Mac CPU WU
Mac CPU WU
I understand that with the recent surge in new donors there has been a WU shortage. I started a few weeks ago running on a old laptop I had sitting around the house and everything ran fine for a week or two. Now when I check the computer the log says that there is no WU's available for my configuration. Is this due to the WU shortage or is there something wrong with the way I have my computer configured and the settings?
iLoreto
- Hardware configuration: 1. mbp i5 2.4GHz (4 CPU) 16GB
2. mba i5 1.8GHz (4 CPU) 4GB
3. HP ProBook i7 1.8GHz (8 CPU) 8GB
4. Lenovo IdeaPad i3 2.3GHz (4 CPU) 20GB
5. Lenovo IdeaPad i3 2.3GHz (4 CPU) 20GB
6. Lenovo ThinkBlade i7 XEON (8 CPU) 40GB
7. Lenovo ThinkCenter i7 XEON (12 CPU) 80GB - Location: https://iloreto.me
Re: Mac CPU WU
what is your project preference set to in the FAHControl? default or is a project selected?
do you have v7 and which client version are you on?
Team Name:iLoretoDevelopment
Team ID:264740
Team Stats: https://stats.foldingathome.org/team/264740
Donor Name:iLoreto
Donor ID:145598594
Donor Stats: https://stats.foldingathome.org/donor/145598594
Team ID:264740
Donor Name:iLoreto
Donor ID:145598594
Re: Mac CPU WU
I have been getting CPU WUs for my Mac's almost continuously, so there should be work available. There might be an issue with one of your settings, or something else. Please use the directions in this post - viewtopic.php?p=327414&f=24#p327414 - and post the first couple hundred lines of the log file to show the system info and client setup.
Re: Mac CPU WU
I am running on version 7.6.9 and my preference is set to any disease.iLoreto wrote:what is your project preference set to in the FAHControl? default or is a project selected?
Re: Mac CPU WU
Joe_H wrote:I have been getting CPU WUs for my Mac's almost continuously, so there should be work available. There might be an issue with one of your settings, or something else. Please use the directions in this post - viewtopic.php?p=327414&f=24#p327414 - and post the first couple hundred lines of the log file to show the system info and client setup.
This is all that shows in my log.
*********************** Log Started 2020-04-30T02:10:05Z ***********************
******************************* Date: 2020-04-30 *******************************
11:30:15:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
******************************* Date: 2020-05-04 *******************************
Re: Mac CPU WU
Please follow the directions to go directly to the log file in the data folder and open it up with TextEdit. Copy and paste from there.
Re: Mac CPU WU
02:10:45:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 60 -checkpoint 10 -np 4
02:10:45:WU00:FS00:Started FahCore on PID 475
02:11:07:WU00:FS00:Core PID:485
02:11:07:WU00:FS00:FahCore 0xa7 started
02:11:20:WU00:FS00:0xa7:*********************** Log Started 2020-04-30T02:11:20Z ***********************
02:11:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:11:20:WU00:FS00:0xa7: Type: 0xa7
02:11:20:WU00:FS00:0xa7: Core: Gromacs
02:11:20:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 475 -checkpoint 10 -np 4
02:11:20:WU00:FS00:0xa7:************************************ CBang *************************************
02:11:20:WU00:FS00:0xa7: Date: Oct 26 2019
02:11:20:WU00:FS00:0xa7: Time: 03:00:53
02:11:20:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
02:11:20:WU00:FS00:0xa7: Branch: master
02:11:20:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
02:11:20:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
02:11:20:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
02:11:20:WU00:FS00:0xa7: Platform: darwin 19.0.0
02:11:20:WU00:FS00:0xa7: Bits: 64
02:11:20:WU00:FS00:0xa7: Mode: Release
02:11:20:WU00:FS00:0xa7:************************************ System ************************************
02:11:20:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2435M CPU @ 2.40GHz
02:11:20:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:11:20:WU00:FS00:0xa7: CPUs: 4
02:11:20:WU00:FS00:0xa7: Memory: 10.00GiB
02:11:20:WU00:FS00:0xa7:Free Memory: 7.10GiB
02:11:20:WU00:FS00:0xa7: Threads: POSIX_THREADS
02:11:20:WU00:FS00:0xa7: OS Version: 10.12
02:11:20:WU00:FS00:0xa7:Has Battery: true
02:11:20:WU00:FS00:0xa7: On Battery: false
02:11:20:WU00:FS00:0xa7: UTC Offset: -5
02:11:20:WU00:FS00:0xa7: PID: 485
02:11:20:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
02:11:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:11:20:WU00:FS00:0xa7: Version: 0.0.18
02:11:20:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:11:20:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
02:11:20:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
02:11:20:WU00:FS00:0xa7: Time: 03:06:33
02:11:20:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
02:11:20:WU00:FS00:0xa7:************************************ Build *************************************
02:11:20:WU00:FS00:0xa7: SIMD: avx_256
02:11:20:WU00:FS00:0xa7:********************************************************************************Code: Select all
15:19:45:36:127.0.0.1:New Web session
15:20:11:Saving configuration to config.xml
15:20:11:<config>
15:20:11: <!-- Folding Core -->
15:20:11: <checkpoint v='10'/>
15:20:11:
15:20:11: <!-- Network -->
15:20:11: <proxy v=':8080'/>
15:20:11:
15:20:11: <!-- Slot Control -->
15:20:11: <power v='full'/>
15:20:11:
15:20:11: <!-- User Information -->
15:20:11: <passkey v='*****'/>
15:20:11: <team v='223518'/>
15:20:11: <user v='FWWR2248'/>
15:20:11:
15:20:11: <!-- Folding Slots -->
15:20:11: <slot id='0' type='CPU'/>
15:20:11:</config>
17:09:25:62:127.0.0.1:New Web session
19:40:35:87:127.0.0.1:New Web sessionRe: Mac CPU WU
Update: When I restart the computer the client picks up one work unit however once it finishes it just sits at idle with a log similar to the one above.
Re: Mac CPU WU
Welcome to the F@H Forum FWWR2248,
Can you please post the entire content of the most recent log file so we can see what's happening. The snippets above aren't providing the full picture especially after the WU has downloaded. I am aware that a new version of the client has been released which has some tweaks for getting WUs which you may want to try: viewtopic.php?f=24&t=34466
