Change in WU after restart
woodworth1
Post by woodworth1 »
I had to restart my computer to install a Windows update, so I paused the client, restarted the computer, and then began the client again. Prior to the restart, the GPU had completed about 60% of a WU that was estimated to get around 160,000 points, but after the restart, it said that it was working on another WU with 0% completed, but after a few minutes, it went back up to about 60%, but with a different estimate for final credit, and a different WU project description. It just finished the WU, with a final credit estimate of about 188,000 points. Any idea what caused this? I worry that it may have conflated results from two separate WUs, however this seems unlikely, as the server seems to have accepted the results.
Re: Change in WU after restart
Welcome to the F@H Forum woodworth1,
Can you please post the log file? You may have to look into the logs folder for the previous logs as they are rotated upon client restarts. Guidance is provided in this topic if needed: viewtopic.php?f=24&t=26036
Post by muziqaz »
PPD values are liquid values, which means they change, going up when GPU is folding and nothing else is happening on the system, and it will go down with time if you are doing something to take away some GPU power off folding. Pausing and restarting a WU can influence PPD value as well, since you wasted few minutes without folding, value will be smaller. It is possible in your case, with restart your GPU got clean period of folding where nothing else could influence it, and thus PPD value increased. The more you fold the bigger PPD value there is gonna be.
If you fold 24 hours non stop PPD value will be much higher than if you folded for 12 hours straight, but then decided to game for another 12 hours and stopped folding. PPD calculation takes into account a lot of aspects :)
FAH Omega tester
woodworth1
PantherX wrote:Welcome to the F@H Forum woodworth1,
Here is some of the previous log file:
20:28:12:WU00:FS01:Connecting to 65.254.110.245:80
20:28:12:WU00:FS01:Assigned to work server 3.133.76.19
20:28:12:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1070] 6463 from 3.133.76.19
20:28:12:WU00:FS01:Connecting to 3.133.76.19:8080
20:29:20:WU00:FS01:Downloading 17.39MiB
20:29:26:WU00:FS01:Download 91.64%
20:29:26:WU00:FS01:Download complete
20:29:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14436 run:2178 clone:1 gen:11 core:0x22 unit:0x0000001103854c135e9a790da4b1af9f
20:29:32:WU02:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
20:31:19:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
20:31:27:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
20:31:27:WU01:FS01:0x22:Saving result file checkpointState.xml
20:31:28:WU01:FS01:0x22:Saving result file checkpt.crc
20:31:28:WU01:FS01:0x22:Saving result file positions.xtc
20:31:28:WU01:FS01:0x22:Saving result file science.log
20:31:28:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:31:29:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:31:29:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14430 run:0 clone:1351 gen:34 core:0x22 unit:0x0000002d0d5262775e8b4d5c2ecb9c52
20:31:29:WU01:FS01:Uploading 43.92MiB to 13.82.98.119
20:31:29:WU01:FS01:Connecting to 13.82.98.119:8080
20:31:29:WU00:FS01:Starting
20:31:29:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\james\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12852 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:31:29:WU00:FS01:Started FahCore on PID 21416
20:31:29:WU00:FS01:Core PID:24700
20:31:29:WU00:FS01:FahCore 0x22 started
20:31:30:WU00:FS01:0x22:*********************** Log Started 2020-05-03T20:31:29Z ***********************
20:31:30:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:31:30:WU00:FS01:0x22:       Type: 0x22
20:31:30:WU00:FS01:0x22:       Core: Core22
20:31:30:WU00:FS01:0x22:    Website: https://foldingathome.org/
20:31:30:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
20:31:30:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:31:30:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
20:31:30:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 21416 -checkpoint 15
20:31:30:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:31:30:WU00:FS01:0x22:             0 -gpu 0
20:31:30:WU00:FS01:0x22:     Config: <none>
20:31:30:WU00:FS01:0x22:************************************ Build *************************************
20:31:30:WU00:FS01:0x22:    Version: 0.0.2
20:31:30:WU00:FS01:0x22:       Date: Dec 6 2019
20:31:30:WU00:FS01:0x22:       Time: 21:30:31
20:31:30:WU00:FS01:0x22: Repository: Git
20:31:30:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:31:30:WU00:FS01:0x22:     Branch: HEAD
20:31:30:WU00:FS01:0x22:   Compiler: Visual C++ 2008
20:31:30:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:31:30:WU00:FS01:0x22:   Platform: win32 10
20:31:30:WU00:FS01:0x22:       Bits: 64
20:31:30:WU00:FS01:0x22:       Mode: Release
20:31:30:WU00:FS01:0x22:************************************ System ************************************
20:31:30:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
20:31:30:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
20:31:30:WU00:FS01:0x22:       CPUs: 12
20:31:30:WU00:FS01:0x22:     Memory: 63.92GiB
20:31:30:WU00:FS01:0x22:Free Memory: 56.08GiB
20:31:30:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
20:31:30:WU00:FS01:0x22: OS Version: 6.2
20:31:30:WU00:FS01:0x22:Has Battery: false
20:31:30:WU00:FS01:0x22: On Battery: false
20:31:30:WU00:FS01:0x22: UTC Offset: -6
20:31:30:WU00:FS01:0x22:        PID: 24700
20:31:30:WU00:FS01:0x22:        CWD: C:\Users\james\AppData\Roaming\FAHClient\work
20:31:30:WU00:FS01:0x22:         OS: Windows 10 Pro
20:31:30:WU00:FS01:0x22:    OS Arch: AMD64
20:31:30:WU00:FS01:0x22:********************************************************************************
20:31:30:WU00:FS01:0x22:Project: 14436 (Run 2178, Clone 1, Gen 11)
20:31:30:WU00:FS01:0x22:Unit: 0x0000001103854c135e9a790da4b1af9f
20:31:30:WU00:FS01:0x22:Reading tar file core.xml
20:31:30:WU00:FS01:0x22:Reading tar file integrator.xml
20:31:30:WU00:FS01:0x22:Reading tar file state.xml
20:31:31:WU00:FS01:0x22:Reading tar file system.xml
20:31:33:WU00:FS01:0x22:Digital signatures verified
20:31:33:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:31:33:WU00:FS01:0x22:Version 0.0.2
20:31:35:WU01:FS01:Upload 9.53%
20:31:41:WU01:FS01:Upload 19.92%
20:31:47:WU01:FS01:Upload 30.45%
20:31:53:WU01:FS01:Upload 40.84%
20:31:59:WU01:FS01:Upload 51.23%
20:32:03:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
20:32:03:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:32:05:WU01:FS01:Upload 61.76%
20:32:11:WU01:FS01:Upload 69.58%
20:32:17:WU01:FS01:Upload 78.98%
20:32:23:WU01:FS01:Upload 89.51%
20:32:29:WU01:FS01:Upload 99.61%
20:32:29:WU01:FS01:Upload complete
20:32:29:WU01:FS01:Server responded WORK_ACK (400)
20:32:29:WU01:FS01:Final credit estimate, 162301.00 points
20:32:29:WU01:FS01:Cleaning up
20:33:13:WU02:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
20:35:52:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
20:36:02:6911:127.0.0.1:New Web session
20:37:11:WU02:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
20:39:51:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
20:41:05:WU02:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
20:43:53:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
20:45:07:WU02:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
20:45:46:6919:127.0.0.1:New Web session
20:47:30:6927:127.0.0.1:New Web session
20:47:59:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
20:49:04:WU02:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
20:52:00:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
20:52:43:6935:127.0.0.1:New Web session
20:52:54:WU02:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
20:53:06:6943:127.0.0.1:New Web session
20:55:58:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
20:56:54:WU02:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
20:59:56:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
21:00:51:WU02:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
21:03:58:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
21:04:43:WU02:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
21:07:53:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
21:08:33:WU02:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
21:11:52:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
21:12:16:WU02:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
21:15:51:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
21:16:23:WU02:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
21:19:50:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
21:20:19:WU02:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
21:23:45:6952:127.0.0.1:New Web session
21:23:51:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
21:24:10:WU02:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
21:27:51:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
21:27:53:WU02:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
21:31:31:WU02:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
21:31:43:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
21:35:20:WU02:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
21:35:42:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
21:39:25:WU02:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
21:39:43:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
21:43:20:WU02:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
21:43:49:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
21:44:16:6960:127.0.0.1:New Web session
21:47:21:WU02:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
21:47:55:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
21:50:05:6968:127.0.0.1:New Web session
21:51:30:WU02:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
21:52:01:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
21:55:29:WU02:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
21:56:08:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
21:58:04:6976:127.0.0.1:New Web session
21:59:29:WU02:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
22:00:11:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
22:03:14:WU02:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
22:04:00:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
22:06:56:WU02:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
22:07:48:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
22:10:40:WU02:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
22:11:39:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
22:12:23:6984:127.0.0.1:New Web session
22:14:56:WU02:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
22:15:40:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
22:18:54:WU02:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
22:19:35:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
22:23:05:WU02:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
22:23:31:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
22:24:34:6992:127.0.0.1:New Web session
22:27:00:WU02:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
22:27:29:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
22:29:31:6999:127.0.0.1:New Web session
22:30:55:WU02:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
22:31:22:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
22:34:46:WU02:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
22:35:17:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
22:38:34:WU02:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
22:39:04:7021:127.0.0.1:New Web session
22:39:11:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
22:42:37:WU02:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
22:43:16:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
22:46:35:WU02:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
22:47:10:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
22:50:32:WU02:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
22:51:08:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
22:53:44:7048:127.0.0.1:New Web session
22:54:36:WU02:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
22:55:08:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
22:58:18:WU02:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
22:59:07:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
23:02:00:WU02:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
23:03:07:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
23:03:10:7061:127.0.0.1:New Web session
23:05:49:WU02:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
23:06:58:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
23:09:12:7069:127.0.0.1:New Web session
23:09:50:WU02:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
23:10:54:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
23:13:46:WU02:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
23:14:44:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
23:16:43:7076:127.0.0.1:New Web session
23:17:37:WU02:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
23:17:59:7082:127.0.0.1:New Web session
23:18:40:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
23:21:35:WU02:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
23:22:48:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
23:23:35:7096:127.0.0.1:New Web session
23:25:14:7102:127.0.0.1:New Web session
23:25:40:WU02:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
23:25:51:7109:127.0.0.1:New Web session
23:26:59:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
23:28:30:7115:127.0.0.1:New Web session
23:29:21:7122:127.0.0.1:New Web session
23:29:39:WU02:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
23:31:08:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
23:31:08:7129:127.0.0.1:New Web session
23:33:49:WU02:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
23:35:13:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
23:37:47:WU02:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
23:38:33:7137:127.0.0.1:New Web session
23:39:23:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
23:41:41:WU02:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
23:43:24:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
23:44:20:7145:127.0.0.1:New Web session
******************************* Date: 2020-05-03 *******************************
23:45:36:WU02:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
23:47:21:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
23:49:22:WU02:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
23:51:12:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
23:53:04:WU02:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
23:55:11:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
23:57:02:WU02:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
23:59:06:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
00:00:58:WU02:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
00:03:03:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
00:05:04:WU02:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
00:07:05:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
00:08:54:WU02:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
00:11:07:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
00:12:47:WU02:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
00:15:09:7153:127.0.0.1:New Web session
00:15:10:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
00:16:45:WU02:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
00:19:11:7159:127.0.0.1:New Web session
00:19:13:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
00:20:44:WU02:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
00:21:25:7167:127.0.0.1:New Web session
00:25:58:7174:127.0.0.1:New Web session
00:27:09:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
00:34:35:7184:127.0.0.1:New Web session
00:37:47:7193:127.0.0.1:New Web session
00:40:33:7200:127.0.0.1:New Web session
00:41:51:WU02:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
00:42:03:7208:127.0.0.1:New Web session
00:42:22:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
00:46:30:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
00:46:38:WU02:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
00:46:43:7217:127.0.0.1:New Web session
00:48:46:FS00:Paused
00:48:46:FS01:Paused
00:48:46:FS00:Shutting core down
00:48:46:FS01:Shutting core down
00:48:46:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 24700
00:48:46:WU00:FS01:0x22:Exiting, please wait. . .
00:48:46:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 2844
00:48:46:WU02:FS00:0xa7:Exiting, please wait. . .
00:48:46:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
00:48:46:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:48:47:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
00:48:47:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:49:04:Saving configuration to config.xml
00:49:04:<config>
00:49:04:  <!-- Slot Control -->
00:49:04:  <power v='FULL'/>
00:49:04:
00:49:04:  <!-- User Information -->
00:49:04:  <passkey v='*****'/>
00:49:04:  <user v='woodworth1'/>
00:49:04:
00:49:04:  <!-- Folding Slots -->
00:49:04:  <slot id='0' type='CPU'>
00:49:04:    <paused v='true'/>
00:49:04:  </slot>
00:49:04:  <slot id='1' type='GPU'>
00:49:04:  </slot>
00:49:04:</config>
And after the restart, to the point at which the WU that underwent the change in description and final credit estimate was submitted:
*********************** Log Started 2020-05-04T00:50:49Z ***********************
00:50:49:****************************** FAHClient ******************************
00:50:49:        Version: 7.6.9
00:50:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:50:49:      Copyright: 2020 foldingathome.org
00:50:49:       Homepage: https://foldingathome.org/
00:50:49:           Date: Apr 17 2020
00:50:49:           Time: 11:13:06
00:50:49:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
00:50:49:         Branch: master
00:50:49:       Compiler: Visual C++ 2008
00:50:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:50:49:       Platform: win32 10
00:50:49:           Bits: 32
00:50:49:           Mode: Release
00:50:49:         Config: C:\Users\james\AppData\Roaming\FAHClient\config.xml
00:50:49:******************************** CBang ********************************
00:50:49:           Time: 11:10:09
00:50:49:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
00:50:49:           Bits: 32
00:50:49:******************************* System ********************************
00:50:49:            CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
00:50:49:         CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
00:50:49:           CPUs: 12
00:50:49:         Memory: 63.92GiB
00:50:49:    Free Memory: 60.20GiB
00:50:49:        Threads: WINDOWS_THREADS
00:50:49:     OS Version: 6.2
00:50:49:    Has Battery: false
00:50:49:     On Battery: false
00:50:49:     UTC Offset: -6
00:50:49:            PID: 12120
00:50:49:            CWD: C:\Users\james\AppData\Roaming\FAHClient
00:50:49:             OS: Windows 10 Enterprise
00:50:49:        OS Arch: AMD64
00:50:49:           GPUs: 1
00:50:49:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
00:50:49:  CUDA Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:6.1 Driver:11.0
00:50:49:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:445.87
00:50:49:  Win32 Service: false
00:50:49:******************************* libFAH ********************************
00:50:49:           Date: Apr 15 2020
00:50:49:           Time: 14:53:14
00:50:49:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
00:50:49:           Bits: 32
00:50:49:***********************************************************************
00:50:49:<config>
00:50:49:  <!-- Slot Control -->
00:50:49:  <power v='FULL'/>
00:50:49:
00:50:49:  <!-- User Information -->
00:50:49:  <passkey v='*****'/>
00:50:49:  <user v='woodworth1'/>
00:50:49:
00:50:49:  <!-- Folding Slots -->
00:50:49:  <slot id='0' type='CPU'>
00:50:49:    <paused v='true'/>
00:50:49:  </slot>
00:50:49:  <slot id='1' type='GPU'>
00:50:49:  </slot>
00:50:49:</config>
00:50:49:Trying to access database...
00:50:49:Successfully acquired database lock
00:50:49:Enabled folding slot 00: PAUSED cpu:11 (by user)
00:50:49:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] 6463 (by user)
00:51:17:FS00:Unpaused
00:51:17:FS01:Unpaused
00:51:17:WU00:FS01:Starting
00:51:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\james\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 12120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:51:17:WU00:FS01:Started FahCore on PID 4164
00:51:17:WU00:FS01:Core PID:4720
00:51:17:WU00:FS01:FahCore 0x22 started
00:51:18:WU02:FS00:Starting
00:51:18:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\james\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 12120 -checkpoint 15 -np 11
00:51:18:WU02:FS00:Started FahCore on PID 4132
00:51:18:WU02:FS00:Core PID:4428
00:51:18:WU02:FS00:FahCore 0xa7 started
00:51:18:WU00:FS01:0x22:*********************** Log Started 2020-05-04T00:51:18Z ***********************
00:51:18:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:51:18:WU00:FS01:0x22:       Type: 0x22
00:51:18:WU00:FS01:0x22:       Core: Core22
00:51:18:WU00:FS01:0x22:    Website: https://foldingathome.org/
00:51:18:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:51:18:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:51:18:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:51:18:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4164 -checkpoint 15
00:51:18:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
00:51:18:WU00:FS01:0x22:             0 -gpu 0
00:51:18:WU00:FS01:0x22:     Config: <none>
00:51:18:WU00:FS01:0x22:************************************ Build *************************************
00:51:18:WU00:FS01:0x22:    Version: 0.0.2
00:51:18:WU00:FS01:0x22:       Date: Dec 6 2019
00:51:18:WU00:FS01:0x22:       Time: 21:30:31
00:51:18:WU00:FS01:0x22: Repository: Git
00:51:18:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:51:18:WU00:FS01:0x22:     Branch: HEAD
00:51:18:WU00:FS01:0x22:   Compiler: Visual C++ 2008
00:51:18:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:51:18:WU00:FS01:0x22:   Platform: win32 10
00:51:18:WU00:FS01:0x22:       Bits: 64
00:51:18:WU00:FS01:0x22:       Mode: Release
00:51:18:WU00:FS01:0x22:************************************ System ************************************
00:51:18:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
00:51:18:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
00:51:18:WU00:FS01:0x22:       CPUs: 12
00:51:18:WU00:FS01:0x22:     Memory: 63.92GiB
00:51:18:WU00:FS01:0x22:Free Memory: 59.90GiB
00:51:18:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
00:51:18:WU00:FS01:0x22: OS Version: 6.2
00:51:18:WU00:FS01:0x22:Has Battery: false
00:51:18:WU00:FS01:0x22: On Battery: false
00:51:18:WU00:FS01:0x22: UTC Offset: -6
00:51:18:WU00:FS01:0x22:        PID: 4720
00:51:18:WU00:FS01:0x22:        CWD: C:\Users\james\AppData\Roaming\FAHClient\work
00:51:18:WU00:FS01:0x22:         OS: Windows 10 Pro
00:51:18:WU00:FS01:0x22:    OS Arch: AMD64
00:51:18:WU00:FS01:0x22:********************************************************************************
00:51:18:WU00:FS01:0x22:Project: 14436 (Run 2178, Clone 1, Gen 11)
00:51:18:WU00:FS01:0x22:Unit: 0x0000001103854c135e9a790da4b1af9f
00:51:18:WU00:FS01:0x22:Digital signatures verified
00:51:18:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:51:18:WU00:FS01:0x22:Version 0.0.2
00:51:18:WU02:FS00:0xa7:*********************** Log Started 2020-05-04T00:51:18Z ***********************
00:51:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:51:18:WU02:FS00:0xa7:       Type: 0xa7
00:51:18:WU02:FS00:0xa7:       Core: Gromacs
00:51:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np
00:51:18:WU02:FS00:0xa7:             11
00:51:18:WU02:FS00:0xa7:************************************ CBang *************************************
00:51:18:WU02:FS00:0xa7:       Date: Oct 26 2019
00:51:18:WU02:FS00:0xa7:       Time: 01:38:25
00:51:18:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:51:18:WU02:FS00:0xa7:     Branch: master
00:51:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:51:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:51:18:WU02:FS00:0xa7:   Platform: win32 10
00:51:18:WU02:FS00:0xa7:       Bits: 64
00:51:18:WU02:FS00:0xa7:       Mode: Release
00:51:18:WU02:FS00:0xa7:************************************ System ************************************
00:51:18:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
00:51:18:WU00:FS01:0x22:  Found a checkpoint file
00:51:18:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
00:51:18:WU02:FS00:0xa7:       CPUs: 12
00:51:18:WU02:FS00:0xa7:     Memory: 63.92GiB
00:51:18:WU02:FS00:0xa7:Free Memory: 59.89GiB
00:51:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:51:18:WU02:FS00:0xa7: OS Version: 6.2
00:51:18:WU02:FS00:0xa7:Has Battery: false
00:51:18:WU02:FS00:0xa7: On Battery: false
00:51:18:WU02:FS00:0xa7: UTC Offset: -6
00:51:18:WU02:FS00:0xa7:        PID: 4428
00:51:18:WU02:FS00:0xa7:        CWD: C:\Users\james\AppData\Roaming\FAHClient\work
00:51:18:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:51:18:WU02:FS00:0xa7:    Version: 0.0.18
00:51:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:51:18:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:51:18:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:51:18:WU02:FS00:0xa7:       Time: 01:52:30
00:51:18:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:51:18:WU02:FS00:0xa7:************************************ Build *************************************
00:51:18:WU02:FS00:0xa7:       SIMD: avx_256
00:51:18:WU02:FS00:0xa7:********************************************************************************
00:51:18:WU02:FS00:0xa7:Project: 16801 (Run 1, Clone 306, Gen 34)
00:51:18:WU02:FS00:0xa7:Unit: 0x0000002282ed0b915e9597e26f65cd42
00:51:18:WU02:FS00:0xa7:Digital signatures verified
00:51:18:WU02:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
00:51:18:WU02:FS00:0xa7:Calling: mdrun -s frame34.tpr -o frame34.trr -cpi state.cpt -cpt 15 -nt 10
00:51:18:WU02:FS00:0xa7:Steps: first=17000000 total=500000
00:51:20:WU02:FS00:0xa7:Completed 357592 out of 500000 steps (71%)
00:51:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
00:51:50:Saving configuration to config.xml
00:51:50:<config>
00:51:50:  <!-- Slot Control -->
00:51:50:  <power v='FULL'/>
00:51:50:
00:51:50:  <!-- User Information -->
00:51:50:  <passkey v='*****'/>
00:51:50:  <user v='woodworth1'/>
00:51:50:
00:51:50:  <!-- Folding Slots -->
00:51:50:  <slot id='0' type='CPU'/>
00:51:50:  <slot id='1' type='GPU'/>
00:51:50:</config>
00:51:52:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
00:51:52:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:53:20:WU02:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
00:53:34:5:127.0.0.1:New Web session
00:54:46:13:127.0.0.1:New Web session
00:55:38:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
00:56:08:21:127.0.0.1:New Web session
00:57:33:WU02:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
00:59:24:29:127.0.0.1:New Web session
00:59:39:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
01:01:25:WU02:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
01:02:08:37:127.0.0.1:New Web session
01:03:36:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
01:04:11:44:127.0.0.1:New Web session
01:05:27:WU02:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
01:05:46:60:127.0.0.1:New Web session
01:06:35:67:127.0.0.1:New Web session
01:07:34:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
01:09:40:WU02:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
01:10:03:74:127.0.0.1:New Web session
01:11:35:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
01:13:43:WU02:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
01:14:28:82:127.0.0.1:New Web session
01:15:29:89:127.0.0.1:New Web session
01:15:37:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
01:17:40:WU02:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
01:19:36:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
01:21:37:WU02:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
01:23:36:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
01:25:35:WU02:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
01:27:37:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
01:29:42:WU02:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
01:31:34:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
01:33:34:WU02:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
01:35:30:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
01:37:36:WU02:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
01:39:30:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
01:41:37:WU02:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
01:43:31:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
01:45:34:WU02:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
01:47:23:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
01:49:25:WU02:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
01:51:13:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
01:53:02:97:127.0.0.1:New Web session
01:53:17:WU02:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
01:54:32:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
01:55:08:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
01:56:55:WU02:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
01:58:57:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
02:00:48:WU02:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
02:02:39:106:127.0.0.1:New Web session
02:02:54:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
02:04:54:WU02:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
02:06:54:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
02:09:12:WU02:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
02:10:52:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
02:13:07:WU02:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
02:14:44:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
02:16:51:WU02:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
02:18:39:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
02:19:33:114:127.0.0.1:New Web session
02:20:44:WU02:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
02:21:33:121:127.0.0.1:New Web session
02:22:39:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
02:24:44:WU02:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
02:26:43:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
02:28:33:WU02:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
02:29:18:129:127.0.0.1:New Web session
02:29:57:135:127.0.0.1:New Web session
02:30:42:142:127.0.0.1:New Web session
02:30:42:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
02:32:35:WU02:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
02:34:48:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
02:36:34:WU02:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
02:36:45:150:127.0.0.1:New Web session
02:38:51:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
02:40:26:WU02:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
02:40:27:WU01:FS00:Connecting to 65.254.110.245:80
02:40:27:WU01:FS00:Assigned to work server 155.247.164.214
02:40:27:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:11 from 155.247.164.214
02:40:27:WU01:FS00:Connecting to 155.247.164.214:8080
02:40:27:WU01:FS00:Downloading 2.83MiB
02:40:28:WU01:FS00:Download complete
02:40:28:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14852 run:50 clone:0 gen:30 core:0xa7 unit:0x0000001f9bf7a4d65ea103a38e11be74
02:42:48:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
02:43:46:158:127.0.0.1:New Web session
02:44:16:WU02:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
02:44:18:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
02:44:18:WU02:FS00:0xa7:Saving result file ener.edr
02:44:18:WU02:FS00:0xa7:Saving result file frame34.trr
02:44:18:WU02:FS00:0xa7:Saving result file md.log
02:44:18:WU02:FS00:0xa7:Saving result file science.log
02:44:18:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:44:19:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:44:19:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16801 run:1 clone:306 gen:34 core:0xa7 unit:0x0000002282ed0b915e9597e26f65cd42
02:44:19:WU02:FS00:Uploading 8.57MiB to 130.237.11.145
02:44:19:WU02:FS00:Connecting to 130.237.11.145:8080
02:44:19:WU01:FS00:Starting
02:44:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\james\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12120 -checkpoint 15 -np 11
02:44:19:WU01:FS00:Started FahCore on PID 6564
02:44:19:WU01:FS00:Core PID:5032
02:44:19:WU01:FS00:FahCore 0xa7 started
02:44:19:WU01:FS00:0xa7:*********************** Log Started 2020-05-04T02:44:19Z ***********************
02:44:19:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:44:19:WU01:FS00:0xa7:       Type: 0xa7
02:44:19:WU01:FS00:0xa7:       Core: Gromacs
02:44:19:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6564 -checkpoint 15 -np
02:44:19:WU01:FS00:0xa7:             11
02:44:19:WU01:FS00:0xa7:************************************ CBang *************************************
02:44:19:WU01:FS00:0xa7:       Date: Oct 26 2019
02:44:19:WU01:FS00:0xa7:       Time: 01:38:25
02:44:19:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:44:19:WU01:FS00:0xa7:     Branch: master
02:44:19:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
02:44:19:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:44:19:WU01:FS00:0xa7:   Platform: win32 10
02:44:19:WU01:FS00:0xa7:       Bits: 64
02:44:19:WU01:FS00:0xa7:       Mode: Release
02:44:19:WU01:FS00:0xa7:************************************ System ************************************
02:44:19:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
02:44:19:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
02:44:19:WU01:FS00:0xa7:       CPUs: 12
02:44:19:WU01:FS00:0xa7:     Memory: 63.92GiB
02:44:19:WU01:FS00:0xa7:Free Memory: 56.74GiB
02:44:19:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
02:44:19:WU01:FS00:0xa7: OS Version: 6.2
02:44:19:WU01:FS00:0xa7:Has Battery: false
02:44:19:WU01:FS00:0xa7: On Battery: false
02:44:19:WU01:FS00:0xa7: UTC Offset: -6
02:44:19:WU01:FS00:0xa7:        PID: 5032
02:44:19:WU01:FS00:0xa7:        CWD: C:\Users\james\AppData\Roaming\FAHClient\work
02:44:19:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
02:44:19:WU01:FS00:0xa7:    Version: 0.0.18
02:44:19:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:44:19:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:44:19:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
02:44:19:WU01:FS00:0xa7:       Time: 01:52:30
02:44:19:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:44:19:WU01:FS00:0xa7:************************************ Build *************************************
02:44:19:WU01:FS00:0xa7:       SIMD: avx_256
02:44:19:WU01:FS00:0xa7:********************************************************************************
02:44:19:WU01:FS00:0xa7:Project: 14852 (Run 50, Clone 0, Gen 30)
02:44:19:WU01:FS00:0xa7:Unit: 0x0000001f9bf7a4d65ea103a38e11be74
02:44:19:WU01:FS00:0xa7:Reading tar file core.xml
02:44:19:WU01:FS00:0xa7:Reading tar file frame30.tpr
02:44:19:WU01:FS00:0xa7:Digital signatures verified
02:44:19:WU01:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
02:44:19:WU01:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -cpt 15 -nt 10
02:44:19:WU01:FS00:0xa7:Steps: first=0 total=250000
02:44:21:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
02:44:25:WU02:FS00:Upload 21.14%
02:44:31:WU02:FS00:Upload 43.74%
02:44:37:WU02:FS00:Upload 66.33%
02:44:43:WU02:FS00:Upload 88.93%
02:44:46:WU02:FS00:Upload complete
02:44:46:WU02:FS00:Server responded WORK_ACK (400)
02:44:46:WU02:FS00:Final credit estimate, 8421.00 points
02:44:46:WU02:FS00:Cleaning up
02:44:54:166:127.0.0.1:New Web session
02:45:46:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
02:46:45:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
02:47:08:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
02:48:31:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
02:50:07:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
02:50:39:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
02:51:30:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
02:53:03:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
02:53:38:174:127.0.0.1:New Web session
02:54:31:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
02:54:33:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
02:56:00:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
02:57:24:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
02:58:23:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
02:58:47:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
03:00:13:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
03:01:42:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
03:02:18:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
03:03:11:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
03:04:38:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
03:06:00:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
03:06:10:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
03:07:24:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
03:08:55:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
03:10:06:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
03:10:30:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
03:11:57:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
03:13:23:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
03:14:00:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
03:14:59:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
03:16:27:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
03:17:52:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
03:17:56:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
03:19:24:182:127.0.0.1:New Web session
03:19:31:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
03:19:58:189:127.0.0.1:New Web session
03:21:05:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
03:21:48:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
03:22:35:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
03:23:32:197:127.0.0.1:New Web session
03:24:12:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
03:25:40:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
03:25:45:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
03:25:46:WU02:FS01:Connecting to 65.254.110.245:80
03:25:46:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:25:46:WU02:FS01:Connecting to 18.218.241.186:80
03:25:46:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:25:47:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:25:47:WU02:FS01:Connecting to 18.218.241.186:80
03:25:47:WU02:FS01:Assigned to work server 13.82.98.119
03:25:47:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1070] 6463 from 13.82.98.119
03:25:47:WU02:FS01:Connecting to 13.82.98.119:8080
03:25:47:ERROR:WU02:FS01:Exception: Server did not assign work unit
03:25:47:WU02:FS01:Connecting to 65.254.110.245:80
03:25:48:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:25:48:WU02:FS01:Connecting to 18.218.241.186:80
03:25:48:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:25:48:WU02:FS01:Connecting to 65.254.110.245:80
03:25:48:ERROR:WU02:FS01:Exception: Could not get an assignment
03:26:47:WU02:FS01:Connecting to 65.254.110.245:80
03:26:47:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
03:26:47:WU02:FS01:Connecting to 18.218.241.186:80
03:26:48:WU02:FS01:Assigned to work server 140.163.4.241
03:26:48:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.241
03:26:48:WU02:FS01:Connecting to 140.163.4.241:8080
03:27:07:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
03:28:22:WU02:FS01:Downloading 7.85MiB
03:28:27:WU02:FS01:Download complete
03:28:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:4655 gen:90 core:0x22 unit:0x0000007d8ca304f15e69f398f15a07dc
03:28:34:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
03:29:43:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
03:29:52:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
03:29:52:WU00:FS01:0x22:Saving result file checkpointState.xml
03:29:55:WU00:FS01:0x22:Saving result file checkpt.crc
03:29:55:WU00:FS01:0x22:Saving result file positions.xtc
03:30:00:WU00:FS01:0x22:Saving result file science.log
03:30:00:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:30:00:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
03:30:00:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:30:00:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14436 run:2178 clone:1 gen:11 core:0x22 unit:0x0000001103854c135e9a790da4b1af9f
03:30:00:WU00:FS01:Uploading 79.89MiB to 3.133.76.19
03:30:00:WU00:FS01:Connecting to 3.133.76.19:8080
03:30:01:WU02:FS01:Starting
03:30:01:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\james\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:30:01:WU02:FS01:Started FahCore on PID 16020
03:30:01:WU02:FS01:Core PID:8872
03:30:01:WU02:FS01:FahCore 0x22 started
03:30:01:WU02:FS01:0x22:*********************** Log Started 2020-05-04T03:30:01Z ***********************
03:30:01:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:30:01:WU02:FS01:0x22:       Type: 0x22
03:30:01:WU02:FS01:0x22:       Core: Core22
03:30:01:WU02:FS01:0x22:    Website: https://foldingathome.org/
03:30:01:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:30:01:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:30:01:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:30:01:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 16020 -checkpoint 15
03:30:01:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:30:01:WU02:FS01:0x22:             0 -gpu 0
03:30:01:WU02:FS01:0x22:     Config: <none>
03:30:01:WU02:FS01:0x22:************************************ Build *************************************
03:30:01:WU02:FS01:0x22:    Version: 0.0.2
03:30:01:WU02:FS01:0x22:       Date: Dec 6 2019
03:30:01:WU02:FS01:0x22:       Time: 21:30:31
03:30:01:WU02:FS01:0x22: Repository: Git
03:30:01:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:30:01:WU02:FS01:0x22:     Branch: HEAD
03:30:01:WU02:FS01:0x22:   Compiler: Visual C++ 2008
03:30:01:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:30:01:WU02:FS01:0x22:   Platform: win32 10
03:30:01:WU02:FS01:0x22:       Bits: 64
03:30:01:WU02:FS01:0x22:       Mode: Release
03:30:01:WU02:FS01:0x22:************************************ System ************************************
03:30:01:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
03:30:01:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
03:30:01:WU02:FS01:0x22:       CPUs: 12
03:30:01:WU02:FS01:0x22:     Memory: 63.92GiB
03:30:01:WU02:FS01:0x22:Free Memory: 58.77GiB
03:30:01:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
03:30:01:WU02:FS01:0x22: OS Version: 6.2
03:30:01:WU02:FS01:0x22:Has Battery: false
03:30:01:WU02:FS01:0x22: On Battery: false
03:30:01:WU02:FS01:0x22: UTC Offset: -6
03:30:01:WU02:FS01:0x22:        PID: 8872
03:30:01:WU02:FS01:0x22:        CWD: C:\Users\james\AppData\Roaming\FAHClient\work
03:30:01:WU02:FS01:0x22:         OS: Windows 10 Pro
03:30:01:WU02:FS01:0x22:    OS Arch: AMD64
03:30:01:WU02:FS01:0x22:********************************************************************************
03:30:01:WU02:FS01:0x22:Project: 11744 (Run 0, Clone 4655, Gen 90)
03:30:01:WU02:FS01:0x22:Unit: 0x0000007d8ca304f15e69f398f15a07dc
03:30:01:WU02:FS01:0x22:Reading tar file core.xml
03:30:01:WU02:FS01:0x22:Reading tar file integrator.xml
03:30:01:WU02:FS01:0x22:Reading tar file state.xml
03:30:03:WU02:FS01:0x22:Reading tar file system.xml
03:30:04:WU02:FS01:0x22:Digital signatures verified
03:30:04:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:30:04:WU02:FS01:0x22:Version 0.0.2
03:30:21:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
03:30:21:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:30:51:WU00:FS01:Upload 0.16%
03:31:26:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
03:31:37:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
03:31:37:204:127.0.0.1:New Web session
03:31:44:WU00:FS01:Upload 0.23%
03:31:50:WU00:FS01:Upload 4.46%
03:31:56:WU00:FS01:Upload 9.31%
03:32:02:WU00:FS01:Upload 14.16%
03:32:08:WU00:FS01:Upload 19.01%
03:32:14:WU00:FS01:Upload 23.86%
03:32:20:WU00:FS01:Upload 28.63%
03:32:26:WU00:FS01:Upload 33.48%
03:32:32:WU00:FS01:Upload 38.25%
03:32:38:WU00:FS01:Upload 43.10%
03:32:44:WU00:FS01:Upload 47.88%
03:32:50:WU00:FS01:Upload 52.73%
03:32:54:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
03:32:55:213:127.0.0.1:New Web session
03:32:56:WU00:FS01:Upload 57.58%
03:33:02:WU00:FS01:Upload 62.35%
03:33:04:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
03:33:08:WU00:FS01:Upload 67.20%
03:33:14:WU00:FS01:Upload 71.97%
03:33:20:WU00:FS01:Upload 76.82%
03:33:26:WU00:FS01:Upload 81.51%
03:33:32:WU00:FS01:Upload 86.36%
03:33:38:WU00:FS01:Upload 91.06%
03:33:44:WU00:FS01:Upload 95.99%
03:33:50:WU00:FS01:Upload complete
03:33:50:WU00:FS01:Server responded WORK_ACK (400)
03:33:50:WU00:FS01:Final credit estimate, 188786.00 points
03:33:50:WU00:FS01:Cleaning up
It's interesting, because if I look up the project ID from when the WU was first downloaded in the log, it's the more recent description, the one that it changed to. I wonder if they just got the description wrong, not sure.
muziqaz wrote:PPD values are liquid values, which means they change, going up when GPU is folding and nothing else is happening on the system, and it will go down with time if you are doing something to take away some GPU power off folding. Pausing and restarting a WU can influence PPD value as well, since you wasted few minutes without folding, value will be smaller. It is possible in your case, with restart your GPU got clean period of folding where nothing else could influence it, and thus PPD value increased. The more you fold the bigger PPD value there is gonna be.
Yeah, but I'm not simply talking about the PPD estimate in the FAH control panel.
Post by muziqaz »
I see nothing wrong with the logs, and after restart your GPU slot did pick up the same projects and WU as before, or am I missing something?
before restart:
After restart:
As you can see same stuff, and restarted exactly were it stopped :)
And final credit estimate for a project is printed only once, when it is accepted by a server, so most likely you are mixing with other WU in the logs (easy to do, since unfiltered logs are quite hard to dissect :) )
FAH Omega tester
woodworth1
Yeah, maybe they updated the description of the WU, because the description prior to the restart was for a different project, and the estimated credit was around 160,000 points, but I actually ended up getting more than that.
Post by muziqaz »
woodworth1 wrote:Yeah, maybe they updated the description of the WU, because the description prior to the restart was for a different project, and the estimated credit was around 160,000 points, but I actually ended up getting more than that.
I do not see anywhere showing 160k estimate.
As I mentioned before, final credit estimate is printed only once when the Wu is accepted by server:
FAH Omega tester
Post by muziqaz »
By the way, if there are any changes to Base Credit for a project while you are folding that project, the change will not affect you. You will get whatever was set when you downloaded the WU :)
The next one downloaded will be with updated base credit values
FAH Omega tester
woodworth1
160k was the credit estimate in the web client prior to the restart, however it went up to 190ish after the restart, and the final credit ended up being around there.
Post by muziqaz »
woodworth1 wrote: 160k was the credit estimate in the web client prior to the restart, however it went up to 190ish after the restart, and the final credit ended up being around there.
Ah, I see now. Yes, web control is showing base credit without Quick Return Bonus :)
As you can see estimated points in webcontrol are different from final PPD value :)
FAH Omega tester
woodworth1
I've also noticed that if a GPU WU hasn't been assigned, after say, 10 attempts, it'll impose a delay between the last failed attempt and subsequent attempt to obtain a WU, but if I pause and then unpause the client, the delay is reset, and it is sometimes able to obtain a GPU WU much more quickly. Is this intended, or is the reset of the delay between WU attempts after pausing and unpausing the client a bug?
When a WU approaches completion, FAHClient will attempt to download a new assignment. If it succeeds, there are now two WUs associated with the same slot. If you do nothing, the first one will finish and the second one will begin processing with minimal delay.
I don't understand your initial report. You said one WU was 60% complete but it started a different WUs. That's certainly not normal. The first WU should have been the only GPU WU that you had so how did it start another one. Please find that log segment in the history file "logs" (The other WUs associated with the CPU slots can be ignored.) This certainly looks like one WU reached 100% just as a new WU was downloading which shouldn't have been a problem at all.
If, while two WUs are enqueued, IF YOU PAUSE and then UNPAUSE FAH, either one may start processing, not necessarily the one that's almost finished. That was supposedly fixed some time in the past, but apparently not although I don't see that that happened.
Personally, I normally adjust the next-unit-percentage to 100 which is great when we're not dealing with servers that are bandwidth-saturated. I'll open a ticket on this issue, now that I've been reminded of it.
Post by muziqaz »
woodworth1 wrote:I've also noticed that if a GPU WU hasn't been assigned, after say, 10 attempts, it'll impose a delay between the last failed attempt and subsequent attempt to obtain a WU, but if I pause and then unpause the client, the delay is reset, and it is sometimes able to obtain a GPU WU much more quickly. Is this intended, or is the reset of the delay between WU attempts after pausing and unpausing the client a bug?
that is normal behavior
FAH Omega tester
woodworth1
bruce wrote:When a WU approaches completion, FAHClient will attempt to download a new assignment. If it succeeds, there are now two WUs associated with the same slot. If you do nothing, the first one will finish and the second one will begin processing with minimal delay.
My initial report was based on the fact that the description and credit estimate for the GPU WU changed after the system restarted, and after the client was unpaused. It would appear that, according to the log, the project ID stayed the same, but the description changed. I am sure that I was not viewing the description for the CPU work unit, as the credit estimate for the GPU work unit which changed alongside the description was consistent with the credit that was awarded for the GPU work unit.
Post by muziqaz »
Webcontrol pulls descriptions from project summary page live, whatever changes happen, they will be shown straight away (or after webcontrol restart). Base credit however, even if displayed as updated value, will not change for your current WU. Your current WU will get what it was initially set to get. Base Credit values almost never change in public FAH. Last time it gets adjusted is during Beta stage
FAH Omega tester
