I got a new laptop a few days ago with a RTX 2070 Super installed, but GPUs.txt isn't finding it. Appears to be a 1E91, which is different than the devices discussed in other threads.
Would it be possible to add this one please?
FYI - I tried to fix it by installing the Beta version and also by downloading and replacing the GPUs.txt file, but neither method worked and F@H still isn't recognizing it.
Thanks!
[Note: First post so I can't post URLs. I'll post a screenshot of GPU-Z as a follow-up]
Please whitelist a new version of RTX 2070 Super
Re: Please whitelist a new version of RTX 2070 Super
As mentioned above, it appears to be a 1E91, which is different than the devices discussed at viewtopic.php?f=83&t=31714.
Thank you!
Thank you!
Yes these 2 mobile GPUs are missing, please whitelist.
10de 1e91 TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
10de 1e93 TU104M [GeForce RTX 2080 SUPER Mobile / Max-Q]
https://devicehunt.com/view/type/pci/ve ... evice/1C31
Thank you! I just loaded the new GPUs.txt file and it found the 2070 without a problem.bruce wrote:Done
