Remote web control no information about status -just loading
sazecis
Post by sazecis »
Hi,
I have just installed the latest version f@h client (7.6.9) on a linux machine.
This is a remote machine and I used to check the folding status via remote web control.
Now this solution was working with the version which I was using until now (7.4.4), but now with the latest version I cannot see the important information. This means that the page itself is loaded just, the progress indicator, points, name etc are not shown, just a "Loading..." string is present instead of them.
Was there any change which could provoke this behavior? Do I need to change something in my configuration?
You can find a screenshot about the page, here: https://drive.google.com/file/d/17XljsQ ... sp=sharing
Thanks in advance for your help.
Re: Remote web control no information about status -just loa
You may need to check the network settings for the new version, there have been some reports of it not inheriting all settings from an older install. The web server also needs to be enabled in the client to connect to more than just the local IP. If you used a password, that may also need to be reentered.
sazecis
Post by sazecis »
I used the same config file as for my earlier install. The config file contains the necessary setting to allow remote web access and as I wrote, the page is shown, just not all content appears.
