GTX 980M Not being recognised.
gerbil1966
Post by gerbil1966 »
Below is an extract from the log.
GPU-Z tells me it is Open CL 1.2 OK and Cuda
The log picks out the drivers but does not see the GPU
Any help would be of benefit
Regards, Andy
PS I have had a browse for similar issues but most were in regard to Linux not W10 dut if there is the answer out there and I have not seen it, please show me the way.
*********************** Log Started 2020-05-04T11:55:50Z ***********************
11:55:50:****************************** FAHClient ******************************
11:55:50:        Version: 7.6.9
11:55:50:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:55:50:      Copyright: 2020 foldingathome.org
11:55:50:       Homepage: https://foldingathome.org/
11:55:50:           Date: Apr 17 2020
11:55:50:           Time: 11:13:06
11:55:50:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
11:55:50:         Branch: master
11:55:50:       Compiler: Visual C++ 2008
11:55:50:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:55:50:       Platform: win32 10
11:55:50:           Bits: 32
11:55:50:           Mode: Release
11:55:50:           Args: --open-web-control
11:55:50:******************************** CBang ********************************
11:55:50:           Time: 11:10:09
11:55:50:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
11:55:50:           Bits: 32
11:55:50:******************************* System ********************************
11:55:50:            CPU: Intel(R) Core(TM) i7-6820HK CPU @ 2.70GHz
11:55:50:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
11:55:50:           CPUs: 8
11:55:50:         Memory: 31.94GiB
11:55:50:    Free Memory: 26.24GiB
11:55:50:        Threads: WINDOWS_THREADS
11:55:50:     OS Version: 6.2
11:55:50:    Has Battery: true
11:55:50:     On Battery: false
11:55:50:     UTC Offset: 1
11:55:50:            PID: 17188
11:55:50:            CWD: C:\Users\Andrew Jervis\AppData\Roaming\FAHClient
11:55:50:             OS: Windows 10 Home
11:55:50:        OS Arch: AMD64
11:55:50:           GPUs: 0
11:55:50:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.0
11:55:50:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
11:55:50:  Win32 Service: false
11:55:50:******************************* libFAH ********************************
11:55:50:           Date: Apr 15 2020
11:55:50:           Time: 14:53:14
11:55:50:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:55:50:           Bits: 32
11:55:50:***********************************************************************
11:55:50:<config>
11:55:50:  <!-- Folding Slots -->
11:55:50:</config>
11:55:50:Trying to access database...
11:55:50:Successfully acquired database lock
11:55:50:Enabled folding slot 00: PAUSED cpu:3 (not configured)
11:55:52:4:127.0.0.1:New Web session
11:56:51:Saving configuration to config.xml
11:56:51:<config>
11:56:51:  <!-- Folding Slots -->
11:56:51:  <slot id='0' type='CPU'/>
11:56:51:</config>
11:56:51:Set client configured
Re: GTX 980M Not being recognised.
There is a known issue with the version 7.6.9 installer and new installations the folding client, it does not download the necessary GPUs.txt file to identify usable GPUs. Sometimes it will do this after a reboot and restart of the client software, and then you can manually add the GPU folding slot.
If that does not work, download the file from here - https://apps.foldingathome.org/GPUs.txt. Then place it in this directory - C:\Users\Andrew Jervis\AppData\Roaming\FAHClient, and restart. Your GPU should now be detected.
