GPU Asus 1070 8gb oc not getting wu
Erock
Post by Erock »
I almost hit 1 Million points with my cpu in my desktop pc and my notebook but I also want to use my GPU in my desktop pc. I have got an ASUS 1070 8GB OC Dual Series. In the advanced control it is detected but I don't get any WU and I am waiting for 2 weeks and yes, I restarted my computer a couple of times :) .
Thank you for your help!
*********************** Log Started 2020-04-28T23:42:13Z ***********************
23:42:13:****************************** FAHClient ******************************
23:42:13:      Version: 7.6.9
23:42:13:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:42:13:    Copyright: 2020 foldingathome.org
23:42:13:     Homepage: https://foldingathome.org/
23:42:13:         Date: Apr 17 2020
23:42:13:         Time: 11:13:06
23:42:13:     Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:42:13:       Branch: master
23:42:13:     Compiler: Visual C++ 2008
23:42:13:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:42:13:     Platform: win32 10
23:42:13:         Bits: 32
23:42:13:         Mode: Release
23:42:13:         Args: --open-web-control
23:42:13:       Config: C:\Users\Simon\AppData\Roaming\FAHClient\config.xml
23:42:13:******************************** CBang ********************************
23:42:13:         Time: 11:10:09
23:42:13:     Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:42:13:         Bits: 32
23:42:13:******************************* System ********************************
23:42:13:          CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
23:42:13:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:42:13:         CPUs: 4
23:42:13:       Memory: 15.94GiB
23:42:13:  Free Memory: 9.93GiB
23:42:13:      Threads: WINDOWS_THREADS
23:42:13:   OS Version: 6.1
23:42:13:  Has Battery: false
23:42:13:   On Battery: false
23:42:13:   UTC Offset: 2
23:42:13:          PID: 9248
23:42:13:          CWD: C:\Users\Simon\AppData\Roaming\FAHClient
23:42:13:           OS: Windows 7 Enterprise
23:42:13:      OS Arch: AMD64
23:42:13:         GPUs: 1
23:42:13:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
23:42:13:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
23:42:13:       OpenCL: Not detected: clGetDeviceIDs() returned -1
23:42:13:Win32 Service: false
23:42:13:******************************* libFAH ********************************
23:42:13:         Date: Apr 15 2020
23:42:13:         Time: 14:53:14
23:42:13:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:42:13:         Bits: 32
23:42:13:***********************************************************************
23:42:13:<config>
23:42:13:  <!-- Folding Core -->
23:42:13:  <core-priority v='low'/>
23:42:13:
23:42:13:  <!-- Network -->
23:42:13:  <proxy v=':8080'/>
23:42:13:
23:42:13:  <!-- Slot Control -->
23:42:13:  <pause-on-battery v='false'/>
23:42:13:  <power v='full'/>
23:42:13:
23:42:13:  <!-- User Information -->
23:42:13:  <passkey v='*****'/>
23:42:13:  <team v='246127'/>
23:42:13:  <user v='EMotionRennteam16'/>
23:42:13:
23:42:13:  <!-- Folding Slots -->
23:42:13:  <slot id='0' type='CPU'/>
23:42:13:  <slot id='1' type='GPU'/>
23:42:13:</config>
23:42:13:Trying to access database...
23:42:13:Successfully acquired database lock
23:42:13:Enabled folding slot 00: READY cpu:3
23:42:13:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463
23:42:13:WU00:FS00:Starting
23:42:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 9248 -checkpoint 15 -np 3
23:42:13:WU00:FS00:Started FahCore on PID 7940
23:42:13:WU00:FS00:Core PID:10108
23:42:13:WU00:FS00:FahCore 0xa7 started
23:42:13:WU01:FS01:Connecting to 65.254.110.245:80
23:42:14:WU00:FS00:0xa7:*********************** Log Started 2020-04-28T23:42:13Z ***********************
23:42:14:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:42:14:WU00:FS00:0xa7:       Type: 0xa7
23:42:14:WU00:FS00:0xa7:       Core: Gromacs
23:42:14:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7940 -checkpoint 15 -np 3
23:42:14:WU00:FS00:0xa7:************************************ CBang *************************************
23:42:14:WU00:FS00:0xa7:       Date: Oct 26 2019
23:42:14:WU00:FS00:0xa7:       Time: 01:38:25
23:42:14:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:42:14:WU00:FS00:0xa7:     Branch: master
23:42:14:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:42:14:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:42:14:WU00:FS00:0xa7:   Platform: win32 10
23:42:14:WU00:FS00:0xa7:       Bits: 64
23:42:14:WU00:FS00:0xa7:       Mode: Release
23:42:14:WU00:FS00:0xa7:************************************ System ************************************
23:42:14:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
23:42:14:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:42:14:WU00:FS00:0xa7:       CPUs: 4
23:42:14:WU00:FS00:0xa7:     Memory: 15.94GiB
23:42:14:WU00:FS00:0xa7:Free Memory: 9.90GiB
23:42:14:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:42:14:WU00:FS00:0xa7: OS Version: 6.1
23:42:14:WU00:FS00:0xa7:Has Battery: false
23:42:14:WU00:FS00:0xa7: On Battery: false
23:42:14:WU00:FS00:0xa7: UTC Offset: 2
23:42:14:WU00:FS00:0xa7:        PID: 10108
23:42:14:WU00:FS00:0xa7:        CWD: C:\Users\Simon\AppData\Roaming\FAHClient\work
23:42:14:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:42:14:WU00:FS00:0xa7:    Version: 0.0.18
23:42:14:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:42:14:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:42:14:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:42:14:WU00:FS00:0xa7:       Time: 01:52:30
23:42:14:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:42:14:WU00:FS00:0xa7:************************************ Build *************************************
23:42:14:WU00:FS00:0xa7:       SIMD: avx_256
23:42:14:WU00:FS00:0xa7:********************************************************************************
23:42:14:WU00:FS00:0xa7:Project: 16401 (Run 1181, Clone 0, Gen 122)
23:42:14:WU00:FS00:0xa7:Unit: 0x0000008496880e6e5e814c77a0da6aa5
23:42:14:WU00:FS00:0xa7:Digital signatures verified
23:42:14:WU00:FS00:0xa7:Calling: mdrun -s frame122.tpr -o frame122.trr -x frame122.xtc -cpi state.cpt -cpt 15 -nt 3
23:42:14:WU00:FS00:0xa7:Steps: first=61000000 total=500000
23:42:14:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
23:42:14:WU01:FS01:Connecting to 18.218.241.186:80
23:42:14:3:127.0.0.1:New Web session
23:42:14:WU01:FS01:Assigned to work server 140.163.4.241
23:42:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.241
23:42:14:WU01:FS01:Connecting to 140.163.4.241:8080
23:42:14:WU00:FS00:0xa7:Completed 24122 out of 500000 steps (4%)
23:42:33:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
23:42:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
23:42:35:WU01:FS01:Connecting to 140.163.4.241:80
23:44:06:WU01:FS01:Downloading 4.53MiB
23:44:12:WU01:FS01:Download 59.35%
23:44:15:WU01:FS01:Download complete
23:44:15:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11742 run:0 clone:1743 gen:81 core:0x22 unit:0x0000006f8ca304f15e67da442b5feb13
23:44:15:WU01:FS01:Starting
23:44:15:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
23:44:16:WU01:FS01:Starting
23:44:16:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
23:44:21:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
23:45:16:WU01:FS01:Starting
23:45:16:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
Re: GPU Asus 1070 8gb oc not getting wu
Welcome to the F@H Forum Erock,
Please note that you will have to install the latest version of Nvidia Drivers from this site (https://www.nvidia.com/Download/index.aspx?lang=en-us#), not rely on Microsoft's updates which don't include the OpenCL drivers.
This is what your configuration looks like (OpenCL is missing):
23:42:13: GPUs: 1
This is what my system looks like (OpenCL is present):
02:25:01: GPUs: 1
02:25:01: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
02:25:01: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
02:25:01:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
With the correct divers, you should be able to fold on your GPU without getting any errors :)
Erock
Post by Erock »
I have got Nvidia Geforce Experience and I installed the drivers from there before and they are up to date. Anyway I will try the driver from the website. The game ready driver is the same as mine and Studio driver is not available.
Post by muziqaz »
Latest drivers should always install opencl package as well.
Try something else:
in systray, right click fahcontrol, select Advanced Control.
Right click on your GPU slot, select Pause
Click on Configure top left corner
Select Slots tab
Select your GPU slot, slick Edit at the bottom right
GPU-index write 0
OpenCL-index write 0
CUDA-index write 0
Click OK bottom right
Click Save bottom right
Wait for a second or two for changes to be saved (you can see SAVING... at the bottom of the fahcontrol).
Right click on the GPU slot, select Fold. See if it starts connecting to server to get work.
If it doesn't, and it still shows that opencl device is not found, click on Configure
Select Slots tab
select your GPU slot, click Remove, at the bottom right.
Click Save at the bottom right. Wait for the slot to disappear from main window.
Click Configure
Slots tab
Click Add at the bottom right
Select GPU bubble
GPU-index write 0
CUDA-index write 0
I hope this will help ;)
FAH Omega tester
Erock
Post by Erock »
Thank you so much, the first option already worked. I thought that wouldn't change anything but yeah it works.
This Line in the Log is intersting:
19:39:26:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
Normal?
Thanks for your help
Yeah, normal. It is a leftover from an early version of the GPU folding core that included this as a last ditch method of avoiding overheating a GPU when running. It never worked all that well, and was turned off by default in the client.
Several years later, the firmware and GPU drivers do a much better job of protecting the GPU from overheating. This is one of the items on the list to be removed form the folding core code.
Post by muziqaz »
Erock wrote:Thank you so much, the first option already worked. I thought that wouldn't change anything but yeah it works.
Normal?
Good stuff!
FAH Omega tester
Erock
Post by Erock »
Normal?
Good stuff!
Do I need to worry about the line in the Log I mentioned?
Post by Neil-B »
Nope
Post by muziqaz »
As Neil and Joe already mentioned, no. It will always show up, even for systems with AMD GPU. There is a master plan in the works to get rid of it :D
FAH Omega tester
