Web Control only showing stats for 1 GPU
clhardingjr
I'm currently using 7.6.9 running exclusively 2 x NVidia GTX 1070 FE GPUs on a Win 10 Pro (x64) system. Why is the Web control only showing the stats for only one GPU slot when both are running WUs? Even when only one GPU is running a WU it does not always show stats. I realize I can always use the advanced control, but there are some of us that use the Web Control as a quick glance as to what is running.
Re: Web Control only showing stats for 1 GPU
Web Control has each slot as a tab. So to see what the second GPU is doing you need to select that tab.
