Issues uploading WUs to 13.82.98.119 and 52.224.109.74
Hi there,
I have issues uploading completed WUs to Work Server 13.82.98.119 and Collection Server 52.224.109.74 since several days.
Folding and uploading to other servers works just fine, but there are now 5 WUs that simply don't get delivered. According to the serverstats the servers seem to be running just fine.
Any ideas?
Thanks a lot & stay safe,
Ettekite
Any ideas?
Ettekite
Re: Issues uploading WUs to 13.82.98.119 and 52.224.109.74
Welcome to the F@H Forum ettekite,
Please note that as long as you successfully uploaded the WUs, it will eventually be credited. Sometimes it requires a manual intervention but give it a week or so.
BTW, if you mean "WUs that simply don't get delivered" are you referring to the fact that they are not being uploaded from your system?
Thanks for your reply, PantherX!
Yes, correct. My system did the work and it shows currently around 73 failed attemps to upload just for a single WU. Credits clearly went down to the base credit, even though the work got done within a few hours. The job was assigned (and finished) on May 3rd but since then did not get uploaded. Other WUs (with different servers) went throught without any issues - same client, clearly.
Unfortunately, the WU that's on your system will be managed by the client. Hopefully, it will be uploaded to the Servers before the Expiration date. If you want, please post the log section showing the upload attempt and failure so we can investigate it further.
It is only happening for the WUs of the GPU, CPU is fine. I just finished a WU for 137517 credits but I'm ure it is going down to the minimum and will dissapear then. Sure, any help would be much appreciated. Shall I copy & paste the entire log?
14:57:12:WARNING:WU06:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:57:12:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:57:13:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:57:13:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:57:14:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:57:14:ERROR:WU05:FS01:Exception: Could not get an assignment
14:57:15:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:57:15:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:57:16:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:57:16:ERROR:WU05:FS01:Exception: Could not get an assignment
14:58:15:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
14:58:27:WARNING:WU05:FS01:WorkServer connection failed on port 8080 trying 80
14:58:39:ERROR:WU05:FS01:Exception: Failed to connect to 128.252.203.10:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
14:59:52:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:00:13:WARNING:WU05:FS01:WorkServer connection failed on port 8080 trying 80
15:00:35:ERROR:WU05:FS01:Exception: Failed to connect to 3.133.76.19:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
15:02:30:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:02:30:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:02:31:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:02:31:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:02:31:ERROR:WU05:FS01:Exception: Could not get an assignment
15:06:43:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:06:44:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:06:44:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:07:06:WARNING:WU05:FS01:WorkServer connection failed on port 8080 trying 80
15:07:45:ERROR:WU05:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:13:35:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:13:35:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:36:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:13:36:WARNING:WU05:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:36:ERROR:WU05:FS01:Exception: Could not get an assignment
15:25:02:WARNING:WU05:FS01:WorkServer connection failed on port 8080 trying 80
15:25:22:ERROR:WU05:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:35:11:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:12:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:12:ERROR:WU01:FS01:Exception: Transfer failed
15:35:12:ERROR:WU02:FS01:Exception: Transfer failed
15:35:12:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:12:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:12:ERROR:WU03:FS01:Exception: Transfer failed
15:35:12:ERROR:WU07:FS01:Exception: Transfer failed
15:35:13:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:13:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
15:35:13:ERROR:WU00:FS01:Exception: Transfer failed
15:35:13:ERROR:WU04:FS01:Exception: Transfer failed
15:42:43:ERROR:WU05:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:11:39:WARNING:WU05:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:28:34:WARNING:WU01:FS01:Past final deadline 2020-05-07T16:28:33Z, dumping
16:54:37:WARNING:WU05:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:54:38:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:54:38:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:54:59:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
16:56:09:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:56:09:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:56:10:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:56:10:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:56:10:ERROR:WU06:FS01:Exception: Could not get an assignment
16:57:10:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:57:10:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:11:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:11:ERROR:WU06:FS01:Exception: Could not get an assignment
16:59:06:ERROR:WU06:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:01:24:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:01:46:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
17:02:07:ERROR:WU06:FS01:Exception: Failed to connect to 3.133.76.19:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
17:05:47:ERROR:WU06:FS01:Exception: Server did not assign work unit
17:12:29:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:12:30:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:12:30:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:12:31:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:12:31:ERROR:WU06:FS01:Exception: Could not get an assignment
17:23:35:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:38:11:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
17:38:11:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
17:38:12:ERROR:WU02:FS01:Exception: Transfer failed
17:38:12:ERROR:WU03:FS01:Exception: Transfer failed
17:38:12:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
17:38:12:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
17:38:12:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
17:38:12:ERROR:WU07:FS01:Exception: Transfer failed
17:38:12:ERROR:WU04:FS01:Exception: Transfer failed
17:38:13:ERROR:WU00:FS01:Exception: Transfer failed
******************************* Date: 2020-05-07 *******************************
19:49:23:WARNING:WU02:FS01:Past final deadline 2020-05-07T19:49:22Z, dumping
20:42:44:WARNING:WU06:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:42:44:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:42:45:ERROR:WU06:FS01:Exception: Transfer failed
20:42:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:42:45:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:43:46:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:43:46:ERROR:WU06:FS01:Exception: Transfer failed
20:45:23:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:45:23:ERROR:WU06:FS01:Exception: Transfer failed
20:48:00:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:48:00:ERROR:WU06:FS01:Exception: Transfer failed
20:49:00:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:49:01:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:49:01:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:49:02:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:49:02:ERROR:WU02:FS01:Exception: Could not get an assignment
20:49:02:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:49:03:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:49:03:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:49:03:ERROR:WU02:FS01:Exception: Could not get an assignment
20:49:21:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:50:02:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:50:03:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:50:03:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:50:23:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:50:30:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
20:51:40:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:51:40:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:51:41:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:51:41:ERROR:WU02:FS01:Exception: Could not get an assignment
20:52:14:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:52:15:ERROR:WU06:FS01:Exception: Transfer failed
20:54:17:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:54:17:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:57:13:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
20:57:13:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
20:57:13:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
20:57:13:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
20:57:13:ERROR:WU07:FS01:Exception: Transfer failed
20:57:13:ERROR:WU00:FS01:Exception: Transfer failed
20:57:13:ERROR:WU03:FS01:Exception: Transfer failed
20:57:14:ERROR:WU04:FS01:Exception: Transfer failed
20:59:06:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
20:59:06:ERROR:WU06:FS01:Exception: Transfer failed
21:10:13:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
21:10:13:ERROR:WU06:FS01:Exception: Transfer failed
21:28:08:WARNING:WU06:FS01:Exception: Failed to send results to work server: Transfer failed
21:28:08:ERROR:WU06:FS01:Exception: Transfer failed
Based on the messages below, you might have an unstable system
My suggestion would be that you pause the client, restart your system and then post a fresh log from the beginning. If you require guidance, please see this topic: viewtopic.php?f=24&t=26036
Here a few comments on the topics mentioned above
- I restart my system on a regular basis
- WUs go through (get uploaded) if they are not from that server combination. Means: the slot is folding and able to upload
- I can confirm that my system is extremely stable. I clearly copied only the errors not the positive log entries.
Any additional ideas?
Regularly rebooting your system is fine... as long as it isn't during the checkpoint in which case, you will lose the WU. Best option would be to pause the client few minutes before rebooting the system.
Assuming you have only copied the errors, the log shows less than 24 hours (the date line is printed 4 times a day and in this case, is visible only once), that is still a lot of errors on your system
Moreover, this message means that your system is unable to complete the allocated WU within the Expiration date:
As I suggested, we will need to see your log files so we can understand what system you have (hardware wise) and how the client is configured.
Yes, I understand. Having around 35 years of IT experience I let the system finish WUs before restarting the system.
The log file is actually to long to paste it here. Shall I provide it for download or upload it somewhere?
Could you please post the first ~300 lines of the log file. They contain the information we need plus the initial messages which would be a good start
Sure! here you go:
*********************** Log Started 2020-05-07T12:17:46Z ***********************
12:17:46:****************************** FAHClient ******************************
12:17:46: Version: 7.6.9
12:17:46: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:17:46: Copyright: 2020 foldingathome.org
12:17:46: Homepage: https://foldingathome.org/
12:17:46: Date: Apr 17 2020
12:17:46: Time: 11:13:06
12:17:46: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:17:46: Branch: master
12:17:46: Compiler: Visual C++ 2008
12:17:46: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:17:46: Platform: win32 10
12:17:46: Bits: 32
12:17:46: Mode: Release
12:17:46: Args: --open-web-control
12:17:46: Config: C:\Users\srich\AppData\Roaming\FAHClient\config.xml
12:17:46:******************************** CBang ********************************
12:17:46: Time: 11:10:09
12:17:46: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:17:46: Bits: 32
12:17:46:******************************* System ********************************
12:17:46: CPU: AMD Ryzen 5 2600 Six-Core Processor
12:17:46: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
12:17:46: CPUs: 12
12:17:46: Memory: 31.95GiB
12:17:46: Free Memory: 19.53GiB
12:17:46: Threads: WINDOWS_THREADS
12:17:46: OS Version: 6.2
12:17:46: Has Battery: false
12:17:46: On Battery: false
12:17:46: UTC Offset: 2
12:17:46: PID: 4456
12:17:46: CWD: C:\Users\srich\AppData\Roaming\FAHClient
12:17:46: OS: Windows 10 Enterprise
12:17:46: OS Arch: AMD64
12:17:46: GPUs: 1
12:17:46: GPU 0: Bus:43 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
12:17:46: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
12:17:46: angegebene Modul wurde nicht gefunden.
12:17:46:
12:17:46:OpenCL Device 0: Platform:0 Device:0 Bus:43 Slot:0 Compute:1.2 Driver:2841.5
12:17:46: Win32 Service: false
12:17:46:******************************* libFAH ********************************
12:17:46: Date: Apr 15 2020
12:17:46: Time: 14:53:14
12:17:46: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:17:46: Bits: 32
12:17:46:***********************************************************************
12:17:46:<config>
12:17:46: <!-- Network -->
12:17:46: <proxy v=':8080'/>
12:17:46:
12:17:46: <!-- Slot Control -->
12:17:46: <power v='full'/>
12:17:46:
12:17:46: <!-- User Information -->
12:17:46: <passkey v='*****'/>
12:17:46: <team v='3'/>
12:17:46: <user v='Ettekite'/>
12:17:46:
12:17:46: <!-- Folding Slots -->
12:17:46: <slot id='0' type='CPU'/>
12:17:46: <slot id='1' type='GPU'/>
12:17:46:</config>
12:17:46:Trying to access database...
12:17:46:Successfully acquired database lock
12:17:46:Enabled folding slot 00: READY cpu:11
12:17:46:Enabled folding slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64]
12:17:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1861 gen:20 core:0x22 unit:0x000000240d5262775e84c8a549da0ff5
12:17:46:WU02:FS01:Uploading 291.84MiB to 13.82.98.119
12:17:46:WU02:FS01:Connecting to 13.82.98.119:8080
12:17:46:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14417 run:0 clone:310 gen:27 core:0x22 unit:0x0000002a0d5262775e84c8a616b779b5
12:17:46:WU03:FS01:Uploading 233.68MiB to 13.82.98.119
12:17:46:WU07:FS01:Sending unit results: id:07 state:SEND error:FAULTY project:14415 run:0 clone:305 gen:34 core:0x22 unit:0x0000002e0d5262775e839e5c1861bdea
12:17:46:WU03:FS01:Connecting to 13.82.98.119:8080
12:17:46:WU07:FS01:Uploading 212.19MiB to 13.82.98.119
12:17:46:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14417 run:0 clone:1305 gen:33 core:0x22 unit:0x000000300d5262775e84c8a517167678
12:17:46:WU07:FS01:Connecting to 13.82.98.119:8080
12:17:46:WU00:FS01:Uploading 209.77MiB to 13.82.98.119
12:17:46:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14416 run:0 clone:923 gen:16 core:0x22 unit:0x000000220d5262775e84c8a70524e6b7
12:17:46:WU00:FS01:Connecting to 13.82.98.119:8080
12:17:46:WU01:FS01:Uploading 260.81MiB to 13.82.98.119
12:17:46:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14415 run:0 clone:922 gen:32 core:0x22 unit:0x000000330d5262775e839e5c8fa6e7ca
12:17:46:WU01:FS01:Connecting to 13.82.98.119:8080
12:17:46:WU04:FS01:Uploading 286.29MiB to 13.82.98.119
12:17:46:WU04:FS01:Connecting to 13.82.98.119:8080
12:17:46:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU02:FS01:Trying to send results to collection server
12:17:46:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU02:FS01:Uploading 291.84MiB to 52.224.109.74
12:17:46:WU03:FS01:Trying to send results to collection server
12:17:46:WU02:FS01:Connecting to 52.224.109.74:8080
12:17:46:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU03:FS01:Uploading 233.68MiB to 52.224.109.74
12:17:46:WU01:FS01:Trying to send results to collection server
12:17:46:WU03:FS01:Connecting to 52.224.109.74:8080
12:17:46:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU01:FS01:Uploading 260.81MiB to 52.224.109.74
12:17:46:WU00:FS01:Trying to send results to collection server
12:17:46:WU01:FS01:Connecting to 52.224.109.74:8080
12:17:46:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU00:FS01:Uploading 209.77MiB to 52.224.109.74
12:17:46:WU04:FS01:Trying to send results to collection server
12:17:46:WU00:FS01:Connecting to 52.224.109.74:8080
12:17:46:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:46:WU04:FS01:Uploading 286.29MiB to 52.224.109.74
12:17:46:WU07:FS01:Trying to send results to collection server
12:17:46:WU04:FS01:Connecting to 52.224.109.74:8080
12:17:46:WU07:FS01:Uploading 212.19MiB to 52.224.109.74
12:17:46:WU07:FS01:Connecting to 52.224.109.74:8080
12:17:47:ERROR:WU02:FS01:Exception: Transfer failed
12:17:47:ERROR:WU03:FS01:Exception: Transfer failed
12:17:47:ERROR:WU01:FS01:Exception: Transfer failed
12:17:47:WU05:FS00:Connecting to 65.254.110.245:80
12:17:47:ERROR:WU00:FS01:Exception: Transfer failed
12:17:47:WU06:FS01:Connecting to 65.254.110.245:80
12:17:47:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14416 run:0 clone:923 gen:16 core:0x22 unit:0x000000220d5262775e84c8a70524e6b7
12:17:47:ERROR:WU04:FS01:Exception: Transfer failed
12:17:47:WU01:FS01:Uploading 260.81MiB to 13.82.98.119
12:17:47:WU01:FS01:Connecting to 13.82.98.119:8080
12:17:47:ERROR:WU07:FS01:Exception: Transfer failed
12:17:47:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14417 run:0 clone:1305 gen:33 core:0x22 unit:0x000000300d5262775e84c8a517167678
12:17:47:WU00:FS01:Uploading 209.77MiB to 13.82.98.119
12:17:47:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1861 gen:20 core:0x22 unit:0x000000240d5262775e84c8a549da0ff5
12:17:47:WU00:FS01:Connecting to 13.82.98.119:8080
12:17:47:WU02:FS01:Uploading 291.84MiB to 13.82.98.119
12:17:47:WU02:FS01:Connecting to 13.82.98.119:8080
12:17:47:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:47:WU01:FS01:Trying to send results to collection server
12:17:47:WU01:FS01:Uploading 260.81MiB to 52.224.109.74
12:17:47:WU01:FS01:Connecting to 52.224.109.74:8080
12:17:47:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14417 run:0 clone:310 gen:27 core:0x22 unit:0x0000002a0d5262775e84c8a616b779b5
12:17:47:WU03:FS01:Uploading 233.68MiB to 13.82.98.119
12:17:47:WU03:FS01:Connecting to 13.82.98.119:8080
12:17:47:WU06:FS01:Assigned to work server 128.252.203.10
12:17:47:WU06:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 128.252.203.10
12:17:47:WU05:FS00:Assigned to work server 155.247.164.214
12:17:47:WU06:FS01:Connecting to 128.252.203.10:8080
12:17:47:WU05:FS00:Requesting new work unit for slot 00: READY cpu:11 from 155.247.164.214
12:17:47:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:47:WU05:FS00:Connecting to 155.247.164.214:8080
12:17:47:WU02:FS01:Trying to send results to collection server
12:17:47:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:47:WU02:FS01:Uploading 291.84MiB to 52.224.109.74
12:17:47:WU00:FS01:Trying to send results to collection server
12:17:47:WU02:FS01:Connecting to 52.224.109.74:8080
12:17:47:WU00:FS01:Uploading 209.77MiB to 52.224.109.74
12:17:47:WU00:FS01:Connecting to 52.224.109.74:8080
12:17:47:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:47:WU03:FS01:Trying to send results to collection server
12:17:47:WU03:FS01:Uploading 233.68MiB to 52.224.109.74
12:17:47:WU03:FS01:Connecting to 52.224.109.74:8080
12:17:47:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14415 run:0 clone:922 gen:32 core:0x22 unit:0x000000330d5262775e839e5c8fa6e7ca
12:17:47:WU04:FS01:Uploading 286.29MiB to 13.82.98.119
12:17:47:WU04:FS01:Connecting to 13.82.98.119:8080
12:17:47:WU07:FS01:Sending unit results: id:07 state:SEND error:FAULTY project:14415 run:0 clone:305 gen:34 core:0x22 unit:0x0000002e0d5262775e839e5c1861bdea
12:17:47:WU07:FS01:Uploading 212.19MiB to 13.82.98.119
12:17:47:WU05:FS00:Downloading 2.83MiB
12:17:47:WU07:FS01:Connecting to 13.82.98.119:8080
12:17:48:ERROR:WU03:FS01:Exception: Transfer failed
12:17:48:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:48:WU04:FS01:Trying to send results to collection server
12:17:48:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
12:17:48:WU04:FS01:Uploading 286.29MiB to 52.224.109.74
12:17:48:WU07:FS01:Trying to send results to collection server
12:17:48:WU04:FS01:Connecting to 52.224.109.74:8080
12:17:48:WU07:FS01:Uploading 212.19MiB to 52.224.109.74
12:17:48:WU07:FS01:Connecting to 52.224.109.74:8080
12:17:48:ERROR:WU04:FS01:Exception: Transfer failed
12:17:48:ERROR:WU07:FS01:Exception: Transfer failed
12:17:50:17:127.0.0.1:New Web session
12:17:50:WU05:FS00:Download complete
12:17:50:WU05:FS00:Received Unit: id:05 state:DOWNLOAD error:NO_ERROR project:14728 run:250 clone:1 gen:9 core:0xa7 unit:0x000000099bf7a4d65ea6f25a845b89f6
12:17:50:WU05:FS00:Starting
12:17:50:WU05:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\srich\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 05 -suffix 01 -version 706 -lifeline 4456 -checkpoint 15 -np 11
12:17:50:WU05:FS00:Started FahCore on PID 6604
12:17:50:WU05:FS00:Core PID:28164
12:17:50:WU05:FS00:FahCore 0xa7 started
12:17:51:WU05:FS00:0xa7:*********************** Log Started 2020-05-07T12:17:50Z ***********************
12:17:51:WU05:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:17:51:WU05:FS00:0xa7: Type: 0xa7
12:17:51:WU05:FS00:0xa7: Core: Gromacs
12:17:51:WU05:FS00:0xa7: Args: -dir 05 -suffix 01 -version 706 -lifeline 6604 -checkpoint 15 -np
12:17:51:WU05:FS00:0xa7: 11
12:17:51:WU05:FS00:0xa7:************************************ CBang *************************************
12:17:51:WU05:FS00:0xa7: Date: Oct 26 2019
12:17:51:WU05:FS00:0xa7: Time: 01:38:25
12:17:51:WU05:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:17:51:WU05:FS00:0xa7: Branch: master
12:17:51:WU05:FS00:0xa7: Compiler: Visual C++ 2008
12:17:51:WU05:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:17:51:WU05:FS00:0xa7: Platform: win32 10
12:17:51:WU05:FS00:0xa7: Bits: 64
12:17:51:WU05:FS00:0xa7: Mode: Release
12:17:51:WU05:FS00:0xa7:************************************ System ************************************
12:17:51:WU05:FS00:0xa7: CPU: AMD Ryzen 5 2600 Six-Core Processor
12:17:51:WU05:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
12:17:51:WU05:FS00:0xa7: CPUs: 12
12:17:51:WU05:FS00:0xa7: Memory: 31.95GiB
12:17:51:WU05:FS00:0xa7:Free Memory: 19.46GiB
12:17:51:WU05:FS00:0xa7: Threads: WINDOWS_THREADS
12:17:51:WU05:FS00:0xa7: OS Version: 6.2
12:17:51:WU05:FS00:0xa7:Has Battery: false
12:17:51:WU05:FS00:0xa7: On Battery: false
12:17:51:WU05:FS00:0xa7: UTC Offset: 2
12:17:51:WU05:FS00:0xa7: PID: 28164
12:17:51:WU05:FS00:0xa7: CWD: C:\Users\srich\AppData\Roaming\FAHClient\work
12:17:51:WU05:FS00:0xa7:******************************** Build - libFAH ********************************
12:17:51:WU05:FS00:0xa7: Version: 0.0.18
12:17:51:WU05:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:17:51:WU05:FS00:0xa7: Copyright: 2019 foldingathome.org
12:17:51:WU05:FS00:0xa7: Homepage: https://foldingathome.org/
12:17:51:WU05:FS00:0xa7: Time: 01:52:30
12:17:51:WU05:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:17:51:WU05:FS00:0xa7:************************************ Build *************************************
12:17:51:WU05:FS00:0xa7: SIMD: avx_256
12:17:51:WU05:FS00:0xa7:********************************************************************************
12:17:51:WU05:FS00:0xa7:Project: 14728 (Run 250, Clone 1, Gen 9)
12:17:51:WU05:FS00:0xa7:Unit: 0x000000099bf7a4d65ea6f25a845b89f6
12:17:51:WU05:FS00:0xa7:Reading tar file core.xml
12:17:51:WU05:FS00:0xa7:Reading tar file frame9.tpr
12:17:51:WU05:FS00:0xa7:Digital signatures verified
12:17:51:WU05:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
12:17:51:WU05:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -cpt 15 -nt 10
12:17:51:WU05:FS00:0xa7:Steps: first=0 total=250000
12:17:52:WU05:FS00:0xa7:Completed 1 out of 250000 steps (0%)
12:18:08:WARNING:WU06:FS01:WorkServer connection failed on port 8080 trying 80
12:18:08:WU06:FS01:Connecting to 128.252.203.10:80
12:18:47:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14416 run:0 clone:923 gen:16 core:0x22 unit:0x000000220d5262775e84c8a70524e6b7
12:18:47:WU01:FS01:Uploading 260.81MiB to 13.82.98.119
12:18:47:WU01:FS01:Connecting to 13.82.98.119:8080
12:18:47:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1861 gen:20 core:0x22 unit:0x000000240d5262775e84c8a549da0ff5
12:18:47:WU02:FS01:Uploading 291.84MiB to 13.82.98.119
12:18:47:WU02:FS01:Connecting to 13.82.98.119:8080
12:18:47:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:47:WU01:FS01:Trying to send results to collection server
12:18:47:WU01:FS01:Uploading 260.81MiB to 52.224.109.74
12:18:47:WU01:FS01:Connecting to 52.224.109.74:8080
12:18:47:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14417 run:0 clone:310 gen:27 core:0x22 unit:0x0000002a0d5262775e84c8a616b779b5
12:18:47:WU03:FS01:Uploading 233.68MiB to 13.82.98.119
12:18:47:WU03:FS01:Connecting to 13.82.98.119:8080
12:18:47:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:47:WU02:FS01:Trying to send results to collection server
12:18:47:WU02:FS01:Uploading 291.84MiB to 52.224.109.74
12:18:47:WU02:FS01:Connecting to 52.224.109.74:8080
12:18:47:ERROR:WU01:FS01:Exception: Transfer failed
12:18:47:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14415 run:0 clone:922 gen:32 core:0x22 unit:0x000000330d5262775e839e5c8fa6e7ca
12:18:47:WU04:FS01:Uploading 286.29MiB to 13.82.98.119
12:18:47:WU04:FS01:Connecting to 13.82.98.119:8080
12:18:48:WU07:FS01:Sending unit results: id:07 state:SEND error:FAULTY project:14415 run:0 clone:305 gen:34 core:0x22 unit:0x0000002e0d5262775e839e5c1861bdea
12:18:48:WU07:FS01:Uploading 212.19MiB to 13.82.98.119
12:18:48:WU07:FS01:Connecting to 13.82.98.119:8080
12:18:48:WARNING:WU03:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:48:WU03:FS01:Trying to send results to collection server
12:18:48:WU03:FS01:Uploading 233.68MiB to 52.224.109.74
12:18:48:WU03:FS01:Connecting to 52.224.109.74:8080
12:18:48:ERROR:WU02:FS01:Exception: Transfer failed
12:18:48:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14417 run:0 clone:1305 gen:33 core:0x22 unit:0x000000300d5262775e84c8a517167678
12:18:48:WU00:FS01:Uploading 209.77MiB to 13.82.98.119
12:18:48:WU00:FS01:Connecting to 13.82.98.119:8080
12:18:48:WARNING:WU04:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:48:WU04:FS01:Trying to send results to collection server
12:18:48:WU04:FS01:Uploading 286.29MiB to 52.224.109.74
12:18:48:WU04:FS01:Connecting to 52.224.109.74:8080
12:18:48:WARNING:WU07:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:48:WU07:FS01:Trying to send results to collection server
12:18:48:WU07:FS01:Uploading 212.19MiB to 52.224.109.74
12:18:48:WU07:FS01:Connecting to 52.224.109.74:8080
12:18:48:ERROR:WU03:FS01:Exception: Transfer failed
12:18:48:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
12:18:48:WU00:FS01:Trying to send results to collection server
12:18:48:ERROR:WU04:FS01:Exception: Transfer failed
12:18:48:WU00:FS01:Uploading 209.77MiB to 52.224.109.74
12:18:48:WU00:FS01:Connecting to 52.224.109.74:8080
12:18:48:ERROR:WU07:FS01:Exception: Transfer failed
12:18:49:ERROR:WU00:FS01:Exception: Transfer failed
12:19:08:WU06:FS01:Downloading 51.20MiB
12:19:10:WU05:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
12:19:14:WU06:FS01:Download 7.94%
12:19:20:WU06:FS01:Download 16.73%
12:20:04:WU06:FS01:Download 20.19%
12:20:04:ERROR:WU06:FS01:Exception: Transfer failed
12:20:04:WU06:FS01:Connecting to 65.254.110.245:80
12:20:04:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:20:04:WU06:FS01:Connecting to 18.218.241.186:80
12:20:05:WARNING:WU06:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:20:05:WU06:FS01:Connecting to 65.254.110.245:80
12:20:05:WARNING:WU06:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:20:05:WU06:FS01:Connecting to 18.218.241.186:80
12:20:05:ERROR:WU06:FS01:Exception: Could not get an assignment
12:20:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14416 run:0 clone:923 gen:16 core:0x22 unit:0x000000220d5262775e84c8a70524e6b7
12:20:24:WU01:FS01:Uploading 260.81MiB to 13.82.98.119
12:20:24:WU01:FS01:Connecting to 13.82.98.119:8080
12:20:24:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:20:24:WU01:FS01:Trying to send results to collection server
12:20:24:WU01:FS01:Uploading 260.81MiB to 52.224.109.74
12:20:24:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1861 gen:20 core:0x22 unit:0x000000240d5262775e84c8a549da0ff5
12:20:24:WU01:FS01:Connecting to 52.224.109.74:8080
12:20:24:WU02:FS01:Uploading 291.84MiB to 13.82.98.119
12:20:24:WU02:FS01:Connecting to 13.82.98.119:8080
12:20:24:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14417 run:0 clone:310 gen:27 core:0x22 unit:0x0000002a0d5262775e84c8a616b779b5
12:20:24:WU03:FS01:Uploading 233.68MiB to 13.82.98.119
12:20:24:WU03:FS01:Connecting to 13.82.98.119:8080
12:20:24:ERROR:WU01:FS01:Exception: Transfer failed
12:20:24:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14415 run:0 clone:922 gen:32 core:0x22 unit:0x000000330d5262775e839e5c8fa6e7ca
12:20:25:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
12:20:25:WU04:FS01:Uploading 286.29MiB to 13.82.98.119
12:20:25:WU02:FS01:Trying to send results to collection server
12:20:25:WU04:FS01:Connecting to 13.82.98.119:8080
12:20:25:WU02:FS01:Uploading 291.84MiB to 52.224.109.74
12:20:25:WU02:FS01:Connecting to 52.224.109.74:8080
12:20:25:WU07:FS01:Sending unit results: id:07 state:SEND error:FAULTY project:14415 run:0 clone:305 gen:34 core:0x22 unit:0x0000002e0d5262775e839e5c1861bdea
I would suggest that you manually set your CPU to 10 by following this:
Advanced Control (AKA FAHControl) -> Configure -> Slots Tab -> CPU Slot -> Edit -> Change value from -1 to 10
That way, you will no longer see this line in your log file:
Also, it seems that your GPU may require a closer examination as it has failed 5 out of 6 WUs:
project:14416 run:0 clone:1861 gen:20 -> Completed successfully: https://apps.foldingathome.org/wu#proje ... 861&gen=20
project:14417 run:0 clone:310 gen:27 -> Completed successfully but other had issues too: https://apps.foldingathome.org/wu#proje ... 310&gen=27
project:14415 run:0 clone:305 gen:34 -> Not yet in the system
project:14417 run:0 clone:1305 gen:33 -> Completed successfully: https://apps.foldingathome.org/wu#proje ... 305&gen=33
project:14416 run:0 clone:923 gen:16 -> Completed successfully but others had issues too: https://apps.foldingathome.org/wu#proje ... 923&gen=16
project:14415 run:0 clone:922 gen:32 -> Completed successfully but others had issues too: https://apps.foldingathome.org/wu#proje ... 922&gen=32
CPU is set to 10 - thanks for that!
"it seems that your GPU may require a closer examination..." - is there anything I can provide to you to help me with that? It worked perfectly fine the past weeks only happened recently (hardware did NOT get changed at all)
To allow you to upload the successfully completed WUs, I would suggest that you quit the client and delete the correct folder from here C:\Users\srich\AppData\Roaming\FAHClient\work as the science has continued:
12:17:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:14416 run:0 clone:1861 gen:20 -> Delete folder 02
12:17:46:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:14417 run:0 clone:310 gen:27 -> Delete folder 03
12:17:46:WU07:FS01:Sending unit results: id:07 state:SEND error:FAULTY project:14415 run:0 clone:305 gen:34 -> Delete folder 07
12:17:46:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14417 run:0 clone:1305 gen:33 -> Do not delete folder 00
12:17:46:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14416 run:0 clone:923 gen:16 -> Delete folder 01
12:17:46:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:14415 run:0 clone:922 gen:32 -> Delete folder 04
That way, you can hopefully upload the completed WU and get credits for it.
The reason you might be encountering this issue now is Project 14415 to 14417 were released this week (viewtopic.php?f=24&t=34095) and are rather big as the atom counts vary from 274,297 to 307,167. A large atom count generally means more stress which could explain why you are encountering those issues now. For hardware issues, please work through this topic and hopefully, you can resolve the issue: viewtopic.php?f=19&t=16526
