Number of snapshots in viewer
iceman1992
Post by iceman1992 »
How many snapshots are taken? Are they different per project?
Because I usually see a constant 4.0 snapshots, but now I'm seeing for project 16433 the number of snapshots keep increasing as it progresses. Now up to 264 snapshots.
Re: Number of snapshots in viewer
I think that the number of snapshots are dependent on the Project and FahCore. Can't remember exactly what it is.
iceman1992
I like that this one shows so many snapshots. Is there a way to export the snapshots?
I have a vague recollection that you might be able to but those file sizes might be large...
If you look in the work folder for the running WU, there will be a series of .json files for the viewer. Once copied out, not sure how you would get the viewer to display them, but the needed information is in those files.
