Hello,
Whenever I try to access the web control, it keeps refreshing. Is there a known fix?
Thank you.
Can't Access the Web Control
Re: Can't Access the Web Control
Depends on which version of the F@h client you are running. With 7.5.1 this is a known problem with Chrome and Chromium based browsers, there are some workarounds posted as item #7 in this FAQ - viewtopic.php?f=61&t=32463#p312879.
Some fixes have been put into the recent release of the client 7.6.9. I don't use Chrome, so don't know how well those fixes work.
Welcome to the F@H Forum SickNameDude,
Do you know what client version you're running? The log files will have the information and here's how you can get to it: viewtopic.php?f=24&t=26036
There was an issue with Web Control in V7.5.X and a workaround is present, see point 7 here: viewtopic.php?f=61&t=32463
However, a new version 7.6.9 has been published which fixes this issue: viewtopic.php?f=24&t=34466
