rpalri
Posts: 17 Joined: Tue May 05, 2020 11:40 am
Post
by rpalri » Tue May 05, 2020 11:46 am
I'm using a 2008 vintage PC with a NVIDIA GeForce 9400 GT.
It kept trying to obtain a WU assignment to no avail. Thinking it might be a problem with the server, I uninstalled F@H and reinstalled. Same deal each time. Lately the logs have shown that there was a problem connecting:
09:06:35:WU00:FS00:Connecting to 65.254.110.245:80
09:06:37:WU00:FS00:Assigned to work server 192.0.2.1
09:06:37:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:G96 [GeForce 9400 GT] from 192.0.2.1
09:06:37:WU00:FS00:Connecting to 192.0.2.1:8080
09:06:58:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:06:58:WU00:FS00:Connecting to 192.0.2.1:80
09:07:19:ERROR:WU00:FS00:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
The CPU slot is working but it seems a waste to just use it when the GPU has done so well in the past.
All device drivers are up to date and the F@H client version is 7.6.9. Is there something I'm missing?
Posts: 8343 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Tue May 05, 2020 12:57 pm
The 9400 GT is too old to be used for GPU folding. Current minimum nVidia GPU would be one from the GT 400 series or newer, GT 600 or newer is recommended.
rpalri
Post
by rpalri » Tue May 05, 2020 1:55 pm
Thanks for the information @Joe_H
My CPU remains underutilized too because 1 thread is kept for the GPU. Is there a way I can atleast put the CPU to 100% use?
HaloJones
Posts: 914 Joined: Thu Jul 24, 2008 10:16 am
Post
by HaloJones » Tue May 05, 2020 3:32 pm
delete the gpu slot, set the slider to full
4070 super
Posts: 1996 Joined: Sun Mar 22, 2020 5:52 pm
Hardware configuration: 1: 2x Xeon E5-2697v3@2.60GHz, 512GB DDR4 LRDIMM, SSD Raid, Win10 Ent 20H2, Quadro K420 1GB, FAH 7.6.21 2: Xeon E3-1505Mv5@2.80GHz, 32GB DDR4, NVME, Win10 Pro 20H2, Quadro M1000M 2GB, FAH 7.6.21 (actually have two of these) 3: i7-960@3.20GHz, 12GB DDR3, SSD, Win10 Pro 20H2, GTX 750Ti 2GB, GTX 1080Ti 11GB, FAH 7.6.21
Post
by Neil-B » Tue May 05, 2020 3:39 pm
... or edit the CPU slot and replace the CPU figure in there (possibly -1) with the full number of cores/threads you have.
rpalri
Post
by rpalri » Tue May 05, 2020 3:54 pm
Nope. Neither of these worked. @HolaJones @Neil-B
Post
by Neil-B » Tue May 05, 2020 4:02 pm
Odd … can you post your log including the first couple of hundred lines and any latest config report … with no GPU slot and either -1 in CPU slot configuration with slider on Full or actual number of cores/threads in the CPU slot configuration should do it
Post
by Neil-B » Tue May 05, 2020 4:03 pm
Ah … hang on .. it won't change until the next WU … can't uplift CPUs above what was set at WU download.
rpalri
Post
by rpalri » Tue May 05, 2020 5:10 pm
Oh. Okay. Let me wait and see. I'll update here as it finishes. ETA 23 hours 31 minutes.
Crunchtimer
Posts: 50 Joined: Tue May 05, 2020 5:34 am
Post
by Crunchtimer » Tue May 05, 2020 5:59 pm
Hi, I
believe you can restart the Fahclient to get the GPU change in effect without losing the WU.
At least I can on both Windows and Linux.
You can also directly edit the config-file for the change as specified in this guide
https://medium.com/@julsimon/running-fo ... 6bb8f84218 In Windows it's under C:\Users\User\AppData\Roaming\FAHClient/
However, today my GPU is not getting any work at all, so I think there is some problem with the GPU WU assignment generally today.
Post
by Neil-B » Tue May 05, 2020 7:08 pm
Iirc a WU can/will not run at a higher CPU core count that that it was downloaded at ... but I am happy to be proven wrong.
rpalri
Post
by rpalri » Tue May 05, 2020 11:56 pm
@Crunchtimer Tried both y0our methods. Neither worked.
Posts: 2521 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Wed May 06, 2020 1:20 am
Honest, once you show us the first 200 lines of the log, the solution will go much faster.
viewtopic.php?f=24&t=26036
rpalri
Post
by rpalri » Wed May 06, 2020 2:46 am
There you go:
*********************** Log Started 2020-05-06T02:44:52Z ***********************
02:44:52:****************************** FAHClient ******************************
02:44:52: Version: 7.6.9
02:44:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:44:52: Copyright: 2020 foldingathome.org
02:44:52: Homepage: https://foldingathome.org/
02:44:52: Date: Apr 17 2020
02:44:52: Time: 11:13:06
02:44:52: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
02:44:52: Branch: master
02:44:52: Compiler: Visual C++ 2008
02:44:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:44:52: Platform: win32 10
02:44:52: Bits: 32
02:44:52: Mode: Release
02:44:52: Config: C:\Users\Palriwala\AppData\Roaming\FAHClient\config.xml
02:44:52:******************************** CBang ********************************
02:44:52: Time: 11:10:09
02:44:52: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
02:44:52: Bits: 32
02:44:52:******************************* System ********************************
02:44:52: CPU: Intel(R) Core(TM)2 Duo CPU E4600 @ 2.40GHz
02:44:52: CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
02:44:52: CPUs: 2
02:44:52: Memory: 2.00GiB
02:44:52: Free Memory: 1.36GiB
02:44:52: Threads: WINDOWS_THREADS
02:44:52: OS Version: 6.1
02:44:52: Has Battery: false
02:44:52: On Battery: false
02:44:52: UTC Offset: -7
02:44:52: PID: 3056
02:44:52: CWD: C:\Users\Palriwala\AppData\Roaming\FAHClient
02:44:52: OS: Windows 7 Ultimate
02:44:52: OS Arch: X86
02:44:52: GPUs: 1
02:44:52: GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:0 G96 [GeForce 9400 GT]
02:44:52: CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.1 Driver:6.5
02:44:52:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.0 Driver:342.1
02:44:52: Win32 Service: false
02:44:52:******************************* libFAH ********************************
02:44:52: Date: Apr 15 2020
02:44:52: Time: 14:53:14
02:44:52: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
02:44:52: Bits: 32
02:44:52:***********************************************************************
02:44:52:<config>
02:44:52: <!-- Folding Core -->
02:44:52: <core-priority v='low'/>
02:44:52:
02:44:52: <!-- Folding Slot Configuration -->
02:44:52: <cause v='COVID_19'/>
02:44:52:
02:44:52: <!-- Network -->
02:44:52: <proxy v=':8080'/>
02:44:52:
02:44:52: <!-- Slot Control -->
02:44:52: <power v='full'/>
02:44:52:
02:44:52: <!-- User Information -->
02:44:52: <passkey v='*****'/>
02:44:52: <team v='264366'/>
02:44:52: <user v='palri-gpu2'/>
02:44:52:
02:44:52: <!-- Folding Slots -->
02:44:52: <slot id='1' type='CPU'/>
02:44:52:</config>
02:44:52:Trying to access database...
02:44:52:Successfully acquired database lock
02:44:52:Enabled folding slot 01: READY cpu:2
02:44:53:WU01:FS01:Starting
02:44:53:WARNING:WU01:FS01:AS lowered CPUs from 2 to 1
02:44:53:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\Palriwala\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/32bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 3056 -checkpoint 15 -np 1
02:44:53:WU01:FS01:Started FahCore on PID 3264
02:44:53:WU01:FS01:Core PID:3280
02:44:53:WU01:FS01:FahCore 0xa7 started
02:44:59:WU01:FS01:0xa7:*********************** Log Started 2020-05-06T02:44:59Z ***********************
02:44:59:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
02:44:59:WU01:FS01:0xa7: Type: 0xa7
02:44:59:WU01:FS01:0xa7: Core: Gromacs
02:44:59:WU01:FS01:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 3264 -checkpoint 15 -np 1
02:44:59:WU01:FS01:0xa7:************************************ CBang *************************************
02:44:59:WU01:FS01:0xa7: Date: Oct 26 2019
02:44:59:WU01:FS01:0xa7: Time: 01:27:58
02:44:59:WU01:FS01:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:44:59:WU01:FS01:0xa7: Branch: master
02:44:59:WU01:FS01:0xa7: Compiler: Visual C++ 2008
02:44:59:WU01:FS01:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:44:59:WU01:FS01:0xa7: Platform: win32 10
02:44:59:WU01:FS01:0xa7: Bits: 32
02:44:59:WU01:FS01:0xa7: Mode: Release
02:44:59:WU01:FS01:0xa7:************************************ System ************************************
02:44:59:WU01:FS01:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU E4600 @ 2.40GHz
02:44:59:WU01:FS01:0xa7: CPU ID: GenuineIntel Family 6 Model 15 Stepping 13
02:44:59:WU01:FS01:0xa7: CPUs: 2
02:44:59:WU01:FS01:0xa7: Memory: 2.00GiB
02:44:59:WU01:FS01:0xa7:Free Memory: 1.31GiB
02:44:59:WU01:FS01:0xa7: Threads: WINDOWS_THREADS
02:44:59:WU01:FS01:0xa7: OS Version: 6.1
02:44:59:WU01:FS01:0xa7:Has Battery: false
02:44:59:WU01:FS01:0xa7: On Battery: false
02:44:59:WU01:FS01:0xa7: UTC Offset: -7
02:44:59:WU01:FS01:0xa7: PID: 3280
02:44:59:WU01:FS01:0xa7: CWD: C:\Users\Palriwala\AppData\Roaming\FAHClient\work
02:44:59:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
02:44:59:WU01:FS01:0xa7: Version: 0.0.18
02:44:59:WU01:FS01:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:44:59:WU01:FS01:0xa7: Copyright: 2019 foldingathome.org
02:44:59:WU01:FS01:0xa7: Homepage: https://foldingathome.org/
02:44:59:WU01:FS01:0xa7: Time: 01:34:37
02:44:59:WU01:FS01:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:44:59:WU01:FS01:0xa7:************************************ Build *************************************
02:44:59:WU01:FS01:0xa7: SIMD: sse2
02:44:59:WU01:FS01:0xa7:********************************************************************************
02:44:59:WU01:FS01:0xa7:Project: 14546 (Run 0, Clone 357, Gen 59)
02:44:59:WU01:FS01:0xa7:Unit: 0x000000460d5262775e80ea3bcfe88f1b
02:44:59:WU01:FS01:0xa7:Digital signatures verified
02:44:59:WU01:FS01:0xa7:Calling: mdrun -s frame59.tpr -o frame59.trr -x frame59.xtc -cpi state.cpt -cpt 15 -nt 1
02:45:02:WU01:FS01:0xa7:Steps: first=29500000 total=500000
02:45:04:WU01:FS01:0xa7:Completed 346571 out of 500000 steps (69%)
anandhanju
Posts: 522 Joined: Mon Dec 03, 2007 4:33 am
Post
by anandhanju » Wed May 06, 2020 3:01 am
It looks good to me.
`02:44:53:WARNING:WU01:FS01:AS lowered CPUs from 2 to 1` means that the current WU was downloaded when the CPU slot was allocated to use 1 CPUs. The system is attempting to bump that up that to 2 now but there is a restriction that prevents downloaded WUs from using more CPUs that when then client got it.
Your next CPU WU should be running with 2 CPUs as the config and logs look good otherwise.
