CPU stuck at low usage while folding
- Hardware configuration: Oldest hardware:
4* Intel(R) Core i5-230M CPU @ 2.40 GHz
NVIDIA GeForce GT 520MX
6 GB RAM
Newest hardware:
4* AMD A12-9720P RADEON R7, 12 COMPUTE CORE 4C+8G
AMD ATI RADEON (TM) R7 M340
16 GB RAM - Location: Italy, Umbria, Perugia (PG)
Goodmorning folders,
Is a few days that I noticed that my CPU (AMD A12-9720 RADEON R7 COMPUTE CORE 4C+8G) is stucked on low usage (seeing from task manager of Windows 10), infact when I fold I can see that is only using almost 12-20% of my computing power, and is working only about 0.7-1.0 GHz frequency, can someone explain me why? (I don't think is necessary to show my log because I think is not related to my configuration but maybe something in my pc's settings).
In addition if I check my PC's stats (GPU0, GPU1 and CPU usage) from the AMD panel I can see that is using almost 100%, so now the question becomes: which method could be more suitable for checking my PC usage? Or better explained, do you suggest me to check them from Task Manger or AMD controlo panel?
In summary, I'm afraid that I'm using only 20% of my computing power, if I could use about 80/90 I'll be happiest.
Maybe is useless to tell you, but I've set up the Client at full folding power, that's why I'm confused on his usage.
I'm asking this because I noticed that in my second (and older) notebook, which has an Intel i5 and Windows 7, it use constantly about 90-100% of computing power.
Thank you for your time, and sorry if I posted the question in wrong topic, have a nice day.
Re: CPU stuck at low usage while folding
Welcome to the F@H Forum BrunoL,
Can you please post your log file so that we can see what the client has detected your hardware as and how it is configured? I appreciate that you have described what hardware you have and how you have configured it which will then allow us to compare and see where the issue lies. Plus, we can also see how the WUs are progressing which may provide some additional insight.
I am guessing that you have a mobile device so can you verify that the temperature of the CPU/GPU are within reasonable limits? Reason is poor ventilation for mobile/desktop can cause the CPU/GPU to throttle back to prevent overheating failures.
If you need guidance on posting logs see the "Welcome to …" link in PantherX's sig block … Please make sure you include at least the top hundred lines or so that has the system configuration
6 GB RAM
Newest hardware:
Sure, I'll post my log file below here, thank you both for your fast reply!
And yes, i'm checking my temperature using AMD control panel on Windows and smartphone.
In addition to that, I've also seen that from Task Manager i'm using 0% of my GPU1, while on AMD Control Panel I'm seeing that it's using at full load (100%), which one of program should I believe most?
*********************** Log Started 2020-05-05T06:59:50Z ***********************
06:59:50:****************************** FAHClient ******************************
06:59:50: Version: 7.6.9
06:59:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:59:50: Copyright: 2020 foldingathome.org
06:59:50: Homepage: https://foldingathome.org/
06:59:50: Date: Apr 17 2020
06:59:50: Time: 11:13:06
06:59:50: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
06:59:50: Branch: master
06:59:50: Compiler: Visual C++ 2008
06:59:50: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:59:50: Platform: win32 10
06:59:50: Bits: 32
06:59:50: Mode: Release
06:59:50: Args: --open-web-control
06:59:50: Config: C:\Users\bruno\AppData\Roaming\FAHClient\config.xml
06:59:50:******************************** CBang ********************************
06:59:50: Time: 11:10:09
06:59:50: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
06:59:50: Bits: 32
06:59:50:******************************* System ********************************
06:59:50: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
06:59:50: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
06:59:50: CPUs: 4
06:59:50: Memory: 15.47GiB
06:59:50: Free Memory: 11.96GiB
06:59:50: Threads: WINDOWS_THREADS
06:59:50: OS Version: 6.2
06:59:50: Has Battery: true
06:59:50: On Battery: false
06:59:50: UTC Offset: 2
06:59:50: PID: 13188
06:59:50: CWD: C:\Users\bruno\AppData\Roaming\FAHClient
06:59:50: OS: Windows 10 Home
06:59:50: OS Arch: AMD64
06:59:50: GPUs: 2
06:59:50: GPU 0: Bus:5 Slot:0 Func:0 AMD:5 Mars [Radeon R7 M260/M265/M270]
06:59:50: GPU 1: Bus:0 Slot:1 Func:0 AMD:5 Carrizo [Radeon R7/R6/R5 Series]
06:59:50: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
06:59:50: Impossibile trovare il modulo specificato.
06:59:50:
06:59:50:OpenCL Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:3004.8
06:59:50:OpenCL Device 1: Platform:0 Device:1 Bus:0 Slot:1 Compute:1.2 Driver:3004.8
06:59:50: Win32 Service: false
06:59:50:******************************* libFAH ********************************
06:59:50: Date: Apr 15 2020
06:59:50: Time: 14:53:14
06:59:50: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:59:50: Bits: 32
06:59:50:***********************************************************************
06:59:50:<config>
06:59:50: <!-- Folding Core -->
06:59:50: <checkpoint v='5'/>
06:59:50:
06:59:50: <!-- Folding Slot Configuration -->
06:59:50: <cause v='COVID_19'/>
06:59:50:
06:59:50: <!-- Network -->
06:59:50: <proxy v=':8080'/>
06:59:50:
06:59:50: <!-- Slot Control -->
06:59:50: <power v='full'/>
06:59:50:
06:59:50: <!-- User Information -->
06:59:50: <passkey v='*****'/>
06:59:50: <team v='260847'/>
06:59:50: <user v='BrunoL98'/>
06:59:50:
06:59:50: <!-- Folding Slots -->
06:59:50: <slot id='0' type='CPU'>
06:59:50: <cpus v='4'/>
06:59:50: </slot>
06:59:50: <slot id='1' type='GPU'/>
06:59:50: <slot id='2' type='GPU'/>
06:59:50:</config>
06:59:50:Trying to access database...
06:59:50:Successfully acquired database lock
06:59:50:Enabled folding slot 00: READY cpu:4
06:59:50:Enabled folding slot 01: READY gpu:0:Mars [Radeon R7 M260/M265/M270]
06:59:50:Enabled folding slot 02: READY gpu:1:Carrizo [Radeon R7/R6/R5 Series]
06:59:50:WU00:FS02:Starting
06:59:50:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
06:59:50:WU00:FS02:Started FahCore on PID 9712
06:59:50:WU00:FS02:Core PID:5960
06:59:50:WU00:FS02:FahCore 0x22 started
06:59:51:WU00:FS02:0x22:*********************** Log Started 2020-05-05T06:59:51Z ***********************
06:59:53:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
06:59:53:WU00:FS02:0x22: Type: 0x22
06:59:53:WU00:FS02:0x22: Core: Core22
06:59:53:WU00:FS02:0x22: Website: https://foldingathome.org/
06:59:53:WU00:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:59:53:WU00:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:59:53:WU00:FS02:0x22: <rafal.wiewiora@choderalab.org>
06:59:53:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9712 -checkpoint 5
06:59:53:WU00:FS02:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
06:59:53:WU00:FS02:0x22: Config: <none>
06:59:53:WU00:FS02:0x22:************************************ Build *************************************
06:59:53:WU00:FS02:0x22: Version: 0.0.2
06:59:53:WU00:FS02:0x22: Date: Dec 6 2019
06:59:53:WU00:FS02:0x22: Time: 21:30:31
06:59:53:WU00:FS02:0x22: Repository: Git
06:59:53:WU00:FS02:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
06:59:53:WU00:FS02:0x22: Branch: HEAD
06:59:53:WU00:FS02:0x22: Compiler: Visual C++ 2008
06:59:53:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:59:54:WU00:FS02:0x22: Platform: win32 10
06:59:54:WU00:FS02:0x22: Bits: 64
06:59:54:WU00:FS02:0x22: Mode: Release
06:59:54:WU00:FS02:0x22:************************************ System ************************************
06:59:54:WU00:FS02:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
06:59:54:WU00:FS02:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
06:59:54:WU00:FS02:0x22: CPUs: 4
06:59:54:WU00:FS02:0x22: Memory: 15.47GiB
06:59:54:WU00:FS02:0x22:Free Memory: 11.94GiB
06:59:54:WU00:FS02:0x22: Threads: WINDOWS_THREADS
06:59:54:WU00:FS02:0x22: OS Version: 6.2
06:59:54:WU00:FS02:0x22:Has Battery: true
06:59:54:WU00:FS02:0x22: On Battery: false
06:59:54:WU00:FS02:0x22: UTC Offset: 2
06:59:54:WU00:FS02:0x22: PID: 5960
06:59:54:WU00:FS02:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
06:59:54:WU00:FS02:0x22: OS: Windows 10 Home
06:59:54:WU00:FS02:0x22: OS Arch: AMD64
06:59:54:WU00:FS02:0x22:********************************************************************************
06:59:54:WU00:FS02:0x22:Project: 11763 (Run 0, Clone 1356, Gen 59)
06:59:54:WU00:FS02:0x22:Unit: 0x0000006480fccb0a5e6d813651fc8c72
06:59:54:WU00:FS02:0x22:Digital signatures verified
06:59:54:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
06:59:54:WU00:FS02:0x22:Version 0.0.2
06:59:55:WU00:FS02:0x22: Found a checkpoint file
06:59:57:WU03:FS01:Starting
06:59:57:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
06:59:57:WU03:FS01:Started FahCore on PID 6964
06:59:57:WU03:FS01:Core PID:12776
06:59:57:WU03:FS01:FahCore 0x22 started
06:59:58:WU03:FS01:0x22:*********************** Log Started 2020-05-05T06:59:57Z ***********************
06:59:58:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
06:59:58:WU03:FS01:0x22: Type: 0x22
06:59:58:WU03:FS01:0x22: Core: Core22
06:59:58:WU03:FS01:0x22: Website: https://foldingathome.org/
06:59:58:WU03:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:59:58:WU03:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:59:58:WU03:FS01:0x22: <rafal.wiewiora@choderalab.org>
06:59:58:WU03:FS01:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 6964 -checkpoint 5
06:59:58:WU03:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
06:59:58:WU03:FS01:0x22: Config: <none>
06:59:58:WU03:FS01:0x22:************************************ Build *************************************
06:59:58:WU03:FS01:0x22: Version: 0.0.2
06:59:58:WU03:FS01:0x22: Date: Dec 6 2019
06:59:58:WU03:FS01:0x22: Time: 21:30:31
06:59:58:WU03:FS01:0x22: Repository: Git
06:59:58:WU03:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
06:59:58:WU03:FS01:0x22: Branch: HEAD
06:59:58:WU03:FS01:0x22: Compiler: Visual C++ 2008
06:59:58:WU03:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:59:58:WU03:FS01:0x22: Platform: win32 10
06:59:58:WU03:FS01:0x22: Bits: 64
06:59:58:WU03:FS01:0x22: Mode: Release
06:59:58:WU03:FS01:0x22:************************************ System ************************************
06:59:58:WU03:FS01:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
06:59:58:WU03:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
06:59:58:WU03:FS01:0x22: CPUs: 4
06:59:58:WU03:FS01:0x22: Memory: 15.47GiB
06:59:58:WU03:FS01:0x22:Free Memory: 11.78GiB
06:59:58:WU03:FS01:0x22: Threads: WINDOWS_THREADS
06:59:58:WU03:FS01:0x22: OS Version: 6.2
06:59:58:WU03:FS01:0x22:Has Battery: true
06:59:58:WU03:FS01:0x22: On Battery: false
06:59:58:WU03:FS01:0x22: UTC Offset: 2
06:59:58:WU03:FS01:0x22: PID: 12776
06:59:58:WU03:FS01:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
06:59:58:WU03:FS01:0x22: OS: Windows 10 Home
06:59:58:WU03:FS01:0x22: OS Arch: AMD64
06:59:58:WU03:FS01:0x22:********************************************************************************
06:59:58:WU03:FS01:0x22:Project: 14563 (Run 0, Clone 867, Gen 12)
06:59:58:WU03:FS01:0x22:Unit: 0x0000001280fccb025e9615b7ec44a1fa
06:59:58:WU03:FS01:0x22:Digital signatures verified
06:59:58:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
06:59:58:WU03:FS01:0x22:Version 0.0.2
06:59:58:WU03:FS01:0x22: Found a checkpoint file
06:59:59:WU01:FS00:Starting
06:59:59:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -np 4
06:59:59:WU01:FS00:Started FahCore on PID 3360
07:00:00:WU01:FS00:Core PID:76
07:00:00:WU01:FS00:FahCore 0xa7 started
07:00:00:WU01:FS00:0xa7:*********************** Log Started 2020-05-05T07:00:00Z ***********************
07:00:01:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:00:01:WU01:FS00:0xa7: Type: 0xa7
07:00:01:WU01:FS00:0xa7: Core: Gromacs
07:00:01:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 3360 -checkpoint 5 -np 4
07:00:01:WU01:FS00:0xa7:************************************ CBang *************************************
07:00:01:WU01:FS00:0xa7: Date: Oct 26 2019
07:00:01:WU01:FS00:0xa7: Time: 01:38:25
07:00:01:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:00:01:WU01:FS00:0xa7: Branch: master
07:00:01:WU01:FS00:0xa7: Compiler: Visual C++ 2008
07:00:01:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:00:01:WU01:FS00:0xa7: Platform: win32 10
07:00:01:WU01:FS00:0xa7: Bits: 64
07:00:01:WU01:FS00:0xa7: Mode: Release
07:00:01:WU01:FS00:0xa7:************************************ System ************************************
07:00:01:WU01:FS00:0xa7: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
07:00:01:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
07:00:01:WU01:FS00:0xa7: CPUs: 4
07:00:01:WU01:FS00:0xa7: Memory: 15.47GiB
07:00:01:WU01:FS00:0xa7:Free Memory: 11.60GiB
07:00:01:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
07:00:01:WU01:FS00:0xa7: OS Version: 6.2
07:00:01:WU01:FS00:0xa7:Has Battery: true
07:00:01:WU01:FS00:0xa7: On Battery: false
07:00:01:WU01:FS00:0xa7: UTC Offset: 2
07:00:01:WU01:FS00:0xa7: PID: 76
07:00:01:WU01:FS00:0xa7: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
07:00:01:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:00:01:WU01:FS00:0xa7: Version: 0.0.18
07:00:01:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:00:01:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
07:00:01:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
07:00:01:WU01:FS00:0xa7: Time: 01:52:30
07:00:01:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:00:01:WU01:FS00:0xa7:************************************ Build *************************************
07:00:01:WU01:FS00:0xa7: SIMD: avx_256
07:00:01:WU01:FS00:0xa7:********************************************************************************
07:00:01:WU01:FS00:0xa7:Project: 14621 (Run 572, Clone 0, Gen 65)
07:00:01:WU01:FS00:0xa7:Unit: 0x000000489bf7a4d55e89f1cb5624b28f
07:00:01:WU01:FS00:0xa7:Digital signatures verified
07:00:01:WU01:FS00:0xa7:Calling: mdrun -s frame65.tpr -o frame65.trr -cpi state.cpt -cpt 5 -nt 4
07:00:05:WU01:FS00:0xa7:Steps: first=0 total=250000
07:00:08:WU01:FS00:0xa7:Completed 64511 out of 250000 steps (25%)
07:01:05:WARNING:WU00:FS02:Detected clock skew (1 mins 08 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
07:01:05:WARNING:WU03:FS01:Detected clock skew (1 mins 06 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
07:01:08:WARNING:WU01:FS00:Detected clock skew (1 mins 08 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
07:01:54:WU00:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
07:01:54:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:02:14:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
07:07:31:WU03:FS01:0x22:Completed 380000 out of 500000 steps (76%)
07:07:32:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:14:11:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
07:34:01:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
07:39:45:FS00:Paused
07:39:45:FS01:Paused
07:39:45:FS02:Paused
07:39:45:FS00:Shutting core down
07:39:45:FS01:Shutting core down
07:39:45:FS02:Shutting core down
07:39:45:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 5960
07:39:45:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 76
07:39:45:WU00:FS02:0x22:Exiting, please wait. . .
07:39:45:WU01:FS00:0xa7:Exiting, please wait. . .
07:39:45:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 12776
07:39:45:WU03:FS01:0x22:Exiting, please wait. . .
07:39:46:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
07:39:46:Removing old file 'configs/config-20200503-101334.xml'
07:39:46:WU03:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
07:39:46:Saving configuration to config.xml
07:39:46:<config>
07:39:46: <!-- Folding Core -->
07:39:46: <checkpoint v='5'/>
07:39:46:
07:39:46: <!-- Folding Slot Configuration -->
07:39:46: <cause v='COVID_19'/>
07:39:46:
07:39:46: <!-- Network -->
07:39:46: <proxy v=':8080'/>
07:39:46:
07:39:46: <!-- Slot Control -->
07:39:46: <power v='full'/>
07:39:46:
07:39:46: <!-- User Information -->
07:39:46: <passkey v='*****'/>
07:39:46: <team v='260847'/>
07:39:46: <user v='BrunoL98'/>
07:39:46:
07:39:46: <!-- Folding Slots -->
07:39:46: <slot id='0' type='CPU'>
07:39:46: <cpus v='4'/>
07:39:46: <paused v='true'/>
07:39:46: </slot>
07:39:46: <slot id='1' type='GPU'>
07:39:46: </slot>
07:39:46: <slot id='2' type='GPU'>
07:39:46: </slot>
07:39:46:</config>
07:39:47:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
07:39:49:WU03:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:39:50:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:12:44:FS00:Unpaused
10:12:44:FS01:Unpaused
10:12:44:FS02:Unpaused
10:12:44:WU00:FS02:Starting
10:12:44:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
10:12:44:WU00:FS02:Started FahCore on PID 10200
10:12:44:WU00:FS02:Core PID:2008
10:12:44:WU00:FS02:FahCore 0x22 started
10:12:45:WU00:FS02:0x22:*********************** Log Started 2020-05-05T10:12:44Z ***********************
10:12:45:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
10:12:45:WU00:FS02:0x22: Type: 0x22
10:12:45:WU00:FS02:0x22: Core: Core22
10:12:45:WU00:FS02:0x22: Website: https://foldingathome.org/
10:12:45:WU00:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
10:12:45:WU00:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:12:45:WU00:FS02:0x22: <rafal.wiewiora@choderalab.org>
10:12:45:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 10200 -checkpoint 5
10:12:45:WU00:FS02:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
10:12:45:WU00:FS02:0x22: Config: <none>
10:12:45:WU00:FS02:0x22:************************************ Build *************************************
10:12:45:WU00:FS02:0x22: Version: 0.0.2
10:12:45:WU00:FS02:0x22: Date: Dec 6 2019
10:12:45:WU00:FS02:0x22: Time: 21:30:31
10:12:45:WU00:FS02:0x22: Repository: Git
10:12:45:WU00:FS02:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
10:12:45:WU00:FS02:0x22: Branch: HEAD
10:12:45:WU00:FS02:0x22: Compiler: Visual C++ 2008
10:12:45:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:12:45:WU00:FS02:0x22: Platform: win32 10
10:12:45:WU00:FS02:0x22: Bits: 64
10:12:45:WU00:FS02:0x22: Mode: Release
10:12:45:WU00:FS02:0x22:************************************ System ************************************
10:12:45:WU00:FS02:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
10:12:45:WU00:FS02:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
10:12:45:WU00:FS02:0x22: CPUs: 4
10:12:45:WU00:FS02:0x22: Memory: 15.47GiB
10:12:45:WU00:FS02:0x22:Free Memory: 9.89GiB
10:12:45:WU00:FS02:0x22: Threads: WINDOWS_THREADS
10:12:45:WU00:FS02:0x22: OS Version: 6.2
10:12:45:WU00:FS02:0x22:Has Battery: true
10:12:45:WU00:FS02:0x22: On Battery: false
10:12:45:WU00:FS02:0x22: UTC Offset: 2
10:12:45:WU00:FS02:0x22: PID: 2008
10:12:45:WU00:FS02:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
10:12:45:WU00:FS02:0x22: OS: Windows 10 Home
10:12:45:WU00:FS02:0x22: OS Arch: AMD64
10:12:45:WU00:FS02:0x22:********************************************************************************
10:12:45:WU00:FS02:0x22:Project: 11763 (Run 0, Clone 1356, Gen 59)
10:12:45:WU00:FS02:0x22:Unit: 0x0000006480fccb0a5e6d813651fc8c72
10:12:45:WU00:FS02:0x22:Digital signatures verified
10:12:45:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
10:12:45:WU00:FS02:0x22:Version 0.0.2
10:12:45:WU00:FS02:0x22: Found a checkpoint file
10:12:47:WU03:FS01:Starting
10:12:47:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:12:48:WU03:FS01:Started FahCore on PID 16308
10:12:48:WU03:FS01:Core PID:16232
10:12:48:WU03:FS01:FahCore 0x22 started
10:12:49:WU03:FS01:0x22:*********************** Log Started 2020-05-05T10:12:48Z ***********************
10:12:49:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:12:49:WU03:FS01:0x22: Type: 0x22
10:12:49:WU03:FS01:0x22: Core: Core22
10:12:49:WU03:FS01:0x22: Website: https://foldingathome.org/
10:12:49:WU03:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
10:12:49:WU03:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
10:12:49:WU03:FS01:0x22: <rafal.wiewiora@choderalab.org>
10:12:49:WU03:FS01:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 16308 -checkpoint 5
10:12:49:WU03:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:12:49:WU03:FS01:0x22: Config: <none>
10:12:49:WU03:FS01:0x22:************************************ Build *************************************
10:12:49:WU03:FS01:0x22: Version: 0.0.2
10:12:49:WU03:FS01:0x22: Date: Dec 6 2019
10:12:49:WU03:FS01:0x22: Time: 21:30:31
10:12:49:WU03:FS01:0x22: Repository: Git
10:12:49:WU03:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
10:12:49:WU03:FS01:0x22: Branch: HEAD
10:12:49:WU03:FS01:0x22: Compiler: Visual C++ 2008
10:12:49:WU03:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:12:49:WU03:FS01:0x22: Platform: win32 10
10:12:49:WU03:FS01:0x22: Bits: 64
10:12:49:WU03:FS01:0x22: Mode: Release
10:12:49:WU03:FS01:0x22:************************************ System ************************************
10:12:49:WU03:FS01:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
10:12:49:WU03:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
10:12:49:WU03:FS01:0x22: CPUs: 4
10:12:49:WU03:FS01:0x22: Memory: 15.47GiB
10:12:49:WU03:FS01:0x22:Free Memory: 9.85GiB
10:12:49:WU03:FS01:0x22: Threads: WINDOWS_THREADS
10:12:49:WU03:FS01:0x22: OS Version: 6.2
10:12:49:WU03:FS01:0x22:Has Battery: true
10:12:49:WU03:FS01:0x22: On Battery: false
10:12:49:WU03:FS01:0x22: UTC Offset: 2
10:12:49:WU03:FS01:0x22: PID: 16232
10:12:49:WU03:FS01:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
10:12:49:WU03:FS01:0x22: OS: Windows 10 Home
10:12:49:WU03:FS01:0x22: OS Arch: AMD64
10:12:49:WU03:FS01:0x22:********************************************************************************
10:12:49:WU03:FS01:0x22:Project: 14563 (Run 0, Clone 867, Gen 12)
10:12:49:WU03:FS01:0x22:Unit: 0x0000001280fccb025e9615b7ec44a1fa
10:12:49:WU03:FS01:0x22:Digital signatures verified
10:12:49:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:12:49:WU03:FS01:0x22:Version 0.0.2
10:12:49:WU03:FS01:0x22: Found a checkpoint file
10:12:49:WU01:FS00:Starting
10:12:49:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13188 -checkpoint 5 -np 4
10:12:50:WU01:FS00:Started FahCore on PID 4532
10:12:50:WU01:FS00:Core PID:4608
10:12:50:WU01:FS00:FahCore 0xa7 started
10:12:50:WU01:FS00:0xa7:*********************** Log Started 2020-05-05T10:12:50Z ***********************
10:12:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:12:50:WU01:FS00:0xa7: Type: 0xa7
10:12:50:WU01:FS00:0xa7: Core: Gromacs
10:12:50:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 4532 -checkpoint 5 -np 4
10:12:50:WU01:FS00:0xa7:************************************ CBang *************************************
10:12:50:WU01:FS00:0xa7: Date: Oct 26 2019
10:12:50:WU01:FS00:0xa7: Time: 01:38:25
10:12:50:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:12:50:WU01:FS00:0xa7: Branch: master
10:12:50:WU01:FS00:0xa7: Compiler: Visual C++ 2008
10:12:50:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:12:50:WU01:FS00:0xa7: Platform: win32 10
10:12:50:WU01:FS00:0xa7: Bits: 64
10:12:50:WU01:FS00:0xa7: Mode: Release
10:12:50:WU01:FS00:0xa7:************************************ System ************************************
10:12:50:WU01:FS00:0xa7: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
10:12:50:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
10:12:50:WU01:FS00:0xa7: CPUs: 4
10:12:50:WU01:FS00:0xa7: Memory: 15.47GiB
10:12:50:WU01:FS00:0xa7:Free Memory: 9.85GiB
10:12:50:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
10:12:50:WU01:FS00:0xa7: OS Version: 6.2
10:12:50:WU01:FS00:0xa7:Has Battery: true
10:12:50:WU01:FS00:0xa7: On Battery: false
10:12:50:WU01:FS00:0xa7: UTC Offset: 2
10:12:50:WU01:FS00:0xa7: PID: 4608
10:12:50:WU01:FS00:0xa7: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
10:12:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:12:50:WU01:FS00:0xa7: Version: 0.0.18
10:12:50:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:12:50:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
10:12:50:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
10:12:50:WU01:FS00:0xa7: Time: 01:52:30
10:12:50:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:12:50:WU01:FS00:0xa7:************************************ Build *************************************
10:12:50:WU01:FS00:0xa7: SIMD: avx_256
10:12:50:WU01:FS00:0xa7:********************************************************************************
10:12:50:WU01:FS00:0xa7:Project: 14621 (Run 572, Clone 0, Gen 65)
10:12:50:WU01:FS00:0xa7:Unit: 0x000000489bf7a4d55e89f1cb5624b28f
10:12:50:WU01:FS00:0xa7:Digital signatures verified
10:12:50:WU01:FS00:0xa7:Calling: mdrun -s frame65.tpr -o frame65.trr -cpi state.cpt -cpt 5 -nt 4
10:12:51:WU01:FS00:0xa7:Steps: first=0 total=250000
10:12:53:WU01:FS00:0xa7:Completed 70727 out of 250000 steps (28%)
10:13:49:Removing old file 'configs/config-20200503-140724.xml'
10:13:49:Saving configuration to config.xml
10:13:49:<config>
10:13:49: <!-- Folding Core -->
10:13:49: <checkpoint v='5'/>
10:13:49:
10:13:49: <!-- Folding Slot Configuration -->
10:13:49: <cause v='COVID_19'/>
10:13:49:
10:13:49: <!-- Network -->
10:13:49: <proxy v=':8080'/>
10:13:49:
10:13:49: <!-- Slot Control -->
10:13:49: <power v='full'/>
10:13:49:
10:13:49: <!-- User Information -->
10:13:49: <passkey v='*****'/>
10:13:49: <team v='260847'/>
10:13:49: <user v='BrunoL98'/>
10:13:49:
10:13:49: <!-- Folding Slots -->
10:13:49: <slot id='0' type='CPU'>
10:13:49: <cpus v='4'/>
10:13:49: </slot>
10:13:49: <slot id='1' type='GPU'/>
10:13:49: <slot id='2' type='GPU'/>
10:13:49:</config>
10:13:52:ERROR:Receive error: 10053: Connessione interrotta dal software del computer host.
You have 4 CPU threads, F@H just calls them CPUs
You have 2 GPUs, F@H should reserve 2 threads to keeping them fed.
However when I see the CPU Core_a7 start, all 4 threads are allocated to the CPU
10:12:50:WU01:FS00:0xa7:Calling: mdrun -s frame65.tpr -o frame65.trr -cpi state.cpt -cpt 5 -nt 4 (-nt 4 is number of threads 4)
I blame this line
which should be set to 2, so your GPUs stay fed with data.
You have 2 GPUs, to measure their usage I would use the sensor screen of GPU-Z, and notice there is a pulldown to change GPUs.
I blame this line
JimboPalmer's suggestion of using GPU-Z is correct. However, if you're curious, Windows Task Manager shows various sections of the GPU's utilization. Thus, it may not be meaningful if you don't know what to look at. If you open the GPU panel, from the drop down menu, cycle through until to get to Compute_0 or Compute_1 and you will notice that they are generally above 95% while folding.BrunoL wrote:...I've also seen that from Task Manager i'm using 0% of my GPU1, while on AMD Control Panel I'm seeing that it's using at full load (100%), which one of program should I believe most?...
The CPU and GPU portions of your chip share TDP. I have a Kaveri A8-7600 with a clock speed of 3.1 GHz that can turbo up to 3.8 GHz. When folding on the GPU, max CPU speed drops to 2.4 GHz. This gives maximum power to the GPU and is fine since the GPU produces more PPD. (There is a relative shortage of GPU work units compared to CPU so I'm not currently folding on the GPU portion.) I suspect this is why your CPU is slowing down <= 1.0 GHz when the GPU slot is active. Task Manager will show low CPU usage because 100% is based on clock speed being closer to maximum.BrunoL wrote:Goodmorning folders,
6 GB RAM
Newest hardware:
Goodmorning everyone and sorry for my late reply but yesterday I was busy.
I tried to apply the suggestion to set cpu cores at 2, but I didn't noticed anything differences from the previous situation, here below I'll share my task manager's stats, for CPU, GPU0 and GPU1, CPU is still stuck at 20-30% usage with 0.78 GHz frequency; in addition to this, as you can see, it seems like is not using GPU1 (the dedicated one with 2 GB of VRAM), infact his usage is on 0-3% and VRAM usage is only 300 MB/2000 MB, maybe should I change something on settings? (I also mean to PC's setting).
It's so frustrating because I'm struggling to understand if it depends on F@H client's setting or my PC's settings, I would appreciate all your suggestion.
I also shared another time my log file to let you see details with maximum trasparency.
Thank you.
CPU=
GPU0=
GPU1=
Thank you.
CPU=
GPU0=
GPU1=
*********************** Log Started 2020-05-06T07:55:20Z ***********************
07:55:20:****************************** FAHClient ******************************
07:55:20: Version: 7.6.9
07:55:20: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:55:20: Copyright: 2020 foldingathome.org
07:55:20: Homepage: https://foldingathome.org/
07:55:20: Date: Apr 17 2020
07:55:20: Time: 11:13:06
07:55:20: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
07:55:20: Branch: master
07:55:20: Compiler: Visual C++ 2008
07:55:20: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:55:20: Platform: win32 10
07:55:20: Bits: 32
07:55:20: Mode: Release
07:55:20: Args: --open-web-control
07:55:20: Config: C:\Users\bruno\AppData\Roaming\FAHClient\config.xml
07:55:20:******************************** CBang ********************************
07:55:20: Time: 11:10:09
07:55:20: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
07:55:20: Bits: 32
07:55:20:******************************* System ********************************
07:55:20: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
07:55:20: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
07:55:20: CPUs: 4
07:55:20: Memory: 15.47GiB
07:55:20: Free Memory: 11.05GiB
07:55:20: Threads: WINDOWS_THREADS
07:55:20: OS Version: 6.2
07:55:20: Has Battery: true
07:55:20: On Battery: false
07:55:20: UTC Offset: 2
07:55:20: PID: 6268
07:55:20: CWD: C:\Users\bruno\AppData\Roaming\FAHClient
07:55:20: OS: Windows 10 Home
07:55:20: OS Arch: AMD64
07:55:20: GPUs: 2
07:55:20: GPU 0: Bus:5 Slot:0 Func:0 AMD:5 Mars [Radeon R7 M260/M265/M270]
07:55:20: GPU 1: Bus:0 Slot:1 Func:0 AMD:5 Carrizo [Radeon R7/R6/R5 Series]
07:55:20: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
07:55:20: Impossibile trovare il modulo specificato.
07:55:20:
07:55:20:OpenCL Device 0: Platform:0 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:3004.8
07:55:20:OpenCL Device 1: Platform:0 Device:1 Bus:0 Slot:1 Compute:1.2 Driver:3004.8
07:55:20: Win32 Service: false
07:55:20:******************************* libFAH ********************************
07:55:20: Date: Apr 15 2020
07:55:20: Time: 14:53:14
07:55:20: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:55:20: Bits: 32
07:55:20:***********************************************************************
07:55:20:<config>
07:55:20: <!-- Folding Core -->
07:55:20: <checkpoint v='5'/>
07:55:20:
07:55:20: <!-- Folding Slot Configuration -->
07:55:20: <cause v='COVID_19'/>
07:55:20:
07:55:20: <!-- Network -->
07:55:20: <proxy v=':8080'/>
07:55:20:
07:55:20: <!-- Slot Control -->
07:55:20: <power v='full'/>
07:55:20:
07:55:20: <!-- User Information -->
07:55:20: <passkey v='*****'/>
07:55:20: <team v='260847'/>
07:55:20: <user v='BrunoL98'/>
07:55:20:
07:55:20: <!-- Folding Slots -->
07:55:20: <slot id='0' type='CPU'>
07:55:20: <cpus v='2'/>
07:55:20: <paused v='true'/>
07:55:20: </slot>
07:55:20: <slot id='1' type='GPU'>
07:55:20: </slot>
07:55:20: <slot id='2' type='GPU'>
07:55:20: </slot>
07:55:20:</config>
07:55:20:Trying to access database...
07:55:20:Successfully acquired database lock
07:55:20:Enabled folding slot 00: PAUSED cpu:2 (by user)
07:55:20:Enabled folding slot 01: PAUSED gpu:0:Mars [Radeon R7 M260/M265/M270] (by user)
07:55:20:Enabled folding slot 02: PAUSED gpu:1:Carrizo [Radeon R7/R6/R5 Series] (by user)
07:55:32:18:127.0.0.1:New Web session
07:55:59:FS00:Unpaused
07:55:59:FS01:Unpaused
07:55:59:FS02:Unpaused
07:55:59:WU00:FS02:Starting
07:55:59:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 6268 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
07:55:59:WU00:FS02:Started FahCore on PID 6676
07:55:59:WU00:FS02:Core PID:15348
07:55:59:WU00:FS02:FahCore 0x22 started
07:56:00:WU00:FS02:0x22:*********************** Log Started 2020-05-06T07:56:00Z ***********************
07:56:00:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
07:56:00:WU00:FS02:0x22: Type: 0x22
07:56:00:WU00:FS02:0x22: Core: Core22
07:56:00:WU00:FS02:0x22: Website: https://foldingathome.org/
07:56:00:WU00:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
07:56:00:WU00:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:56:00:WU00:FS02:0x22: <rafal.wiewiora@choderalab.org>
07:56:00:WU00:FS02:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 6676 -checkpoint 5
07:56:00:WU00:FS02:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
07:56:00:WU00:FS02:0x22: Config: <none>
07:56:00:WU00:FS02:0x22:************************************ Build *************************************
07:56:00:WU00:FS02:0x22: Version: 0.0.2
07:56:00:WU00:FS02:0x22: Date: Dec 6 2019
07:56:00:WU00:FS02:0x22: Time: 21:30:31
07:56:00:WU00:FS02:0x22: Repository: Git
07:56:00:WU00:FS02:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
07:56:00:WU00:FS02:0x22: Branch: HEAD
07:56:00:WU00:FS02:0x22: Compiler: Visual C++ 2008
07:56:00:WU00:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:56:00:WU00:FS02:0x22: Platform: win32 10
07:56:00:WU00:FS02:0x22: Bits: 64
07:56:00:WU00:FS02:0x22: Mode: Release
07:56:00:WU00:FS02:0x22:************************************ System ************************************
07:56:00:WU00:FS02:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
07:56:00:WU00:FS02:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
07:56:00:WU00:FS02:0x22: CPUs: 4
07:56:00:WU00:FS02:0x22: Memory: 15.47GiB
07:56:00:WU00:FS02:0x22:Free Memory: 11.49GiB
07:56:00:WU00:FS02:0x22: Threads: WINDOWS_THREADS
07:56:00:WU00:FS02:0x22: OS Version: 6.2
07:56:00:WU00:FS02:0x22:Has Battery: true
07:56:00:WU00:FS02:0x22: On Battery: false
07:56:00:WU00:FS02:0x22: UTC Offset: 2
07:56:00:WU00:FS02:0x22: PID: 15348
07:56:00:WU00:FS02:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
07:56:00:WU00:FS02:0x22: OS: Windows 10 Home
07:56:00:WU00:FS02:0x22: OS Arch: AMD64
07:56:00:WU00:FS02:0x22:********************************************************************************
07:56:00:WU00:FS02:0x22:Project: 11763 (Run 0, Clone 1356, Gen 59)
07:56:00:WU00:FS02:0x22:Unit: 0x0000006480fccb0a5e6d813651fc8c72
07:56:00:WU00:FS02:0x22:Digital signatures verified
07:56:00:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
07:56:00:WU00:FS02:0x22:Version 0.0.2
07:56:01:WU00:FS02:0x22: Found a checkpoint file
07:56:03:WU03:FS01:Starting
07:56:03:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 6268 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:56:03:WU03:FS01:Started FahCore on PID 5308
07:56:03:WU03:FS01:Core PID:9608
07:56:03:WU03:FS01:FahCore 0x22 started
07:56:04:WU03:FS01:0x22:*********************** Log Started 2020-05-06T07:56:04Z ***********************
07:56:04:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:56:04:WU03:FS01:0x22: Type: 0x22
07:56:04:WU03:FS01:0x22: Core: Core22
07:56:04:WU03:FS01:0x22: Website: https://foldingathome.org/
07:56:04:WU03:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
07:56:04:WU03:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:56:04:WU03:FS01:0x22: <rafal.wiewiora@choderalab.org>
07:56:04:WU03:FS01:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 5308 -checkpoint 5
07:56:04:WU03:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:56:04:WU03:FS01:0x22: Config: <none>
07:56:04:WU03:FS01:0x22:************************************ Build *************************************
07:56:04:WU03:FS01:0x22: Version: 0.0.2
07:56:04:WU03:FS01:0x22: Date: Dec 6 2019
07:56:04:WU03:FS01:0x22: Time: 21:30:31
07:56:04:WU03:FS01:0x22: Repository: Git
07:56:04:WU03:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
07:56:04:WU03:FS01:0x22: Branch: HEAD
07:56:04:WU03:FS01:0x22: Compiler: Visual C++ 2008
07:56:04:WU03:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:56:04:WU03:FS01:0x22: Platform: win32 10
07:56:04:WU03:FS01:0x22: Bits: 64
07:56:04:WU03:FS01:0x22: Mode: Release
07:56:04:WU03:FS01:0x22:************************************ System ************************************
07:56:04:WU03:FS01:0x22: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
07:56:04:WU03:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
07:56:04:WU03:FS01:0x22: CPUs: 4
07:56:04:WU03:FS01:0x22: Memory: 15.47GiB
07:56:04:WU03:FS01:0x22:Free Memory: 11.42GiB
07:56:04:WU03:FS01:0x22: Threads: WINDOWS_THREADS
07:56:04:WU03:FS01:0x22: OS Version: 6.2
07:56:04:WU03:FS01:0x22:Has Battery: true
07:56:04:WU03:FS01:0x22: On Battery: false
07:56:04:WU03:FS01:0x22: UTC Offset: 2
07:56:04:WU03:FS01:0x22: PID: 9608
07:56:04:WU03:FS01:0x22: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
07:56:04:WU03:FS01:0x22: OS: Windows 10 Home
07:56:04:WU03:FS01:0x22: OS Arch: AMD64
07:56:04:WU03:FS01:0x22:********************************************************************************
07:56:04:WU03:FS01:0x22:Project: 14563 (Run 0, Clone 867, Gen 12)
07:56:04:WU03:FS01:0x22:Unit: 0x0000001280fccb025e9615b7ec44a1fa
07:56:04:WU03:FS01:0x22:Digital signatures verified
07:56:04:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:56:04:WU03:FS01:0x22:Version 0.0.2
07:56:05:WU03:FS01:0x22: Found a checkpoint file
07:56:05:WU01:FS00:Starting
07:56:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bruno\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 6268 -checkpoint 5 -np 2
07:56:05:WU01:FS00:Started FahCore on PID 9492
07:56:05:WU01:FS00:Core PID:10460
07:56:05:WU01:FS00:FahCore 0xa7 started
07:56:06:WU01:FS00:0xa7:*********************** Log Started 2020-05-06T07:56:05Z ***********************
07:56:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:56:06:WU01:FS00:0xa7: Type: 0xa7
07:56:06:WU01:FS00:0xa7: Core: Gromacs
07:56:06:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 9492 -checkpoint 5 -np 2
07:56:06:WU01:FS00:0xa7:************************************ CBang *************************************
07:56:06:WU01:FS00:0xa7: Date: Oct 26 2019
07:56:06:WU01:FS00:0xa7: Time: 01:38:25
07:56:06:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:56:06:WU01:FS00:0xa7: Branch: master
07:56:06:WU01:FS00:0xa7: Compiler: Visual C++ 2008
07:56:06:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:56:06:WU01:FS00:0xa7: Platform: win32 10
07:56:06:WU01:FS00:0xa7: Bits: 64
07:56:06:WU01:FS00:0xa7: Mode: Release
07:56:06:WU01:FS00:0xa7:************************************ System ************************************
07:56:06:WU01:FS00:0xa7: CPU: AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
07:56:06:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 101 Stepping 1
07:56:06:WU01:FS00:0xa7: CPUs: 4
07:56:06:WU01:FS00:0xa7: Memory: 15.47GiB
07:56:06:WU01:FS00:0xa7:Free Memory: 11.39GiB
07:56:06:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
07:56:06:WU01:FS00:0xa7: OS Version: 6.2
07:56:06:WU01:FS00:0xa7:Has Battery: true
07:56:06:WU01:FS00:0xa7: On Battery: false
07:56:06:WU01:FS00:0xa7: UTC Offset: 2
07:56:06:WU01:FS00:0xa7: PID: 10460
07:56:06:WU01:FS00:0xa7: CWD: C:\Users\bruno\AppData\Roaming\FAHClient\work
07:56:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
07:56:06:WU01:FS00:0xa7: Version: 0.0.18
07:56:06:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:56:06:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
07:56:06:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
07:56:06:WU01:FS00:0xa7: Time: 01:52:30
07:56:06:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:56:06:WU01:FS00:0xa7:************************************ Build *************************************
07:56:06:WU01:FS00:0xa7: SIMD: avx_256
07:56:06:WU01:FS00:0xa7:********************************************************************************
07:56:06:WU01:FS00:0xa7:Project: 14621 (Run 572, Clone 0, Gen 65)
07:56:06:WU01:FS00:0xa7:Unit: 0x000000489bf7a4d55e89f1cb5624b28f
07:56:06:WU01:FS00:0xa7:Digital signatures verified
07:56:06:WU01:FS00:0xa7:Calling: mdrun -s frame65.tpr -o frame65.trr -cpi state.cpt -cpt 5 -nt 2
07:56:07:WU01:FS00:0xa7:Steps: first=0 total=250000
07:56:09:WU01:FS00:0xa7:Completed 109909 out of 250000 steps (43%)
07:56:38:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
07:57:03:Removing old file 'configs/config-20200505-102803.xml'
07:57:03:Saving configuration to config.xml
07:57:03:<config>
07:57:03: <!-- Folding Core -->
07:57:03: <checkpoint v='5'/>
07:57:03:
07:57:03: <!-- Folding Slot Configuration -->
07:57:03: <cause v='COVID_19'/>
07:57:03:
07:57:03: <!-- Network -->
07:57:03: <proxy v=':8080'/>
07:57:03:
07:57:03: <!-- Slot Control -->
07:57:03: <power v='full'/>
07:57:03:
07:57:03: <!-- User Information -->
07:57:03: <passkey v='*****'/>
07:57:03: <team v='260847'/>
07:57:03: <user v='BrunoL98'/>
07:57:03:
07:57:03: <!-- Folding Slots -->
07:57:03: <slot id='0' type='CPU'>
07:57:03: <cpus v='2'/>
07:57:03: </slot>
07:57:03: <slot id='1' type='GPU'/>
07:57:03: <slot id='2' type='GPU'/>
07:57:03:</config>
07:57:05:ERROR:Receive error: 10053: Connessione interrotta dal software del computer host.
07:57:21:WU00:FS02:0x22:Completed 900000 out of 1000000 steps (90%)
07:57:21:WU00:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:03:25:WU03:FS01:0x22:Completed 400000 out of 500000 steps (80%)
08:03:26:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:22:42:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
08:32:25:FS00:Paused
08:32:25:FS01:Paused
08:32:25:FS02:Paused
08:32:25:FS00:Shutting core down
08:32:26:FS01:Shutting core down
08:32:26:FS02:Shutting core down
08:32:27:WU00:FS02:0x22:WARNING:Console control signal 1 on PID 15348
08:32:27:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 10460
08:32:27:WU03:FS01:0x22:WARNING:Console control signal 1 on PID 9608
08:32:27:WU00:FS02:0x22:Exiting, please wait. . .
08:32:27:WU01:FS00:0xa7:Exiting, please wait. . .
08:32:27:WU03:FS01:0x22:Exiting, please wait. . .
08:32:27:WU03:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
08:32:28:WU00:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
08:32:33:WU00:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
08:32:34:WU03:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
08:32:35:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:32:38:Removing old file 'configs/config-20200505-110259.xml'
08:32:38:Saving configuration to config.xml
08:32:38:<config>
08:32:38: <!-- Folding Core -->
08:32:38: <checkpoint v='5'/>
08:32:38:
08:32:38: <!-- Folding Slot Configuration -->
08:32:38: <cause v='COVID_19'/>
08:32:38:
08:32:38: <!-- Network -->
08:32:38: <proxy v=':8080'/>
08:32:38:
08:32:38: <!-- Slot Control -->
08:32:38: <power v='full'/>
08:32:38:
08:32:38: <!-- User Information -->
08:32:38: <passkey v='*****'/>
08:32:38: <team v='260847'/>
08:32:38: <user v='BrunoL98'/>
08:32:38:
08:32:38: <!-- Folding Slots -->
08:32:38: <slot id='0' type='CPU'>
08:32:38: <cpus v='2'/>
08:32:38: <paused v='true'/>
08:32:38: </slot>
08:32:38: <slot id='1' type='GPU'>
08:32:38: </slot>
08:32:38: <slot id='2' type='GPU'>
08:32:38: </slot>
08:32:38:</config>
