Very Minor bug: Failed to rename 'log.txt'
arachnaut
Hardware configuration: Windows 10 Pro version 1903 (OS Build 18362.535)
CPU: Core i9-9900K 5.1GHz
MB: ASUS Maximus XI Hero (Wi-Fi)
Memory: 32 GB G.Skill TridentZ 4000Mhz (4x F4-4000C18-8GTZKW)
Boot SSD - Intel Optane 905P 960 GB
Data SSD - Samsung 970 EVO 2 TB
Hard drives - two Seagate Barracuda Pro 8TB each
ASUS ROG STRIX GeForce GTX 1080 TI 11GB
ASUS ROG Swift PG348Q 3440x1440 monitor
Corsair AX1600i power supply
Cooler Master MasterLiquid ML360R radiator + several auxiliary fans
Post by arachnaut »
Using version 7.6.9 and see a few nits like this in the Windows 10 Application Error log:
C:\Program Files (x86)\FAHClient\FAHClient.exe
Exception: Failed to rename 'log.txt' to 'logs\log-20200428-131910.txt': The process cannot access the file because it is being used by another process.
Exception: Failed to rename 'log.txt' to 'logs\log-20200428-131911.txt': The process cannot access the file because it is being used by another process.
Exception: Failed to rename 'log.txt' to 'logs\log-20200428-132012.txt': The process cannot access the file because it is being used by another process.
Jim Hurley
Re: Very Minor bug: Failed to rename 'log.txt'
Post by muziqaz »
These appear during the WU clean up process. WU is still being sent (or failing to be sent), and fahclient is trying to clean up the slot, and since WU files are attempting to upload, they are still in use.
This happens very often when you delete the slot in the middle of the running WU, and create new slot next to it. Fahclient just tries to clean deleted slot data, but it is still attempting to send the data to overloaded servers, thus cannot delete file which is being used.
Eventually that all clears up :)
FAH Omega tester
Do you have an anti-virus or anti-malware application running on the system? These errors may be from the file being locked by being accessed from such software. If you running these, we recommend excluding the data directory from scans.
