GeForce RTX 2080 Ti Rev. A1
StevoTVR
Post by StevoTVR »
*********************** Log Started 2020-04-27T21:27:12Z ***********************
21:27:12:****************************** FAHClient ******************************
21:27:12:        Version: 7.6.9
21:27:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:27:12:      Copyright: 2020 foldingathome.org
21:27:12:       Homepage: https://foldingathome.org/
21:27:12:           Date: Apr 17 2020
21:27:12:           Time: 11:13:06
21:27:12:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
21:27:12:         Branch: master
21:27:12:       Compiler: Visual C++ 2008
21:27:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:27:12:       Platform: win32 10
21:27:12:           Bits: 32
21:27:12:           Mode: Release
21:27:12:         Config: C:\Users\Steve\AppData\Roaming\FAHClient\config.xml
21:27:12:******************************** CBang ********************************
21:27:12:           Time: 11:10:09
21:27:12:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
21:27:12:           Bits: 32
21:27:12:******************************* System ********************************
21:27:12:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:27:12:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:27:12:           CPUs: 16
21:27:12:         Memory: 31.92GiB
21:27:12:    Free Memory: 27.92GiB
21:27:12:        Threads: WINDOWS_THREADS
21:27:12:     OS Version: 6.2
21:27:12:    Has Battery: false
21:27:12:     On Battery: false
21:27:12:     UTC Offset: -7
21:27:12:            PID: 15200
21:27:12:            CWD: C:\Users\Steve\AppData\Roaming\FAHClient
21:27:12:             OS: Windows 10 Enterprise
21:27:12:        OS Arch: AMD64
21:27:12:           GPUs: 1
21:27:12:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti] M
21:27:12:                 13448
21:27:12:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
21:27:12:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
21:27:12:  Win32 Service: false
21:27:12:******************************* libFAH ********************************
21:27:12:           Date: Apr 15 2020
21:27:12:           Time: 14:53:14
21:27:12:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:27:12:           Bits: 32
21:27:12:***********************************************************************
21:27:12:<config>
21:27:12:  <!-- Network -->
21:27:12:  <proxy v=':8080'/>
21:27:12:
21:27:12:  <!-- Slot Control -->
21:27:12:  <power v='FULL'/>
21:27:12:
21:27:12:  <!-- User Information -->
21:27:12:  <passkey v='*****'/>
21:27:12:  <team v='248312'/>
21:27:12:  <user v='StevoTVR'/>
21:27:12:
21:27:12:  <!-- Folding Slots -->
21:27:12:  <slot id='0' type='CPU'/>
21:27:12:</config>
21:27:12:Trying to access database...
21:27:12:Successfully acquired database lock
21:27:12:Enabled folding slot 00: READY cpu:16
21:27:12:WU00:FS00:Starting
21:27:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 15200 -checkpoint 15 -np 16
21:27:12:WU00:FS00:Started FahCore on PID 14924
21:27:12:WU00:FS00:Core PID:15152
21:27:12:WU00:FS00:FahCore 0xa7 started
21:27:13:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T21:27:12Z ***********************
21:27:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:27:13:WU00:FS00:0xa7:       Type: 0xa7
21:27:13:WU00:FS00:0xa7:       Core: Gromacs
21:27:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14924 -checkpoint 15 -np
21:27:13:WU00:FS00:0xa7:             16
21:27:13:WU00:FS00:0xa7:************************************ CBang *************************************
21:27:13:WU00:FS00:0xa7:       Date: Oct 26 2019
21:27:13:WU00:FS00:0xa7:       Time: 01:38:25
21:27:13:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:27:13:WU00:FS00:0xa7:     Branch: master
21:27:13:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:27:13:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:27:13:WU00:FS00:0xa7:   Platform: win32 10
21:27:13:WU00:FS00:0xa7:       Bits: 64
21:27:13:WU00:FS00:0xa7:       Mode: Release
21:27:13:WU00:FS00:0xa7:************************************ System ************************************
21:27:13:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:27:13:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:27:13:WU00:FS00:0xa7:       CPUs: 16
21:27:13:WU00:FS00:0xa7:     Memory: 31.92GiB
21:27:13:WU00:FS00:0xa7:Free Memory: 27.71GiB
21:27:13:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:27:13:WU00:FS00:0xa7: OS Version: 6.2
21:27:13:WU00:FS00:0xa7:Has Battery: false
21:27:13:WU00:FS00:0xa7: On Battery: false
21:27:13:WU00:FS00:0xa7: UTC Offset: -7
21:27:13:WU00:FS00:0xa7:        PID: 15152
21:27:13:WU00:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
21:27:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:27:13:WU00:FS00:0xa7:    Version: 0.0.18
21:27:13:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:27:13:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:27:13:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:27:13:WU00:FS00:0xa7:       Time: 01:52:30
21:27:13:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:27:13:WU00:FS00:0xa7:************************************ Build *************************************
21:27:13:WU00:FS00:0xa7:       SIMD: avx_256
21:27:13:WU00:FS00:0xa7:********************************************************************************
21:27:13:WU00:FS00:0xa7:Project: 14620 (Run 1830, Clone 0, Gen 40)
21:27:13:WU00:FS00:0xa7:Unit: 0x0000002e9bf7a4d55e876befb1c5ee05
21:27:13:WU00:FS00:0xa7:Digital signatures verified
21:27:13:WU00:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 16
21:27:13:WU00:FS00:0xa7:ERROR:Guru Meditation #cdb90bf091a2cc60.d0306ddbf6d662ed (14081.14498) '00/01/pullx.xvg'
21:27:13:WU00:FS00:0xa7:WARNING:Unexpected exit() call
21:27:13:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
21:27:13:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:27:13:WU00:FS00:0xa7:Saving result file dhdl.xvg
21:27:13:WU00:FS00:0xa7:Saving result file frame40.trr
21:27:13:WU00:FS00:0xa7:Saving result file md.log
21:27:13:WU00:FS00:0xa7:Saving result file pullf.xvg
21:27:13:WU00:FS00:0xa7:ERROR:Guru Meditation #1945be94803beaad.a2e445b7acd3477f (3480.5004) '00/01/pullf.xvg'
21:27:14:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:27:14:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:27:14:WU00:FS00:Starting
21:27:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 15200 -checkpoint 15 -np 16
21:27:14:WU00:FS00:Started FahCore on PID 3960
21:27:14:WU00:FS00:Core PID:16136
21:27:14:WU00:FS00:FahCore 0xa7 started
21:27:15:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T21:27:14Z ***********************
21:27:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:27:15:WU00:FS00:0xa7:       Type: 0xa7
21:27:15:WU00:FS00:0xa7:       Core: Gromacs
21:27:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3960 -checkpoint 15 -np
21:27:15:WU00:FS00:0xa7:             16
21:27:15:WU00:FS00:0xa7:************************************ CBang *************************************
21:27:15:WU00:FS00:0xa7:       Date: Oct 26 2019
21:27:15:WU00:FS00:0xa7:       Time: 01:38:25
21:27:15:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:27:15:WU00:FS00:0xa7:     Branch: master
21:27:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:27:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:27:15:WU00:FS00:0xa7:   Platform: win32 10
21:27:15:WU00:FS00:0xa7:       Bits: 64
21:27:15:WU00:FS00:0xa7:       Mode: Release
21:27:15:WU00:FS00:0xa7:************************************ System ************************************
21:27:15:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:27:15:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:27:15:WU00:FS00:0xa7:       CPUs: 16
21:27:15:WU00:FS00:0xa7:     Memory: 31.92GiB
21:27:15:WU00:FS00:0xa7:Free Memory: 27.35GiB
21:27:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:27:15:WU00:FS00:0xa7: OS Version: 6.2
21:27:15:WU00:FS00:0xa7:Has Battery: false
21:27:15:WU00:FS00:0xa7: On Battery: false
21:27:15:WU00:FS00:0xa7: UTC Offset: -7
21:27:15:WU00:FS00:0xa7:        PID: 16136
21:27:15:WU00:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
21:27:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:27:15:WU00:FS00:0xa7:    Version: 0.0.18
21:27:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:27:15:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:27:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:27:15:WU00:FS00:0xa7:       Time: 01:52:30
21:27:15:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:27:15:WU00:FS00:0xa7:************************************ Build *************************************
21:27:15:WU00:FS00:0xa7:       SIMD: avx_256
21:27:15:WU00:FS00:0xa7:********************************************************************************
21:27:15:WU00:FS00:0xa7:Project: 14620 (Run 1830, Clone 0, Gen 40)
21:27:15:WU00:FS00:0xa7:Unit: 0x0000002e9bf7a4d55e876befb1c5ee05
21:27:15:WU00:FS00:0xa7:Digital signatures verified
21:27:15:WU00:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 16
21:27:15:WU00:FS00:0xa7:ERROR:Guru Meditation #cdb90bf091a2cc60.d0306ddbf6d662ed (14081.14498) '00/01/pullx.xvg'
21:27:15:WU00:FS00:0xa7:WARNING:Unexpected exit() call
21:27:15:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
21:27:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:27:15:WU00:FS00:0xa7:Saving result file dhdl.xvg
21:27:15:WU00:FS00:0xa7:Saving result file frame40.trr
21:27:15:WU00:FS00:0xa7:Saving result file md.log
21:27:15:WU00:FS00:0xa7:Saving result file pullf.xvg
21:27:15:WU00:FS00:0xa7:ERROR:Guru Meditation #1945be94803beaad.a2e445b7acd3477f (3480.5004) '00/01/pullf.xvg'
21:27:16:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:27:16:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:27:37:3:127.0.0.1:New Web session
21:28:14:WU00:FS00:Starting
21:28:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 15200 -checkpoint 15 -np 16
21:28:14:WU00:FS00:Started FahCore on PID 19136
21:28:14:WU00:FS00:Core PID:5248
21:28:14:WU00:FS00:FahCore 0xa7 started
21:28:15:WU00:FS00:0xa7:*********************** Log Started 2020-04-27T21:28:14Z ***********************
21:28:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:28:15:WU00:FS00:0xa7:       Type: 0xa7
21:28:15:WU00:FS00:0xa7:       Core: Gromacs
21:28:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 19136 -checkpoint 15 -np
21:28:15:WU00:FS00:0xa7:             16
21:28:15:WU00:FS00:0xa7:************************************ CBang *************************************
21:28:15:WU00:FS00:0xa7:       Date: Oct 26 2019
21:28:15:WU00:FS00:0xa7:       Time: 01:38:25
21:28:15:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:28:15:WU00:FS00:0xa7:     Branch: master
21:28:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
21:28:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:28:15:WU00:FS00:0xa7:   Platform: win32 10
21:28:15:WU00:FS00:0xa7:       Bits: 64
21:28:15:WU00:FS00:0xa7:       Mode: Release
21:28:15:WU00:FS00:0xa7:************************************ System ************************************
21:28:15:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:28:15:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:28:15:WU00:FS00:0xa7:       CPUs: 16
21:28:15:WU00:FS00:0xa7:     Memory: 31.92GiB
21:28:15:WU00:FS00:0xa7:Free Memory: 26.42GiB
21:28:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
21:28:15:WU00:FS00:0xa7: OS Version: 6.2
21:28:15:WU00:FS00:0xa7:Has Battery: false
21:28:15:WU00:FS00:0xa7: On Battery: false
21:28:15:WU00:FS00:0xa7: UTC Offset: -7
21:28:15:WU00:FS00:0xa7:        PID: 5248
21:28:15:WU00:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
21:28:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
21:28:15:WU00:FS00:0xa7:    Version: 0.0.18
21:28:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:28:15:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:28:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
21:28:15:WU00:FS00:0xa7:       Time: 01:52:30
21:28:15:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:28:15:WU00:FS00:0xa7:************************************ Build *************************************
21:28:15:WU00:FS00:0xa7:       SIMD: avx_256
21:28:15:WU00:FS00:0xa7:********************************************************************************
21:28:15:WU00:FS00:0xa7:Project: 14620 (Run 1830, Clone 0, Gen 40)
21:28:15:WU00:FS00:0xa7:Unit: 0x0000002e9bf7a4d55e876befb1c5ee05
21:28:15:WU00:FS00:0xa7:Digital signatures verified
21:28:15:WU00:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpi state.cpt -cpt 15 -nt 16
21:28:15:WU00:FS00:0xa7:ERROR:Guru Meditation #cdb90bf091a2cc60.d0306ddbf6d662ed (14081.14498) '00/01/pullx.xvg'
21:28:15:WU00:FS00:0xa7:WARNING:Unexpected exit() call
21:28:15:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
21:28:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:28:15:WU00:FS00:0xa7:Saving result file dhdl.xvg
21:28:15:WU00:FS00:0xa7:Saving result file frame40.trr
21:28:15:WU00:FS00:0xa7:Saving result file md.log
21:28:15:WU00:FS00:0xa7:Saving result file pullf.xvg
21:28:15:WU00:FS00:0xa7:ERROR:Guru Meditation #1945be94803beaad.a2e445b7acd3477f (3480.5004) '00/01/pullf.xvg'
21:28:16:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:28:16:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
21:28:16:WARNING:WU00:FS00:Too many errors, failing
21:28:16:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14620 run:1830 clone:0 gen:40 core:0xa7 unit:0x0000002e9bf7a4d55e876befb1c5ee05
21:28:16:WU00:FS00:Uploading 2.83MiB to 155.247.164.213
21:28:16:WU00:FS00:Connecting to 155.247.164.213:8080
21:28:16:WU01:FS00:Connecting to 65.254.110.245:80
21:28:16:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:28:16:WU01:FS00:Connecting to 18.218.241.186:80
21:28:17:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:28:17:WU01:FS00:Connecting to 65.254.110.245:80
21:28:17:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:28:17:WU01:FS00:Connecting to 18.218.241.186:80
21:28:17:ERROR:WU01:FS00:Exception: Could not get an assignment
21:28:18:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:28:18:WU01:FS00:Connecting to 18.218.241.186:80
21:28:18:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:28:18:WU01:FS00:Connecting to 65.254.110.245:80
21:28:18:ERROR:WU01:FS00:Exception: Could not get an assignment
21:28:20:WU00:FS00:Upload complete
21:28:20:WU00:FS00:Server responded WORK_QUIT (404)
21:28:20:WARNING:WU00:FS00:Server did not like results, dumping
21:28:20:WU00:FS00:Cleaning up
21:29:17:WU01:FS00:Connecting to 65.254.110.245:80
21:29:17:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:29:17:WU01:FS00:Connecting to 18.218.241.186:80
21:29:18:WU01:FS00:Assigned to work server 150.136.14.110
21:29:18:WU01:FS00:Requesting new work unit for slot 00: READY cpu:16 from 150.136.14.110
21:29:18:WU01:FS00:Connecting to 150.136.14.110:8080
21:29:18:WU01:FS00:Downloading 3.27MiB
21:29:19:WU01:FS00:Download complete
21:29:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16418 run:0 clone:727 gen:114 core:0xa7 unit:0x0000007e96880e6e5e8255b2241e3b8a
21:29:19:WU01:FS00:Starting
21:29:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Steve\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 15200 -checkpoint 15 -np 16
21:29:19:WU01:FS00:Started FahCore on PID 18076
21:29:19:WU01:FS00:Core PID:18332
21:29:19:WU01:FS00:FahCore 0xa7 started
21:29:20:WU01:FS00:0xa7:*********************** Log Started 2020-04-27T21:29:19Z ***********************
21:29:20:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:29:20:WU01:FS00:0xa7:       Type: 0xa7
21:29:20:WU01:FS00:0xa7:       Core: Gromacs
21:29:20:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 18076 -checkpoint 15 -np
21:29:20:WU01:FS00:0xa7:             16
21:29:20:WU01:FS00:0xa7:************************************ CBang *************************************
21:29:20:WU01:FS00:0xa7:       Date: Oct 26 2019
21:29:20:WU01:FS00:0xa7:       Time: 01:38:25
21:29:20:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:29:20:WU01:FS00:0xa7:     Branch: master
21:29:20:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:29:20:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:29:20:WU01:FS00:0xa7:   Platform: win32 10
21:29:20:WU01:FS00:0xa7:       Bits: 64
21:29:20:WU01:FS00:0xa7:       Mode: Release
21:29:20:WU01:FS00:0xa7:************************************ System ************************************
21:29:20:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
21:29:20:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:29:20:WU01:FS00:0xa7:       CPUs: 16
21:29:20:WU01:FS00:0xa7:     Memory: 31.92GiB
21:29:20:WU01:FS00:0xa7:Free Memory: 26.48GiB
21:29:20:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:29:20:WU01:FS00:0xa7: OS Version: 6.2
21:29:20:WU01:FS00:0xa7:Has Battery: false
21:29:20:WU01:FS00:0xa7: On Battery: false
21:29:20:WU01:FS00:0xa7: UTC Offset: -7
21:29:20:WU01:FS00:0xa7:        PID: 18332
21:29:20:WU01:FS00:0xa7:        CWD: C:\Users\Steve\AppData\Roaming\FAHClient\work
21:29:20:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:29:20:WU01:FS00:0xa7:    Version: 0.0.18
21:29:20:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:29:20:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:29:20:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:29:20:WU01:FS00:0xa7:       Time: 01:52:30
21:29:20:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:29:20:WU01:FS00:0xa7:************************************ Build *************************************
21:29:20:WU01:FS00:0xa7:       SIMD: avx_256
21:29:20:WU01:FS00:0xa7:********************************************************************************
21:29:20:WU01:FS00:0xa7:Project: 16418 (Run 0, Clone 727, Gen 114)
21:29:20:WU01:FS00:0xa7:Unit: 0x0000007e96880e6e5e8255b2241e3b8a
21:29:20:WU01:FS00:0xa7:Reading tar file core.xml
21:29:20:WU01:FS00:0xa7:Reading tar file frame114.tpr
21:29:20:WU01:FS00:0xa7:Digital signatures verified
21:29:20:WU01:FS00:0xa7:Calling: mdrun -s frame114.tpr -o frame114.trr -x frame114.xtc -cpt 15 -nt 16
21:29:20:WU01:FS00:0xa7:Steps: first=28500000 total=250000
21:29:20:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:30:01:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:30:36:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:31:12:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
21:31:48:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
21:32:29:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
21:33:07:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
21:33:47:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
21:34:27:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
21:35:08:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
21:35:47:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
21:36:27:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
21:37:07:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
21:37:47:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
21:38:28:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
HaloJones
Re: GeForce RTX 2080 Ti Rev. A1
Post by HaloJones »
(stolen from a post on another identical topic)
Version 7.6.9 has a bug where it doesn't download the GPUs.txt file and set up a GPU slot. Check in this directory to see if there is a GPUs.txt file - CWD: C:\Users\Steve\AppData\Roaming\FAHClient. If one is not there, you can download a copy from here - https://apps.foldingathome.org/GPUs.txt, and place it in that directory. Then restart the client. You will probably need to add the GPU slot manually.
There is also a beta version out for testing that is supposed to fix the bug - https://foldingathome.org/beta/ - if you want to try that out.
single 1070
HaloJones
Post by HaloJones »
To add the slot manually, click on the Folding@Home icon in your task bar (bottom right). Select Advanced Control. Select Configure. Select Slots. Select Add. Click to select GPU. Click Save.
single 1070
StevoTVR
Post by StevoTVR »
I tried all that before posting and it didn't work. I just tried again and now it appears to be working. I don't know what I did different. Thanks for the help!
HaloJones
Post by HaloJones »
That's what always happens whenever anyone gets support involved. Then support sits there looking smug :D
single 1070
audriusa
Hardware configuration: RTX 2080 Ti under Ubuntu 18.
Post by audriusa »
GeForce RTX 2080 Ti is exactly my card, and it works with FAH without any issues under Ubuntu Linux 18.0 with latest drivers. Please check the following:
1. Are all three power connectors connected? The card did not work at all for me with only two connected.
2. Is it a PCI-E x16 slot? It was hanging all operating system for some reason while in the x8 slot.
3. Is the driver up to the newest version? I am using the version 440.
4. Finally, are you using the latest version of the FAH client? Download it from the front page. Linux installation manual contains links to the older version.
The card works also under Windows 7 fine in general but I am not using Windows 7 boot much and do not have FAH installed there.
