11741 (0, 2910, 65)
Dave?
11741 (0, 2910, 65)
Post by Dave? »
This is my second post on the forum. I let my previous WU expire because someone pointed out I was assigned a unit that was already completed and accepted, providing no project value.
This work unit is suffering a similar problem. I was assigned a WU this morning and it is estimated to complete in over 3 days. My GPU usually completes tasks in a few hours, and the previous one was not going to be completed by the expiration. This one will be completed long after the timeout and provide only the base points on completion. As stated in the previous post, I am fine with minuscule points, but if my hardware is struggling with these projects I'd rather shut down the GPU and focus on the CPUs I have while someone with better suited hardware completes the WUs faster.
Is this a problem with the GPU or a recent set of projects that I just happen to struggle with?
Some troubleshooting points:
Stock hardware, stock drivers, stock BIOS
Dusted system
Hardware monitor says GPU is lower temp than CPU and well within within its limits.
Fans are running fine.
Re: 11741 (0, 2910, 65)
First, is the estimate after the WU has run for at least 2-3% continuously? If not, the estimate will be off, usually on the high side.
Two, as mentioned in that other topic, post your log information. We need to see the first couple hundred lines that shows what the client detected as hardware and software, plus a section showing the WU being worked on. This topic has directions to the log and how to post depending on which OS you are running - viewtopic.php?f=61&t=26036.
Dave?
Post by Dave? »
I hope I did this right. I grabbed it at the point it asked the server for a task to 5% completion on GPU. It is currently at 15.55% with no pausing or power issues.
05:32:07:WU00:FS01:Assigned to work server 140.163.4.241
05:32:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106M [GeForce GTX 1060 Mobile] from 140.163.4.241
05:32:07:WU00:FS01:Connecting to 140.163.4.241:8080
05:32:07:WU01:FS00:0xa7:Completed 27164 out of 250000 steps (10%)
05:32:29:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
05:32:54:Removing old file 'configs/config-20200426-122459.xml'
05:32:54:Saving configuration to config.xml
05:32:54:<config>
05:32:54:  <!-- Logging -->
05:32:54:  <verbosity v='4'/>
05:32:54:
05:32:54:  <!-- Network -->
05:32:54:  <proxy v=':8080'/>
05:32:54:
05:32:54:  <!-- Slot Control -->
05:32:54:  <power v='FULL'/>
05:32:54:
05:32:54:  <!-- User Information -->
05:32:54:  <passkey v='********************************'/>
05:32:54:  <team v='260817'/>
05:32:54:  <user v='Dave?'/>
05:32:54:
05:32:54:  <!-- Folding Slots -->
05:32:54:  <slot id='0' type='CPU'/>
05:32:54:  <slot id='1' type='GPU'/>
05:32:54:</config>
05:33:58:WU00:FS01:Downloading 11.97MiB
05:34:01:WU00:FS01:Download complete
05:34:01:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:2910 gen:65 core:0x22 unit:0x0000005f8ca304f15e693b22dbbf65c8
05:34:01:WU00:FS01:Starting
05:34:01:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Work\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 7604 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:34:01:WU00:FS01:Started FahCore on PID 32772
05:34:02:WU00:FS01:Core PID:46144
05:34:02:WU00:FS01:FahCore 0x22 started
05:34:02:WU00:FS01:0x22:*********************** Log Started 2020-05-03T05:34:02Z ***********************
05:34:02:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:34:02:WU00:FS01:0x22:       Type: 0x22
05:34:02:WU00:FS01:0x22:       Core: Core22
05:34:02:WU00:FS01:0x22:    Website: https://foldingathome.org/
05:34:02:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:34:02:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:34:02:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:34:02:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 32772 -checkpoint 15
05:34:02:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:34:02:WU00:FS01:0x22:             0 -gpu 0
05:34:02:WU00:FS01:0x22:     Config: <none>
05:34:02:WU00:FS01:0x22:************************************ Build *************************************
05:34:02:WU00:FS01:0x22:    Version: 0.0.2
05:34:02:WU00:FS01:0x22:       Date: Dec 6 2019
05:34:02:WU00:FS01:0x22:       Time: 21:30:31
05:34:02:WU00:FS01:0x22: Repository: Git
05:34:02:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:34:02:WU00:FS01:0x22:     Branch: HEAD
05:34:02:WU00:FS01:0x22:   Compiler: Visual C++ 2008
05:34:02:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:34:02:WU00:FS01:0x22:   Platform: win32 10
05:34:02:WU00:FS01:0x22:       Bits: 64
05:34:02:WU00:FS01:0x22:       Mode: Release
05:34:02:WU00:FS01:0x22:************************************ System ************************************
05:34:02:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
05:34:02:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:34:02:WU00:FS01:0x22:       CPUs: 4
05:34:02:WU00:FS01:0x22:     Memory: 11.87GiB
05:34:02:WU00:FS01:0x22:Free Memory: 6.64GiB
05:34:02:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
05:34:02:WU00:FS01:0x22: OS Version: 6.2
05:34:02:WU00:FS01:0x22:Has Battery: true
05:34:02:WU00:FS01:0x22: On Battery: false
05:34:02:WU00:FS01:0x22: UTC Offset: -4
05:34:02:WU00:FS01:0x22:        PID: 46144
05:34:02:WU00:FS01:0x22:        CWD: C:\Users\Work\AppData\Roaming\FAHClient\work
05:34:02:WU00:FS01:0x22:         OS: Windows 10 Home
05:34:02:WU00:FS01:0x22:    OS Arch: AMD64
05:34:02:WU00:FS01:0x22:********************************************************************************
05:34:02:WU00:FS01:0x22:Project: 11741 (Run 0, Clone 2910, Gen 65)
05:34:02:WU00:FS01:0x22:Unit: 0x0000005f8ca304f15e693b22dbbf65c8
05:34:02:WU00:FS01:0x22:Reading tar file core.xml
05:34:02:WU00:FS01:0x22:Reading tar file integrator.xml
05:34:02:WU00:FS01:0x22:Reading tar file state.xml
05:34:06:WU00:FS01:0x22:Reading tar file system.xml
05:34:07:WU00:FS01:0x22:Digital signatures verified
05:34:07:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:34:07:WU00:FS01:0x22:Version 0.0.2
05:34:28:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
05:34:28:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:35:23:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
05:38:34:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
05:41:43:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
05:44:40:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
05:47:35:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
05:48:17:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
05:50:30:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
05:53:26:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
05:56:34:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
05:59:31:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
06:02:32:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
06:05:34:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
06:08:36:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
06:11:35:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
06:14:37:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
06:17:37:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
06:20:36:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
06:23:34:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
06:26:33:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
06:29:34:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
06:32:33:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
06:35:33:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
06:38:32:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
06:39:02:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
06:41:30:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
06:44:30:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
06:47:30:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
06:50:27:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
06:53:28:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
06:56:25:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
06:59:25:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
07:02:27:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
07:05:26:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
07:08:26:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
07:11:24:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
07:14:32:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
07:17:33:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
07:20:32:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
07:23:30:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
07:26:29:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
07:29:30:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
07:29:45:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
07:32:30:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
07:35:29:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
07:38:34:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
07:41:30:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
07:44:35:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
07:47:35:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
07:50:33:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
07:53:33:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
07:56:32:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
07:59:35:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
08:02:40:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
08:05:38:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
08:08:42:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
08:11:42:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
08:14:46:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
08:17:47:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
08:20:28:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
08:20:51:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
08:23:55:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
08:26:55:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
08:30:00:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
08:33:03:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
08:36:07:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
08:39:11:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
08:42:13:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
08:45:15:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
08:48:18:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
08:51:22:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
08:54:30:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
08:57:31:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
09:00:32:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
09:03:39:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
09:06:40:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
09:09:43:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
09:11:13:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
First 100-200 lines of the log? How many cores does you CPU have, and how many are being used for CPU folding?
Within FAHControl you may need to use Refresh to reload the log from beginning.
Please reduce the logging verbosity back to the default of 3.
Dave?
Post by Dave? »
The CPUs shouldn't be a concern. The problem is the GPU. The CPU on this and my other machine are fine on their work units.
This is over 200 lines to include the GPU getting to 4%. GPU is FS01.
There are 4 cpu cores running folding and the first 200 lines of the log don't cover this WU at all, so I copied the 200 lines from the start of 5/3/2020.
I've reset the verbosity to 3 and cleared the log to refresh it. I think this section still has verbosity 4, though
05:32:06:WU01:FS00:0xa7:*********************** Log Started 2020-05-03T05:32:06Z ***********************
05:32:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:32:06:WU01:FS00:0xa7:       Type: 0xa7
05:32:06:WU01:FS00:0xa7:       Core: Gromacs
05:32:06:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 27292 -checkpoint 15 -np
05:32:06:WU01:FS00:0xa7:             3
05:32:06:WU01:FS00:0xa7:************************************ CBang *************************************
05:32:06:WU01:FS00:0xa7:       Date: Oct 26 2019
05:32:06:WU01:FS00:0xa7:       Time: 01:38:25
05:32:06:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
05:32:06:WU01:FS00:0xa7:     Branch: master
05:32:06:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
05:32:06:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:32:06:WU01:FS00:0xa7:   Platform: win32 10
05:32:06:WU01:FS00:0xa7:       Bits: 64
05:32:06:WU01:FS00:0xa7:       Mode: Release
05:32:06:WU01:FS00:0xa7:************************************ System ************************************
05:32:06:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
05:32:06:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
05:32:06:WU01:FS00:0xa7:       CPUs: 4
05:32:06:WU01:FS00:0xa7:     Memory: 11.87GiB
05:32:06:WU01:FS00:0xa7:Free Memory: 6.68GiB
05:32:06:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
05:32:06:WU01:FS00:0xa7: OS Version: 6.2
05:32:06:WU01:FS00:0xa7:Has Battery: true
05:32:06:WU01:FS00:0xa7: On Battery: false
05:32:06:WU01:FS00:0xa7: UTC Offset: -4
05:32:06:WU01:FS00:0xa7:        PID: 39448
05:32:06:WU01:FS00:0xa7:        CWD: C:\Users\Work\AppData\Roaming\FAHClient\work
05:32:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
05:32:06:WU01:FS00:0xa7:    Version: 0.0.18
05:32:06:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:32:06:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:32:06:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
05:32:06:WU01:FS00:0xa7:       Time: 01:52:30
05:32:06:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
05:32:06:WU01:FS00:0xa7:************************************ Build *************************************
05:32:06:WU01:FS00:0xa7:       SIMD: avx_256
05:32:06:WU01:FS00:0xa7:********************************************************************************
05:32:06:WU01:FS00:0xa7:Project: 14379 (Run 3408, Clone 3, Gen 57)
05:32:06:WU01:FS00:0xa7:Unit: 0x0000003f455e42075e932e0075efbc20
05:32:06:WU01:FS00:0xa7:Digital signatures verified
05:32:06:WU01:FS00:0xa7:Calling: mdrun -s frame57.tpr -o frame57.trr -cpi state.cpt -cpt 15 -nt 3
05:32:06:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:32:06:WU00:FS01:Connecting to 18.218.241.186:80
05:32:06:WU01:FS00:0xa7:Steps: first=0 total=250000
05:32:54:<config>
05:32:54:
05:32:54:
05:32:54:
05:32:54:
05:32:54:</config>
Welcome to the F@H Forum Dave?
From your log file, I can see that your GPU is a GTX 1060 Mobile (https://www.techpowerup.com/gpu-specs/g ... bile.c2868) which isn't a really an old GPU. What temperatures are your CPU and GPU running at? Reason is that the GPU might be throttling itself resulting in lower clock speeds thus taking a long time to finish WUs.
Dave?
Post by Dave? »
The highest the GPU has ever gotten during folding was 90°C, but it was running at 83°C during this and the last slow WU. The 90°C was weeks ago and a fluke during a warm day. It still finished WUs in hours, not days. Its usual temp is between 80°C and 85°C.
The CPU maxes out at 87°C, currently folding at max speed at 76°C. Does the CPU data matter for the GPU folding?
HaloJones
Post by HaloJones »
There are a number of different specs of the GP106M. Can you provide details of the laptop - make and model ? Chances are it's a) a low power chip and b) it's probably thermally throttling to stay at 83C which is NVidia's preferred max temp.
If you download something like GPU-Z, its sensors tab will show a "Perfcap Reason". If you could have a look while the gpu is folding and say what the Perfcap Reason says?
single 1070
Dave?
Post by Dave? »
https://www.dell.com/support/home/us/en ... 0/overview
is the machine.
Perfcap is jumping between idle and thermal. Why wasn't this a problem on the last 50 WUs at the same temperatures?
Try running the GPU slot with the CPU WU paused. You may be running into combined thermal limit of the laptop cooling system. Or the air passages may need blowing out or the heat transfer pad or paste has dried out.
HaloJones
Post by HaloJones »
Different units have different numbers of atoms. 11741 has a lot - 165550 - and that will push smaller cards pretty hard. Big cards (e.g. a 1080ti with three times the cores of your 1060) love big molecules but smaller cards can struggle.
I suggest you download MSI Afterburner and use it to downclock your card. Alternatively do what Dell advise for this very laptop:
https://www.dell.com/support/article/en ... psolutions
single 1070
