Hi all,
So I've read here that up to 32 threads per WU is supported.
However I have a bit of an issue.
I have a system with 2 sockets. Each socket has a 22 core CPU. Now if I create two slots, each with 32 threads, they both start on CPU 1 and nothing is running on CPU 0. Any idea what is going on with that ?
If I manually change the CPU affinity in task manager, i can separate them by pause/restart but when a new WU starts it goes back to CPU 1.
Windows 8.1, current FAH Client. Intel CPU and chipset. No GPU.
Are there any advanced instructions for using FAHClient on multisocket systems ?
Issues with multisocket system
tulanebarandgrill
- TulaneBaG
Re: Issues with multisocket system
Please post your log including the top 200 or so lines which has the system config info in it) and we can try to help … for guidance on this see viewtopic.php?f=61&t=26036
Usually configuring multisocket systems is relatively simple and shouldn't cause you too much pain - as soon as we know your configuration we should get this sorted quickly.
Please note that standard Windows 8.1 will not support more than 1 physical CPU (https://superuser.com/questions/495105/ ... -8-support). Also, in Windows, behavior is very different with high CPU count (https://www.anandtech.com/show/15483/am ... x-review/3).
Is there a reason you need to you Windows? I would recommend that you switch to Ubuntu/Mint and you can setup CPU folding very easily since you're not folding on GPUs. Here's the breakdown:
2 CPUs with 22 Physical Cores each results in 88 threads with hyperthreading. For F@H, it would be:
CPU Slot 1: 32 CPUs
CPU Slot 2: 32 CPUs
CPU Slot 3: 24 CPUs
If heat becomes an issue, disable hyperthreading so you get a total of 44 CPUs which would result in :
CPU Slot 1: 32 CPUs
CPU Slot 2: 12 CPUs
CPU Slot 1: 32 CPUs
CPU Slot 2: 32 CPUs
CPU Slot 3: 24 CPUs
CPU Slot 1: 32 CPUs
CPU Slot 2: 12 CPUs
Which version of 8.1 .. pro or ent will do two cpu systems .. home unfortunately doesn't
FireFox-89
- Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ stock | Noctua NH-U9s with 2 Noctua B9 Redux 1600 92mm Fans
Gigabyte B550 Gaming X V2 Revision 1.3 BIOS version FFg
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+Bronze PSU
Terra - Active
Intel Core i5-4690K @ 4.20GHz with Vcore of 1.138v | Corsair H100i V2 with 2 Corsair SP120 120mm fans
Gigabyte Z87X-UD3H BIOS version 10b
Kingston HyperX Fury 4x4GB DDR3-1866 | Timings 9-10-9-28
Asus GeForce GTX 1070 Ti Strix OC 8GB
OCZ Technology ZS Series 550w 80+Bronze PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ 0.980 Vcore | Cooler Master Hyper 212 with Noctua NF-F12 120mm IPPC 3000 fan
Gigabyte X99-SOC Champion BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Need Sorting)
Sapphire Radeon RX 580 Nitro+ 4GB
Sapphire Radeon RX 570 Pulse 4GB
SeaSonic Prime Platinum 750w 80+Platinum PSU
All machines running F@H v8.4.9 - Location: Lincolnshire, UK
I would look into upgrading to Windows 10 Pro, as far as I'm aware although additional research may/will be required it supports 2 sockets and depends on where you look Windows 10 Pro key can be bought cheap from Amazon.
Do you even fold bro?
MARSTG
- Hardware configuration: B450 AORUS M w 3800X & WRAITH PRISM
16 GB DELTA RGB 3600 & WD SN 770 500GB
GTX 1070 GAMING X w LG OLED C1 55"
ECLIPSE P300A TG - Location: Montreal
Tulane, you solved it ?
Windows Pro does support it; or Linux.
I'm not sure if Windows 10 supports dual die CPUs, but if it does, it will probably be limited to an x-amount of cores (like 32 or so).
Linux is your best bet. It supports up to 4096 CPU cores.
Windows 10 Pro 64- bit has 2 physical CPU support up-to 256 threads: https://answers.microsoft.com/en-us/win ... 23f?auth=1MeeLee wrote:...I'm not sure if Windows 10 supports dual die CPUs, but if it does, it will probably be limited to an x-amount of cores (like 32 or so)...
Windows Server 2019 supports more than 255 threads: https://support.microsoft.com/en-nz/hel ... -rome-proc
I would say that Linux is the easiest with multi-CPU system while Windows can work if you have the right stuff.
