3 days with no folding
NateMac00
Post by NateMac00 »
I started FAH on one of my render computers that holds 4x 980Ti’s that with the quarantine are not doing anything. I added the GPU.txt file to the FAH folder, paused the CPU (cause it’s slow) and let it go. It’s been 3 days and nothing has happened. Any idea’s what I did wrong?
https://i.imgur.com/399rldB.jpg
Mod Edit: Fixed URL - PantherX
Re: 3 days with no folding
Welcome to the F@H Forum NateMac00,
Can you please post the first 100 lines of the log file so we can see what the system configuration is and how the client is setup? Guidance is provided here if you need: memberlist.php?mode=viewprofile&u=15009
In the screenshot, I can see the error about not being able to get an assignment ID which would indicate a network issue on your end. I would suggest that you review this topic and work through it to get some pointers on how to fix the issue: viewtopic.php?f=18&t=17794
