"opencl-index v=true" on Radeon R5 m240
Hello!
I have a AMD a6-6310 with Radeon R4 iGPU and a dedicated Radeon R5 m240. The only way to make work the R5 is with "<opencl-index v=true/>". I think I sought that
in the log one time but I'm not sure...
The thing is: I can't find no single place where that option is documented, and when I set that parameter FAHControl can't edit again that slot, it complains about the parameter.
I fact, I try to edit the slot now to copy the output and Sway window manager crashed...
I have tried to set both GPU to "<opencl-index v=true/>" and worked. Now I have the R4 (iGPU) with "<opencl-index v=0/>" and the R5 with "<opencl-index v=true/>" and works, but
is very slow, the R4 says 5 ETA days and the other says 23hs.
Re: "opencl-index v=true" on Radeon R5 m240
Welcome to the F@H Forum ignacio,
Please note that the correct value is a number, not text.
It would be great if you can post your log file here. Guidance is provided here: viewtopic.php?f=24&t=26036
Regarding the documentation of flags, it is present in the above topic and is also present by running FAHClient --help from the command window
opencl-index <string>
The OpenCL device index of the GPU, counting starts from 0.
The OpenCL index is generally set automatically depending on where FAHClient finds a supportable GPU.
Thanks for the answer.PantherX wrote:Welcome to the F@H Forum ignacio,
Please note that the correct value is a number, not text.It would be great if you can post your log file here. Guidance is provided here: viewtopic.php?f=24&t=26036Code: Select all
opencl-index <string> The OpenCL device index of the GPU, counting starts from 0.
I have re-installed the client and start again.
I use Archlinux.
The R4 is folding, the R5 fails with "BAD_WORK_UNIT". I tried a lot of times, if I add "opencl-index v='true'" to the slot it starts folding, but lately
the ETA was 6 or 7 days, very slow.
This is the last log:
*********************** Log Started 2020-04-29T15:43:25Z ***********************
15:43:25:****************************** FAHClient ******************************
15:43:25: Version: 7.6.9
15:43:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:43:25: Copyright: 2020 foldingathome.org
15:43:25: Homepage: https://foldingathome.org/
15:43:25: Date: Apr 17 2020
15:43:25: Time: 18:11:26
15:43:25: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
15:43:25: Branch: master
15:43:25: Compiler: GNU 8.3.0
15:43:25: Options: -std=c++11 -ffunction-sections -fdata-sections -O3
15:43:25: -funroll-loops -fno-pie
15:43:25: Platform: linux2 4.19.0-5-amd64
15:43:25: Bits: 64
15:43:25: Mode: Release
15:43:25: Args: --config /etc/foldingathome/config.xml --log
15:43:25: /var/log/foldingathome/log.txt --log-rotate-dir
15:43:25: Config: /etc/foldingathome/config.xml
15:43:25:******************************** CBang ********************************
15:43:25: Time: 18:10:13
15:43:25: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
15:43:25: -funroll-loops -fno-pie -fPIC
15:43:25: Bits: 64
15:43:25:******************************* System ********************************
15:43:25: CPU: AMD A6-6310 APU with AMD Radeon R4 Graphics
15:43:25: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
15:43:25: CPUs: 4
15:43:25: Memory: 6.75GiB
15:43:25: Free Memory: 4.52GiB
15:43:25: Threads: POSIX_THREADS
15:43:25: OS Version: 5.6
15:43:25: Has Battery: true
15:43:25: On Battery: false
15:43:25: UTC Offset: -3
15:43:25: PID: 8559
15:43:25: CWD: /var/lib/private/fah
15:43:25: OS: Linux 5.6.7-arch1-1 x86_64
15:43:25: OS Arch: AMD64
15:43:25: GPUs: 2
15:43:25: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Mullins [Radeon APU A4-6000 R2]
15:43:25: GPU 1: Bus:1 Slot:0 Func:0 AMD:5 xxxx [Radeon R5 M200 Series]
15:43:25: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
15:43:25: libcuda.so: cannot open shared object file: No such file or
15:43:25: directory
15:43:25:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:3004.6
15:43:25:OpenCL Device 1: Platform:0 Device:1 Bus:1 Slot:0 Compute:1.2 Driver:3004.6
15:43:25:******************************* libFAH ********************************
15:43:25: Date: Apr 15 2020
15:43:25: Time: 21:43:24
15:43:25: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:43:25: Bits: 64
15:43:25:***********************************************************************
15:43:25:<config>
15:43:25: <!-- Network -->
15:43:25: <proxy v=':8080'/>
15:43:25:
15:43:25: <!-- User Information -->
15:43:25: <passkey v='*****'/>
15:43:25: <team v='225605'/>
15:43:25: <user v='nkS2020Carg'/>
15:43:25:
15:43:25: <!-- Folding Slots -->
15:43:25: <slot id='0' type='GPU'/>
15:43:25: <slot id='1' type='GPU'/>
15:43:25:</config>
15:43:25:Trying to access database...
15:43:25:Successfully acquired database lock
15:43:25:Enabled folding slot 00: PAUSED gpu:0:Mullins [Radeon APU A4-6000 R2] (waiting for idle)
15:43:25:Enabled folding slot 01: PAUSED gpu:1:xxxx [Radeon R5 M200 Series] (waiting for idle)
15:44:03:WU00:FS00:Connecting to 65.254.110.245:80
15:44:03:WU01:FS01:Connecting to 65.254.110.245:80
15:44:03:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:03:WU00:FS00:Connecting to 18.218.241.186:80
15:44:03:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:03:WU01:FS01:Connecting to 18.218.241.186:80
15:44:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:04:WU00:FS00:Connecting to 65.254.110.245:80
15:44:04:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:04:WU01:FS01:Connecting to 65.254.110.245:80
15:44:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:04:WU00:FS00:Connecting to 18.218.241.186:80
15:44:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:05:WU01:FS01:Connecting to 18.218.241.186:80
15:44:05:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:05:ERROR:WU00:FS00:Exception: Could not get an assignment
15:44:05:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:05:ERROR:WU01:FS01:Exception: Could not get an assignment
15:44:06:WU00:FS00:Connecting to 65.254.110.245:80
15:44:06:WU01:FS01:Connecting to 65.254.110.245:80
15:44:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:06:WU00:FS00:Connecting to 18.218.241.186:80
15:44:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:06:WU01:FS01:Connecting to 18.218.241.186:80
15:44:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:07:WU00:FS00:Connecting to 65.254.110.245:80
15:44:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:07:WU01:FS01:Connecting to 65.254.110.245:80
15:44:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:07:WU00:FS00:Connecting to 18.218.241.186:80
15:44:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:44:07:WU01:FS01:Connecting to 18.218.241.186:80
15:44:08:WU00:FS00:Assigned to work server 13.82.98.119
15:44:08:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Mullins [Radeon APU A4-6000 R2] from 13.82.98.119
15:44:08:WU00:FS00:Connecting to 13.82.98.119:8080
15:44:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:44:08:ERROR:WU01:FS01:Exception: Could not get an assignment
15:44:26:Removing old file 'configs/config-20200429-145057.xml'
15:44:26:Saving configuration to /etc/foldingathome/config.xml
15:44:26:<config>
15:44:26: <!-- Network -->
15:44:26: <proxy v=':8080'/>
15:44:26:
15:44:26: <!-- Slot Control -->
15:44:26: <power v='medium'/>
15:44:26:
15:44:26: <!-- User Information -->
15:44:26: <passkey v='*****'/>
15:44:26: <team v='225605'/>
15:44:26: <user v='nkS2020Carg'/>
15:44:26:
15:44:26: <!-- Folding Slots -->
15:44:26: <slot id='0' type='GPU'/>
15:44:26: <slot id='1' type='GPU'/>
15:44:26:</config>
15:45:06:WU01:FS01:Connecting to 65.254.110.245:80
15:45:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:45:06:WU01:FS01:Connecting to 18.218.241.186:80
15:45:07:WU01:FS01:Assigned to work server 128.252.203.10
15:45:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:xxxx [Radeon R5 M200 Series] from 128.252.203.10
15:45:07:WU01:FS01:Connecting to 128.252.203.10:8080
15:45:11:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
15:45:12:WU00:FS00:Connecting to 65.254.110.245:80
15:45:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:45:12:WU00:FS00:Connecting to 18.218.241.186:80
15:45:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:45:13:WU00:FS00:Connecting to 65.254.110.245:80
15:45:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:45:14:WU00:FS00:Connecting to 18.218.241.186:80
15:45:14:WU00:FS00:Assigned to work server 128.252.203.10
15:45:14:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Mullins [Radeon APU A4-6000 R2] from 128.252.203.10
15:45:14:WU00:FS00:Connecting to 128.252.203.10:8080
15:46:01:FS00:Finishing
15:46:01:FS01:Finishing
15:46:17:WU00:FS00:Downloading 50.73MiB
15:46:19:WU01:FS01:Downloading 50.74MiB
15:46:23:WU00:FS00:Download 13.06%
15:46:25:WU01:FS01:Download 12.20%
15:46:29:WU00:FS00:Download 28.95%
15:46:31:WU01:FS01:Download 25.13%
15:46:35:WU00:FS00:Download 40.04%
15:46:37:WU01:FS01:Download 40.04%
15:46:41:WU00:FS00:Download 50.88%
15:46:43:WU01:FS01:Download 51.25%
15:46:47:WU00:FS00:Download 64.55%
15:46:49:WU01:FS01:Download 63.69%
15:46:53:WU00:FS00:Download 78.35%
15:46:55:WU01:FS01:Download 73.67%
15:46:59:WU00:FS00:Download 83.15%
15:47:01:WU01:FS01:Download 79.45%
15:47:05:WU00:FS00:Download 96.21%
15:47:06:WU00:FS00:Download complete
15:47:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:4039 gen:56 core:0x22 unit:0x0000006580fccb0a5e6d8105308cc700
15:47:06:WU00:FS00:Starting
15:47:06:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 8559 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:47:06:WU00:FS00:Started FahCore on PID 9050
15:47:06:WU00:FS00:Core PID:9054
15:47:06:WU00:FS00:FahCore 0x22 started
15:47:07:WU01:FS01:Download 90.91%
15:47:07:WU00:FS00:0x22:*********************** Log Started 2020-04-29T15:47:07Z ***********************
15:47:07:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
15:47:07:WU00:FS00:0x22: Type: 0x22
15:47:07:WU00:FS00:0x22: Core: Core22
15:47:07:WU00:FS00:0x22: Website: https://foldingathome.org/
15:47:07:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:47:07:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:47:07:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
15:47:07:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9050 -checkpoint 15
15:47:07:WU00:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:47:07:WU00:FS00:0x22: Config: <none>
15:47:07:WU00:FS00:0x22:************************************ Build *************************************
15:47:07:WU00:FS00:0x22: Version: 0.0.2
15:47:07:WU00:FS00:0x22: Date: Dec 6 2019
15:47:07:WU00:FS00:0x22: Time: 21:20:17
15:47:07:WU00:FS00:0x22: Repository: Git
15:47:07:WU00:FS00:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:47:07:WU00:FS00:0x22: Branch: core22
15:47:07:WU00:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:47:07:WU00:FS00:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:47:07:WU00:FS00:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:47:07:WU00:FS00:0x22: Bits: 64
15:47:07:WU00:FS00:0x22: Mode: Release
15:47:07:WU00:FS00:0x22:************************************ System ************************************
15:47:07:WU00:FS00:0x22: CPU: AMD A6-6310 APU with AMD Radeon R4 Graphics
15:47:07:WU00:FS00:0x22: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
15:47:07:WU00:FS00:0x22: CPUs: 4
15:47:07:WU00:FS00:0x22: Memory: 6.75GiB
15:47:07:WU00:FS00:0x22:Free Memory: 4.27GiB
15:47:07:WU00:FS00:0x22: Threads: POSIX_THREADS
15:47:07:WU00:FS00:0x22: OS Version: 5.6
15:47:07:WU00:FS00:0x22:Has Battery: true
15:47:07:WU00:FS00:0x22: On Battery: false
15:47:07:WU00:FS00:0x22: UTC Offset: -3
15:47:07:WU00:FS00:0x22: PID: 9054
15:47:07:WU00:FS00:0x22: CWD: /var/lib/private/fah/work
15:47:07:WU00:FS00:0x22: OS: Linux 5.6.7-arch1-1 x86_64
15:47:07:WU00:FS00:0x22: OS Arch: AMD64
15:47:07:WU00:FS00:0x22:********************************************************************************
15:47:07:WU00:FS00:0x22:Project: 11762 (Run 0, Clone 4039, Gen 56)
15:47:07:WU00:FS00:0x22:Unit: 0x0000006580fccb0a5e6d8105308cc700
15:47:07:WU00:FS00:0x22:Reading tar file core.xml
15:47:07:WU00:FS00:0x22:Reading tar file integrator.xml
15:47:07:WU00:FS00:0x22:Reading tar file state.xml
15:47:07:WU00:FS00:0x22:Reading tar file system.xml
15:47:07:WU00:FS00:0x22:Digital signatures verified
15:47:08:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:47:08:WU00:FS00:0x22:Version 0.0.2
15:47:11:WU01:FS01:Download complete
15:47:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:9011 gen:30 core:0x22 unit:0x0000003a80fccb0a5e7113c4847fe703
15:47:11:WU01:FS01:Starting
15:47:11:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 8559 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
15:47:11:WU01:FS01:Started FahCore on PID 9067
15:47:11:WU01:FS01:Core PID:9071
15:47:11:WU01:FS01:FahCore 0x22 started
15:47:11:WU01:FS01:0x22:*********************** Log Started 2020-04-29T15:47:11Z ***********************
15:47:11:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:47:11:WU01:FS01:0x22: Type: 0x22
15:47:11:WU01:FS01:0x22: Core: Core22
15:47:11:WU01:FS01:0x22: Website: https://foldingathome.org/
15:47:11:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:47:11:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:47:11:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:47:11:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 9067 -checkpoint 15
15:47:11:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
15:47:11:WU01:FS01:0x22: Config: <none>
15:47:11:WU01:FS01:0x22:************************************ Build *************************************
15:47:11:WU01:FS01:0x22: Version: 0.0.2
15:47:11:WU01:FS01:0x22: Date: Dec 6 2019
15:47:11:WU01:FS01:0x22: Time: 21:20:17
15:47:11:WU01:FS01:0x22: Repository: Git
15:47:11:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:47:11:WU01:FS01:0x22: Branch: core22
15:47:11:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:47:11:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:47:11:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:47:11:WU01:FS01:0x22: Bits: 64
15:47:11:WU01:FS01:0x22: Mode: Release
15:47:11:WU01:FS01:0x22:************************************ System ************************************
15:47:11:WU01:FS01:0x22: CPU: AMD A6-6310 APU with AMD Radeon R4 Graphics
15:47:11:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
15:47:11:WU01:FS01:0x22: CPUs: 4
15:47:11:WU01:FS01:0x22: Memory: 6.75GiB
15:47:11:WU01:FS01:0x22:Free Memory: 4.01GiB
15:47:11:WU01:FS01:0x22: Threads: POSIX_THREADS
15:47:11:WU01:FS01:0x22: OS Version: 5.6
15:47:11:WU01:FS01:0x22:Has Battery: true
15:47:11:WU01:FS01:0x22: On Battery: false
15:47:11:WU01:FS01:0x22: UTC Offset: -3
15:47:11:WU01:FS01:0x22: PID: 9071
15:47:11:WU01:FS01:0x22: CWD: /var/lib/private/fah/work
15:47:11:WU01:FS01:0x22: OS: Linux 5.6.7-arch1-1 x86_64
15:47:11:WU01:FS01:0x22: OS Arch: AMD64
15:47:11:WU01:FS01:0x22:********************************************************************************
15:47:11:WU01:FS01:0x22:Project: 11762 (Run 0, Clone 9011, Gen 30)
15:47:11:WU01:FS01:0x22:Unit: 0x0000003a80fccb0a5e7113c4847fe703
15:47:11:WU01:FS01:0x22:Reading tar file core.xml
15:47:11:WU01:FS01:0x22:Reading tar file integrator.xml
15:47:11:WU01:FS01:0x22:Reading tar file state.xml
15:47:11:WU01:FS01:0x22:Reading tar file system.xml
15:47:12:WU01:FS01:0x22:Digital signatures verified
15:47:12:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:47:12:WU01:FS01:0x22:Version 0.0.2
15:47:24:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateCommandQueue (-6)
15:47:24:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:47:24:WU01:FS01:0x22:Saving result file science.log
15:47:24:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:47:25:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:47:25:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11762 run:0 clone:9011 gen:30 core:0x22 unit:0x0000003a80fccb0a5e7113c4847fe703
15:47:25:WU01:FS01:Uploading 8.00KiB to 128.252.203.10
15:47:25:WU01:FS01:Connecting to 128.252.203.10:8080
15:47:25:WU02:FS01:Connecting to 65.254.110.245:80
15:47:26:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:47:26:WU02:FS01:Connecting to 18.218.241.186:80
15:47:26:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:47:26:WU02:FS01:Connecting to 65.254.110.245:80
15:47:27:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:47:27:WU02:FS01:Connecting to 18.218.241.186:80
15:47:28:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:47:28:ERROR:WU02:FS01:Exception: Could not get an assignment
15:47:28:WU02:FS01:Connecting to 65.254.110.245:80
15:47:29:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:47:29:WU02:FS01:Connecting to 18.218.241.186:80
15:47:29:WU02:FS01:Assigned to work server 13.82.98.119
15:47:29:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:xxxx [Radeon R5 M200 Series] from 13.82.98.119
15:47:29:WU02:FS01:Connecting to 13.82.98.119:8080
15:47:39:WU00:FS00:0x22:Completed 0 out of 1000000 steps (0%)
15:47:39:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:48:07:ERROR:WU02:FS01:Exception: Server did not assign work unit
15:48:29:WU02:FS01:Connecting to 65.254.110.245:80
15:48:30:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:48:30:WU02:FS01:Connecting to 18.218.241.186:80
15:48:31:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:48:31:WU02:FS01:Connecting to 65.254.110.245:80
15:48:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:48:32:WU02:FS01:Connecting to 18.218.241.186:80
15:48:32:WU02:FS01:Assigned to work server 140.163.4.231
15:48:32:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:xxxx [Radeon R5 M200 Series] from 140.163.4.231
15:48:32:WU02:FS01:Connecting to 140.163.4.231:8080
15:48:46:WU01:FS01:Upload complete
15:48:46:WU01:FS01:Server responded WORK_ACK (400)
15:48:47:WU01:FS01:Cleaning up
15:50:26:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
15:50:26:WU02:FS01:Connecting to 65.254.110.245:80
15:50:26:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:50:26:WU02:FS01:Connecting to 18.218.241.186:80
15:50:27:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:50:27:WU02:FS01:Connecting to 65.254.110.245:80
15:50:28:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:50:28:WU02:FS01:Connecting to 18.218.241.186:80
15:50:28:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:50:28:ERROR:WU02:FS01:Exception: Could not get an assignment-
https://www.techpowerup.com/gpu-specs/r ... hics.c2494
Meets F@H prerequisites
https://www.techpowerup.com/gpu-specs/r ... m230.c2415
It seems wildly unlikely you would have both in a single system. Does your computer have a model number?
Acer Aspire E5-521GJimboPalmer wrote:https://www.techpowerup.com/gpu-specs/r ... hics.c2494
micro: AMD A6-6310 APU with AMD Radeon R4 Graphics
GPU: "Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Jet XT [Radeon R5 M240]"
This is the iGPU:
https://www.techpowerup.com/gpu-specs/r ... hics.c2496
This the GPU:
https://www.techpowerup.com/gpu-specs/r ... m240.c2416
This the GPU:
According to - https://www.techpowerup.com/gpu-specs/r ... hics.c2496 - the iGPU in the APU should also meet the requirements, does the motherboard it is installed on support having both the iGPU and an installed GPU active? That may also be an option that defaults to th iGPU not being active, and would need to be made active in the BIOS.
As for setting the value to 'true' for 'OpenCL-index', please post your config.xml file to show this. You can blank out the passkey entry part of the file.
The iGPU can't be controled from the BIOS in this model. Also I have problems with the discrete GPU, the iGPU never returns BAD_WORK_UNIT.Joe_H wrote:According to - https://www.techpowerup.com/gpu-specs/r ... hics.c2496 - the iGPU in the APU should also meet the requirements, does the motherboard it is installed on support having both the iGPU and an installed GPU active? That may also be an option that defaults to th iGPU not being active, and would need to be made active in the BIOS.
I have started again: deleted all slots and added the GPU's one at a time.
With the normal config the Radeon R5 (discrete gpu) fails with "BAD_WORKING_UNIT"
Then I added "opencl-index v='true'" only to R5 slot and get WU assigned and is running. But now the R4 (iGPU) also run but with ETA 120 days!
https://imgur.com/BUkhbs2
https://imgur.com/0XGbzBK
20:17:04:Removing old file 'configs/config-20200429-175136.xml'
20:17:04:Saving configuration to /etc/foldingathome/config.xml
20:17:04:<config>
20:17:04: <!-- Network -->
20:17:04: <proxy v=':8080'/>
20:17:04:
20:17:04: <!-- Slot Control -->
20:17:04: <power v='medium'/>
20:17:04:
20:17:04: <!-- User Information -->
20:17:04: <passkey v='*****'/>
20:17:04: <team v='225605'/>
20:17:04: <user v='nkS2020Carg'/>
20:17:04:
20:17:04: <!-- Folding Slots -->
20:17:04: <slot id='0' type='GPU'/>
20:17:04: <slot id='1' type='GPU'>
20:17:04: <opencl-index v='true'/>
20:17:04: </slot>
20:17:04:</config>
20:17:19:Removing old file 'configs/config-20200429-184033.xml'
20:17:19:Saving configuration to /etc/foldingathome/config.xml
20:17:19:<config>
20:17:19: <!-- Network -->
20:17:19: <proxy v=':8080'/>
20:17:19:
20:17:19: <!-- Slot Control -->
20:17:19: <power v='medium'/>
20:17:19:
20:17:19: <!-- User Information -->
20:17:19: <passkey v='*****'/>
20:17:19: <team v='225605'/>
20:17:19: <user v='nkS2020Carg'/>
20:17:19:
20:17:19: <!-- Folding Slots -->
20:17:19: <slot id='0' type='GPU'/>
20:17:19: <slot id='1' type='GPU'>
20:17:19: <opencl-index v='true'/>
20:17:19: </slot>
20:17:19:</config>
20:18:27:WU02:FS01:Connecting to 65.254.110.245:80
20:18:28:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:18:28:WU02:FS01:Connecting to 18.218.241.186:80
20:18:28:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:18:28:WU02:FS01:Connecting to 65.254.110.245:80
20:18:29:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:18:29:WU02:FS01:Connecting to 18.218.241.186:80
20:18:29:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:18:29:ERROR:WU02:FS01:Exception: Could not get an assignment
20:20:49:WU00:FS00:Connecting to 65.254.110.245:80
20:20:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:20:49:WU00:FS00:Connecting to 18.218.241.186:80
20:20:50:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:20:50:WU00:FS00:Connecting to 65.254.110.245:80
20:20:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:20:51:WU00:FS00:Connecting to 18.218.241.186:80
20:20:51:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:20:51:ERROR:WU00:FS00:Exception: Could not get an assignment
20:22:41:WU02:FS01:Connecting to 65.254.110.245:80
20:22:42:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:22:42:WU02:FS01:Connecting to 18.218.241.186:80
20:22:42:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:22:42:WU02:FS01:Connecting to 65.254.110.245:80
20:22:43:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:22:43:WU02:FS01:Connecting to 18.218.241.186:80
20:22:43:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:22:43:ERROR:WU02:FS01:Exception: Could not get an assignment
20:29:32:WU02:FS01:Connecting to 65.254.110.245:80
20:29:33:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:29:33:WU02:FS01:Connecting to 18.218.241.186:80
20:29:34:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:29:34:WU02:FS01:Connecting to 65.254.110.245:80
20:29:34:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:29:34:WU02:FS01:Connecting to 18.218.241.186:80
20:29:35:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:29:35:ERROR:WU02:FS01:Exception: Could not get an assignment
20:38:45:WU00:FS00:Connecting to 65.254.110.245:80
20:38:46:WU00:FS00:Assigned to work server 3.133.76.19
20:38:46:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Mullins [Radeon APU A4-6000 R2] from 3.133.76.19
20:38:46:WU00:FS00:Connecting to 3.133.76.19:8080
20:38:47:WU00:FS00:Downloading 30.38MiB
20:38:53:WU00:FS00:Download 25.10%
20:38:59:WU00:FS00:Download 48.55%
20:39:05:WU00:FS00:Download 76.74%
20:39:10:WU00:FS00:Download complete
20:39:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16435 run:3537 clone:2 gen:0 core:0x22 unit:0x0000000103854c135e9a4ef622b7c360
20:39:10:WU00:FS00:Starting
20:39:10:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 17748 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:39:10:WU00:FS00:Started FahCore on PID 22925
20:39:10:WU00:FS00:Core PID:22929
20:39:10:WU00:FS00:FahCore 0x22 started
20:39:10:WU00:FS00:0x22:*********************** Log Started 2020-04-29T20:39:10Z ***********************
20:39:10:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
20:39:10:WU00:FS00:0x22: Type: 0x22
20:39:10:WU00:FS00:0x22: Core: Core22
20:39:10:WU00:FS00:0x22: Website: https://foldingathome.org/
20:39:10:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:39:10:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:39:10:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
20:39:10:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 22925 -checkpoint 15
20:39:10:WU00:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:39:10:WU00:FS00:0x22: Config: <none>
20:39:10:WU00:FS00:0x22:************************************ Build *************************************
20:39:10:WU00:FS00:0x22: Version: 0.0.2
20:39:10:WU00:FS00:0x22: Date: Dec 6 2019
20:39:10:WU00:FS00:0x22: Time: 21:20:17
20:39:10:WU00:FS00:0x22: Repository: Git
20:39:10:WU00:FS00:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
20:39:10:WU00:FS00:0x22: Branch: core22
20:39:10:WU00:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
20:39:10:WU00:FS00:0x22: Options: -std=gnu++98 -O3 -funroll-loops
20:39:10:WU00:FS00:0x22: Platform: linux2 4.9.87-linuxkit-aufs
20:39:10:WU00:FS00:0x22: Bits: 64
20:39:10:WU00:FS00:0x22: Mode: Release
20:39:10:WU00:FS00:0x22:************************************ System ************************************
20:39:10:WU00:FS00:0x22: CPU: AMD A6-6310 APU with AMD Radeon R4 Graphics
20:39:10:WU00:FS00:0x22: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
20:39:10:WU00:FS00:0x22: CPUs: 4
20:39:10:WU00:FS00:0x22: Memory: 6.75GiB
20:39:10:WU00:FS00:0x22:Free Memory: 3.58GiB
20:39:10:WU00:FS00:0x22: Threads: POSIX_THREADS
20:39:10:WU00:FS00:0x22: OS Version: 5.6
20:39:10:WU00:FS00:0x22:Has Battery: true
20:39:10:WU00:FS00:0x22: On Battery: false
20:39:10:WU00:FS00:0x22: UTC Offset: -3
20:39:10:WU00:FS00:0x22: PID: 22929
20:39:10:WU00:FS00:0x22: CWD: /var/lib/private/fah/work
20:39:10:WU00:FS00:0x22: OS: Linux 5.6.7-arch1-1 x86_64
20:39:10:WU00:FS00:0x22: OS Arch: AMD64
20:39:10:WU00:FS00:0x22:********************************************************************************
20:39:10:WU00:FS00:0x22:Project: 16435 (Run 3537, Clone 2, Gen 0)
20:39:10:WU00:FS00:0x22:Unit: 0x0000000103854c135e9a4ef622b7c360
20:39:10:WU00:FS00:0x22:Reading tar file core.xml
20:39:10:WU00:FS00:0x22:Reading tar file integrator.xml
20:39:10:WU00:FS00:0x22:Reading tar file state.xml
20:39:10:WU00:FS00:0x22:Reading tar file system.xml
20:39:10:WU00:FS00:0x22:Digital signatures verified
20:39:10:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
20:39:10:WU00:FS00:0x22:Version 0.0.2
20:39:32:WU00:FS00:0x22:Completed 0 out of 5000000 steps (0%)
20:39:32:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:40:38:WU02:FS01:Connecting to 65.254.110.245:80
20:40:39:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:40:39:WU02:FS01:Connecting to 18.218.241.186:80
20:40:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:40:39:WU02:FS01:Connecting to 65.254.110.245:80
20:40:40:WU02:FS01:Assigned to work server 140.163.4.241
20:40:40:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:xxxx [Radeon R5 M200 Series] from 140.163.4.241
20:40:40:WU02:FS01:Connecting to 140.163.4.241:8080
20:42:10:WU02:FS01:Downloading 4.53MiB
20:42:16:WU02:FS01:Download 80.03%
20:42:16:WU02:FS01:Download complete
20:42:16:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:12058 gen:6 core:0x22 unit:0x000000088ca304f15e6d7ef5e93689bd
20:42:16:WU02:FS01:Starting
20:42:16:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/private/fah/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 706 -lifeline 17748 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:42:16:WU02:FS01:Started FahCore on PID 23269
20:42:16:WU02:FS01:Core PID:23273
20:42:16:WU02:FS01:FahCore 0x22 started
20:42:17:WU02:FS01:0x22:*********************** Log Started 2020-04-29T20:42:16Z ***********************
20:42:17:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:42:17:WU02:FS01:0x22: Type: 0x22
20:42:17:WU02:FS01:0x22: Core: Core22
20:42:17:WU02:FS01:0x22: Website: https://foldingathome.org/
20:42:17:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:42:17:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:42:17:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:42:17:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 23269 -checkpoint 15
20:42:17:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:42:17:WU02:FS01:0x22: Config: <none>
20:42:17:WU02:FS01:0x22:************************************ Build *************************************
20:42:17:WU02:FS01:0x22: Version: 0.0.2
20:42:17:WU02:FS01:0x22: Date: Dec 6 2019
20:42:17:WU02:FS01:0x22: Time: 21:20:17
20:42:17:WU02:FS01:0x22: Repository: Git
20:42:17:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
20:42:17:WU02:FS01:0x22: Branch: core22
20:42:17:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
20:42:17:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
20:42:17:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
20:42:17:WU02:FS01:0x22: Bits: 64
20:42:17:WU02:FS01:0x22: Mode: Release
20:42:17:WU02:FS01:0x22:************************************ System ************************************
20:42:17:WU02:FS01:0x22: CPU: AMD A6-6310 APU with AMD Radeon R4 Graphics
20:42:17:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 22 Model 48 Stepping 1
20:42:17:WU02:FS01:0x22: CPUs: 4
20:42:17:WU02:FS01:0x22: Memory: 6.75GiB
20:42:17:WU02:FS01:0x22:Free Memory: 3.19GiB
20:42:17:WU02:FS01:0x22: Threads: POSIX_THREADS
20:42:17:WU02:FS01:0x22: OS Version: 5.6
20:42:17:WU02:FS01:0x22:Has Battery: true
20:42:17:WU02:FS01:0x22: On Battery: false
20:42:17:WU02:FS01:0x22: UTC Offset: -3
20:42:17:WU02:FS01:0x22: PID: 23273
20:42:17:WU02:FS01:0x22: CWD: /var/lib/private/fah/work
20:42:17:WU02:FS01:0x22: OS: Linux 5.6.7-arch1-1 x86_64
20:42:17:WU02:FS01:0x22: OS Arch: AMD64
20:42:17:WU02:FS01:0x22:********************************************************************************
20:42:17:WU02:FS01:0x22:Project: 11742 (Run 0, Clone 12058, Gen 6)
20:42:17:WU02:FS01:0x22:Unit: 0x000000088ca304f15e6d7ef5e93689bd
20:42:17:WU02:FS01:0x22:Reading tar file core.xml
20:42:17:WU02:FS01:0x22:Reading tar file integrator.xml
20:42:17:WU02:FS01:0x22:Reading tar file state.xml
20:42:18:WU02:FS01:0x22:Reading tar file system.xml
20:42:19:WU02:FS01:0x22:Digital signatures verified
20:42:19:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:42:19:WU02:FS01:0x22:Version 0.0.2
20:43:01:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
20:43:01:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900Re: "opencl-index v=true" on Radeon R5 m240
'true' is not a valid setting for 'OpenCL-index'
For this sysem, one OpenCL index would be 0 and the other would be 1.
15:43:25: GPUs: 2
15:43:25: GPU 1: Bus:1 Slot:0 Func:0 AMD:5 xxxx [Radeon R5 M200 Series]Posting FAH's log:
First, thanks for answer.bruce wrote:'true' is not a valid setting for 'OpenCL-index'For this sysem, one OpenCL index would be 0 and the other would be 1.Code: Select all
15:43:25: GPUs: 2 15:43:25: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Mullins [Radeon APU A4-6000 R2] 15:43:25: GPU 1: Bus:1 Slot:0 Func:0 AMD:5 xxxx [Radeon R5 M200 Series]
I know about the opencl index, I've searched for information and read the docs and forums.
But the R5 fails with and without opencl-index set, this is the error:
01:31:11:WU01:FS01:0x22:ERROR:exception: Error initializing context: clCreateCommandQueue (-6)Code: Select all
01:27:12: GPUs: 2
01:27:12: GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Mullins [Radeon APU A4-6000 R2]
01:27:12: GPU 1: Bus:1 Slot:0 Func:0 AMD:5 xxxx [Radeon R5 M200 Series]
01:27:12: CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
01:27:12: libcuda.so: cannot open shared object file: No such file or
01:27:12: directory
01:27:12:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:3004.6
01:27:12:OpenCL Device 1: Platform:0 Device:1 Bus:1 Slot:0 Compute:1.2 Driver:3004.6
01:27:12:OpenCL Device 2: Platform:1 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:20.0
01:27:12:OpenCL Device 3: Platform:1 Device:1 Bus:NA Slot:NA Compute:1.1 Driver:20.0-
What bruce means is this is how your configuration should look like:
May I ask how you are editing the config.xml file? Are you using FAHControl or a text editor?
<opencl-index v='0'/>
</slot>
<opencl-index v='1'/>
</slot>
I have edited it with FAHControl. Also I have tried the opencl indexes that you mention and the R5 fails.PantherX wrote:What bruce means is this is how your configuration should look like:May I ask how you are editing the config.xml file? Are you using FAHControl or a text editor?Code: Select all
<!-- Folding Slots --> <slot id='1' type='GPU'> <opencl-index v='0'/> </slot> <slot id='1' type='GPU'> <opencl-index v='1'/> </slot>
I have found something that could be the cause of
The Radeon R5 m240 is GCN 1.0. The Radeon R4 (iGPU) is working fine and it's GCN 2.0.
It seems that OpenCL driver has a problem with that architecture of GPUS:
https://community.amd.com/thread/237006
https://developer.blender.org/T50761
I have tried with the environment variables that mentions here https://github.com/xmrig/xmrig-amd/issues/32 but still fails with the same error.
Error initializing context: clCreateCommandQueue (-6)It seems that OpenCL driver has a problem with that architecture of GPUS:
