Folding.ExtremeOverclocking.com is down?
Did the stat site go down for some reason? I tried to check yesterday, and I can't reach it.
Re: Folding.ExtremeOverclocking.com is down?
Never mind. It was just me. I rebooted and the site worked fine for me. Stupid computer.
EOC appears to be up now, and the few times I checked yesterday it was up. I don't see any announcement newer than a week ago from the guy who runs the site, so my guess is there may have been a temporary outage.
- Hardware configuration: AMD 5700x, Asus Prime X570-Pro, EVGA 3080 12gb, G.SKILL Aegis 16GB DDR4 3200, Windows 10
I have trouble connecting depending on which vpn server I am connected to.
The site has not been reachable for a few days!
Anyone have information on this?
I have had absolutely no problems connecting to EOC over the last few days. So I would assume the problem is somewhere between your system and EOC.famasoft wrote:The site has not been reachable for a few days!
Since yesterday morning I have not been able to access the site from either the Desktop PC or the Notebook, even using different browsers. I have not made updates, I have changes to either PC and I have only worked with PDF and Excel files. I thought that the server had some problems as happened in the past but if you confirm that you can access it, it worries me a little.I have had absolutely no problems connecting to EOC over the last few days. So I would assume the problem is somewhere between your system and EOC.
- Hardware configuration: 2 iMacs and 1 dedicated Windows 10 Pro rig with 1 RTX 2070 Super and 1 RTX 2060 KO
As @skydivingcatfan noted, the only time I have had a problem connecting to EOC is when I have been using a VPN Server.
I can tell you the current numbers: Active users is still down to 50000 but points is up again to 32 billion PPD - cause of CUDA upgrade.
I don't use Proxy or VPN and I haven't updated or changed either of my PCs.Burlingtonian wrote:As @skydivingcatfan noted, the only time I have had a problem connecting to EOC is when I have been using a VPN Server.
Do you have any suggestions to overcome this problem?
(Sorry for my English)
The site is up. You can always check it at https://down.com/
Maybe restart your router? Flush your DNS?
Thanks for the tip!ajm wrote:The site is up. You can always check it at https://down.com/
I rebooted the router and I have access to EOC again.
Thanks also other users who answered me.
Good day everyone ...
Looks like they have blocked Russia.
https://ping-admin.com/free_test/result ... 3mr66.html
- Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w - Location: Russia
Not every proxy or VPN opens EOC from there.. this can't look good.
