Unable to get Folding@home to work
Homecomp
Hardware configuration: Self build. Corsair Cabinet with H80i GT water cooler. - Intel i5-4690K CPU @ 3.50GHz (4 cores)
RAM - 16.00GB
64 bit Operating system
Windows 10 Pro
Nvidia GeForce 9600 GT
intel HD Graphics 4600
Samsung SSD 500GB
Post by Homecomp »
Hi,
having resolved problems with 7.5.1 I am now running 7.6.9 and have been so since the end of march.
I now have 3 machines running, the 2nd and 3rd are ticking along quite nicely.
My main machine finished its WU and uploaded it, Just prior to finishing I saw it had requested an new Wu, then it downloaded it
The if finished the last Wu and uploaded it then it came back upload complete and ever since then nothing, I have tried installing FAH again, but it refused to connect, meanwhile the other 2 machine finish their Wu's and get new ones no problems at all.
I will attach the log.txt
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Re: Unable to get Folding@home to work
Post by Homecomp »
*********************** Log Started 2020-04-27T12:34:59Z ***********************
12:34:59:****************************** FAHClient ******************************
12:34:59:        Version: 7.6.9
12:34:59:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:34:59:      Copyright: 2020 foldingathome.org
12:34:59:       Homepage: https://foldingathome.org/
12:34:59:           Date: Apr 17 2020
12:34:59:           Time: 11:13:06
12:34:59:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:34:59:         Branch: master
12:34:59:       Compiler: Visual C++ 2008
12:34:59:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:34:59:       Platform: win32 10
12:34:59:           Bits: 32
12:34:59:           Mode: Release
12:34:59:           Args: --open-web-control
12:34:59:         Config: C:\Users\Steve\AppData\Roaming\FAHClient\config.xml
12:34:59:******************************** CBang ********************************
12:34:59:           Time: 11:10:09
12:34:59:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:34:59:           Bits: 32
12:34:59:******************************* System ********************************
12:34:59:            CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
12:34:59:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:34:59:           CPUs: 4
12:34:59:         Memory: 7.84GiB
12:34:59:    Free Memory: 1.51GiB
12:34:59:        Threads: WINDOWS_THREADS
12:34:59:     OS Version: 6.2
12:34:59:    Has Battery: false
12:34:59:     On Battery: false
12:34:59:     UTC Offset: 1
12:34:59:            PID: 13148
12:34:59:            CWD: C:\Users\Steve\AppData\Roaming\FAHClient
12:34:59:             OS: Windows 10 Enterprise
12:34:59:        OS Arch: AMD64
12:34:59:           GPUs: 0
12:34:59:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:6.5
12:34:59:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
12:34:59:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.0 Driver:342.1
12:34:59:  Win32 Service: false
12:34:59:******************************* libFAH ********************************
12:34:59:           Date: Apr 15 2020
12:34:59:           Time: 14:53:14
12:34:59:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:34:59:           Bits: 32
12:34:59:***********************************************************************
12:34:59:<config>
12:34:59:  <!-- Folding Core -->
12:34:59:  <checkpoint v='10'/>
12:34:59:
12:34:59:  <!-- Network -->
12:34:59:  <proxy v=':8080'/>
12:34:59:
12:34:59:  <!-- Slot Control -->
12:34:59:  <pause-on-battery v='false'/>
12:34:59:  <power v='full'/>
12:34:59:
12:34:59:  <!-- User Information -->
12:34:59:  <passkey v='*****'/>
12:34:59:  <team v='1'/>
12:34:59:  <user v='Steve_Bishop'/>
12:34:59:
12:34:59:  <!-- Folding Slots -->
12:34:59:  <slot id='0' type='CPU'/>
12:34:59:</config>
12:34:59:Trying to access database...
12:34:59:Successfully acquired database lock
12:34:59:FS00:Set client configured
12:34:59:Enabled folding slot 00: READY cpu:4
12:35:00:WU00:FS00:Connecting to 65.254.110.245:80
12:35:03:20:127.0.0.1:New Web session
12:35:03:WARNING:Command server access denied
12:35:03:30:127.0.0.1:New Web session
12:35:08:WARNING:Command server access denied
12:35:13:WARNING:Command server access denied
12:35:18:WARNING:Command server access denied
12:35:50:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10001: Server responded: HTTP_NOT_FOUND
12:35:50:WU00:FS00:Connecting to 18.218.241.186:80
12:36:13:56:127.0.0.1:New Web session
12:36:41:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10001: Server responded: HTTP_NOT_FOUND
12:36:41:WU00:FS00:Connecting to 65.254.110.245:80
12:37:31:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10001: Server responded: HTTP_NOT_FOUND
12:37:31:WU00:FS00:Connecting to 18.218.241.186:80
12:37:49:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
12:37:50:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:37:50:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:37:50:WU00:FS00:Connecting to 65.254.110.245:80
12:37:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:37:51:WU00:FS00:Connecting to 18.218.241.186:80
12:37:51:WU00:FS00:Assigned to work server 155.247.164.214
12:37:51:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 155.247.164.214
12:37:51:WU00:FS00:Connecting to 155.247.164.214:8080
12:37:52:WU00:FS00:Downloading 2.80MiB
12:37:53:WU00:FS00:Download complete
12:37:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14366 run:162 clone:2 gen:60 core:0xa7 unit:0x000000439bf7a4d65e84ae37baeecc2a
12:37:53:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
12:37:53:WU00:FS00:Connecting to cores.foldingathome.org:80
12:37:54:WU00:FS00:FahCore a7: Downloading 6.71MiB
12:37:55:WU00:FS00:FahCore a7: Download complete
12:37:55:WU00:FS00:Valid core signature
12:37:55:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
12:37:55:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
12:37:55:WU00:FS00:Starting
12:37:55:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13148 -checkpoint 10 -np 4
12:37:56:WU00:FS00:Started FahCore on PID 18428
12:37:56:WU00:FS00:Core PID:3372
12:37:56:WU00:FS00:FahCore 0xa7 started
12:37:57:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T12:37:56Z ***********************
12:37:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:37:57:WU00:FS00:0xa7:       Type: 0xa7
12:37:57:WU00:FS00:0xa7:       Core: Gromacs
12:37:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 18428 -checkpoint 10 -np
12:37:57:WU00:FS00:0xa7:             4
12:37:57:WU00:FS00:0xa7:************************************ CBang *************************************
12:37:57:WU00:FS00:0xa7:       Date: Oct 26 2019
12:37:57:WU00:FS00:0xa7:       Time: 01:38:25
12:37:57:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:37:57:WU00:FS00:0xa7:     Branch: master
12:37:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:37:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:37:57:WU00:FS00:0xa7:   Platform: win32 10
12:37:57:WU00:FS00:0xa7:       Bits: 64
12:37:57:WU00:FS00:0xa7:       Mode: Release
12:37:57:WU00:FS00:0xa7:************************************ System ************************************
12:37:57:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
12:37:57:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:37:57:WU00:FS00:0xa7:       CPUs: 4
12:37:57:WU00:FS00:0xa7:     Memory: 7.84GiB
12:37:57:WU00:FS00:0xa7:Free Memory: 1.73GiB
12:37:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:37:57:WU00:FS00:0xa7: OS Version: 6.2
12:37:57:WU00:FS00:0xa7:Has Battery: false
12:37:57:WU00:FS00:0xa7: On Battery: false
12:37:57:WU00:FS00:0xa7: UTC Offset: 1
12:37:57:WU00:FS00:0xa7:        PID: 3372
12:37:57:WU00:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
12:37:57:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:37:57:WU00:FS00:0xa7:    Version: 0.0.18
12:37:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:37:57:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:37:57:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:37:57:WU00:FS00:0xa7:       Time: 01:52:30
12:37:57:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:37:57:WU00:FS00:0xa7:************************************ Build *************************************
12:37:57:WU00:FS00:0xa7:       SIMD: avx_256
12:37:57:WU00:FS00:0xa7:********************************************************************************
12:37:57:WU00:FS00:0xa7:Project: 14366 (Run 162, Clone 2, Gen 60)
12:37:57:WU00:FS00:0xa7:Unit: 0x000000439bf7a4d65e84ae37baeecc2a
12:37:57:WU00:FS00:0xa7:Reading tar file core.xml
12:37:57:WU00:FS00:0xa7:Reading tar file frame60.tpr
12:37:57:WU00:FS00:0xa7:Digital signatures verified
12:37:57:WU00:FS00:0xa7:Calling: mdrun -s frame60.tpr -o frame60.trr -cpt 10 -nt 4
12:37:57:WU00:FS00:0xa7:Steps: first=0 total=250000
12:37:58:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
12:39:59:Connecting to assign1.foldingathome.org:80
12:39:59:Updated GPUs.txt
12:40:00:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
12:42:00:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
12:43:58:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
12:45:53:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
12:47:52:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
12:49:47:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
12:51:41:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
12:53:36:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
12:55:30:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
12:57:24:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
12:59:18:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
13:01:14:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
13:03:09:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
13:05:02:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
13:06:55:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
13:08:50:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
13:10:51:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
13:12:54:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
13:14:50:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
13:16:43:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
13:18:40:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
13:20:38:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
13:22:37:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
13:24:33:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
13:26:29:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
13:28:24:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
13:30:19:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
13:32:12:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
13:34:05:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
13:35:58:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
13:37:51:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
13:39:48:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
13:41:50:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
13:43:44:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
13:45:42:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
13:47:40:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
13:49:35:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
13:51:31:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
13:53:28:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
13:55:33:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
13:57:41:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
13:59:40:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
14:01:37:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
14:03:32:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
14:05:29:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
14:07:24:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
14:09:27:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
14:11:31:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
14:13:33:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
14:15:28:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
14:17:22:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:19:16:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:21:10:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:23:04:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:25:01:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:27:00:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:28:55:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:30:49:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:32:40:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:34:30:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:36:20:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:38:14:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:40:05:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:42:02:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:43:52:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:45:44:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:47:50:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:49:51:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:51:55:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:53:48:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:55:37:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
14:57:25:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
14:59:13:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
15:01:03:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:02:51:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:04:39:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:06:31:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:08:25:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:10:16:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:12:11:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:14:10:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:16:15:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:18:18:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:20:25:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:22:19:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
15:24:08:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
15:25:58:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
15:27:48:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:29:38:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:31:28:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:33:18:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
15:35:09:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
15:36:59:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
15:38:50:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
15:40:42:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
15:42:30:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
15:44:19:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
15:46:09:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
15:47:57:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
15:47:57:WU01:FS00:Connecting to 65.254.110.245:80
15:47:57:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:47:58:WU01:FS00:Connecting to 18.218.241.186:80
15:47:58:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:47:58:WU01:FS00:Connecting to 65.254.110.245:80
15:47:59:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:47:59:WU01:FS00:Connecting to 18.218.241.186:80
15:47:59:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:47:59:ERROR:WU01:FS00:Exception: Could not get an assignment
15:47:59:WU01:FS00:Connecting to 65.254.110.245:80
15:48:00:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:48:00:WU01:FS00:Connecting to 18.218.241.186:80
15:48:00:WU01:FS00:Assigned to work server 155.247.164.213
15:48:00:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.164.213
15:48:00:WU01:FS00:Connecting to 155.247.164.213:8080
15:48:01:WU01:FS00:Downloading 2.82MiB
15:48:02:WU01:FS00:Download complete
15:48:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14823 run:2260 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55ea30c46530edb28
15:49:47:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
15:49:49:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
15:49:49:WU00:FS00:0xa7:Saving result file dhdl.xvg
15:49:49:WU00:FS00:0xa7:Saving result file frame60.trr
15:49:49:WU00:FS00:0xa7:Saving result file md.log
15:49:49:WU00:FS00:0xa7:Saving result file pullf.xvg
15:49:49:WU00:FS00:0xa7:Saving result file pullx.xvg
15:49:49:WU00:FS00:0xa7:Saving result file science.log
15:49:49:WU00:FS00:0xa7:Saving result file traj_comp.xtc
15:49:49:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:49:50:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:49:50:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14366 run:162 clone:2 gen:60 core:0xa7 unit:0x000000439bf7a4d65e84ae37baeecc2a
15:49:50:WU00:FS00:Uploading 6.42MiB to 155.247.164.214
15:49:50:WU00:FS00:Connecting to 155.247.164.214:8080
15:49:50:WU01:FS00:Starting
15:49:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 13148 -checkpoint 10 -np 4
15:49:50:WU01:FS00:Started FahCore on PID 18304
15:49:50:WU01:FS00:Core PID:10020
15:49:50:WU01:FS00:FahCore 0xa7 started
15:49:51:WU01:FS00:0xa7:*********************** Log Started 2020-04-27T15:49:51Z ***********************
15:49:51:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:49:51:WU01:FS00:0xa7:       Type: 0xa7
15:49:51:WU01:FS00:0xa7:       Core: Gromacs
15:49:51:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 18304 -checkpoint 10 -np
15:49:51:WU01:FS00:0xa7:             4
15:49:51:WU01:FS00:0xa7:************************************ CBang *************************************
15:49:51:WU01:FS00:0xa7:       Date: Oct 26 2019
15:49:51:WU01:FS00:0xa7:       Time: 01:38:25
15:49:51:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:49:51:WU01:FS00:0xa7:     Branch: master
15:49:51:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:49:51:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:49:51:WU01:FS00:0xa7:   Platform: win32 10
15:49:51:WU01:FS00:0xa7:       Bits: 64
15:49:51:WU01:FS00:0xa7:       Mode: Release
15:49:51:WU01:FS00:0xa7:************************************ System ************************************
15:49:51:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
15:49:51:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:49:51:WU01:FS00:0xa7:       CPUs: 4
15:49:51:WU01:FS00:0xa7:     Memory: 7.84GiB
15:49:51:WU01:FS00:0xa7:Free Memory: 1.78GiB
15:49:51:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
15:49:51:WU01:FS00:0xa7: OS Version: 6.2
15:49:51:WU01:FS00:0xa7:Has Battery: false
15:49:51:WU01:FS00:0xa7: On Battery: false
15:49:51:WU01:FS00:0xa7: UTC Offset: 1
15:49:51:WU01:FS00:0xa7:        PID: 10020
15:49:51:WU01:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
15:49:51:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:49:51:WU01:FS00:0xa7:    Version: 0.0.18
15:49:51:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:49:51:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:49:51:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:49:51:WU01:FS00:0xa7:       Time: 01:52:30
15:49:51:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:49:51:WU01:FS00:0xa7:************************************ Build *************************************
15:49:51:WU01:FS00:0xa7:       SIMD: avx_256
15:49:51:WU01:FS00:0xa7:********************************************************************************
15:49:51:WU01:FS00:0xa7:Project: 14823 (Run 2260, Clone 0, Gen 6)
15:49:51:WU01:FS00:0xa7:Unit: 0x000000069bf7a4d55ea30c46530edb28
15:49:51:WU01:FS00:0xa7:Reading tar file core.xml
15:49:51:WU01:FS00:0xa7:Reading tar file frame6.tpr
15:49:51:WU01:FS00:0xa7:Digital signatures verified
15:49:51:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 10 -nt 4
15:49:51:WU01:FS00:0xa7:Steps: first=0 total=250000
15:49:52:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
15:49:56:WU00:FS00:Upload 31.14%
15:50:02:WU00:FS00:Upload 83.70%
15:50:04:WU00:FS00:Upload complete
15:50:04:WU00:FS00:Server responded WORK_ACK (400)
15:50:04:WU00:FS00:Final credit estimate, 3830.00 points
15:50:04:WU00:FS00:Cleaning up
Reason: Added Code tags
HaloJones
Post by HaloJones »
Stop FAH. Open explorer and go to C:\Users\Steve\AppData\Roaming\FAHClient\work
delete the subdirectory probably called 00
then restart the computer. let us know.
by the way, if next time you put all that text inside a [ code ] [ / code ] without the spaces, it will not take up quite so much screen space and will scroll within a little window.
Note from Mod: Edited second post per your suggestion.
Deleted extra posts as redundant (they showed progress on CPU folding.)
single 1070
I notice this
342.1 is a really old Nvidia driver, do you have a really old Nvidia GPU?
Some critical information is shown in the first page of the log.
Apparently you're "protected" by a firewall that's preventing you from getting the appropriate information from FAH's servers. You'll need to configure your firewall or AV program to permit FAHClient to connect to the internet just like your browsers.
Presumably your browser can open
65.254.110.245 and
18.218.241.186
FAHClient has to be able to do the same.
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi Bruce,
that simple..... but it was working ok up until then, so what do you thinks happened to change the firewall
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi HaloJones,
Thank you, i will see what happens.
Sorry about the text log. Thanks for the advice.
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi JimboPalmer,
sorry to say I do...... Didn't realise my graphics card had grown old.... its working fine for everything else except FAH. I will be getting a newer graphics card sometime this month. So until then I do not use my gpu just my cpu
paulmd199
Hardware configuration: Machine 1: Gigabyte Z160MX-Gaming 5, Core i5-6500, eVGA 600 W PSU, thermaltake water 3.0120 cooling, 16GB DDR4, GPU 0: GT1030, GPU 1: GTX1050 Ti, GPU 2: GTX1660
Machine 2: Core i3 laptop (dell inspiron 1464)
Retired/spare: GT 750
Unusable: Intel HD 530
Post by paulmd199 »
Can you tell us exactly what it is? It may yet qualify for the most recent driver, or, failing that, a more recent than the current one. Your current driver is a bit over 3 years old.
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi HaloJones,
Its working...Thank You
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi paulmd199,
I used Speccy and the results are attached
From Device manager Its driver I updated from the Navidia site just two days ago......its probably old as well
NVIDIA GeForce 9600 GT
	Manufacturer	NVIDIA
	Model	GeForce 9600 GT
	GPU	G94
	Device ID	10DE-0622
	Revision	A2
	Subvendor	Undefined (0000)
	Series	GeForce 9
	Current Performance Level	Level 0
	Technology	65 nm
	Die Size	240 mm²
	Transistors	505 M
	Release Date	Feb 21, 2008
	DirectX Support	10.0
	DirectX Shader Model	4.0
	OpenGL Support	3.0
	Bus Interface	PCI Express x16
	Temperature	34 °C
	Driver version	21.21.13.4201
	BIOS Version	62.94.11.00.00
	ROPs	16
	Shaders	64 unified
	Memory Type	GDDR3
	Memory	512 MB
	Bus Width	64x4 (256 bit)
	Anti Aliasing Modes	-?-
	Filtering Modes	Bilinear, Trilinear, 2x Anisotropic, 4x Anisotropic, 8x Anisotropic, 16x Anisotropic
	Noise Level	Moderate
	Max Power Draw	95 Watts
paulmd199
Post by paulmd199 »
You have the the latest supported driver for that card.
Homecomp
RAM - 16.00GB
Windows 10 Pro
Samsung SSD 500GB
Post by Homecomp »
Hi paulmd199,
wasn't sure i had , I only went by what their website offered me.
Looking around now for a better one.
paulmd199
Post by paulmd199 »
From what i can determine (and please correct me if I'm wrong), the card lacks the capability to double precision floating point math, which FaH now requires.
The GPU doesn't support OpenCL 1.2 and Double Precision: https://www.techpowerup.com/gpu-specs/g ... 00-gt.c206 so it can't fold :(
