Wierd one, I have 7.6.9 installed under Win8.1
Installed, ran perfectly fine after installing.
After a reboot I am stuck at "Connecting" to 127.0.0.1
Firewall rules should be OK, although I only allowed FAQClient
if I need a firewall rule, what component needs it?
Unable to connect?
Re: Unable to connect?
Can you please post the log file? You should be able to get to it from %AppData%\FAHClient if you chose the default values.
Additional information is here if needed: viewtopic.php?f=108&t=26036
