AMD Radeon (TM) R9 390 Series
My AMD Radeon (TM) R9 390 Series GPU is not in the GPUs.txt listing.
Why? you seem to favor NVidia card by the lack of approved AMD cards
Re: AMD Radeon (TM) R9 390 Series
The list is by device ID numbers, and the card you have is more than likely already in the GPUs.txt file. AMD reused GPU chips and device ID numbers throughout the range of cards the sold, especially on the low to mid-range cards. If you look up your GPU device ID most likely you will find it listed as a R9 290 or similar.
The most likely listing:
0x1002:0x67b1:1:5:Hawaii [Radeon R9 200/300 Series]-
Finished going through the posts waiting moderation, your second post has been deleted. But the supplied log showed that the card was recognized as expected, you ran into the same bug with the 7.6.9 version of the client software as other AMD and nVidia card owners, it did not create a GPU slot. However it did show a GPUs.txt file had been loaded and your card was recognized.
Please see this post for how to fix - viewtopic.php?f=61&t=34950&p=331168#p331168
Hi Joe_H,
Thank you for info.
Unfortunately this did not fix the problem.
I was only able to add another CPU slot. I have two CPU slots from before to be able to utilize the processor to the fullest.
Maybe its possible to download and use a previous version?
Thank you for info.
Did you check off the GPU button on the left side of the window when creating the slot for the GPU? Depending on the theme setting, that can be of low contrast.
Welcome to the F@H Forum JTorset,
Can you please post the first few hundred lines from your log file? Guidance is available here: viewtopic.php?f=24&t=26036
Yes, this solved the problem. I did not see this previously. My bad.Joe_H wrote:Did you check off the GPU button on the left side of the window when creating the slot for the GPU? Depending on the theme setting, that can be of low contrast.
Thank you. Working now, at least I could make the slot. Now waiting for a job.
Thank you for your post. Problem solved.PantherX wrote:Welcome to the F@H Forum JTorset,
My bad I did not catch the and mark off the GPU radio button for creating the GPU slot.
Please note that currently the demand for GPU WUs has exceeded the supply for GPU WUs so it might take a while for your GPU to be assigned a WU. If in doubt, please post your log fileJTorset wrote:...Working now, at least I could make the slot. Now waiting for a job.
