of 5000000 steps (29%)
22:31:05:WU02:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
22:33:04:WU00:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
22:35:00:WU02:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
22:37:41:WU00:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
22:38:55:WU02:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
22:42:11:WU00:FS01:0x22:Completed 1600000 out of 5000000 steps (32%)
22:42:50:WU02:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
22:46:42:WU00:FS01:0x22:Completed 1650000 out of 5000000 steps (33%)
22:46:46:WU02:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
22:50:41:WU02:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
22:51:14:WU00:FS01:0x22:Completed 1700000 out of 5000000 steps (34%)
22:54:37:WU02:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
22:55:45:WU00:FS01:0x22:Completed 1750000 out of 5000000 steps (35%)
22:58:34:WU02:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
23:00:19:WU00:FS01:0x22:Completed 1800000 out of 5000000 steps (36%)
23:02:30:WU02:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
23:04:50:WU00:FS01:0x22:Completed 1850000 out of 5000000 steps (37%)
23:06:25:WU02:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
23:09:21:WU00:FS01:0x22:Completed 1900000 out of 5000000 steps (38%)
23:10:22:WU02:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
23:14:02:WU00:FS01:0x22:Completed 1950000 out of 5000000 steps (39%)
23:14:19:WU02:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
23:18:15:WU02:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
23:18:39:WU00:FS01:0x22:Completed 2000000 out of 5000000 steps (40%)
23:22:11:WU02:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
23:23:16:WU00:FS01:0x22:Completed 2050000 out of 5000000 steps (41%)
23:26:07:WU02:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
23:27:57:WU00:FS01:0x22:Completed 2100000 out of 5000000 steps (42%)
23:30:03:WU02:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
23:32:31:WU00:FS01:0x22:Completed 2150000 out of 5000000 steps (43%)
23:33:58:WU02:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
23:37:08:WU00:FS01:0x22:Completed 2200000 out of 5000000 steps (44%)
23:37:55:WU02:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
23:41:42:WU00:FS01:0x22:Completed 2250000 out of 5000000 steps (45%)
23:41:50:WU02:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
23:45:46:WU02:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
23:46:21:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
23:49:45:WU02:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
23:51:03:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
23:53:44:WU02:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
23:55:46:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
23:57:45:WU02:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
00:00:27:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
00:01:44:WU02:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
00:05:04:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
00:05:43:WU02:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
00:09:41:WU02:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
00:09:43:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
00:13:38:WU02:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
00:14:16:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
00:17:36:WU02:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
00:19:01:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
00:21:34:WU02:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
00:23:35:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
00:25:30:WU02:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
00:28:09:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
00:29:26:WU02:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
00:32:40:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
00:33:21:WU02:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
00:37:13:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
00:37:18:WU02:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
00:41:13:WU02:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
00:41:46:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
00:45:10:WU02:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
00:46:21:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
00:49:08:WU02:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
00:50:55:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
00:51:58:WU02:FS00:Starting
00:51:58:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -np 15
00:51:58:WU02:FS00:Started FahCore on PID 9192
00:51:58:WU02:FS00:Core PID:2368
00:51:58:WU02:FS00:FahCore 0xa7 started
00:51:59:WU02:FS00:0xa7:*********************** Log Started 2020-05-06T00:51:58Z ***********************
00:51:59:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:51:59:WU02:FS00:0xa7:       Type: 0xa7
00:51:59:WU02:FS00:0xa7:       Core: Gromacs
00:51:59:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9192 -checkpoint 15 -np
00:51:59:WU02:FS00:0xa7:             15
00:51:59:WU02:FS00:0xa7:************************************ CBang *************************************
00:51:59:WU02:FS00:0xa7:       Date: Oct 26 2019
00:51:59:WU02:FS00:0xa7:       Time: 01:38:25
00:51:59:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:51:59:WU02:FS00:0xa7:     Branch: master
00:51:59:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:51:59:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:51:59:WU02:FS00:0xa7:   Platform: win32 10
00:51:59:WU02:FS00:0xa7:       Bits: 64
00:51:59:WU02:FS00:0xa7:       Mode: Release
00:51:59:WU02:FS00:0xa7:************************************ System ************************************
00:51:59:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
00:51:59:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
00:51:59:WU02:FS00:0xa7:       CPUs: 16
00:51:59:WU02:FS00:0xa7:     Memory: 15.96GiB
00:51:59:WU02:FS00:0xa7:Free Memory: 13.27GiB
00:51:59:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:51:59:WU02:FS00:0xa7: OS Version: 6.2
00:51:59:WU02:FS00:0xa7:Has Battery: false
00:51:59:WU02:FS00:0xa7: On Battery: false
00:51:59:WU02:FS00:0xa7: UTC Offset: -4
00:51:59:WU02:FS00:0xa7:        PID: 2368
00:51:59:WU02:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
00:51:59:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:51:59:WU02:FS00:0xa7:    Version: 0.0.18
00:51:59:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:51:59:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:51:59:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:51:59:WU02:FS00:0xa7:       Time: 01:52:30
00:51:59:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:51:59:WU02:FS00:0xa7:************************************ Build *************************************
00:51:59:WU02:FS00:0xa7:       SIMD: avx_256
00:51:59:WU02:FS00:0xa7:********************************************************************************
00:51:59:WU02:FS00:0xa7:Project: 16803 (Run 10, Clone 661, Gen 14)
00:51:59:WU02:FS00:0xa7:Unit: 0x0000001282ed0b915e99f8d84e15ae3b
00:51:59:WU02:FS00:0xa7:Digital signatures verified
00:51:59:WU02:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 15 -nt 15
00:51:59:WU02:FS00:0xa7:Steps: first=7000000 total=500000
00:52:01:WU02:FS00:0xa7:Completed 301301 out of 500000 steps (60%)
00:54:57:WU02:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
00:55:32:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
00:58:55:WU02:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
01:00:07:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
01:02:51:WU02:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
01:04:38:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
01:06:48:WU02:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
01:09:15:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
01:10:45:WU02:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
01:13:47:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
01:14:41:WU02:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
01:18:21:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
01:18:38:WU02:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
01:21:20:WU02:FS00:Starting
01:21:20:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -np 15
01:21:20:WU02:FS00:Started FahCore on PID 3884
01:21:20:WU02:FS00:Core PID:6276
01:21:20:WU02:FS00:FahCore 0xa7 started
01:21:20:WU02:FS00:0xa7:*********************** Log Started 2020-05-06T01:21:20Z ***********************
01:21:20:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:21:20:WU02:FS00:0xa7:       Type: 0xa7
01:21:20:WU02:FS00:0xa7:       Core: Gromacs
01:21:20:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3884 -checkpoint 15 -np
01:21:20:WU02:FS00:0xa7:             15
01:21:20:WU02:FS00:0xa7:************************************ CBang *************************************
01:21:20:WU02:FS00:0xa7:       Date: Oct 26 2019
01:21:20:WU02:FS00:0xa7:       Time: 01:38:25
01:21:20:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:21:20:WU02:FS00:0xa7:     Branch: master
01:21:20:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
01:21:20:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:21:20:WU02:FS00:0xa7:   Platform: win32 10
01:21:20:WU02:FS00:0xa7:       Bits: 64
01:21:20:WU02:FS00:0xa7:       Mode: Release
01:21:20:WU02:FS00:0xa7:************************************ System ************************************
01:21:20:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
01:21:20:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
01:21:20:WU02:FS00:0xa7:       CPUs: 16
01:21:20:WU02:FS00:0xa7:     Memory: 15.96GiB
01:21:20:WU02:FS00:0xa7:Free Memory: 13.28GiB
01:21:20:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
01:21:20:WU02:FS00:0xa7: OS Version: 6.2
01:21:20:WU02:FS00:0xa7:Has Battery: false
01:21:20:WU02:FS00:0xa7: On Battery: false
01:21:20:WU02:FS00:0xa7: UTC Offset: -4
01:21:20:WU02:FS00:0xa7:        PID: 6276
01:21:20:WU02:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
01:21:20:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
01:21:20:WU02:FS00:0xa7:    Version: 0.0.18
01:21:20:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:21:20:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:21:20:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
01:21:20:WU02:FS00:0xa7:       Time: 01:52:30
01:21:20:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:21:20:WU02:FS00:0xa7:************************************ Build *************************************
01:21:20:WU02:FS00:0xa7:       SIMD: avx_256
01:21:20:WU02:FS00:0xa7:********************************************************************************
01:21:20:WU02:FS00:0xa7:Project: 16803 (Run 10, Clone 661, Gen 14)
01:21:20:WU02:FS00:0xa7:Unit: 0x0000001282ed0b915e99f8d84e15ae3b
01:21:20:WU02:FS00:0xa7:Digital signatures verified
01:21:20:WU02:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 15 -nt 15
01:21:20:WU02:FS00:0xa7:Steps: first=7000000 total=500000
01:21:23:WU02:FS00:0xa7:Completed 320301 out of 500000 steps (64%)
01:23:03:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
01:25:05:WU02:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
01:27:36:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
01:29:00:WU02:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
01:32:07:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
01:32:55:WU02:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
01:36:39:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
01:36:52:WU02:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
01:40:47:WU02:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
01:41:11:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
01:44:43:WU02:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
01:45:42:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
01:48:39:WU02:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
01:50:14:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
01:52:35:WU02:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
01:54:45:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
01:56:30:WU02:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
01:59:24:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
02:00:27:WU02:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
02:03:54:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
02:04:22:WU02:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
02:08:17:WU02:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
02:08:27:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
02:12:12:WU02:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
02:13:00:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
02:16:07:WU02:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
02:17:33:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
02:20:03:WU02:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
02:22:04:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
02:23:59:WU02:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
02:26:36:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
02:27:54:WU02:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
02:31:10:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
02:31:48:WU02:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
02:35:41:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
02:35:41:WU02:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
02:39:36:WU02:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
02:40:14:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
02:43:29:WU02:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
02:44:45:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
02:47:22:WU02:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
02:49:21:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
02:51:16:WU02:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
02:53:54:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
02:55:11:WU02:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
02:58:28:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
02:59:06:WU02:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
03:03:01:WU02:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
03:03:03:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
03:06:58:WU02:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
03:07:40:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
03:08:04:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:16803 run:10 clone:661 gen:14 core:0xa7 unit:0x0000001282ed0b915e99f8d84e15ae3b
03:08:04:WU02:FS00:Connecting to 130.237.11.145:8080
03:08:05:WU01:FS00:Connecting to 65.254.110.245:80
03:08:05:WU02:FS00:Server responded WORK_ACK (400)
03:08:06:WU02:FS00:Cleaning up
03:08:07:WU01:FS00:Assigned to work server 40.114.52.201
03:08:07:WU01:FS00:Requesting new work unit for slot 00: READY cpu:15 from 40.114.52.201
03:08:07:WU01:FS00:Connecting to 40.114.52.201:8080
03:08:09:WU01:FS00:Downloading 1.21MiB
03:08:12:WU01:FS00:Download complete
03:08:12:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14574 run:0 clone:1452 gen:117 core:0xa7 unit:0x00000091287234c95e79250a96f5824b
03:08:12:WU01:FS00:Starting
03:08:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -np 14
03:08:12:WU01:FS00:Started FahCore on PID 7588
03:08:12:WU01:FS00:Core PID:9320
03:08:12:WU01:FS00:FahCore 0xa7 started
03:08:12:WU01:FS00:0xa7:*********************** Log Started 2020-05-06T03:08:12Z ***********************
03:08:12:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:08:12:WU01:FS00:0xa7:       Type: 0xa7
03:08:12:WU01:FS00:0xa7:       Core: Gromacs
03:08:12:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7588 -checkpoint 15 -np
03:08:12:WU01:FS00:0xa7:             14
03:08:12:WU01:FS00:0xa7:************************************ CBang *************************************
03:08:12:WU01:FS00:0xa7:       Date: Oct 26 2019
03:08:12:WU01:FS00:0xa7:       Time: 01:38:25
03:08:12:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:08:12:WU01:FS00:0xa7:     Branch: master
03:08:12:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:08:12:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:08:12:WU01:FS00:0xa7:   Platform: win32 10
03:08:12:WU01:FS00:0xa7:       Bits: 64
03:08:12:WU01:FS00:0xa7:       Mode: Release
03:08:12:WU01:FS00:0xa7:************************************ System ************************************
03:08:12:WU01:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
03:08:12:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
03:08:12:WU01:FS00:0xa7:       CPUs: 16
03:08:12:WU01:FS00:0xa7:     Memory: 15.96GiB
03:08:12:WU01:FS00:0xa7:Free Memory: 13.30GiB
03:08:12:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:08:12:WU01:FS00:0xa7: OS Version: 6.2
03:08:12:WU01:FS00:0xa7:Has Battery: false
03:08:12:WU01:FS00:0xa7: On Battery: false
03:08:12:WU01:FS00:0xa7: UTC Offset: -4
03:08:12:WU01:FS00:0xa7:        PID: 9320
03:08:12:WU01:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
03:08:12:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:08:12:WU01:FS00:0xa7:    Version: 0.0.18
03:08:12:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:08:12:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:08:12:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:08:12:WU01:FS00:0xa7:       Time: 01:52:30
03:08:12:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:08:12:WU01:FS00:0xa7:************************************ Build *************************************
03:08:12:WU01:FS00:0xa7:       SIMD: avx_256
03:08:12:WU01:FS00:0xa7:********************************************************************************
03:08:12:WU01:FS00:0xa7:Project: 14574 (Run 0, Clone 1452, Gen 117)
03:08:12:WU01:FS00:0xa7:Unit: 0x00000091287234c95e79250a96f5824b
03:08:12:WU01:FS00:0xa7:Reading tar file core.xml
03:08:12:WU01:FS00:0xa7:Reading tar file frame117.tpr
03:08:12:WU01:FS00:0xa7:Digital signatures verified
03:08:12:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
03:08:12:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
03:08:12:WU01:FS00:0xa7:Calling: mdrun -s frame117.tpr -o frame117.trr -x frame117.xtc -cpt 15 -nt 12
03:08:12:WU01:FS00:0xa7:Steps: first=58500000 total=500000
03:08:13:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
03:09:03:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
03:09:54:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
03:10:45:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
03:11:36:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
03:11:57:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
03:12:27:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
03:13:17:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
03:14:08:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
03:14:59:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
03:15:50:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
03:16:14:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
03:16:41:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
03:17:32:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
03:18:22:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
03:19:13:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
03:20:04:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
03:20:31:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
03:20:54:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
03:21:43:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
03:22:32:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
03:23:21:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
03:24:10:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
03:24:52:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
03:25:00:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
03:25:49:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
03:26:38:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
03:27:28:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
03:28:17:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
03:29:06:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
03:29:11:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
03:29:55:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
03:30:43:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
03:31:33:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
03:32:22:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
03:33:11:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
03:33:31:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
03:34:01:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
03:34:51:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
03:35:41:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
03:36:31:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
03:37:21:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
03:37:50:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
03:38:11:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
03:38:59:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
03:39:48:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
03:40:36:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
03:41:24:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
03:42:11:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
03:42:13:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
03:43:04:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
03:43:54:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
03:44:44:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
03:45:34:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
03:46:25:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
03:46:30:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
03:46:31:WU02:FS01:Connecting to 65.254.110.245:80
03:46:33:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:46:33:WU02:FS01:Connecting to 18.218.241.186:80
03:46:34:WU02:FS01:Assigned to work server 140.163.4.241
03:46:34:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
03:46:34:WU02:FS01:Connecting to 140.163.4.241:8080
03:47:15:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
03:47:37:WU02:FS01:Downloading 4.52MiB
03:47:43:WU02:FS01:Download 47.06%
03:47:48:WU02:FS01:Download complete
03:47:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:4501 gen:84 core:0x22 unit:0x0000007a8ca304f15e69ded61deccc4b
03:48:06:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
03:48:57:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
03:49:47:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
03:50:38:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
03:50:47:WU00:FS01:0x22:Completed 5000000 out of 5000000 steps (100%)
03:50:50:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
03:50:50:WU00:FS01:0x22:Saving result file checkpointState.xml
03:50:50:WU00:FS01:0x22:Saving result file checkpt.crc
03:50:50:WU00:FS01:0x22:Saving result file positions.xtc
03:50:51:WU00:FS01:0x22:Saving result file science.log
03:50:51:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:50:52:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:50:52:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16435 run:712 clone:3 gen:4 core:0x22 unit:0x0000000603854c135e9a4efaefb1adb4
03:50:52:WU00:FS01:Uploading 126.66MiB to 3.133.76.19
03:50:52:WU02:FS01:Starting
03:50:52:WU00:FS01:Connecting to 3.133.76.19:8080
03:50:52:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:50:52:WU02:FS01:Started FahCore on PID 2520
03:50:52:WU02:FS01:Core PID:5224
03:50:52:WU02:FS01:FahCore 0x22 started
03:50:52:WU02:FS01:0x22:*********************** Log Started 2020-05-06T03:50:52Z ***********************
03:50:52:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:50:52:WU02:FS01:0x22:       Type: 0x22
03:50:52:WU02:FS01:0x22:       Core: Core22
03:50:52:WU02:FS01:0x22:    Website: https://foldingathome.org/
03:50:52:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:50:52:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:50:52:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:50:52:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2520 -checkpoint 15
03:50:52:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:50:52:WU02:FS01:0x22:     Config: <none>
03:50:52:WU02:FS01:0x22:************************************ Build *************************************
03:50:52:WU02:FS01:0x22:    Version: 0.0.5
03:50:52:WU02:FS01:0x22:       Date: Apr 22 2020
03:50:52:WU02:FS01:0x22:       Time: 04:42:59
03:50:52:WU02:FS01:0x22: Repository: Git
03:50:52:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
03:50:52:WU02:FS01:0x22:     Branch: HEAD
03:50:52:WU02:FS01:0x22:   Compiler: Visual C++ 2008
03:50:52:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:50:52:WU02:FS01:0x22:   Platform: win32 10
03:50:52:WU02:FS01:0x22:       Bits: 64
03:50:52:WU02:FS01:0x22:       Mode: Release
03:50:52:WU02:FS01:0x22:************************************ System ************************************
03:50:52:WU02:FS01:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
03:50:52:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
03:50:52:WU02:FS01:0x22:       CPUs: 16
03:50:52:WU02:FS01:0x22:     Memory: 15.96GiB
03:50:52:WU02:FS01:0x22:Free Memory: 13.25GiB
03:50:52:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
03:50:52:WU02:FS01:0x22: OS Version: 6.2
03:50:52:WU02:FS01:0x22:Has Battery: false
03:50:52:WU02:FS01:0x22: On Battery: false
03:50:52:WU02:FS01:0x22: UTC Offset: -4
03:50:52:WU02:FS01:0x22:        PID: 5224
03:50:52:WU02:FS01:0x22:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
03:50:52:WU02:FS01:0x22:         OS: Windows 10 Pro
03:50:52:WU02:FS01:0x22:    OS Arch: AMD64
03:50:52:WU02:FS01:0x22:********************************************************************************
03:50:52:WU02:FS01:0x22:Project: 11743 (Run 0, Clone 4501, Gen 84)
03:50:52:WU02:FS01:0x22:Unit: 0x0000007a8ca304f15e69ded61deccc4b
03:50:52:WU02:FS01:0x22:Reading tar file core.xml
03:50:52:WU02:FS01:0x22:Reading tar file integrator.xml
03:50:52:WU02:FS01:0x22:Reading tar file state.xml
03:50:53:WU02:FS01:0x22:Reading tar file system.xml
03:50:53:WU02:FS01:0x22:Digital signatures verified
03:50:53:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:50:53:WU02:FS01:0x22:Version 0.0.5
03:51:01:WU00:FS01:Upload 0.10%
03:51:06:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
03:51:06:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:51:29:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
03:51:57:WU00:FS01:Upload 0.15%
03:52:03:WU00:FS01:Upload 0.74%
03:52:09:WU00:FS01:Upload 1.33%
03:52:15:WU00:FS01:Upload 1.88%
03:52:19:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
03:52:21:WU00:FS01:Upload 2.47%
03:52:27:WU00:FS01:Upload 3.06%
03:52:33:WU00:FS01:Upload 3.65%
03:52:39:WU00:FS01:Upload 4.24%
03:52:45:WU00:FS01:Upload 4.84%
03:52:51:WU00:FS01:Upload 5.43%
03:52:57:WU00:FS01:Upload 6.02%
03:53:03:WU00:FS01:Upload 6.56%
03:53:09:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
03:53:09:WU00:FS01:Upload 7.16%
03:53:10:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
03:53:15:WU00:FS01:Upload 7.75%
03:53:22:WU00:FS01:Upload 8.34%
03:53:28:WU00:FS01:Upload 8.64%
03:53:34:WU00:FS01:Upload 9.13%
03:53:40:WU00:FS01:Upload 9.67%
03:53:46:WU00:FS01:Upload 10.26%
03:53:52:WU00:FS01:Upload 10.86%
03:53:58:WU00:FS01:Upload 11.45%
03:54:01:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
03:54:04:WU00:FS01:Upload 11.99%
03:54:10:WU00:FS01:Upload 12.63%
03:54:16:WU00:FS01:Upload 13.22%
03:54:22:WU00:FS01:Upload 13.77%
03:54:28:WU00:FS01:Upload 14.36%
03:54:34:WU00:FS01:Upload 14.90%
03:54:40:WU00:FS01:Upload 15.49%
03:54:46:WU00:FS01:Upload 16.09%
03:54:51:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
03:54:52:WU00:FS01:Upload 16.68%
03:54:58:WU00:FS01:Upload 17.27%
03:55:04:WU00:FS01:Upload 17.81%
03:55:10:WU00:FS01:Upload 18.41%
03:55:10:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
03:55:16:WU00:FS01:Upload 19.00%
03:55:22:WU00:FS01:Upload 19.59%
03:55:28:WU00:FS01:Upload 20.13%
03:55:34:WU00:FS01:Upload 20.73%
03:55:40:WU00:FS01:Upload 21.32%
03:55:42:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
03:55:46:WU00:FS01:Upload 21.91%
03:55:52:WU00:FS01:Upload 22.50%
03:55:58:WU00:FS01:Upload 23.04%
03:56:04:WU00:FS01:Upload 23.69%
03:56:10:WU00:FS01:Upload 24.23%
03:56:16:WU00:FS01:Upload 24.82%
03:56:22:WU00:FS01:Upload 25.36%
03:56:28:WU00:FS01:Upload 25.96%
03:56:33:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
03:56:34:WU00:FS01:Upload 26.55%
03:56:40:WU00:FS01:Upload 27.14%
03:56:46:WU00:FS01:Upload 27.73%
03:56:52:WU00:FS01:Upload 28.28%
03:56:58:WU00:FS01:Upload 28.87%
03:57:04:WU00:FS01:Upload 29.46%
03:57:10:WU00:FS01:Upload 30.00%
03:57:14:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
03:57:16:WU00:FS01:Upload 30.55%
03:57:22:WU00:FS01:Upload 31.14%
03:57:24:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
03:57:28:WU00:FS01:Upload 31.73%
03:57:34:WU00:FS01:Upload 32.32%
03:57:40:WU00:FS01:Upload 32.96%
03:57:46:WU00:FS01:Upload 33.51%
03:57:52:WU00:FS01:Upload 34.05%
03:57:58:WU00:FS01:Upload 34.64%
03:58:04:WU00:FS01:Upload 35.23%
03:58:10:WU00:FS01:Upload 35.78%
03:58:15:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
03:58:16:WU00:FS01:Upload 36.37%
03:58:22:WU00:FS01:Upload 36.96%
03:58:28:WU00:FS01:Upload 37.55%
03:58:34:WU00:FS01:Upload 38.19%
03:58:40:WU00:FS01:Upload 38.74%
03:58:46:WU00:FS01:Upload 39.38%
03:58:52:WU00:FS01:Upload 39.92%
03:58:58:WU00:FS01:Upload 40.51%
03:59:04:WU00:FS01:Upload 41.06%
03:59:06:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
03:59:10:WU00:FS01:Upload 41.60%
03:59:16:WU00:FS01:Upload 42.24%
03:59:16:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
03:59:22:WU00:FS01:Upload 42.83%
03:59:28:WU00:FS01:Upload 43.38%
03:59:34:WU00:FS01:Upload 43.97%
03:59:40:WU00:FS01:Upload 44.56%
03:59:46:WU00:FS01:Upload 45.15%
03:59:52:WU00:FS01:Upload 45.74%
03:59:56:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
03:59:58:WU00:FS01:Upload 46.29%
04:00:04:WU00:FS01:Upload 46.73%
04:00:10:WU00:FS01:Upload 47.08%
04:00:16:WU00:FS01:Upload 47.67%
04:00:22:WU00:FS01:Upload 48.26%
04:00:28:WU00:FS01:Upload 48.80%
04:00:34:WU00:FS01:Upload 49.40%
04:00:40:WU00:FS01:Upload 49.99%
04:00:46:WU00:FS01:Upload 50.58%
04:00:47:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
04:00:52:WU00:FS01:Upload 51.17%
04:00:58:WU00:FS01:Upload 51.71%
04:01:04:WU00:FS01:Upload 52.36%
04:01:10:WU00:FS01:Upload 53.00%
04:01:16:WU00:FS01:Upload 53.59%
04:01:18:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
04:01:24:WU00:FS01:Upload 54.13%
04:01:30:WU00:FS01:Upload 54.72%
04:01:36:WU00:FS01:Upload 55.37%
04:01:36:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
04:01:42:WU00:FS01:Upload 56.06%
04:01:48:WU00:FS01:Upload 56.80%
04:01:54:WU00:FS01:Upload 57.49%
04:02:00:WU00:FS01:Upload 58.03%
04:02:06:WU00:FS01:Upload 58.72%
04:02:12:WU00:FS01:Upload 59.46%
04:02:18:WU00:FS01:Upload 60.20%
04:02:24:WU00:FS01:Upload 60.89%
04:02:26:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
04:02:30:WU00:FS01:Upload 61.63%
04:02:36:WU00:FS01:Upload 62.37%
04:02:42:WU00:FS01:Upload 63.06%
04:02:48:WU00:FS01:Upload 63.76%
04:02:54:WU00:FS01:Upload 64.50%
04:03:00:WU00:FS01:Upload 65.24%
04:03:06:WU00:FS01:Upload 65.98%
04:03:12:WU00:FS01:Upload 66.52%
04:03:15:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
04:03:18:WU00:FS01:Upload 67.11%
04:03:24:WU00:FS01:Upload 67.75%
04:03:24:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
04:03:30:WU00:FS01:Upload 68.44%
04:03:36:WU00:FS01:Upload 69.08%
04:03:42:WU00:FS01:Upload 69.78%
04:03:48:WU00:FS01:Upload 70.52%
04:03:54:WU00:FS01:Upload 71.21%
04:04:00:WU00:FS01:Upload 71.90%
04:04:05:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
04:04:06:WU00:FS01:Upload 72.59%
04:04:12:WU00:FS01:Upload 73.28%
04:04:18:WU00:FS01:Upload 73.97%
04:04:24:WU00:FS01:Upload 74.66%
04:04:30:WU00:FS01:Upload 75.40%
04:04:36:WU00:FS01:Upload 76.09%
04:04:42:WU00:FS01:Upload 76.78%
04:04:48:WU00:FS01:Upload 77.47%
04:04:54:WU00:FS01:Upload 78.16%
04:04:55:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
04:05:00:WU00:FS01:Upload 78.86%
04:05:06:WU00:FS01:Upload 79.55%
04:05:12:WU00:FS01:Upload 80.24%
04:05:18:WU00:FS01:Upload 80.93%
04:05:24:WU00:FS01:Upload 81.62%
04:05:27:WU02:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
04:05:30:WU00:FS01:Upload 82.36%
04:05:36:WU00:FS01:Upload 83.05%
04:05:42:WU00:FS01:Upload 83.74%
04:05:45:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
04:05:48:WU00:FS01:Upload 84.28%
04:05:54:WU00:FS01:Upload 84.92%
04:06:00:WU00:FS01:Upload 85.57%
04:06:06:WU00:FS01:Upload 86.16%
04:06:12:WU00:FS01:Upload 86.75%
04:06:18:WU00:FS01:Upload 87.29%
04:06:24:WU00:FS01:Upload 87.89%
04:06:30:WU00:FS01:Upload 88.48%
04:06:36:WU00:FS01:Upload 89.07%
04:06:36:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
04:06:42:WU00:FS01:Upload 89.66%
04:06:48:WU00:FS01:Upload 90.25%
04:06:54:WU00:FS01:Upload 90.80%
04:07:00:WU00:FS01:Upload 91.39%
04:07:06:WU00:FS01:Upload 91.98%
04:07:12:WU00:FS01:Upload 92.57%
04:07:18:WU00:FS01:Upload 93.17%
04:07:24:WU00:FS01:Upload 93.76%
04:07:26:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
04:07:30:WU00:FS01:Upload 94.35%
04:07:31:WU02:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
04:07:36:WU00:FS01:Upload 94.94%
04:07:42:WU00:FS01:Upload 95.48%
04:07:48:WU00:FS01:Upload 96.13%
04:07:54:WU00:FS01:Upload 96.67%
04:08:00:WU00:FS01:Upload 97.21%
04:08:06:WU00:FS01:Upload 97.80%
04:08:12:WU00:FS01:Upload 98.45%
04:08:15:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
04:08:18:WU00:FS01:Upload 98.99%
04:08:24:WU00:FS01:Upload 99.58%
04:08:29:WU00:FS01:Upload complete
04:08:29:WU00:FS01:Server responded WORK_ACK (400)
04:08:29:WU00:FS01:Final credit estimate, 109657.00 points
04:08:29:WU00:FS01:Cleaning up
04:09:05:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
04:09:17:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
04:09:17:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
04:09:17:WARNING:WU02:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
04:09:17:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
04:09:17:WU01:FS00:Starting
04:09:17:WARNING:WU01:FS00:AS lowered CPUs from 15 to 14
04:09:17:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -np 14
04:09:17:WU01:FS00:Started FahCore on PID 7064
04:09:17:WU01:FS00:FahCore 0xa7 started
04:09:18:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
04:09:18:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
04:09:18:WU02:FS01:Starting
04:09:18:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8284 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
04:09:18:WU02:FS01:Started FahCore on PID 5632
04:09:18:WU02:FS01:FahCore 0x22 started
04:09:18:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
04:09:18:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
JuWaJo
Post by JuWaJo »
*********************** Log Started 2020-05-06T16:43:13Z ***********************
16:43:13:****************************** FAHClient ******************************
16:43:13:        Version: 7.6.9
16:43:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:43:13:      Copyright: 2020 foldingathome.org
16:43:13:       Homepage: https://foldingathome.org/
16:43:13:           Date: Apr 17 2020
16:43:13:           Time: 11:13:06
16:43:13:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
16:43:13:         Branch: master
16:43:13:       Compiler: Visual C++ 2008
16:43:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:43:13:       Platform: win32 10
16:43:13:           Bits: 32
16:43:13:           Mode: Release
16:43:13:           Args: --open-web-control
16:43:13:         Config: C:\Users\Justin\AppData\Roaming\FAHClient\config.xml
16:43:13:******************************** CBang ********************************
16:43:13:           Time: 11:10:09
16:43:13:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
16:43:13:           Bits: 32
16:43:13:******************************* System ********************************
16:43:13:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:43:13:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:43:13:           CPUs: 16
16:43:13:         Memory: 15.96GiB
16:43:13:    Free Memory: 13.80GiB
16:43:13:        Threads: WINDOWS_THREADS
16:43:13:     OS Version: 6.2
16:43:13:    Has Battery: false
16:43:13:     On Battery: false
16:43:13:     UTC Offset: -4
16:43:13:            PID: 8804
16:43:13:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
16:43:13:             OS: Windows 10 Enterprise
16:43:13:        OS Arch: AMD64
16:43:13:           GPUs: 1
16:43:13:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
16:43:13:                 470/480/570/580/590]
16:43:13:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
16:43:13:                 specified module could not be found.
16:43:13:
16:43:13:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:2841.19
16:43:13:  Win32 Service: false
16:43:13:******************************* libFAH ********************************
16:43:13:           Date: Apr 15 2020
16:43:13:           Time: 14:53:14
16:43:13:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:43:13:           Bits: 32
16:43:13:***********************************************************************
16:43:13:<config>
16:43:13:  <!-- Folding Core -->
16:43:13:  <core-priority v='low'/>
16:43:13:
16:43:13:  <!-- Folding Slot Configuration -->
16:43:13:  <cause v='COVID_19'/>
16:43:13:
16:43:13:  <!-- Network -->
16:43:13:  <proxy v=':8080'/>
16:43:13:
16:43:13:  <!-- Remote Command Server -->
16:43:13:  <password v='*****'/>
16:43:13:
16:43:13:  <!-- Slot Control -->
16:43:13:  <pause-on-battery v='false'/>
16:43:13:  <power v='full'/>
16:43:13:
16:43:13:  <!-- User Information -->
16:43:13:  <passkey v='*****'/>
16:43:13:  <team v='33'/>
16:43:13:  <user v='vastspace91'/>
16:43:13:
16:43:13:  <!-- Folding Slots -->
16:43:13:  <slot id='0' type='CPU'/>
16:43:13:  <slot id='1' type='GPU'/>
16:43:13:</config>
16:43:13:Trying to access database...
16:43:13:Successfully acquired database lock
16:43:13:Enabled folding slot 00: READY cpu:15
16:43:13:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
16:43:13:WU02:FS01:Starting
16:43:13:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:43:13:WU02:FS01:Started FahCore on PID 1968
16:43:15:WU02:FS01:Core PID:2952
16:43:15:WU02:FS01:FahCore 0x22 started
16:43:17:WU00:FS00:Starting
16:43:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:43:17:WU00:FS00:Started FahCore on PID 7976
16:43:17:WU02:FS01:0x22:*********************** Log Started 2020-05-06T16:43:17Z ***********************
16:43:17:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:43:17:WU02:FS01:0x22:       Type: 0x22
16:43:17:WU02:FS01:0x22:       Core: Core22
16:43:17:WU02:FS01:0x22:    Website: https://foldingathome.org/
16:43:17:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:43:17:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:43:17:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:43:17:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 1968 -checkpoint 15
16:43:17:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:43:17:WU02:FS01:0x22:     Config: <none>
16:43:17:WU02:FS01:0x22:************************************ Build *************************************
16:43:17:WU02:FS01:0x22:    Version: 0.0.5
16:43:17:WU02:FS01:0x22:       Date: Apr 22 2020
16:43:17:WU02:FS01:0x22:       Time: 04:42:59
16:43:17:WU02:FS01:0x22: Repository: Git
16:43:17:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
16:43:17:WU02:FS01:0x22:     Branch: HEAD
16:43:17:WU02:FS01:0x22:   Compiler: Visual C++ 2008
16:43:17:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:43:17:WU02:FS01:0x22:   Platform: win32 10
16:43:17:WU02:FS01:0x22:       Bits: 64
16:43:17:WU02:FS01:0x22:       Mode: Release
16:43:17:WU02:FS01:0x22:************************************ System ************************************
16:43:17:WU02:FS01:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:43:17:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:43:17:WU02:FS01:0x22:       CPUs: 16
16:43:17:WU02:FS01:0x22:     Memory: 15.96GiB
16:43:17:WU02:FS01:0x22:Free Memory: 13.63GiB
16:43:17:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
16:43:17:WU02:FS01:0x22: OS Version: 6.2
16:43:17:WU02:FS01:0x22:Has Battery: false
16:43:17:WU02:FS01:0x22: On Battery: false
16:43:17:WU02:FS01:0x22: UTC Offset: -4
16:43:17:WU02:FS01:0x22:        PID: 2952
16:43:17:WU02:FS01:0x22:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:43:17:WU02:FS01:0x22:         OS: Windows 10 Pro
16:43:17:WU02:FS01:0x22:    OS Arch: AMD64
16:43:17:WU02:FS01:0x22:********************************************************************************
16:43:17:WU02:FS01:0x22:Project: 11743 (Run 0, Clone 4501, Gen 84)
16:43:17:WU02:FS01:0x22:Unit: 0x0000007a8ca304f15e69ded61deccc4b
16:43:17:WU02:FS01:0x22:Digital signatures verified
16:43:17:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:43:17:WU02:FS01:0x22:Version 0.0.5
16:43:17:WU02:FS01:0x22:  Found a checkpoint file
16:43:18:WU00:FS00:Core PID:888
16:43:18:WU00:FS00:FahCore 0xa7 started
16:43:19:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T16:43:19Z ***********************
16:43:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:43:19:WU00:FS00:0xa7:       Type: 0xa7
16:43:19:WU00:FS00:0xa7:       Core: Gromacs
16:43:19:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7976 -checkpoint 15 -np
16:43:19:WU00:FS00:0xa7:             15
16:43:19:WU00:FS00:0xa7:************************************ CBang *************************************
16:43:19:WU00:FS00:0xa7:       Date: Oct 26 2019
16:43:19:WU00:FS00:0xa7:       Time: 01:38:25
16:43:19:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:43:19:WU00:FS00:0xa7:     Branch: master
16:43:19:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:43:19:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:43:19:WU00:FS00:0xa7:   Platform: win32 10
16:43:19:WU00:FS00:0xa7:       Bits: 64
16:43:19:WU00:FS00:0xa7:       Mode: Release
16:43:19:WU00:FS00:0xa7:************************************ System ************************************
16:43:19:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:43:19:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:43:19:WU00:FS00:0xa7:       CPUs: 16
16:43:19:WU00:FS00:0xa7:     Memory: 15.96GiB
16:43:19:WU00:FS00:0xa7:Free Memory: 13.46GiB
16:43:19:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:43:19:WU00:FS00:0xa7: OS Version: 6.2
16:43:19:WU00:FS00:0xa7:Has Battery: false
16:43:19:WU00:FS00:0xa7: On Battery: false
16:43:19:WU00:FS00:0xa7: UTC Offset: -4
16:43:19:WU00:FS00:0xa7:        PID: 888
16:43:19:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:43:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:43:19:WU00:FS00:0xa7:    Version: 0.0.18
16:43:19:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:43:19:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:43:19:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:43:19:WU00:FS00:0xa7:       Time: 01:52:30
16:43:19:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:43:19:WU00:FS00:0xa7:************************************ Build *************************************
16:43:19:WU00:FS00:0xa7:       SIMD: avx_256
16:43:19:WU00:FS00:0xa7:********************************************************************************
16:43:19:WU00:FS00:0xa7:Project: 14827 (Run 363, Clone 0, Gen 6)
16:43:19:WU00:FS00:0xa7:Unit: 0x000000069bf7a4d65ea6672dcff6a736
16:43:19:WU00:FS00:0xa7:Digital signatures verified
16:43:19:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 15
16:43:20:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:43:20:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:43:21:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:43:21:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:43:21:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:43:21:WU00:FS00:0xa7:Saving result file frame6.trr
16:43:21:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:43:25:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:43:25:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
16:43:25:WU00:FS00:Starting
16:43:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:43:25:WU00:FS00:Started FahCore on PID 9920
16:43:25:WU00:FS00:Core PID:9956
16:43:25:WU00:FS00:FahCore 0xa7 started
16:43:26:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T16:43:25Z ***********************
16:43:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:43:26:WU00:FS00:0xa7:       Type: 0xa7
16:43:26:WU00:FS00:0xa7:       Core: Gromacs
16:43:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9920 -checkpoint 15 -np
16:43:26:WU00:FS00:0xa7:             15
16:43:26:WU00:FS00:0xa7:************************************ CBang *************************************
16:43:26:WU00:FS00:0xa7:       Date: Oct 26 2019
16:43:26:WU00:FS00:0xa7:       Time: 01:38:25
16:43:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:43:26:WU00:FS00:0xa7:     Branch: master
16:43:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:43:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:43:26:WU00:FS00:0xa7:   Platform: win32 10
16:43:26:WU00:FS00:0xa7:       Bits: 64
16:43:26:WU00:FS00:0xa7:       Mode: Release
16:43:26:WU00:FS00:0xa7:************************************ System ************************************
16:43:26:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:43:26:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:43:26:WU00:FS00:0xa7:       CPUs: 16
16:43:26:WU00:FS00:0xa7:     Memory: 15.96GiB
16:43:26:WU00:FS00:0xa7:Free Memory: 13.13GiB
16:43:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:43:26:WU00:FS00:0xa7: OS Version: 6.2
16:43:26:WU00:FS00:0xa7:Has Battery: false
16:43:26:WU00:FS00:0xa7: On Battery: false
16:43:26:WU00:FS00:0xa7: UTC Offset: -4
16:43:26:WU00:FS00:0xa7:        PID: 9956
16:43:26:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:43:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:43:26:WU00:FS00:0xa7:    Version: 0.0.18
16:43:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:43:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:43:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:43:26:WU00:FS00:0xa7:       Time: 01:52:30
16:43:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:43:26:WU00:FS00:0xa7:************************************ Build *************************************
16:43:26:WU00:FS00:0xa7:       SIMD: avx_256
16:43:26:WU00:FS00:0xa7:********************************************************************************
16:43:26:WU00:FS00:0xa7:Project: 14827 (Run 363, Clone 0, Gen 6)
16:43:26:WU00:FS00:0xa7:Unit: 0x000000069bf7a4d65ea6672dcff6a736
16:43:26:WU00:FS00:0xa7:Digital signatures verified
16:43:26:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 15
16:43:26:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:43:26:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:43:26:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:43:26:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:43:26:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:43:26:WU00:FS00:0xa7:Saving result file frame6.trr
16:43:27:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:43:27:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
16:43:30:9:127.0.0.1:New Web session
16:43:36:WU02:FS01:0x22:Completed 250000 out of 2000000 steps (12%)
16:43:36:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:44:25:WU00:FS00:Starting
16:44:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:44:25:WU00:FS00:Started FahCore on PID 2004
16:44:25:WU00:FS00:Core PID:6468
16:44:25:WU00:FS00:FahCore 0xa7 started
16:44:26:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T16:44:25Z ***********************
16:44:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:44:26:WU00:FS00:0xa7:       Type: 0xa7
16:44:26:WU00:FS00:0xa7:       Core: Gromacs
16:44:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2004 -checkpoint 15 -np
16:44:26:WU00:FS00:0xa7:             15
16:44:26:WU00:FS00:0xa7:************************************ CBang *************************************
16:44:26:WU00:FS00:0xa7:       Date: Oct 26 2019
16:44:26:WU00:FS00:0xa7:       Time: 01:38:25
16:44:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:44:26:WU00:FS00:0xa7:     Branch: master
16:44:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:44:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:44:26:WU00:FS00:0xa7:   Platform: win32 10
16:44:26:WU00:FS00:0xa7:       Bits: 64
16:44:26:WU00:FS00:0xa7:       Mode: Release
16:44:26:WU00:FS00:0xa7:************************************ System ************************************
16:44:26:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:44:26:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:44:26:WU00:FS00:0xa7:       CPUs: 16
16:44:26:WU00:FS00:0xa7:     Memory: 15.96GiB
16:44:26:WU00:FS00:0xa7:Free Memory: 12.49GiB
16:44:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:44:26:WU00:FS00:0xa7: OS Version: 6.2
16:44:26:WU00:FS00:0xa7:Has Battery: false
16:44:26:WU00:FS00:0xa7: On Battery: false
16:44:26:WU00:FS00:0xa7: UTC Offset: -4
16:44:26:WU00:FS00:0xa7:        PID: 6468
16:44:26:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:44:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:44:26:WU00:FS00:0xa7:    Version: 0.0.18
16:44:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:44:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:44:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:44:26:WU00:FS00:0xa7:       Time: 01:52:30
16:44:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:44:26:WU00:FS00:0xa7:************************************ Build *************************************
16:44:26:WU00:FS00:0xa7:       SIMD: avx_256
16:44:26:WU00:FS00:0xa7:********************************************************************************
16:44:26:WU00:FS00:0xa7:Project: 14827 (Run 363, Clone 0, Gen 6)
16:44:26:WU00:FS00:0xa7:Unit: 0x000000069bf7a4d65ea6672dcff6a736
16:44:26:WU00:FS00:0xa7:Digital signatures verified
16:44:26:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 15
16:44:26:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:44:26:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:44:26:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:44:26:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:44:26:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:44:26:WU00:FS00:0xa7:Saving result file frame6.trr
16:44:27:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:44:27:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
16:44:29:WU02:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
16:45:25:WU00:FS00:Starting
16:45:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:45:25:WU00:FS00:Started FahCore on PID 8332
16:45:26:WU00:FS00:Core PID:8200
16:45:26:WU00:FS00:FahCore 0xa7 started
16:45:26:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T16:45:26Z ***********************
16:45:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:45:26:WU00:FS00:0xa7:       Type: 0xa7
16:45:26:WU00:FS00:0xa7:       Core: Gromacs
16:45:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8332 -checkpoint 15 -np
16:45:26:WU00:FS00:0xa7:             15
16:45:26:WU00:FS00:0xa7:************************************ CBang *************************************
16:45:26:WU00:FS00:0xa7:       Date: Oct 26 2019
16:45:26:WU00:FS00:0xa7:       Time: 01:38:25
16:45:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:45:26:WU00:FS00:0xa7:     Branch: master
16:45:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:45:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:45:26:WU00:FS00:0xa7:   Platform: win32 10
16:45:26:WU00:FS00:0xa7:       Bits: 64
16:45:26:WU00:FS00:0xa7:       Mode: Release
16:45:26:WU00:FS00:0xa7:************************************ System ************************************
16:45:26:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:45:26:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:45:26:WU00:FS00:0xa7:       CPUs: 16
16:45:26:WU00:FS00:0xa7:     Memory: 15.96GiB
16:45:26:WU00:FS00:0xa7:Free Memory: 11.95GiB
16:45:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:45:26:WU00:FS00:0xa7: OS Version: 6.2
16:45:26:WU00:FS00:0xa7:Has Battery: false
16:45:26:WU00:FS00:0xa7: On Battery: false
16:45:26:WU00:FS00:0xa7: UTC Offset: -4
16:45:26:WU00:FS00:0xa7:        PID: 8200
16:45:26:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:45:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:45:26:WU00:FS00:0xa7:    Version: 0.0.18
16:45:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:45:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:45:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:45:26:WU00:FS00:0xa7:       Time: 01:52:30
16:45:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:45:26:WU00:FS00:0xa7:************************************ Build *************************************
16:45:26:WU00:FS00:0xa7:       SIMD: avx_256
16:45:26:WU00:FS00:0xa7:********************************************************************************
16:45:26:WU00:FS00:0xa7:Project: 14827 (Run 363, Clone 0, Gen 6)
16:45:26:WU00:FS00:0xa7:Unit: 0x000000069bf7a4d65ea6672dcff6a736
16:45:26:WU00:FS00:0xa7:Digital signatures verified
16:45:26:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 15
16:45:26:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:45:26:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:45:26:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:45:26:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:45:26:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:45:26:WU00:FS00:0xa7:Saving result file frame6.trr
16:45:27:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:45:27:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
16:46:15:WU02:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
16:46:25:WU00:FS00:Starting
16:46:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:46:25:WU00:FS00:Started FahCore on PID 7548
16:46:26:WU00:FS00:Core PID:7584
16:46:26:WU00:FS00:FahCore 0xa7 started
16:46:26:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T16:46:26Z ***********************
16:46:26:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:46:26:WU00:FS00:0xa7:       Type: 0xa7
16:46:26:WU00:FS00:0xa7:       Core: Gromacs
16:46:26:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7548 -checkpoint 15 -np
16:46:26:WU00:FS00:0xa7:             15
16:46:26:WU00:FS00:0xa7:************************************ CBang *************************************
16:46:26:WU00:FS00:0xa7:       Date: Oct 26 2019
16:46:26:WU00:FS00:0xa7:       Time: 01:38:25
16:46:26:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:46:26:WU00:FS00:0xa7:     Branch: master
16:46:26:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:46:26:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:46:26:WU00:FS00:0xa7:   Platform: win32 10
16:46:26:WU00:FS00:0xa7:       Bits: 64
16:46:26:WU00:FS00:0xa7:       Mode: Release
16:46:26:WU00:FS00:0xa7:************************************ System ************************************
16:46:26:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:46:26:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:46:26:WU00:FS00:0xa7:       CPUs: 16
16:46:26:WU00:FS00:0xa7:     Memory: 15.96GiB
16:46:26:WU00:FS00:0xa7:Free Memory: 12.36GiB
16:46:26:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:46:26:WU00:FS00:0xa7: OS Version: 6.2
16:46:26:WU00:FS00:0xa7:Has Battery: false
16:46:26:WU00:FS00:0xa7: On Battery: false
16:46:26:WU00:FS00:0xa7: UTC Offset: -4
16:46:26:WU00:FS00:0xa7:        PID: 7584
16:46:26:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:46:26:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:46:26:WU00:FS00:0xa7:    Version: 0.0.18
16:46:26:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:46:26:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:46:26:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:46:26:WU00:FS00:0xa7:       Time: 01:52:30
16:46:26:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:46:26:WU00:FS00:0xa7:************************************ Build *************************************
16:46:26:WU00:FS00:0xa7:       SIMD: avx_256
16:46:26:WU00:FS00:0xa7:********************************************************************************
16:46:26:WU00:FS00:0xa7:Project: 14827 (Run 363, Clone 0, Gen 6)
16:46:26:WU00:FS00:0xa7:Unit: 0x000000069bf7a4d65ea6672dcff6a736
16:46:26:WU00:FS00:0xa7:Digital signatures verified
16:46:26:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 15
16:46:26:WU00:FS00:0xa7:ERROR:Guru Meditation #ceafabebf50f2254.d1a6e40a82cc6f2 (1342032.2684064) '00/01/frame6.trr'
16:46:26:WU00:FS00:0xa7:WARNING:Unexpected exit() call
16:46:26:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
16:46:26:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
16:46:26:WU00:FS00:0xa7:Saving result file dhdl.xvg
16:46:26:WU00:FS00:0xa7:Saving result file frame6.trr
16:46:27:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:46:27:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
16:46:27:WARNING:WU00:FS00:Too many errors, failing
16:46:27:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14827 run:363 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d65ea6672dcff6a736
16:46:27:WU00:FS00:Uploading 28.50KiB to 155.247.164.214
16:46:27:WU00:FS00:Connecting to 155.247.164.214:8080
16:46:28:WU00:FS00:Upload complete
16:46:29:WU01:FS00:Connecting to 65.254.110.245:80
16:46:29:WU00:FS00:Server responded WORK_QUIT (404)
16:46:29:WARNING:WU00:FS00:Server did not like results, dumping
16:46:29:WU00:FS00:Cleaning up
16:46:31:WU01:FS00:Assigned to work server 150.136.14.110
16:46:31:WU01:FS00:Requesting new work unit for slot 00: READY cpu:15 from 150.136.14.110
16:46:31:WU01:FS00:Connecting to 150.136.14.110:8080
16:46:32:WU01:FS00:Downloading 3.27MiB
16:46:38:WU01:FS00:Download 78.41%
16:46:39:WU01:FS00:Download complete
16:46:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16426 run:658 clone:4 gen:70 core:0xa7 unit:0x0000004f96880e6e5e961eaa22c287e8
16:46:39:WU01:FS00:Starting
16:46:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
16:46:39:WU01:FS00:Started FahCore on PID 7420
16:46:39:WU01:FS00:Core PID:5636
16:46:39:WU01:FS00:FahCore 0xa7 started
16:46:40:WU01:FS00:0xa7:*********************** Log Started 2020-05-06T16:46:39Z ***********************
16:46:40:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:46:40:WU01:FS00:0xa7:       Type: 0xa7
16:46:40:WU01:FS00:0xa7:       Core: Gromacs
16:46:40:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7420 -checkpoint 15 -np
16:46:40:WU01:FS00:0xa7:             15
16:46:40:WU01:FS00:0xa7:************************************ CBang *************************************
16:46:40:WU01:FS00:0xa7:       Date: Oct 26 2019
16:46:40:WU01:FS00:0xa7:       Time: 01:38:25
16:46:40:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:46:40:WU01:FS00:0xa7:     Branch: master
16:46:40:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
16:46:40:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:46:40:WU01:FS00:0xa7:   Platform: win32 10
16:46:40:WU01:FS00:0xa7:       Bits: 64
16:46:40:WU01:FS00:0xa7:       Mode: Release
16:46:40:WU01:FS00:0xa7:************************************ System ************************************
16:46:40:WU01:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
16:46:40:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:46:40:WU01:FS00:0xa7:       CPUs: 16
16:46:40:WU01:FS00:0xa7:     Memory: 15.96GiB
16:46:40:WU01:FS00:0xa7:Free Memory: 12.34GiB
16:46:40:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
16:46:40:WU01:FS00:0xa7: OS Version: 6.2
16:46:40:WU01:FS00:0xa7:Has Battery: false
16:46:40:WU01:FS00:0xa7: On Battery: false
16:46:40:WU01:FS00:0xa7: UTC Offset: -4
16:46:40:WU01:FS00:0xa7:        PID: 5636
16:46:40:WU01:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
16:46:40:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:46:40:WU01:FS00:0xa7:    Version: 0.0.18
16:46:40:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:46:40:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:46:40:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
16:46:40:WU01:FS00:0xa7:       Time: 01:52:30
16:46:40:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:46:40:WU01:FS00:0xa7:************************************ Build *************************************
16:46:40:WU01:FS00:0xa7:       SIMD: avx_256
16:46:40:WU01:FS00:0xa7:********************************************************************************
16:46:40:WU01:FS00:0xa7:Project: 16426 (Run 658, Clone 4, Gen 70)
16:46:40:WU01:FS00:0xa7:Unit: 0x0000004f96880e6e5e961eaa22c287e8
16:46:40:WU01:FS00:0xa7:Reading tar file core.xml
16:46:40:WU01:FS00:0xa7:Reading tar file frame70.tpr
16:46:40:WU01:FS00:0xa7:Digital signatures verified
16:46:40:WU01:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -x frame70.xtc -cpt 15 -nt 15
16:46:40:WU01:FS00:0xa7:Steps: first=17500000 total=250000
16:46:40:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
16:47:29:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
16:48:14:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
16:48:31:WU02:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
16:49:00:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
16:49:45:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
16:50:29:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
16:50:34:WU02:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
16:51:15:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
16:52:00:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
16:52:33:WU02:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
16:52:46:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
16:53:31:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
16:54:16:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
16:54:34:WU02:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
16:55:01:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
16:55:46:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
16:56:31:WU02:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
16:56:31:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
16:57:16:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
16:58:02:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
16:58:28:WU02:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
16:58:47:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
16:59:32:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
17:00:17:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
17:00:27:WU02:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
17:01:03:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
17:01:49:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
17:02:24:WU02:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
17:02:34:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
17:03:19:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
17:04:05:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
17:04:24:WU02:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
17:04:50:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
17:05:35:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
17:06:20:WU02:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
17:06:21:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
17:07:06:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
17:07:51:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
17:08:15:WU02:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
17:08:37:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
17:09:22:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
17:10:07:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
17:10:14:WU02:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
17:10:53:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
17:11:38:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
17:12:11:WU02:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
17:12:24:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
17:13:09:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
17:13:55:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
17:14:10:WU02:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
17:14:40:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
17:15:26:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
17:16:07:WU02:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
17:16:12:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
17:16:58:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
17:17:43:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
17:18:05:WU02:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
17:18:29:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
17:19:15:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
17:20:01:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
17:20:06:WU02:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
17:20:46:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
17:21:32:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
17:22:05:WU02:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
17:22:17:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
17:23:03:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
17:23:49:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
17:24:07:WU02:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
17:24:35:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
17:25:20:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
17:26:05:WU02:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
17:26:06:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
17:26:51:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
17:27:37:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
17:28:05:WU02:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
17:28:23:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
17:29:09:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
17:29:56:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
17:30:09:WU02:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
17:30:43:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
17:31:32:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
17:32:14:WU02:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
17:32:18:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
17:33:04:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
17:33:50:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
17:34:19:WU02:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
17:34:36:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
17:35:21:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
17:36:07:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
17:36:18:WU02:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
17:36:52:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
17:37:38:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
17:38:16:WU02:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
17:38:24:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
17:39:10:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
17:39:55:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
17:40:15:WU02:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
17:40:41:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
17:41:26:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
17:42:12:WU02:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
17:42:12:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
17:42:57:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
17:43:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:43:45:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
17:44:22:WU02:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
17:44:31:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
17:45:17:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
17:46:03:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
17:46:26:WU02:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
17:46:49:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
17:47:36:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
17:48:22:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
17:48:29:WU02:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
17:49:08:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
17:49:54:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
17:50:37:WU02:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
17:50:40:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
17:51:26:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
17:52:05:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:52:13:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
17:52:39:WU02:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
17:52:58:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
17:53:44:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
17:54:29:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
17:54:39:WU02:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
17:55:15:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
17:56:00:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
17:56:36:WU02:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
17:56:46:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
17:57:31:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
17:58:16:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
17:58:33:WU02:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
17:59:02:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
17:59:48:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
18:00:33:WU02:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
18:00:34:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
18:01:19:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
18:02:05:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
18:02:07:WU00:FS00:Connecting to 65.254.110.245:80
18:02:09:WU00:FS00:Assigned to work server 206.223.170.146
18:02:09:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:15 from 206.223.170.146
18:02:09:WU00:FS00:Connecting to 206.223.170.146:8080
18:02:10:WU00:FS00:Downloading 3.24MiB
18:02:16:WU00:FS00:Download 61.72%
18:02:18:WU00:FS00:Download complete
18:02:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14237 run:0 clone:38 gen:52 core:0xa7 unit:0x00000038cedfaa925ea9f6a01822d721
18:02:30:WU02:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
18:02:51:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:02:52:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
18:02:52:WU01:FS00:0xa7:Saving result file frame70.trr
18:02:52:WU01:FS00:0xa7:Saving result file frame70.xtc
18:02:52:WU01:FS00:0xa7:Saving result file md.log
18:02:52:WU01:FS00:0xa7:Saving result file science.log
18:02:53:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:02:53:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:02:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16426 run:658 clone:4 gen:70 core:0xa7 unit:0x0000004f96880e6e5e961eaa22c287e8
18:02:53:WU01:FS00:Uploading 2.72MiB to 150.136.14.110
18:02:53:WU01:FS00:Connecting to 150.136.14.110:8080
18:02:53:WU00:FS00:Starting
18:02:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
18:02:53:WU00:FS00:Started FahCore on PID 5704
18:02:53:WU00:FS00:Core PID:6404
18:02:53:WU00:FS00:FahCore 0xa7 started
18:02:54:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T18:02:53Z ***********************
18:02:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:02:54:WU00:FS00:0xa7:       Type: 0xa7
18:02:54:WU00:FS00:0xa7:       Core: Gromacs
18:02:54:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 5704 -checkpoint 15 -np
18:02:54:WU00:FS00:0xa7:             15
18:02:54:WU00:FS00:0xa7:************************************ CBang *************************************
18:02:54:WU00:FS00:0xa7:       Date: Oct 26 2019
18:02:54:WU00:FS00:0xa7:       Time: 01:38:25
18:02:54:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:02:54:WU00:FS00:0xa7:     Branch: master
18:02:54:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:02:54:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:02:54:WU00:FS00:0xa7:   Platform: win32 10
18:02:54:WU00:FS00:0xa7:       Bits: 64
18:02:54:WU00:FS00:0xa7:       Mode: Release
18:02:54:WU00:FS00:0xa7:************************************ System ************************************
18:02:54:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
18:02:54:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
18:02:54:WU00:FS00:0xa7:       CPUs: 16
18:02:54:WU00:FS00:0xa7:     Memory: 15.96GiB
18:02:54:WU00:FS00:0xa7:Free Memory: 13.17GiB
18:02:54:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:02:54:WU00:FS00:0xa7: OS Version: 6.2
18:02:54:WU00:FS00:0xa7:Has Battery: false
18:02:54:WU00:FS00:0xa7: On Battery: false
18:02:54:WU00:FS00:0xa7: UTC Offset: -4
18:02:54:WU00:FS00:0xa7:        PID: 6404
18:02:54:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
18:02:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:02:54:WU00:FS00:0xa7:    Version: 0.0.18
18:02:54:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:02:54:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:02:54:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:02:54:WU00:FS00:0xa7:       Time: 01:52:30
18:02:54:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:02:54:WU00:FS00:0xa7:************************************ Build *************************************
18:02:54:WU00:FS00:0xa7:       SIMD: avx_256
18:02:54:WU00:FS00:0xa7:********************************************************************************
18:02:54:WU00:FS00:0xa7:Project: 14237 (Run 0, Clone 38, Gen 52)
18:02:54:WU00:FS00:0xa7:Unit: 0x00000038cedfaa925ea9f6a01822d721
18:02:54:WU00:FS00:0xa7:Reading tar file core.xml
18:02:54:WU00:FS00:0xa7:Reading tar file frame52.tpr
18:02:54:WU00:FS00:0xa7:Digital signatures verified
18:02:54:WU00:FS00:0xa7:Calling: mdrun -s frame52.tpr -o frame52.trr -x frame52.xtc -cpt 15 -nt 15
18:02:54:WU00:FS00:0xa7:Steps: first=13000000 total=250000
18:02:55:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
18:02:59:WU01:FS00:Upload 39.00%
18:03:05:WU01:FS00:Upload 87.18%
18:03:07:WU01:FS00:Upload complete
18:03:07:WU01:FS00:Server responded WORK_ACK (400)
18:03:07:WU01:FS00:Final credit estimate, 5085.00 points
18:03:07:WU01:FS00:Cleaning up
18:03:41:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
18:04:26:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
18:04:30:WU02:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
18:05:12:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
18:05:58:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
18:06:30:WU02:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
18:06:43:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
18:06:46:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:06:47:WARNING:WU02:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
18:06:47:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
18:06:47:WARNING:WU00:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
18:06:47:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
18:06:47:WU02:FS01:Starting
18:06:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:06:47:WU02:FS01:Started FahCore on PID 720
18:06:47:WU02:FS01:FahCore 0x22 started
18:06:48:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
18:06:48:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
18:06:48:WARNING:WU02:FS01:Too many errors, failing
18:06:48:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:11743 run:0 clone:4501 gen:84 core:0x22 unit:0x0000007a8ca304f15e69ded61deccc4b
18:06:48:WU00:FS00:Starting
18:06:48:WU02:FS01:Connecting to 140.163.4.241:8080
18:06:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8804 -checkpoint 15 -np 15
18:06:48:WU00:FS00:Started FahCore on PID 7764
18:06:48:WU00:FS00:FahCore 0xa7 started
18:06:48:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:06:48:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
18:06:48:WU01:FS01:Connecting to 65.254.110.245:80
JuWaJo
Re: Gromacs / system is not well equilibrated errors
Post by JuWaJo »
*********************** Log Started 2020-05-06T21:10:23Z ***********************
21:10:23:****************************** FAHClient ******************************
21:10:23:        Version: 7.6.9
21:10:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:10:23:      Copyright: 2020 foldingathome.org
21:10:23:       Homepage: https://foldingathome.org/
21:10:23:           Date: Apr 17 2020
21:10:23:           Time: 11:13:06
21:10:23:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
21:10:23:         Branch: master
21:10:23:       Compiler: Visual C++ 2008
21:10:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:10:23:       Platform: win32 10
21:10:23:           Bits: 32
21:10:23:           Mode: Release
21:10:23:           Args: --open-web-control
21:10:23:         Config: C:\Users\Justin\AppData\Roaming\FAHClient\config.xml
21:10:23:******************************** CBang ********************************
21:10:23:           Time: 11:10:09
21:10:23:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
21:10:23:           Bits: 32
21:10:23:******************************* System ********************************
21:10:23:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
21:10:23:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:10:23:           CPUs: 16
21:10:23:         Memory: 15.96GiB
21:10:23:    Free Memory: 13.55GiB
21:10:23:        Threads: WINDOWS_THREADS
21:10:23:     OS Version: 6.2
21:10:23:    Has Battery: false
21:10:23:     On Battery: false
21:10:23:     UTC Offset: -4
21:10:23:            PID: 4140
21:10:23:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
21:10:23:             OS: Windows 10 Enterprise
21:10:23:        OS Arch: AMD64
21:10:23:           GPUs: 1
21:10:23:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
21:10:23:                 470/480/570/580/590]
21:10:23:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:10:23:                 specified module could not be found.
21:10:23:
21:10:23:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:2841.19
21:10:23:  Win32 Service: false
21:10:23:******************************* libFAH ********************************
21:10:23:           Date: Apr 15 2020
21:10:23:           Time: 14:53:14
21:10:23:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:10:23:           Bits: 32
21:10:23:***********************************************************************
21:10:24:<config>
21:10:24:  <!-- Folding Core -->
21:10:24:  <core-priority v='low'/>
21:10:24:
21:10:24:  <!-- Folding Slot Configuration -->
21:10:24:  <cause v='COVID_19'/>
21:10:24:
21:10:24:  <!-- Network -->
21:10:24:  <proxy v=':8080'/>
21:10:24:
21:10:24:  <!-- Remote Command Server -->
21:10:24:  <password v='*****'/>
21:10:24:
21:10:24:  <!-- Slot Control -->
21:10:24:  <pause-on-battery v='false'/>
21:10:24:  <power v='full'/>
21:10:24:
21:10:24:  <!-- User Information -->
21:10:24:  <passkey v='*****'/>
21:10:24:  <team v='33'/>
21:10:24:  <user v='vastspace91'/>
21:10:24:
21:10:24:  <!-- Folding Slots -->
21:10:24:  <slot id='0' type='CPU'/>
21:10:24:  <slot id='1' type='GPU'/>
21:10:24:</config>
21:10:24:Trying to access database...
21:10:24:Successfully acquired database lock
21:10:24:Enabled folding slot 00: READY cpu:15
21:10:24:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
21:10:24:WU00:FS00:Starting
21:10:24:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
21:10:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -np 14
21:10:24:WU00:FS00:Started FahCore on PID 3460
21:10:26:WU00:FS00:Core PID:5400
21:10:26:WU00:FS00:FahCore 0xa7 started
21:10:27:WU01:FS01:Starting
21:10:27:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:10:27:WU01:FS01:Started FahCore on PID 8180
21:10:27:WU00:FS00:0xa7:*********************** Log Started 2020-05-06T21:10:27Z ***********************
21:10:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:10:27:WU00:FS00:0xa7:       Type: 0xa7
21:10:27:WU00:FS00:0xa7:       Core: Gromacs
21:10:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3460 -checkpoint 15 -np
21:10:27:WU00:FS00:0xa7:             14
21:10:27:WU00:FS00:0xa7:************************************ CBang *************************************
21:10:27:WU00:FS00:0xa7:       Date: Oct 26 2019
21:10:27:WU00:FS00:0xa7:       Time: 01:38:25
21:10:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:10:27:WU00:FS00:0xa7:     Branch: master
21:10:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:10:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:10:27:WU00:FS00:0xa7:   Platform: win32 10
21:10:27:WU00:FS00:0xa7:       Bits: 64
21:10:27:WU00:FS00:0xa7:       Mode: Release
21:10:27:WU00:FS00:0xa7:************************************ System ************************************
21:10:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
21:10:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:10:27:WU00:FS00:0xa7:       CPUs: 16
21:10:27:WU00:FS00:0xa7:     Memory: 15.96GiB
21:10:27:WU00:FS00:0xa7:Free Memory: 13.27GiB
21:10:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:10:27:WU00:FS00:0xa7: OS Version: 6.2
21:10:27:WU00:FS00:0xa7:Has Battery: false
21:10:27:WU00:FS00:0xa7: On Battery: false
21:10:27:WU00:FS00:0xa7: UTC Offset: -4
21:10:27:WU00:FS00:0xa7:        PID: 5400
21:10:27:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
21:10:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:10:27:WU00:FS00:0xa7:    Version: 0.0.18
21:10:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:10:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:10:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:10:27:WU00:FS00:0xa7:       Time: 01:52:30
21:10:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:10:27:WU00:FS00:0xa7:************************************ Build *************************************
21:10:27:WU00:FS00:0xa7:       SIMD: avx_256
21:10:27:WU00:FS00:0xa7:********************************************************************************
21:10:27:WU00:FS00:0xa7:Project: 14580 (Run 0, Clone 922, Gen 88)
21:10:27:WU00:FS00:0xa7:Unit: 0x0000006e287234c95e7a34c6f09b926b
21:10:27:WU00:FS00:0xa7:Digital signatures verified
21:10:27:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
21:10:27:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
21:10:27:WU00:FS00:0xa7:Calling: mdrun -s frame88.tpr -o frame88.trr -x frame88.xtc -cpi state.cpt -cpt 15 -nt 12
21:10:29:WU00:FS00:0xa7:Steps: first=44000000 total=500000
21:10:29:WU01:FS01:Core PID:7672
21:10:29:WU01:FS01:FahCore 0x22 started
21:10:31:WU00:FS00:0xa7:Completed 300181 out of 500000 steps (60%)
21:10:35:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:10:36:WU01:FS01:Starting
21:10:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:10:36:WU01:FS01:Started FahCore on PID 9096
21:10:36:WU01:FS01:Core PID:3352
21:10:36:WU01:FS01:FahCore 0x22 started
21:10:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:11:36:WU01:FS01:Starting
21:11:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:11:36:WU01:FS01:Started FahCore on PID 7540
21:11:36:WU01:FS01:Core PID:6024
21:11:36:WU01:FS01:FahCore 0x22 started
21:11:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:11:44:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
21:12:36:WU01:FS01:Starting
21:12:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:12:36:WU01:FS01:Started FahCore on PID 8580
21:12:36:WU01:FS01:Core PID:6400
21:12:36:WU01:FS01:FahCore 0x22 started
21:12:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:12:40:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
21:13:36:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
21:13:36:WU01:FS01:Starting
21:13:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:13:36:WU01:FS01:Started FahCore on PID 1012
21:13:36:WU01:FS01:Core PID:1512
21:13:36:WU01:FS01:FahCore 0x22 started
21:13:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:13:37:WARNING:WU01:FS01:Too many errors, failing
21:13:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:11742 run:0 clone:8345 gen:39 core:0x22 unit:0x0000003b8ca304f15e6bc4edf7593a32
21:13:37:WU01:FS01:Connecting to 140.163.4.241:8080
21:13:37:WU02:FS01:Connecting to 65.254.110.245:80
21:13:38:WU01:FS01:Server responded WORK_ACK (400)
21:13:38:WU01:FS01:Cleaning up
21:13:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:13:38:WU02:FS01:Connecting to 18.218.241.186:80
21:13:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:13:39:WU02:FS01:Connecting to 65.254.110.245:80
21:13:40:WU02:FS01:Assigned to work server 3.133.76.19
21:13:40:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
21:13:40:WU02:FS01:Connecting to 3.133.76.19:8080
21:14:01:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
21:14:01:WU02:FS01:Connecting to 3.133.76.19:80
21:14:22:ERROR:WU02:FS01:Exception: Failed to connect to 3.133.76.19:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:14:22:WU02:FS01:Connecting to 65.254.110.245:80
21:14:22:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:14:22:WU02:FS01:Connecting to 18.218.241.186:80
21:14:22:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:14:23:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:14:23:WU02:FS01:Connecting to 18.218.241.186:80
21:14:23:WU02:FS01:Assigned to work server 128.252.203.10
21:14:23:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
21:14:23:WU02:FS01:Connecting to 128.252.203.10:8080
21:14:32:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
21:14:49:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:15:22:WU02:FS01:Connecting to 65.254.110.245:80
21:15:22:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:15:22:WU02:FS01:Connecting to 18.218.241.186:80
21:15:23:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:15:23:WU02:FS01:Connecting to 65.254.110.245:80
21:15:23:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:15:23:WU02:FS01:Connecting to 18.218.241.186:80
21:15:23:ERROR:WU02:FS01:Exception: Could not get an assignment
21:15:27:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
21:16:23:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
21:16:59:WU02:FS01:Connecting to 65.254.110.245:80
21:17:00:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:17:00:WU02:FS01:Connecting to 18.218.241.186:80
21:17:00:WU02:FS01:Assigned to work server 128.252.203.10
21:17:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.252.203.10
21:17:00:WU02:FS01:Connecting to 128.252.203.10:8080
21:17:19:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
21:17:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
21:17:21:WU02:FS01:Connecting to 128.252.203.10:80
21:17:42:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:18:15:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
21:19:10:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
21:19:36:WU02:FS01:Connecting to 65.254.110.245:80
21:19:37:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:19:37:WU02:FS01:Connecting to 18.218.241.186:80
21:19:37:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:19:37:WU02:FS01:Connecting to 65.254.110.245:80
21:19:37:ERROR:WU02:FS01:Exception: Could not get an assignment
21:20:05:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
21:21:00:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
21:21:55:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
21:22:50:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
21:23:45:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
21:23:51:WU02:FS01:Connecting to 65.254.110.245:80
21:23:51:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:23:51:WU02:FS01:Connecting to 18.218.241.186:80
21:23:51:WU02:FS01:Assigned to work server 3.133.76.19
21:23:51:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 3.133.76.19
21:23:51:WU02:FS01:Connecting to 3.133.76.19:8080
21:24:12:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
21:24:12:WU02:FS01:Connecting to 3.133.76.19:80
21:24:40:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
21:25:12:WU02:FS01:Downloading 30.32MiB
21:25:18:WU02:FS01:Download 47.20%
21:25:24:WU02:FS01:Download 95.02%
21:25:24:WU02:FS01:Download complete
21:25:24:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16435 run:2948 clone:1 gen:3 core:0x22 unit:0x0000000a03854c135e9a4ef74e5c2767
21:25:24:WU02:FS01:Starting
21:25:24:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:25:25:WU02:FS01:Started FahCore on PID 9424
21:25:25:WU02:FS01:Core PID:6564
21:25:25:WU02:FS01:FahCore 0x22 started
21:25:25:WU02:FS01:0x22:*********************** Log Started 2020-05-06T21:25:25Z ***********************
21:25:25:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:25:25:WU02:FS01:0x22:       Type: 0x22
21:25:25:WU02:FS01:0x22:       Core: Core22
21:25:25:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:25:25:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:25:25:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:25:25:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:25:25:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9424 -checkpoint 15
21:25:25:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:25:25:WU02:FS01:0x22:     Config: <none>
21:25:25:WU02:FS01:0x22:************************************ Build *************************************
21:25:25:WU02:FS01:0x22:    Version: 0.0.5
21:25:25:WU02:FS01:0x22:       Date: Apr 22 2020
21:25:25:WU02:FS01:0x22:       Time: 04:42:59
21:25:25:WU02:FS01:0x22: Repository: Git
21:25:25:WU02:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
21:25:25:WU02:FS01:0x22:     Branch: HEAD
21:25:25:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:25:25:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:25:25:WU02:FS01:0x22:   Platform: win32 10
21:25:25:WU02:FS01:0x22:       Bits: 64
21:25:25:WU02:FS01:0x22:       Mode: Release
21:25:25:WU02:FS01:0x22:************************************ System ************************************
21:25:25:WU02:FS01:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
21:25:25:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:25:25:WU02:FS01:0x22:       CPUs: 16
21:25:25:WU02:FS01:0x22:     Memory: 15.96GiB
21:25:25:WU02:FS01:0x22:Free Memory: 11.84GiB
21:25:25:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:25:25:WU02:FS01:0x22: OS Version: 6.2
21:25:25:WU02:FS01:0x22:Has Battery: false
21:25:25:WU02:FS01:0x22: On Battery: false
21:25:25:WU02:FS01:0x22: UTC Offset: -4
21:25:25:WU02:FS01:0x22:        PID: 6564
21:25:25:WU02:FS01:0x22:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
21:25:25:WU02:FS01:0x22:         OS: Windows 10 Pro
21:25:25:WU02:FS01:0x22:    OS Arch: AMD64
21:25:25:WU02:FS01:0x22:********************************************************************************
21:25:25:WU02:FS01:0x22:Project: 16435 (Run 2948, Clone 1, Gen 3)
21:25:25:WU02:FS01:0x22:Unit: 0x0000000a03854c135e9a4ef74e5c2767
21:25:25:WU02:FS01:0x22:Reading tar file core.xml
21:25:25:WU02:FS01:0x22:Reading tar file integrator.xml
21:25:25:WU02:FS01:0x22:Reading tar file state.xml
21:25:26:WU02:FS01:0x22:Reading tar file system.xml
21:25:26:WU02:FS01:0x22:Digital signatures verified
21:25:26:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:25:26:WU02:FS01:0x22:Version 0.0.5
21:25:36:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
21:25:39:WU02:FS01:0x22:Completed 0 out of 5000000 steps (0%)
21:25:39:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:26:33:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
21:27:29:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
21:28:26:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
21:29:24:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
21:29:57:WU02:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
21:30:21:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
21:31:19:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
21:32:17:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
21:33:15:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
21:34:14:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
21:34:16:WU02:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
21:35:12:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
21:36:11:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
21:37:09:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
21:38:08:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
21:38:35:WU02:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
21:39:06:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
21:40:05:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
21:41:03:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
21:42:02:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
21:42:54:WU02:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
21:43:01:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
21:43:59:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
21:44:58:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
21:45:57:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
21:46:56:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
21:47:13:WU02:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
21:47:54:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
21:47:55:WU01:FS00:Connecting to 65.254.110.245:80
21:47:55:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:47:55:WU01:FS00:Connecting to 18.218.241.186:80
21:47:56:WU01:FS00:Assigned to work server 206.223.170.146
21:47:56:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:15 from 206.223.170.146
21:47:56:WU01:FS00:Connecting to 206.223.170.146:8080
21:47:56:WU01:FS00:Downloading 4.29MiB
21:47:57:WU01:FS00:Download complete
21:47:57:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14234 run:75 clone:1 gen:40 core:0xa7 unit:0x0000002bcedfaa925ea3784e2bc7f4cb
21:48:52:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
21:48:53:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:48:53:WU00:FS00:0xa7:Saving result file frame88.trr
21:48:53:WU00:FS00:0xa7:Saving result file frame88.xtc
21:48:53:WU00:FS00:0xa7:Saving result file md.log
21:48:53:WU00:FS00:0xa7:Saving result file science.log
21:48:53:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:48:54:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:48:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14580 run:0 clone:922 gen:88 core:0xa7 unit:0x0000006e287234c95e7a34c6f09b926b
21:48:54:WU00:FS00:Uploading 1.78MiB to 40.114.52.201
21:48:54:WU00:FS00:Connecting to 40.114.52.201:8080
21:48:54:WU01:FS00:Starting
21:48:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 4140 -checkpoint 15 -np 15
21:48:54:WU01:FS00:Started FahCore on PID 3148
21:48:54:WU01:FS00:Core PID:8924
21:48:54:WU01:FS00:FahCore 0xa7 started
21:48:55:WU01:FS00:0xa7:*********************** Log Started 2020-05-06T21:48:54Z ***********************
21:48:55:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:48:55:WU01:FS00:0xa7:       Type: 0xa7
21:48:55:WU01:FS00:0xa7:       Core: Gromacs
21:48:55:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3148 -checkpoint 15 -np
21:48:55:WU01:FS00:0xa7:             15
21:48:55:WU01:FS00:0xa7:************************************ CBang *************************************
21:48:55:WU01:FS00:0xa7:       Date: Oct 26 2019
21:48:55:WU01:FS00:0xa7:       Time: 01:38:25
21:48:55:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:48:55:WU01:FS00:0xa7:     Branch: master
21:48:55:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:48:55:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:48:55:WU01:FS00:0xa7:   Platform: win32 10
21:48:55:WU01:FS00:0xa7:       Bits: 64
21:48:55:WU01:FS00:0xa7:       Mode: Release
21:48:55:WU01:FS00:0xa7:************************************ System ************************************
21:48:55:WU01:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
21:48:55:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:48:55:WU01:FS00:0xa7:       CPUs: 16
21:48:55:WU01:FS00:0xa7:     Memory: 15.96GiB
21:48:55:WU01:FS00:0xa7:Free Memory: 11.60GiB
21:48:55:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:48:55:WU01:FS00:0xa7: OS Version: 6.2
21:48:55:WU01:FS00:0xa7:Has Battery: false
21:48:55:WU01:FS00:0xa7: On Battery: false
21:48:55:WU01:FS00:0xa7: UTC Offset: -4
21:48:55:WU01:FS00:0xa7:        PID: 8924
21:48:55:WU01:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
21:48:55:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:48:55:WU01:FS00:0xa7:    Version: 0.0.18
21:48:55:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:48:55:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:48:55:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:48:55:WU01:FS00:0xa7:       Time: 01:52:30
21:48:55:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:48:55:WU01:FS00:0xa7:************************************ Build *************************************
21:48:55:WU01:FS00:0xa7:       SIMD: avx_256
21:48:55:WU01:FS00:0xa7:********************************************************************************
21:48:55:WU01:FS00:0xa7:Project: 14234 (Run 75, Clone 1, Gen 40)
21:48:55:WU01:FS00:0xa7:Unit: 0x0000002bcedfaa925ea3784e2bc7f4cb
21:48:55:WU01:FS00:0xa7:Reading tar file core.xml
21:48:55:WU01:FS00:0xa7:Reading tar file frame40.tpr
21:48:55:WU01:FS00:0xa7:Digital signatures verified
21:48:55:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -x frame40.xtc -cpt 15 -nt 15
21:48:55:WU01:FS00:0xa7:Steps: first=10000000 total=250000
21:48:56:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
21:48:56:WU00:FS00:Connecting to 40.114.52.201:80
21:48:57:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:48:58:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
21:48:58:WU00:FS00:Trying to send results to collection server
21:48:58:WU00:FS00:Uploading 1.78MiB to 52.224.109.74
21:48:58:WU00:FS00:Connecting to 52.224.109.74:8080
21:49:00:WU00:FS00:Upload complete
21:49:00:WU00:FS00:Server responded WORK_ACK (400)
21:49:00:WU00:FS00:Final credit estimate, 4312.00 points
21:49:00:WU00:FS00:Cleaning up
21:49:58:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:50:58:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:51:55:WU02:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
21:51:57:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
21:52:57:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
21:53:56:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
21:54:56:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
21:55:55:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
21:56:45:WU02:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
21:56:55:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
21:57:56:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
JuWaJo
Post by JuWaJo »
These have surpassed the 60000 character limit.
https://we.tl/t-9l9RHra2wk
https://we.tl/t-PAY1oMenA1
JuWaJo
Post by JuWaJo »
*********************** Log Started 2020-05-05T14:38:01Z ***********************
14:38:01:****************************** FAHClient ******************************
14:38:01:        Version: 7.6.9
14:38:01:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:38:01:      Copyright: 2020 foldingathome.org
14:38:01:       Homepage: https://foldingathome.org/
14:38:01:           Date: Apr 17 2020
14:38:01:           Time: 11:13:06
14:38:01:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
14:38:01:         Branch: master
14:38:01:       Compiler: Visual C++ 2008
14:38:01:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:38:01:       Platform: win32 10
14:38:01:           Bits: 32
14:38:01:           Mode: Release
14:38:01:           Args: --open-web-control
14:38:01:         Config: C:\Users\Justin\AppData\Roaming\FAHClient\config.xml
14:38:01:******************************** CBang ********************************
14:38:01:           Time: 11:10:09
14:38:01:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
14:38:01:           Bits: 32
14:38:01:******************************* System ********************************
14:38:01:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
14:38:01:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:38:01:           CPUs: 16
14:38:01:         Memory: 15.96GiB
14:38:01:    Free Memory: 13.46GiB
14:38:01:        Threads: WINDOWS_THREADS
14:38:01:     OS Version: 6.2
14:38:01:    Has Battery: false
14:38:01:     On Battery: false
14:38:01:     UTC Offset: -4
14:38:01:            PID: 4652
14:38:01:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
14:38:01:             OS: Windows 10 Enterprise
14:38:01:        OS Arch: AMD64
14:38:01:           GPUs: 1
14:38:01:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
14:38:01:                 470/480/570/580/590]
14:38:01:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:38:01:                 specified module could not be found.
14:38:01:
14:38:01:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:2841.19
14:38:01:  Win32 Service: false
14:38:01:******************************* libFAH ********************************
14:38:01:           Date: Apr 15 2020
14:38:01:           Time: 14:53:14
14:38:01:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:38:01:           Bits: 32
14:38:01:***********************************************************************
14:38:01:<config>
14:38:01:  <!-- Folding Core -->
14:38:01:  <core-priority v='low'/>
14:38:01:
14:38:01:  <!-- Folding Slot Configuration -->
14:38:01:  <cause v='COVID_19'/>
14:38:01:
14:38:01:  <!-- Network -->
14:38:01:  <proxy v=':8080'/>
14:38:01:
14:38:01:  <!-- Remote Command Server -->
14:38:01:  <password v='*****'/>
14:38:01:
14:38:01:  <!-- Slot Control -->
14:38:01:  <pause-on-battery v='false'/>
14:38:01:  <power v='full'/>
14:38:01:
14:38:01:  <!-- User Information -->
14:38:01:  <passkey v='*****'/>
14:38:01:  <team v='33'/>
14:38:01:  <user v='vastspace91'/>
14:38:01:
14:38:01:  <!-- Folding Slots -->
14:38:01:  <slot id='0' type='CPU'/>
14:38:01:  <slot id='1' type='GPU'/>
14:38:01:</config>
14:38:01:Trying to access database...
14:38:01:Successfully acquired database lock
14:38:01:Enabled folding slot 00: READY cpu:15
14:38:01:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
14:38:02:WU02:FS00:Starting
14:38:02:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4652 -checkpoint 15 -np 15
14:38:11:WU02:FS00:Started FahCore on PID 10208
14:38:17:WU02:FS00:Core PID:6364
14:38:17:WU02:FS00:FahCore 0xa7 started
14:38:19:WU02:FS00:0xa7:*********************** Log Started 2020-05-05T14:38:18Z ***********************
14:38:19:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:38:19:WU02:FS00:0xa7:       Type: 0xa7
14:38:19:WU02:FS00:0xa7:       Core: Gromacs
14:38:19:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 10208 -checkpoint 15 -np
14:38:19:WU02:FS00:0xa7:             15
14:38:19:WU02:FS00:0xa7:************************************ CBang *************************************
14:38:19:WU02:FS00:0xa7:       Date: Oct 26 2019
14:38:19:WU02:FS00:0xa7:       Time: 01:38:25
14:38:19:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:38:19:WU02:FS00:0xa7:     Branch: master
14:38:19:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:38:19:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:38:19:WU02:FS00:0xa7:   Platform: win32 10
14:38:19:WU02:FS00:0xa7:       Bits: 64
14:38:19:WU02:FS00:0xa7:       Mode: Release
14:38:19:WU02:FS00:0xa7:************************************ System ************************************
14:38:19:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
14:38:19:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:38:19:WU02:FS00:0xa7:       CPUs: 16
14:38:19:WU02:FS00:0xa7:     Memory: 15.96GiB
14:38:19:WU02:FS00:0xa7:Free Memory: 12.53GiB
14:38:19:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:38:19:WU02:FS00:0xa7: OS Version: 6.2
14:38:19:WU02:FS00:0xa7:Has Battery: false
14:38:19:WU02:FS00:0xa7: On Battery: false
14:38:19:WU02:FS00:0xa7: UTC Offset: -4
14:38:19:WU02:FS00:0xa7:        PID: 6364
14:38:19:WU02:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
14:38:19:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:38:19:WU02:FS00:0xa7:    Version: 0.0.18
14:38:19:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:38:19:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:38:19:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:38:19:WU02:FS00:0xa7:       Time: 01:52:30
14:38:19:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:38:19:WU02:FS00:0xa7:************************************ Build *************************************
14:38:19:WU02:FS00:0xa7:       SIMD: avx_256
14:38:19:WU02:FS00:0xa7:********************************************************************************
14:38:19:WU02:FS00:0xa7:Project: 13851 (Run 0, Clone 24718, Gen 81)
14:38:19:WU02:FS00:0xa7:Unit: 0x00000067287234c95e7886be5b8888ec
14:38:19:WU02:FS00:0xa7:Digital signatures verified
14:38:20:WU02:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -x frame81.xtc -e frame81.edr -cpi state.cpt -cpt 15 -nt 15
14:38:22:WU02:FS00:0xa7:Steps: first=40500000 total=500000
14:38:23:WU02:FS00:0xa7:Completed 194251 out of 500000 steps (38%)
14:38:25:WU00:FS01:Connecting to 65.254.110.245:80
14:38:27:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:38:27:WU00:FS01:Connecting to 18.218.241.186:80
14:38:28:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:38:28:WU00:FS01:Connecting to 65.254.110.245:80
14:38:29:12:127.0.0.1:New Web session
14:38:30:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:38:30:WU00:FS01:Connecting to 18.218.241.186:80
14:38:32:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:38:32:ERROR:WU00:FS01:Exception: Could not get an assignment
14:38:32:WU00:FS01:Connecting to 65.254.110.245:80
14:38:33:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:38:33:WU00:FS01:Connecting to 18.218.241.186:80
14:38:34:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:38:34:WU00:FS01:Connecting to 65.254.110.245:80
14:38:35:WU02:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
14:38:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:38:36:WU00:FS01:Connecting to 18.218.241.186:80
14:38:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:38:38:ERROR:WU00:FS01:Exception: Could not get an assignment
14:38:44:WU02:FS00:0xa7:ERROR:
14:38:44:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
14:38:44:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
14:38:44:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:38:44:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
14:38:44:WU02:FS00:0xa7:ERROR:Fatal error:
14:38:44:WU02:FS00:0xa7:ERROR:100 particles communicated to PME rank 7 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
14:38:44:WU02:FS00:0xa7:ERROR:5 particles communicated to PME rank 11 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
14:38:44:WU02:FS00:0xa7:ERROR:3 particles communicated to PME rank 9 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
14:38:44:WU02:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
14:38:44:WU02:FS00:0xa7:ERROR:288 particles communicated to PME rank 10 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
14:38:44:WU02:FS00:0xa7:ERROR:1 particles communicated to PME rank 6 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension y.
14:38:44:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
14:38:44:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
14:38:46:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:38:46:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741784 = 0xc0000028)
14:38:47:WU02:FS00:Starting
14:38:47:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4652 -checkpoint 15 -np 15
14:38:47:WU02:FS00:Started FahCore on PID 2204
14:38:47:WU02:FS00:Core PID:7588
14:38:47:WU02:FS00:FahCore 0xa7 started
14:38:48:WU02:FS00:0xa7:*********************** Log Started 2020-05-05T14:38:47Z ***********************
14:38:48:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:38:48:WU02:FS00:0xa7:       Type: 0xa7
14:38:48:WU02:FS00:0xa7:       Core: Gromacs
14:38:48:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2204 -checkpoint 15 -np
14:38:48:WU02:FS00:0xa7:             15
14:38:48:WU02:FS00:0xa7:************************************ CBang *************************************
14:38:48:WU02:FS00:0xa7:       Date: Oct 26 2019
14:38:48:WU02:FS00:0xa7:       Time: 01:38:25
14:38:48:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:38:48:WU02:FS00:0xa7:     Branch: master
14:38:48:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:38:48:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:38:48:WU02:FS00:0xa7:   Platform: win32 10
14:38:48:WU02:FS00:0xa7:       Bits: 64
14:38:48:WU02:FS00:0xa7:       Mode: Release
14:38:48:WU02:FS00:0xa7:************************************ System ************************************
14:38:48:WU02:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
14:38:48:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:38:48:WU02:FS00:0xa7:       CPUs: 16
14:38:48:WU02:FS00:0xa7:     Memory: 15.96GiB
14:38:48:WU02:FS00:0xa7:Free Memory: 12.71GiB
14:38:48:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:38:48:WU02:FS00:0xa7: OS Version: 6.2
14:38:48:WU02:FS00:0xa7:Has Battery: false
14:38:48:WU02:FS00:0xa7: On Battery: false
14:38:48:WU02:FS00:0xa7: UTC Offset: -4
14:38:48:WU02:FS00:0xa7:        PID: 7588
14:38:48:WU02:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
14:38:48:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:38:48:WU02:FS00:0xa7:    Version: 0.0.18
14:38:48:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:38:48:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:38:48:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:38:48:WU02:FS00:0xa7:       Time: 01:52:30
14:38:48:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:38:48:WU02:FS00:0xa7:************************************ Build *************************************
14:38:48:WU02:FS00:0xa7:       SIMD: avx_256
14:38:48:WU02:FS00:0xa7:********************************************************************************
14:38:48:WU02:FS00:0xa7:Project: 13851 (Run 0, Clone 24718, Gen 81)
14:38:48:WU02:FS00:0xa7:Unit: 0x00000067287234c95e7886be5b8888ec
14:38:48:WU02:FS00:0xa7:Digital signatures verified
14:38:48:WU02:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -x frame81.xtc -e frame81.edr -cpi state.cpt -cpt 15 -nt 15
14:38:48:WU02:FS00:0xa7:ERROR:Guru Meditation #9e7f699fa8446f97.ccfb12f5d9b998e5 (24907.26124) '02/01/md.log'
14:38:48:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:38:48:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
14:38:48:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:38:48:WU02:FS00:0xa7:Saving result file frame81.edr
14:38:48:WU02:FS00:0xa7:Saving result file frame81.trr
14:38:48:WU02:FS00:0xa7:Saving result file frame81.xtc
14:38:48:WU02:FS00:0xa7:Saving result file md.log
14:38:48:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:38:48:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
14:39:32:WU00:FS01:Connecting to 65.254.110.245:80
14:39:34:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:39:34:WU00:FS01:Connecting to 18.218.241.186:80
14:39:35:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:39:35:WU00:FS01:Connecting to 65.254.110.245:80
JuWaJo
Post by JuWaJo »
*********************** Log Started 2020-05-05T14:58:57Z ***********************
14:58:57:****************************** FAHClient ******************************
14:58:57:        Version: 7.6.9
14:58:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:58:57:      Copyright: 2020 foldingathome.org
14:58:57:       Homepage: https://foldingathome.org/
14:58:57:           Date: Apr 17 2020
14:58:57:           Time: 11:13:06
14:58:57:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
14:58:57:         Branch: master
14:58:57:       Compiler: Visual C++ 2008
14:58:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:58:57:       Platform: win32 10
14:58:57:           Bits: 32
14:58:57:           Mode: Release
14:58:57:           Args: --open-web-control
14:58:57:         Config: C:\Users\Justin\AppData\Roaming\FAHClient\config.xml
14:58:57:******************************** CBang ********************************
14:58:57:           Time: 11:10:09
14:58:57:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
14:58:57:           Bits: 32
14:58:57:******************************* System ********************************
14:58:57:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
14:58:57:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
14:58:57:           CPUs: 16
14:58:57:         Memory: 15.96GiB
14:58:57:    Free Memory: 13.31GiB
14:58:57:        Threads: WINDOWS_THREADS
14:58:57:     OS Version: 6.2
14:58:57:    Has Battery: false
14:58:57:     On Battery: false
14:58:57:     UTC Offset: -4
14:58:57:            PID: 5360
14:58:57:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
14:58:57:             OS: Windows 10 Enterprise
14:58:57:        OS Arch: AMD64
14:58:57:           GPUs: 1
14:58:57:          GPU 0: Bus:45 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
14:58:57:                 470/480/570/580/590]
14:58:57:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:58:57:                 specified module could not be found.
14:58:57:
14:58:57:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:2841.19
14:58:57:  Win32 Service: false
14:58:57:******************************* libFAH ********************************
14:58:57:           Date: Apr 15 2020
14:58:57:           Time: 14:53:14
14:58:57:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:58:57:           Bits: 32
14:58:57:***********************************************************************
14:58:57:<config>
14:58:57:  <!-- Folding Core -->
14:58:57:  <core-priority v='low'/>
14:58:57:
14:58:57:  <!-- Folding Slot Configuration -->
14:58:57:  <cause v='COVID_19'/>
14:58:57:
14:58:57:  <!-- Network -->
14:58:57:  <proxy v=':8080'/>
14:58:57:
14:58:57:  <!-- Remote Command Server -->
14:58:57:  <password v='*****'/>
14:58:57:
14:58:57:  <!-- Slot Control -->
14:58:57:  <pause-on-battery v='false'/>
14:58:57:  <power v='full'/>
14:58:57:
14:58:57:  <!-- User Information -->
14:58:57:  <passkey v='*****'/>
14:58:57:  <team v='33'/>
14:58:57:  <user v='vastspace91'/>
14:58:57:
14:58:57:  <!-- Folding Slots -->
14:58:57:  <slot id='0' type='CPU'/>
14:58:57:  <slot id='1' type='GPU'/>
14:58:57:</config>
14:58:57:Trying to access database...
14:58:57:Successfully acquired database lock
14:58:57:Enabled folding slot 00: READY cpu:15
14:58:57:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590]
14:58:58:WU00:FS00:Connecting to 65.254.110.245:80
14:58:58:WU01:FS01:Connecting to 65.254.110.245:80
14:58:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:58:59:WU00:FS00:Connecting to 18.218.241.186:80
14:58:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:58:59:WU01:FS01:Connecting to 18.218.241.186:80
14:59:00:WU00:FS00:Assigned to work server 128.252.203.2
14:59:00:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 128.252.203.2
14:59:00:WU00:FS00:Connecting to 128.252.203.2:8080
14:59:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:59:00:WU01:FS01:Connecting to 65.254.110.245:80
14:59:01:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:59:01:WU01:FS01:Connecting to 18.218.241.186:80
14:59:01:10:127.0.0.1:New Web session
14:59:02:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:59:02:WU00:FS00:Connecting to 65.254.110.245:80
14:59:02:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:59:02:ERROR:WU01:FS01:Exception: Could not get an assignment
14:59:02:WU01:FS01:Connecting to 65.254.110.245:80
14:59:03:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:59:03:WU00:FS00:Connecting to 18.218.241.186:80
14:59:04:WU01:FS01:Assigned to work server 140.163.4.241
14:59:04:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 140.163.4.241
14:59:04:WU01:FS01:Connecting to 140.163.4.241:8080
14:59:04:WU00:FS00:Assigned to work server 128.252.203.9
14:59:04:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 128.252.203.9
14:59:04:WU00:FS00:Connecting to 128.252.203.9:8080
15:00:33:WU01:FS01:Downloading 7.92MiB
15:00:39:WU01:FS01:Download 26.82%
15:00:45:WU01:FS01:Download 73.36%
15:00:48:WU01:FS01:Download complete
15:00:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:9515 gen:44 core:0x22 unit:0x0000004c8ca304f15e6bc378e385352f
15:00:49:WU01:FS01:Starting
15:00:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5360 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:00:49:WU01:FS01:Started FahCore on PID 7388
15:00:51:WU01:FS01:Core PID:7624
15:00:51:WU01:FS01:FahCore 0x22 started
15:00:52:WU01:FS01:0x22:*********************** Log Started 2020-05-05T15:00:51Z ***********************
15:00:52:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:00:52:WU01:FS01:0x22:       Type: 0x22
15:00:52:WU01:FS01:0x22:       Core: Core22
15:00:52:WU01:FS01:0x22:    Website: https://foldingathome.org/
15:00:52:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:00:52:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:00:52:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:00:52:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7388 -checkpoint 15
15:00:52:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:00:52:WU01:FS01:0x22:     Config: <none>
15:00:52:WU01:FS01:0x22:************************************ Build *************************************
15:00:52:WU01:FS01:0x22:    Version: 0.0.5
15:00:52:WU01:FS01:0x22:       Date: Apr 22 2020
15:00:52:WU01:FS01:0x22:       Time: 04:42:59
15:00:52:WU01:FS01:0x22: Repository: Git
15:00:52:WU01:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
15:00:52:WU01:FS01:0x22:     Branch: HEAD
15:00:52:WU01:FS01:0x22:   Compiler: Visual C++ 2008
15:00:52:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:00:52:WU01:FS01:0x22:   Platform: win32 10
15:00:52:WU01:FS01:0x22:       Bits: 64
15:00:52:WU01:FS01:0x22:       Mode: Release
15:00:52:WU01:FS01:0x22:************************************ System ************************************
15:00:52:WU01:FS01:0x22:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:00:52:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:00:52:WU01:FS01:0x22:       CPUs: 16
15:00:52:WU01:FS01:0x22:     Memory: 15.96GiB
15:00:52:WU01:FS01:0x22:Free Memory: 12.34GiB
15:00:52:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
15:00:52:WU01:FS01:0x22: OS Version: 6.2
15:00:52:WU01:FS01:0x22:Has Battery: false
15:00:52:WU01:FS01:0x22: On Battery: false
15:00:52:WU01:FS01:0x22: UTC Offset: -4
15:00:52:WU01:FS01:0x22:        PID: 7624
15:00:52:WU01:FS01:0x22:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
15:00:52:WU01:FS01:0x22:         OS: Windows 10 Pro
15:00:52:WU01:FS01:0x22:    OS Arch: AMD64
15:00:52:WU01:FS01:0x22:********************************************************************************
15:00:52:WU01:FS01:0x22:Project: 11745 (Run 0, Clone 9515, Gen 44)
15:00:52:WU01:FS01:0x22:Unit: 0x0000004c8ca304f15e6bc378e385352f
15:00:52:WU01:FS01:0x22:Reading tar file core.xml
15:00:52:WU01:FS01:0x22:Reading tar file integrator.xml
15:00:52:WU01:FS01:0x22:Reading tar file state.xml
15:00:53:WU01:FS01:0x22:Reading tar file system.xml
15:00:54:WU01:FS01:0x22:Digital signatures verified
15:00:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:00:54:WU01:FS01:0x22:Version 0.0.5
15:01:11:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
15:01:11:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:02:48:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
15:04:23:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
Based on your last log, this is the WU Project: 13851 (Run 0, Clone 24718, Gen 81)
I have reported this to the researcher.
Post by muziqaz »
From collection of logs, it seems, that your system is not very stable. Whichever log I scroll, its just overwhelming amount of straight up errors.
FAH Omega tester
The Ellesmere XT [Radeon RX 470/480/570/580/590] has had more than it's share of troubles, depending on the project. There's a known issue with OpenCL and AMD doesn't seem to be willing to support the drviers. The issue has been explored by the OpenMM developers and they believe they have a fix for the problem. It has not yet been rolled out, however so you'll have to wait until the back-port it to a special version of OpenMM.
When a new project is beta tested, if the known issue is noted, assignments of that project will be restricted. If the problem is not noted, nobody knows whether it might turn up later as the project progresses.
The only real fix will probably be a new version of FAHCore_22 that incorporates the change. They don't really have a good way to test it on this particular driver and hardware.
