Mod Edit: Fixed Image Tags - PantherX
*********************** Log Started 2020-04-27T11:27:26Z ***********************
11:27:26:****************************** FAHClient ******************************
11:27:26: Version: 7.6.9
11:27:26: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:27:26: Copyright: 2020 foldingathome.org
11:27:26: Homepage: https://foldingathome.org/
11:27:26: Date: Apr 17 2020
11:27:26: Time: 11:13:06
11:27:26: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
11:27:26: Branch: master
11:27:26: Compiler: Visual C++ 2008
11:27:26: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:27:26: Platform: win32 10
11:27:26: Bits: 32
11:27:26: Mode: Release
11:27:26: Config: C:\Users\Admin\AppData\Roaming\FAHClient\config.xml
11:27:26:******************************** CBang ********************************
11:27:26: Time: 11:10:09
11:27:26: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
11:27:26: Bits: 32
11:27:26:******************************* System ********************************
11:27:26: CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
11:27:26: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:27:26: CPUs: 12
11:27:26: Memory: 7.85GiB
11:27:26: Free Memory: 4.03GiB
11:27:26: Threads: WINDOWS_THREADS
11:27:26: OS Version: 6.2
11:27:26: Has Battery: true
11:27:26: On Battery: false
11:27:26: UTC Offset: 8
11:27:26: PID: 14764
11:27:26: CWD: C:\Users\Admin\AppData\Roaming\FAHClient
11:27:26: OS: Windows 10 Home
11:27:26: OS Arch: AMD64
11:27:26: GPUs: 2
11:27:26: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 [xxx]
11:27:26: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Ti Max-Q]
11:27:26: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
11:27:26:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
11:27:26:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
11:27:26: Win32 Service: false
11:27:26:******************************* libFAH ********************************
11:27:26: Date: Apr 15 2020
11:27:26: Time: 14:53:14
11:27:26: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:27:26: Bits: 32
11:27:26:***********************************************************************
11:27:26:<config>
11:27:26: <!-- Folding Core -->
11:27:26: <core-priority v='low'/>
11:27:26:
11:27:26: <!-- Folding Slot Configuration -->
11:27:26: <cause v='COVID_19'/>
11:27:26:
11:27:26: <!-- Network -->
11:27:26: <proxy v=':8080'/>
11:27:26:
11:27:26: <!-- Slot Control -->
11:27:26: <power v='MEDIUM'/>
11:27:26:
11:27:26: <!-- User Information -->
11:27:26: <passkey v='*****'/>
11:27:26: <team v='251999'/>
11:27:26: <user v='TheProgrammer7'/>
11:27:26:
11:27:26: <!-- Folding Slots -->
11:27:26: <slot id='0' type='CPU'/>
11:27:26: <slot id='1' type='GPU'/>
11:27:26:</config>
11:27:26:Trying to access database...
11:27:26:Successfully acquired database lock
11:27:26:Enabled folding slot 00: READY cpu:10
11:27:26:Enabled folding slot 01: READY gpu:0:[xxx]
11:27:27:WU00:FS00:Connecting to 65.254.110.245:80
11:27:27:WU01:FS01:Connecting to 65.254.110.245:80
11:27:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:28:WU01:FS01:Connecting to 18.218.241.186:80
11:27:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:28:WU00:FS00:Connecting to 18.218.241.186:80
11:27:29:WU01:FS01:Assigned to work server 40.114.52.201
11:27:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[xxx] from 40.114.52.201
11:27:29:WU01:FS01:Connecting to 40.114.52.201:8080
11:27:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:27:29:WU00:FS00:Connecting to 65.254.110.245:80
11:27:30:WU01:FS01:Downloading 2.14MiB
11:27:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:30:WU00:FS00:Connecting to 18.218.241.186:80
11:27:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:27:31:ERROR:WU00:FS00:Exception: Could not get an assignment
11:27:31:WU00:FS00:Connecting to 65.254.110.245:80
11:27:32:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:32:WU00:FS00:Connecting to 18.218.241.186:80
11:27:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:27:33:WU00:FS00:Connecting to 65.254.110.245:80
11:27:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:33:WU00:FS00:Connecting to 18.218.241.186:80
11:27:34:WU00:FS00:Assigned to work server 128.252.203.2
11:27:34:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 128.252.203.2
11:27:34:WU00:FS00:Connecting to 128.252.203.2:8080
11:27:36:WU01:FS01:Download 29.18%
11:27:42:WU01:FS01:Download 55.44%
11:27:48:WU01:FS01:Download 81.70%
11:27:55:WU01:FS01:Download 96.28%
11:27:55:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:28:00:WU01:FS01:Download complete
11:28:00:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:38694 gen:62 core:0xa7 unit:0x0000004e287234c95e787a95fb3b45cf
11:28:00:WU01:FS01:Starting
11:28:00:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 14764 -checkpoint 15 -gpu-vendor intel -opencl-platform 1 -opencl-device 0 -gpu 0
11:28:01:WU01:FS01:Started FahCore on PID 7952
11:28:02:WU01:FS01:Core PID:2480
11:28:02:WU01:FS01:FahCore 0xa7 started
11:28:02:WU01:FS01:0xa7:*********************** Log Started 2020-04-27T11:28:02Z ***********************
11:28:02:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
11:28:02:WU01:FS01:0xa7: Type: 0xa7
11:28:02:WU01:FS01:0xa7: Core: Gromacs
11:28:02:WU01:FS01:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 7952 -checkpoint 15
11:28:02:WU01:FS01:0xa7: -gpu-vendor intel -opencl-platform 1 -opencl-device 0 -gpu 0
11:28:02:WU01:FS01:0xa7:************************************ CBang *************************************
11:28:02:WU01:FS01:0xa7: Date: Oct 26 2019
11:28:02:WU01:FS01:0xa7: Time: 01:38:25
11:28:02:WU01:FS01:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:28:02:WU01:FS01:0xa7: Branch: master
11:28:02:WU01:FS01:0xa7: Compiler: Visual C++ 2008
11:28:02:WU01:FS01:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:28:02:WU01:FS01:0xa7: Platform: win32 10
11:28:02:WU01:FS01:0xa7: Bits: 64
11:28:02:WU01:FS01:0xa7: Mode: Release
11:28:02:WU01:FS01:0xa7:************************************ System ************************************
11:28:03:WU01:FS01:0xa7: CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
11:28:03:WU01:FS01:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:28:03:WU01:FS01:0xa7: CPUs: 12
11:28:03:WU01:FS01:0xa7: Memory: 7.85GiB
11:28:03:WU01:FS01:0xa7:Free Memory: 2.79GiB
11:28:03:WU01:FS01:0xa7: Threads: WINDOWS_THREADS
11:28:03:WU01:FS01:0xa7: OS Version: 6.2
11:28:03:WU01:FS01:0xa7:Has Battery: true
11:28:03:WU01:FS01:0xa7: On Battery: false
11:28:03:WU01:FS01:0xa7: UTC Offset: 8
11:28:03:WU01:FS01:0xa7: PID: 2480
11:28:03:WU01:FS01:0xa7: CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
11:28:03:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
11:28:03:WU01:FS01:0xa7: Version: 0.0.18
11:28:03:WU01:FS01:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:28:03:WU01:FS01:0xa7: Copyright: 2019 foldingathome.org
11:28:03:WU01:FS01:0xa7: Homepage: https://foldingathome.org/
11:28:03:WU01:FS01:0xa7: Date: Oct 26 2019
11:28:03:WU01:FS01:0xa7: Time: 01:52:30
11:28:03:WU01:FS01:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:28:03:WU01:FS01:0xa7: Branch: master
11:28:03:WU01:FS01:0xa7: Compiler: Visual C++ 2008
11:28:03:WU01:FS01:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:28:03:WU01:FS01:0xa7: Platform: win32 10
11:28:03:WU01:FS01:0xa7: Bits: 64
11:28:03:WU01:FS01:0xa7: Mode: Release
11:28:03:WU01:FS01:0xa7:************************************ Build *************************************
11:28:03:WU01:FS01:0xa7: SIMD: avx_256
11:28:03:WU01:FS01:0xa7:********************************************************************************
11:28:03:WU01:FS01:0xa7:Project: 13851 (Run 0, Clone 38694, Gen 62)
11:28:03:WU01:FS01:0xa7:Unit: 0x0000004e287234c95e787a95fb3b45cf
11:28:03:WU01:FS01:0xa7:Reading tar file core.xml
11:28:03:WU01:FS01:0xa7:Reading tar file frame62.tpr
11:28:03:WU01:FS01:0xa7:Digital signatures verified
11:28:03:WU01:FS01:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -x frame62.xtc -e frame62.edr -cpt 15 -nt 1
11:28:03:WU01:FS01:0xa7:Steps: first=31000000 total=500000
11:28:03:WU01:FS01:0xa7:Completed 1 out of 500000 steps (0%)
11:28:31:WU00:FS00:Connecting to 65.254.110.245:80
11:28:32:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:32:WU00:FS00:Connecting to 18.218.241.186:80
11:28:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:33:WU00:FS00:Connecting to 65.254.110.245:80
11:28:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:33:WU00:FS00:Connecting to 18.218.241.186:80
11:28:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:34:ERROR:WU00:FS00:Exception: Could not get an assignment
11:30:08:WU00:FS00:Connecting to 65.254.110.245:80
11:30:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:30:09:WU00:FS00:Connecting to 18.218.241.186:80
11:30:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:30:10:WU00:FS00:Connecting to 65.254.110.245:80
11:30:11:WU00:FS00:Assigned to work server 150.136.14.110
11:30:11:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 150.136.14.110
11:30:11:WU00:FS00:Connecting to 150.136.14.110:8080
11:30:11:WU00:FS00:Downloading 2.34MiB
11:30:17:WU00:FS00:Download 34.72%
11:30:23:WU00:FS00:Download 80.12%
11:30:27:WU00:FS00:Download complete
11:30:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16416 run:0 clone:248 gen:100 core:0xa7 unit:0x0000007196880e6e5e8255e2a977a58b
11:30:27:WU00:FS00:Starting
11:30:27:WARNING:WU00:FS00:AS lowered CPUs from 10 to 9
11:30:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 14764 -checkpoint 15 -np 9
11:30:27:WU00:FS00:Started FahCore on PID 4428
11:30:28:WU00:FS00:Core PID:4300
11:30:28:WU00:FS00:FahCore 0xa7 started
11:30:29:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T11:30:28Z ***********************
11:30:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:30:29:WU00:FS00:0xa7: Type: 0xa7
11:30:29:WU00:FS00:0xa7: Core: Gromacs
11:30:29:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 4428 -checkpoint 15 -np 9
11:30:29:WU00:FS00:0xa7:************************************ CBang *************************************
11:30:29:WU00:FS00:0xa7: Date: Oct 26 2019
11:30:29:WU00:FS00:0xa7: Time: 01:38:25
11:30:29:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:30:29:WU00:FS00:0xa7: Branch: master
11:30:29:WU00:FS00:0xa7: Compiler: Visual C++ 2008
11:30:29:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:30:29:WU00:FS00:0xa7: Platform: win32 10
11:30:29:WU00:FS00:0xa7: Bits: 64
11:30:29:WU00:FS00:0xa7: Mode: Release
11:30:29:WU00:FS00:0xa7:************************************ System ************************************
11:30:29:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
11:30:29:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:30:29:WU00:FS00:0xa7: CPUs: 12
11:30:29:WU00:FS00:0xa7: Memory: 7.85GiB
11:30:29:WU00:FS00:0xa7:Free Memory: 1.79GiB
11:30:29:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
11:30:29:WU00:FS00:0xa7: OS Version: 6.2
11:30:29:WU00:FS00:0xa7:Has Battery: true
11:30:29:WU00:FS00:0xa7: On Battery: false
11:30:29:WU00:FS00:0xa7: UTC Offset: 8
11:30:29:WU00:FS00:0xa7: PID: 4300
11:30:29:WU00:FS00:0xa7: CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
11:30:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:30:29:WU00:FS00:0xa7: Version: 0.0.18
11:30:29:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:30:29:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:30:29:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:30:29:WU00:FS00:0xa7: Time: 01:52:30
11:30:29:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:30:29:WU00:FS00:0xa7:************************************ Build *************************************
11:30:29:WU00:FS00:0xa7: SIMD: avx_256
11:30:29:WU00:FS00:0xa7:********************************************************************************
11:30:29:WU00:FS00:0xa7:Project: 16416 (Run 0, Clone 248, Gen 100)
11:30:29:WU00:FS00:0xa7:Unit: 0x0000007196880e6e5e8255e2a977a58b
11:30:29:WU00:FS00:0xa7:Reading tar file core.xml
11:30:29:WU00:FS00:0xa7:Reading tar file frame100.tpr
11:30:29:WU00:FS00:0xa7:Digital signatures verified
11:30:29:WU00:FS00:0xa7:Calling: mdrun -s frame100.tpr -o frame100.trr -x frame100.xtc -cpt 15 -nt 9
11:30:29:WU00:FS00:0xa7:Steps: first=25000000 total=250000
11:30:33:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
11:32:25:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
11:34:05:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
11:36:13:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
11:38:02:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
11:39:45:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11:41:23:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
11:43:03:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
11:44:42:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
11:46:21:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
11:47:04:WU01:FS01:0xa7:Completed 5000 out of 500000 steps (1%)
11:48:02:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
11:49:42:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
11:51:20:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
11:53:07:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
11:54:55:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
11:56:32:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
11:58:16:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
11:59:58:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
12:01:38:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
12:03:19:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
12:04:57:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
12:06:35:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
12:08:18:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
12:09:40:WU01:FS01:0xa7:Completed 10000 out of 500000 steps (2%)
12:09:56:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
12:11:31:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
12:13:03:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
12:14:36:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
12:16:29:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
12:18:18:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
12:20:01:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
12:21:30:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
12:23:17:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
12:24:51:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
12:26:52:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
12:28:59:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
12:30:54:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
12:32:21:WU01:FS01:0xa7:Completed 15000 out of 500000 steps (3%)
12:32:36:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
12:34:31:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
12:36:30:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
12:38:23:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
12:40:02:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
12:41:48:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
12:43:26:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
12:45:04:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
12:46:43:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
12:48:19:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
******************************* Date: 2020-04-29 *******************************
08:50:15:WU01:FS01:Starting
08:50:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 14764 -checkpoint 15 -gpu-vendor intel -opencl-platform 1 -opencl-device 0 -cuda-device 1 -gpu 0
08:50:15:WU01:FS01:Started FahCore on PID 18168
08:50:16:WU01:FS01:Core PID:24908
08:50:16:WU01:FS01:FahCore 0xa7 started
08:50:17:WU01:FS01:0xa7:*********************** Log Started 2020-04-29T08:50:16Z ***********************
08:50:17:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
08:50:17:WU01:FS01:0xa7: Type: 0xa7
08:50:17:WU01:FS01:0xa7: Core: Gromacs
08:50:17:WU01:FS01:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 18168 -checkpoint 15
08:50:17:WU01:FS01:0xa7: -gpu-vendor intel -opencl-platform 1 -opencl-device 0 -cuda-device
08:50:17:WU01:FS01:0xa7: 1 -gpu 0
08:50:17:WU01:FS01:0xa7:************************************ CBang *************************************
08:50:17:WU01:FS01:0xa7: Date: Oct 26 2019
08:50:17:WU01:FS01:0xa7: Time: 01:38:25
08:50:17:WU01:FS01:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:50:17:WU01:FS01:0xa7: Branch: master
08:50:17:WU01:FS01:0xa7: Compiler: Visual C++ 2008
08:50:17:WU01:FS01:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:50:17:WU01:FS01:0xa7: Platform: win32 10
08:50:17:WU01:FS01:0xa7: Bits: 64
08:50:17:WU01:FS01:0xa7: Mode: Release
08:50:17:WU01:FS01:0xa7:************************************ System ************************************
08:50:17:WU01:FS01:0xa7: CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
08:50:17:WU01:FS01:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
08:50:17:WU01:FS01:0xa7: CPUs: 12
08:50:17:WU01:FS01:0xa7: Memory: 7.85GiB
08:50:17:WU01:FS01:0xa7:Free Memory: 852.20MiB
08:50:17:WU01:FS01:0xa7: Threads: WINDOWS_THREADS
08:50:17:WU01:FS01:0xa7: OS Version: 6.2
08:50:17:WU01:FS01:0xa7:Has Battery: true
08:50:17:WU01:FS01:0xa7: On Battery: false
08:50:17:WU01:FS01:0xa7: UTC Offset: 8
08:50:17:WU01:FS01:0xa7: PID: 24908
08:50:17:WU01:FS01:0xa7: CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
08:50:17:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
08:50:17:WU01:FS01:0xa7: Version: 0.0.18
08:50:17:WU01:FS01:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:50:17:WU01:FS01:0xa7: Copyright: 2019 foldingathome.org
08:50:17:WU01:FS01:0xa7: Homepage: https://foldingathome.org/
08:50:17:WU01:FS01:0xa7: Time: 01:52:30
08:50:17:WU01:FS01:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:50:17:WU01:FS01:0xa7:************************************ Build *************************************
08:50:17:WU01:FS01:0xa7: SIMD: avx_256
08:50:17:WU01:FS01:0xa7:********************************************************************************
08:50:17:WU01:FS01:0xa7:Project: 13851 (Run 0, Clone 38694, Gen 62)
08:50:17:WU01:FS01:0xa7:Unit: 0x0000004e287234c95e787a95fb3b45cf
08:50:17:WU01:FS01:0xa7:Digital signatures verified
08:50:17:WU01:FS01:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -x frame62.xtc -e frame62.edr -cpi state.cpt -cpt 15 -nt 1
08:50:17:WU01:FS01:0xa7:Steps: first=31000000 total=500000
08:50:17:WU01:FS01:0xa7:Completed 365672 out of 500000 steps (73%)
