Wu result file bigger than 100MB fail on transfer to 3.*
Knish
3.21.157.11 Work_Quit, dumping p16434 (503 2 4)
Post by Knish »
first, i saw this thread about the possibility of it being a server issue: viewtopic.php?p=330294#p330294
so if posting this is moot, let me know and I'll won't post identical ones in the future
Win 10 Pro, 7.6.9 client
GTX 950
*********************** Log Started 2020-04-28T18:48:55Z ***********************
18:48:55:****************************** FAHClient ******************************
18:48:55:        Version: 7.6.9
18:48:55:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:48:55:      Copyright: 2020 foldingathome.org
18:48:55:       Homepage: https://foldingathome.org/
18:48:55:           Date: Apr 17 2020
18:48:55:           Time: 11:13:06
18:48:55:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
18:48:55:         Branch: master
18:48:55:       Compiler: Visual C++ 2008
18:48:55:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:48:55:       Platform: win32 10
18:48:55:           Bits: 32
18:48:55:           Mode: Release
18:48:55:         Config: C:\Users\jets\AppData\Roaming\FAHClient\config.xml
18:48:55:******************************** CBang ********************************
18:48:55:           Time: 11:10:09
18:48:55:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
18:48:55:           Bits: 32
18:48:55:******************************* System ********************************
18:48:55:            CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
18:48:55:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:48:55:           CPUs: 8
18:48:55:         Memory: 7.96GiB
18:48:55:    Free Memory: 6.12GiB
18:48:55:        Threads: WINDOWS_THREADS
18:48:55:     OS Version: 6.2
18:48:55:    Has Battery: false
18:48:55:     On Battery: false
18:48:55:     UTC Offset: -7
18:48:55:            PID: 9412
18:48:55:            CWD: C:\Users\jets\AppData\Roaming\FAHClient
18:48:55:             OS: Windows 10 Enterprise
18:48:55:        OS Arch: AMD64
18:48:55:           GPUs: 1
18:48:55:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 950] 1572
18:48:55:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:10.1
18:48:55:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
18:48:55:  Win32 Service: false
18:48:55:******************************* libFAH ********************************
18:48:55:           Date: Apr 15 2020
18:48:55:           Time: 14:53:14
18:48:55:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:48:55:           Bits: 32
18:48:55:***********************************************************************
18:48:55:<config>
18:48:55:  <!-- HTTP Server -->
18:48:55:  <allow v='127.0.0.1 192.168.2.181 192.168.2.183'/>
18:48:55:
18:48:55:  <!-- Network -->
18:48:55:  <proxy v=':8080'/>
18:48:55:
18:48:55:  <!-- Remote Command Server -->
18:48:55:  <command-allow-no-pass v='127.0.0.1 192.168.2.181 192.168.2.183'/>
18:48:55:
18:48:55:  <!-- Slot Control -->
18:48:55:  <power v='FULL'/>
18:48:55:
18:48:55:  <!-- User Information -->
18:48:55:  <passkey v='*****'/>
18:48:55:  <tea
18:48:55:
18:48:55:  <!-- Folding Slots -->
18:48:55:  <slot id='1' type='GPU'>
18:48:55:    <client-type v='advanced'/>
18:48:55:    <paused v='true'/>
18:48:55:  </slot>
18:48:55:</config>
17:14:36:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
17:14:41:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
17:14:41:WU00:FS01:0x22:Saving result file checkpointState.xml
17:14:41:WU00:FS01:0x22:Saving result file checkpt.crc
17:14:41:WU00:FS01:0x22:Saving result file positions.xtc
17:14:42:WU00:FS01:0x22:Saving result file science.log
17:14:42:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:14:43:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:14:43:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16434 run:503 clone:2 gen:4 core:0x22 unit:0x0000000503854c135e9cbacc660cead7
17:14:43:WU00:FS01:Uploading 104.36MiB to 3.133.76.19
17:14:43:WU00:FS01:Connecting to 3.133.76.19:8080
17:14:49:WU00:FS01:Upload 0.72%
17:15:37:WU00:FS01:Upload 7.25%
17:15:38:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
17:15:38:WU00:FS01:Trying to send results to collection server
17:15:38:WU00:FS01:Uploading 104.36MiB to 3.21.157.11
17:15:38:WU00:FS01:Connecting to 3.21.157.11:8080
17:15:44:WU00:FS01:Upload 1.08%
17:23:57:WU00:FS01:Upload complete
17:23:57:WU00:FS01:Server responded WORK_QUIT (404)
17:23:57:WARNING:WU00:FS01:Server did not like results, dumping
17:23:57:WU00:FS01:Cleaning up
Avacado
Re: 3.21.157.11 Work_Quit, dumping p16434 (503 2 4)
Post by Avacado »
Having issues with this server too.
sf8kkn
Post by sf8kkn »
Hi there, I'm still under 7.5.1. Again I just finished a wu that client can't send because result file is bigger than 100MB ( 141MB here ), another 3-4 hours lost ...
1 error on this wu between 62 and 63% :
22:13:56:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
22:13:56:WU00:FS01:0x22:Following exception occured: Potential energy error of 93.2721, threshold of 10
22:13:56:WU00:FS01:0x22:Reference Potential Energy: -851433 | Given Potential Energy: -851340
But then going to 100%
And finally failed on transfer :
23:56:09:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16435 run:2182 clone:1 gen:0 core:0x22 unit:0x0000000003854c135e9a4ef80d9c109e
23:56:09:WU00:FS01:Uploading 141.53MiB to 3.133.76.19
23:56:09:WU00:FS01:Connecting to 3.133.76.19:8080
23:56:09:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
23:56:09:WU00:FS01:Trying to send results to collection server
23:56:09:WU00:FS01:Uploading 141.53MiB to 3.21.157.11
23:56:09:WU00:FS01:Connecting to 3.21.157.11:8080
23:56:09:ERROR:WU00:FS01:Exception: Transfer failed
Is this limit still active on the last client version ?
Is there any way to not finish that wu and get another ?
Thanks
sf8kkn
Re: Wu result file bigger than 100MB fail on transfer
Post by sf8kkn »
ok just seen the other topic about that ...
FireFox-89
Hardware configuration: Luna - Active
AMD Ryzen 7 3700X @ Stock | Noctua NH-U14S
Gigabyte B550 Gaming X V2 Revision 1.3 | BIOS version FHa
Corsair Vengeance LPX 2x16GB DDR4-3600 | Timings 18-22-22-42
ASUS GeForce RTX 3060 Ti Strix OC 8GB
SeaSonic M12II 850w 80+ Bronze PSU
Terra - Active
AMD Ryzen 7 2700X @ Stock | Noctua C14S
ASRock B450M/ac R2.0 | BIOS version p10.60
G.Skill Trident RGB 2x8GB DDR4-2800 | Timings 15-15-15-36
Asus GeForce GTX 1070 Ti Strix OC 8GB
be quiet! Pure Power 13 M 550W 80+ Gold PSU
Anubis - Active
Intel Xeon E5-2695 V4 @ Stock | Cooler Master Hyper 212
Gigabyte X99-SOC Champion | BIOS version F23c
Corsair Vengeance LPX 4x8GB @ 2400 | Timings 20-18-18-40 (Needs Sorting)
2x Sapphire Radeon RX 580 Nitro+ 4GB
SeaSonic Prime Platinum 750w 80+ Platinum PSU
All machines running F@H v8.5.5
Post by FireFox-89 »
I'm currently getting an issue like this but I did make a post a little while ago. My failed WU is currently 208MB
Do you even fold bro?
anandhanju
Post by anandhanju »
@Firefox-89, Can you post your log? It'd be useful to see what project the WU is for and the server that's failing to accept the result.
smharr10
Post by smharr10 »
I am also having issues with this server. I have been trying to send a completed WU for the past 24 hours. Project 16435.
HaloJones
Post by HaloJones »
****************************** Date: 2020-04-29 *******************************
11:07:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16435 run:295 clone:0 gen:13 core:0x22 unit:0x0000001103854c135e9a4efbdcf5aa75
11:07:10:WU02:FS00:Uploading 156.40MiB to 3.133.76.19
11:07:10:WU02:FS00:Connecting to 3.133.76.19:8080
11:07:10:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
11:07:10:WU02:FS00:Trying to send results to collection server
11:07:10:WU02:FS00:Uploading 156.40MiB to 3.21.157.11
11:07:10:WU02:FS00:Connecting to 3.21.157.11:8080
11:07:10:ERROR:WU02:FS00:Exception: Transfer failed
This is mine.
4070 super
anandhanju
Can you post the section of the log when you received this WU and started work on it? I'd like to see if it was assigned between 2020-04-25 04:44:27 and 2020-04-25 04:58:01.
The researcher has confirmed the server has been set to accept returns for this project. If the retry fails, please post that section of the log too.
Not_a_Number
Post by Not_a_Number »
I'm having the same problem:
00:43:14:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16435 run:3127 clone:0 gen:1 core:0x22 unit:0x0000000303854c135e9a4ef707714c1c
00:43:14:WU00:FS01:Uploading 141.16MiB to 3.133.76.19
00:43:14:WU00:FS01:Connecting to 3.133.76.19:8080
00:43:15:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
00:43:15:WU00:FS01:Trying to send results to collection server
00:43:15:WU00:FS01:Uploading 141.16MiB to 3.21.157.11
00:43:15:WU00:FS01:Connecting to 3.21.157.11:8080
00:43:15:ERROR:WU00:FS01:Exception: Transfer failed
TIA
LaTeXPython
Post by LaTeXPython »
And another me too.
02:15:32:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16435 run:3763 clone:0 gen:1 core:0x22 unit:0x0000000303854c135e9a4ef608e3d508
02:15:32:WU01:FS01:Uploading 133.90MiB to 3.133.76.19
02:15:32:WU01:FS01:Connecting to 3.133.76.19:8080
02:15:32:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
02:15:32:WU01:FS01:Trying to send results to collection server
02:15:32:WU01:FS01:Uploading 133.90MiB to 3.21.157.11
02:15:32:WU01:FS01:Connecting to 3.21.157.11:8080
02:15:32:ERROR:WU01:FS01:Exception: Transfer failed
Welcome to the F@H Forum smharr10,
Please note that the F@H Team is aware of this issue and is working on it. In the meantime, please leave the client running and the WU will eventually be returned hopefully before the expiration date.
1TM
Re: Server 3.133.76.19 sends Beta units to public
Post by 1TM »
Thank you for your answers. These WUs now have downloaded and uploaded properly.
anandhanju
Thanks, flagged this for the researchers to take a look again.
Nuitari
Hardware configuration: 1x Nvidia 1050ti
1x Nvidia 1660Super
1x Nvidia GTX 660
1x Nvidia 1060 3gb
1x AMD rx570
2x AMD rx560
1x AMD Ryzen 7 PRO 1700
1x AMD Ryzen 7 3700X
1x AMD Phenom II
1x AMD A8-9600
1x Intel i5-4590S
Post by Nuitari »
The one I have that is having this issue was assigned at 2020-04-27 22:11:33
project:16434 run:293 clone:4 gen:1
