Mac Client - No WUs available for this configuration
PaulMpls
Post by PaulMpls »
I installed the FAH client about a week ago on a Windows 10 machine and a macOS 10.15.4 machine and its working fine on the Windows 10 machine, but has yet to process any work on the Mac due to the "No WUs available for this configuration" errors. I do not see this error on my Windows client as it has processed 40+ work units. So is there a configuration/installation setup issue with the Mac client that I can correct? The word 'configuration' in the error leads me to believe it is something to do with how the client is configured on the Mac.
Thanks.
Here is the log:
*********************** Log Started 2020-04-18T12:54:04Z ***********************
13:18:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
13:18:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:47:38:WARNING:WU00:FS00:Detected clock skew (30 mins 02 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
14:47:39:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
15:28:49:WARNING:WU00:FS00:Detected clock skew (40 mins 19 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
15:28:50:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
15:28:50:WU00:FS00:0xa7:ERROR:Guru Meditation #5bab89650504734c.87fa3d20d902d11e (54332.68016) '00/01/frame32.xtc'
15:28:50:WU00:FS00:0xa7:WARNING:Unexpected exit() call
15:28:50:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
15:28:51:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
15:28:51:WARNING:WU00:FS00:Fatal error, dumping
15:29:28:ERROR:WU01:FS00:Exception: Server did not assign work unit
15:36:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
15:36:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:36:06:ERROR:WU01:FS00:Exception: Server did not assign work unit
16:00:02:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:00:02:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:00:04:ERROR:WU01:FS00:Exception: Server did not assign work unit
16:14:50:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:14:50:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:14:51:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:14:51:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:14:51:ERROR:WU01:FS00:Exception: Could not get an assignment
16:17:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
16:17:27:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
******************************* Date: 2020-04-19 *******************************
******************************* Date: 2020-04-20 *******************************
******************************* Date: 2020-04-27 *******************************
Re: Mac Client - No WUs available for this configuration
Post by Neil-B »
Could you post the top 100 lines or so of the log that include the system configuration information please
Actually you did have a WU processing at some point, the messages about clock skew and WU_STALLED point to that. Eventually there were too many errors and the WU was dumped. But it looks like you have turned on one of the filters, what the WU was and what else happened is missing.
As mentioned, could you post the beginning 100 or so lines of the log that show the system info and configuration. From within the FAHControl log window you will need to click on Refresh to reload from the beginning.
PaulMpls
Post by PaulMpls »
The FAHControl log viewer doesn't display those lines, but was able to find the file using Finder. Here is the contents of the log file, not just what the FAHControl displays:
12:54:04:****************************** FAHClient ******************************
12:54:04:    Version: 7.6.9
12:54:04:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:54:04:  Copyright: 2020 foldingathome.org
12:54:04:   Homepage: https://foldingathome.org/
12:54:04:       Date: Apr 17 2020
12:54:04:       Time: 11:11:45
12:54:04:   Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:54:04:     Branch: master
12:54:04:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
12:54:04:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
12:54:04:             -Wno-unused-local-typedefs -stdlib=libc++
12:54:04:   Platform: darwin 19.2.0
12:54:04:       Bits: 64
12:54:04:       Mode: Release
12:54:04:     Config: /Library/Application Support/FAHClient/config.xml
12:54:04:******************************** CBang ********************************
12:54:04:       Time: 11:10:06
12:54:04:   Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:54:04:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
12:54:04:       Bits: 64
12:54:04:******************************* System ********************************
12:54:04:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
12:54:04:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
12:54:04:       CPUs: 4
12:54:04:     Memory: 16.00GiB
12:54:04:Free Memory: 4.83GiB
12:54:04:    Threads: POSIX_THREADS
12:54:04: OS Version: 10.15
12:54:04:Has Battery: true
12:54:04: On Battery: false
12:54:04: UTC Offset: -5
12:54:04:        PID: 1799
12:54:04:        CWD: /Library/Application Support/FAHClient
12:54:04:         OS: Darwin 19.4.0 x86_64
12:54:04:    OS Arch: AMD64
12:54:04:       GPUs: 0
12:54:04:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
12:54:04:             dlopen(libcuda.dylib, 1): image not found
12:54:04:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
12:54:04:             dlopen(libOpenCL.dylib, 1): image not found
12:54:04:******************************* libFAH ********************************
12:54:04:       Date: Apr 15 2020
12:54:04:       Time: 14:43:28
12:54:04:   Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:54:04:       Bits: 64
12:54:04:***********************************************************************
12:54:04:<config>
12:54:04:  <!-- User Information -->
12:54:04:  <passkey v='*****'/>
12:54:04:  <team v='240260'/>
12:54:04:  <user v='PaulMpls'/>
12:54:04:
12:54:04:  <!-- Folding Slots -->
12:54:04:  <slot id='0' type='CPU'>
12:54:04:    <idle v='true'/>
12:54:04:  </slot>
12:54:04:</config>
12:54:04:Trying to access database...
12:54:04:Successfully acquired database lock
12:54:04:Enabled folding slot 00: PAUSED cpu:1 (waiting for idle)
12:55:17:9:127.0.0.1:New Web session
12:59:04:Connecting to assign1.foldingathome.org:80
12:59:04:Updated GPUs.txt
13:04:14:Saving configuration to config.xml
13:04:14:<config>
13:04:14:  <!-- Folding Slot Configuration -->
13:04:14:  <cause v='COVID_19'/>
13:04:14:
13:04:14:  <!-- User Information -->
13:04:14:  <passkey v='*****'/>
13:04:14:  <team v='240260'/>
13:04:14:  <user v='PaulMpls'/>
13:04:14:
13:04:14:  <!-- Folding Slots -->
13:04:14:  <slot id='0' type='CPU'>
13:04:14:    <idle v='true'/>
13:04:14:  </slot>
13:04:14:</config>
13:04:29:Caught signal SIGPIPE(13) on PID 1799
13:18:00:WU00:FS00:Connecting to 65.254.110.245:80
[93m13:18:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
13:18:00:WU00:FS00:Connecting to 18.218.241.186:80
[93m13:18:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
13:18:01:WU00:FS00:Assigned to work server 150.136.14.110
13:18:01:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 150.136.14.110
13:18:01:WU00:FS00:Connecting to 150.136.14.110:8080
13:18:01:WU00:FS00:Downloading 2.18MiB
13:18:01:WU00:FS00:Download complete
13:18:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16423 run:3495 clone:0 gen:32 core:0xa7 unit:0x0000002496880e6e5e8a8dc1c86b4d7e
13:18:01:WU00:FS00:Starting
13:18:01:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
13:18:01:WU00:FS00:Started FahCore on PID 2923
13:18:02:WU00:FS00:Core PID:2924
13:18:02:WU00:FS00:FahCore 0xa7 started
13:18:03:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T13:18:02Z ***********************
13:18:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:18:03:WU00:FS00:0xa7:       Type: 0xa7
13:18:03:WU00:FS00:0xa7:       Core: Gromacs
13:18:03:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 2923 -checkpoint 15 -np 1
13:18:03:WU00:FS00:0xa7:************************************ CBang *************************************
13:18:03:WU00:FS00:0xa7:       Date: Oct 26 2019
13:18:03:WU00:FS00:0xa7:       Time: 03:00:53
13:18:03:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
13:18:03:WU00:FS00:0xa7:     Branch: master
13:18:03:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
13:18:03:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
13:18:03:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
13:18:03:WU00:FS00:0xa7:   Platform: darwin 19.0.0
13:18:03:WU00:FS00:0xa7:       Bits: 64
13:18:03:WU00:FS00:0xa7:       Mode: Release
13:18:03:WU00:FS00:0xa7:************************************ System ************************************
13:18:03:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
13:18:03:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
13:18:03:WU00:FS00:0xa7:       CPUs: 4
13:18:03:WU00:FS00:0xa7:     Memory: 16.00GiB
13:18:03:WU00:FS00:0xa7:Free Memory: 4.75GiB
13:18:03:WU00:FS00:0xa7:    Threads: POSIX_THREADS
13:18:03:WU00:FS00:0xa7: OS Version: 10.15
13:18:03:WU00:FS00:0xa7:Has Battery: true
13:18:03:WU00:FS00:0xa7: On Battery: false
13:18:03:WU00:FS00:0xa7: UTC Offset: -5
13:18:03:WU00:FS00:0xa7:        PID: 2924
13:18:03:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
13:18:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:18:03:WU00:FS00:0xa7:    Version: 0.0.18
13:18:03:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:18:03:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:18:03:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:18:03:WU00:FS00:0xa7:       Time: 03:06:33
13:18:03:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
13:18:03:WU00:FS00:0xa7:************************************ Build *************************************
13:18:03:WU00:FS00:0xa7:       SIMD: avx_256
13:18:03:WU00:FS00:0xa7:********************************************************************************
13:18:03:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
13:18:03:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
13:18:03:WU00:FS00:0xa7:Reading tar file core.xml
13:18:03:WU00:FS00:0xa7:Reading tar file frame32.tpr
13:18:03:WU00:FS00:0xa7:Digital signatures verified
13:18:03:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpt 15 -nt 1
13:18:03:WU00:FS00:0xa7:Steps: first=8000000 total=250000
13:18:03:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
13:21:31:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
13:25:04:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
13:28:33:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
13:30:38:FS00:Shutting core down
13:30:38:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 2924
13:30:38:WU00:FS00:0xa7:Exiting, please wait. . .
13:30:41:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
13:30:41:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:53:42:WU00:FS00:Starting
13:53:42:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
13:53:42:WU00:FS00:Started FahCore on PID 3065
13:53:42:WU00:FS00:Core PID:3066
13:53:42:WU00:FS00:FahCore 0xa7 started
13:53:43:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T13:53:42Z ***********************
13:53:43:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:53:43:WU00:FS00:0xa7:       Type: 0xa7
13:53:43:WU00:FS00:0xa7:       Core: Gromacs
13:53:43:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3065 -checkpoint 15 -np 1
13:53:43:WU00:FS00:0xa7:************************************ CBang *************************************
13:53:43:WU00:FS00:0xa7:       Date: Oct 26 2019
13:53:43:WU00:FS00:0xa7:       Time: 03:00:53
13:53:43:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
13:53:43:WU00:FS00:0xa7:     Branch: master
13:53:43:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
13:53:43:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
13:53:43:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
13:53:43:WU00:FS00:0xa7:   Platform: darwin 19.0.0
13:53:43:WU00:FS00:0xa7:       Bits: 64
13:53:43:WU00:FS00:0xa7:       Mode: Release
13:53:43:WU00:FS00:0xa7:************************************ System ************************************
13:53:43:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
13:53:43:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
13:53:43:WU00:FS00:0xa7:       CPUs: 4
13:53:43:WU00:FS00:0xa7:     Memory: 16.00GiB
13:53:43:WU00:FS00:0xa7:Free Memory: 4.69GiB
13:53:43:WU00:FS00:0xa7:    Threads: POSIX_THREADS
13:53:43:WU00:FS00:0xa7: OS Version: 10.15
13:53:43:WU00:FS00:0xa7:Has Battery: true
13:53:43:WU00:FS00:0xa7: On Battery: false
13:53:43:WU00:FS00:0xa7: UTC Offset: -5
13:53:43:WU00:FS00:0xa7:        PID: 3066
13:53:43:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
13:53:43:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:53:43:WU00:FS00:0xa7:    Version: 0.0.18
13:53:43:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:53:43:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:53:43:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:53:43:WU00:FS00:0xa7:       Time: 03:06:33
13:53:43:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
13:53:43:WU00:FS00:0xa7:************************************ Build *************************************
13:53:43:WU00:FS00:0xa7:       SIMD: avx_256
13:53:43:WU00:FS00:0xa7:********************************************************************************
13:53:43:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
13:53:43:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
13:53:43:WU00:FS00:0xa7:Digital signatures verified
13:53:43:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
13:53:43:WU00:FS00:0xa7:Steps: first=8000000 total=250000
13:53:43:WU00:FS00:0xa7:Completed 8962 out of 250000 steps (3%)
13:55:00:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
13:58:32:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
14:00:01:FS00:Shutting core down
14:00:01:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 3066
14:00:01:WU00:FS00:0xa7:Exiting, please wait. . .
14:00:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:00:15:WU00:FS00:Starting
14:00:15:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
14:00:15:WU00:FS00:Started FahCore on PID 3087
14:00:15:WU00:FS00:Core PID:3088
14:00:15:WU00:FS00:FahCore 0xa7 started
14:00:16:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T14:00:15Z ***********************
14:00:16:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:00:16:WU00:FS00:0xa7:       Type: 0xa7
14:00:16:WU00:FS00:0xa7:       Core: Gromacs
14:00:16:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3087 -checkpoint 15 -np 1
14:00:16:WU00:FS00:0xa7:************************************ CBang *************************************
14:00:16:WU00:FS00:0xa7:       Date: Oct 26 2019
14:00:16:WU00:FS00:0xa7:       Time: 03:00:53
14:00:16:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:00:16:WU00:FS00:0xa7:     Branch: master
14:00:16:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:00:16:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:00:16:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:00:16:WU00:FS00:0xa7:   Platform: darwin 19.0.0
14:00:16:WU00:FS00:0xa7:       Bits: 64
14:00:16:WU00:FS00:0xa7:       Mode: Release
14:00:16:WU00:FS00:0xa7:************************************ System ************************************
14:00:16:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
14:00:16:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
14:00:16:WU00:FS00:0xa7:       CPUs: 4
14:00:16:WU00:FS00:0xa7:     Memory: 16.00GiB
14:00:16:WU00:FS00:0xa7:Free Memory: 4.64GiB
14:00:16:WU00:FS00:0xa7:    Threads: POSIX_THREADS
14:00:16:WU00:FS00:0xa7: OS Version: 10.15
14:00:16:WU00:FS00:0xa7:Has Battery: true
14:00:16:WU00:FS00:0xa7: On Battery: false
14:00:16:WU00:FS00:0xa7: UTC Offset: -5
14:00:16:WU00:FS00:0xa7:        PID: 3088
14:00:16:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
14:00:16:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:00:16:WU00:FS00:0xa7:    Version: 0.0.18
14:00:16:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:00:16:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:00:16:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:00:16:WU00:FS00:0xa7:       Time: 03:06:33
14:00:16:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:00:16:WU00:FS00:0xa7:************************************ Build *************************************
14:00:16:WU00:FS00:0xa7:       SIMD: avx_256
14:00:16:WU00:FS00:0xa7:********************************************************************************
14:00:16:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
14:00:16:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
14:00:16:WU00:FS00:0xa7:Digital signatures verified
14:00:16:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
14:00:16:WU00:FS00:0xa7:Steps: first=8000000 total=250000
14:00:16:WU00:FS00:0xa7:Completed 13552 out of 250000 steps (5%)
14:02:14:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
14:03:06:FS00:Shutting core down
14:03:06:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 3088
14:03:06:WU00:FS00:0xa7:Exiting, please wait. . .
14:03:09:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:03:09:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:03:20:WU00:FS00:Starting
14:03:20:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
14:03:20:WU00:FS00:Started FahCore on PID 3099
14:03:20:WU00:FS00:Core PID:3100
14:03:20:WU00:FS00:FahCore 0xa7 started
14:03:20:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T14:03:20Z ***********************
14:03:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:03:20:WU00:FS00:0xa7:       Type: 0xa7
14:03:20:WU00:FS00:0xa7:       Core: Gromacs
14:03:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3099 -checkpoint 15 -np 1
14:03:20:WU00:FS00:0xa7:************************************ CBang *************************************
14:03:20:WU00:FS00:0xa7:       Date: Oct 26 2019
14:03:20:WU00:FS00:0xa7:       Time: 03:00:53
14:03:20:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:03:20:WU00:FS00:0xa7:     Branch: master
14:03:20:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:03:20:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:03:20:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:03:20:WU00:FS00:0xa7:   Platform: darwin 19.0.0
14:03:20:WU00:FS00:0xa7:       Bits: 64
14:03:20:WU00:FS00:0xa7:       Mode: Release
14:03:20:WU00:FS00:0xa7:************************************ System ************************************
14:03:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
14:03:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
14:03:20:WU00:FS00:0xa7:       CPUs: 4
14:03:20:WU00:FS00:0xa7:     Memory: 16.00GiB
14:03:20:WU00:FS00:0xa7:Free Memory: 4.66GiB
14:03:20:WU00:FS00:0xa7:    Threads: POSIX_THREADS
14:03:20:WU00:FS00:0xa7: OS Version: 10.15
14:03:20:WU00:FS00:0xa7:Has Battery: true
14:03:20:WU00:FS00:0xa7: On Battery: false
14:03:20:WU00:FS00:0xa7: UTC Offset: -5
14:03:20:WU00:FS00:0xa7:        PID: 3100
14:03:20:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
14:03:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:03:20:WU00:FS00:0xa7:    Version: 0.0.18
14:03:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:03:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:03:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:03:20:WU00:FS00:0xa7:       Time: 03:06:33
14:03:20:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:03:20:WU00:FS00:0xa7:************************************ Build *************************************
14:03:20:WU00:FS00:0xa7:       SIMD: avx_256
14:03:20:WU00:FS00:0xa7:********************************************************************************
14:03:20:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
14:03:20:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
14:03:20:WU00:FS00:0xa7:Digital signatures verified
14:03:20:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
14:03:20:WU00:FS00:0xa7:Steps: first=8000000 total=250000
14:03:21:WU00:FS00:0xa7:Completed 15632 out of 250000 steps (6%)
14:05:13:FS00:Shutting core down
14:05:13:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 3100
14:05:13:WU00:FS00:0xa7:Exiting, please wait. . .
14:05:15:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:05:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:05:27:WU00:FS00:Starting
14:05:27:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
14:05:27:WU00:FS00:Started FahCore on PID 3101
14:05:27:WU00:FS00:Core PID:3102
14:05:27:WU00:FS00:FahCore 0xa7 started
14:05:27:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T14:05:27Z ***********************
14:05:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:05:27:WU00:FS00:0xa7:       Type: 0xa7
14:05:27:WU00:FS00:0xa7:       Core: Gromacs
14:05:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3101 -checkpoint 15 -np 1
14:05:27:WU00:FS00:0xa7:************************************ CBang *************************************
14:05:27:WU00:FS00:0xa7:       Date: Oct 26 2019
14:05:27:WU00:FS00:0xa7:       Time: 03:00:53
14:05:27:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:05:27:WU00:FS00:0xa7:     Branch: master
14:05:27:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:05:27:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:05:27:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:05:27:WU00:FS00:0xa7:   Platform: darwin 19.0.0
14:05:27:WU00:FS00:0xa7:       Bits: 64
14:05:27:WU00:FS00:0xa7:       Mode: Release
14:05:27:WU00:FS00:0xa7:************************************ System ************************************
14:05:27:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
14:05:27:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
14:05:27:WU00:FS00:0xa7:       CPUs: 4
14:05:27:WU00:FS00:0xa7:     Memory: 16.00GiB
14:05:27:WU00:FS00:0xa7:Free Memory: 4.64GiB
14:05:27:WU00:FS00:0xa7:    Threads: POSIX_THREADS
14:05:27:WU00:FS00:0xa7: OS Version: 10.15
14:05:27:WU00:FS00:0xa7:Has Battery: true
14:05:27:WU00:FS00:0xa7: On Battery: false
14:05:27:WU00:FS00:0xa7: UTC Offset: -5
14:05:27:WU00:FS00:0xa7:        PID: 3102
14:05:27:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
14:05:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:05:27:WU00:FS00:0xa7:    Version: 0.0.18
14:05:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:05:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:05:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:05:27:WU00:FS00:0xa7:       Time: 03:06:33
14:05:27:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:05:27:WU00:FS00:0xa7:************************************ Build *************************************
14:05:27:WU00:FS00:0xa7:       SIMD: avx_256
14:05:27:WU00:FS00:0xa7:********************************************************************************
14:05:27:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
14:05:27:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
14:05:27:WU00:FS00:0xa7:Digital signatures verified
14:05:27:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
14:05:27:WU00:FS00:0xa7:Steps: first=8000000 total=250000
14:05:28:WU00:FS00:0xa7:Completed 17022 out of 250000 steps (6%)
14:06:06:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
14:09:31:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
14:12:59:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
[93m14:47:38:WARNING:WU00:FS00:Detected clock skew (30 mins 02 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates[0m
[93m14:47:39:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)[0m
14:47:39:WU00:FS00:Starting
14:47:39:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
14:47:39:WU00:FS00:Started FahCore on PID 3142
14:47:39:WU00:FS00:Core PID:3146
14:47:39:WU00:FS00:FahCore 0xa7 started
14:47:40:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T14:47:39Z ***********************
14:47:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:47:40:WU00:FS00:0xa7:       Type: 0xa7
14:47:40:WU00:FS00:0xa7:       Core: Gromacs
14:47:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3142 -checkpoint 15 -np 1
14:47:40:WU00:FS00:0xa7:************************************ CBang *************************************
14:47:40:WU00:FS00:0xa7:       Date: Oct 26 2019
14:47:40:WU00:FS00:0xa7:       Time: 03:00:53
14:47:40:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
14:47:40:WU00:FS00:0xa7:     Branch: master
14:47:40:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
14:47:40:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
14:47:40:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
14:47:40:WU00:FS00:0xa7:   Platform: darwin 19.0.0
14:47:40:WU00:FS00:0xa7:       Bits: 64
14:47:40:WU00:FS00:0xa7:       Mode: Release
14:47:40:WU00:FS00:0xa7:************************************ System ************************************
14:47:40:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
14:47:40:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
14:47:40:WU00:FS00:0xa7:       CPUs: 4
14:47:40:WU00:FS00:0xa7:     Memory: 16.00GiB
14:47:40:WU00:FS00:0xa7:Free Memory: 4.72GiB
14:47:40:WU00:FS00:0xa7:    Threads: POSIX_THREADS
14:47:40:WU00:FS00:0xa7: OS Version: 10.15
14:47:40:WU00:FS00:0xa7:Has Battery: true
14:47:40:WU00:FS00:0xa7: On Battery: false
14:47:40:WU00:FS00:0xa7: UTC Offset: -5
14:47:40:WU00:FS00:0xa7:        PID: 3146
14:47:40:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
14:47:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:47:40:WU00:FS00:0xa7:    Version: 0.0.18
14:47:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:47:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:47:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:47:40:WU00:FS00:0xa7:       Time: 03:06:33
14:47:40:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
14:47:40:WU00:FS00:0xa7:************************************ Build *************************************
14:47:40:WU00:FS00:0xa7:       SIMD: avx_256
14:47:40:WU00:FS00:0xa7:********************************************************************************
14:47:40:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
14:47:40:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
14:47:40:WU00:FS00:0xa7:Digital signatures verified
14:47:40:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
14:47:40:WU00:FS00:0xa7:Steps: first=8000000 total=250000
14:47:40:WU00:FS00:0xa7:Completed 17022 out of 250000 steps (6%)
[93m15:28:49:WARNING:WU00:FS00:Detected clock skew (40 mins 19 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates[0m
[93m15:28:50:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)[0m
15:28:50:WU00:FS00:Starting
15:28:50:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 1799 -checkpoint 15 -np 1
15:28:50:WU00:FS00:Started FahCore on PID 3161
15:28:50:WU00:FS00:Core PID:3162
15:28:50:WU00:FS00:FahCore 0xa7 started
15:28:50:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T15:28:50Z ***********************
15:28:50:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:28:50:WU00:FS00:0xa7:       Type: 0xa7
15:28:50:WU00:FS00:0xa7:       Core: Gromacs
15:28:50:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3161 -checkpoint 15 -np 1
15:28:50:WU00:FS00:0xa7:************************************ CBang *************************************
15:28:50:WU00:FS00:0xa7:       Date: Oct 26 2019
15:28:50:WU00:FS00:0xa7:       Time: 03:00:53
15:28:50:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
15:28:50:WU00:FS00:0xa7:     Branch: master
15:28:50:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
15:28:50:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
15:28:50:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
15:28:50:WU00:FS00:0xa7:   Platform: darwin 19.0.0
15:28:50:WU00:FS00:0xa7:       Bits: 64
15:28:50:WU00:FS00:0xa7:       Mode: Release
15:28:50:WU00:FS00:0xa7:************************************ System ************************************
15:28:50:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8210Y CPU @ 1.60GHz
15:28:50:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
15:28:50:WU00:FS00:0xa7:       CPUs: 4
15:28:50:WU00:FS00:0xa7:     Memory: 16.00GiB
15:28:50:WU00:FS00:0xa7:Free Memory: 4.72GiB
15:28:50:WU00:FS00:0xa7:    Threads: POSIX_THREADS
15:28:50:WU00:FS00:0xa7: OS Version: 10.15
15:28:50:WU00:FS00:0xa7:Has Battery: true
15:28:50:WU00:FS00:0xa7: On Battery: false
15:28:50:WU00:FS00:0xa7: UTC Offset: -5
15:28:50:WU00:FS00:0xa7:        PID: 3162
15:28:50:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
15:28:50:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:28:50:WU00:FS00:0xa7:    Version: 0.0.18
15:28:50:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:28:50:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:28:50:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
15:28:50:WU00:FS00:0xa7:       Time: 03:06:33
15:28:50:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
15:28:50:WU00:FS00:0xa7:************************************ Build *************************************
15:28:50:WU00:FS00:0xa7:       SIMD: avx_256
15:28:50:WU00:FS00:0xa7:********************************************************************************
15:28:50:WU00:FS00:0xa7:Project: 16423 (Run 3495, Clone 0, Gen 32)
15:28:50:WU00:FS00:0xa7:Unit: 0x0000002496880e6e5e8a8dc1c86b4d7e
15:28:50:WU00:FS00:0xa7:Digital signatures verified
15:28:50:WU00:FS00:0xa7:Calling: mdrun -s frame32.tpr -o frame32.trr -x frame32.xtc -cpi state.cpt -cpt 15 -nt 1
15:28:50:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
15:28:50:WU00:FS00:0xa7:Saving result file frame32.trr
15:28:50:WU00:FS00:0xa7:Saving result file frame32.xtc
[93m15:28:51:WARNING:WU00:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)[0m
[93m15:28:51:WARNING:WU00:FS00:Fatal error, dumping[0m
15:28:51:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:16423 run:3495 clone:0 gen:32 core:0xa7 unit:0x0000002496880e6e5e8a8dc1c86b4d7e
15:28:51:WU00:FS00:Connecting to 150.136.14.110:8080
15:28:51:WU01:FS00:Connecting to 65.254.110.245:80
15:28:51:WU00:FS00:Server responded WORK_ACK (400)
15:28:51:WU00:FS00:Cleaning up
15:28:53:WU01:FS00:Assigned to work server 128.252.203.9
15:28:53:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 128.252.203.9
15:28:53:WU01:FS00:Connecting to 128.252.203.9:8080
[91m15:29:28:ERROR:WU01:FS00:Exception: Server did not assign work unit[0m
15:36:05:WU01:FS00:Connecting to 65.254.110.245:80
[93m15:36:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
15:36:05:WU01:FS00:Connecting to 18.218.241.186:80
[93m15:36:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
15:36:05:WU01:FS00:Assigned to work server 69.94.66.7
15:36:05:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 69.94.66.7
15:36:05:WU01:FS00:Connecting to 69.94.66.7:8080
[91m15:36:06:ERROR:WU01:FS00:Exception: Server did not assign work unit[0m
16:00:01:WU01:FS00:Connecting to 65.254.110.245:80
[93m16:00:02:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
16:00:02:WU01:FS00:Connecting to 18.218.241.186:80
[93m16:00:02:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
16:00:02:WU01:FS00:Connecting to 65.254.110.245:80
16:00:03:WU01:FS00:Assigned to work server 40.114.52.201
16:00:03:WU01:FS00:Requesting new work unit for slot 00: PAUSED cpu:1 (waiting for idle) from 40.114.52.201
16:00:03:WU01:FS00:Connecting to 40.114.52.201:8080
[91m16:00:04:ERROR:WU01:FS00:Exception: Server did not assign work unit[0m
16:14:50:WU01:FS00:Connecting to 65.254.110.245:80
[93m16:14:50:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
16:14:50:WU01:FS00:Connecting to 18.218.241.186:80
[93m16:14:50:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[93m16:14:51:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
16:14:51:WU01:FS00:Connecting to 18.218.241.186:80
[93m16:14:51:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
[91m16:14:51:ERROR:WU01:FS00:Exception: Could not get an assignment[0m
16:17:27:WU01:FS00:Connecting to 65.254.110.245:80
[93m16:17:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration[0m
16:17:27:WU01:FS00:Connecting to 18.218.241.186:80
[93m16:17:27:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration[0m
16:17:28:WU01:FS00:Assigned to work server 155.247.164.214
16:17:28:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 155.247.164.214
16:17:28:WU01:FS00:Connecting to 155.247.164.214:8080
16:17:30:WU01:FS00:Downloading 2.81MiB
16:17:37:WU01:FS00:Download 55.55%
14:05:12:32:127.0.0.1:New Web session
14:07:57:Saving configuration to config.xml
14:07:57:<config>
14:07:57:  <!-- Folding Slot Configuration -->
14:07:57:  <cause v='COVID_19'/>
14:07:57:
14:07:57:  <!-- User Information -->
14:07:57:  <passkey v='*****'/>
14:07:57:  <team v='240260'/>
14:07:57:  <user v='PaulMpls'/>
14:07:57:
14:07:57:  <!-- Folding Slots -->
14:07:57:  <slot id='0' type='CPU'/>
14:07:57:</config>
10:48:52:59:127.0.0.1:New Web session
13:48:39:234:127.0.0.1:New Web session
13:49:50:Saving configuration to config.xml
13:49:50:<config>
13:49:50:  <!-- Folding Slot Configuration -->
13:49:50:  <cause v='COVID_19'/>
13:49:50:
13:49:50:  <!-- Slot Control -->
13:49:50:  <power v='medium'/>
13:49:50:
13:49:50:  <!-- User Information -->
13:49:50:  <passkey v='*****'/>
13:49:50:  <team v='240260'/>
13:49:50:  <user v='PaulMpls'/>
13:49:50:
13:49:50:  <!-- Folding Slots -->
13:49:50:  <slot id='0' type='CPU'/>
13:49:50:</config>
17:51:35:255:127.0.0.1:New Web session
Okay, from what I am seeing ion the log it appears to be set to fold "On Idle" and is being frequently interrupted. The system also appears to be set to sleep as well when not actively being used. The macOS does not consider the F@h client running in the background to be "active use". The client also considers this to be in the "laptop" class, the default setting is Light, otherwise the change to Medium would not have shown in the log at the end.
So there are a number of pauses in folding, followed by it resuming. Usually that would be after a few minutes of inactivity, but here is about 15 seconds. If not automatic, were you manually stopping and starting? If automatic, a timer value may be set incorrectly in the client somewhere.
Here would be consistent with a laptop either going to sleep due to inactivity or being closed up to be moved around:
The next time though at 15:28, the core processing woke up and then went into "stalled" processing. It appears some file from the checkpoint was missing or had been corrupted in some way, and the restart failed:
Now to why you haven't seen another WU yet, you have run into a bug in the network code that sometimes results in the client not detecting that a download or upload has stopped. It usually does detect this and retries after within about 15-30 minutes:
Your system was connected to a server, the download went to 55%, and that is it.
To get this going again, the FAHClient process needs to be restarted. Easiest way is by rebooting your Mac.
Some suggestions on your configuration would be to set the folding on a steady 2 cores, part of the delay in getting a new assignment may have been a limited number of WUs from projects that will assign to a single CPU core. Second would be to take off the On Idle setting, and disable sleep on inactivity when connected to power.
Manually pausing folding before closing up your laptop or shutting down can help avoid the checkpoint getting messed up. Depending on the speed of the processor and the drive, that can take 15-30 seconds to write out the checkpoint.
PaulMpls
Post by PaulMpls »
I tried the suggestions, but couldn't get it to work. I uninstalled the FAH client on the Mac and will just use it on my Windows machine. Thanks.
