Just noticed one of my first work units that failed to send. Thought I would report it here. Is there any other info I should provide to be helpful in this case (and future cases)?
******************************* Date: 2020-04-28 *******************************
08:33:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:33:28:WARNING:WU00:FS00:Server did not like results, dumping
23:14:41:WU01:FS00:Connecting to 40.121.152.108:8080
23:14:41:WU00:FS00:Starting
23:14:41:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jason\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 8480 -checkpoint 30 -np 8
23:14:41:WU00:FS00:Started FahCore on PID 17928
23:14:41:WU00:FS00:Core PID:2424
23:14:41:WU00:FS00:FahCore 0xa7 started
23:14:42:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T23:14:41Z ***********************
23:14:42:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:14:42:WU00:FS00:0xa7: Type: 0xa7
23:14:42:WU00:FS00:0xa7: Core: Gromacs
23:14:42:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 17928 -checkpoint 30 -np
23:14:42:WU00:FS00:0xa7: 8
23:14:42:WU00:FS00:0xa7:************************************ CBang *************************************
23:14:42:WU00:FS00:0xa7: Date: Oct 26 2019
23:14:42:WU00:FS00:0xa7: Time: 01:38:25
23:14:42:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:14:42:WU00:FS00:0xa7: Branch: master
23:14:42:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:14:42:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:14:42:WU00:FS00:0xa7: Platform: win32 10
23:14:42:WU00:FS00:0xa7: Bits: 64
23:14:42:WU00:FS00:0xa7: Mode: Release
23:14:42:WU00:FS00:0xa7:************************************ System ************************************
23:14:42:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790S CPU @ 3.20GHz
23:14:42:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:14:42:WU00:FS00:0xa7: CPUs: 8
23:14:42:WU00:FS00:0xa7: Memory: 7.89GiB
23:14:42:WU00:FS00:0xa7:Free Memory: 4.94GiB
23:14:42:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:14:42:WU00:FS00:0xa7: OS Version: 6.2
23:14:42:WU00:FS00:0xa7:Has Battery: false
23:14:42:WU00:FS00:0xa7: On Battery: false
23:14:42:WU00:FS00:0xa7: UTC Offset: -6
23:14:42:WU00:FS00:0xa7: PID: 2424
23:14:42:WU00:FS00:0xa7: CWD: C:\Users\Jason\AppData\Roaming\FAHClient\work
23:14:42:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:14:42:WU00:FS00:0xa7: Version: 0.0.18
23:14:42:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:14:42:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:14:42:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:14:42:WU00:FS00:0xa7: Time: 01:52:30
23:14:42:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:14:42:WU00:FS00:0xa7:************************************ Build *************************************
23:14:42:WU00:FS00:0xa7: SIMD: avx_256
23:14:42:WU00:FS00:0xa7:********************************************************************************
23:14:42:WU00:FS00:0xa7:Project: 16413 (Run 1023, Clone 0, Gen 4)
23:14:42:WU00:FS00:0xa7:Unit: 0x0000000403854c135e9a98a1e0fb7588
23:14:42:WU00:FS00:0xa7:Reading tar file core.xml
23:14:42:WU00:FS00:0xa7:Reading tar file frame4.tpr
23:14:42:WU00:FS00:0xa7:Digital signatures verified
23:14:42:WU00:FS00:0xa7:Calling: mdrun -s frame4.tpr -o frame4.trr -x frame4.xtc -cpt 30 -nt 8
23:14:42:WU00:FS00:0xa7:Steps: first=1000000 total=250000
23:14:43:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:14:47:WU01:FS00:Upload 29.03%
23:14:53:WU01:FS00:Upload 84.19%
23:14:54:WU01:FS00:Upload complete
23:14:54:WU01:FS00:Server responded WORK_ACK (400)
23:14:54:WU01:FS00:Final credit estimate, 3914.00 points
23:14:54:WU01:FS00:Cleaning up
23:20:16:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
23:25:49:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
23:31:23:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
23:36:56:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
23:42:30:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
23:48:05:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
23:53:39:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
23:59:12:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
00:04:46:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
00:10:20:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
00:15:55:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
00:21:28:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
00:27:03:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
00:32:36:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
00:38:09:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
00:43:46:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
00:49:21:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
00:54:54:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
01:00:28:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
01:06:02:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
01:11:36:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
01:17:11:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
01:22:45:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
01:28:19:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
01:33:52:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
01:39:26:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
01:45:02:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
01:50:35:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
01:56:09:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
02:01:44:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
02:07:18:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
02:12:52:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
02:18:28:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
02:24:02:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
02:29:36:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
02:35:10:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
02:40:44:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
02:46:19:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
02:51:52:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
02:57:26:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
03:03:00:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
03:08:33:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
03:14:07:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
03:19:42:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
03:25:15:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
03:30:49:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
03:36:22:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
03:41:56:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
03:47:41:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
03:53:19:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
03:58:52:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
04:04:25:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
04:09:59:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
04:15:34:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
04:21:07:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
04:26:41:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
04:32:15:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
04:37:48:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
04:43:22:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
04:48:57:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
04:54:30:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
05:00:03:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
05:05:36:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
05:11:10:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
05:16:44:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
05:22:18:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
05:27:52:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
05:33:25:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
05:38:59:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
05:44:32:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
05:50:07:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
05:55:40:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
06:01:14:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
06:06:47:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
06:12:20:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
06:17:56:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
06:23:29:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
06:29:02:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
06:34:35:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
06:40:09:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
06:45:49:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
06:51:23:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
06:57:01:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
07:02:34:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
07:08:07:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
07:13:40:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
07:19:15:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
07:24:49:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
07:30:22:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
07:35:56:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
07:41:29:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
07:47:04:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
07:52:37:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
07:58:11:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
08:03:44:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
08:09:18:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
08:14:53:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
08:20:26:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:26:00:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:26:00:WU01:FS00:Connecting to 65.254.110.245:80
08:26:00:WU01:FS00:Assigned to work server 128.252.203.4
08:26:00:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 128.252.203.4
08:26:00:WU01:FS00:Connecting to 128.252.203.4:8080
08:26:01:WU01:FS00:Downloading 4.19MiB
08:26:02:WU01:FS00:Download complete
08:26:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14542 run:0 clone:1652 gen:117 core:0xa7 unit:0x0000007780fccb045e7fbf7e7257eb23
08:31:33:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:31:40:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:31:40:WU00:FS00:0xa7:Saving result file frame4.trr
08:31:40:WU00:FS00:0xa7:Saving result file frame4.xtc
08:31:40:WU00:FS00:0xa7:Saving result file md.log
08:31:40:WU00:FS00:0xa7:Saving result file science.log
08:31:40:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:31:40:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:31:40:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16413 run:1023 clone:0 gen:4 core:0xa7 unit:0x0000000403854c135e9a98a1e0fb7588
08:31:40:WU00:FS00:Uploading 6.54MiB to 3.133.76.19
08:31:40:WU01:FS00:Starting
08:31:40:WU00:FS00:Connecting to 3.133.76.19:8080
08:31:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Jason\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 8480 -checkpoint 30 -np 8
08:31:41:WU01:FS00:Started FahCore on PID 17160
08:31:41:WU01:FS00:Core PID:1668
08:31:41:WU01:FS00:FahCore 0xa7 started
08:31:41:WU01:FS00:0xa7:*********************** Log Started 2020-04-28T08:31:41Z ***********************
08:31:41:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:31:41:WU01:FS00:0xa7: Type: 0xa7
08:31:41:WU01:FS00:0xa7: Core: Gromacs
08:31:41:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 17160 -checkpoint 30 -np
08:31:41:WU01:FS00:0xa7: 8
08:31:41:WU01:FS00:0xa7:************************************ CBang *************************************
08:31:41:WU01:FS00:0xa7: Date: Oct 26 2019
08:31:41:WU01:FS00:0xa7: Time: 01:38:25
08:31:41:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:31:41:WU01:FS00:0xa7: Branch: master
08:31:41:WU01:FS00:0xa7: Compiler: Visual C++ 2008
08:31:41:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:31:41:WU01:FS00:0xa7: Platform: win32 10
08:31:41:WU01:FS00:0xa7: Bits: 64
08:31:41:WU01:FS00:0xa7: Mode: Release
08:31:41:WU01:FS00:0xa7:************************************ System ************************************
08:31:41:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790S CPU @ 3.20GHz
08:31:41:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:31:41:WU01:FS00:0xa7: CPUs: 8
08:31:41:WU01:FS00:0xa7: Memory: 7.89GiB
08:31:41:WU01:FS00:0xa7:Free Memory: 4.89GiB
08:31:41:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
08:31:41:WU01:FS00:0xa7: OS Version: 6.2
08:31:41:WU01:FS00:0xa7:Has Battery: false
08:31:41:WU01:FS00:0xa7: On Battery: false
08:31:41:WU01:FS00:0xa7: UTC Offset: -6
08:31:41:WU01:FS00:0xa7: PID: 1668
08:31:41:WU01:FS00:0xa7: CWD: C:\Users\Jason\AppData\Roaming\FAHClient\work
08:31:41:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:31:41:WU01:FS00:0xa7: Version: 0.0.18
08:31:41:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:31:41:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
08:31:41:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
08:31:41:WU01:FS00:0xa7: Time: 01:52:30
08:31:41:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:31:41:WU01:FS00:0xa7:************************************ Build *************************************
08:31:41:WU01:FS00:0xa7: SIMD: avx_256
08:31:41:WU01:FS00:0xa7:********************************************************************************
08:31:41:WU01:FS00:0xa7:Project: 14542 (Run 0, Clone 1652, Gen 117)
08:31:41:WU01:FS00:0xa7:Unit: 0x0000007780fccb045e7fbf7e7257eb23
08:31:41:WU01:FS00:0xa7:Reading tar file core.xml
08:31:41:WU01:FS00:0xa7:Reading tar file frame117.tpr
08:31:41:WU01:FS00:0xa7:Digital signatures verified
08:31:41:WU01:FS00:0xa7:Calling: mdrun -s frame117.tpr -o frame117.trr -x frame117.xtc -cpt 30 -nt 8
08:31:41:WU01:FS00:0xa7:Steps: first=58500000 total=500000
08:31:43:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
08:33:20:WU00:FS00:Upload 1.91%
08:33:20:WU00:FS00:Trying to send results to collection server
08:33:20:WU00:FS00:Uploading 6.54MiB to 3.21.157.11
08:33:20:WU00:FS00:Connecting to 3.21.157.11:8080
08:33:26:WU00:FS00:Upload 72.64%
08:33:28:WU00:FS00:Upload complete
08:33:28:WU00:FS00:Server responded WORK_QUIT (404)
08:33:28:WU00:FS00:Cleaning up
