GPU Connection Problems?
tiltingatfahcores
Post by tiltingatfahcores »
Hello, I'm trying to leave FAH running on my old PC, but I am having GPU problems, and quickly getting out of my depth.
I checked, and my GPU is on the whitelist (GeForce GT 240)
When I first installed FAH, it detected 1 CPU slot. I manually added slots so I have 2 CPU and 1 GPU.
Whenever I look at the status, the CPU slot is working on something, but the GPU slot is always Downloading at 0%
The log makes it look like the server it's pinging is not responding.
Is there some problem with my setup?
Log:
*********************** Log Started 2020-05-03T17:15:58Z ***********************
17:15:58:************************* Folding@home Client *************************
17:15:58:        Website: https://foldingathome.org/
17:15:58:      Copyright: (c) 2009-2018 foldingathome.org
17:15:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:15:58:           Args:
17:15:58:         Config: C:\Users\Patrick\AppData\Roaming\FAHClient\config.xml
17:15:58:******************************** Build ********************************
17:15:58:        Version: 7.5.1
17:15:58:           Date: May 11 2018
17:15:58:           Time: 13:06:32
17:15:58:     Repository: Git
17:15:58:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:15:58:         Branch: master
17:15:58:       Compiler: Visual C++ 2008
17:15:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:15:58:       Platform: win32 10
17:15:58:           Bits: 32
17:15:58:           Mode: Release
17:15:58:******************************* System ********************************
17:15:58:            CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
17:15:58:         CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
17:15:58:           CPUs: 2
17:15:58:         Memory: 6.00GiB
17:15:58:    Free Memory: 4.30GiB
17:15:58:        Threads: WINDOWS_THREADS
17:15:58:     OS Version: 6.2
17:15:58:    Has Battery: false
17:15:58:     On Battery: false
17:15:58:     UTC Offset: -4
17:15:58:            PID: 4300
17:15:58:            CWD: C:\Users\Patrick\AppData\Roaming\FAHClient
17:15:58:             OS: Windows 10 Home
17:15:58:        OS Arch: AMD64
17:15:58:           GPUs: 1
17:15:58:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:0 GT215 [GeForce GT 240]
17:15:58:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:6.5
17:15:58:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.0 Driver:342.1
17:15:58:  Win32 Service: false
17:15:58:***********************************************************************
17:15:58:<config>
17:15:58:  <!-- Folding Core -->
17:15:58:  <checkpoint v='30'/>
17:15:58:
17:15:58:  <!-- Network -->
17:15:58:  <proxy v=':8080'/>
17:15:58:
17:15:58:  <!-- Slot Control -->
17:15:58:  <power v='FULL'/>
17:15:58:
17:15:58:  <!-- User Information -->
17:15:58:  <passkey v='********************************'/>
17:15:58:  <team v='50959'/>
17:15:58:  <user v='semitones'/>
17:15:58:
17:15:58:  <!-- Folding Slots -->
17:15:58:  <slot id='0' type='CPU'>
17:15:58:    <cpus v='2'/>
17:15:58:  </slot>
17:15:58:  <slot id='1' type='GPU'/>
17:15:58:</config>
17:15:58:Trying to access database...
17:15:58:Successfully acquired database lock
17:15:58:Enabled folding slot 00: READY cpu:2
17:15:58:Enabled folding slot 01: READY gpu:0:GT215 [GeForce GT 240]
17:15:58:WU02:FS00:Starting
17:15:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Patrick\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4300 -checkpoint 30 -np 2
17:16:01:WU02:FS00:Started FahCore on PID 2868
17:16:03:WU02:FS00:Core PID:7080
17:16:03:WU02:FS00:FahCore 0xa7 started
17:16:06:WU02:FS00:0xa7:*********************** Log Started 2020-05-03T17:16:05Z ***********************
17:16:06:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:16:06:WU02:FS00:0xa7:       Type: 0xa7
17:16:06:WU02:FS00:0xa7:       Core: Gromacs
17:16:06:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2868 -checkpoint 30 -np 2
17:16:06:WU02:FS00:0xa7:************************************ CBang *************************************
17:16:06:WU02:FS00:0xa7:       Date: Oct 26 2019
17:16:06:WU02:FS00:0xa7:       Time: 01:38:35
17:16:06:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:16:06:WU02:FS00:0xa7:     Branch: master
17:16:06:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
17:16:06:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:16:06:WU02:FS00:0xa7:   Platform: win32 10
17:16:06:WU02:FS00:0xa7:       Bits: 64
17:16:06:WU02:FS00:0xa7:       Mode: Release
17:16:06:WU02:FS00:0xa7:************************************ System ************************************
17:16:06:WU02:FS00:0xa7:        CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+
17:16:06:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
17:16:06:WU02:FS00:0xa7:       CPUs: 2
17:16:06:WU02:FS00:0xa7:     Memory: 6.00GiB
17:16:06:WU02:FS00:0xa7:Free Memory: 4.26GiB
17:16:06:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
17:16:06:WU02:FS00:0xa7: OS Version: 6.2
17:16:06:WU02:FS00:0xa7:Has Battery: false
17:16:06:WU02:FS00:0xa7: On Battery: false
17:16:06:WU02:FS00:0xa7: UTC Offset: -4
17:16:06:WU02:FS00:0xa7:        PID: 7080
17:16:06:WU02:FS00:0xa7:        CWD: C:\Users\Patrick\AppData\Roaming\FAHClient\work
17:16:06:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
17:16:06:WU02:FS00:0xa7:    Version: 0.0.18
17:16:06:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:16:06:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:16:06:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
17:16:06:WU02:FS00:0xa7:       Time: 01:52:44
17:16:06:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:16:06:WU02:FS00:0xa7:************************************ Build *************************************
17:16:06:WU02:FS00:0xa7:       SIMD: sse2
17:16:06:WU02:FS00:0xa7:********************************************************************************
17:16:06:WU02:FS00:0xa7:Project: 14578 (Run 0, Clone 1343, Gen 50)
17:16:06:WU02:FS00:0xa7:Unit: 0x00000036287234c95e7eeb59f378d304
17:16:06:WU02:FS00:0xa7:Digital signatures verified
17:16:07:WU02:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpi state.cpt -cpt 30 -nt 2
17:16:14:WU02:FS00:0xa7:Steps: first=6250000 total=125000
17:16:21:WU00:FS01:Connecting to 65.254.110.245:8080
17:16:22:WU00:FS01:Assigned to work server 192.0.2.1
17:16:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:16:22:WU00:FS01:Connecting to 192.0.2.1:8080
17:16:25:WU02:FS00:0xa7:Completed 12311 out of 125000 steps (9%)
17:16:43:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:16:43:WU00:FS01:Connecting to 192.0.2.1:80
17:17:05:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:17:06:WU00:FS01:Connecting to 65.254.110.245:8080
17:17:07:WU00:FS01:Assigned to work server 192.0.2.1
17:17:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:17:07:WU00:FS01:Connecting to 192.0.2.1:8080
17:17:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:17:29:WU00:FS01:Connecting to 192.0.2.1:80
17:17:50:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:18:06:WU00:FS01:Connecting to 65.254.110.245:8080
17:18:06:WU00:FS01:Assigned to work server 192.0.2.1
17:18:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:18:08:WU00:FS01:Connecting to 192.0.2.1:8080
17:18:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:18:29:WU00:FS01:Connecting to 192.0.2.1:80
17:18:50:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:19:44:WU00:FS01:Connecting to 65.254.110.245:8080
17:19:44:WU00:FS01:Assigned to work server 192.0.2.1
17:19:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:19:45:WU00:FS01:Connecting to 192.0.2.1:8080
17:20:06:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:20:06:WU00:FS01:Connecting to 192.0.2.1:80
17:20:27:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:22:21:WU00:FS01:Connecting to 65.254.110.245:8080
17:22:21:WU00:FS01:Assigned to work server 192.0.2.1
17:22:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:22:22:WU00:FS01:Connecting to 192.0.2.1:8080
17:22:27:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
17:22:43:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:22:43:WU00:FS01:Connecting to 192.0.2.1:80
17:23:05:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:26:35:WU00:FS01:Connecting to 65.254.110.245:8080
17:26:35:WU00:FS01:Assigned to work server 192.0.2.1
17:26:36:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:26:36:WU00:FS01:Connecting to 192.0.2.1:8080
17:26:57:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:26:57:WU00:FS01:Connecting to 192.0.2.1:80
17:27:19:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:33:27:WU00:FS01:Connecting to 65.254.110.245:8080
17:33:27:WU00:FS01:Assigned to work server 192.0.2.1
17:33:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [GeForce GT 240] from 192.0.2.1
17:33:28:WU00:FS01:Connecting to 192.0.2.1:8080
17:33:49:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:33:49:WU00:FS01:Connecting to 192.0.2.1:80
17:34:10:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Re: GPU Connection Problems?
Just delete the GPU folding slot for the GT 240. GPUs.txt is not just a whitelist, it also blacklists GPUs that can not be used - viewtopic.php?f=83&t=26208.
The entry for the GT 240 shows that is blacklisted:
0x10de:0x0ca3:::GT215 [GeForce GT 240]
The blank fields between the colons in the middle indicate this.
TheDareDavid
Post by TheDareDavid »
Hello,
first of all, I am happy to contribute, so, thank you for this possibility and the support.
A few days ago I started F@H, following more or less the same steps described also by @tiltingatfahcores during the setup:
- CPU and 4 cores recognised by default (OK)
- GPU (NVIDIA) present, but not automatically present into the slots inside the Advanced Control GUI -> I added it manually, than it appeared also into the Advanced Control GUI.
After having checked the GPUs.txt list, it seems that the GPU I am currently using is supported (if I well understood it is whitelisted): it is an NVIDIA GeForce 820M.
Everything seems well configured, but what happens is:
- The Client connects to the server and downloads a WU
- Starts the executable (FahCore 0x22 appears into the log as actually a FahCore_22.exe is present inside the core directory):
C:\Users\...\FAHClient\cores\cores.foldingathome.org\v7\win\64bit\Core_22.fah
- Then a
BAD_WORK_UNIT (114 = 0x72)
error appears into the log.
- Again the Client requesta another WU, connects, downloads, than the same error appears into the log and so on, in a loop.
Actually the GPU is not calculationg anything since yesterday May 2, 2020.
Here is a summary of the log file filtered for what concern only the GPU slot:
*********************** Log Started 2020-05-03T18:26:35Z ***********************
18:27:49:WU01:FS01:Connecting to 18.218.241.186:80
18:27:50:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:27:50:ERROR:WU01:FS01:Exception: Could not get an assignment
18:29:20:WU01:FS01:Connecting to 65.254.110.245:80
18:29:22:WU01:FS01:Assigned to work server 3.133.76.19
18:29:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF117 [GeForce 620M/720M/820M] from 3.133.76.19
18:29:22:WU01:FS01:Connecting to 3.133.76.19:8080
18:29:28:FS01:Paused
18:29:34:FS01:Unpaused
18:29:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:29:43:WU01:FS01:Connecting to 3.133.76.19:80
18:30:44:WU01:FS01:Downloading 9.20MiB
18:30:50:WU01:FS01:Download 25.82%
18:30:56:WU01:FS01:Download 75.41%
18:30:59:WU01:FS01:Download complete
18:30:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16433 run:801 clone:1 gen:11 core:0x22 unit:0x0000000e03854c135e9a4effa2b3b88f
18:30:59:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
18:30:59:WU01:FS01:Connecting to cores.foldingathome.org:80
18:31:00:WU01:FS01:FahCore 22: Downloading 4.04MiB
18:31:06:WU01:FS01:FahCore 22: 13.91%
18:31:12:WU01:FS01:FahCore 22: 71.10%
18:31:14:WU01:FS01:FahCore 22: Download complete
18:31:14:WU01:FS01:Valid core signature
18:31:14:WU01:FS01:Unpacked 13.50MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
18:31:14:WU01:FS01:Starting
18:31:14:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\D\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 2588 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
18:31:14:WU01:FS01:Started FahCore on PID 10688
18:31:14:WU01:FS01:Core PID:9008
18:31:14:WU01:FS01:FahCore 0x22 started
18:31:23:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
Is something going wrong in the WU assignement, or should I config differently the slot?
Thank you in advance
Dave
tiltingatfahcores
Thanks, that solves a lot of mysteries. Here is a link to some more information I found about the 192.0.2.1:8080 thing -- it looks like the newer versions of FAH might have more informational text when this happens: https://github.com/FoldingAtHome/fah-issues/issues/1309
It's almost like the project I learned about 10 years ago has grown super rapidly in the past few months! ;)
Confusing relics of the past?:
* blacklisted and whitelisted gpu all being in the same txt file called whitelist
* server recognizes an incompatible setup, but redirects to dummy WU server (192...) because it can't update the local gui in a meaningful way
TheDareDavid wrote:...Is something going wrong in the WU assignement, or should I config differently the slot?...
Welcome to the F@H Forum TheDareDavid,
Can you please post the first 100 lines of the log file which will show what the client thinks your system is and how it is configured.
Also, you seem to be getting issues so I would suggest that you review this topic and see if you can resolve your issue: viewtopic.php?f=19&t=16526
TheDareDavid
Thank you for the reply @ PanterX.
Sorry for my late reply, but for many reasons I wasn't able to connect again to the forum during the last week.
ByTheWay, during the week I connected again many times to fold, but the same issue of "not good WU assignement to the GPU" still remains.
So, here are the first 100 lines from the log file:
*********************** Log Started 2020-05-09T11:30:45Z ***********************
11:30:45:****************************** FAHClient ******************************
11:30:45:        Version: 7.6.9
11:30:45:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:30:45:      Copyright: 2020 foldingathome.org
11:30:45:       Homepage: https://foldingathome.org/
11:30:45:           Date: Apr 17 2020
11:30:45:           Time: 11:13:06
11:30:45:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
11:30:45:         Branch: master
11:30:45:       Compiler: Visual C++ 2008
11:30:45:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:30:45:       Platform: win32 10
11:30:45:           Bits: 32
11:30:45:           Mode: Release
11:30:45:           Args: --open-web-control
11:30:45:         Config: C:\Users\...\AppData\Roaming\FAHClient\config.xml
11:30:45:******************************** CBang ********************************
11:30:45:           Time: 11:10:09
11:30:45:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
11:30:45:           Bits: 32
11:30:45:******************************* System ********************************
11:30:45:            CPU: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
11:30:45:         CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
11:30:45:           CPUs: 4
11:30:45:         Memory: 7.92GiB
11:30:45:    Free Memory: 4.89GiB
11:30:45:        Threads: WINDOWS_THREADS
11:30:45:     OS Version: 6.2
11:30:45:    Has Battery: true
11:30:45:     On Battery: true
11:30:45:     UTC Offset: 2
11:30:45:            PID: 5724
11:30:45:            CWD: C:\Users\...\AppData\Roaming\FAHClient
11:30:45:             OS: Windows 10 Home
11:30:45:        OS Arch: AMD64
11:30:45:           GPUs: 1
11:30:45:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:2 GF117 [GeForce 620M/720M/820M]
11:30:45:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:2.1 Driver:8.0
11:30:45:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
11:30:45:OpenCL Device 2: Platform:1 Device:0 Bus:4 Slot:0 Compute:1.1 Driver:382.5
11:30:45:  Win32 Service: false
11:30:45:******************************* libFAH ********************************
11:30:45:           Date: Apr 15 2020
11:30:45:           Time: 14:53:14
11:30:45:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:30:45:           Bits: 32
11:30:45:***********************************************************************
11:30:45:<config>
11:30:45:  <!-- Network -->
11:30:45:  <proxy v=':8080'/>
11:30:45:
11:30:45:  <!-- Slot Control -->
11:30:45:  <pause-on-battery v='false'/>
11:30:45:  <power v='full'/>
11:30:45:
11:30:45:  <!-- User Information -->
11:30:45:  <passkey v='*****'/>
11:30:45:  <team v='264556'/>
11:30:45:  <user v='DareDavid'/>
11:30:45:
11:30:45:  <!-- Folding Slots -->
11:30:45:  <slot id='0' type='CPU'>
11:30:45:    <cpus v='4'/>
11:30:45:    <idle v='False'/>
11:30:45:    <paused v='true'/>
11:30:45:  </slot>
11:30:45:  <slot id='1' type='GPU'>
11:30:45:  </slot>
11:30:45:</config>
11:30:45:Trying to access database...
11:30:45:Successfully acquired database lock
11:30:45:Enabled folding slot 00: PAUSED cpu:4 (by user)
11:30:45:Enabled folding slot 01: PAUSED gpu:0:GF117 [GeForce 620M/720M/820M] (by user)
11:30:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14239 run:0 clone:1703 gen:0 core:0xa7 unit:0x00000000cedfaa925ea9f79762aa6614
...and here is the issue of "bad WU assignement" while it is in progress (even while I am writing):
11:44:26:WU00:FS01:Download complete
11:44:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14253 run:1725 clone:4 gen:1 core:0x22 unit:0x00000001cedfaa925eaba95c9d8d3eab
11:44:26:WU00:FS01:Starting
11:44:26:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\...\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 5724 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
11:44:26:WU00:FS01:Started FahCore on PID 592
11:44:26:WU00:FS01:Core PID:8220
11:44:26:WU00:FS01:FahCore 0x22 started
11:44:27:WU00:FS01:0x22:*********************** Log Started 2020-05-09T11:44:26Z ***********************
11:44:27:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:44:27:WU00:FS01:0x22:       Type: 0x22
11:44:27:WU00:FS01:0x22:       Core: Core22
11:44:27:WU00:FS01:0x22:    Website: https://foldingathome.org/
11:44:27:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
11:44:27:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:44:27:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
11:44:27:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 592 -checkpoint 15
11:44:27:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
11:44:27:WU00:FS01:0x22:             0 -gpu 0
11:44:27:WU00:FS01:0x22:     Config: <none>
11:44:27:WU00:FS01:0x22:************************************ Build *************************************
11:44:27:WU00:FS01:0x22:    Version: 0.0.5
11:44:27:WU00:FS01:0x22:       Date: Apr 22 2020
11:44:27:WU00:FS01:0x22:       Time: 04:42:59
11:44:27:WU00:FS01:0x22: Repository: Git
11:44:27:WU00:FS01:0x22:   Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
11:44:27:WU00:FS01:0x22:     Branch: HEAD
11:44:27:WU00:FS01:0x22:   Compiler: Visual C++ 2008
11:44:27:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:44:27:WU00:FS01:0x22:   Platform: win32 10
11:44:27:WU00:FS01:0x22:       Bits: 64
11:44:27:WU00:FS01:0x22:       Mode: Release
11:44:27:WU00:FS01:0x22:************************************ System ************************************
11:44:27:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
11:44:27:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
11:44:27:WU00:FS01:0x22:       CPUs: 4
11:44:27:WU00:FS01:0x22:     Memory: 7.92GiB
11:44:27:WU00:FS01:0x22:Free Memory: 3.38GiB
11:44:27:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
11:44:27:WU00:FS01:0x22: OS Version: 6.2
11:44:27:WU00:FS01:0x22:Has Battery: true
11:44:27:WU00:FS01:0x22: On Battery: false
11:44:27:WU00:FS01:0x22: UTC Offset: 2
11:44:27:WU00:FS01:0x22:        PID: 8220
11:44:27:WU00:FS01:0x22:        CWD: C:\Users\...\AppData\Roaming\FAHClient\work
11:44:27:WU00:FS01:0x22:         OS: Windows 10 Home
11:44:27:WU00:FS01:0x22:    OS Arch: AMD64
11:44:27:WU00:FS01:0x22:********************************************************************************
11:44:27:WU00:FS01:0x22:Project: 14253 (Run 1725, Clone 4, Gen 1)
11:44:27:WU00:FS01:0x22:Unit: 0x00000001cedfaa925eaba95c9d8d3eab
11:44:27:WU00:FS01:0x22:Reading tar file core.xml
11:44:27:WU00:FS01:0x22:Reading tar file integrator.xml
11:44:27:WU00:FS01:0x22:Reading tar file state.xml
11:44:34:WU00:FS01:0x22:Reading tar file system.xml
11:44:43:WU00:FS01:0x22:Digital signatures verified
11:44:43:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:44:43:WU00:FS01:0x22:Version 0.0.5
11:47:36:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
11:47:36:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:47:36:WU00:FS01:0x22:Saving result file science.log
11:47:36:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
11:47:36:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:47:36:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14253 run:1725 clone:4 gen:1 core:0x22 unit:0x00000001cedfaa925eaba95c9d8d3eab
11:47:36:WU00:FS01:Uploading 8.50KiB to 206.223.170.146
11:47:36:WU00:FS01:Connecting to 206.223.170.146:8080
11:47:37:WU02:FS01:Connecting to 65.254.110.245:80
11:47:37:WU02:FS01:Assigned to work server 206.223.170.146
11:47:37:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF117 [GeForce 620M/720M/820M] from 206.223.170.146
11:47:37:WU02:FS01:Connecting to 206.223.170.146:8080
11:47:58:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:47:58:WU00:FS01:Connecting to 206.223.170.146:80
11:47:59:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:47:59:WU02:FS01:Connecting to 206.223.170.146:80
11:48:19:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:48:19:WU00:FS01:Trying to send results to collection server
11:48:19:WU00:FS01:Uploading 8.50KiB to 52.224.109.74
11:48:19:WU00:FS01:Connecting to 52.224.109.74:8080
11:48:20:WU00:FS01:Upload complete
11:48:20:WU00:FS01:Server responded WORK_ACK (400)
11:48:20:WU00:FS01:Cleaning up
11:48:20:ERROR:WU02:FS01:Exception: Failed to connect to 206.223.170.146:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:48:21:WU02:FS01:Connecting to 65.254.110.245:80
11:48:21:WU02:FS01:Assigned to work server 128.252.203.10
11:48:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF117 [GeForce 620M/720M/820M] from 128.252.203.10
11:48:21:WU02:FS01:Connecting to 128.252.203.10:8080
11:48:43:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:48:43:WU02:FS01:Connecting to 128.252.203.10:80
11:49:45:WU02:FS01:Downloading 51.19MiB
11:49:51:WU02:FS01:Download 7.08%
11:49:57:WU02:FS01:Download 15.50%
What's you opinion?
Looking forward to fold even better.
Regards
D
What GPU model do you have? Have you installed the latest version of the Drivers from Nvidia? Is your GPU overclocked? What temperatures is your GPU running at?
Currently, there seems that the supply of GPU WUs haven't quite matched the demand of GPU WUs so it can take a while to get a GPU WU. However, it is not good that your GPU is getting this error regularly:
As that indicates an issue on your system which needs to be addressed first to allow your GPU to continue folding without issues.
TheDareDavid
Well,
the GPU model is an NVIDIA GeForce 820M with dedicated memory (of course).
It's not overclocked, it works with other softwares (like CAD softwares which make use of it) and I have the latest drivers installed on it (latest referred to the last made available by NVIDIA, as the GPU is not so young... :mrgreen: ).
Consider also that it is a week that I am experiencing this problem and no usable WU is ever arrived to the GPU since then...
What type of error is the BAD_WORK_UNIT (114 = 0x72) ?
What can I do to have a look if it is true or it is a false positive?
Dave
Assuming that you have been folding on the GPU for a while without issues, a potential reason that you're encountering this issue now is because Project 14253 is a massive one (438,651 atoms) and was released a few days ago (viewtopic.php?f=24&t=35080). Different projects may stress the GPU differently and generally speaking, folding is measurably more stressful than CAD or other benchmark/stress tests.
BAD_WORK_UNIT is when the sanity check (data/science check) fails. Statistically, there are bad WUs but it is very few but the same issue can be caused by hardware issues too. A quick way is to look up the WU and if other donors can successfully fold it, it is a good WU and the issue lies in your system 99% of the time. Currently, you're the only donor that the WU has been assigned to: https://apps.foldingathome.org/wu#proje ... ne=4&gen=1 so wait a few hours and check back.
Your 820M is one of two different models given that name by nVidia. It is based on the older Fermi GF117 chip and is essentially a rebadged GT 620M GPU running at a bit higher clock rate. There was also a GT 720M that again was a a rebadged GT 620M.
Apparently a later version of the GT 820M was planned and possibly released that was based on a Kepler GPU chip, but I can't find quickly any further information on that.
The Fermi based GPUs are starting to show some issues lately as researchers have started to use some simulation methods available in the OpenMM based Core_22 that had not been used in the past. The Fermi based GPUs support OpenCL 1.1 and the software is based on OpenCL 1.2 support being present. These GPUs had worked mostly before, now there are projects they fail on. It is guessed that the projects are now calling for OpenCL 1.2 specific support that these don't have. They are looking into this to determine details of what works and what doesn't.
That set of issues may be related to the errors you have seen. The other possibility is this being a laptop. Many laptops with a both a discrete GPU like the GT 820M and the iGPU from an Intel processor such as your I5-5200U use nVidia's Optimus to switch between using the iGPU for low power needs and the other GPU. If folding starts up the folding core and the GT 820M is not active, then it will fail.
Workarounds posted here have included disabling the iGPU, or setting the discrete GPU to always be active. Details will depend on the version of Optimus present. I would check for how this is done on your laptop.
