whitelist NVIDIA GeForce RTX 2070 SUPER 0x10de:0x1e84:1:0:0
Piranja
Post by Piranja »
Card Name:	NVIDIA GeForce RTX 2070 SUPER
Owner:	Anonymous	Submitted:	May 1st, 2020 02:11
GPU:	TU104	Revision:	A1
Technology:	12 nm	Die Size:	545 mm²
BIOS Version:	90.04.76.00.F2	Device ID:	10DE - 1E84
Bus Interface:	PCIe x16 3.0 @ x16 3.0	Subvendor:	ASUS (1043 - 870A)
ROPs / TMUs:	64 / 160	Shaders:	2560 (DX 12 (12_1))
Pixel Fillrate:	113.3 GPixel/s	Texture Fillrate:	283.2 GTexel/s
Memory Type:	GDDR6	Bus Width:	256 bit
Memory Size:	8192 MB	Bandwidth:	448.0 GB/s
Driver:	26.21.14.4587 (NVIDIA 445.87) DCH / Win10 64
GPU Clock:	1605 MHz	GPU Default:	1605 MHz
GPU Boost:	1770 MHz	GPU Boost Default:	1770 MHz
Memory Clock:	1750 MHz	Memory Default:	1750 MHz
GPU Overclock:	0%	Mem Overclock:	0%
C:\Program Files (x86)\FAHClient>fahclient --lspci
0x8086:0xa36d:0:20:0:Intel Corporation:USB-xHCI-kompatibler Hostcontroller
0x8086:0x15bc:0:31:6:Intel Corporation:Intel(R) Ethernet Connection (7) I219-V
0x10de:0x10f8:1:0:1:NVIDIA Corporation:High Definition Audio-Controller
0x8086:0xa352:0:23:0:Intel Corporation:Intel(R) 300 Series Chipset Family SATA AHCI Controller
0x8086:0xa36f:0:20:2:Intel Corporation:PCI Standard-RAM-Controller
0x8086:0xa324:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - A324
0x8086:0xa32c:0:27:0:Intel Corporation:Intel(R) PCI Express Root Port #21 - A32C
0x8086:0x3e30:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 3E30
0x8086:0xa360:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x10de:0x1ad9:1:0:3:NVIDIA Corporation:NVIDIA USB Type-C Port Policy Controller
0x8086:0xa323:0:31:4:Intel Corporation:Intel(R) SMBus - A323
0x8086:0xa33c:0:28:0:Intel Corporation:Intel(R) PCI Express Root Port #5 - A33C
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) PCIe Controller (x16) - 1901
0x8086:0xa330:0:29:0:Intel Corporation:Intel(R) PCI Express Root Port #9 - A330
0x10de:0x1ad8:1:0:2:NVIDIA Corporation:USB-xHCI-kompatibler Hostcontroller
0x8086:0xa348:0:31:3:Intel Corporation:High Definition Audio-Controller
0x10de:0x1e84:1:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 2070 SUPER
0x8086:0xa308:0:31:0:Intel Corporation:Intel(R) 300 Series Chipset Family LPC Controller (B360) - A308
*********************** Log Started 2020-04-30T23:58:15Z ***********************
23:58:15:****************************** FAHClient ******************************
23:58:15:        Version: 7.6.9
23:58:15:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:58:15:      Copyright: 2020 foldingathome.org
23:58:15:       Homepage: https://foldingathome.org/
23:58:15:           Date: Apr 17 2020
23:58:15:           Time: 11:13:06
23:58:15:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:58:15:         Branch: master
23:58:15:       Compiler: Visual C++ 2008
23:58:15:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:58:15:       Platform: win32 10
23:58:15:           Bits: 32
23:58:15:           Mode: Release
23:58:15:           Args: --open-web-control
23:58:15:         Config: C:\Users\info\AppData\Roaming\FAHClient\config.xml
23:58:15:******************************** CBang ********************************
23:58:15:           Time: 11:10:09
23:58:15:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:58:15:           Bits: 32
23:58:15:******************************* System ********************************
23:58:15:            CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
23:58:15:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:58:15:           CPUs: 8
23:58:15:         Memory: 15.92GiB
23:58:15:    Free Memory: 2.88GiB
23:58:15:        Threads: WINDOWS_THREADS
23:58:15:     OS Version: 6.2
23:58:15:    Has Battery: false
23:58:15:     On Battery: false
23:58:15:     UTC Offset: 2
23:58:15:            PID: 22592
23:58:15:            CWD: C:\Users\info\AppData\Roaming\FAHClient
23:58:15:             OS: Windows 10 Home
23:58:15:        OS Arch: AMD64
23:58:15:           GPUs: 1
23:58:15:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 Super]
23:58:15:                 8218
23:58:15:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
23:58:15:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
23:58:15:  Win32 Service: false
23:58:15:******************************* libFAH ********************************
23:58:15:           Date: Apr 15 2020
23:58:15:           Time: 14:53:14
23:58:15:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:58:15:           Bits: 32
23:58:15:***********************************************************************
23:58:15:<config>
23:58:15:  <!-- User Information -->
23:58:15:  <passkey v='*****'/>
23:58:15:  <team v='251999'/>
23:58:15:  <user v='Piranja'/>
23:58:15:
23:58:15:  <!-- Folding Slots -->
23:58:15:  <slot id='0' type='CPU'/>
23:58:15:</config>
23:58:15:Trying to access database...
23:58:15:Successfully acquired database lock
23:58:15:Enabled folding slot 00: READY cpu:7
23:58:15:WU00:FS00:Starting
23:58:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\info\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 22592 -checkpoint 15 -np 7
23:58:15:WU00:FS00:Started FahCore on PID 148
23:58:15:WU00:FS00:Core PID:23944
23:58:15:WU00:FS00:FahCore 0xa7 started
23:58:15:WU00:FS00:0xa7:*********************** Log Started 2020-04-30T23:58:15Z ***********************
23:58:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:58:15:WU00:FS00:0xa7:       Type: 0xa7
23:58:15:WU00:FS00:0xa7:       Core: Gromacs
23:58:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 148 -checkpoint 15 -np 7
23:58:15:WU00:FS00:0xa7:************************************ CBang *************************************
23:58:15:WU00:FS00:0xa7:       Date: Oct 26 2019
23:58:15:WU00:FS00:0xa7:       Time: 01:38:25
23:58:15:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:58:15:WU00:FS00:0xa7:     Branch: master
23:58:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:58:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:58:15:WU00:FS00:0xa7:   Platform: win32 10
23:58:15:WU00:FS00:0xa7:       Bits: 64
23:58:15:WU00:FS00:0xa7:       Mode: Release
23:58:15:WU00:FS00:0xa7:************************************ System ************************************
23:58:15:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz
23:58:15:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
23:58:15:WU00:FS00:0xa7:       CPUs: 8
23:58:15:WU00:FS00:0xa7:     Memory: 15.92GiB
23:58:15:WU00:FS00:0xa7:Free Memory: 2.85GiB
23:58:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:58:15:WU00:FS00:0xa7: OS Version: 6.2
23:58:15:WU00:FS00:0xa7:Has Battery: false
23:58:15:WU00:FS00:0xa7: On Battery: false
23:58:15:WU00:FS00:0xa7: UTC Offset: 2
23:58:15:WU00:FS00:0xa7:        PID: 23944
23:58:15:WU00:FS00:0xa7:        CWD: C:\Users\info\AppData\Roaming\FAHClient\work
23:58:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:58:15:WU00:FS00:0xa7:    Version: 0.0.18
23:58:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:58:15:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:58:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:58:15:WU00:FS00:0xa7:       Time: 01:52:30
23:58:15:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:58:15:WU00:FS00:0xa7:************************************ Build *************************************
23:58:15:WU00:FS00:0xa7:       SIMD: avx_256
23:58:15:WU00:FS00:0xa7:********************************************************************************
23:58:15:WU00:FS00:0xa7:Project: 14628 (Run 847, Clone 3, Gen 73)
23:58:15:WU00:FS00:0xa7:Unit: 0x0000004d9bf7a4d65e88b47d71c6c509
23:58:15:WU00:FS00:0xa7:Digital signatures verified
23:58:15:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
23:58:15:WU00:FS00:0xa7:Calling: mdrun -s frame73.tpr -o frame73.trr -cpi state.cpt -cpt 15 -nt 6
23:58:15:WU00:FS00:0xa7:Steps: first=0 total=250000
23:58:16:WU00:FS00:0xa7:Completed 52015 out of 250000 steps (20%)
23:58:17:16:127.0.0.1:New Web session
23:58:18:17:127.0.0.1:New Web session
23:58:24:35:127.0.0.1:New Web session
23:58:27:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
23:59:19:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
00:00:12:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
00:01:06:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
00:01:58:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
00:02:51:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
00:03:43:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
00:04:36:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
00:05:28:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
00:06:19:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
00:07:12:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
00:08:07:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
00:09:01:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
00:09:54:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
00:10:45:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
00:11:38:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
00:12:30:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
00:13:24:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
00:14:20:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
00:15:13:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
00:16:05:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
00:16:58:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
00:17:50:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
00:18:43:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
00:19:36:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
00:20:28:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
00:21:21:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
00:22:14:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
00:23:07:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
00:24:00:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
00:24:53:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
00:25:46:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
00:26:38:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
00:27:31:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
00:28:23:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
00:29:17:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
00:30:10:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
00:31:03:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
00:31:56:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
00:32:49:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
00:33:43:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
00:34:36:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
00:35:29:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
00:36:22:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
00:37:16:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
00:38:09:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
00:39:02:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
00:39:56:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
00:40:49:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
00:41:44:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
00:42:39:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
00:43:34:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
00:44:28:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
00:45:22:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
00:46:16:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
00:47:10:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
00:48:04:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
00:48:58:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
00:49:51:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
00:50:44:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
00:51:37:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
00:52:30:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
Re: whitelist NVIDIA GeForce RTX 2070 SUPER 0x10de:0x1e84:1:
This GPU is late on the whitelist:
0x10de:0x1e84:2:8:TU104 [GeForce RTX 2070 Super] 8218
There is a bug in version 7.6.9 on adding GPU folding, please see this post for how to fix"
viewtopic.php?f=61&t=34950&p=331168#p331168
MARSTG
Hardware configuration: B450 AORUS M w 3800X & WRAITH PRISM
16 GB DELTA RGB 3600 & WD SN 770 500GB
GTX 1070 GAMING X w LG OLED C1 55"
ECLIPSE P300A TG
Re: whitelist NVIDIA GeForce RTX 2070 SUPER 0x10de:0x1e84:1:0:0
Post by MARSTG »
2070 S is doing 3 mil PPD plus on Windows these days, for those wondering, with driver 512.xx
