GPU folding three WUs at the same time
DrCarnicero
Post by DrCarnicero »
Hello everyone!
As of today, my setup has started folding three GPU WUs at the same time. I've been running FAH successfully for over a month now, so not sure what happened.
I guess what might be the issue is that one WU is almost finished, got stuck, and the client keeps downloading the 'next' WU thinking it is almost time.
Any help would be appreciated! If additional info (like logs) is missing, please let me know.
HaloJones
Re: GPU folding three WUs at the same time
Post by HaloJones »
One of them (wu02 - 16424) is the wu that the cpu is doing.
wu00 looks like it thought it was about to finish and downloaded wu03
wu02 is the active gpu project.
My suggestion is to set wu02 to "finish" by right-clicking on it and selecting finish.
When it finsihes, see what the gpu moves on to. It should stop. If it jumps on to wu03 that would be understandable although arguably wrong. If it does nothing, without seeing the full logs, I suspect the client has got itself in a mess; finish the cpu project as well and then, stop the whole folding client. navigate to %APPDATA%\fahclient and remove the work directory. then reboot.
single 1070
DrCarnicero
Thanks for the quick reply.
I believe WU02 is the one the CPU is working on. WU00, WU01 and WU03 are the GPU ones.
I have now set the GPU to finish, and will let you know what results.
Also, the log for WU00 is as follows:
*********************** Log Started 2020-05-04T17:47:33Z ***********************
:roll:
There might be entries for WU00 in a prior log, check in the logs folder in the data directory. There are a small number of ways this could happen, but the information in the logs is what is needed to figure out what that was.
DrCarnicero
The weirdness continues: I set the GPU to 'finish', and it completed WU01. Then it went on to complete WU00, and has now re-started WU01. :e?:
Below is an excerpt from the log from this morning until a restart some hours ago - I had paused folding before rebooting:
*********************** Log Started 2020-05-04T07:13:48Z ***********************
14:07:52:WU03:FS00:0xa7:*********************** Log Started 2020-05-04T14:07:52Z ***********************
14:07:52:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:07:52:WU03:FS00:0xa7:       Type: 0xa7
14:07:52:WU03:FS00:0xa7:       Core: Gromacs
14:07:52:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 12088 -checkpoint 15 -np
14:07:52:WU03:FS00:0xa7:             7
14:07:52:WU03:FS00:0xa7:************************************ CBang *************************************
14:07:52:WU03:FS00:0xa7:       Date: Oct 26 2019
14:07:52:WU03:FS00:0xa7:       Time: 01:38:25
14:07:52:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:07:52:WU03:FS00:0xa7:     Branch: master
14:07:52:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
14:07:52:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:07:52:WU03:FS00:0xa7:   Platform: win32 10
14:07:52:WU03:FS00:0xa7:       Bits: 64
14:07:52:WU03:FS00:0xa7:       Mode: Release
14:07:52:WU03:FS00:0xa7:************************************ System ************************************
14:07:52:WU03:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
14:07:52:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:07:52:WU03:FS00:0xa7:       CPUs: 8
14:07:52:WU03:FS00:0xa7:     Memory: 7.93GiB
14:07:52:WU03:FS00:0xa7:Free Memory: 2.55GiB
14:07:52:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
14:07:52:WU03:FS00:0xa7: OS Version: 6.2
14:07:52:WU03:FS00:0xa7:Has Battery: false
14:07:52:WU03:FS00:0xa7: On Battery: false
14:07:52:WU03:FS00:0xa7: UTC Offset: 2
14:07:52:WU03:FS00:0xa7:        PID: 1676
14:07:52:WU03:FS00:0xa7:        CWD: C:\Users\XXXX\AppData\Roaming\FAHClient\work
14:07:52:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
14:07:52:WU03:FS00:0xa7:    Version: 0.0.18
14:07:52:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:07:52:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:07:52:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
14:07:52:WU03:FS00:0xa7:       Time: 01:52:30
14:07:52:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:07:52:WU03:FS00:0xa7:************************************ Build *************************************
14:07:52:WU03:FS00:0xa7:       SIMD: avx_256
14:07:52:WU03:FS00:0xa7:********************************************************************************
14:07:52:WU03:FS00:0xa7:Project: 14625 (Run 1812, Clone 1, Gen 32)
14:07:52:WU03:FS00:0xa7:Unit: 0x000000269bf7a4d65e88de89d599d7fe
14:07:52:WU03:FS00:0xa7:Reading tar file core.xml
14:07:52:WU03:FS00:0xa7:Reading tar file frame32.tpr
14:07:52:WU03:FS00:0xa7:Digital signatures verified
14:07:52:WU03:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
14:07:52:WU03:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -cpt 15 -nt 6
14:07:52:WU03:FS00:0xa7:Steps: first=0 total=250000
14:07:53:WU03:FS00:0xa7:Completed 1 out of 250000 steps (0%)
14:07:57:WU02:FS00:Upload 76.73%
14:07:58:WU02:FS00:Upload complete
14:07:59:WU02:FS00:Server responded WORK_ACK (400)
14:07:59:WU02:FS00:Final credit estimate, 7811.00 points
14:07:59:WU02:FS00:Cleaning up
14:08:21:WU00:FS01:0x22:Completed 2300000 out of 5000000 steps (46%)
14:09:58:WU03:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
14:11:58:WU03:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
14:12:16:WU00:FS01:0x22:Completed 2350000 out of 5000000 steps (47%)
14:13:57:WU03:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
14:15:56:WU03:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
14:16:05:WU00:FS01:0x22:Completed 2400000 out of 5000000 steps (48%)
14:17:55:WU03:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
14:19:54:WU00:FS01:0x22:Completed 2450000 out of 5000000 steps (49%)
14:19:55:WU03:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
14:21:55:WU03:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
14:23:43:WU00:FS01:0x22:Completed 2500000 out of 5000000 steps (50%)
14:23:55:WU03:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
14:25:55:WU03:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
14:27:32:WU00:FS01:0x22:Completed 2550000 out of 5000000 steps (51%)
14:27:54:WU03:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
14:29:54:WU03:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
14:31:23:WU00:FS01:0x22:Completed 2600000 out of 5000000 steps (52%)
14:31:54:WU03:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
14:33:52:WU03:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
14:35:10:WU00:FS01:0x22:Completed 2650000 out of 5000000 steps (53%)
14:35:56:WU03:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
14:37:56:WU03:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
14:39:03:WU00:FS01:0x22:Completed 2700000 out of 5000000 steps (54%)
14:39:55:WU03:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
14:41:53:WU03:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
14:42:50:WU00:FS01:0x22:Completed 2750000 out of 5000000 steps (55%)
14:43:52:WU03:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
14:45:52:WU03:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
14:46:37:WU00:FS01:0x22:Completed 2800000 out of 5000000 steps (56%)
14:47:52:WU03:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
14:49:52:WU03:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
14:50:24:WU00:FS01:0x22:Completed 2850000 out of 5000000 steps (57%)
14:51:53:WU03:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
14:53:53:WU03:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
14:54:11:WU00:FS01:0x22:Completed 2900000 out of 5000000 steps (58%)
14:55:54:WU03:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
14:57:54:WU03:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
14:57:57:WU00:FS01:0x22:Completed 2950000 out of 5000000 steps (59%)
14:59:54:WU03:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
15:01:44:WU00:FS01:0x22:Completed 3000000 out of 5000000 steps (60%)
15:01:54:WU03:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
15:03:54:WU03:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
15:05:31:WU00:FS01:0x22:Completed 3050000 out of 5000000 steps (61%)
15:05:54:WU03:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
15:07:55:WU03:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
15:09:17:WU00:FS01:0x22:Completed 3100000 out of 5000000 steps (62%)
15:09:55:WU03:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
15:11:54:WU03:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
15:13:05:WU00:FS01:0x22:Completed 3150000 out of 5000000 steps (63%)
15:13:53:WU03:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
15:15:51:WU03:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
15:16:52:WU00:FS01:0x22:Completed 3200000 out of 5000000 steps (64%)
15:17:49:WU03:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
15:19:48:WU03:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
15:20:38:WU00:FS01:0x22:Completed 3250000 out of 5000000 steps (65%)
15:21:47:WU03:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
15:23:46:WU03:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
15:24:25:WU00:FS01:0x22:Completed 3300000 out of 5000000 steps (66%)
15:25:44:WU03:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
15:27:43:WU03:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
15:28:11:WU00:FS01:0x22:Completed 3350000 out of 5000000 steps (67%)
15:29:42:WU03:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
15:31:40:WU03:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
15:31:58:WU00:FS01:0x22:Completed 3400000 out of 5000000 steps (68%)
15:33:39:WU03:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
15:35:37:WU03:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
15:35:45:WU00:FS01:0x22:Completed 3450000 out of 5000000 steps (69%)
15:37:37:WU03:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
15:39:32:WU00:FS01:0x22:Completed 3500000 out of 5000000 steps (70%)
15:39:38:WU03:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
15:41:39:WU03:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
15:43:25:WU00:FS01:0x22:Completed 3550000 out of 5000000 steps (71%)
15:43:47:WU03:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
15:45:50:WU03:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
15:47:26:WU00:FS01:0x22:Completed 3600000 out of 5000000 steps (72%)
15:48:02:WU03:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
15:50:05:WU03:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
15:51:19:WU00:FS01:0x22:Completed 3650000 out of 5000000 steps (73%)
15:52:09:WU03:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
15:54:14:WU03:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
15:55:14:WU00:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
15:56:17:WU03:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
15:58:21:WU03:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
15:59:06:WU00:FS01:0x22:Completed 3750000 out of 5000000 steps (75%)
16:00:25:WU03:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
16:02:27:WU03:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
16:02:58:WU00:FS01:0x22:Completed 3800000 out of 5000000 steps (76%)
16:04:30:WU03:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
16:06:33:WU03:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
16:06:50:WU00:FS01:0x22:Completed 3850000 out of 5000000 steps (77%)
16:08:36:WU03:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
16:10:36:WU03:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
16:10:41:WU00:FS01:0x22:Completed 3900000 out of 5000000 steps (78%)
16:12:36:WU03:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
16:14:33:WU00:FS01:0x22:Completed 3950000 out of 5000000 steps (79%)
16:14:39:WU03:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
16:16:45:WU03:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
16:18:34:WU00:FS01:0x22:Completed 4000000 out of 5000000 steps (80%)
16:18:49:WU03:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
16:20:52:WU03:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
16:22:29:WU00:FS01:0x22:Completed 4050000 out of 5000000 steps (81%)
16:22:53:WU03:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
16:24:53:WU03:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
16:26:19:WU00:FS01:0x22:Completed 4100000 out of 5000000 steps (82%)
16:26:54:WU03:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
16:28:54:WU03:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
16:30:09:WU00:FS01:0x22:Completed 4150000 out of 5000000 steps (83%)
16:30:56:WU03:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
16:33:04:WU03:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
16:34:08:WU00:FS01:0x22:Completed 4200000 out of 5000000 steps (84%)
16:35:09:WU03:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
16:37:16:WU03:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
16:38:04:WU00:FS01:0x22:Completed 4250000 out of 5000000 steps (85%)
16:39:20:WU03:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
16:41:23:WU03:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
16:41:58:WU00:FS01:0x22:Completed 4300000 out of 5000000 steps (86%)
16:43:29:WU03:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
16:45:36:WU03:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
16:45:56:WU00:FS01:0x22:Completed 4350000 out of 5000000 steps (87%)
16:47:37:WU03:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
16:49:42:WU03:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
16:49:53:WU00:FS01:0x22:Completed 4400000 out of 5000000 steps (88%)
16:51:45:WU03:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
16:53:47:WU00:FS01:0x22:Completed 4450000 out of 5000000 steps (89%)
16:53:51:WU03:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
16:56:00:WU03:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
16:57:49:WU00:FS01:0x22:Completed 4500000 out of 5000000 steps (90%)
16:58:03:WU03:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
17:00:07:WU03:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
17:01:59:WU00:FS01:0x22:Completed 4550000 out of 5000000 steps (91%)
17:02:33:WU03:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
17:05:21:WU03:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
17:07:22:WU00:FS01:0x22:Completed 4600000 out of 5000000 steps (92%)
17:07:57:WU03:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
17:10:41:WU03:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
17:12:44:WU00:FS01:0x22:Completed 4650000 out of 5000000 steps (93%)
17:13:22:WU03:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
17:15:59:WU03:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
17:18:01:WU00:FS01:0x22:Completed 4700000 out of 5000000 steps (94%)
17:18:35:WU03:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
17:21:16:WU03:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
17:23:14:WU00:FS01:0x22:Completed 4750000 out of 5000000 steps (95%)
17:23:54:WU03:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
17:26:32:WU03:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
17:28:35:WU00:FS01:0x22:Completed 4800000 out of 5000000 steps (96%)
17:29:20:WU03:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
17:32:01:WU03:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
17:33:47:WU00:FS01:0x22:Completed 4850000 out of 5000000 steps (97%)
17:34:29:WU03:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
17:36:35:WU03:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
17:36:36:WU02:FS00:Connecting to 65.254.110.245:8080
17:36:36:WU02:FS00:Assigned to work server 168.245.198.125
17:36:36:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 168.245.198.125
17:36:36:WU02:FS00:Connecting to 168.245.198.125:8080
17:36:37:WU02:FS00:Downloading 8.31MiB
17:36:43:WU02:FS00:Download 84.20%
17:36:44:WU02:FS00:Download complete
17:36:44:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16424 run:2562 clone:0 gen:27 core:0xa7 unit:0x00000022a8f5c67d5e8f66f4ef47083c
17:37:48:WU00:FS01:0x22:Completed 4900000 out of 5000000 steps (98%)
17:38:42:WU03:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
17:38:44:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
17:38:44:WU03:FS00:0xa7:Saving result file dhdl.xvg
17:38:44:WU03:FS00:0xa7:Saving result file frame32.trr
17:38:44:WU03:FS00:0xa7:Saving result file md.log
17:38:44:WU03:FS00:0xa7:Saving result file pullf.xvg
17:38:44:WU03:FS00:0xa7:Saving result file pullx.xvg
17:38:44:WU03:FS00:0xa7:Saving result file science.log
17:38:44:WU03:FS00:0xa7:Saving result file traj_comp.xtc
17:38:44:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:38:45:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:38:45:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:14625 run:1812 clone:1 gen:32 core:0xa7 unit:0x000000269bf7a4d65e88de89d599d7fe
17:38:45:WU03:FS00:Uploading 6.52MiB to 155.247.164.214
17:38:45:WU02:FS00:Starting
17:38:45:WU03:FS00:Connecting to 155.247.164.214:8080
17:38:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\XXXX\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 16128 -checkpoint 15 -np 7
17:38:45:WU02:FS00:Started FahCore on PID 18780
17:38:45:WU02:FS00:Core PID:892
17:38:45:WU02:FS00:FahCore 0xa7 started
17:38:45:WU02:FS00:0xa7:*********************** Log Started 2020-05-04T17:38:45Z ***********************
17:38:45:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:38:45:WU02:FS00:0xa7:       Type: 0xa7
17:38:45:WU02:FS00:0xa7:       Core: Gromacs
17:38:45:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 18780 -checkpoint 15 -np
17:38:45:WU02:FS00:0xa7:             7
17:38:45:WU02:FS00:0xa7:************************************ CBang *************************************
17:38:45:WU02:FS00:0xa7:       Date: Oct 26 2019
17:38:45:WU02:FS00:0xa7:       Time: 01:38:25
17:38:45:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:38:45:WU02:FS00:0xa7:     Branch: master
17:38:45:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
17:38:45:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:38:45:WU02:FS00:0xa7:   Platform: win32 10
17:38:45:WU02:FS00:0xa7:       Bits: 64
17:38:45:WU02:FS00:0xa7:       Mode: Release
17:38:45:WU02:FS00:0xa7:************************************ System ************************************
17:38:45:WU02:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
17:38:45:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:38:45:WU02:FS00:0xa7:       CPUs: 8
17:38:45:WU02:FS00:0xa7:     Memory: 7.93GiB
17:38:45:WU02:FS00:0xa7:Free Memory: 2.06GiB
17:38:45:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
17:38:45:WU02:FS00:0xa7: OS Version: 6.2
17:38:45:WU02:FS00:0xa7:Has Battery: false
17:38:45:WU02:FS00:0xa7: On Battery: false
17:38:45:WU02:FS00:0xa7: UTC Offset: 2
17:38:45:WU02:FS00:0xa7:        PID: 892
17:38:45:WU02:FS00:0xa7:        CWD: C:\Users\XXXX\AppData\Roaming\FAHClient\work
17:38:45:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
17:38:45:WU02:FS00:0xa7:    Version: 0.0.18
17:38:46:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:38:46:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:38:46:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
17:38:46:WU02:FS00:0xa7:       Date: Oct 26 2019
17:38:46:WU02:FS00:0xa7:       Time: 01:52:30
17:38:46:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:38:46:WU02:FS00:0xa7:     Branch: master
17:38:46:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
17:38:46:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:38:46:WU02:FS00:0xa7:   Platform: win32 10
17:38:46:WU02:FS00:0xa7:       Bits: 64
17:38:46:WU02:FS00:0xa7:       Mode: Release
17:38:46:WU02:FS00:0xa7:************************************ Build *************************************
17:38:46:WU02:FS00:0xa7:       SIMD: avx_256
17:38:46:WU02:FS00:0xa7:********************************************************************************
17:38:46:WU02:FS00:0xa7:Project: 16424 (Run 2562, Clone 0, Gen 27)
17:38:46:WU02:FS00:0xa7:Unit: 0x00000022a8f5c67d5e8f66f4ef47083c
17:38:46:WU02:FS00:0xa7:Reading tar file core.xml
17:38:46:WU02:FS00:0xa7:Reading tar file frame27.tpr
17:38:46:WU02:FS00:0xa7:Digital signatures verified
17:38:46:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
17:38:46:WU02:FS00:0xa7:Calling: mdrun -s frame27.tpr -o frame27.trr -x frame27.xtc -cpt 15 -nt 6
17:38:46:WU02:FS00:0xa7:Steps: first=6750000 total=250000
17:38:48:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
17:38:51:WU03:FS00:Upload 38.33%
17:38:57:WU03:FS00:Upload 80.50%
17:39:00:WU03:FS00:Upload complete
17:39:00:WU03:FS00:Server responded WORK_ACK (400)
17:39:00:WU03:FS00:Final credit estimate, 3509.00 points
17:39:00:WU03:FS00:Cleaning up
17:42:05:WU00:FS01:0x22:Completed 4950000 out of 5000000 steps (99%)
17:42:06:WU03:FS01:Connecting to 65.254.110.245:8080
17:42:06:WU03:FS01:Assigned to work server 128.252.203.10
17:42:06:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Hawaii [Radeon R9 200/300 Series] from 128.252.203.10
17:42:06:WU03:FS01:Connecting to 128.252.203.10:8080
17:42:28:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
17:42:28:WU03:FS01:Connecting to 128.252.203.10:80
17:42:49:ERROR:WU03:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:42:49:WU03:FS01:Connecting to 65.254.110.245:8080
17:42:50:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:42:50:WU03:FS01:Connecting to 18.218.241.186:80
17:42:51:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:42:51:ERROR:WU03:FS01:Exception: Could not get an assignment
17:43:44:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
17:43:49:WU03:FS01:Connecting to 65.254.110.245:8080
17:43:50:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:43:50:WU03:FS01:Connecting to 18.218.241.186:80
17:43:50:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:43:50:ERROR:WU03:FS01:Exception: Could not get an assignment
17:45:01:FS00:Paused
17:45:01:FS01:Paused
17:45:01:FS00:Shutting core down
17:45:01:FS01:Shutting core down
17:45:01:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 892
17:45:01:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 13756
17:45:01:WU02:FS00:0xa7:Exiting, please wait. . .
17:45:01:WU00:FS01:0x22:Exiting, please wait. . .
17:45:01:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
17:45:02:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:45:05:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:45:09:Removing old file 'configs/config-20200419-222554.xml'
17:45:09:Saving configuration to config.xml
17:45:09:<config>
17:45:09:  <!-- Network -->
17:45:09:  <proxy v=':8080'/>
17:45:09:
17:45:09:  <!-- Slot Control -->
17:45:09:  <power v='full'/>
17:45:09:
17:45:09:  <!-- User Information -->
17:45:09:  <passkey v='********************************'/>
17:45:09:  <team v='XXXX'/>
17:45:09:  <user v='XXXX'/>
17:45:09:
17:45:09:  <!-- Folding Slots -->
17:45:09:  <slot id='0' type='CPU'>
17:45:09:    <paused v='true'/>
17:45:09:  </slot>
17:45:09:  <slot id='1' type='GPU'>
17:45:09:  </slot>
17:45:09:</config>
17:45:32:Clean exit
You probably removed a slot. If you have two closely releated slots and you remove one, FAH attempts to transfer the WU to another slot which can finish it. Once the WU that active in that slot finishes, the GPU will process the "extra" WU rather than downloading a new one.
