Am I really folding?
Mannivu
- Hardware configuration: CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
CPUs: 4
Memory: 7.82GiB
Threads: WINDOWS_THREADS
OS Version: 6.2
OS: Windows 10 Home
OS Arch: AMD64 - Location: Caravaggio, Bergamo, Italy
I've been a user a while ago, but then had to stop because my PC broke. I've started folding again in March, but since i've seen that my stats are nowhere to be found. On the "official" stats page on stats.foldingathome.org my rank ist still 0 of 2,660,829 (but I've read that that might be caused by the overload of users on the stats servers). So I've headed to extremeoverclocking, but, as you can see from my signature below, my username doesn't exists. My team, however, gets point, since the 1700 point made today from my team are mine. I don't know if I'm doing something wrong or it's just a server issue. I have setup a passkey since the first day of folding and I don't know if I'm really folding or not.
Re: Am I really folding?
Welcome back to the forums,
EOC only to User tracking for members of the top 800 teams iirc … Also iirc you will get a ranking once your points pass 100k (or a figure somewhere near that).
Do you have a passkey without which you are not eligable for the QRB (if relevant) which can make a difference to the rate at which you accrue points? https://foldingathome.org/support/faq/points/
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
Hi, thank your repplay.
Yes, I have a passkey. My team on the EOC is at 4510 place. That's why I can't understand why my name can't be found.
Could you post your config.xml from %Appdata%fahclient
delete the actual passkey assuming it is there.
single 1070
Welcome to the F@H Forum Mannivu,
If you're missing from EOC stats, then this might apply to you:
If in doubt, might be better to contact Jason from EOC to see if there's an issue: https://www.extremeoverclocking.com/contact_info.php
https://folding.extremeoverclocking.com/?nav=FAQQ: Why don't we have user (individual) stats for our team?
A: Individual stats are added when the team's rank reaches at least 800. It is possible for individuals to be added sooner based on their team's production and movement. Most active teams have their members auto-added around a team rank of 1,200 - 2,000. If you *really* want yours added sooner, contact me directly and I can change it manually.
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
Sure
<config>
<cause v='HIGH_PRIORITY'/>
<!-- Network -->
<proxy v=':8080'/>
<!-- Slot Control -->
<power v='full'/>
<!-- User Information -->
<passkey v='XXXXXXX'/>
<team v='47965'/>
<user v='Mannivu'/>
<!-- Folding Slots -->
<slot id='0' type='CPU'/>
</config>-
Good news is that you have a CPU slot configured and it looks good. Can you please post the log file which should be below the config.xml?
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
Ah, I see. That might be it.PantherX wrote:Welcome to the F@H Forum Mannivu,
If you're missing from EOC stats, then this might apply to you:https://folding.extremeoverclocking.com/?nav=FAQQ: Why don't we have user (individual) stats for our team?
My bad I typed 8000 instead of 800 when referring to the teams with points .. glad PantherX clarified that
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
Here it is.PantherX wrote:Good news is that you have a CPU slot configured and it looks good. Can you please post the log file which should be below the config.xml?
*********************** Log Started 2020-04-30T08:26:23Z ***********************
08:26:23:****************************** FAHClient ******************************
08:26:23: Version: 7.6.9
08:26:23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:26:23: Copyright: 2020 foldingathome.org
08:26:23: Homepage: https://foldingathome.org/
08:26:23: Date: Apr 17 2020
08:26:23: Time: 11:13:06
08:26:23: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
08:26:23: Branch: master
08:26:23: Compiler: Visual C++ 2008
08:26:23: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:26:23: Platform: win32 10
08:26:23: Bits: 32
08:26:23: Mode: Release
08:26:23: Config: C:\Users\Manuel\AppData\Roaming\FAHClient\config.xml
08:26:23:******************************** CBang ********************************
08:26:23: Time: 11:10:09
08:26:23: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
08:26:23: Bits: 32
08:26:23:******************************* System ********************************
08:26:23: CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
08:26:23: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:26:23: CPUs: 4
08:26:23: Memory: 7.82GiB
08:26:23: Free Memory: 5.02GiB
08:26:23: Threads: WINDOWS_THREADS
08:26:23: OS Version: 6.2
08:26:23: Has Battery: false
08:26:23: On Battery: false
08:26:23: UTC Offset: 2
08:26:23: PID: 7364
08:26:23: CWD: C:\Users\Manuel\AppData\Roaming\FAHClient
08:26:23: OS: Windows 10 Home
08:26:23: OS Arch: AMD64
08:26:23: GPUs: 1
08:26:23: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF117 [GeForce 620M/720M/820M]
08:26:23: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.1
08:26:23:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:391.35
08:26:23: Win32 Service: false
08:26:23:******************************* libFAH ********************************
08:26:23: Date: Apr 15 2020
08:26:23: Time: 14:53:14
08:26:23: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:26:23: Bits: 32
08:26:23:***********************************************************************
08:26:23:<config>
08:26:23: <!-- Folding Slot Configuration -->
08:26:23: <cause v='HIGH_PRIORITY'/>
08:26:23:
08:26:23: <!-- Network -->
08:26:23: <proxy v=':8080'/>
08:26:23:
08:26:23: <!-- Slot Control -->
08:26:23: <power v='full'/>
08:26:23:
08:26:23: <!-- User Information -->
08:26:23: <passkey v='*****'/>
08:26:23: <team v='47965'/>
08:26:23: <user v='Mannivu'/>
08:26:23:
08:26:23: <!-- Folding Slots -->
08:26:23: <slot id='0' type='CPU'/>
08:26:23:</config>
08:26:23:Trying to access database...
08:26:25:Successfully acquired database lock
08:26:25:Enabled folding slot 00: READY cpu:4
08:26:26:WU01:FS00:Starting
08:26:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Manuel\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 7364 -checkpoint 15 -np 4
08:26:26:WU01:FS00:Started FahCore on PID 9712
08:26:27:WU01:FS00:Core PID:12704
08:26:27:WU01:FS00:FahCore 0xa7 started
08:26:29:WU01:FS00:0xa7:*********************** Log Started 2020-04-30T08:26:29Z ***********************
08:26:29:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:26:29:WU01:FS00:0xa7: Type: 0xa7
08:26:29:WU01:FS00:0xa7: Core: Gromacs
08:26:29:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 9712 -checkpoint 15 -np 4
08:26:29:WU01:FS00:0xa7:************************************ CBang *************************************
08:26:29:WU01:FS00:0xa7: Date: Oct 26 2019
08:26:29:WU01:FS00:0xa7: Time: 01:38:25
08:26:29:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:26:29:WU01:FS00:0xa7: Branch: master
08:26:29:WU01:FS00:0xa7: Compiler: Visual C++ 2008
08:26:29:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:26:29:WU01:FS00:0xa7: Platform: win32 10
08:26:29:WU01:FS00:0xa7: Bits: 64
08:26:29:WU01:FS00:0xa7: Mode: Release
08:26:29:WU01:FS00:0xa7:************************************ System ************************************
08:26:29:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz
08:26:29:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
08:26:29:WU01:FS00:0xa7: CPUs: 4
08:26:29:WU01:FS00:0xa7: Memory: 7.82GiB
08:26:29:WU01:FS00:0xa7:Free Memory: 5.01GiB
08:26:29:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
08:26:29:WU01:FS00:0xa7: OS Version: 6.2
08:26:29:WU01:FS00:0xa7:Has Battery: false
08:26:29:WU01:FS00:0xa7: On Battery: false
08:26:29:WU01:FS00:0xa7: UTC Offset: 2
08:26:29:WU01:FS00:0xa7: PID: 12704
08:26:29:WU01:FS00:0xa7: CWD: C:\Users\Manuel\AppData\Roaming\FAHClient\work
08:26:29:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:26:29:WU01:FS00:0xa7: Version: 0.0.18
08:26:29:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:26:29:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
08:26:29:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
08:26:29:WU01:FS00:0xa7: Time: 01:52:30
08:26:29:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:26:29:WU01:FS00:0xa7:************************************ Build *************************************
08:26:29:WU01:FS00:0xa7: SIMD: avx_256
08:26:29:WU01:FS00:0xa7:********************************************************************************
08:26:30:WU01:FS00:0xa7:Project: 16414 (Run 0, Clone 1527, Gen 32)
08:26:30:WU01:FS00:0xa7:Unit: 0x00000028a8f5c67d5e82307470f0e043
08:26:30:WU01:FS00:0xa7:Digital signatures verified
08:26:30:WU01:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 4
08:26:31:WU01:FS00:0xa7:Steps: first=8000000 total=250000
08:26:44:WU01:FS00:0xa7:Completed 24031 out of 250000 steps (9%)
08:37:52:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
09:10:29:3:127.0.0.1:New Web session
09:23:14:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
10:01:56:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
10:35:33:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
The log file shows that you're currently folding on your CPU. It seems fine since it is using all 4 CPUs of your mobile device
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
Yeah, so the "issue" is just that my team rank it's not high enough. Well, at least now I know I'm still doing my part. Thank you allPantherX wrote:The log file shows that you're currently folding on your CPU. It seems fine since it is using all 4 CPUs of your mobile device
The downside I'm afraid is that there is no record of any results for the username 'Mannivu'.
How long have you been folding? Do you fold 24/7?
If you look in the Advanced Control of the FAHClient, the current work unit should be shown. It will show a date/time for "Assigned" - can you post that here?
single 1070
Mannivu
CPUs: 4
Memory: 7.82GiB
OS Version: 6.2
OS: Windows 10 Home
I've been folding since March 2020, but I folded a long time ago in another machine (though I had to stop on that PC since the client was making my PC too slow). I can't remember the exact period, but it was around 2016 (based on my past forum posts).HaloJones wrote:The downside I'm afraid is that there is no record of any results for the username 'Mannivu'.
… https://stats.foldingathome.org/donor/MannivuHaloJones wrote:The downside I'm afraid is that there is no record of any results for the username 'Mannivu'.
