Hi,
I thought about renting a vServer and run FAH on it.
- is it recommended or does it make any sense, to run FAH on a vServer (e.g. on Digitalocean)?
- is there a tutorial, how to setup fah when FAH-Client and FAH-Control are not on the same device (controlling the client from a remote location) or is there a command line interface for starting it directly on the server?
Best Regards
mschop
Running FAH on vServer
Re: Running FAH on vServer
Welcome to the F@H Forum mschop,
Here's a tutorial for vast.ai if you're interested: viewtopic.php?p=324550#p324550
You can fold on VMs but there will be a performance impact cause by the overhead of the VM.
