starkruzr
Posts: 10 Joined: Sun Apr 19, 2020 3:36 am
Post
by starkruzr » Sat Apr 25, 2020 6:15 am
Has anyone tried this recently? You can fold on the CPU, but if you try on the GPU you get a bunch of these errors:
ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
This is after installing amdgpu-pro with sudo ./amdgpu-pro-install --opencl=legacy --no-dkms --headless. If I leave out --headless, gdm crashes and X doesn't work, and the tty that shows up flickers between the dmesg stream and the login. This is what I get in my logs:
06:10:39:WU01:FS00:0x22:*********************** Log Started 2020-04-25T06:10:38Z ***********************
06:10:39:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
06:10:39:WU01:FS00:0x22: Type: 0x22
06:10:39:WU01:FS00:0x22: Core: Core22
06:10:39:WU01:FS00:0x22: Website: https://foldingathome.org/
06:10:39:WU01:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:10:39:WU01:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:10:39:WU01:FS00:0x22: <rafal.wiewiora@choderalab.org>
06:10:39:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 704 -lifeline 1714 -checkpoint 15 -gpu
06:10:39:WU01:FS00:0x22: 0 -gpu-vendor ati
06:10:39:WU01:FS00:0x22: Config: <none>
06:10:39:WU01:FS00:0x22:************************************ Build *************************************
06:10:39:WU01:FS00:0x22: Version: 0.0.5
06:10:39:WU01:FS00:0x22: Date: Apr 22 2020
06:10:39:WU01:FS00:0x22: Time: 03:57:11
06:10:39:WU01:FS00:0x22: Repository: Git
06:10:39:WU01:FS00:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
06:10:39:WU01:FS00:0x22: Branch: HEAD
06:10:39:WU01:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
06:10:39:WU01:FS00:0x22: Options: -std=c++11 -O3 -funroll-loops
06:10:39:WU01:FS00:0x22: Platform: linux2 4.19.76-linuxkit
06:10:39:WU01:FS00:0x22: Bits: 64
06:10:39:WU01:FS00:0x22: Mode: Release
06:10:39:WU01:FS00:0x22:************************************ System ************************************
06:10:39:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
06:10:39:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
06:10:39:WU01:FS00:0x22: CPUs: 8
06:10:39:WU01:FS00:0x22: Memory: 15.52GiB
06:10:39:WU01:FS00:0x22:Free Memory: 14.32GiB
06:10:39:WU01:FS00:0x22: Threads: POSIX_THREADS
06:10:39:WU01:FS00:0x22: OS Version: 5.3
06:10:39:WU01:FS00:0x22:Has Battery: true
06:10:39:WU01:FS00:0x22: On Battery: false
06:10:39:WU01:FS00:0x22: UTC Offset: -4
06:10:39:WU01:FS00:0x22: PID: 1718
06:10:39:WU01:FS00:0x22: CWD: /var/lib/fahclient/work
06:10:39:WU01:FS00:0x22: OS: Linux 5.3.0-46-generic x86_64
06:10:39:WU01:FS00:0x22: OS Arch: AMD64
06:10:39:WU01:FS00:0x22:********************************************************************************
06:10:39:WU01:FS00:0x22:Project: 13400 (Run 25, Clone 26, Gen 1)
06:10:39:WU01:FS00:0x22:Unit: 0x0000000312bc7d9a5ea36f75e27fb880
06:10:39:WU01:FS00:0x22:Reading tar file core.xml
06:10:39:WU01:FS00:0x22:Reading tar file integrator.xml
06:10:39:WU01:FS00:0x22:Reading tar file state.xml
06:10:39:WU01:FS00:0x22:Reading tar file system.xml
06:10:40:WU01:FS00:0x22:Digital signatures verified
06:10:40:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
06:10:40:WU01:FS00:0x22:Version 0.0.5
06:10:50:WU01:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
06:10:50:WU01:FS00:0x22:Saving result file ../logfile_01.txt
06:10:50:WU01:FS00:0x22:Saving result file science.log
06:10:50:WU01:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
06:10:50:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:10:50:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13400 run:25 clone:26 gen:1 core:0x22 unit:0x0000000312bc7d9a5ea36f75e27fb880
06:10:50:WU01:FS00:Uploading 2.19KiB to 18.188.125.154
06:10:50:WU01:FS00:Connecting to 18.188.125.154:8080
06:10:50:WU01:FS00:Upload complete
06:10:51:WU01:FS00:Server responded WORK_ACK (400)
06:10:51:WU01:FS00:Cleaning up
06:10:51:WU02:FS00:Connecting to 65.254.110.245:80
06:10:51:WU02:FS00:Assigned to work server 18.188.125.154
06:10:51:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:[Radeon HD 8800M Series] from 18.188.125.154
06:10:51:WU02:FS00:Connecting to 18.188.125.154:8080
06:10:54:WU02:FS00:Downloading 9.84MiB
06:10:54:WU02:FS00:Download complete
06:10:54:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13400 run:119 clone:95 gen:0 core:0x22 unit:0x0000000312bc7d9a5ea3c3b8c8a62dc4
06:10:54:WU02:FS00:Starting
06:10:54:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 704 -lifeline 1681 -checkpoint 15 -gpu 0 -gpu-vendor ati
06:10:54:WU02:FS00:Started FahCore on PID 1729
06:10:54:WU02:FS00:Core PID:1733
06:10:54:WU02:FS00:FahCore 0x22 started
06:10:55:WU02:FS00:0x22:*********************** Log Started 2020-04-25T06:10:54Z ***********************
06:10:55:WU02:FS00:0x22:*************************** Core22 Folding@home Core ***************************
06:10:55:WU02:FS00:0x22: Type: 0x22
06:10:55:WU02:FS00:0x22: Core: Core22
06:10:55:WU02:FS00:0x22: Website: https://foldingathome.org/
06:10:55:WU02:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
06:10:55:WU02:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
06:10:55:WU02:FS00:0x22: <rafal.wiewiora@choderalab.org>
06:10:55:WU02:FS00:0x22: Args: -dir 02 -suffix 01 -version 704 -lifeline 1729 -checkpoint 15 -gpu
06:10:55:WU02:FS00:0x22: 0 -gpu-vendor ati
06:10:55:WU02:FS00:0x22: Config: <none>
06:10:55:WU02:FS00:0x22:************************************ Build *************************************
06:10:55:WU02:FS00:0x22: Version: 0.0.5
06:10:55:WU02:FS00:0x22: Date: Apr 22 2020
06:10:55:WU02:FS00:0x22: Time: 03:57:11
06:10:55:WU02:FS00:0x22: Repository: Git
06:10:55:WU02:FS00:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
06:10:55:WU02:FS00:0x22: Branch: HEAD
06:10:55:WU02:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
06:10:55:WU02:FS00:0x22: Options: -std=c++11 -O3 -funroll-loops
06:10:55:WU02:FS00:0x22: Platform: linux2 4.19.76-linuxkit
06:10:55:WU02:FS00:0x22: Bits: 64
06:10:55:WU02:FS00:0x22: Mode: Release
06:10:55:WU02:FS00:0x22:************************************ System ************************************
06:10:55:WU02:FS00:0x22: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
06:10:55:WU02:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
06:10:55:WU02:FS00:0x22: CPUs: 8
06:10:55:WU02:FS00:0x22: Memory: 15.52GiB
06:10:55:WU02:FS00:0x22:Free Memory: 14.26GiB
06:10:55:WU02:FS00:0x22: Threads: POSIX_THREADS
06:10:55:WU02:FS00:0x22: OS Version: 5.3
06:10:55:WU02:FS00:0x22:Has Battery: true
06:10:55:WU02:FS00:0x22: On Battery: false
06:10:55:WU02:FS00:0x22: UTC Offset: -4
06:10:55:WU02:FS00:0x22: PID: 1733
06:10:55:WU02:FS00:0x22: CWD: /var/lib/fahclient/work
06:10:55:WU02:FS00:0x22: OS: Linux 5.3.0-46-generic x86_64
06:10:55:WU02:FS00:0x22: OS Arch: AMD64
06:10:55:WU02:FS00:0x22:********************************************************************************
06:10:55:WU02:FS00:0x22:Project: 13400 (Run 119, Clone 95, Gen 0)
06:10:55:WU02:FS00:0x22:Unit: 0x0000000312bc7d9a5ea3c3b8c8a62dc4
06:10:55:WU02:FS00:0x22:Reading tar file core.xml
06:10:55:WU02:FS00:0x22:Reading tar file integrator.xml
06:10:55:WU02:FS00:0x22:Reading tar file state.xml
06:10:55:WU02:FS00:0x22:Reading tar file system.xml
06:10:56:WU02:FS00:0x22:Digital signatures verified
06:10:56:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
06:10:56:WU02:FS00:0x22:Version 0.0.5
06:11:06:WU02:FS00:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
06:11:06:WU02:FS00:0x22:Saving result file ../logfile_01.txt
06:11:06:WU02:FS00:0x22:Saving result file science.log
06:11:06:WU02:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
06:11:06:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:11:06:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:13400 run:119 clone:95 gen:0 core:0x22 unit:0x0000000312bc7d9a5ea3c3b8c8a62dc4
06:11:06:WU02:FS00:Uploading 2.19KiB to 18.188.125.154
06:11:06:WU02:FS00:Connecting to 18.188.125.154:8080
06:11:06:WU02:FS00:Upload complete
06:11:07:WU02:FS00:Server responded WORK_ACK (400)
06:11:07:WU02:FS00:Cleaning up
06:11:07:WU01:FS00:Connecting to 65.254.110.245:80
06:11:07:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': Empty work server assignment
06:11:07:WU01:FS00:Connecting to 18.218.241.186:80
06:11:07:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': Empty work server assignment
06:11:07:ERROR:WU01:FS00:Exception: Could not get an assignment
06:11:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': Empty work server assignment
06:11:08:ERROR:WU01:FS00:Exception: Could not get an assignment
06:11:11:WU00:FS01:0xa7:Completed 225000 out of 250000 steps (90%)
Does anyone know how to fix this?
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Sat Apr 25, 2020 7:19 am
FAH requires OpenCL to do the analysis. Apparently you still need to install that prerequisite.
The portion of the log that I'm most interested it is much earlier, near the very top. It shows the detection process of the GPU as well as your config.xml. After installing opencl, try restarting FAHClient and post the earlier part of the log.
ajm
Posts: 750 Joined: Sat Mar 21, 2020 5:22 am
Post
by ajm » Sat Apr 25, 2020 7:20 am
There is a workaround in viewtopic.php?f=81&t=33353#p318278
starkruzr
Post
by starkruzr » Sat Apr 25, 2020 8:12 am
bruce wrote: FAH requires OpenCL to do the analysis. Apparently you still need to install that prerequisite.
I tried the steps in ajm's workaround link below, and now things look like this. I even tried running it as root. Still gets "interrupted" like this.
*********************** Log Started 2020-04-25T08:08:09Z ***********************
08:08:09:************************* Folding@home Client *************************
08:08:09: Website: http://folding.stanford.edu/
08:08:09: Copyright: (c) 2009-2014 Stanford University
08:08:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:08:09: Args: --child --lifeline 3635 /etc/fahclient/config.xml
08:08:09: --pid-file=/var/run/fahclient/fahclient.pid --daemon
08:08:09: Config: /etc/fahclient/config.xml
08:08:09:******************************** Build ********************************
08:08:09: Version: 7.4.4
08:08:09: Date: Mar 4 2014
08:08:09: Time: 12:02:38
08:08:09: SVN Rev: 4130
08:08:09: Branch: fah/trunk/client
08:08:09: Compiler: GNU 4.4.7
08:08:09: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
08:08:09: -fno-unsafe-math-optimizations -msse2
08:08:09: Platform: linux2 3.2.0-1-amd64
08:08:09: Bits: 64
08:08:09: Mode: Release
08:08:09:******************************* System ********************************
08:08:09: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
08:08:09: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
08:08:09: CPUs: 8
08:08:09: Memory: 15.52GiB
08:08:09:Free Memory: 13.42GiB
08:08:09: Threads: POSIX_THREADS
08:08:09: OS Version: 5.3
08:08:09:Has Battery: true
08:08:09: On Battery: false
08:08:09: UTC Offset: -4
08:08:09: PID: 3641
08:08:09: CWD: /root
08:08:09: OS: Linux 5.3.0-46-generic x86_64
08:08:09: OS Arch: AMD64
08:08:09: GPUs: 1
08:08:09: GPU 0: ATI:5 [Radeon HD 8800M Series]
08:08:09: CUDA: Not detected
08:08:09:***********************************************************************
08:08:09:<config>
08:08:09: <!-- HTTP Server -->
08:08:09: <allow v='192.168.9.0/24'/>
08:08:09:
08:08:09: <!-- Network -->
08:08:09: <proxy v=':8080'/>
08:08:09:
08:08:09: <!-- Remote Command Server -->
08:08:09: <command-allow-no-pass v='127.0.0.1 192.168.9.0/24'/>
08:08:09:
08:08:09: <!-- Slot Control -->
08:08:09: <power v='full'/>
08:08:09:
08:08:09: <!-- User Information -->
08:08:09: <passkey v='********************************'/>
08:08:09: <team v='number'/>
08:08:09: <user v='user'/>
08:08:09:
08:08:09: <!-- Web Server -->
08:08:09: <web-allow v='192.168.9.0/24'/>
08:08:09:
08:08:09: <!-- Folding Slots -->
08:08:09: <slot id='0' type='GPU'/>
08:08:09: <slot id='1' type='CPU'/>
08:08:09:</config>
08:08:09:Trying to access database...
08:08:09:Successfully acquired database lock
08:08:09:Enabled folding slot 00: READY gpu:0:[Radeon HD 8800M Series]
08:08:09:Enabled folding slot 01: READY cpu:7
08:08:09:WU01:FS01:Starting
08:08:09:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /root/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 3641 -checkpoint 15 -np 7
08:08:09:WU01:FS01:Started FahCore on PID 3650
08:08:09:WU01:FS01:Core PID:3654
08:08:09:WU01:FS01:FahCore 0xa7 started
08:08:09:WU00:FS00:Starting
08:08:09:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /root/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 704 -lifeline 3641 -checkpoint 15 -gpu 0 -gpu-vendor ati
08:08:09:WU00:FS00:Started FahCore on PID 3658
08:08:09:WU00:FS00:Core PID:3662
08:08:09:WU00:FS00:FahCore 0x22 started
08:08:10:WU01:FS01:0xa7:*********************** Log Started 2020-04-25T08:08:09Z ***********************
08:08:10:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
08:08:10:WU01:FS01:0xa7: Type: 0xa7
08:08:10:WU01:FS01:0xa7: Core: Gromacs
08:08:10:WU01:FS01:0xa7: Args: -dir 01 -suffix 01 -version 704 -lifeline 3650 -checkpoint 15 -np 7
08:08:10:WU01:FS01:0xa7:************************************ CBang *************************************
08:08:10:WU01:FS01:0xa7: Date: Nov 5 2019
08:08:10:WU01:FS01:0xa7: Time: 06:06:57
08:08:10:WU01:FS01:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:08:10:WU01:FS01:0xa7: Branch: master
08:08:10:WU01:FS01:0xa7: Compiler: GNU 8.3.0
08:08:10:WU01:FS01:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:08:10:WU01:FS01:0xa7: Platform: linux2 4.19.0-5-amd64
08:08:10:WU01:FS01:0xa7: Bits: 64
08:08:10:WU01:FS01:0xa7: Mode: Release
08:08:10:WU01:FS01:0xa7:************************************ System ************************************
08:08:10:WU01:FS01:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
08:08:10:WU01:FS01:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
08:08:10:WU01:FS01:0xa7: CPUs: 8
08:08:10:WU01:FS01:0xa7: Memory: 15.52GiB
08:08:10:WU01:FS01:0xa7:Free Memory: 13.42GiB
08:08:10:WU01:FS01:0xa7: Threads: POSIX_THREADS
08:08:10:WU01:FS01:0xa7: OS Version: 5.3
08:08:10:WU01:FS01:0xa7:Has Battery: true
08:08:10:WU01:FS01:0xa7: On Battery: false
08:08:10:WU01:FS01:0xa7: UTC Offset: -4
08:08:10:WU01:FS01:0xa7: PID: 3654
08:08:10:WU01:FS01:0xa7: CWD: /root/work
08:08:10:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
08:08:10:WU01:FS01:0xa7: Version: 0.0.18
08:08:10:WU01:FS01:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:08:10:WU01:FS01:0xa7: Copyright: 2019 foldingathome.org
08:08:10:WU01:FS01:0xa7: Homepage: https://foldingathome.org/
08:08:10:WU01:FS01:0xa7: Time: 06:13:26
08:08:10:WU01:FS01:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:08:10:WU01:FS01:0xa7:************************************ Build *************************************
08:08:10:WU01:FS01:0xa7: SIMD: avx_256
08:08:10:WU01:FS01:0xa7:********************************************************************************
08:08:10:WU01:FS01:0xa7:Project: 14616 (Run 1600, Clone 3, Gen 62)
08:08:10:WU01:FS01:0xa7:Unit: 0x000000439bf7a4d65e8323b023214944
08:08:10:WU01:FS01:0xa7:Digital signatures verified
08:08:10:WU01:FS01:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
08:08:10:WU01:FS01:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -cpi state.cpt -cpt 15 -nt 6
08:08:10:WU01:FS01:0xa7:Steps: first=0 total=250000
08:08:10:WU00:FS00:0x22:*********************** Log Started 2020-04-25T08:08:09Z ***********************
08:08:10:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
08:08:10:WU00:FS00:0x22: Type: 0x22
08:08:10:WU00:FS00:0x22: Core: Core22
08:08:10:WU00:FS00:0x22: Website: https://foldingathome.org/
08:08:10:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
08:08:10:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:08:10:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
08:08:10:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 704 -lifeline 3658 -checkpoint 15 -gpu
08:08:10:WU00:FS00:0x22: 0 -gpu-vendor ati
08:08:10:WU00:FS00:0x22: Config: <none>
08:08:10:WU00:FS00:0x22:************************************ Build *************************************
08:08:10:WU00:FS00:0x22: Version: 0.0.5
08:08:10:WU00:FS00:0x22: Date: Apr 22 2020
08:08:10:WU00:FS00:0x22: Time: 03:57:11
08:08:10:WU00:FS00:0x22: Repository: Git
08:08:10:WU00:FS00:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
08:08:10:WU00:FS00:0x22: Branch: HEAD
08:08:10:WU00:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:08:10:WU00:FS00:0x22: Options: -std=c++11 -O3 -funroll-loops
08:08:10:WU00:FS00:0x22: Platform: linux2 4.19.76-linuxkit
08:08:10:WU00:FS00:0x22: Bits: 64
08:08:10:WU00:FS00:0x22: Mode: Release
08:08:10:WU00:FS00:0x22:************************************ System ************************************
08:08:10:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
08:08:10:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
08:08:10:WU00:FS00:0x22: CPUs: 8
08:08:10:WU00:FS00:0x22: Memory: 15.52GiB
08:08:10:WU00:FS00:0x22:Free Memory: 13.41GiB
08:08:10:WU00:FS00:0x22: Threads: POSIX_THREADS
08:08:10:WU00:FS00:0x22: OS Version: 5.3
08:08:10:WU00:FS00:0x22:Has Battery: true
08:08:10:WU00:FS00:0x22: On Battery: false
08:08:10:WU00:FS00:0x22: UTC Offset: -4
08:08:10:WU00:FS00:0x22: PID: 3662
08:08:10:WU00:FS00:0x22: CWD: /root/work
08:08:10:WU00:FS00:0x22: OS: Linux 5.3.0-46-generic x86_64
08:08:10:WU00:FS00:0x22: OS Arch: AMD64
08:08:10:WU00:FS00:0x22:********************************************************************************
08:08:10:WU00:FS00:0x22:Project: 13400 (Run 12, Clone 16, Gen 1)
08:08:10:WU00:FS00:0x22:Unit: 0x0000000412bc7d9a5ea35ec131a2849c
08:08:10:WU00:FS00:0x22:Reading tar file core.xml
08:08:10:WU00:FS00:0x22:Reading tar file integrator.xml
08:08:10:WU00:FS00:0x22:Reading tar file state.xml
08:08:10:WU00:FS00:0x22:Reading tar file system.xml
08:08:10:WU00:FS00:0x22:Digital signatures verified
08:08:10:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
08:08:10:WU00:FS00:0x22:Version 0.0.5
08:08:10:WU01:FS01:0xa7:Completed 4784 out of 250000 steps (1%)
08:08:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:08:11:WU00:FS00:Starting
08:08:11:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /root/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 704 -lifeline 3641 -checkpoint 15 -gpu 0 -gpu-vendor ati
08:08:11:WU00:FS00:Started FahCore on PID 3671
08:08:11:WU00:FS00:Core PID:3675
08:08:11:WU00:FS00:FahCore 0x22 started
08:08:11:WU00:FS00:0x22:*********************** Log Started 2020-04-25T08:08:11Z ***********************
08:08:11:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
08:08:11:WU00:FS00:0x22: Type: 0x22
08:08:11:WU00:FS00:0x22: Core: Core22
08:08:11:WU00:FS00:0x22: Website: https://foldingathome.org/
08:08:11:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
08:08:11:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:08:11:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
08:08:11:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 704 -lifeline 3671 -checkpoint 15 -gpu
08:08:11:WU00:FS00:0x22: 0 -gpu-vendor ati
08:08:11:WU00:FS00:0x22: Config: <none>
08:08:11:WU00:FS00:0x22:************************************ Build *************************************
08:08:11:WU00:FS00:0x22: Version: 0.0.5
08:08:11:WU00:FS00:0x22: Date: Apr 22 2020
08:08:11:WU00:FS00:0x22: Time: 03:57:11
08:08:11:WU00:FS00:0x22: Repository: Git
08:08:11:WU00:FS00:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
08:08:11:WU00:FS00:0x22: Branch: HEAD
08:08:11:WU00:FS00:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
08:08:11:WU00:FS00:0x22: Options: -std=c++11 -O3 -funroll-loops
08:08:11:WU00:FS00:0x22: Platform: linux2 4.19.76-linuxkit
08:08:11:WU00:FS00:0x22: Bits: 64
08:08:11:WU00:FS00:0x22: Mode: Release
08:08:11:WU00:FS00:0x22:************************************ System ************************************
08:08:11:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
08:08:11:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
08:08:11:WU00:FS00:0x22: CPUs: 8
08:08:11:WU00:FS00:0x22: Memory: 15.52GiB
08:08:11:WU00:FS00:0x22:Free Memory: 13.33GiB
08:08:11:WU00:FS00:0x22: Threads: POSIX_THREADS
08:08:11:WU00:FS00:0x22: OS Version: 5.3
08:08:11:WU00:FS00:0x22:Has Battery: true
08:08:11:WU00:FS00:0x22: On Battery: false
08:08:11:WU00:FS00:0x22: UTC Offset: -4
08:08:11:WU00:FS00:0x22: PID: 3675
08:08:11:WU00:FS00:0x22: CWD: /root/work
08:08:11:WU00:FS00:0x22: OS: Linux 5.3.0-46-generic x86_64
08:08:11:WU00:FS00:0x22: OS Arch: AMD64
08:08:11:WU00:FS00:0x22:********************************************************************************
08:08:11:WU00:FS00:0x22:Project: 13400 (Run 12, Clone 16, Gen 1)
08:08:11:WU00:FS00:0x22:Unit: 0x0000000412bc7d9a5ea35ec131a2849c
08:08:11:WU00:FS00:0x22:Reading tar file core.xml
08:08:11:WU00:FS00:0x22:Reading tar file integrator.xml
08:08:11:WU00:FS00:0x22:Reading tar file state.xml
08:08:11:WU00:FS00:0x22:Reading tar file system.xml
08:08:12:WU00:FS00:0x22:Digital signatures verified
08:08:12:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
08:08:12:WU00:FS00:0x22:Version 0.0.5
08:08:12:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:08:09: Bits: 64
08:08:09: CPUs: 8
08:08:09: PID: 3641
08:08:09: GPUs: 1
08:08:09:<config>
08:08:09:
08:08:09:
08:08:09:
08:08:09:
08:08:09:
08:08:09:
08:08:09:</config>
08:08:18:WU01:FS01:0xa7:Completed 5000 out of 250000 steps (2%)
ajm
Post
by ajm » Sat Apr 25, 2020 8:34 am
I installed AMD drivers with
./amdgpu-pro-install -y --opencl=pal,legacy --headless
as provided here:
https://amdgpu-install.readthedocs.io/e ... ro-variant
And I do have to run it as root (it's a dedicated folding rig). But it's been working flawlessly for a week now.
Unrelated, but you should edit your CPU slot: 7 is not a good number of threads.
starkruzr
Post
by starkruzr » Sat Apr 25, 2020 8:39 am
ajm wrote: I installed AMD drivers with
as provided here:
Yes, that headless option was actually the first thing I tried when just "pal,legacy" didn't work. Still no go.
ajm
Post
by ajm » Sat Apr 25, 2020 8:44 am
In the install code, I don't have the --no-dkms
EDIT: the AMD package contains
amdgpu-dkms_5.4.7.53-1048554_all.deb
amdgpu-dkms-firmware_5.4.7.53-1048554_all.deb
And I changed something in the workaround too (not mine, btw). In /etc/systemd/system/FAHClient.service, I directly replaced the user (User=fahclient) with root.
starkruzr
Post
by starkruzr » Sat Apr 25, 2020 10:02 pm
ajm wrote: In the install code, I don't have the --no-dkms
Just changed my configuration to how you describe here; still getting the "interrupted" messages.
ETA: clinfo output
jtd@Fornacis ~ % sudo /opt/amdgpu-pro/bin/clinfo
Number of platforms: 1
Platform Profile: FULL_PROFILE
Platform Version: OpenCL 2.1 AMD-APP (3075.10)
Platform Name: AMD Accelerated Parallel Processing
Platform Vendor: Advanced Micro Devices, Inc.
Platform Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Number of devices: 1
Device Type: CL_DEVICE_TYPE_GPU
Vendor ID: 1002h
Board name: AMD Radeon R9 (TM) M370X
Device Topology: PCI[ B#1, D#0, F#0 ]
Max compute units: 5
Max work items dimensions: 3
Max work items[0]: 1024
Max work items[1]: 1024
Max work items[2]: 1024
Max work group size: 256
Preferred vector width char: 4
Preferred vector width short: 2
Preferred vector width int: 1
Preferred vector width long: 1
Preferred vector width float: 1
Preferred vector width double: 1
Native vector width char: 4
Native vector width short: 2
Native vector width int: 1
Native vector width long: 1
Native vector width float: 1
Native vector width double: 1
Max clock frequency: 800Mhz
Address bits: 32
Max memory allocation: 1418435174
Image support: Yes
Max number of images read arguments: 128
Max number of images write arguments: 8
Max image 2D width: 16384
Max image 2D height: 16384
Max image 3D width: 2048
Max image 3D height: 2048
Max image 3D depth: 2048
Max samplers within kernel: 16
Max size of kernel argument: 1024
Alignment (bits) of base address: 2048
Minimum alignment (bytes) for any datatype: 128
Single precision floating point capability
Denorms: No
Quiet NaNs: Yes
Round to nearest even: Yes
Round to zero: Yes
Round to +ve and infinity: Yes
IEEE754-2008 fused multiply-add: Yes
Cache type: Read/Write
Cache line size: 64
Cache size: 16384
Global memory size: 1892823040
Constant buffer size: 65536
Max number of constant args: 8
Local memory type: Scratchpad
Local memory size: 32768
Max pipe arguments: 0
Max pipe active reservations: 0
Max pipe packet size: 0
Max global variable size: 0
Max global variable preferred total size: 0
Max read/write image args: 0
Max on device events: 0
Queue on device max size: 0
Max on device queues: 0
Queue on device preferred size: 0
SVM capabilities:
Coarse grain buffer: No
Fine grain buffer: No
Fine grain system: No
Atomics: No
Preferred platform atomic alignment: 0
Preferred global atomic alignment: 0
Preferred local atomic alignment: 0
Kernel Preferred work group size multiple: 64
Error correction support: 0
Unified memory for Host and Device: 0
Profiling timer resolution: 1
Device endianess: Little
Available: Yes
Compiler available: Yes
Execution capabilities:
Execute OpenCL kernels: Yes
Execute native function: No
Queue on Host properties:
Out-of-Order: No
Profiling : Yes
Queue on Device properties:
Out-of-Order: No
Profiling : No
Platform ID: 0x7f50e8c40e50
Device OpenCL C version: OpenCL C 1.2
Driver version: 3075.10
Version: OpenCL 1.2 AMD-APP (3075.10)
Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_spir cl_khr_gl_event
ajm
Post
by ajm » Sun Apr 26, 2020 4:57 am
From your log above:
From clinfo:
Isn't that odd?
Posts: 8362 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Sun Apr 26, 2020 5:44 am
Nothing odd about it when dealing with AMD GPUs. The entry in the GPUs.txt file that is used for the description in the log file is based on device ID. AMD uses the same device ID for the same chip used in a multiple of applications at times.
clinfo is reading the "Board name" from somewhere else in the ROM on the card than a device ID. Wherever that is located, it is not what the folding client uses to determine whether a GPU can be used or not.
Post
by bruce » Sun Apr 26, 2020 6:23 am
To run FAHCore_22, a GPU must support FP64 (Double Precision) operations. This GPU does not. Unfortunately that means you won't be able to fold with the GPU.
Somewhere along the line you should have gotten a "GPU not supported message" or you might have been assigned another project but apparently you didn't. I'll check into that so others are informed earlier.
ajm
Post
by ajm » Sun Apr 26, 2020 6:33 am
ajm
Post
by ajm » Sun Apr 26, 2020 6:40 am
If the GPU has double precision:
@ starkruzr: did you recreate the GPU slot after the change in the config?
I would first check the Configure -> Expert section in Fahcontrol. If there is anything there (eg GPU:false), I would delete it (or change it to true as the case may be). Then delete the GPU slot, then stop the service. Then to be really safe, I would have a look at /etc/fahclient/config.xml (that also stores the Expert section codes) to see whether everything looks fine (it must not have <gpu value="false"/>) . Then start the service and add a GPU slot manually.
