Hello,
is there any argument for shortcut to set cause to covid 19? --cause=COVID_19 is not working.
Thank you
Arguments to set cause in shortcut
Re: Arguments to set cause in shortcut
Add that line to the config.xml. Why do you need it in a shortcut?
4070 super
And how do you know it is not working when set in webcontrol or fahcontrol?
If you are not getting COVID related work, it means there is none at that given moment. As soon there is more, you will receive it.
New version was released specifically for this new feature, and it was tested to work.
... and all other cause selectors are only a statement of preference anyway … If there are no WUs that match you systems configuration for your preference then the AS/WS will allocate you WU from another cause.
