7.6.9 New version hangs on connecting
ArianMohlmann
The new version 7.6.9 hangs on connecting:
Re: 7.6.9 New version hangs on connecting
Welcome to the F@H Forum ArianMohlmann,
Can you please provide the log file, ensure you have the first 100 lines so we can see what's happening? Guidance is provided here if needed: viewtopic.php?f=24&t=26036
ArianMohlmann
The log file within FAH Controller is not accessable. It is disable the button.
What is the location of the file for Fedora distributions?
ArianMohlmann
Now it is hanging switched to Updating after it was connecting a whole day. Still the log panel and all other options are grayed out. Disabled.
You'll find instructions about the log at viewtopic.php?p=327412&f=24#p327413
Does your version of Fedora still support Python2? FAHControl needs it and I believe Fedora dropped it in F32. And even before that you might have to install it. Not sure, though.
ArianMohlmann
I have two Fedora systems. One does support the other does not.
Both suffer the same issue.
The system that has Python2 is modief as the Folding At Home did not point to Python2.
ArianMohlmann
At this moment still updating.
Where can I see this log file?
In /var/lib/fahclient
You should be able to control both systems from the one that can run FAHControl. In order to allow access, the non-Python2 PC must have the following code
in the <config> section of
and you then have to restart the client on that machine.
Then, in FAHControl on the Python2 PC, you add a client with the IP of the first PC. Like this:
<!-- HTTP Server -->
<allow v="127.0.0.1 192.168.0.0/24"/>
<!-- Network -->
<proxy v=":8080"/>
<!-- Remote Command Server -->
<command-allow-no-pass v="127.0.0.1 192.168.0.0/24"/>
/etc/fahclient/config.xmlThen, in FAHControl on the Python2 PC, you add a client with the IP of the first PC. Like this:
1. Open up Advanced Control (AKA FAHControl)
2. Click Add
3. Under Name, enter the Remote System's name or any other name
4. Under the Address, enter either the Hostname or IP address of the Remote System
5. Under the Password, enter the password used in the Remote System
6. Click Save
ArianMohlmann
The log:
16:28:19:WU01:FS00:Cleaning up
16:28:33:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
16:29:51:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
16:31:08:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
16:32:26:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
16:33:43:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
16:35:01:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
16:36:19:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
16:37:37:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
16:38:56:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
16:40:14:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
16:41:32:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
16:42:49:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
16:44:06:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
16:45:24:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
16:46:41:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
16:47:58:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
16:49:15:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
16:50:31:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
16:51:48:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
16:53:05:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
16:54:22:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
16:55:38:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
16:56:55:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
16:58:12:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
16:59:30:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
17:00:46:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
17:02:04:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
17:03:23:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
17:04:40:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
17:05:59:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
17:07:18:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
17:08:37:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
17:09:54:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
17:11:10:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
17:12:26:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
17:13:43:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
17:15:00:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
17:16:17:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
17:17:34:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
17:18:52:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
17:20:10:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
17:21:28:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
17:22:44:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
17:24:01:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
17:25:19:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
17:26:37:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
17:27:54:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
17:29:11:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
17:30:29:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
17:31:46:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
17:33:03:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
17:34:20:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
17:35:37:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
17:36:54:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
17:38:10:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
17:39:27:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
17:40:46:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
17:42:03:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
17:43:21:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
17:44:38:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
17:45:55:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
17:47:12:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
17:48:29:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
17:49:46:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
17:51:04:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
17:52:21:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
17:53:38:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
17:54:56:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
17:56:13:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
17:57:30:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
17:58:46:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
18:00:03:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
18:01:21:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
18:02:37:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
18:03:53:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
18:05:10:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
18:06:26:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
18:07:42:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
18:08:59:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
18:10:16:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
18:11:34:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
18:12:52:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
18:14:10:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
18:15:28:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
18:16:45:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
18:18:03:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
18:19:20:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
18:20:38:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
18:21:56:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
18:23:13:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
18:24:31:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
18:25:49:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
18:27:07:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
18:28:25:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
18:29:43:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
18:31:01:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
18:32:19:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
18:33:36:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
18:34:57:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
18:34:58:WU01:FS00:Connecting to 65.254.110.245:8080
18:34:59:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:34:59:WU01:FS00:Connecting to 18.218.241.186:80
18:34:59:WU01:FS00:Assigned to work server 150.136.14.110
18:34:59:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 150.136.14.110
18:34:59:WU01:FS00:Connecting to 150.136.14.110:8080
18:35:00:WU01:FS00:Downloading 1.25MiB
18:35:00:WU01:FS00:Download complete
18:35:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16403 run:1960 clone:1 gen:90 core:0xa7 unit:0x0000006396880e6e5e8bdf968ec6a258
18:36:17:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
18:36:18:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
18:36:18:WU00:FS00:0xa7:Saving result file dhdl.xvg
18:36:18:WU00:FS00:0xa7:Saving result file frame6.trr
18:36:18:WU00:FS00:0xa7:Saving result file md.log
18:36:18:WU00:FS00:0xa7:Saving result file pullf.xvg
18:36:18:WU00:FS00:0xa7:Saving result file pullx.xvg
18:36:18:WU00:FS00:0xa7:Saving result file science.log
18:36:18:WU00:FS00:0xa7:Saving result file traj_comp.xtc
18:36:18:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:36:18:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:36:18:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14823 run:974 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55ea30d02c78cef97
18:36:19:WU00:FS00:Uploading 6.86MiB to 155.247.164.213
18:36:19:WU00:FS00:Connecting to 155.247.164.213:8080
18:36:19:WU01:FS00:Starting
18:36:19:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1499 -checkpoint 15 -np 8
18:36:19:WU01:FS00:Started FahCore on PID 23032
18:36:19:WU01:FS00:Core PID:23036
18:36:19:WU01:FS00:FahCore 0xa7 started
18:36:19:WU01:FS00:0xa7:*********************** Log Started 2020-04-28T18:36:19Z ***********************
18:36:19:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:36:19:WU01:FS00:0xa7: Type: 0xa7
18:36:19:WU01:FS00:0xa7: Core: Gromacs
18:36:19:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 23032 -checkpoint 15 -np
18:36:19:WU01:FS00:0xa7: 8
18:36:19:WU01:FS00:0xa7:************************************ CBang *************************************
18:36:19:WU01:FS00:0xa7: Date: Nov 5 2019
18:36:19:WU01:FS00:0xa7: Time: 06:06:57
18:36:19:WU01:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
18:36:19:WU01:FS00:0xa7: Branch: master
18:36:19:WU01:FS00:0xa7: Compiler: GNU 8.3.0
18:36:19:WU01:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
18:36:19:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
18:36:19:WU01:FS00:0xa7: Bits: 64
18:36:19:WU01:FS00:0xa7: Mode: Release
18:36:19:WU01:FS00:0xa7:************************************ System ************************************
18:36:19:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
18:36:19:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:36:19:WU01:FS00:0xa7: CPUs: 8
18:36:19:WU01:FS00:0xa7: Memory: 7.72GiB
18:36:19:WU01:FS00:0xa7:Free Memory: 1.60GiB
18:36:19:WU01:FS00:0xa7: Threads: POSIX_THREADS
18:36:19:WU01:FS00:0xa7: OS Version: 3.19
18:36:19:WU01:FS00:0xa7:Has Battery: false
18:36:19:WU01:FS00:0xa7: On Battery: false
18:36:19:WU01:FS00:0xa7: UTC Offset: 2
18:36:19:WU01:FS00:0xa7: PID: 23036
18:36:19:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
18:36:19:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
18:36:19:WU01:FS00:0xa7: Version: 0.0.18
18:36:19:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:36:19:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
18:36:19:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
18:36:19:WU01:FS00:0xa7: Time: 06:13:26
18:36:19:WU01:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
18:36:19:WU01:FS00:0xa7:************************************ Build *************************************
18:36:19:WU01:FS00:0xa7: SIMD: avx_256
18:36:19:WU01:FS00:0xa7:********************************************************************************
18:36:19:WU01:FS00:0xa7:Project: 16403 (Run 1960, Clone 1, Gen 90)
18:36:19:WU01:FS00:0xa7:Unit: 0x0000006396880e6e5e8bdf968ec6a258
18:36:19:WU01:FS00:0xa7:Reading tar file core.xml
18:36:19:WU01:FS00:0xa7:Reading tar file frame90.tpr
18:36:19:WU01:FS00:0xa7:Digital signatures verified
18:36:19:WU01:FS00:0xa7:Calling: mdrun -s frame90.tpr -o frame90.trr -x frame90.xtc -cpt 15 -nt 8
18:36:19:WU01:FS00:0xa7:Steps: first=45000000 total=500000
18:36:19:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
18:36:51:WU00:FS00:Upload 0.91%
18:37:30:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
******************************* Date: 2020-04-28 *******************************
18:37:47:Lost lifeline PID 1497, exiting
18:38:51:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
18:39:27:FS00:Paused
18:39:56:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
18:41:01:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
18:41:44:Caught signal SIGTERM(15) on PID 1499
18:41:44:Exiting, please wait. . .
18:41:44:WU00:FS00:Upload 1.82%
18:41:44:WU01:FS00:0xa7:Caught signal SIGTERM(15) on PID 23036
18:41:44:WU01:FS00:0xa7:Exiting, please wait. . .
18:41:44:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED-
It seems that the first section of the log file is missing. This is how the log file starts:
So can you please post that section so we can see how your client is configured?
*********************** Log Started 2020-05-01T16:41:36Z ***********************
16:41:36:****************************** FAHClient ******************************
16:41:36: Version: 7.6.9
16:41:36: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:41:36: Copyright: 2020 foldingathome.org
16:41:36: Homepage: https://foldingathome.org/
16:41:36: Date: Apr 17 2020
16:41:36: Time: 11:13:06
16:41:36: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
16:41:36: Branch: master
16:41:36: Compiler: Visual C++ 2008
16:41:36: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:41:36: Platform: win32 10
16:41:36: Bits: 32
16:41:36: Mode: Release
16:41:36: Config: C:\Users\PantherX-H\AppData\Roaming\FAHClient\config.xml
16:41:36:******************************** CBang ********************************
16:41:36: Time: 11:10:09
16:41:36: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
16:41:36: Bits: 32
16:41:36:******************************* System ********************************
16:41:36: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
16:41:36: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
16:41:36: CPUs: 8
16:41:36: Memory: 31.94GiB
16:41:36: Free Memory: 27.68GiB
16:41:36: Threads: WINDOWS_THREADS
16:41:36: OS Version: 6.2
16:41:36: Has Battery: false
16:41:36: On Battery: false
16:41:36: UTC Offset: 12
16:41:36: PID: 11440
16:41:36: CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient
16:41:36: OS: Windows 10 Enterprise
16:41:36: OS Arch: AMD64
16:41:36: GPUs: 1
16:41:36: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
16:41:36: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
16:41:36:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
16:41:36: Win32 Service: false
16:41:36:******************************* libFAH ********************************
16:41:36: Date: Apr 15 2020
16:41:36: Time: 14:53:14
16:41:36: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
16:41:36: Bits: 32
16:41:36:***********************************************************************
16:41:36:<config>
16:41:36: <!-- Folding Core -->
16:41:36: <checkpoint v='30'/>
16:41:36: <core-priority v='low'/>
16:41:36:
16:41:36: <!-- Folding Slot Configuration -->
16:41:36: <client-type v='advanced'/>
16:41:36:
16:41:36: <!-- Network -->
16:41:36: <proxy v=':8080'/>
16:41:36:
16:41:36: <!-- Slot Control -->
16:41:36: <pause-on-start v='true'/>
16:41:36: <power v='full'/>
16:41:36:
16:41:36: <!-- User Information -->
16:41:36: <passkey v='*****'/>
16:41:36: <team v='69411'/>
16:41:36: <user v='PantherX'/>
16:41:36:
16:41:36: <!-- Work Unit Control -->
16:41:36: <next-unit-percentage v='100'/>
16:41:36:
16:41:36: <!-- Folding Slots -->
16:41:36: <slot id='0' type='CPU'>
16:41:36: <cpus v='4'/>
16:41:36: </slot>
16:41:36: <slot id='1' type='GPU'/>
16:41:36:</config>
16:41:36:Trying to access database...
16:41:36:Successfully acquired database lock
16:41:36:Enabled folding slot 00: PAUSED cpu:4 (by user)
16:41:36:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
16:57:49:FS01:Unpaused
ArianMohlmann
First section:
*********************** Log Started 2020-04-24T06:13:44Z ***********************
06:13:44:************************* Folding@home Client *************************
06:13:44: Website: https://foldingathome.org/
06:13:44: Copyright: (c) 2009-2018 foldingathome.org
06:13:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:13:44: Args: --child --lifeline 1497 /etc/fahclient/config.xml --run-as
06:13:44: fahclient --pid-file=/var/run/fahclient.pid --daemon
06:13:44: Config: /etc/fahclient/config.xml
06:13:44:******************************** Build ********************************
06:13:44: Version: 7.5.1
06:13:44: Date: May 12 2018
06:13:44: Time: 22:51:07
06:13:44: Repository: Git
06:13:44: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
06:13:44: Branch: master
06:13:44: Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
06:13:44: Options: -std=gnu++98 -O3 -funroll-loops
06:13:44: Platform: linux2 4.14.0-3-amd64
06:13:44: Bits: 64
06:13:44: Mode: Release
06:13:44:******************************* System ********************************
06:13:44: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
06:13:44: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:13:44: CPUs: 8
06:13:44: Memory: 7.72GiB
06:13:44:Free Memory: 7.27GiB
06:13:44: Threads: POSIX_THREADS
06:13:44: OS Version: 3.19
06:13:44:Has Battery: false
06:13:44: On Battery: false
06:13:44: UTC Offset: 2
06:13:44: PID: 1499
06:13:44: CWD: /var/lib/fahclient
06:13:44: OS: Linux 3.19.8-100.fc20.x86_64 x86_64
06:13:44: OS Arch: AMD64
06:13:44: GPUs: 0
06:13:44: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
06:13:44: libcuda.so: cannot open shared object file: No such file or
06:13:44: directory
06:13:44: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
06:13:44: libOpenCL.so: cannot open shared object file: No such file or
06:13:44: directory
06:13:44:***********************************************************************
06:13:44:<config>
06:13:44: <!-- Folding Slot Configuration -->
06:13:44: <gpu v='false'/>
06:13:44:
06:13:44: <!-- Network -->
06:13:44: <proxy v=':8080'/>
06:13:44:
06:13:44: <!-- Slot Control -->
06:13:44: <power v='full'/>
06:13:44:
06:13:44: <!-- User Information -->
06:13:44: <team v='260626'/>
06:13:44: <user v='ArianMohlmann'/>
06:13:44:
06:13:44: <!-- Folding Slots -->
06:13:44: <slot id='0' type='CPU'/>
06:13:44:</config>
06:13:44:Switching to user fahclient
06:13:44:Trying to access database...
06:13:44:Successfully acquired database lock
06:13:44:Enabled folding slot 00: READY cpu:8
06:13:44:WU00:FS00:Starting
06:13:44:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1499 -checkpoint 15 -np 8
06:13:44:WU00:FS00:Started FahCore on PID 1540
06:13:45:WU00:FS00:Core PID:1544
06:13:45:WU00:FS00:FahCore 0xa7 started
06:13:47:WU00:FS00:0xa7:*********************** Log Started 2020-04-24T06:13:47Z ***********************
06:13:47:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:13:47:WU00:FS00:0xa7: Type: 0xa7
06:13:47:WU00:FS00:0xa7: Core: Gromacs
06:13:47:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 1540 -checkpoint 15 -np 8
06:13:47:WU00:FS00:0xa7:************************************ CBang *************************************
06:13:47:WU00:FS00:0xa7: Date: Nov 5 2019
06:13:47:WU00:FS00:0xa7: Time: 06:06:57
06:13:47:WU00:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
06:13:47:WU00:FS00:0xa7: Branch: master
06:13:47:WU00:FS00:0xa7: Compiler: GNU 8.3.0
06:13:47:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
06:13:47:WU00:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
06:13:47:WU00:FS00:0xa7: Bits: 64
06:13:47:WU00:FS00:0xa7: Mode: Release
06:13:47:WU00:FS00:0xa7:************************************ System ************************************
06:13:47:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
06:13:47:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:13:47:WU00:FS00:0xa7: CPUs: 8
06:13:47:WU00:FS00:0xa7: Memory: 7.72GiB
06:13:47:WU00:FS00:0xa7:Free Memory: 7.20GiB
06:13:47:WU00:FS00:0xa7: Threads: POSIX_THREADS
06:13:47:WU00:FS00:0xa7: OS Version: 3.19
06:13:47:WU00:FS00:0xa7:Has Battery: false
06:13:47:WU00:FS00:0xa7: On Battery: false
06:13:47:WU00:FS00:0xa7: UTC Offset: 2
06:13:47:WU00:FS00:0xa7: PID: 1544
06:13:47:WU00:FS00:0xa7: CWD: /var/lib/fahclient/work
06:13:47:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:13:47:WU00:FS00:0xa7: Version: 0.0.18
06:13:47:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:13:47:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:13:47:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:13:47:WU00:FS00:0xa7: Time: 06:13:26
06:13:47:WU00:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
06:13:47:WU00:FS00:0xa7:************************************ Build *************************************
06:13:47:WU00:FS00:0xa7: SIMD: avx_256
06:13:47:WU00:FS00:0xa7:********************************************************************************
06:13:47:WU00:FS00:0xa7:Project: 14614 (Run 243, Clone 0, Gen 40)
06:13:47:WU00:FS00:0xa7:Unit: 0x0000002c9bf7a4d65e7f6663ad69cef5
06:13:47:WU00:FS00:0xa7:Digital signatures verified
06:13:47:WU00:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 8
06:13:49:WU00:FS00:0xa7:Steps: first=0 total=250000
06:13:50:WU00:FS00:0xa7:Completed 63869 out of 250000 steps (25%)
06:14:31:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
06:15:02:FS00:Shutting core down
06:15:02:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 1544
06:15:02:WU00:FS00:0xa7:Exiting, please wait. . .
06:15:03:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:15:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:15:04:WU00:FS00:Starting
[93m06:15:04:WARNING:WU00:FS00:Changed SMP threads from 8 to 7 this can cause some work units to fail[0m
06:15:04:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 1499 -checkpoint 15 -np 7
06:15:04:WU00:FS00:Started FahCore on PID 2442
06:15:04:WU00:FS00:Core PID:2446-
Humm... you stated that you're using V7.6.9 but your log says otherwise:
I can't see any issue in the log file, you started a CPU WU with 8 CPUs and then change it to seven. After that, the log stops.
ArianMohlmann
Of course it does not show 7.6.9 because it does not work!
Both systems 7.6.9 distribution installed.
Nothing is running.
Eebooted the systems.
Still nothing. No logging nothing.
What can I do to get state of the process besides FAH Controll or the log files.
Nothing is running.
If version 7.6.9 isn't running and you don't have the log files, I am guessing that you did an in-place installation which would explain why you have the log folders for the previous client?
I would uninstall everything include the option to delete the data folders too.
I am aware that V7.6.9 for FAHControl has Python 2 dependencies so if you can resolve that, you can install FAHControl. FAHClient should run fine without any issues and I believe the same is true for FAHViewer.
BTW, I have noticed that you are not using a passkey which is recommended for security reasons and bonus points. Here's a link with more details for you to look into: https://foldingathome.org/support/faq/points/passkey/
